  3. Off Topic
  4. /bin/sh: 1: hcitool: not found
35 Beiträge 7 Kommentatoren 3.6k Aufrufe 5 Beobachtet
  • PreslP Offline
    PreslP Offline
    Presl
    Kann mir jemand hier helfen...
    Hab das ganze in HomeAssistant wenn ich JS Controller auf Version 4 + Node auf 16 und Admin auf 6 update...
    Starting ioBroker...
    Running 'eval' commands
    library: loaded
    Library version=2022-12-09
        Welcome to the ioBroker installation fixer!
        Script version: 2023-04-02
        Installing prerequisites (1/5)
    Get:1 http://security.debian.org/debian-security buster/updates InRelease [34,8 kB]
    Get:2 http://deb.debian.org/debian buster InRelease [122 kB]
    Get:3 http://deb.debian.org/debian buster-updates InRelease [56,6 kB]
    Get:4 https://deb.nodesource.com/node_12.x buster InRelease [4.584 B]
    Get:5 http://security.debian.org/debian-security buster/updates/main arm64 Packages [542 kB]
    Get:6 http://deb.debian.org/debian buster/main arm64 Packages [7.737 kB]
    Get:7 http://deb.debian.org/debian buster-updates/main arm64 Packages [8.780 B]
    Get:8 https://deb.nodesource.com/node_12.x buster/main arm64 Packages [774 B]
    Fetched 8.506 kB in 4s (2.153 kB/s)
    Reading package lists...
    Installed gcc-c++
    Installed cmake
    Docker detected!
    If you have any adapters that need the CAP_NET_ADMIN capability,
    you need to start the docker container with the option --cap-add=NET_ADMIN
    and manually add that capability to node
        Checking ioBroker user and directory permissions (2/5)
        Check and cleanup npm temporary directories (3/5)
    Done.
        Database maintenance (4/5)
    Checking for uncompressed JSONL databases... This might take a while!
    npx: Installierte 12 in 6.074s
    No path given, using /data/iobroker/iobroker-data
    Compressing /data/iobroker/iobroker-data/states.jsonl
    Compressing /data/iobroker/iobroker-data/objects.jsonl
    Compressed 2 JSONL files. Done
        Checking autostart (5/5)
    Unsupported init system, cannot enable autostart!
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    ================================== > LOG REDIRECT system.adapter.admin.0 => true [starting]
    host.1e14b3fb-iobroker check instance "system.adapter.admin.0" for host "1e14b3fb-iobroker"
    host.1e14b3fb-iobroker check instance "system.adapter.mqtt.0" for host "1e14b3fb-iobroker"
    host.1e14b3fb-iobroker check instance "system.adapter.mqtt-client.0" for host "1e14b3fb-iobroker"
    host.1e14b3fb-iobroker check instance "system.adapter.discovery.0" for host "1e14b3fb-iobroker"
    host.1e14b3fb-iobroker check instance "system.adapter.info.0" for host "1e14b3fb-iobroker"
    host.1e14b3fb-iobroker check instance "system.adapter.gruenbeck.0" for host "1e14b3fb-iobroker"
    Thomas BraunT ? Marc BergM 4 Antworten Letzte Antwort
    • PreslP Presl
      library: loaded
      Installed gcc-c++
      Installed cmake
      Docker detected!
      Done.
      @presl
      iob diag
      und
      apt policy bluez
      sagen?
      node12 ist auch zu alt.
      • PreslP Presl
        library: loaded
        Installed gcc-c++
        Installed cmake
        Docker detected!
        Done.
        @presl sagte in /bin/sh: 1: hcitool: not found:
        Docker detected!
        Seh ich jetzt erst...
        Dann gilt:
        Docker detected!
        PreslP 1 Antwort Letzte Antwort
          Docker detected!
          Dann gilt:
          Docker detected!
          PreslP Offline
          PreslP Offline
          Presl
          @thomas-braun Danke für deine Antwort!!!1
          Kannst du mir hier ein bisschen auf die Sprünge helfen?
          Da ich das ganze unter HA laufen lasse habe ich nur eval wo ich Commands mitschicken kann mit ";" sep.
          node hätte ich eigentlich schon hochgezogen - keine Ahnung warum die jetzt wieder auf 12 ist. War schon auf 18...
          • PreslP Presl
            heisst was genau?
            keine eigene iob Installation?
            node-Version ggf. durch HA festgepinnt?
            erzähl mal mehr über dein Konstrukt
            • PreslP Presl
              library: loaded
              Installed gcc-c++
              Installed cmake
              Docker detected!
              Done.
              Moin,
              ich bin verwirrt, Home Assistant ist eine eigene Hausautomatisierungs-Software, wie kann man darin ein ioBroker laufen lassen?
              Ich kenne da nur die Möglichkeit, dass man sich gegenseitig die jeweiligen Zugriffe erlaubt, einrichtet, mal einfach ausgedrückt.
              Bernd
              • PreslP Presl
                library: loaded
                Installed gcc-c++
                Installed cmake
                Docker detected!
                Done.
                Marc BergM Online
                Marc BergM Online
                Marc Berg
                Abgesehen vom Home Assistant Thema, was ich auch etwas verwirrend finde, kam bei mir auch immer diese Fehlermeldung im Container, bis ich den Info-Adapter deinstalliert habe. Da dieser sowieso nicht weiter entwickelt wird, war die Entscheidung dann einfach.
                Irgendwelche CAP_NET_ADMIN Anpassungen haben übrigens nicht geholfen.
                  Moin,
                  Bernd
                  PreslP Offline
                  PreslP Offline
                  Presl
                  @dp20eic :
                  Man kann unter Add-Ons den Iobroker installieren und dieser läuft dann nehm ich an in so nem Container oder Docker...
                  Bin leider überhaupt nicht in dem Thema drinnen und möchte eigentlich nur meinen Gruenbeck Adapter zum laufen bekommen^^.
                  Aber man lernt nie aus und darum muss ich mich damit mehr befassen.
                  keine eigene iob Installation? -> Home Assistant ist ein eigenes BS für nen Rasp.
                  node-Version ggf. durch HA festgepinnt? -> das kann ich dir leider nicht sagen weil ich mich damit nicht auskenne... Ich hab es geschafft zu updaten und durch die neue node konnte ich dann auch den Admin Adapater installieren welche ich für MQTT benötige.
                  Nach nem Neustart von iobroker ging nichts mehr und ich bekomm hcitool not found.
                  @Marc-Berg: dann werde ich mal versuchen diesen zu deinstallieren - danke!
                  • PreslP Presl
                    @dp20eic :
                    Marc BergM Online
                    Marc BergM Online
                    Marc Berg
                    Dass "nichts mehr geht" ist jetzt eine neue Information für mich. Das wird nicht am Info-Adapter liegen.
                    • Marc BergM Marc Berg
                      PreslP Offline
                      PreslP Offline
                      Presl
                      @marc-berg:
                      hab ich auch grad festgestellt^^. Hat nichts geholfen. Sehr komisch ich komm einfach nicht mehr in die UI rein...
                      • PreslP Presl
                        @marc-berg:
                        PreslP Offline
                        PreslP Offline
                        Presl
                        @presl: Ich kann auch den neuen JS Controller gar nicht installieren auf diesem System da bekomme ich immer diverse Fehler. Wobei das System lief mit Version 4... bis zum neustart.
                        • PreslP Presl
                          mcm1957M Offline
                          mcm1957M Offline
                          mcm1957
                          Also dass HOME ASSISTENT eine BETRIEBSSYSTEM ist wäre mir neu. Ich glaub da ahst du was falschg verstanden. Du kannst home assistent mittels Assistenten auf einem Pi installieren - der installierte dir dann eine Basis (Rapian, Linuxvariente, ...) und das eigentlich homeassistent.
                          Wie es homeassistent dann schafft ioBroker zu installierne - keine Ahnung. Aber ob in diesem Umfeld überhaupt eine Aktualisierung von node und js-controller möglich ist wird dir eher im homeassistent support wer sagen können.
                          Edit:
                          Offensichtlich wird das Einrichten einer dedizierten homeassitant installation auf einem Pi wirklich als Betriebssysteminstallation bezeichnet:
                          https://www.home-assistant.io/installation/raspberrypi/
                          man lernt nie aus ...
                          Support Repositoryverwaltung.
                          LESEN - gute Forenbeitrage
                          PreslP ? 2 Antworten Letzte Antwort
                          • mcm1957M mcm1957
                            Edit:
                            PreslP Offline
                            PreslP Offline
                            Presl
                            schrieb am zuletzt editiert von Presl
                            @mcm57 said in /bin/sh: 1: hcitool: not found:
                            genau so gut kenn ich mich aus^^. Dachte ich zumindest.
                            Bin halt völlig in der Windows-welt :) und durch Smart Home hier reingekommen.
                            Update:
                            haha hatte ich doch recht - wie gesagt ich bin voll der noob mit Linux und so
                            • PreslP Presl
                              Update:
                              mcm1957M Offline
                              mcm1957M Offline
                              mcm1957
                              @presl
                              Aber wie hast du ioBroker dann auf einem Pi installiert das du mit homeassistant initialisiert hast installiert? Wenn ich mal auf homeassistent suche gibts keine iobroker integration.
                              • mcm1957M mcm1957
                                @presl
                                @mcm57 sagte in /bin/sh: 1: hcitool: not found:
                                Moin,
                                gibt es auch nicht, man kann entweder, in ioBroker z. B. mqtt installieren, und die Datenpunkte, die man in Home Assistant (HA) haben möchte Publishen/Subscriben und in HA dann mittels mqtt Client hineinziehen, oder andersherum in ioBroker den Adapter installieren und HA anbinden, mal ganz platt gesprochen.
                                Da ich aber noch eine VM vom HA habe, werde ich mich mal dransetzen und nachschauen.
                                Bernd
                                Edit
                                Unter den AddOn in HA, gibt es nichts zu ioBroker
                                Unter Integration gibt es kein ioBroker
                                Auch im HACS kein ioBroker
                                • mcm1957M mcm1957
                                  Edit:
                                  Moin,
                                  ja es gibt, nicht nur für SBCs, sondern auch ganz allgemein, z. B. als VM Abbild das sogenannte HAOS → https://developers.home-assistant.io/docs/operating-system/ das ist ein fertig konfiguriertes Linux, so weit ich das sehe, dient Alpine → https://www.alpinelinux.org/ als Unterbau
                                  Edit
                                  Jetzt könnte man auf die Idee kommen, parallel mittels Einzeiler, auch noch den ioBroker auf dem HAOS zu installieren, das birgt aber Gefahren, oder spezielles KnowHoff.
                                  • Alpine nutzt nicht apt, sondern einen anderen Paketmanager → apk
                                  • Home Assistant bringt monatliche Updates, von HA Core, das entspricht in etwas ioBroker , aber es gibt auch alle paar Monate Updates vom HAOS sobald die eingespielt werden, ist alles futsch, was man sich da selbst installiert hat, deshalb gibt es einige Standard Programme als AddOn, z. B. InfluxDB, Grafana
                                  Bernd
                                    Moin,
                                    Edit
                                    Bernd
                                    mcm1957M Offline
                                    mcm1957M Offline
                                    mcm1957
                                    So ...
                                    Ich hab jetzt hier mal gesucht. Es gibt ein iobroker addon (ev. auch noch andere).
                                    Das von mir gefundene liegt hier:
                                    https://github.com/MaxWinterstein/homeassistant-addons/tree/main/ioBroker
                                    Ob dieses addon das "Richtige" ist muss @presl bestätigen bzw. korrigieren.
                                    So wie es für mich aussieht wird da ioBroker irgendwie via container installiert.
                                    Es stellt sich aber die Frage ob das Problem nicht besser bei homeassistant aufgehoben wäre.
                                    mcm1957M ? PreslP 3 Antworten Letzte Antwort
                                    • mcm1957M mcm1957
                                      So ...
                                      mcm1957M Offline
                                      mcm1957M Offline
                                      mcm1957
                                      Und wie ich sehe gibts von @Presl auch schon ein issue im oben genannten Repo.
                                      Wär schön gewesen, wenn er hier gleich alle Infos die er hat gepostet hätte :-)
                                      https://github.com/MaxWinterstein/homeassistant-addons/issues/184
                                      https://github.com/MaxWinterstein/homeassistant-addons/issues/159
                                      Offensichttlich wird hier der buanet container 5.1.0 verwendet. Ob es Sinn macht bzw. überhaupt möglich ist IN diesem node und ioBroker zu aktualiseren weiß ich nicht. Aktuell ist jedenfalls 8.x.x
                                      Wahrscheinlich wäre die saubere Vorgangsweise das addOn zu aktualisieren
                                      • mcm1957M mcm1957
                                        So ...
                                        Moin,
                                        Danke fürs Suchen, aber erstens nichts Offizielles von HA und der Container ist ja Asbach Uralt
                                        ARG BUILD_FROM=buanet/iobroker:v5.1.0
                                        FROM ${BUILD_FROM}
                                        # copy over the patched iobroker_startup.sh
                                        COPY iobroker_startup.sh /opt/scripts/iobroker_startup.sh
                                        RUN chmod a+x /opt/scripts/iobroker_startup.sh
                                        Das ist mir zu viel gewürgte, bin dann mal raus.
                                        Bernd
                                        Sehe ich genauso.
                                          Moin,
                                          FROM ${BUILD_FROM}
                                          Bernd
                                          Sehe ich genauso.
                                          mcm1957M Offline
                                          mcm1957M Offline
                                          mcm1957
                                          @dp20eic
                                          Ja das gepantschte Startupskrikt hat bei mir auch Alarmglocken ausgelöst...
                                          @Presl
                                          Ich glaub du musst dich da wirklich an den Maintainer dieses addOns wenden.
                                          Alternativ installiert dir ioBroker nativ oder via Container auf einem System.
                                          82.7k
