wie Enigma2 Update f. js-Controller 5
[[topic:post-is-deleted]]
Jetzt bin ich aber schon langsam überfordert. Mein Ziel ist nur dass der enigma2 wieder geht
@krisiun said in js-controller 5.0.x jetzt für alle User im STABLE!:
Ok, enigma in der aktuellen Version (2.x.x aus latest) sollte mit js-controller 5 gehen. Wenn nicht,
mach bitte ein eigenes Topic auf, verlink es hier und stell in das neue Topic alle Versionsangaben und den Logoutput. -
2023-09-14 22:37:30.728 - error: host.raspberrypi4-iob Caught by controller[0]: node:internal/modules/cjs/loader:1080 2023-09-14 22:37:30.729 - error: host.raspberrypi4-iob Caught by controller[0]: throw err; 2023-09-14 22:37:30.729 - error: host.raspberrypi4-iob Caught by controller[0]: ^ 2023-09-14 22:37:30.729 - error: host.raspberrypi4-iob Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js' 2023-09-14 22:37:30.729 - error: host.raspberrypi4-iob Caught by controller[0]: Require stack: 2023-09-14 22:37:30.729 - error: host.raspberrypi4-iob Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.enigma2/lib/utils.js 2023-09-14 22:37:30.729 - error: host.raspberrypi4-iob Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.enigma2/main.js 2023-09-14 22:37:30.729 - error: host.raspberrypi4-iob Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15) 2023-09-14 22:37:30.730 - error: host.raspberrypi4-iob Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:922:27) 2023-09-14 22:37:30.730 - error: host.raspberrypi4-iob Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19) 2023-09-14 22:37:30.730 - error: host.raspberrypi4-iob Caught by controller[0]: at require (node:internal/modules/cjs/helpers:121:18) 2023-09-14 22:37:30.730 - error: host.raspberrypi4-iob Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.enigma2/lib/utils.js:46:25) 2023-09-14 22:37:30.730 - error: host.raspberrypi4-iob Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14) 2023-09-14 22:37:30.730 - error: host.raspberrypi4-iob Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10) 2023-09-14 22:37:30.730 - error: host.raspberrypi4-iob Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32) 2023-09-14 22:37:30.730 - error: host.raspberrypi4-iob Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:960:12) 2023-09-14 22:37:30.731 - error: host.raspberrypi4-iob Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19) { 2023-09-14 22:37:30.731 - error: host.raspberrypi4-iob Caught by controller[0]: code: 'MODULE_NOT_FOUND', 2023-09-14 22:37:30.731 - error: host.raspberrypi4-iob Caught by controller[0]: requireStack: [ 2023-09-14 22:37:30.731 - error: host.raspberrypi4-iob Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.enigma2/lib/utils.js', 2023-09-14 22:37:30.731 - error: host.raspberrypi4-iob Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.enigma2/main.js' 2023-09-14 22:37:30.731 - error: host.raspberrypi4-iob Caught by controller[0]: ] 2023-09-14 22:37:30.732 - error: host.raspberrypi4-iob Caught by controller[0]: } 2023-09-14 22:37:30.732 - error: host.raspberrypi4-iob Caught by controller[0]: Node.js v18.17.1 2023-09-14 22:37:30.732 - error: host.raspberrypi4-iob instance system.adapter.enigma2.0 terminated with code 1 (JS_CONTROLLER_STOPPED) -
@krisiun sagte in js-controller 5.0.x jetzt für alle User im STABLE!:
Dann installier die aktuelle (Beta)-Version, die ist zum js-controller5 kompatibel gemacht worden.
@thomas-braun sagte in js-controller 5.0.x jetzt für alle User im STABLE!:
Habe ich doch schon
@krisiun
Der log ist NICHT von der 1.4.0 oder einer 2.0.0 sondern von der alten 1.3.x die nicht js-controller 5 fähig ist.Und bitte mach dafür wirklich einen getrennten Thread (= neues Topic) auf.
Danke -
Habe ich doch schon
Habe ich doch schon
iob updatesagt? Vollständigst posten...
Wie bekomme ich mein backup von gestern wieder drauf? Da hat´s wenigstens alles funktioniert
Siehe mein Posting von vor 5 Minuten
Siehe Eröffnungsposting im Abschnitt 'VOR der Installation' -
Used repository: Stable (default) Adapter "admin" : 6.8.0 , installed 6.8.0 Adapter "alexa2" : 3.24.1 , installed 3.24.1 Adapter "backitup" : 2.6.23 , installed 2.6.23 Adapter "broadlink2" : 2.1.5 , installed 2.1.5 Adapter "cloud" : 4.4.1 , installed 4.4.1 Adapter "discovery" : 3.1.0 , installed 3.1.0 Adapter "echarts" : 1.5.1 , installed 1.5.1 Adapter "firetv" : 1.0.0 , installed 1.0.0 Adapter "flot" : 1.12.0 , installed 1.12.0 Adapter "geofency" : 1.2.4 , installed 1.2.4 Adapter "history" : 2.2.6 , installed 2.2.6 Adapter "hmip" : 1.20.0 , installed 1.20.0 Adapter "info" : 1.9.26 , installed 1.9.26 Adapter "iot" : 1.14.5 , installed 1.14.5 Adapter "javascript" : 7.0.3 , installed 7.0.3 Controller "js-controller": 5.0.12 , installed 5.0.12 Adapter "mihome-vacuum": 3.11.0 , installed 3.11.0 Adapter "parcel" : 0.0.27 , installed 0.0.27 Adapter "philips-tv" : 0.5.3 , installed 0.5.3 Adapter "ping" : 1.6.2 , installed 1.6.2 Adapter "pushover" : 3.0.3 , installed 3.0.3 Adapter "scenes" : 2.3.9 , installed 2.3.9 Adapter "shelly" : 6.4.1 , installed 6.4.1 Adapter "simple-api" : 2.7.2 , installed 2.7.2 Adapter "socketio" : 6.5.3 , installed 6.5.3 Adapter "sonoff" : 2.5.3 , installed 2.5.3 Adapter "tankerkoenig" : 3.3.7 , installed 3.3.7 Adapter "telegram" : 1.16.0 , installed 1.16.0 Adapter "text2command" : 3.0.2 , installed 3.0.2 Adapter "tr-064" : 4.2.18 , installed 4.2.18 Adapter "tuya" : 3.14.2 , installed 3.14.2 Adapter "vis" : 1.4.16 , installed 1.4.16 Adapter "web" : 6.1.1 , installed 6.1.1 Adapter "ws" : 2.5.4 , installed 2.5.4 Adapter "yahka" : 1.0.3 , installed 1.0.3 pi@raspberrypi4-iob:~ $ pi@raspberrypi4-iob:~ $ iob update Used repository: Stable (default) Adapter "admin" : 6.8.0 , installed 6.8.0 Adapter "alexa2" : 3.24.1 , installed 3.24.1 Adapter "backitup" : 2.6.23 , installed 2.6.23 Adapter "broadlink2" : 2.1.5 , installed 2.1.5 Adapter "cloud" : 4.4.1 , installed 4.4.1 Adapter "discovery" : 3.1.0 , installed 3.1.0 Adapter "echarts" : 1.5.1 , installed 1.5.1 Adapter "firetv" : 1.0.0 , installed 1.0.0 Adapter "flot" : 1.12.0 , installed 1.12.0 Adapter "geofency" : 1.2.4 , installed 1.2.4 Adapter "history" : 2.2.6 , installed 2.2.6 Adapter "hmip" : 1.20.0 , installed 1.20.0 -
Used repository: Stable (default) Adapter "admin" : 6.8.0 , installed 6.8.0 Adapter "alexa2" : 3.24.1 , installed 3.24.1 Adapter "backitup" : 2.6.23 , installed 2.6.23 Adapter "broadlink2" : 2.1.5 , installed 2.1.5 Adapter "cloud" : 4.4.1 , installed 4.4.1 Adapter "discovery" : 3.1.0 , installed 3.1.0 Adapter "echarts" : 1.5.1 , installed 1.5.1 Adapter "firetv" : 1.0.0 , installed 1.0.0 Adapter "flot" : 1.12.0 , installed 1.12.0 Adapter "geofency" : 1.2.4 , installed 1.2.4 Adapter "history" : 2.2.6 , installed 2.2.6 Adapter "hmip" : 1.20.0 , installed 1.20.0 Adapter "info" : 1.9.26 , installed 1.9.26 Adapter "iot" : 1.14.5 , installed 1.14.5 Adapter "javascript" : 7.0.3 , installed 7.0.3 Controller "js-controller": 5.0.12 , installed 5.0.12 Adapter "mihome-vacuum": 3.11.0 , installed 3.11.0 Adapter "parcel" : 0.0.27 , installed 0.0.27 Adapter "philips-tv" : 0.5.3 , installed 0.5.3 Adapter "ping" : 1.6.2 , installed 1.6.2 Adapter "pushover" : 3.0.3 , installed 3.0.3 Adapter "scenes" : 2.3.9 , installed 2.3.9 Adapter "shelly" : 6.4.1 , installed 6.4.1 Adapter "simple-api" : 2.7.2 , installed 2.7.2 Adapter "socketio" : 6.5.3 , installed 6.5.3 Adapter "sonoff" : 2.5.3 , installed 2.5.3 Adapter "tankerkoenig" : 3.3.7 , installed 3.3.7 Adapter "telegram" : 1.16.0 , installed 1.16.0 Adapter "text2command" : 3.0.2 , installed 3.0.2 Adapter "tr-064" : 4.2.18 , installed 4.2.18 Adapter "tuya" : 3.14.2 , installed 3.14.2 Adapter "vis" : 1.4.16 , installed 1.4.16 Adapter "web" : 6.1.1 , installed 6.1.1 Adapter "ws" : 2.5.4 , installed 2.5.4 Adapter "yahka" : 1.0.3 , installed 1.0.3 pi@raspberrypi4-iob:~ $ pi@raspberrypi4-iob:~ $ iob update Used repository: Stable (default) Adapter "admin" : 6.8.0 , installed 6.8.0 Adapter "alexa2" : 3.24.1 , installed 3.24.1 Adapter "backitup" : 2.6.23 , installed 2.6.23 Adapter "broadlink2" : 2.1.5 , installed 2.1.5 Adapter "cloud" : 4.4.1 , installed 4.4.1 Adapter "discovery" : 3.1.0 , installed 3.1.0 Adapter "echarts" : 1.5.1 , installed 1.5.1 Adapter "firetv" : 1.0.0 , installed 1.0.0 Adapter "flot" : 1.12.0 , installed 1.12.0 Adapter "geofency" : 1.2.4 , installed 1.2.4 Adapter "history" : 2.2.6 , installed 2.2.6 Adapter "hmip" : 1.20.0 , installed 1.20.0@krisiun
Enigma kannst du nur via latest / beta repository aktualisisern. Du benutzt derzeit das stable repository daher wird dir dort kein Eniga Update angezeigt.Für weitere Hilfe zur Installation eines Adapters von Lastest eröffne bitte einen neuen Thread - ein neues Topic. Hier werde ich zu reinen Installationsfragen nicht weiter eingehen. Nicht böse sein, aber dieses Topic soll sich mit js-controller 5 und allfälligen direkt damit zusammenhängenden Problemen und Fragen beschäaftigen.
@krisiun
@mcm57 sagte in js-controller 5.0.x jetzt für alle User im STABLE!:
@krisiun
Enigma kannst du nur via latest / beta repository aktualisisern. Du benutzt derzeit das stable repository daher wird dir dort kein Eniga Update angezeigt.Für weiter Hilfe zur Installation eines Adapters von Lastest eröffne bitte einen neuen Thread - ein neues Topic. Hier werde cih zu reinen Installationsfragen nicht weiter eingehen. Nicht böse sein, aber dieses Topic soll sich mit js-controller 5 und allfälligen direkt damit zusammenhängenden Problemen und Fragen beschäaftigen.
Du hast ja leicht zu reden. Ich hab da überhaupt keine ahnung wo von du da sprichtst. Will nur mein Backup hinbekommen und dann wäre alles gut. Aber das klappt nicht
@foxriver76 said in js-controller 5.0.x jetzt für alle User im STABLE!:
@liv-in-sky Im Endeffekt iwo ein binding in vis, welches mist macht. Aber ich denke wir sollten noch eine neue Web Adapter Version machen weil ist eigentlich gefixt in socket classes aber dafür müsste web Adapter neu installiert oder geupdated werden.
Ab morgen sollte eine neue Release von web / ws / socketio im stable angeboten werden, die dieses Problem (invalid bindings in vis) fixed. Danke an @foxriver76 für die schnelle Release.
Die habe ich schon heute als updates bekommen. Hat aber nicht weiter geholfen
@krisiun
@krisiun
iob upgrade enigma2@2.0.3sollte tun@foxriver76 sagte in js-controller 5.0.x jetzt für alle User im STABLE!:
iobroker start pi@raspberrypi4-iob:~ $ iob upgrade enigma2@2.0.3 Adapter "enigma2" is not in the repository and cannot be updated. -
host.raspberrypi4-iob 2023-09-14 23:10:10.047 error instance system.adapter.enigma2.0 terminated with code 1 (JS_CONTROLLER_STOPPED) host.raspberrypi4-iob 2023-09-14 23:10:10.047 error Caught by controller[0]: Node.js v18.17.1 host.raspberrypi4-iob 2023-09-14 23:10:10.047 error Caught by controller[0]: } host.raspberrypi4-iob 2023-09-14 23:10:10.047 error Caught by controller[0]: ] host.raspberrypi4-iob 2023-09-14 23:10:10.046 error Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.enigma2/main.js' host.raspberrypi4-iob 2023-09-14 23:10:10.046 error Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.enigma2/lib/utils.js', host.raspberrypi4-iob 2023-09-14 23:10:10.046 error Caught by controller[0]: requireStack: [ host.raspberrypi4-iob 2023-09-14 23:10:10.046 error Caught by controller[0]: code: 'MODULE_NOT_FOUND', host.raspberrypi4-iob 2023-09-14 23:10:10.046 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19) { host.raspberrypi4-iob 2023-09-14 23:10:10.046 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:960:12) host.raspberrypi4-iob 2023-09-14 23:10:10.046 error Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32) host.raspberrypi4-iob 2023-09-14 23:10:10.046 error Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10) host.raspberrypi4-iob 2023-09-14 23:10:10.045 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14) host.raspberrypi4-iob 2023-09-14 23:10:10.045 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.enigma2/lib/utils.js:46:25) host.raspberrypi4-iob 2023-09-14 23:10:10.045 error Caught by controller[0]: at require (node:internal/modules/cjs/helpers:121:18) host.raspberrypi4-iob 2023-09-14 23:10:10.045 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19) host.raspberrypi4-iob 2023-09-14 23:10:10.045 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:922:27) host.raspberrypi4-iob 2023-09-14 23:10:10.045 error Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15) host.raspberrypi4-iob 2023-09-14 23:10:10.045 error Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.enigma2/main.js host.raspberrypi4-iob 2023-09-14 23:10:10.045 error Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.enigma2/lib/utils.js host.raspberrypi4-iob 2023-09-14 23:10:10.044 error Caught by controller[0]: Require stack: host.raspberrypi4-iob 2023-09-14 23:10:10.044 error Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js' host.raspberrypi4-iob 2023-09-14 23:10:10.044 error Caught by controller[0]: ^ host.raspberrypi4-iob 2023-09-14 23:10:10.044 error Caught by controller[0]: throw err; host.raspberrypi4-iob 2023-09-14 23:10:10.043 error Caught by controller[0]: node:internal/modules/cjs/loader:1080 host.raspberrypi4-iob 2023-09-14 23:09:24.537 error instance system.adapter.enigma2.0 terminated with code 1 (JS_CONTROLLER_STOPPED) host.raspberrypi4-iob 2023-09-14 23:09:24.537 error Caught by controller[0]: Node.js v18.17.1 host.raspberrypi4-iob 2023-09-14 23:09:24.536 error Caught by controller[0]: } host.raspberrypi4-iob 2023-09-14 23:09:24.536 error Caught by controller[0]: ] host.raspberrypi4-iob 2023-09-14 23:09:24.535 error Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.enigma2/main.js' host.raspberrypi4-iob 2023-09-14 23:09:24.535 error Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.enigma2/lib/utils.js', host.raspberrypi4-iob 2023-09-14 23:09:24.534 error Caught by controller[0]: requireStack: [ host.raspberrypi4-iob 2023-09-14 23:09:24.534 error Caught by controller[0]: code: 'MODULE_NOT_FOUND', host.raspberrypi4-iob 2023-09-14 23:09:24.534 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19) { host.raspberrypi4-iob 2023-09-14 23:09:24.533 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:960:12) host.raspberrypi4-iob 2023-09-14 23:09:24.533 error Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32) host.raspberrypi4-iob 2023-09-14 23:09:24.532 error Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10) host.raspberrypi4-iob 2023-09-14 23:09:24.532 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14) host.raspberrypi4-iob 2023-09-14 23:09:24.531 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.enigma2/lib/utils.js:46:25) host.raspberrypi4-iob 2023-09-14 23:09:24.530 error Caught by controller[0]: at require (node:internal/modules/cjs/helpers:121:18) host.raspberrypi4-iob 2023-09-14 23:09:24.530 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19) host.raspberrypi4-iob 2023-09-14 23:09:24.529 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:922:27) host.raspberrypi4-iob 2023-09-14 23:09:24.529 error Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15) host.raspberrypi4-iob 2023-09-14 23:09:24.529 error Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.enigma2/main.js host.raspberrypi4-iob 2023-09-14 23:09:24.528 error Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.enigma2/lib/utils.js host.raspberrypi4-iob 2023-09-14 23:09:24.528 error Caught by controller[0]: Require stack: host.raspberrypi4-iob 2023-09-14 23:09:24.527 error Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js' host.raspberrypi4-iob 2023-09-14 23:09:24.527 error Caught by controller[0]: ^ host.raspberrypi4-iob 2023-09-14 23:09:24.526 error Caught by controller[0]: throw err; host.raspberrypi4-iob 2023-09-14 23:09:24.525 error Caught by controller[0]: node:internal/modules/cjs/loader:1080 parcel.0 2023-09-14 23:08:14.783 error Error: read ETIMEDOUT parcel.0 2023-09-14 23:08:14.782 error https://www.dhl.de/int-verfolgen/data/search?piececode=&noRedirect=true&language=de&cid=app host.raspberrypi4-iob 2023-09-14 23:07:35.937 error instance system.adapter.enigma2.0 terminated with code 1 (JS_CONTROLLER_STOPPED) host.raspberrypi4-iob 2023-09-14 23:07:35.937 error Caught by controller[1]: Node.js v18.17.1 host.raspberrypi4-iob 2023-09-14 23:07:35.937 error Caught by controller[0]: } host.raspberrypi4-iob 2023-09-14 23:07:35.937 error Caught by controller[0]: ] host.raspberrypi4-iob 2023-09-14 23:07:35.936 error Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.enigma2/main.js' host.raspberrypi4-iob 2023-09-14 23:07:35.936 error Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.enigma2/lib/utils.js', host.raspberrypi4-iob 2023-09-14 23:07:35.936 error Caught by controller[0]: requireStack: [ host.raspberrypi4-iob 2023-09-14 23:07:35.936 error Caught by controller[0]: code: 'MODULE_NOT_FOUND', host.raspberrypi4-iob 2023-09-14 23:07:35.936 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19) { host.raspberrypi4-iob 2023-09-14 23:07:35.936 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:960:12) host.raspberrypi4-iob 2023-09-14 23:07:35.936 error Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32) host.raspberrypi4-iob 2023-09-14 23:07:35.936 error Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10) host.raspberrypi4-iob 2023-09-14 23:07:35.935 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14) host.raspberrypi4-iob 2023-09-14 23:07:35.935 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.enigma2/lib/utils.js:46:25) host.raspberrypi4-iob 2023-09-14 23:07:35.935 error Caught by controller[0]: at require (node:internal/modules/cjs/helpers:121:18) host.raspberrypi4-iob 2023-09-14 23:07:35.935 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19) host.raspberrypi4-iob 2023-09-14 23:07:35.935 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:922:27) host.raspberrypi4-iob 2023-09-14 23:07:35.935 error Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15) host.raspberrypi4-iob 2023-09-14 23:07:35.935 error Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.enigma2/main.js host.raspberrypi4-iob 2023-09-14 23:07:35.935 error Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.enigma2/lib/utils.js host.raspberrypi4-iob 2023-09-14 23:07:35.934 error Caught by controller[0]: Require stack: host.raspberrypi4-iob 2023-09-14 23:07:35.934 error Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js' host.raspberrypi4-iob 2023-09-14 23:07:35.934 error Caught by controller[0]: ^ host.raspberrypi4-iob 2023-09-14 23:07:35.934 error Caught by controller[0]: throw err; host.raspberrypi4-iob 2023-09-14 23:07:35.934 error Caught by controller[0]: node:internal/modules/cjs/loader:1080 host.raspberrypi4-iob 2023-09-14 23:07:13.101 error instance system.adapter.enigma2.0 terminated with code 1 (JS_CONTROLLER_STOPPED) host.raspberrypi4-iob 2023-09-14 23:07:13.101 error Caught by controller[1]: Node.js v18.17.1 host.raspberrypi4-iob 2023-09-14 23:07:13.101 error Caught by controller[0]: } host.raspberrypi4-iob 2023-09-14 23:07:13.101 error Caught by controller[0]: ] host.raspberrypi4-iob 2023-09-14 23:07:13.101 error Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.enigma2/main.js' host.raspberrypi4-iob 2023-09-14 23:07:13.101 error Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.enigma2/lib/utils.js', host.raspberrypi4-iob 2023-09-14 23:07:13.100 error Caught by controller[0]: requireStack: [ host.raspberrypi4-iob 2023-09-14 23:07:13.100 error Caught by controller[0]: code: 'MODULE_NOT_FOUND', host.raspberrypi4-iob 2023-09-14 23:07:13.100 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19) { host.raspberrypi4-iob 2023-09-14 23:07:13.100 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:960:12) host.raspberrypi4-iob 2023-09-14 23:07:13.100 error Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32) host.raspberrypi4-iob 2023-09-14 23:07:13.099 error Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10) host.raspberrypi4-iob 2023-09-14 23:07:13.099 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14) host.raspberrypi4-iob 2023-09-14 23:07:13.099 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.enigma2/lib/utils.js:46:25) host.raspberrypi4-iob 2023-09-14 23:07:13.098 error Caught by controller[0]: at require (node:internal/modules/cjs/helpers:121:18) host.raspberrypi4-iob 2023-09-14 23:07:13.098 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19) host.raspberrypi4-iob 2023-09-14 23:07:13.098 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:922:27) host.raspberrypi4-iob 2023-09-14 23:07:13.098 error Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15) host.raspberrypi4-iob 2023-09-14 23:07:13.097 error Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.enigma2/main.js host.raspberrypi4-iob 2023-09-14 23:07:13.097 error Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.enigma2/lib/utils.js host.raspberrypi4-iob 2023-09-14 23:07:13.097 error Caught by controller[0]: Require stack: host.raspberrypi4-iob 2023-09-14 23:07:13.096 error Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js' host.raspberrypi4-iob 2023-09-14 23:07:13.096 error Caught by controller[0]: ^ host.raspberrypi4-iob 2023-09-14 23:07:13.095 error Caught by controller[0]: throw err; host.raspberrypi4-iob 2023-09-14 23:07:13.094 error Caught by controller[0]: node:internal/modules/cjs/loader:1080
