  3. Off Topic
  4. /bin/sh: 1: hcitool: not found
    6.0k
35 Beiträge 7 Kommentatoren 4.1k Aufrufe 5 Beobachtet
  • PreslP Presl
    Kann mir jemand hier helfen...
    Hab das ganze in HomeAssistant wenn ich JS Controller auf Version 4 + Node auf 16 und Admin auf 6 update...
    Starting ioBroker...
    Running 'eval' commands
    library: loaded
    Library version=2022-12-09
        Welcome to the ioBroker installation fixer!
        Script version: 2023-04-02
        Installing prerequisites (1/5)
    Get:1 http://security.debian.org/debian-security buster/updates InRelease [34,8 kB]
    Get:2 http://deb.debian.org/debian buster InRelease [122 kB]
    Get:3 http://deb.debian.org/debian buster-updates InRelease [56,6 kB]
    Get:4 https://deb.nodesource.com/node_12.x buster InRelease [4.584 B]
    Get:5 http://security.debian.org/debian-security buster/updates/main arm64 Packages [542 kB]
    Get:6 http://deb.debian.org/debian buster/main arm64 Packages [7.737 kB]
    Get:7 http://deb.debian.org/debian buster-updates/main arm64 Packages [8.780 B]
    Get:8 https://deb.nodesource.com/node_12.x buster/main arm64 Packages [774 B]
    Fetched 8.506 kB in 4s (2.153 kB/s)
    Reading package lists...
    Installed gcc-c++
    Installed cmake
    Docker detected!
    If you have any adapters that need the CAP_NET_ADMIN capability,
    you need to start the docker container with the option --cap-add=NET_ADMIN
    and manually add that capability to node
        Checking ioBroker user and directory permissions (2/5)
        Check and cleanup npm temporary directories (3/5)
    Done.
        Database maintenance (4/5)
    Checking for uncompressed JSONL databases... This might take a while!
    npx: Installierte 12 in 6.074s
    No path given, using /data/iobroker/iobroker-data
    Compressing /data/iobroker/iobroker-data/states.jsonl
    Compressing /data/iobroker/iobroker-data/objects.jsonl
    Compressed 2 JSONL files. Done
        Checking autostart (5/5)
    Unsupported init system, cannot enable autostart!
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    ================================== > LOG REDIRECT system.adapter.admin.0 => true [starting]
    host.1e14b3fb-iobroker check instance "system.adapter.admin.0" for host "1e14b3fb-iobroker"
    host.1e14b3fb-iobroker check instance "system.adapter.mqtt.0" for host "1e14b3fb-iobroker"
    host.1e14b3fb-iobroker check instance "system.adapter.mqtt-client.0" for host "1e14b3fb-iobroker"
    host.1e14b3fb-iobroker check instance "system.adapter.discovery.0" for host "1e14b3fb-iobroker"
    host.1e14b3fb-iobroker check instance "system.adapter.info.0" for host "1e14b3fb-iobroker"
    host.1e14b3fb-iobroker check instance "system.adapter.gruenbeck.0" for host "1e14b3fb-iobroker"
    Marc BergM Offline
    Marc BergM Offline
    Marc Berg
    @presl sagte in /bin/sh: 1: hcitool: not found:
    Abgesehen vom Home Assistant Thema, was ich auch etwas verwirrend finde, kam bei mir auch immer diese Fehlermeldung im Container, bis ich den Info-Adapter deinstalliert habe. Da dieser sowieso nicht weiter entwickelt wird, war die Entscheidung dann einfach.
    Irgendwelche CAP_NET_ADMIN Anpassungen haben übrigens nicht geholfen.
      Moin,
      ich bin verwirrt, Home Assistant ist eine eigene Hausautomatisierungs-Software, wie kann man darin ein ioBroker laufen lassen?
      Ich kenne da nur die Möglichkeit, dass man sich gegenseitig die jeweiligen Zugriffe erlaubt, einrichtet, mal einfach ausgedrückt.
      Bernd
      PreslP Offline
      PreslP Offline
      Presl
      @dp20eic :
      Man kann unter Add-Ons den Iobroker installieren und dieser läuft dann nehm ich an in so nem Container oder Docker...
      Bin leider überhaupt nicht in dem Thema drinnen und möchte eigentlich nur meinen Gruenbeck Adapter zum laufen bekommen^^.
      Aber man lernt nie aus und darum muss ich mich damit mehr befassen.
      keine eigene iob Installation? -> Home Assistant ist ein eigenes BS für nen Rasp.
      node-Version ggf. durch HA festgepinnt? -> das kann ich dir leider nicht sagen weil ich mich damit nicht auskenne... Ich hab es geschafft zu updaten und durch die neue node konnte ich dann auch den Admin Adapater installieren welche ich für MQTT benötige.
      Nach nem Neustart von iobroker ging nichts mehr und ich bekomm hcitool not found.
      @Marc-Berg: dann werde ich mal versuchen diesen zu deinstallieren - danke!
      • PreslP Presl
        @dp20eic :
        Marc BergM Offline
        Marc BergM Offline
        Marc Berg
        Dass "nichts mehr geht" ist jetzt eine neue Information für mich. Das wird nicht am Info-Adapter liegen.
        PreslP 1 Antwort Letzte Antwort
        • Marc BergM Marc Berg
          PreslP Offline
          PreslP Offline
          Presl
          @marc-berg:
          hab ich auch grad festgestellt^^. Hat nichts geholfen. Sehr komisch ich komm einfach nicht mehr in die UI rein...
          • PreslP Presl
            @marc-berg:
            PreslP Offline
            PreslP Offline
            Presl
            @presl: Ich kann auch den neuen JS Controller gar nicht installieren auf diesem System da bekomme ich immer diverse Fehler. Wobei das System lief mit Version 4... bis zum neustart.
            • PreslP Presl
              mcm1957M Offline
              mcm1957M Offline
              mcm1957
              Also dass HOME ASSISTENT eine BETRIEBSSYSTEM ist wäre mir neu. Ich glaub da ahst du was falschg verstanden. Du kannst home assistent mittels Assistenten auf einem Pi installieren - der installierte dir dann eine Basis (Rapian, Linuxvariente, ...) und das eigentlich homeassistent.
              Wie es homeassistent dann schafft ioBroker zu installierne - keine Ahnung. Aber ob in diesem Umfeld überhaupt eine Aktualisierung von node und js-controller möglich ist wird dir eher im homeassistent support wer sagen können.
              Edit:
              Offensichtlich wird das Einrichten einer dedizierten homeassitant installation auf einem Pi wirklich als Betriebssysteminstallation bezeichnet:
              https://www.home-assistant.io/installation/raspberrypi/
              man lernt nie aus ...
              Support Repositoryverwaltung.
              LESEN - gute Forenbeitrage
              PreslP ? 2 Antworten Letzte Antwort
              • mcm1957M mcm1957
                Edit:
                PreslP Offline
                PreslP Offline
                Presl
                schrieb am zuletzt editiert von Presl
                @mcm57 said in /bin/sh: 1: hcitool: not found:
                genau so gut kenn ich mich aus^^. Dachte ich zumindest.
                Bin halt völlig in der Windows-welt :) und durch Smart Home hier reingekommen.
                Update:
                haha hatte ich doch recht - wie gesagt ich bin voll der noob mit Linux und so
                • PreslP Presl
                  Update:
                  mcm1957M Offline
                  mcm1957M Offline
                  mcm1957
                  @presl
                  Aber wie hast du ioBroker dann auf einem Pi installiert das du mit homeassistant initialisiert hast installiert? Wenn ich mal auf homeassistent suche gibts keine iobroker integration.
                  • mcm1957M mcm1957
                    @presl
                    @mcm57 sagte in /bin/sh: 1: hcitool: not found:
                    Moin,
                    gibt es auch nicht, man kann entweder, in ioBroker z. B. mqtt installieren, und die Datenpunkte, die man in Home Assistant (HA) haben möchte Publishen/Subscriben und in HA dann mittels mqtt Client hineinziehen, oder andersherum in ioBroker den Adapter installieren und HA anbinden, mal ganz platt gesprochen.
                    Da ich aber noch eine VM vom HA habe, werde ich mich mal dransetzen und nachschauen.
                    Bernd
                    Edit
                    Unter den AddOn in HA, gibt es nichts zu ioBroker
                    Unter Integration gibt es kein ioBroker
                    Auch im HACS kein ioBroker
                    • mcm1957M mcm1957
                      Edit:
                      Moin,
                      ja es gibt, nicht nur für SBCs, sondern auch ganz allgemein, z. B. als VM Abbild das sogenannte HAOS → https://developers.home-assistant.io/docs/operating-system/ das ist ein fertig konfiguriertes Linux, so weit ich das sehe, dient Alpine → https://www.alpinelinux.org/ als Unterbau
                      Edit
                      Jetzt könnte man auf die Idee kommen, parallel mittels Einzeiler, auch noch den ioBroker auf dem HAOS zu installieren, das birgt aber Gefahren, oder spezielles KnowHoff.
                      • Alpine nutzt nicht apt, sondern einen anderen Paketmanager → apk
                      • Home Assistant bringt monatliche Updates, von HA Core, das entspricht in etwas ioBroker , aber es gibt auch alle paar Monate Updates vom HAOS sobald die eingespielt werden, ist alles futsch, was man sich da selbst installiert hat, deshalb gibt es einige Standard Programme als AddOn, z. B. InfluxDB, Grafana
                      Bernd
                        Moin,
                        Edit
                        Bernd
                        mcm1957M Offline
                        mcm1957M Offline
                        mcm1957
                        So ...
                        Ich hab jetzt hier mal gesucht. Es gibt ein iobroker addon (ev. auch noch andere).
                        Das von mir gefundene liegt hier:
                        https://github.com/MaxWinterstein/homeassistant-addons/tree/main/ioBroker
                        Ob dieses addon das "Richtige" ist muss @presl bestätigen bzw. korrigieren.
                        So wie es für mich aussieht wird da ioBroker irgendwie via container installiert.
                        Es stellt sich aber die Frage ob das Problem nicht besser bei homeassistant aufgehoben wäre.
                        mcm1957M ? PreslP 3 Antworten Letzte Antwort
                        • mcm1957M mcm1957
                          So ...
                          mcm1957M Offline
                          mcm1957M Offline
                          mcm1957
                          Und wie ich sehe gibts von @Presl auch schon ein issue im oben genannten Repo.
                          Wär schön gewesen, wenn er hier gleich alle Infos die er hat gepostet hätte :-)
                          https://github.com/MaxWinterstein/homeassistant-addons/issues/184
                          https://github.com/MaxWinterstein/homeassistant-addons/issues/159
                          Offensichttlich wird hier der buanet container 5.1.0 verwendet. Ob es Sinn macht bzw. überhaupt möglich ist IN diesem node und ioBroker zu aktualiseren weiß ich nicht. Aktuell ist jedenfalls 8.x.x
                          Wahrscheinlich wäre die saubere Vorgangsweise das addOn zu aktualisieren
                          • mcm1957M mcm1957
                            So ...
                            Moin,
                            Danke fürs Suchen, aber erstens nichts Offizielles von HA und der Container ist ja Asbach Uralt
                            ARG BUILD_FROM=buanet/iobroker:v5.1.0
                            FROM ${BUILD_FROM}
                            # copy over the patched iobroker_startup.sh
                            COPY iobroker_startup.sh /opt/scripts/iobroker_startup.sh
                            RUN chmod a+x /opt/scripts/iobroker_startup.sh
                            Das ist mir zu viel gewürgte, bin dann mal raus.
                            Bernd
                            Sehe ich genauso.
                              Moin,
                              FROM ${BUILD_FROM}
                              Bernd
                              Sehe ich genauso.
                              mcm1957M Offline
                              mcm1957M Offline
                              mcm1957
                              @dp20eic
                              Ja das gepantschte Startupskrikt hat bei mir auch Alarmglocken ausgelöst...
                              @Presl
                              Ich glaub du musst dich da wirklich an den Maintainer dieses addOns wenden.
                              Alternativ installiert dir ioBroker nativ oder via Container auf einem System.
                              • mcm1957M mcm1957
                                So ...
                                PreslP Offline
                                PreslP Offline
                                Presl
                                @presl Habs schon dort gepostet... aber so wirklich bekomm ich keine antwort :/
                                Sorry fürs nicht bescheid geben!!!!
                                Eigentlich hätte ich gerne eine andere Lösung aber gibts sonst nix :/.
                                Danke trotzdem.
                                mcm1957M ? 2 Antworten Letzte Antwort
                                • PreslP Presl
                                  Danke trotzdem.
                                  mcm1957M Offline
                                  mcm1957M Offline
                                  mcm1957
                                  @presl
                                  Na ja, du könntest eine ganz normale ioBroker Installation auf einem unterstützen Betriebssystem (linux, windows, mac-os) oder in einem docker container laufen lassen. Als hardware ist so fast alles geeignet was linux (oder windows) order docker verdaut, z.B. x86 Rechner, Pi4(ev. Pi3), div. synology NAS, ...
                                  Im Bedarfsfall gibts hier sicher Leute die dir da besser als ich eine für dich geeignete Hardware empfehlen können wenn klar ist was du wie machen willst (bzw. schon machst).
                                  • mcm1957M mcm1957
                                    @presl
                                    PreslP Offline
                                    PreslP Offline
                                    Presl
                                    @mcm57 ich glaub das zahlt sich dafür nicht aus...
                                    ich will nur einen sensor ansprechen aus meiner Entkalkungsanlage^^.
                                    • PreslP Presl
                                      mcm1957M Offline
                                      mcm1957M Offline
                                      mcm1957
                                      @presl
                                      Und was ist das für eins Sensor? Gibts da keinen geeigneten Adapter in homeassistent?
                                      Ja, für einen Sensor alleine ist ioBroker ein gewisser Overhead. Aber vielleicht kannst ja den Rest auch zu ioBroker migrieren :-) :-) :-)
                                      Im Ernst:
                                      Ev. kannst du bei homeassist ein addOn finden, dass dir ermöglicht ein beliebiges docker image zu starten. Und dort könntest du dann eventuell das buanet iobroker docker image mit node 18 laden / starten. Ich bin aber kein docker Kenner keine Ahnung ob bzw. welche Fallen da ev. existieren.
                                      • PreslP Presl
                                        Danke trotzdem.
                                        Moin,
                                        wie ja schon angemerkt wurde, ist das kein offizielles AddOn von HA, Du könntest ja einen Fork davon erstellen und dann baust Du das so um, dass anstatt des drei Jahre alten buanet/iobroker:5.1.x, ein aktuelles genommen wird. Auf welche Probleme Du dann stößt, kann ich natürlich nicht vorhersagen.
                                        Ist ja eh schon seltsam, dass drei Jahre nichts mehr gemacht wurde.
                                        Du nutzt HA und da gibt es für ein Gerät kein Adapter/Integrität? Dann solltest Du mal bei HA anfragen, ob da nicht noch mehr Personen Bedarf haben.
                                        Soweit ich das gesehen habe, geht es um den gruenbeck Adapter, oder?
                                        Dafür gibt es ein Feature Rquest https://community.home-assistant.io/t/new-integration-grunbeck-softliq/157478/39 in HA
                                        Bernd
                                          SHL59
                                          Moin Zusammen,
                                          ich klinke mich mal hier in diese ja noch recht aktuelle Diskussion ein, da meine Frage mit dem eigentlichen Thema (/bin/sh: 1: hcitool: not found) zu tun hat.
                                          Ich bin vor ein paar Tagen mit meinem ioBroker von einem Raspberry Pi4 auf meine QNAP NAS (TS251+) in die Container Station (Docker) umgezogen.
                                          Das hat auch alles gut funktioniert und innerhalb von gut 2 Stunden lief alles wieder in der neuen Umgebung, einzig die von mir viel genutzten justGage Widgets funktionieren in meinen Views nicht mehr 😢 .
                                          Dazu werde ich die Tage einen neuen Beitrag im Forum eröffnen.
                                          Nun zur eigentlichen Frage(n):
                                          Mit dem Start des ioBrokers bekomme ich am Ende des Logs folgende Meldungen:
                                          • /bin/sh: 1: mdadm: not found
                                          • /bin/sh: 1: hcitool: not found
                                          Was hat das zu bedeuten?
                                          Was bewirken diese Dienste?
                                          Muss/kann ich etwas tun und ggf. wie?
                                          Ist das evtl. kritisch für bestimmte Funktionen?
                                          Hier noch einige Systeminformationen:
                                          System Information
                                          • arch: x86_64
                                          • hostname: iobroker-Prod
                                            Version Information
                                          • image: v9.0.1
                                            build: 2023-11-01T23:44:45+00:00
                                          • node: v18.18.2
                                          • npm: 9.8.1
                                            Evironment Variables
                                          • IOB_BACKITUP_EXTDB: true
                                          • PACKAGES: default-mysql-client
                                            SETGID: 1000
                                            SETUID: 1000
                                          Ich hoffe auf Euren Expertenrat.
                                          Viele Grüße
                                          Stefan
