  4. Sonnof Adapter hat ständig Warnungen
25 Beiträge 7 Kommentatoren 2.7k Aufrufe 5 Beobachtet
  • teletapiT teletapi
    @teletapi ```
    Skript v.2023-06-20
    *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer
            Machine ID: a9f1eae0dc5a48ddbf0e2a62c2227673
               Boot ID: 5cce62b81695480fbfbda66850260622
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     19:54:38 up 10:22,  1 user,  load average: 0.22, 0.56, 0.83
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=39.9'C
    volt=0.9460V
    *** Time and Time Zones ***
                   Local time: Sat 2023-09-30 19:54:39 CEST
               Universal time: Sat 2023-09-30 17:54:39 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            7.8G        2.9G        3.3G        1.0M        1.6G        4.8G
    Swap:            99M          0B         99M
    Total:          7.9G        2.9G        3.4G
             7811 M total memory
             2875 M used memory
             3711 M active memory
              607 M inactive memory
             3307 M free memory
              130 M buffer memory
             1498 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4       59G  9.7G   47G  18% /
    devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
    /dev/sda1      vfat      255M   31M  225M  13% /boot
    tmpfs          tmpfs     782M   16K  782M   1% /run/user/1000
    [Sat Sep 30 09:32:14 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:13:A5:D1 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=2c0392e1-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Sat Sep 30 09:32:16 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Sat Sep 30 09:32:16 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Sat Sep 30 09:32:17 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
    TARGET  SOURCE    FSTYPE OPTIONS
    /       /dev/sda2 ext4   rw,noatime
    `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.8G    /var/
    1.1G    /var/log/journal/a9f1eae0dc5a48ddbf0e2a62c2227673
    1.1G    /var/log
    511M    /var/lib
    Archived and active journals take up 1.0G in the file system.
    /opt/iobroker/backups:
    1.1G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    361M    /opt/iobroker/iobroker-data/
    181M    /opt/iobroker/iobroker-data/files
    71M     /opt/iobroker/iobroker-data/backup-objects
    62M     /opt/iobroker/iobroker-data/node-red/node_modules
    37M     /opt/iobroker/iobroker-data/objects.jsonl
    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.9aab3e1f.js.map
    8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
    8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.9aab3e1f.js
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.18.0
    /usr/bin/node           v18.18.0
    /usr/bin/npm            9.8.1
    /usr/bin/npx            9.8.1
    nodejs:
      Installed: 18.18.0-1nodesource1
      Candidate: 18.18.0-1nodesource1
      Version table:
     *** 18.18.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u4 500
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    No configuration change needed.
    Multihost discovery server: disabled
    Discovery authentication:   enabled
    Persistent activation:      disabled
    Objects:                    jsonl on 127.0.0.1
    States:                     jsonl on 127.0.0.1
    Core adapters versions
    js-controller:  5.0.12
    admin:          6.10.4
    javascript:     7.1.4
    Adapters from github:   2
    Adapter State
    + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
      system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
    + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
    + system.adapter.energiefluss.1           : energiefluss          : iobroker                                 -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 18701
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 12001
    + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 12010
    + system.adapter.hm-rpc.3                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hue-extended.0           : hue-extended          : iobroker                                 -  enabled
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
    + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      system.adapter.modbus.0                 : modbus                : iobroker                                 - disabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
    + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
    + system.adapter.nuki.0                   : nuki                  : iobroker                                 -  enabled
    + system.adapter.opendtu.0                : opendtu               : iobroker                                 -  enabled
    + system.adapter.panasonic-viera.0        : panasonic-viera       : iobroker                                 -  enabled
    + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 192.168.178.82, run as: admin
      system.adapter.smartmeter.0             : smartmeter            : iobroker                                 - disabled
      system.adapter.smartmeter.1             : smartmeter            : iobroker                                 - disabled
    + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): beta
    Installed ioBroker-Instances
    Used repository: beta
    Adapter    "admin"        : 6.10.4   , installed 6.10.4
    Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "backitup"     : 2.8.2    , installed 2.8.2
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "discovery"    : 4.1.0    , installed 4.1.0
    Adapter    "fritzdect"    : 2.4.1    , installed 2.4.1
    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
    Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.9-beta.3
    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
    Controller "js-controller": 5.0.12   , installed 5.0.12
    Adapter    "modbus"       : 5.0.11   , installed 5.0.11
    Adapter    "mqtt"         : 5.0.0    , installed 5.0.0
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "node-red"     : 4.0.3    , installed 4.0.3
    Adapter    "nuki"         : 1.6.0    , installed 1.6.0
    Adapter    "opendtu"      : 0.1.8    , installed 0.1.8
    Adapter    "panasonic-viera": 2.0.0  , installed 2.0.0
    Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
    Adapter    "socketio"     : 6.5.6    , installed 6.5.6
    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
    Adapter    "telegram"     : 1.16.0   , installed 1.16.0
    Adapter    "web"          : 6.1.3    , installed 6.1.3
    Adapter    "ws"           : 2.5.6    , installed 2.5.6
    Objects and States
    Objects:        9645
    States:         8963
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:5 https://repos.influxdata.com/debian stable InRelease
    Hit:6 https://apt.grafana.com stable InRelease
    Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 1
    *** Listening Ports ***
    tcp        0      0 192.168.178.82:8087     0.0.0.0:*               LISTEN      1001       24790      2163/io.simple-api.
    tcp        0      0 192.168.178.82:12001    0.0.0.0:*               LISTEN      1001       17735      1337/io.hm-rpc.1
    tcp        0      0 192.168.178.82:12010    0.0.0.0:*               LISTEN      1001       18890      1360/io.hm-rpc.2
    tcp        0      0 192.168.178.82:18701    0.0.0.0:*               LISTEN      1001       15591      1310/io.hm-rpc.0
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          14092      540/cupsd
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       3986       654/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15240      654/iobroker.js-con
    tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       1529196    88470/io.sonoff.0
    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       17026      1239/node-red
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      116        13041      568/mosquitto
    tcp        0      0 192.168.178.82:2001     0.0.0.0:*               LISTEN      1001       19037      1415/io.hm-rpc.3
    tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       20458      1820/io.jarvis.0
    tcp        0      0 192.168.178.82:9092     0.0.0.0:*               LISTEN      1001       24068      2020/io.nuki.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14073      572/sshd: /usr/sbin
    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       24135      2315/io.socketio.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        14121      549/influxd
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15443      1055/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       19700      1643/io.web.0
    tcp6       0      0 :::3000                 :::*                    LISTEN      117        15416      653/grafana
    tcp6       0      0 :::1883                 :::*                    LISTEN      116        13042      568/mosquitto
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          14091      540/cupsd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          14075      572/sshd: /usr/sbin
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13123      457/dhcpcd
    udp        0      0 0.0.0.0:45674           0.0.0.0:*                           108        14965      401/avahi-daemon: r
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          15175      630/cups-browsed
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14963      401/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          14145      457/dhcpcd
    udp6       0      0 :::54331                :::*                                108        14966      401/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        14964      401/avahi-daemon: r
    2023-09-30 19:30:00.172  - info: host.iobroker instance system.adapter.ical.0 started with pid 96578
    2023-09-30 19:30:09.741  - info: ical.0 (96578) Terminated (NO_ERROR): Without reason
    2023-09-30 19:30:10.286  - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
    2023-09-30 19:31:42.572  - info: nuki.0 (2020) status change received for NukiID 790083444: unlocked
    2023-09-30 19:31:42.573  - info: nuki.0 (2020) battery status received for NukiID 790083444: false
    2023-09-30 19:32:03.027  - info: nuki.0 (2020) status change received for NukiID 790083444: unlocked
    2023-09-30 19:32:03.028  - info: nuki.0 (2020) battery status received for NukiID 790083444: false
    2023-09-30 19:33:14.175  - info: nuki.0 (2020) status change received for NukiID 790083444: unlocked
    2023-09-30 19:33:14.176  - info: nuki.0 (2020) battery status received for NukiID 790083444: false
    2023-09-30 19:33:34.878  - info: nuki.0 (2020) status change received for NukiID 790083444: unlocked
    2023-09-30 19:33:34.879  - info: nuki.0 (2020) battery status received for NukiID 790083444: false
    2023-09-30 19:54:21.440  - info: nuki.0 (2020) status change received for NukiID 790083444: locking
    2023-09-30 19:54:21.441  - info: nuki.0 (2020) battery status received for NukiID 790083444: false
    2023-09-30 19:54:41.344  - info: nuki.0 (2020) status change received for NukiID 790083444: unlocked
    2023-09-30 19:54:41.345  - info: nuki.0 (2020) battery status received for NukiID 790083444: false
    2023-09-30 19:55:01.853  - info: nuki.0 (2020) status change received for NukiID 790083444: unlocked
    2023-09-30 19:55:01.854  - info: nuki.0 (2020) battery status received for NukiID 790083444: false
    2023-09-30 19:55:22.003  - info: nuki.0 (2020) status change received for NukiID 790083444: unlocked
    2023-09-30 19:55:22.004  - info: nuki.0 (2020) battery status received for NukiID 790083444: false
    2023-09-30 19:55:51.541  - info: hue-extended.0 (1725) Attempt 1x - Successfully set Deckenlicht Flur unten Haustuer.
    iob diag has finished.
    GlasfaserG Offline
    GlasfaserG Offline
    @teletapi sagte in Sonnof Adapter hat ständig Warnungen:
    • system.adapter.mqtt.0 : mqtt : iobroker - enabled, port: 1883, bind: 0.0.0.0
    • system.adapter.sonoff.0 : sonoff : iobroker - enabled, port: 1886, bind: 0.0.0.0
    mosquitto
    Eventuell funkt da was zwischen !?
    • GlasfaserG Offline
      GlasfaserG Offline
      throttled=0x0
      Hast du diese Meldung im Log auch gesehn !?
        @teletapi ```
        Skript v.2023-06-20
        *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
        Docker          : false
        Kernel          : aarch64
        Userland        : arm64
        CPU threads: 4
        Raspberry only:
        throttled=0x0
        temp=39.9'C
        volt=0.9460V
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        pi
        /home/pi
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:            99M          0B         99M
                 7811 M total memory
                 2875 M used memory
                 3307 M free memory
                  130 M buffer memory
                 1498 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /var:
        1.8G    /var/
        1.1G    /var/log
        511M    /var/lib
        /usr/bin/npm            9.8.1
        /usr/bin/npx            9.8.1
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.10.4
        javascript:     7.1.4
        Adapter State
        + instance is alive
        Objects and States
        Objects:        9645
        States:         8963
        Pending Updates: 1
        haselchenH Offline
        haselchenH Offline
        haselchen
        @teletapi
        Meine Erfahrungen mit den Meldungen sind netzwerktechnischer Natur.
        Wie ist Dein Netzwerk aufgebaut ?
        Und dann hat Dein Raspi zu wenig Power.
        Richtiges (originales) Netzteil?
        Raspberry only:
        throttled=0x0
        temp=39.9'C
        volt=0.9460V
        • haselchenH haselchen
          @teletapi
          Raspberry only:
          throttled=0x0
          temp=39.9'C
          volt=0.9460V
          Thomas BraunT Offline
          @haselchen sagte in Sonnof Adapter hat ständig Warnungen:
          Nein, die Werte sind super. Gibt ja auch kein Gemecker, throttled=0x0 ist die Null-Meldung, also alles i.O.
          Die neuste Version von iob diag ist da aber besser lesbar,die gibt Klartext aus.
          haselchenH teletapiT 2 Antworten Letzte Antwort
            haselchenH Offline
            haselchenH Offline
            haselchen
            Okay , hatte mich da an einen anderen Thread orientiert, wo ich dachte gelesen zu haben , dass diese Aussage Probleme mit der Stromversorgung suggeriert .
              @haselchen
              Wenn da was anders als 0x0 steht ja. Z.B. 0x5005 oder sowas.
                @teletapi
                Raspberry only:
                throttled=0x0
                temp=39.9'C
                volt=0.9460V
                crunchipC Offline
                crunchipC Offline
                so auch meine , z.b.
                • in Verbindung mit TasmoAdmin( werden wohl zu viele Anfragen auf einmal gesendet, beim starten)
                • Wlan überlastet, z.b. durch W-lan Cams
                teletapiT 1 Antwort Letzte Antwort
                  teletapiT Offline
                  teletapiT Offline
                  teletapi
                  @crunchip
                  Ich habe 1ne Wlan Kamera im Netzwerk, der Rest ist per Lan angebunden allerdings hab ich einige Tasmota Steckdosen die ja alle per Wlan eingebunden sind im Netzwerk. Vielleicht liegt es ja tatsächlich daran,
                    teletapiT Offline
                    teletapiT Offline
                    teletapi
                    @thomas-braun Hallo Thomas, was heißt die neue Iob Diag Version wie kann ich die denn aufrufen...?
                      @crunchip
                      crunchipC Offline
                      crunchipC Offline
                      @teletapi kann sein, das dieser genutzte Kanal überlastet ist(anderweitige Störquellen), mögliche Besserung wäre auf einen anderen Kanal zu wechseln
                        teletapiT Offline
                        teletapiT Offline
                        teletapi
                        @crunchip Jetzt müsstest du mir evtl. dabei helfen wie ich das wechseln könnte in der Fritzbox 7590 . ich hab da schon von gelesen aber bin nicht wirklich sicher wie ich den kanal tauschen bzw. wechseln könnte
                          crunchipC Offline
                          crunchipC Offline
                          @teletapi https://www.heise.de/tipps-tricks/FritzBox-Kanal-aendern-so-geht-s-6072593.html?hg=1&hgi=1&hgf=false
                            Hier stand Quark.
                              Hier stand Quark.
                              Maxtor62
                              Hi, diese Warnungen habe ich auch ständig. Auch seit ich den Shelly Adapter upgedatet habe. Werte und Datenpunkte sind aktuell aber haufenweise Warnungen im Log. Das kommt bei mir vermutlich von dem Flatter-Mesh-WLAN-Netzwerk der Fritte. Habe zwei Fritten und zwei Repeater durch drei Betondecken im Einsatz.
                              Wer meint er ist was, hat aufgehört was zu werden
                              • M Maxtor62
                                haselchenH Offline
                                haselchenH Offline
                                haselchen
                                @maxtor62
                                Die Repeater und die Tasmota Geräte sind ja an ihrem Standort fest installiert denke ich mal?
                                Dann kannst du in die GUI der Tasmota Geräte gehen und dort das WLAN stärkste Signal zum Verbinden auswählen.
                                Und so sollte eigentlich jedes Gerät dann stabil verbunden sein.
                                Es sei denn natürlich das die Geräte weit ausserhalb der Repeater Range sind.
                                M crunchipC 2 Antworten Letzte Antwort
                                  @maxtor62
                                  Maxtor62
                                  @haselchen
                                  Das ist eine Option die ich mal testen werde. Danke Dir für den Tipp. Komischerweise, es sind zwei Tasmota Steckdosen ca. 2Meter neben einem FritzRepeater eingesteckt, der über LAN das WLAN verteilt. Auch von denen bekomme ich die Warnmeldungen.
                                    @maxtor62
                                    crunchipC Offline
                                    crunchipC Offline
                                    @haselchen gibt aber auch eine SetOption damit sich das tasmota Gerät mit dem stärksten Signal verbindet
                                      haselchenH Offline
                                      haselchenH Offline
                                      haselchen
                                      @crunchip
                                      Stimmt .
                                      Nachteil ist (denke ich mir ), dass wenn er in einem bestimmten Intervall immer die beste Verbindung sucht , dass er eventuell immer von einem Router/Repeater zum Anderen springt .
                                      Kann gutgehen , aber ich vermute mit dieser Einstellung mehr Probleme und Log Einträge.
