  4. Multihost zusamen führen ** gelöst **
    2.5k
    4.5k
28 Beiträge 7 Kommentatoren 1.6k Aufrufe 5 Beobachtet
  • Horst BöttcherH Horst Böttcher
    @bahnuhr
    pi@PiMaster:~ $ sudo iobroker setup custom
    Current configuration:
    - Objects database:
     - Type: jsonl
     - Host/Unix Socket: 0.0.0.0
     - Port: 9001
    - States database:
     - Type: jsonl
     - Port: 9000
    - Data Directory: ../../iobroker-data/
    Type of objects DB [(j)sonl, (f)ile, (r)edis, ...], default [jsonl]:
    Host / Unix Socket of objects DB(jsonl), default[0.0.0.0]:
    Port of objects DB(jsonl), default[9001]:
    Type of states DB [(j)sonl, (f)file, (r)edis, ...], default [jsonl]:
    Host / Unix Socket of states DB (jsonl), default[0.0.0.0]:
    Port of states DB (jsonl), default[9000]:
    Data directory (file), default[../../iobroker-data/]:
    Host name of this machine [PiMaster]:
    updating conf/iobroker.json
    pi@PiMaster:~ $
    Slave
    pi@Slave1:/opt/iobroker $ sudo iobroker setup custom
    - Objects database:
      - Type: jsonl
      - Host/Unix Socket: 192.168.178.100
      - Port: 9001
    - States database:
      - Type: jsonl
      - Port: 9000
    Host / Unix Socket of objects DB(jsonl), default[192.168.178.100]: 192.168.178.100
    Host / Unix Socket of states DB (jsonl), default[192.168.178.100]: 192.168.178.100
    Host name of this machine [Slave1]: Slave1
    dann
    pi@PiMaster:~ $ iobroker multihost enable
    Multihost discovery server activated on this host. If iobroker is currently not running please start befeore trying to discover this host.
    Important: Multihost discovery works with UDP packets. Make sure they are routed correctly in your network. If you use Docker you also need to configure this correctly.
    Multihost discovery will be automatically deactivated after 15 minutes. If you want to activate it permanently use the --persist flag
    Discovery authentication activated.
    Enter secret phrase for connection:
    Repeat secret phrase for connection:
    Please check the binding of the configured jsonl server to allow remote connections.
    Please restart ioBroker for the changes to take effect: "iobroker restart"
    Multihost discovery server: enabled
    Discovery authentication:   enabled
    Persistent activation:      disabled
    Objects:                    jsonl on 0.0.0.0
    States:                     jsonl on 0.0.0.0
    ^C
    pi@PiMaster:~ $
    und iob restart
    beim Slave
    iobroker multihost browse
    ``` oder iobroker multihost browse
    und es kommt nix
    ich weiss nicht ob intressant log
    host.PiMaster
    2023-09-18 18:36:55.644	info	instance system.adapter.backitup.0 started with pid 17093
    host.PiMaster
    2023-09-18 18:36:51.364	info	instance system.adapter.discovery.0 started with pid 17075
    host.PiMaster
    2023-09-18 18:36:50.889	info	Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    host.PiMaster
    2023-09-18 18:36:47.390	info	instance system.adapter.zigbee.0 started with pid 17052
    host.PiMaster
    2023-09-18 18:36:43.610	info	Some obsolete host states deleted.
    host.PiMaster
    2023-09-18 18:36:43.590	info	Delete state "system.host.PiMaster.versions.npmNewestNext"
    host.PiMaster
    2023-09-18 18:36:43.530	info	Delete state "system.host.PiMaster.versions.npmNewest"
    host.PiMaster
    2023-09-18 18:36:43.504	info	Delete state "system.host.PiMaster.versions.npmCurrent"
    host.PiMaster
    2023-09-18 18:36:43.483	info	instance system.adapter.admin.0 started with pid 17041
    host.PiMaster
    2023-09-18 18:36:43.440	info	Delete state "system.host.PiMaster.versions.nodeNewestNext"
    host.PiMaster
    2023-09-18 18:36:43.404	info	Delete state "system.host.PiMaster.versions.nodeNewest"
    host.PiMaster
    2023-09-18 18:36:43.303	info	starting 4 instances
    host.PiMaster
    2023-09-18 18:36:43.276	info	4 instances found
    host.PiMaster
    2023-09-18 18:36:43.250	info	Delete state "system.host.PiMaster.versions.nodeCurrent"
    host.PiMaster
    2023-09-18 18:36:42.278	info	added notifications configuration of host
    host.PiMaster
    2023-09-18 18:36:42.250	info	connected to Objects and States
    host.PiMaster
    2023-09-18 18:36:41.499	info	ip addresses: 192.168.178.100 2001:9e8:1ec:af00:d975:3f8a:fb83:7a0e fe80::b476:adb:eade:b907
    host.PiMaster
    2023-09-18 18:36:41.498	info	hostname: PiMaster, node: v18.17.1
    host.PiMaster
    2023-09-18 18:36:41.496	info	Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
    host.PiMaster
    2023-09-18 18:36:41.489	info	iobroker.js-controller version 5.0.12 js-controller starting
    host.PiMaster
    2023-09-18 18:36:36.948	info	terminated
    host.PiMaster
    2023-09-18 18:36:36.832	info	All instances are stopped.
    host.PiMaster
    2023-09-18 18:36:36.831	info	instance system.adapter.zigbee.0 terminated with code 0 (NO_ERROR)
    host.PiMaster
    2023-09-18 18:36:36.795	info	instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
    host.PiMaster
    2023-09-18 18:36:36.781	info	instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
    host.PiMaster
    2023-09-18 18:36:36.780	info	instance system.adapter.discovery.0 terminated with code 0 (NO_ERROR)
    host.PiMaster
    2023-09-18 18:36:36.108	info	stopInstance system.adapter.backitup.0 send kill signal
    host.PiMaster
    2023-09-18 18:36:36.107	info	stopInstance system.adapter.discovery.0 send kill signal
    host.PiMaster
    2023-09-18 18:36:36.106	info	stopInstance system.adapter.zigbee.0 send kill signal
    host.PiMaster
    2023-09-18 18:36:36.103	info	stopInstance system.adapter.admin.0 send kill signal
    host.PiMaster
    2023-09-18 18:36:36.079	info	stopInstance system.adapter.backitup.0 (force=false, process=true)
    host.PiMaster
    2023-09-18 18:36:36.078	info	stopInstance system.adapter.discovery.0 (force=false, process=true)
    host.PiMaster
    2023-09-18 18:36:36.077	info	stopInstance system.adapter.zigbee.0 (force=false, process=true)
    host.PiMaster
    2023-09-18 18:36:36.063	info	stopInstance system.adapter.admin.0 (force=false, process=true)
    host.PiMaster
    2023-09-18 18:36:36.056	info	received SIGTERM
    host.PiMaster
    2023-09-18 18:15:06.462	info	Multihost discovery server stopped after 15 minutes, because only temporarily activated
    host.PiMaster
    2023-09-18 18:00:06.462	info	Multi-host discovery server: service started on 0.0.0.0:50005
    host.PiMaster
    2023-09-18 17:37:56.931	info	Multihost discovery server stopped after 15 minutes, because only temporarily activated
    host.PiMaster
    2023-09-18 17:22:56.932	info	Multi-host discovery server: service started on 0.0.0.0:50005
    @horst-böttcher sagte in Multihost zusamen führen:
    Moin,
    @Thomas-Braun hat Dir hier -> https://forum.iobroker.net/topic/68401/multihost-zusamen-führen/9 doch schon gesagt, dass Du iob/iobroker nicht mit sudo ausführen sollst.
    Bernd
    Horst BöttcherH 1 Antwort Letzte Antwort
      Moin,
      Bernd
      Horst BöttcherH Offline
      Horst Böttcher
      @dp20eic ja hatte mich verschreiben hab es ohne sudo gemacht
      ioBroker auf Proxmox (Debian) auf LENOVO PC Thinkcentre als Produktivsystem
      DJMarc75D ? 2 Antworten Letzte Antwort
        DJMarc75D Offline
        DJMarc75D Offline
        DJMarc75
        nö
        Lehrling seit 1975 !!!
          Moin,
          wirklich?
          Bernd
            Moin,
            wirklich?
            Bernd
            haselchenH Offline
            haselchenH Offline
            haselchen
            @dp20eic
            Zur Verteidigung muss man sagen, dass es so eine Anleitung im Netz gibt.
            https://www.iobroker.net/docu/index-24.htm?page_id=3068&lang=de
            Ab der Version des js-controller v1.1.3 wird die Einrichtung eines Multihost-Systems noch weiter vereinfacht.
            Man gibt beim Master nur noch ein: sudo iobroker multihost enable
            Anschließend auf dem slave: sudo iobroker multihost browse
            Jetzt müssten vorhandene Master angezeigt werden.
            Daraufhin wird mit sudo iobroker multihost connect der entsprechenden Master ausgewählt
            Damit ist die Multihost-Verbindung fertig.
            • haselchenH haselchen
              @dp20eic
              @haselchen
              Im Netz findet man viel veralteten Kram. So wie den von dir verlinkten.
              Die aktuelle Doku ist jedenfalls korrekt ohne sudo:
              https://www.iobroker.net/#de/documentation/config/multihost.md
                @haselchen
                haselchenH Offline
                haselchenH Offline
                haselchen
                Da beides unter iobroker.net läuft , woher soll ein , sagen wir Neuling , das dann unterscheiden?
                Wäre ja evtl.sinnvoll den alten Krams dann vom Netz zu nehmen.
                  @haselchen sagte in Multihost zusamen führen:
                  @Homoran
                    @bahnuhr
                    - Objects database:
                     - Type: jsonl
                     - Port: 9001
                    - States database:
                     - Type: jsonl
                     - Port: 9000
                    pi@PiMaster:~ $
                    Slave
                    - Objects database:
                      - Type: jsonl
                      - Port: 9001
                    - States database:
                      - Type: jsonl
                      - Port: 9000
                    dann
                    ^C
                    pi@PiMaster:~ $
                    und iob restart
                    beim Slave
                    und es kommt nix
                    host.PiMaster
                    host.PiMaster
                    host.PiMaster
                    host.PiMaster
                    host.PiMaster
                    host.PiMaster
                    host.PiMaster
                    host.PiMaster
                    host.PiMaster
                    host.PiMaster
                    host.PiMaster
                    host.PiMaster
                    host.PiMaster
                    host.PiMaster
                    host.PiMaster
                    host.PiMaster
                    host.PiMaster
                    host.PiMaster
                    host.PiMaster
                    host.PiMaster
                    host.PiMaster
                    host.PiMaster
                    host.PiMaster
                    host.PiMaster
                    host.PiMaster
                    host.PiMaster
                    host.PiMaster
                    host.PiMaster
                    host.PiMaster
                    host.PiMaster
                    host.PiMaster
                    host.PiMaster
                    host.PiMaster
                    host.PiMaster
                    host.PiMaster
                    host.PiMaster
                    host.PiMaster
                    host.PiMaster
                    host.PiMaster
                    hast du das gemacht?
                      das ist er seit 2018/20
                        haselchenH Offline
                        haselchenH Offline
                        haselchen
                        Hab doch gerade den Link gepostet?
                        Die Seite ist aufrufbar und zu finden über Google.
                          google vergisst nichts
                          haselchenH Thomas BraunT 2 Antworten Letzte Antwort
                            haselchenH Offline
                            haselchenH Offline
                            haselchen
                            Wenn das noch in irgendeinem Cache steckt, dann ist es bestimmt möglich, anhand der URL, Google zum Löschen zu bewegen ?!
                              @homoran sagte in Multihost zusamen führen:
                              Und ChatGPT vergisst auch nix, erzählt aber dennoch belangloses Gebrabbel.
                                Horst Böttcher
                                @homoran ja hab ich komisch jetzt ist er da
