  4. Rotex HPSU / Daikin Altherma Wärmepumpe über ioBroker.canbus
    6.4k
canbuscanbus adapterrotex hpsu
526 Beiträge 26 Kommentatoren 151.7k Aufrufe 21 Beobachtet
  • RaspiUserR RaspiUser
    @crycode
    ... hier der Log:
    canbus.0
    	2023-07-23 19:09:54.062	debug	Plugin sentry Initialize Plugin (enabled=true)
    canbus.0
    	2023-07-23 19:09:49.119	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    canbus.0
    	2023-07-23 19:09:49.118	debug	Plugin sentry destroyed
    canbus.0
    	2023-07-23 19:09:49.117	info	terminating
    canbus.0
    	2023-07-23 19:09:49.116	debug	cleaned everything up...
    canbus.0
    	2023-07-23 19:09:49.113	info	Got terminate signal TERMINATE_YOURSELF
    canbus.0
    	2023-07-23 19:09:30.656	error	Error starting can interface: Error: Error while creating channel
    canbus.0
    	2023-07-23 19:09:30.585	info	starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.canbus, node: v18.17.0, js-controller: 4.0.24
    canbus.0
    	2023-07-23 19:09:30.149	debug	Plugin sentry Initialize Plugin (enabled=true)
    canbus.0
    	2023-07-23 19:09:30.117	debug	States connected to redis: 127.0.0.1:9000
    canbus.0
    	2023-07-23 19:09:30.102	debug	States create User PubSub Client
    canbus.0
    	2023-07-23 19:09:30.101	debug	States create System PubSub Client
    canbus.0
    	2023-07-23 19:09:30.092	debug	Redis States: Use Redis connection: 127.0.0.1:9000
    canbus.0
    	2023-07-23 19:09:30.068	debug	Objects connected to redis: 127.0.0.1:9001
    canbus.0
    	2023-07-23 19:09:30.059	debug	Objects client initialize lua scripts
    canbus.0
    	2023-07-23 19:09:30.036	debug	Objects create User PubSub Client
    canbus.0
    	2023-07-23 19:09:30.033	debug	Objects create System PubSub Client
    canbus.0
    	2023-07-23 19:09:30.031	debug	Objects client ready ... initialize now
    canbus.0
    	2023-07-23 19:09:29.989	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
    canbus.0
    	2023-07-23 19:09:25.199	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    canbus.0
    	2023-07-23 19:09:25.194	info	terminating
    canbus.0
    	2023-07-23 19:09:25.190	info	Got terminate signal TERMINATE_YOURSELF
    canbus.0
    	2023-07-23 19:08:39.954	error	Error starting can interface: Error: Error while creating channel
    canbus.0
    	2023-07-23 19:08:39.877	info	starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.canbus, node: v18.17.0, js-controller: 4.0.24
    ... sonst passiert nix ... und hier die Einstellungen (ohne Änderungen zw. Buste rund Bookworm)
    crycodeC Offline
    crycodeC Offline
    crycode
    #313
    @raspiuser In deiner Config steht vcan0, aber das Interface heißt can0. ;)
    Meine Adapter: discord | canbus | ds18b20 | odl | radiohead
    RaspiUserR 1 Antwort Letzte Antwort
    • crycodeC crycode
      RaspiUserR Offline
      RaspiUserR Offline
      RaspiUser
      #314
      @crycode said in Rotex HPSU / Daikin Altherma Wärmepumpe über ioBroker.canbus:
      nö ... vcan0 ist richtig ... Ich habe / hatte ja bereits ein funktionsfähige Anbindung (siehe #280).
      (Ich habe wirklich "nur" eine frische Bullseye / Bookworm Karte mit Backitup eingesetzt. Und dann ist ja vcan0 immer noch richtig ... funktioniert unter Buster ja einwandfrei ...)
      Ich klone die Buster Karte und upgrade dann DIESE Installation ohne ein ganz frische Installation ... vielleicht ist dann die Lösung ...
      crycodeC 1 Antwort Letzte Antwort
        crycodeC Offline
        crycodeC Offline
        crycode
        #315
        @raspiuser Ah moment... du hast den Adapter ja auf einem anderen System laufen und das CAN-Interface vom Raspi mittel Cannelloni weitergegeben, richtig?
        Den Cannelloni Service hast du auf beiden Seiten richtig eingerichtet?
        Dann schau mal ins Log von den Services, ob dort irgendwelche Fehler gemeldet werden:
        sudo journalctl -u cannelloni-can0.service
        bzw.
        sudo journalctl -u cannelloni-vcan0.service
        Wahrscheinlich klemmt da irgendwas, wodurch dann van0 auf deinem ioBroker System nicht richtig verfügbar ist.
        • crycodeC crycode
          bzw.
          RaspiUserR Offline
          RaspiUserR Offline
          RaspiUser
          #316
          @crycode
          ... ich war mir nicht sicher auf welchem System ich die Logs erstellen soll und habe mal (laienhaft) beide abgefragt ...
          Hier die Ausgabe auf dem ioBroker Raspi Pi4:
          pi@ioBroker-Raspi:~ $ sudo journalctl -u cannelloni-can0.service
          -- No entries --
          pi@ioBroker-Raspi:~ $ sudo journalctl -u cannelloni-vcan0.service
          -- No entries --
          Und hier auf dem vcan0 Raspi Zero:
          pi@ioBroker-Zero:~ $ sudo journalctl -u cannelloni-vcan0.service
          -- Logs begin at Sat 2023-07-22 18:08:42 CEST, end at Mon 2023-07-24 12:10:35 CE
          -- No entries --
          lines 1-2/2 (END)
          pi@ioBroker-Zero:~ $ sudo journalctl -u cannelloni-can0.service
          -- Logs begin at Sat 2023-07-22 18:08:42 CEST, end at Mon 2023-07-24 12:11:16 CE
          Jul 22 18:09:09 ioBroker-Zero systemd[1]: Started Cannelloni for can0.
          Jul 22 18:09:10 ioBroker-Zero cannelloni[556]: INFO:udpthread.cpp[158]:run:UDPTh
          Jul 22 18:09:10 ioBroker-Zero cannelloni[556]: ERROR:canthread.cpp[88]:start:CAN
          Jul 22 18:09:10 ioBroker-Zero cannelloni[556]: INFO:canthread.cpp[108]:run:CANTh
          lines 1-5/5 (END)...skipping...
          -- Logs begin at Sat 2023-07-22 18:08:42 CEST, end at Mon 2023-07-24 12:11:16 CEST. --
          Jul 22 18:09:10 ioBroker-Zero cannelloni[556]: INFO:udpthread.cpp[158]:run:UDPThread up and running
          Jul 22 18:09:10 ioBroker-Zero cannelloni[556]: ERROR:canthread.cpp[88]:start:CAN_FD is not supported on >can0<
          Jul 22 18:09:10 ioBroker-Zero cannelloni[556]: INFO:canthread.cpp[108]:run:CANThread up and running
          lines 1-5/5 (END)
          lines 1-5/5 (END)
            @crycode
            -- No entries --
            -- No entries --
            -- No entries --
            lines 1-2/2 (END)
            lines 1-5/5 (END)
            lines 1-5/5 (END)
            crycodeC Offline
            crycodeC Offline
            crycode
            #317
            @raspiuser Auf dem Raspi Zero sieht soweit gut aus.
            Mach mal auf dem ioBroker Raspi:
            sudo systemctl restart cannelloni-vcan0.service
            sudo systemctl status cannelloni-vcan0.service
            Das startet den Service neu, fragt den Status ab und gibt das Log aus.
            Hat der Raspi Zero nach dem Update noch die gleiche IP-Adresse?
            Falls nicht, musst du in der Datei /etc/systemd/system/cannelloni-vcan0.service auf dem ioBroker Raspi anpassen.
            • crycodeC crycode
              RaspiUserR Offline
              RaspiUserR Offline
              RaspiUser
              schrieb am zuletzt editiert von RaspiUser
              #318
              @crycode
              ... sieht wohl so aus, dass ich (erstmal) canneloni auf dem Raspi einrichten muss, oder ?
              pi@ioBroker-Raspi:~ $ sudo systemctl restart cannelloni-vcan0.service
              Failed to restart cannelloni-vcan0.service: Unit cannelloni-vcan0.service not found.
              pi@ioBroker-Raspi:~ $ sudo systemctl status cannelloni-vcan0.service
              Unit cannelloni-vcan0.service could not be found.
              -- No entries --
              EDIT:
              so, oder ? (siehe auch "meine" Anleitung ab Seite 4 ...)
              sudo apt install can-utils
              sudo apt install build-essential cmake git
              git clone https://github.com/mguentner/cannelloni.git
              cd cannelloni
              cmake -DCMAKE_BUILD_TYPE=Release make
              sudo make install
              usw.
              Während der Installation kam diese Fehlermeldung:
              Job for vcan0-setup.service failed because the control process exited with error code.
              See "systemctl status vcan0-setup.service" and "journalctl -xeu vcan0-setup.service" for details.
              Nachdem ich dann diesem Wunsch entsprochen habe kam dann dieser ewig lange Text (mit dem ich als Laie nix anfangen kann ...):
              pi@ioBroker-Raspi:~ $ systemctl status vcan0-setup.service
              × vcan0-setup.service - Setup vcan0
                   Loaded: loaded (/etc/systemd/system/vcan0-setup.service; enabled; preset: >
                   Active: failed (Result: exit-code) since Mon 2023-07-24 14:43:18 CEST; 1s >
                  Process: 1241 ExecStart=/usr/local/sbin/vcan0-setup.sh start (code=exited, >
                 Main PID: 1241 (code=exited, status=203/EXEC)
                      CPU: 6ms
              Jul 24 14:43:18 ioBroker-Raspi systemd[1]: Starting vcan0-setup.service - Setup>
              Jul 24 14:43:18 ioBroker-Raspi (setup.sh)[1241]: vcan0-setup.service: Failed to>
              Jul 24 14:43:18 ioBroker-Raspi (setup.sh)[1241]: vcan0-setup.service: Failed at>
              Jul 24 14:43:18 ioBroker-Raspi systemd[1]: vcan0-setup.service: Main process ex>
              Jul 24 14:43:18 ioBroker-Raspi systemd[1]: vcan0-setup.service: Failed with res>
              Jul 24 14:43:18 ioBroker-Raspi systemd[1]: Failed to start vcan0-setup.service >
              lines 1-13/13 (END)...skipping...
                   Loaded: loaded (/etc/systemd/system/vcan0-setup.service; enabled; preset: enabled)
                   Active: failed (Result: exit-code) since Mon 2023-07-24 14:43:18 CEST; 1s ago
                  Process: 1241 ExecStart=/usr/local/sbin/vcan0-setup.sh start (code=exited, status=203/EXEC)
                      CPU: 6ms
              Jul 24 14:43:18 ioBroker-Raspi systemd[1]: Starting vcan0-setup.service - Setup vcan0...
              Jul 24 14:43:18 ioBroker-Raspi (setup.sh)[1241]: vcan0-setup.service: Failed to execute /usr/local/sbin/vcan0-setup.sh: Exec format error
              Jul 24 14:43:18 ioBroker-Raspi (setup.sh)[1241]: vcan0-setup.service: Failed at step EXEC spawning /usr/local/sbin/vcan0-setup.sh: Exec forma>
              Jul 24 14:43:18 ioBroker-Raspi systemd[1]: vcan0-setup.service: Main process exited, code=exited, status=203/EXEC
              Jul 24 14:43:18 ioBroker-Raspi systemd[1]: vcan0-setup.service: Failed with result 'exit-code'.
              Jul 24 14:43:18 ioBroker-Raspi systemd[1]: Failed to start vcan0-setup.service - Setup vcan0.
              ...skipping...
                      CPU: 6ms
                      CPU: 6ms
              pi@ioBroker-Raspi:~ $ journalctl -xeu vcan0-setup.service
              ░░ Subject: A start job for unit vcan0-setup.service has begun execution
              ░░ Defined-By: systemd
              ░░ Support: https://www.debian.org/support
              ░░ A start job for unit vcan0-setup.service has begun execution.
              ░░ The job identifier is 9756.
              Jul 24 14:44:49 ioBroker-Raspi (setup.sh)[1333]: vcan0-setup.service: Failed to execute /usr/local/sbin/vcan0-setup.sh: Exec format error
              Jul 24 14:44:49 ioBroker-Raspi (setup.sh)[1333]: vcan0-setup.service: Failed at step EXEC spawning /usr/local/sbin/vcan0-setup.sh: Exec forma>
              ░░ Subject: Process /usr/local/sbin/vcan0-setup.sh could not be executed
              ░░ The process /usr/local/sbin/vcan0-setup.sh could not be executed and failed.
              ░░ The error number returned by this process is ERRNO.
              Jul 24 14:44:49 ioBroker-Raspi systemd[1]: vcan0-setup.service: Main process exited, code=exited, status=203/EXEC
              ░░ Subject: Unit process exited
              ░░ An ExecStart= process belonging to unit vcan0-setup.service has exited.
              ░░ The process' exit code is 'exited' and its exit status is 203.
              Jul 24 14:44:49 ioBroker-Raspi systemd[1]: vcan0-setup.service: Failed with result 'exit-code'.
              ░░ Subject: Unit failed
              ░░ The unit vcan0-setup.service has entered the 'failed' state with result 'exit-code'.
              Jul 24 14:44:49 ioBroker-Raspi systemd[1]: Failed to start vcan0-setup.service - Setup vcan0.
              ░░ Subject: A start job for unit vcan0-setup.service has failed
              ░░ A start job for unit vcan0-setup.service has finished with a failure.
              ░░ The job identifier is 9756 and the job result is failed.
              lines 4118-4155/4155 (END)
                @crycode
                -- No entries --
                EDIT:
                cd cannelloni
                sudo make install
                usw.
                        CPU: 6ms
                        CPU: 6ms
                ...skipping...
                        CPU: 6ms
                        CPU: 6ms
                crycodeC Offline
                crycodeC Offline
                crycode
                #319
                @raspiuser Ja, du musst natürlich Cannelloni installiert und alles eingerichtet haben. ;)
                Da stimmt etwas mit dem vcan0-setup.sh Script nicht.
                • crycodeC crycode
                  RaspiUserR Offline
                  RaspiUserR Offline
                  RaspiUser
                  #320
                  OK, Danke erstmal ...
                  Das einfachste für mich ist es, ich fange mit dem ioBroker-Raspi frisch an.
                  Auf dem CAN-Zero-Raspi sollte ja alles i.O. sein ... mit der "alten" Installation klappt es ja.
                  • hg6806H Offline
                    hg6806H Offline
                    hg6806
                    #321
                    leider kämpfe ich bei aktivem CAN Adapter noch immer mit einer hohen Prozessorlast.
                    Ich habe den CAN über ein CAN HAT am RasPi 4 4GB angeschlossen.
                    Wie und wo kann ich Abfragetimings einstellen? In der Instanz habe ich nichts gefunden.
                    V1.3.1 ist installiert
                    C crycodeC 2 Antworten Letzte Antwort
                    • hg6806H hg6806
                      cb187
                      #322
                      Intervall !
                      • hg6806H hg6806
                        crycodeC Offline
                        crycodeC Offline
                        crycode
                        #323
                        @hg6806 Du kannst pro Parser die Option "Automatisch einen bestimmten Wert setzen" aktivieren/deaktivieren und dazu den jeweiligen Intervall in Millisekunden festlegen.
                        Bei sehr vielen aktiven Abfragen (oder sonst sehr hoher Aktivität auf dem Bus) steigt dann logischerweise die Last von deinem System.
                        hg6806H 1 Antwort Letzte Antwort
                        • crycodeC crycode
                          hg6806H Offline
                          hg6806H Offline
                          hg6806
                          #324
                          @crycode
                          Stimmt, den Intervall Wert kann man aber nur für recht wenige Werte eintragen. Hier habe ich als Minimalen Wert 10 Sek. sonst 1 Min oder auch länger.
                          Manche Abfrage Werte haben keine Intervall Angabe:
                          Kann man die Werte exportieren und dann einfach mal einen Teil löschen, ob es besser werte und dann das File wieder importieren? Die Last muss ja irgendwo herkommen. Ich glaube von dem Abfragen kommt das nicht.
                          • hg6806H hg6806
                            @crycode
                            crycodeC Offline
                            crycodeC Offline
                            crycode
                            #325
                            @hg6806 Das Feld für den Intervall erscheint erst, wenn du den Haken für das automatische Setzen setzt. ;)
                            Du kannst deine Konfiguration exportieren (über Import/Export in der Konfig als json), dann einige Parser testweise löschen und später einfach die exportierte Konfig wieder importieren, um alles zurück zu haben.
                            Wie viele Abfragen hast du aktiv?
                            Hast du die "raw-States" aktiviert? Falls ja mach die mal aus.
                            Hast du mal auf dem Raspi geschaut, welcher Prozess die CPU-Last erzeugt?
                            Das müsste mit htop in einem Terminal zu sehen sein. (Falls nicht installiert: sudo apt install htop)
                            • crycodeC crycode
                              hg6806H Offline
                              hg6806H Offline
                              hg6806
                              #326
                              @crycode
                              Was passiert, wenn der Haken fürs Automatische Setzen nicht gesetzt ist? Wann werden dann die Werte abgefragt bzw. erneuert?
                              Ich habe vielleicht 20 Abfragen aktiv
                              Ja, Raw-States ist angehakt. Ich "unchecke" das mal
                              Hier ist die Last von ioBroker. Ich hoffe das reicht.
                              • hg6806H hg6806
                                @crycode
                                crycodeC Offline
                                crycodeC Offline
                                crycode
                                #327
                                @hg6806 sagte in Rotex HPSU / Daikin Altherma Wärmepumpe über ioBroker.canbus:
                                Dann werden die Werte nur abgefragt, wenn du es manuell oder z.B. über ein eigenes Script triggerst.
                                20 sollten eigentlich ohne größere Probleme funktionieren.
                                • C cb187
                                  Das ist schonmal das wichtigste für den Winter für die Abtauvorgänge.Bildschirmfoto 2023-06-01 um 16.12.27.png Bildschirmfoto 2023-06-01 um 16.13.12.png
                                  letzte ist aktuelle Leistungsberechnung
                                  Und halt nen Dashboard wo ich alles relevante sehe.
                                  earl80
                                  schrieb am zuletzt editiert von earl80
                                  #328
                                  @cb187 Hi, danke für die gezeigten Blockly Scripts! Eine Frage habe ich: Woher kommt bei der Leistungsberechnung der Wert "Rotex Verbrauch" her? Müsste der nicht vom Stromzähler kommen?
                                  LG Earl
                                  • C Offline
                                    cb187
                                    #329
                                    @earl80 said in Rotex HPSU / Daikin Altherma Wärmepumpe über ioBroker.canbus:
                                    LG Earl
                                    Doch kommt vom eigenen WP Zähler.Bin mittlerweile von einem Modbus Zähler auf Shelly 3em gewechselt.
                                    E 1 Antwort Letzte Antwort
                                    • C cb187
                                      LG Earl
                                      earl80
                                      #330
                                      @cb187 said in Rotex HPSU / Daikin Altherma Wärmepumpe über ioBroker.canbus:
                                      Modbus Zähler
                                      Ok, den kannte ich noch nicht. Hast den im Zählerschrank einbauen lassen, oder am Kabel von der WP?
                                      E HomoranH C 3 Antworten Letzte Antwort
                                      • E earl80
                                        Modbus Zähler
                                        earl80
                                        #331
                                        Modbus Zähler
                                        • E earl80
                                          Modbus Zähler
                                          #332
