  4. js-controller 5.0.x jetzt für alle User im STABLE!
js-controllerstableupgrade
509 Beiträge 82 Kommentatoren 178.3k Aufrufe 65 Beobachtet
  • liv-in-skyL liv-in-sky
    @foxriver76
    zu früh gefreut - egal, was ich in der web.x instanz einstelle (integriert, ws oder socket - alles stürzt ab) diesmal dieser fehler
    also keine vis :-(
    host.iobroker59
    2023-09-14 18:53:17.401	error	instance system.adapter.web.5 terminated with code 6 (UNCAUGHT_EXCEPTION)
    host.iobroker59
    2023-09-14 18:53:17.401	error	Caught by controller[1]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
    host.iobroker59
    2023-09-14 18:53:17.401	error	Caught by controller[1]: at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27)
    host.iobroker59
    2023-09-14 18:53:17.401	error	Caught by controller[1]: at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15)
    host.iobroker59
    2023-09-14 18:53:17.401	error	Caught by controller[1]: Error: The pattern "io. scale(1.3, 1.3)" is not a valid ID pattern
    host.iobroker59
    2023-09-14 18:53:17.401	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    web.5
    2023-09-14 18:53:16.746	error	Alias subscription error. Please check your alias definitions: sourceId=zigbee2mqtt.0.0x540f57fffef3f8cf.current_heating_setpoint, sourceObj={"type":"state","common":{"id":"current_heating_setpoint","prop":"current_heating_setpoint","name":"Temperature setpoint","role":"level.temperature","write":true,"read":true,"type":"number","min":5,"max":30,"unit":"°C","def":5},"native":{},"from":"system.adapter.zigbee2mqtt.0","user":"system.user.admin","ts":1694708659978,"_id":"zigbee2mqtt.0.0x540f57fffef3f8cf.current_heating_setpoint","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    web.5
    2023-09-14 18:53:16.746	error	Alias subscription error. Please check your alias definitions: sourceId=zigbee2mqtt.0.0x84ba20fffe2dca6b.current_heating_setpoint, sourceObj={"type":"state","common":{"id":"current_heating_setpoint","prop":"current_heating_setpoint","name":"Temperature setpoint","role":"level.temperature","write":true,"read":true,"type":"number","min":5,"max":30,"unit":"°C","def":5},"native":{},"from":"system.adapter.zigbee2mqtt.0","user":"system.user.admin","ts":1694708659054,"_id":"zigbee2mqtt.0.0x84ba20fffe2dca6b.current_heating_setpoint","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    web.5
    2023-09-14 18:53:16.746	error	Alias subscription error. Please check your alias definitions: sourceId=fritzdect.0.DECT_119610737080.tsoll, sourceObj={"type":"state","common":{"name":"Setpoint Temperature","type":"number","min":0,"max":32,"unit":"°C","read":true,"write":true,"role":"value.temperature","desc":"Setpoint Temperature"},"native":{},"from":"system.adapter.fritzdect.0","user":"system.user.admin","ts":1611662566181,"_id":"fritzdect.0.DECT_119610737080.tsoll","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    web.5
    2023-09-14 18:53:16.696	error	The pattern "io. scale(1.3, 1.3)" is not a valid ID pattern
    web.5
    2023-09-14 18:53:16.695	error	Error: The pattern "io. scale(1.3, 1.3)" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15) at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
    web.5
    2023-09-14 18:53:16.647	error	unhandled promise rejection: The pattern "io. scale(1.3, 1.3)" is not a valid ID pattern
    web.5
    2023-09-14 18:53:16.647	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    web.5
    2023-09-14 18:53:16.642	error	Invalid pattern on subscribe: The pattern " scale(1, 1)" is not a valid ID pattern
    web.5
    2023-09-14 18:53:16.641	error	Invalid pattern on subscribe: The pattern "0% { transform: scale(1, 1)" is not a valid ID pattern
    iob diag:
    Copy text starting here:
                        v.2023-04-16
    Operatingsystem:        Debian GNU/Linux 12 (bookworm)
    Kernel:                 6.2.16-6-pve
    Installation:           lxc
    User-ID:                0
    X-Server:               false
    Pending OS-Updates:     10
    Pending iob updates:    3
    Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                           /usr/bin/node           v18.17.1
                           /usr/bin/npm            9.6.7
                           /usr/bin/npx            9.6.7
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:             11G        8.0G        438M        1.8M        3.3G        3.8G
    Swap:           2.1G          0B        2.1G
    Total:           13G        8.0G        2.6G
    Active iob-Instances:   74
    Active repo(s): beta
    ioBroker Core:          js-controller           5.0.12
                           admin                   6.10.1
    Objects type: jsonl
    States  type: redis
    + system.adapter.admin.0                  : admin                 : iobroker59                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.admin.1                  : admin                 : iobroker59                               -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
     system.adapter.admin.2                  : admin                 : iobroker59                               - disabled, port: 8089, bind: 0.0.0.0, run as: admin
     system.adapter.admin.3                  : admin                 : iobroker59                               - disabled, port: 8071, bind: 0.0.0.0, run as: admin
     system.adapter.web-speedy.0             : web-speedy            : iobroker59                               - disabled
    + system.adapter.web.0                    : web                   : iobroker59                               -  enabled, port: 8082, bind: 192.168.178.59, run as: admin
    + system.adapter.web.1                    : web                   : iobroker59                               -  enabled, port: 8072, bind: 192.168.178.59, run as: admin
     system.adapter.web.2                    : web                   : iobroker59                               - disabled, port: 8098, bind: 0.0.0.0, run as: admin
     system.adapter.web.3                    : web                   : iobroker59                               - disabled, port: 8074, bind: 0.0.0.0, run as: admin
     system.adapter.web.4                    : web                   : iobroker59                               - disabled, port: 8075, bind: 0.0.0.0, run as: admin
    + system.adapter.web.5                    : web                   : iobroker59                               -  enabled, port: 8076, bind: 0.0.0.0, run as: admin
     system.adapter.web.6                    : web                   : iobroker59                               - disabled, port: 8077, bind: 0.0.0.0, run as: admin
     system.adapter.web.7                    : web                   : iobroker59                               - disabled, port: 8078, bind: 0.0.0.0, run as: admin
    + system.adapter.webcal.0                 : webcal                : iobroker59                               -  enabled
    + system.adapter.webcal.1                 : webcal                : iobroker59                               -  enabled
    + system.adapter.webcal.2                 : webcal                : iobroker59                               -  enabled
    Objects:                71340
    States:                 78158
    Size of iob-Database:
    163M    /opt/iobroker/iobroker-data/objects.jsonl
    26M     /opt/iobroker/iobroker-data/states.jsonl
    Installed ioBroker-Instances
    Used repository: beta
    Adapter    "admin"        : 6.10.1   , installed 6.10.1
    Adapter    "alexa-timer-vis": 0.2.0  , installed 0.2.0
    Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "backitup"     : 2.8.1    , installed 2.8.1
    Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
    Adapter    "calendar"     : 1.2.0    , installed 1.2.0
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "contact"      : 1.1.3    , installed 1.1.3
    Adapter    "countdown"    : 2.2.0    , installed 2.2.0
    Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
    Adapter    "device-reminder": 2.0.1  , installed 1.2.9  [Updatable]
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "email"        : 1.2.0    , installed 1.2.0
    Adapter    "esphome"      : 0.2.4    , installed 0.2.4
    Adapter    "eventlist"    : 1.2.3    , installed 1.2.3
    Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
    Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
    Adapter    "fuelpricemonitor": 0.3.6 , installed 0.3.6-alpha.0 [Updatable]
    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
    Adapter    "gotify"       : 0.2.0    , installed 0.2.0
    Adapter    "history"      : 2.2.6    , installed 2.2.6
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "iceroad"      : 1.2.1    , installed 1.2.1
    Adapter    "imap"         : 0.1.1    , installed 0.1.1
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
    Controller "js-controller": 5.0.12   , installed 5.0.12
    Adapter    "lgtv"         : 1.1.12   , installed 1.1.12
    Adapter    "linux-control": 1.1.5    , installed 1.1.5
    Adapter    "meross"       : 1.15.1   , installed 1.15.1
    Adapter    "meteoalarm"   : 2.3.7    , installed 2.3.7
    Adapter    "mihome"       : 1.4.0    , installed 1.4.0
    Adapter    "mpd"          : 1.1.1    , installed 1.1.1
    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
    Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
    Adapter    "node-red"     : 4.0.3    , installed 4.0.3
    Adapter    "nut"          : 1.6.0    , installed 1.6.0
    Adapter    "odl"          : 2.0.5    , installed 2.0.5
    Adapter    "openweathermap": 0.4.3   , installed 0.4.3
    Adapter    "parcel"       : 0.1.2    , installed 0.1.2
    Adapter    "parser"       : 2.0.5    , installed 2.0.5
    Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
    Adapter    "pixelit"      : 1.1.1    , installed 1.1.1
    Adapter    "plex"         : 1.1.0    , installed 1.1.0
    Adapter    "proxmox"      : 2.0.2    , installed 2.0.2
    Adapter    "puppeteer"    : 0.2.7    , installed 0.2.7
    Adapter    "pushbullet"   : 1.0.1    , installed 1.0.1
    Adapter    "pushover"     : 3.0.4    , installed 3.0.4
    Adapter    "pushsafer"    : 1.0.3    , installed 1.0.3
    Adapter    "sayit"        : 3.0.5    , installed 3.0.5
    Adapter    "scheduler"    : 1.1.9    , installed 1.1.9
    Adapter    "socketio"     : 6.5.3    , installed 6.5.3
    Adapter    "sonoff"       : 2.5.7    , installed 2.5.7
    Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
    Adapter    "spotify-premium": 1.2.2  , installed 1.2.2
    Adapter    "telegram"     : 1.16.0   , installed 1.16.0
    Adapter    "telegram-menu": 0.6.7    , installed 0.6.7
    Adapter    "time-switch"  : 2.2.2    , installed 2.2.2
    Adapter    "traccar"      : 1.1.2    , installed 0.0.12 [Updatable]
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "tvprogram"    : 1.1.2    , installed 1.1.2
    Adapter    "unifi"        : 0.6.6    , installed 0.6.6
    Adapter    "upnp"         : 1.0.21   , installed 1.0.21
    Adapter    "valuetrackerovertime": 1.0.1, installed 1.0.1
    Adapter    "virtualpowermeter": 1.4.6, installed 1.4.6
    Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
    Adapter    "web"          : 6.1.1    , installed 6.1.1
    Adapter    "web-speedy"   : 0.2.0    , installed 0.2.0
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
    Adapter    "windows-control": 0.1.5  , installed 0.1.5
    Adapter    "wled"         : 0.7.0    , installed 0.7.0
    Adapter    "ws"           : 2.5.4    , installed 2.5.4
    Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
    Adapter    "zigbee2mqtt"  : 2.13.1   , installed 2.13.1
    @liv-in-sky sagte in js-controller 5.0.x jetzt für alle User im STABLE!:
    User-ID:                0
    Das würde ich zunächst in Angriff nehmen. Also user anlegen und nicht als root herummachen und die Updates einspielen. Auf der Basis kann man dann weiter schauen.
    • mcm1957M mcm1957
      @mcm57 said in js-controller 5.0.x jetzt für alle User im STABLE!:
      @foxriver76
      Ok
      Wenn ihr keine Zeit habt kann ich am Abend release versuchen
      Ok, der botvac hat weder release script noch github tests - Museumsstand was die Infrastruktur betrifft. Ich werd dann mal anfangen, kann aber auch noch nen Tag dauern bis ne saubere Release entsteht.
      Wer will, kann zwischenzeitlich die GITHUB Version versuchen (übliches Disclaimer - at own risk + Backup). Der Code sollte an js-controller 5 angepasst sein. Er enthält allerdings auch ein paar weitere Änderungen die nicht ins README gefunden haben, da muss ich erst mal schaun ob da ne Info was geändert wurde extrahieren kann.
      JohGreJ Offline
      JohGreJ Offline
      JohGre
      @mcm57 Danke schon mal für deine Hilfe beim Botvac Adapter.
      Aber viel wichtiger wäre mir Hilfe bei der Lösung des Problems mit dem ham-modul homebridge-balboa-spa@2.2.6, das brauch ich wirklich da ich damit unsere Whirlpool steuere.
      Mehr spukt das log dazu nicht aus.
      2023-09-14 14:40:20.837  - error: ham.0 (35321) Error: Library homebridge-balboa-spa@2.2.6 not installed after 3 attempts
      nuc i5: RaspberryMatic, ioBroker, pi-hole, SQL-Server, OMV-NAS, Influx-DB & Grafana, OpenHab, tasmoadmin
      mcm1957M apollon77A 2 Antworten Letzte Antwort
        @foxriver76
        also keine vis :-(
        host.iobroker59
        host.iobroker59
        host.iobroker59
        host.iobroker59
        host.iobroker59
        host.iobroker59
        web.5
        web.5
        web.5
        web.5
        web.5
        web.5
        web.5
        web.5
        web.5
        iob diag:
                            v.2023-04-16
        Installation:           lxc
        User-ID:                0
        X-Server:               false
                               /usr/bin/npm            9.6.7
                               /usr/bin/npx            9.6.7
        MEMORY:
        Swap:           2.1G          0B        2.1G
                               admin                   6.10.1
        Objects type: jsonl
        States  type: redis
        Objects:                71340
        States:                 78158
        foxriver76F Offline
        foxriver76F Offline
        foxriver76
        @liv-in-sky Im Endeffekt iwo ein binding in vis, welches mist macht. Aber ich denke wir sollten noch eine neue Web Adapter Version machen weil ist eigentlich gefixt in socket classes aber dafür müsste web Adapter neu installiert oder geupdated werden.
        Videotutorials & mehr
        liv-in-skyL mcm1957M 3 Antworten Letzte Antwort
        • foxriver76F foxriver76
          liv-in-skyL Offline
          liv-in-skyL Offline
          @foxriver76 du meinst ich soll den web adapter deinstallieren und neu installieren ?
          • JohGreJ JohGre
            mcm1957M Online
            mcm1957M Online
            mcm1957
            @johgre said in js-controller 5.0.x jetzt für alle User im STABLE!:
            Sorry, da kann ich nix beitragen.
            @foxriver76
            @apollon77
            Könnt ihr da was dazu sagen oder jemand triggern der sich das ansehen kann?
              User-ID:                0
              liv-in-skyL Offline
              liv-in-skyL Offline
              so ist jetzt der stand:
                                  v.2023-04-16
              Installation:           lxc
              User-ID:                1000
              X-Server:               false
              Pending OS-Updates:     0
              Pending iob updates:    1
                                     /usr/bin/npm            9.6.7
                                     /usr/bin/npx            9.6.7
              MEMORY:
              Mem:             11G        7.6G        2.4G        1.8M        1.8G        4.2G
              Swap:           2.1G          0B        2.1G
              Total:           13G        7.6G        4.5G
              Active iob-Instances:   72
                                     admin                   6.10.1
              Objects type: jsonl
              States  type: redis
              Objects:                71282
              States:                 78322
              84M     /opt/iobroker/iobroker-data/objects.jsonl
              den einen adapter kann ich nicht updaten, da die neue version davon nicht geht - ist traccar - sollte hier kein thema sein
              kein root user :-)
                                    v.2023-04-16
                Installation:           lxc
                User-ID:                1000
                X-Server:               false
                                       /usr/bin/npm            9.6.7
                                       /usr/bin/npx            9.6.7
                MEMORY:
                Swap:           2.1G          0B        2.1G
                                       admin                   6.10.1
                Objects type: jsonl
                States  type: redis
                Objects:                71282
                States:                 78322
                kein root user :-)
                kein root user
                räusper
                User-ID: 0
                Edit:
                Okay, geändert im aktuellen Output...
                  liv-in-skyL Offline
                  liv-in-skyL Offline
                  @foxriver76
                  @Thomas-Braun
                  habe leider keine zeit nehr - gehe wieder auf altes system zurück - evtl kann ich am WE nochmal testen
                  erstmal danke
                  • JohGreJ JohGre
                    @johgre da muss mehr im log stehen bei normalen logleveln.
                    JohGreJ 1 Antwort Letzte Antwort
                    • apollon77A apollon77
                      JohGreJ Offline
                      JohGreJ Offline
                      JohGre
                      @apollon77 Hallo, hat sich erledigt.
                      Einmal Adapter löschen, wieder installieren, Module neu hinzufügen, konfigurieren und schon tuts wieder.
                      Hab das vorher in einem neuen Container probiert und da es da geklappt hat gleich am Produktivsystem.
                      surfer09S 1 Antwort Letzte Antwort
                      • JohGreJ JohGre
                        surfer09S Offline
                        surfer09S Offline
                        surfer09
                        Bei mir hat auch alles funktioniert. Danke! ;-)
                        • mcm1957M mcm1957
                          [[topic:post-is-deleted]]
                          mcm1957M Online
                          mcm1957M Online
                          mcm1957
                          Dieser Beitrag wurde gelöscht!
                          • mcm1957M mcm1957
                            @mcm57
                            Dann kannst du ja den Eintrag dazu ändern:
                            ⚪ enigma2 - required: none - not at stable yet
                              mcm1957M Online
                              mcm1957M Online
                              mcm1957
                              @foxriver76 said in js-controller 5.0.x jetzt für alle User im STABLE!:
                              Ab morgen sollte eine neue Release von web / ws / socketio im stable angeboten werden, die dieses Problem (invalid bindings in vis) fixed. Danke an @foxriver76 für die schnelle Release.
                              KrisiunK 1 Antwort Letzte Antwort
                                Hallo ioBroker-Community,
                                Heute möchten wir Euch den js-controller 5.0 endlich auch im STABLE Repository zur Verfügung stellen. Dieser Post enthält alle wichtigen Infos. Bitte unbedingt lesen!!
                                Wir bedanken uns bei allen Usern die bisher die neue Version bereits als Alpha oder Beta getestet und Feedback gegeben haben.
                                Node.js Versions-Anforderungen
                                In diesem Release entfällt Node.js 12.x welches seit April letztem Jahr nicht mehr gepflegt wird und Node.js 14.x welches seit April diesem Jahres EOL ist. Node.js 18.x ist dazugekommen. Die unterstützten Node.js Versionen sind: 16.4.0+ und 18.x und nach aktuellem Stand Node.js 20.x, wobei hier noch erfahrungen fehlen. Die empfohlene Node.js Version für ioBroker haben wir vor kurzem auf 18.x angehoben.
                                Bitte beachtet weiterhin bei Node.js Updates die Anleitung im Forum unter https://forum.iobroker.net/topic/64032/update-nodejs-best-practise-supported-14-16-und-18 !
                                Informationen zur Version
                                Es gibt EINIGE Adapter die aktualisiert werden müssen!! Bitte weiter unten lesen!
                                In dieser Version wurde die Umstellung des Quellcodes auf TypeScript sehr stark vorangetrieben (inzwischen bei 88%), wodurch am Ende die Stabilität weiter steigt weil viele Code-Fehler nicht mehr auftreten können. Natürlich sind neben Optimierungen und Fehlerbehebungen auch ein paar neue Features hinzugekommen. Auch wenn mit dieser Version keine neuen Prüfungen hinzukommen, die zu Log-Ausgaben bei Adaptern führen, meldet aktuelle Logausgaben bitte weiterhin bei den Adaptern.
                                Detailliertere Informationen zu allen Änderungen und Features findet Ihr weiter unten und im Changelog.
                                Für die aktive Mitarbeit an dieser Version des js-controller bedanke mich diesmal wieder besonders bei Apollon77, AlCalzone und natürlich Bluefox und auch ein paar weiteren Entwicklern!
                                ACHTUNG backups inkompatibel bei Downgrades!!
                                Neben der Node.js Version gibt es eine wichtige Inkompatibilität: Backups die mit der 5.0 des js-controller erstellt wurden lassen sich nicht mit einem js-controller 4 oder kleiner wieder restoren!
                                Darüber hinaus ist der js-controller 5.0 generell kompatibel mit allen bestehenden ioBroker-Systemen. Ein Update von der 2.0/2.1/2.2/3.x ist problemlos möglich. Wir empfehlen allerings vor dem Update auf die 5.0 idealerweise ein Update auf die 4.0 und vorher auf 3.3.x durchzuführen, da ein Downgrade nach einem erfolgten Update nur auf eine 3.3.x möglich ist (siehe FAQ)! Nur die Node.js Version muss weiterhin mindestens 16.x sein, wie oben bereits ausgeführt. Wer überlegt die Node.js Version anzuheben bitte weiter unten im Abschnitt "Was ist zu testen" lesen 🙂
                                Aufgrund einiger internen Umstellungen brauchen wieder einige Adapter Updates. Diese sollten am besten VOR dem Update installiert werden!
                                Bitte dazu die Informationen weiter unten beachten!
                                Installation
                                VOR der Installation
                                Wie bei jedem Upgrade dieser Art: Bitte macht ein Backup! iobroker backup bzw kopieren des iobroker-data Verzeichnisses reichen an sich aus. Bitte nicht das node_modules Verzeichnis einfach kopieren, da sonst symbolische Links kaputt gehen können, was zu größeren Problemen danach führt. Eine alte 4.0.x-Version des js-controller kann im Notfall einfach wieder per npm install iobroker.js-controller@version ("version" durch die gewünschte Versionsnummer ersetzen) installiert werden und sollte alles wieder herstellen (Vorheriger Stable Stand ist die 4.0.24)
                                Nötige Adapter-Aktualisierungen
                                Am besten dennoch VOR dem js-controller Update alle verfügbaren Adapter-Updates prüfen und alle Updates installieren, die im Changelog auf Optimierungen oder Anpassungen für den js-controller 4.0 oder höher hinweisen.
                                Diesmal sind doch einige Adapter auf der Liste die man updaten muss -falls installiert! Siehe Spoiler!
                                • ✅ acme - required: none / 0.1.0 - released
                                • ✅ admin - required: 6.8.0 - released
                                • ✅ anelhut - required: 1.0.15 - released
                                • ✅b-control-em - required: 0.3.1 - released
                                • ⚪ bosch-ebike - required: none
                                • ✅ cul - required: 2.2.0 - released (no change)
                                • ✅ daikin-cloud - required: 0.3.0 - released
                                • ✅ doorbird - required: 0.1.7 - newer released
                                • ✅ ds18b20 - required: 2.0.4 - released
                                • ✅ energymanager - required: 1.4.2 - released
                                • ⚪ enigma2 - required: none - not at stable yet
                                • ✅ fakeroku - required: 0.2.2+ - released
                                • ✅ fhem - required: 2.0.5 - released
                                • ✅ history - required: 2.2.6 - released
                                • ✅ iqontrol - required: 2.3.0 - released
                                • ⚪ javascript - required: none
                                • 🚫 km200 - deprecated - Ersatz: ems-esp
                                • ✅ lgtv - required: 1.1.12 - released
                                • ❗linux-control - required: ???
                                • ✅ maxcul - required: 1.3.1 (no change)
                                • ⚪ miio - required: none - not at stable
                                • ✅ mydlink - required: 1.3.4 - released
                                • ✅ nanoleaf-lightpanales - required: 1.4.0 - released
                                • ✅ node-red - required: 4.03+ (no change)
                                • ✅ notification.manager - required: 0.1.1 - released
                                • ✅ pi-hole - required: 1.3.6+ - released
                                • ✅ ping - required: 1.6.2 - released
                                • ✅ pushbullet - required: 1.0.1 - released
                                • 🚫 samsung_tyzen - stale repo - deprecated with js-controller 5
                                • ✅ socketio - required: 6.5.2 - released
                                • ✅ stiebel-isg - required: 1.7.6+ - newer released
                                • ✅ systeminfo - required: 1.0.0 - released
                                • ✅ viessmann - required: 1.4.4+ - released
                                • ✅ web - required: 6.1.0 - released
                                • ✅ ws - required: 2.5.3 - released
                                • ✅yahka - required: 1.0.1 - newer version released
                                • ✅ zigbee - required: 1.8.23 - released
                                Achtung: MASTER-Systeme Reihenfolgen beachten!
                                Bei einem Multi-Host-System, welches auf js-controller 2.2, 3.x oder 4.0.x läuft, ist es beim Update auf Version 5.0 empfohlen, zuerst das Master-System zu aktualisieren. Der Master muss dann wieder gestartet werden. Die Slaves werden danach aktualisiert!
                                Bei Updates von Master/Slave-Systemen mit js-controller 1.5 oder früher Bitte die jeweiligen Update Threads der empfohlenen Zwischenversionen prüfen.
                                Windows
                                Generell muss das Update manuell via npm installiert werden.
                                Hierzu im ioBroker-Verzeichnis nach stoppen des ioBroker den Befehl iob upgrade self ausführen.
                                Linux
                                • ioBroker stoppen (iobroker stop)
                                • Prüfen das keine Prozesse (Adapter, Backups) mehr laufen (ps auxww|grep io und auch ps auxww|grep backup ). Es passiert manchmal das trotz dem Stoppen noch Zombies zurückbleiben
                                • cd /opt/iobroker
                                • Das Update erfolgt via iob upgrade self
                                • ioBroker starten (iobroker start)
                                Bei Fehlern:
                                Wenn bei der Installation Fehler wegen fehlender Zugriffsrechte auftreten, am besten den Installation-Fixer (iobroker fix wer schon einen js-controller 2.x oder höher hat, alternativ weiterhin manuell via curl -sL https://iobroker.net/fix.sh | bash -) nutzen und die Installation wiederholen.
                                Falls es auch danach noch Fehler gibt, bitte die Installation erneut mittels sudo -H -u iobroker npm install iobroker.js-controller versuchen. Bitte berichtet solche Fälle hier im Thread.
                                NACH der Installation
                                Wenn alles klappt merkt Ihr ausser der höheren Versionsnummer in der Host-Ansicht im Admin keinen Unterschied. Alles funktioniert weiterhin wie vorher. Alle Adapterinstanzen starten und funktionieren. Wenn das so ist hat alles geklappt.
                                Falls im Log Warn-Meldungen auftauchen mit dem Hinweis diese an den Entwickler zu senden, dann bitte schauen welcher Adapter es ist und entsprechend dort Issues bitte anlegen!
                                Was hat sich geändert, was besonders ansehen/beachten?
                                Neben einiger weiterer Bugfixes gibt es folgende Änderungen und Fixes zu erwähnen:
                                • generell siehe Changelog, speziell auch für die Features
                                • generell bitte im CLI und auch sonst überall drüber schauen. Die Typescript Umstellungen haben sehr viel Code angefasst.
                                • Falls jemand sporadisch Alias Fehler im Log hatte bitte versuchen diese mit der neuen version wieder zu provoziere und rückmelden
                                Speziell die Entwickler sollten bitte die genannten Deprecations und neuen Features anschauen und beachten.
                                Wie bereits gesagt, viele Änderungen fanden hinter den Kulissen statt. Hier für Interessierte als Spoiler eine Zusammenfassung:
                                5.0. Release Jana
                                BREAKING CHANGES
                                • Support for Node.js 12 and 14 is dropped! Supported are Node.js 16.4.0+ and 18.x and hopefully 20.x
                                • Backups created with the new js-controller version cannot be restored on hosts with lower js-controller version!
                                • Update recommended npm version to 8
                                • Deprecate binary states, Adapters will change to use Files instead!
                                Features
                                • (foxriver76) Show npm error message on failing adapter installations and update also without debug parameter
                                • (foxriver76) Introduce iobroker setting (dnsResolution) to choose between verbatim and ipv4 first dns resolution order
                                • (foxriver76) Add support for windows for iob fix
                                • (bluefox) Added CLI option to restart/start/stop all instances of an adapter (e.g. iob stop admin now also works)
                                • (foxriver76) Allow to use iob host oldname command when new host already exists but has no instances
                                • (foxriver76) Added an admin notification if redis is misconfigured and info how to fix it
                                • (foxriver76) Enable upgrade of js-controller via Admin UI (Linux only)
                                Optimizations and Fixes
                                • (foxriver76) Speedup "getStates" calls with many IDs often used by visualizations: JSONL 17 times faster, Redis 23 times faster
                                • (foxriver76) significantly reduce backup size
                                • (foxriver76) Enhance CLI help for list command to show all possible types to list
                                • (foxriver76) Also stop instances before updating from GitHub
                                • (foxriver76) Conversion of big parts of the js-controller codebase to typeScript and address all found issues
                                • (Apollon77) Only log error on "enable/disable via .alive" if there is an error
                                • (foxriver76) Optimize adapter unload and stop handling for edge cases
                                • (AlCalzone) Carefully normalize jsonlOptions
                                • (bluefox) Do not show warning on a requested adapter stop/termination
                                • (bluefox) Make sure that the first log line is not missing in Admin
                                • (foxriver76) Fix wrong formatting of cli get binary state if no encoding is passed
                                • (foxriver76) Fix restoring backups from pre js-controller 4.x which were created without config.system
                                • (foxriver76) Preserve tier setting on adapter upload
                                • (foxriver76) update apt sources before installing os dependencies
                                • (foxriver76) Only skip erase on upload if opted out explicitly to always cleanup unneeded files
                                • (foxriver76) Try to fix strange alias errors, inform us if it happens again!
                                • (foxriver76) Remove windows bat files completely, installer will create them when needed
                                • (AlCalzone/Apollon77) Update jsonl db to prevent locking issues
                                • (foxriver76) Fixes iob file sync not working for jsonl
                                • (foxriver76) Do not crash if we cannot initialize db backup directory on start
                                • (foxriver76) Fixed issue with certificate validity on leap years
                                • (Apollon77/foxriver76) Make sure that all relevant files are removed when eraseOnUpload is used
                                • (foxriver76) fix wrong hostname after backup restore
                                • (bluefox) allow CLI vendor update without explicitly specifying vendor file (default file is used)
                                • (Apollon77, foxriver76, bluefox, AlCalzone) Several fixes and refactorings to prevent potential crash cases reported by Sentry and other sources
                                Developer relevant DEPRECATIONS/WARNINGS
                                • Deprecate binary states, Migrate your adapters to use Files instead!
                                • If you need to access special js-controller common tools please use adapter-core instead of js-controller directly - see https://github.com/ioBroker/adapter-core#commontools
                                • Parameter that contain patterns (e.g. mqtt.*) are now checked for allowed characters and general correctness!
                                Developer relevant new Features
                                • (bluefox) Added options to subscribe to file changes: subscribeForeignFiles, unsubscribeForeignFiles, onAdapterFileChanged (event contains id, fileName, size and not the whole content of the file!)
                                • (foxriver76) Introduce on("install") handler for adapter which is automatically called when adapter process is started with --install
                                • (foxriver76) Introduce io-package flag common.nodeProcessParams to allow to pass adapter specific nodejs process parameters (disables compact mode for the adapter!)
                                • (foxriver76) Respect dns resolution (ipv4/ipv6 first) from config internally and provide relevant methods via adapter-core
                                • (foxriver76) Add JSON-Schema for iobroker.json
                                • (bluefox) Allowed export of password.js (to be used with adapter-core)
                                • (bluefox) Added _design/chart to the system designs
                                • (foxriver76) Automatically generated Code-Docs for Adapter class https://github.com/ioBroker/ioBroker.js-controller/tree/master/packages/controller/doc
                                • (foxriver76) Added (foreign)objectExists to adapter methods
                                • (bluefox) Extend getSuitableLicenses to look for other licenses
                                • (buefox/foxriver76) Added new category for notifications: blocked and respect js-controller common.blockedVersions to block versions from starting
                                • (bluefox) Added new system view "custom-full" to return the full objects for objects with a custom part and not only the custom details
                                • (foxriver76) Added support for getForeignObjects with an array of strings as pattern
                                • (AlCalzone) Preparations to allow js-controller Dev version to be used with dev-server
                                • (foxriver76) Validate max timeout value (max 32bit max number) on setTimeout/setInterval and throw on error to prevent issues
                                • (foxriver76) new io-package flag common.supportedMessages to replace messagebox and other messagebox-related properties
                                • (foxriver76) adapter.sendTo now accepts an optional timeout argument
                                • Developer relevant Optimizations and Fixes
                                • (foxriver76) Ensure setObjectNotExists returns id on success
                                • (foxriver76) Fix Typings for sendTo/sendToHost
                                • (Bluefox) Add User permission check to requireLog
                                • (foxriver76) added nonEdit property of objects to types and document functionality
                                • (foxriver76) introduced constants for state quality
                                • (foxriver76) subscribeStates now also accepts an array of ids
                                • general dependency updates
                                • code style optimizations and streamline code
                                Generell ist zu testen, ob alles noch so funktioniert wie vorher auch. Das ist das wichtigste!
                                Wie Fehler melden?
                                Wer sich unsicher ist, ob ein Fehler vorliegt, sollte am besten hier im Thread das Problem beschreiben. So können wir alle versuchen, das Problem nachzuvollziehen und ggf. einzugrenzen.
                                Sobald ein Fehler auftritt der in einer Fehlermeldung oder einen Crash mit Fehlerdetails im Log oder auf Kommandozeile endet, dann dazu am besten direkt ein GitHub-Issue im js-controller Projekt öffnen und zusätzlich hier im Thread posten. Je detaillierter die Angaben im Issue sind (genaue Fehlermeldungen/Logs, Infos zur OS- und Node.js-Umgebung sowie genaue Schritte zur Reproduktion des Problems), umso schneller können wir Fehler einkreisen und beheben.
                                Bitte postet auch die Ausgabe von iob diag mit rein.
                                Wir wünschen allen viel Spaß mit dem neuen Controller und vielen Dank für Eure Unterstützung!
                                fox
                                O Offline
                                O Offline
                                oFbEQnpoLKKl6mbY5e13
                                @foxriver76
                                MQTT-Client crashed wegen eines falschen Zeichens.
                                2023-09-14 23:26:08.910  - info: host.iobroker instance system.adapter.mqtt-client.0 started with pid 3149
                                2023-09-14 23:26:11.236  - info: mqtt-client.0 (3149) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                                2023-09-14 23:26:11.348  - info: mqtt-client.0 (3149) starting. Version 1.6.4 in /opt/iobroker/node_modules/iobroker.mqtt-client, node: v18.16.0, js-controller: 5.0.12
                                2023-09-14 23:26:12.408  - info: mqtt-client.0 (3149) Try to connect to mqtt://admin:*******************@192.168.0.6:1883?clientId=mqtt-client.0.iobroker
                                2023-09-14 23:26:12.625  - error: mqtt-client.0 (3149) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                2023-09-14 23:26:12.631  - info: mqtt.0 (456) Client [mqtt-client.0.iobroker] connected with secret 1694726772485_8486
                                2023-09-14 23:26:12.626  - error: mqtt-client.0 (3149) unhandled promise rejection: The pattern "io.mqtt-client.0.stat.� 0� stat.tasmota_95F" is not a valid ID pattern
                                2023-09-14 23:26:12.628  - error: mqtt-client.0 (3149) Error: The pattern "io.mqtt-client.0.stat.� 0� stat.tasmota_95F" is not a valid ID pattern
                                    at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js:2186:15)
                                    at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:865:100)
                                    at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                                2023-09-14 23:26:12.628  - error: mqtt-client.0 (3149) The pattern "io.mqtt-client.0.stat.� 0� stat.tasmota_95F" is not a valid ID pattern
                                2023-09-14 23:26:12.654  - info: mqtt-client.0 (3149) connected to broker
                                2023-09-14 23:26:12.745  - info: mqtt.0 (456) Client [mqtt-client.0.iobroker] subscribes on "mqtt.0.tele.tasmota_85D39A.STATE"
                                2023-09-14 23:26:13.199  - info: mqtt-client.0 (3149) terminating
                                2023-09-14 23:26:13.202  - warn: mqtt-client.0 (3149) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                2023-09-14 23:26:14.110  - info: mqtt.0 (456) Client [mqtt-client.0.iobroker] publishOnSubscribe send all known states
                                2023-09-14 23:26:14.158  - info: mqtt.0 (456) Client [mqtt-client.0.iobroker] connection closed: disconnected
                                2023-09-14 23:26:14.366  - info: mqtt-client.0 (3149) terminating with timeout
                                2023-09-14 23:26:14.934  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.tele.tasmota_341527.LWT: DB closed
                                2023-09-14 23:26:14.935  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.stat.tasmota_A36501.STATUS6: DB closed
                                2023-09-14 23:26:14.936  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.stat.tasmota_9E62C6.STATUS: DB closed
                                2023-09-14 23:26:14.936  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.tele.tasmota_56D73B.INFO3: DB closed
                                2023-09-14 23:26:14.937  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.tele.tasmota_A36501.LWT: DB closed
                                2023-09-14 23:26:14.938  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.tele.tasmota_3F8AD6.LWT: DB closed
                                2023-09-14 23:26:14.938  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.stat.tasmota_85CD09.STATUS: DB closed
                                2023-09-14 23:26:14.939  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.stat.tasmota_A36501.POWER2: DB closed
                                2023-09-14 23:26:14.940  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.tele.tasmota_95FE9E.STATE: DB closed
                                2023-09-14 23:26:14.941  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.stat.tasmota_7E7404.STATUS4: DB closed
                                2023-09-14 23:26:14.942  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.stat.tasmota_990526.UPGRADE: DB closed
                                2023-09-14 23:26:14.942  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.stat.tasmota_4CC022.STATUS4: DB closed
                                2023-09-14 23:26:14.943  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.stat.tasmota_63E60D.RESULT: DB closed
                                2023-09-14 23:26:14.944  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.stat.tasmota_4E489B.STATUS11: DB closed
                                2023-09-14 23:26:14.944  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.stat.tasmota_53EAB0.STATUS6: DB closed
                                2023-09-14 23:26:14.945  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.stat.tasmota_4E4778.STATUS4: DB closed
                                2023-09-14 23:26:14.945  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.tele.tasmota_9E62C6.INFO2: DB closed
                                2023-09-14 23:26:14.946  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.tasmota.discovery.840D8E5E4526.config: DB closed
                                2023-09-14 23:26:14.947  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.stat.tasmota_BB868C.STATUS3: DB closed
                                2023-09-14 23:26:14.948  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.tele.tasmota_990210.INFO3: DB closed
                                2023-09-14 23:26:14.948  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.stat.tasmota_BEB72E.STATUS4: DB closed
                                2023-09-14 23:26:14.949  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.tele.tasmota_A36501.STATE: DB closed
                                2023-09-14 23:26:14.949  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.tele.tasmota_FD2178.STATE: DB closed
                                2023-09-14 23:26:14.950  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.stat.tasmota_5E4526.STATUS4: DB closed
                                2023-09-14 23:26:14.951  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.tele.tasmota_3F8AD6.SENSOR: DB closed
                                2023-09-14 23:26:14.952  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.stat.tasmota_95FE9E.STATUS4: DB closed
                                2023-09-14 23:26:14.953  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.stat.tasmota_53EAB0.STATUS1: DB closed
                                2023-09-14 23:26:14.953  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.stat.tasmota_41CB86.POWER: DB closed
                                2023-09-14 23:26:14.954  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.stat.tasmota_59618E.STATUS7: DB closed
                                2023-09-14 23:26:14.954  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.stat.tasmota_3F8C42.RESULT: DB closed
                                2023-09-14 23:26:14.955  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.stat.tasmota_3F8C42.STATUS6: DB closed
                                2023-09-14 23:26:14.955  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.stat.tasmota_990576.STATUS4: DB closed
                                2023-09-14 23:26:14.956  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.stat.tasmota_3F8AD6.UPGRADE: DB closed
                                2023-09-14 23:26:14.956  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.stat.tasmota_95F446.STATUS4: DB closed
                                2023-09-14 23:26:14.957  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.stat.tasmota_41CB86.STATUS2: DB closed
                                2023-09-14 23:26:14.958  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.stat.tasmota_53EAB0.UPGRADE: DB closed
                                2023-09-14 23:26:14.963  - warn: mqtt-client.0 (3149) DB closed
                                2023-09-14 23:26:14.964  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.stat.tasmota_98FD5F.STATUS10: DB closed
                                2023-09-14 23:26:15.262  - error: mqtt-client.0 (3149) Cannot check object existence of "mqtt-client.0.info.connection": Connection is closed.
                                2023-09-14 23:26:15.271  - info: mqtt-client.0 (3149) terminating
                                2023-09-14 23:26:15.393  - error: host.iobroker Caught by controller[0]: [ioredis] Unhandled error event: Error: write EPIPE
                                2023-09-14 23:26:15.394  - error: host.iobroker Caught by controller[0]:     at afterWriteDispatched (node:internal/stream_base_commons:160:15)
                                2023-09-14 23:26:15.394  - error: host.iobroker Caught by controller[0]:     at writeGeneric (node:internal/stream_base_commons:151:3)
                                2023-09-14 23:26:15.394  - error: host.iobroker Caught by controller[0]:     at Socket._writeGeneric (node:net:930:11)
                                2023-09-14 23:26:15.394  - error: host.iobroker Caught by controller[0]:     at Socket._write (node:net:942:8)
                                2023-09-14 23:26:15.395  - error: host.iobroker Caught by controller[0]:     at writeOrBuffer (node:internal/streams/writable:392:12)
                                2023-09-14 23:26:15.395  - error: host.iobroker Caught by controller[0]:     at _write (node:internal/streams/writable:333:10)
                                2023-09-14 23:26:15.395  - error: host.iobroker Caught by controller[0]:     at Writable.write (node:internal/streams/writable:337:10)
                                2023-09-14 23:26:15.395  - error: host.iobroker Caught by controller[0]:     at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:679:33)
                                2023-09-14 23:26:15.396  - error: host.iobroker Caught by controller[0]:     at Redis.publish (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
                                2023-09-14 23:26:15.396  - error: host.iobroker Caught by controller[0]:     at StateRedisClient.setState (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:610:35)
                                2023-09-14 23:26:15.396  - error: host.iobroker instance system.adapter.mqtt-client.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                2023-09-14 23:26:15.396  - info: host.iobroker Restart adapter system.adapter.mqtt-client.0 because enabled
                                • O oFbEQnpoLKKl6mbY5e13
                                  @foxriver76
                                  foxriver76F Offline
                                  foxriver76F Offline
                                  foxriver76
                                  @ofbeqnpolkkl6mby5e13 müssen wir im adapter fixen
                                  O 3 Antworten Letzte Antwort
                                    O Offline
                                    O Offline
                                    @foxriver76
                                    Soll ich Issue erstellen?
                                    foxriver76F KrisiunK 2 Antworten Letzte Antwort
                                      @foxriver76
                                      foxriver76F Offline
                                      foxriver76F Offline
                                      foxriver76
                                      @ofbeqnpolkkl6mby5e13 ja sehr gerne
                                        O Offline
                                        O Offline
                                        @foxriver76
                                        https://github.com/iobroker-community-adapters/ioBroker.mqtt-client/issues/233
                                          @foxriver76
                                          KrisiunK Offline
                                          KrisiunK Offline
                                          Krisiun
                                          Ja bitte wobei ich weiß nicht was ich damit anfangen soll. Irgend wie will mir niemand das ganze hier erklären obwohl ich möchte das alles verstehen. Vielen Dank.
