  4. Adapter lassen sich nach io update nicht mehr öffnen?
    5.1k
16 Beiträge 4 Kommentatoren 1.3k Aufrufe 3 Beobachtet
  • TolkinT Tolkin
    @crunchip sagte in Adapter lassen sich nach io update nicht mehr öffnen?:
    iob diag
    Skript v.2023-06-20
    *** BASE SYSTEM ***
       Static hostname: IOBroker
             Icon name: computer-container
               Chassis: container
            Machine ID: 00ce9495f0e241b5b8dd308da14042b1
               Boot ID: 01ef84cc2372422eb709f4c5b1ac44ac
        Virtualization: lxc
      Operating System: Ubuntu 20.04.6 LTS
                Kernel: Linux 5.15.107-2-pve
          Architecture: x86-64
    model name      : AMD Ryzen 5 PRO 4650G with Radeon Graphics
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     11:43:33 up 9 days, 16:59,  1 user,  load average: 0.46, 0.52, 0.70
    CPU threads: 4
    *** Time and Time Zones ***
                   Local time: Fri 2023-09-29 11:43:33 CEST
               Universal time: Fri 2023-09-29 09:43:33 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** User and Groups ***
    root
    /root
    root
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           8.2G         58M        8.1G        0.0K         79M        8.1G
    Swap:            0B          0B          0B
    Total:         8.2G         58M        8.1G
             8192 M total memory
               58 M used memory
               59 M active memory
               53 M inactive memory
             8053 M free memory
                0 M buffer memory
               79 M swap cache
                0 M total swap
                0 M used swap
                0 M free swap
    *** FILESYSTEM ***
    Filesystem                   Type      Size  Used Avail Use% Mounted on
    rpool/data/subvol-301-disk-1 zfs        32G  3.5G   29G  11% /
    none                         tmpfs     492K  4.0K  488K   1% /dev
    udev                         devtmpfs   16G     0   16G   0% /dev/ttyACM0
    tmpfs                        tmpfs      16G     0   16G   0% /dev/shm
    tmpfs                        tmpfs     3.1G  116K  3.1G   1% /run
    tmpfs                        tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs                        tmpfs     3.1G     0  3.1G   0% /run/user/0
    TARGET                    SOURCE                         FSTYPE     OPTIONS
    /                         rpool/data/subvol-301-disk-1   zfs        rw,relatime,xattr,posixacl
    |-/proc/cpuinfo           lxcfs[/proc/cpuinfo]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/proc/diskstats         lxcfs[/proc/diskstats]         fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/proc/loadavg           lxcfs[/proc/loadavg]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/proc/meminfo           lxcfs[/proc/meminfo]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/proc/slabinfo          lxcfs[/proc/slabinfo]          fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/proc/stat              lxcfs[/proc/stat]              fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/proc/swaps             lxcfs[/proc/swaps]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    |-/proc/uptime            lxcfs[/proc/uptime]            fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    `-/sys/devices/system/cpu lxcfs[/sys/devices/system/cpu] fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    /var:
    940M    /var/
    538M    /var/log
    535M    /var/log/journal/00ce9495f0e241b5b8dd308da14042b1
    278M    /var/cache
    Archived and active journals take up 534.2M in the file system.
    /opt/iobroker/backups:
    10M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    295M    /opt/iobroker/iobroker-data/
    143M    /opt/iobroker/iobroker-data/files
    130M    /opt/iobroker/iobroker-data/backup-objects
    25M     /opt/iobroker/iobroker-data/files/material
    23M     /opt/iobroker/iobroker-data/files/material/static
    18M     /opt/iobroker/iobroker-data/objects.jsonl
    18M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
    6.7M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
    6.1M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
    5.7M    /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.17.1
    /usr/bin/node           v18.17.1
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    nodejs:
      Installed: 18.17.1-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
     *** 18.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x focal/main amd64 Packages
         10.19.0~dfsg-3ubuntu1.1 500
            500 http://archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages
            500 http://archive.ubuntu.com/ubuntu focal-security/universe amd64 Packages
         10.19.0~dfsg-3ubuntu1 500
            500 http://archive.ubuntu.com/ubuntu focal/universe amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    iobroker is not running on this host.
    Objects type: jsonl
    States  type: jsonl
    No configuration change needed.
    Multihost discovery server: disabled
    Discovery authentication:   enabled
    Persistent activation:      disabled
    Objects:                    jsonl on 127.0.0.1
    States:                     jsonl on 127.0.0.1
    Core adapters versions
    js-controller:  5.0.12
    admin:          6.8.0
    javascript:     7.1.4
    Adapters from github:   3
    Adapter State
      system.adapter.admin.0                  : admin                 : IOBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alexa2.0                 : alexa2                : IOBroker                                 -  enabled
      system.adapter.amtronwallbox.0          : amtronwallbox         : IOBroker                                 - disabled
      system.adapter.apcups.0                 : apcups                : IOBroker                                 -  enabled
      system.adapter.backitup.0               : backitup              : IOBroker                                 -  enabled
      system.adapter.cloud.0                  : cloud                 : IOBroker                                 -  enabled
      system.adapter.daswetter.0              : daswetter             : IOBroker                                 -  enabled
      system.adapter.discovery.0              : discovery             : IOBroker                                 -  enabled
      system.adapter.energiefluss.0           : energiefluss          : IOBroker                                 -  enabled
      system.adapter.feiertage.0              : feiertage             : IOBroker                                 -  enabled
      system.adapter.history.0                : history               : IOBroker                                 -  enabled
      system.adapter.hm-rega.0                : hm-rega               : IOBroker                                 -  enabled
      system.adapter.hm-rpc.0                 : hm-rpc                : IOBroker                                 -  enabled, port: 0
      system.adapter.hm-rpc.1                 : hm-rpc                : IOBroker                                 -  enabled, port: 0
      system.adapter.hm-rpc.2                 : hm-rpc                : IOBroker                                 -  enabled, port: 0
      system.adapter.hmip.0                   : hmip                  : IOBroker                                 - disabled
      system.adapter.influxdb.0               : influxdb              : IOBroker                                 - disabled, port: 8086
      system.adapter.info.0                   : info                  : IOBroker                                 -  enabled
      system.adapter.iot.0                    : iot                   : IOBroker                                 -  enabled
      system.adapter.javascript.0             : javascript            : IOBroker                                 -  enabled
      system.adapter.material.0               : material              : IOBroker                                 -  enabled
      system.adapter.mielecloudservice.0      : mielecloudservice     : IOBroker                                 - disabled
      system.adapter.modbus.0                 : modbus                : IOBroker                                 -  enabled
      system.adapter.node-red.0               : node-red              : IOBroker                                 - disabled, port: 1880, bind: 10.14.4.34 (SSL)
      system.adapter.nut.0                    : nut                   : IOBroker                                 - disabled
      system.adapter.onvif.0                  : onvif                 : IOBroker                                 - disabled
      system.adapter.ping.0                   : ping                  : IOBroker                                 -  enabled
      system.adapter.pushover.0               : pushover              : IOBroker                                 -  enabled
      system.adapter.pushover.1               : pushover              : IOBroker                                 -  enabled
      system.adapter.pushover.2               : pushover              : IOBroker                                 -  enabled
      system.adapter.pushover.3               : pushover              : IOBroker                                 -  enabled
      system.adapter.pushover.4               : pushover              : IOBroker                                 -  enabled
      system.adapter.pushover.5               : pushover              : IOBroker                                 -  enabled
      system.adapter.pushover.6               : pushover              : IOBroker                                 -  enabled
      system.adapter.pushover.7               : pushover              : IOBroker                                 -  enabled
      system.adapter.pushover.8               : pushover              : IOBroker                                 -  enabled
      system.adapter.shelly.0                 : shelly                : IOBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
      system.adapter.shuttercontrol.0         : shuttercontrol        : IOBroker                                 -  enabled
      system.adapter.sma-em.0                 : sma-em                : IOBroker                                 -  enabled
      system.adapter.smartmeter.0             : smartmeter            : IOBroker                                 - disabled
      system.adapter.sonoff.0                 : sonoff                : IOBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.sourceanalytix.0         : sourceanalytix        : IOBroker                                 - disabled
      system.adapter.synology.0               : synology              : IOBroker                                 -  enabled, port: 5001
      system.adapter.telegram.0               : telegram              : IOBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.text2command.0           : text2command          : IOBroker                                 -  enabled
      system.adapter.tibber.0                 : tibber                : IOBroker                                 -  enabled
      system.adapter.unifi.0                  : unifi                 : IOBroker                                 - disabled
      system.adapter.vis-material-webfont.0   : vis-material-webfont  : IOBroker                                 -  enabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : IOBroker                                 -  enabled
      system.adapter.vis.0                    : vis                   : IOBroker                                 - disabled
      system.adapter.web.0                    : web                   : IOBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.worx.0                   : worx                  : IOBroker                                 -  enabled
      system.adapter.yahka.0                  : yahka                 : IOBroker                                 -  enabled
      system.adapter.zigbee.0                 : zigbee                : IOBroker                                 -  enabled, port: /dev/ttyACM0
    + instance is alive
    ioBroker-Repositories
    Stable (default): http://download.iobroker.net/sources-dist.json
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    Github        : https://github.com/ioBroker/ioBroker.admin
    Active repo(s): Stable (default), Github
    Installed ioBroker-Instances
    [/s]
    crunchipC Abwesend
    crunchipC Abwesend
    @tolkin sagte in Adapter lassen sich nach io update nicht mehr öffnen?:
    was ist das?
    • TolkinT Tolkin
      iob diag
      Skript v.2023-06-20
      *** BASE SYSTEM ***
                 Chassis: container
          Virtualization: lxc
      Docker          : false
      Kernel          : x86_64
      Userland        : amd64
      CPU threads: 4
                       RTC time: n/a
                RTC in local TZ: no
      root
      /root
      root
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            0B          0B          0B
               8192 M total memory
                 58 M used memory
                 59 M active memory
               8053 M free memory
                  0 M buffer memory
                 79 M swap cache
                  0 M total swap
                  0 M used swap
                  0 M free swap
      *** FILESYSTEM ***
      /var:
      940M    /var/
      538M    /var/log
      278M    /var/cache
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.8.0
      javascript:     7.1.4
      Adapter State
      + instance is alive
      [/s]
      Kick das Github-Ding raus.
      Und installier nodejs 18.18.0 sauber.
      Die Ausgabe von iob diag ist auch nicht vollständig.
      TolkinT 1 Antwort Letzte Antwort
        TolkinT Offline
        TolkinT Offline
        Tolkin
        Habe dein Skript laufen lassen und bin jetzt auf 18.18.0. Danke dafür..
        Die Adapter zeigen immer noch die gleiche Fehlermeldung. Wie kicke ich das Github-Ding raus? Keine Ahnung was das ist.
        • TolkinT Tolkin
          Das ist schlecht. Die Kiste wird doch von dir verwaltet? Da solltest du schon wissen, was das ist und woher es kommt...
          iob repo del Github
          müsste das lauten.
          • TolkinT Tolkin
            @tolkin
            Und
            iob diag
            sieht vollständig nun wie aus? Und hampel da nicht als root herum.
              @tolkin
              Und
              iob diag
              TolkinT Offline
              TolkinT Offline
              Tolkin
              @thomas-braun sagte in Adapter lassen sich nach io update nicht mehr öffnen?:
              iob diag
              Sorry, hast ja Recht ;) Jetzt läuft wieder alles..
              Skript v.2023-06-20
              *** BASE SYSTEM ***
                         Chassis: container
                         Boot ID: 49d8e102a1964114a590c493d98ff2ed
                  Virtualization: lxc
              Docker          : false
              Kernel          : x86_64
              Userland        : amd64
               12:17:15 up 5 min,  1 user,  load average: 2.16, 2.53, 2.01
              CPU threads: 4
                             Local time: Fri 2023-09-29 12:17:15 CEST
                         Universal time: Fri 2023-09-29 10:17:15 UTC
                               RTC time: n/a
                        RTC in local TZ: no
              user
              /home/user
              user adm sudo iobroker
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Mem:           8.2G        3.3G        4.8G        0.0K         88M        4.9G
              Swap:            0B          0B          0B
              Total:         8.2G        3.3G        4.8G
                       8192 M total memory
                       3269 M used memory
                         60 M active memory
                       3138 M inactive memory
                       4833 M free memory
                          0 M buffer memory
                         88 M swap cache
                          0 M total swap
                          0 M used swap
                          0 M free swap
              *** FILESYSTEM ***
              rpool/data/subvol-301-disk-1 zfs        32G  3.6G   29G  12% /
              tmpfs                        tmpfs     3.1G  124K  3.1G   1% /run
              tmpfs                        tmpfs     3.1G     0  3.1G   0% /run/user/1001
              /                         rpool/data/subvol-301-disk-1   zfs        rw,relatime,                                                     xattr,posixacl
              |-/proc/cpuinfo           lxcfs[/proc/cpuinfo]           fuse.lxcfs rw,nosuid,no                                                     dev,relatime,user_id=0,group_id=0,allow_other
              |-/proc/diskstats         lxcfs[/proc/diskstats]         fuse.lxcfs rw,nosuid,no                                                     dev,relatime,user_id=0,group_id=0,allow_other
              |-/proc/loadavg           lxcfs[/proc/loadavg]           fuse.lxcfs rw,nosuid,no                                                     dev,relatime,user_id=0,group_id=0,allow_other
              |-/proc/meminfo           lxcfs[/proc/meminfo]           fuse.lxcfs rw,nosuid,no                                                     dev,relatime,user_id=0,group_id=0,allow_other
              |-/proc/slabinfo          lxcfs[/proc/slabinfo]          fuse.lxcfs rw,nosuid,no                                                     dev,relatime,user_id=0,group_id=0,allow_other
              |-/proc/stat              lxcfs[/proc/stat]              fuse.lxcfs rw,nosuid,no                                                     dev,relatime,user_id=0,group_id=0,allow_other
              |-/proc/swaps             lxcfs[/proc/swaps]             fuse.lxcfs rw,nosuid,no                                                     dev,relatime,user_id=0,group_id=0,allow_other
              |-/proc/uptime            lxcfs[/proc/uptime]            fuse.lxcfs rw,nosuid,no                                                     dev,relatime,user_id=0,group_id=0,allow_other
              `-/sys/devices/system/cpu lxcfs[/sys/devices/system/cpu] fuse.lxcfs rw,nosuid,no                                                     dev,relatime,user_id=0,group_id=0,allow_other
              /var:
              969M    /var/
              539M    /var/log
              307M    /var/cache
              Archived and active journals take up 415.8M in the file system.
              302M    /opt/iobroker/iobroker-data/
              23M     /opt/iobroker/iobroker-data/objects.jsonl
              18M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.ma                                                     p
              6.9M    /opt/iobroker/iobroker-data/states.jsonl
              6.7M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.m                                                     ap
              6.1M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.m                                                     ap
              /usr/bin/nodejs         v18.18.0
              /usr/bin/node           v18.18.0
              /usr/bin/npm            9.8.1
              /usr/bin/npx            9.8.1
              nodejs:
                Installed: 18.18.0-1nodesource1
                Candidate: 18.18.0-1nodesource1
                Version table:
               *** 18.18.0-1nodesource1 1001
                      500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                   18.17.1-1nodesource1 1001
                   18.17.0-1nodesource1 1001
                   18.16.1-1nodesource1 1001
                   18.16.0-1nodesource1 1001
                   18.15.0-1nodesource1 1001
                   18.14.2-1nodesource1 1001
                   18.14.1-1nodesource1 1001
                   18.14.0-1nodesource1 1001
                   18.13.0-1nodesource1 1001
                   18.12.0-1nodesource1 1001
                   18.11.0-1nodesource1 1001
                   18.10.0-1nodesource1 1001
                   18.9.1-1nodesource1 1001
                   18.9.0-1nodesource1 1001
                   18.8.0-1nodesource1 1001
                   18.7.0-1nodesource1 1001
                   18.6.0-1nodesource1 1001
                   18.5.0-1nodesource1 1001
                   18.4.0-1nodesource1 1001
                   18.3.0-1nodesource1 1001
                   18.2.0-1nodesource1 1001
                   18.1.0-1nodesource1 1001
                   18.0.0-1nodesource1 1001
                      500 http://archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packag                                                     es
                      500 http://archive.ubuntu.com/ubuntu focal-security/universe amd64 Packa                                                     ges
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin:          6.10.1
              javascript:     7.1.4
              Adapter State
              + system.adapter.admin.0                  : admin                 : IOBroker        -  enabled, port: 8081, bind: 0.0.0.0, run as: admi                                                     n
              + system.adapter.alexa2.0                 : alexa2                : IOBroker        -  enabled
              + system.adapter.apcups.0                 : apcups                : IOBroker        -  enabled
              + system.adapter.backitup.0               : backitup              : IOBroker        -  enabled
              + system.adapter.cloud.0                  : cloud                 : IOBroker        -  enabled
              + system.adapter.discovery.0              : discovery             : IOBroker        -  enabled
              + system.adapter.energiefluss.0           : energiefluss          : IOBroker        -  enabled
              + system.adapter.history.0                : history               : IOBroker        -  enabled
              + system.adapter.hm-rega.0                : hm-rega               : IOBroker        -  enabled
              + system.adapter.hm-rpc.0                 : hm-rpc                : IOBroker        -  enabled, port: 0
              + system.adapter.hm-rpc.1                 : hm-rpc                : IOBroker        -  enabled, port: 0
              + system.adapter.hm-rpc.2                 : hm-rpc                : IOBroker        -  enabled, port: 0
              + system.adapter.info.0                   : info                  : IOBroker        -  enabled
              + system.adapter.iot.0                    : iot                   : IOBroker        -  enabled
              + system.adapter.javascript.0             : javascript            : IOBroker        -  enabled
              + system.adapter.modbus.0                 : modbus                : IOBroker        -  enabled
              + system.adapter.ping.0                   : ping                  : IOBroker        -  enabled
              + system.adapter.pushover.0               : pushover              : IOBroker        -  enabled
              + system.adapter.pushover.1               : pushover              : IOBroker        -  enabled
              + system.adapter.pushover.2               : pushover              : IOBroker        -  enabled
              + system.adapter.pushover.3               : pushover              : IOBroker        -  enabled
              + system.adapter.pushover.4               : pushover              : IOBroker        -  enabled
              + system.adapter.pushover.5               : pushover              : IOBroker        -  enabled
              + system.adapter.pushover.6               : pushover              : IOBroker        -  enabled
              + system.adapter.pushover.7               : pushover              : IOBroker        -  enabled
              + system.adapter.pushover.8               : pushover              : IOBroker        -  enabled
              + system.adapter.shelly.0                 : shelly                : IOBroker        -  enabled, port: 1882, bind: 0.0.0.0
              + system.adapter.shuttercontrol.0         : shuttercontrol        : IOBroker        -  enabled
              + system.adapter.sma-em.0                 : sma-em                : IOBroker        -  enabled
              + system.adapter.sonoff.0                 : sonoff                : IOBroker        -  enabled, port: 1883, bind: 0.0.0.0
              + system.adapter.synology.0               : synology              : IOBroker        -  enabled, port: 5001
              + system.adapter.telegram.0               : telegram              : IOBroker        -  enabled, port: 8443, bind: 0.0.0.0
              + system.adapter.text2command.0           : text2command          : IOBroker        -  enabled
              + system.adapter.tibber.0                 : tibber                : IOBroker        -  enabled
              + system.adapter.web.0                    : web                   : IOBroker        -  enabled, port: 8082, bind: 0.0.0.0, run as: admi                                                     n
              + system.adapter.worx.0                   : worx                  : IOBroker        -  enabled
              + system.adapter.yahka.0                  : yahka                 : IOBroker        -  enabled
              + system.adapter.zigbee.0                 : zigbee                : IOBroker        -  enabled, port: /dev/ttyACM0
              + instance is alive
              Used repositories: Stable (default), Github
              Error: unknown repository is active - "Github". Known: Stable (default), Beta (l                                                     atest)
              Adapter    "admin"        : 6.10.1   , installed 6.10.1
              Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
              Adapter    "apcups"       : 1.0.15   , installed 1.0.15
              Adapter    "backitup"     : 2.8.1    , installed 2.8.1
              Adapter    "cloud"        : 4.4.1    , installed 4.4.1
              Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
              Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
              Adapter    "history"      : 2.2.6    , installed 2.2.6
              Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
              Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
              Adapter    "hmip"         : 1.20.0   , installed 1.20.0
              Adapter    "iot"          : 1.14.5   , installed 1.14.5
              Adapter    "javascript"   : 7.1.4    , installed 7.1.4
              Controller "js-controller": 5.0.12   , installed 5.0.12
              Adapter    "material"     : 1.3.1    , installed 1.3.1
              Adapter    "miele"        : 0.1.5    , installed 0.1.5
              Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
              Adapter    "modbus"       : 5.0.11   , installed 5.0.11
              Adapter    "node-red"     : 4.0.3    , installed 4.0.3
              Adapter    "nut"          : 1.6.0    , installed 1.6.0
              Adapter    "onvif"        : 1.0.5    , installed 1.0.5
              Adapter    "pushover"     : 3.0.3    , installed 3.0.3
              Adapter    "shelly"       : 6.4.1    , installed 6.4.1
              Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
              Adapter    "sma-em"       : 1.0.0    , installed 1.0.0
              Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
              Adapter    "socketio"     : 6.5.5    , installed 6.5.5
              Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
              Adapter    "synology"     : 3.0.0    , installed 3.0.0
              Adapter    "telegram"     : 1.16.0   , installed 1.16.0
              Adapter    "text2command" : 3.0.2    , installed 3.0.2
              Adapter    "unifi"        : 0.6.6    , installed 0.6.6
              Adapter    "web"          : 6.1.2    , installed 6.1.2
              Adapter    "worx"         : 2.3.2    , installed 2.3.2
              Adapter    "ws"           : 2.5.5    , installed 2.5.5
              Adapter    "yahka"        : 1.0.3    , installed 1.0.3
              Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
              Objects and States
              Objects:        133657
              States:         102163
              Hit:1 https://deb.nodesource.com/node_18.x nodistro InRelease
              Hit:2 http://archive.ubuntu.com/ubuntu focal InRelease
              Hit:3 http://archive.ubuntu.com/ubuntu focal-updates InRelease
              Hit:4 http://archive.ubuntu.com/ubuntu focal-security InRelease
              Reading package lists...
              Pending Updates: 0
              *** Listening Ports ***
              Proto Recv-Q Send-Q Local Address           Foreign Address         State                                                            User       Inode      PID/Program name
              tcp        0      0 10.14.4.34:8701         0.0.0.0:*               LISTEN                                                           1000       41856576   652/io.hm-rpc.2
              tcp        0      0 127.0.0.1:46487         0.0.0.0:*               LISTEN                                                           1000       41860740   1022/io.yahka.0
              tcp        0      0 10.14.4.34:42001        0.0.0.0:*               LISTEN                                                           1000       41857598   618/io.hm-rpc.0
              tcp        0      0 10.14.4.34:42010        0.0.0.0:*               LISTEN                                                           1000       41856553   633/io.hm-rpc.1
              tcp        0      0 0.0.0.0:40299           0.0.0.0:*               LISTEN                                                           1000       41866666   1022/io.yahka.0
              tcp        0      0 127.0.0.1:41881         0.0.0.0:*               LISTEN                                                           1000       41860725   1022/io.yahka.0
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN                                                           1000       41857101   155/iobroker.js-con
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN                                                           1000       41857096   155/iobroker.js-con
              tcp        0      0 0.0.0.0:32825           0.0.0.0:*               LISTEN                                                           1000       41866662   1022/io.yahka.0
              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN                                                           0          41847171   1/init
              tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN                                                           1000       41857755   693/io.shelly.0
              tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN                                                           1000       41857819   713/io.sonoff.0
              tcp        0      0 127.0.0.1:44823         0.0.0.0:*               LISTEN                                                           1000       41867622   1022/io.yahka.0
              tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN                                                           106        41850710   138/systemd-resolve
              tcp        0      0 0.0.0.0:41521           0.0.0.0:*               LISTEN                                                           1000       41866658   1022/io.yahka.0
              tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN                                                           0          41846624   331/master
              tcp        0      0 127.0.0.1:34733         0.0.0.0:*               LISTEN                                                           1000       41860720   1022/io.yahka.0
              tcp        0      0 127.0.0.1:33823         0.0.0.0:*               LISTEN                                                           1000       41867842   1022/io.yahka.0
              tcp6       0      0 ::1:25                  :::*                    LISTEN                                                           0          41846625   331/master
              tcp6       0      0 :::8081                 :::*                    LISTEN                                                           1000       41871456   1825/io.admin.0
              tcp6       0      0 :::8082                 :::*                    LISTEN                                                           1000       41867602   964/io.web.0
              tcp6       0      0 :::22                   :::*                    LISTEN                                                           0          41850469   1/init
              tcp6       0      0 :::111                  :::*                    LISTEN                                                           0          41847175   1/init
              udp     1280      0 0.0.0.0:5353            0.0.0.0:*        1000       41866663   1022/io.yahka.0
              udp        0      0 0.0.0.0:5353            0.0.0.0:*        1000       41866659   1022/io.yahka.0
              udp        0      0 0.0.0.0:5353            0.0.0.0:*        1000       41866655   1022/io.yahka.0
              udp        0      0 0.0.0.0:9522            0.0.0.0:*        1000       41866523   879/io.sma-em.0
              udp        0      0 127.0.0.53:53           0.0.0.0:*        106        41850709   138/systemd-resolve
              udp        0      0 0.0.0.0:111             0.0.0.0:*        0          41847172   1/init
              udp6       0      0 :::111                  :::*        0          41847178   1/init
              2023-09-29 12:16:07.744  - info: host.IOBroker iobroker Update "system.adapter.s                                                     huttercontrol.0"
              2023-09-29 12:16:08.228  - info: host.IOBroker iobroker upload [5] shuttercontro                                                     l.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/img/info-big.pn                                                     g img/info-big.png image/png
              2023-09-29 12:16:08.233  - info: host.IOBroker iobroker upload [4] shuttercontro                                                     l.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/index_m.html in                                                     dex_m.html text/html
              2023-09-29 12:16:08.235  - info: host.IOBroker iobroker upload [3] shuttercontro                                                     l.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/index_m.js inde                                                     x_m.js application/javascript
              2023-09-29 12:16:08.239  - info: host.IOBroker iobroker upload [2] shuttercontro                                                     l.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/shuttercontrol.                                                     png shuttercontrol.png image/png
              2023-09-29 12:16:08.241  - info: host.IOBroker iobroker upload [1] shuttercontro                                                     l.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/style.css style                                                     .css text/css
              2023-09-29 12:16:08.244  - info: host.IOBroker iobroker upload [0] shuttercontro                                                     l.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/words.js words.                                                     js application/javascript
              2023-09-29 12:16:08.246  - info: host.IOBroker iobroker host.IOBroker Adapter "s                                                     ystem.adapter.shuttercontrol.0" is started
              2023-09-29 12:16:08.258  - info: host.IOBroker "system.adapter.shuttercontrol.0"                                                      enabled
              2023-09-29 12:16:08.763  - info: host.IOBroker instance system.adapter.shutterco                                                     ntrol.0 started with pid 2712
              2023-09-29 12:16:09.779  - info: host.IOBroker iobroker exit 0
              2023-09-29 12:16:11.059  - info: shuttercontrol.0 (2712) starting. Version 1.6.2                                                      in /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v18.18.0, js-contr                                                     oller: 5.0.12
              2023-09-29 12:16:12.555  - warn: admin.0 (1825) No repository source configured
              2023-09-29 12:16:21.539  - info: alexa2.0 (2096) No smart home devices to query
              2023-09-29 12:16:21.929  - info: alexa2.0 (2096) Subscribing to states...
              2023-09-29 12:16:21.931  - info: alexa2.0 (2096) Deleting the following states:                                                      ["Smart-Home-Devices.e789e8e3-a558-4134-afe6-cce1a7a8fc9d","Smart-Home-Devices.e                                                     789e8e3-a558-4134-afe6-cce1a7a8fc9d.#delete","Smart-Home-Devices.e789e8e3-a558-4                                                     134-afe6-cce1a7a8fc9d.#enabled"]
              2023-09-29 12:16:23.774  - info: alexa2.0 (2096) Alexa-Push-Connection (macDms =                                                      true) established. Disable Polling
              2023-09-29 12:16:33.281  - warn: host.IOBroker Requested repository "Github" doe                                                     s not exist in config.
              2023-09-29 12:16:41.679  - info: alexa2.0 (2096) Initialization Done ...
              2023-09-29 12:16:46.383  - error: modbus.0 (667) Socket Error
              2023-09-29 12:16:46.383  - error: modbus.0 (667) Client in error state.
              2023-09-29 12:16:46.383  - warn: modbus.0 (667) On error: {"errno":-111,"code":"                                                     ECONNREFUSED","syscall":"connect","address":"10.14.4.40","port":502}
              2023-09-29 12:17:47.385  - error: modbus.0 (667) Socket Error
              2023-09-29 12:17:47.386  - error: modbus.0 (667) Client in error state.
              2023-09-29 12:17:47.386  - warn: modbus.0 (667) On error: {"errno":-111,"code":"                                                     ECONNREFUSED","syscall":"connect","address":"10.14.4.40","port":502}
              • TolkinT Tolkin
                iob diag
                Skript v.2023-06-20
                *** BASE SYSTEM ***
                           Chassis: container
                    Virtualization: lxc
                Docker          : false
                Kernel          : x86_64
                Userland        : amd64
                CPU threads: 4
                                 RTC time: n/a
                          RTC in local TZ: no
                user
                /home/user
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Swap:            0B          0B          0B
                         8192 M total memory
                         3269 M used memory
                           60 M active memory
                         4833 M free memory
                            0 M buffer memory
                           88 M swap cache
                            0 M total swap
                            0 M used swap
                            0 M free swap
                *** FILESYSTEM ***
                /var:
                969M    /var/
                539M    /var/log
                307M    /var/cache
                /usr/bin/npm            9.8.1
                /usr/bin/npx            9.8.1
                nodejs:
                  Version table:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin:          6.10.1
                javascript:     7.1.4
                Adapter State
                + instance is alive
                Objects and States
                Objects:        133657
                States:         102163
                Pending Updates: 0
                hmm, alles?
                • TolkinT Tolkin
                  iob diag
                  Skript v.2023-06-20
                  *** BASE SYSTEM ***
                             Chassis: container
                      Virtualization: lxc
                  Docker          : false
                  Kernel          : x86_64
                  Userland        : amd64
                  CPU threads: 4
                                   RTC time: n/a
                            RTC in local TZ: no
                  user
                  /home/user
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Swap:            0B          0B          0B
                           8192 M total memory
                           3269 M used memory
                             60 M active memory
                           4833 M free memory
                              0 M buffer memory
                             88 M swap cache
                              0 M total swap
                              0 M used swap
                              0 M free swap
                  *** FILESYSTEM ***
                  /var:
                  969M    /var/
                  539M    /var/log
                  307M    /var/cache
                  /usr/bin/npm            9.8.1
                  /usr/bin/npx            9.8.1
                  nodejs:
                    Version table:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          6.10.1
                  javascript:     7.1.4
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        133657
                  States:         102163
                  Pending Updates: 0
                  Swap: 0B
                  Würde ich einschalten. Der wird auch dann und wann bei 8GB RAM verwendet.
                  Da schwirrt noch der Github-Eintrag herum.
                  iob repo unset Github
                    hmm, alles?
                    TolkinT Offline
                    TolkinT Offline
                    Tolkin
                    @homoran sagte in Adapter lassen sich nach io update nicht mehr öffnen?:
                    hmm, alles?
                    Ja, der Modbus Adapter funktioniert jetzt auch wieder. ;)
                    Ob das Problem jetzt wirklich der Github Adapter war?
                    • TolkinT Tolkin
                      hmm, alles?
                      crunchipC Abwesend
                      crunchipC Abwesend
                      du hast
                      ausgeschaltet wurde nur dein fehlerhafter Repoeintrag
