  4. s7 Adapter funktioniert nicht mehr noch node update
    6.5k
60 Beiträge 7 Kommentatoren 4.2k Aufrufe 4 Beobachtet
  • J Offline
    Jacke
    So sieht das skript aus
    ioBroker nodejs fixer 2023-09-07
    Recommended nodejs-version is: 18.17.1
    Checking your installation now. Please be patient!
    Your current setup is:
    /usr/bin/node           v16.18.0
    /usr/bin/npm            8.19.2
    /usr/bin/npx            8.19.2
    /usr/bin/corepack       0.14.1
    I found these nodejs versions available for installation:
    nodejs:
      Installed: 16.18.0-deb-1nodesource1
      Candidate: 16.18.0-deb-1nodesource1
      Version table:
     *** 16.18.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x hirsute/main amd64 Packages
         12.21.0~dfsg-3ubuntu1 500
            500 http://old-releases.ubuntu.com/ubuntu hirsute/universe amd64 Packages
    Nothing to do, your installation is using the correct paths.
    You are running nodejs v16.18.0. Do you want to install recommended version 18.17.1?
    Press <y> to continue or any other key to quit
    Trying to fix your installation now. Please be patient.
    [sudo] password for nils:
    lxc
    Waiting for ioBroker to shut down - Give me a minute...
    *** These repos are active on your system:
    Hit:1 http://old-releases.ubuntu.com/ubuntu hirsute InRelease
    Hit:2 http://old-releases.ubuntu.com/ubuntu hirsute-updates InRelease
    Hit:3 http://old-releases.ubuntu.com/ubuntu hirsute-security InRelease
    Reading package lists... Done
    *** Installing ca-certificates, curl and gnupg, just in case they are missing.
    *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
    deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
    Package: nodejs
    Pin: origin deb.nodesource.com
    Pin-Priority: 1001
    *** These repos are active after the adjustments:
    Get:1 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
    Hit:2 http://old-releases.ubuntu.com/ubuntu hirsute InRelease
    Hit:3 http://old-releases.ubuntu.com/ubuntu hirsute-updates InRelease
    Get:4 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages [5181 B]
    Hit:5 http://old-releases.ubuntu.com/ubuntu hirsute-security InRelease
    Fetched 17.3 kB in 0s (35.8 kB/s)
    Installing the recommended nodejs version now!
    Exact recommended version unknown, installing a fallback!
    The following packages will be upgraded:
      nodejs
    1 upgraded, 0 newly installed, 0 to remove and 5 not upgraded.
    Need to get 29.4 MB of archives.
    After this operation, 60.1 MB of additional disk space will be used.
    Get:1 https://deb.nodesource.com/node_18.x nodistro/main amd64 nodejs amd64 18.17.0-1nodesource1 [29.4 MB]
    Fetched 29.4 MB in 1s (35.4 MB/s)
    (Reading database ... 35480 files and directories currently installed.)
    Preparing to unpack .../nodejs_18.17.0-1nodesource1_amd64.deb ...
    Detected old npm client, removing...
    Unpacking nodejs (18.17.0-1nodesource1) over (16.18.0-deb-1nodesource1) ...
    Setting up nodejs (18.17.0-1nodesource1) ...
    Processing triggers for man-db (2.9.4-2) ...
    Updating fallback to latest nodejs v18 release
    Calculating upgrade... Done
    The following packages have been kept back:
      libgl1-mesa-dri libglapi-mesa libglx-mesa0 ubuntu-advantage-tools
      nodejs python3-gdbm
    2 upgraded, 0 newly installed, 0 to remove and 4 not upgraded.
    After this operation, 32.8 kB of additional disk space will be used.
    Get:1 https://deb.nodesource.com/node_18.x nodistro/main amd64 nodejs amd64 18.17.1-1nodesource1 [29.4 MB]
    Get:2 http://old-releases.ubuntu.com/ubuntu hirsute-updates/main amd64 python3-gdbm amd64 3.9.5-0ubuntu3~21.04 [20.1 kB]
    Fetched 29.4 MB in 1s (39.5 MB/s)
    (Reading database ... 37965 files and directories currently installed.)
    Preparing to unpack .../python3-gdbm_3.9.5-0ubuntu3~21.04_amd64.deb ...
    Unpacking python3-gdbm:amd64 (3.9.5-0ubuntu3~21.04) over (3.9.4-0ubuntu1) ...
    Preparing to unpack .../nodejs_18.17.1-1nodesource1_amd64.deb ...
    Unpacking nodejs (18.17.1-1nodesource1) over (18.17.0-1nodesource1) ...
    Setting up python3-gdbm:amd64 (3.9.5-0ubuntu3~21.04) ...
    Setting up nodejs (18.17.1-1nodesource1) ...
    *** You need to manually restart your container now! ***
    We tried our best to fix your nodejs. Please run 'iob diag' again to verify.
    So sieht danach der Fehler im Log aus
    host.IoBrokerLXC
    2023-09-11 17:41:24.854	error	instance system.adapter.s7.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.IoBrokerLXC
    2023-09-11 17:41:24.854	error	Caught by controller[0]: Node.js v18.17.1
    host.IoBrokerLXC
    2023-09-11 17:41:24.854	error	Caught by controller[0]: }
    host.IoBrokerLXC
    2023-09-11 17:41:24.854	error	Caught by controller[0]: ]
    host.IoBrokerLXC
    2023-09-11 17:41:24.854	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/lib/binding/node-v108-linux-x64/node_snap7.node'
    host.IoBrokerLXC
    2023-09-11 17:41:24.854	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/addon-build/default/install-root/node_snap7.node',
    host.IoBrokerLXC
    2023-09-11 17:41:24.854	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/addon-build/debug/install-root/node_snap7.node',
    host.IoBrokerLXC
    2023-09-11 17:41:24.854	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/addon-build/release/install-root/node_snap7.node',
    host.IoBrokerLXC
    2023-09-11 17:41:24.854	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/compiled/18.17.1/linux/x64/node_snap7.node',
    host.IoBrokerLXC
    2023-09-11 17:41:24.854	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/build/default/node_snap7.node',
    host.IoBrokerLXC
    2023-09-11 17:41:24.854	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/Release/node_snap7.node',
    host.IoBrokerLXC
    2023-09-11 17:41:24.854	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/out/Release/node_snap7.node',
    host.IoBrokerLXC
    2023-09-11 17:41:24.854	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/Debug/node_snap7.node',
    host.IoBrokerLXC
    2023-09-11 17:41:24.854	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/out/Debug/node_snap7.node',
    host.IoBrokerLXC
    2023-09-11 17:41:24.854	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/build/Release/node_snap7.node',
    host.IoBrokerLXC
    2023-09-11 17:41:24.853	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/build/Debug/node_snap7.node',
    host.IoBrokerLXC
    2023-09-11 17:41:24.853	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/build/node_snap7.node',
    host.IoBrokerLXC
    2023-09-11 17:41:24.853	error	Caught by controller[0]: tries: [
    host.IoBrokerLXC
    2023-09-11 17:41:24.853	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14) {
    host.IoBrokerLXC
    2023-09-11 17:41:24.853	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.s7/main.js:9:21)
    host.IoBrokerLXC
    2023-09-11 17:41:24.853	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:121:18)
    host.IoBrokerLXC
    2023-09-11 17:41:24.853	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
    host.IoBrokerLXC
    2023-09-11 17:41:24.853	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:960:12)
    host.IoBrokerLXC
    2023-09-11 17:41:24.853	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
    host.IoBrokerLXC
    2023-09-11 17:41:24.853	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
    host.IoBrokerLXC
    host.IoBrokerLXC
    2023-09-11 17:41:24.853	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/node-snap7/lib/node-snap7.js:8:45)
    host.IoBrokerLXC
    2023-09-11 17:41:24.853	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:126:9)
    host.IoBrokerLXC
    2023-09-11 17:41:24.853	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/lib/binding/node-v108-linux-x64/node_snap7.node
    host.IoBrokerLXC
    2023-09-11 17:41:24.853	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/addon-build/default/install-root/node_snap7.node
    host.IoBrokerLXC
    2023-09-11 17:41:24.853	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/addon-build/debug/install-root/node_snap7.node
    host.IoBrokerLXC
    2023-09-11 17:41:24.853	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/addon-build/release/install-root/node_snap7.node
    host.IoBrokerLXC
    2023-09-11 17:41:24.853	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/compiled/18.17.1/linux/x64/node_snap7.node
    host.IoBrokerLXC
    2023-09-11 17:41:24.853	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/build/default/node_snap7.node
    host.IoBrokerLXC
    2023-09-11 17:41:24.852	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/Release/node_snap7.node
    host.IoBrokerLXC
    2023-09-11 17:41:24.852	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/out/Release/node_snap7.node
    host.IoBrokerLXC
    2023-09-11 17:41:24.852	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/Debug/node_snap7.node
    host.IoBrokerLXC
    2023-09-11 17:41:24.852	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/out/Debug/node_snap7.node
    host.IoBrokerLXC
    2023-09-11 17:41:24.852	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/build/Release/node_snap7.node
    host.IoBrokerLXC
    2023-09-11 17:41:24.852	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/build/Debug/node_snap7.node
    host.IoBrokerLXC
    2023-09-11 17:41:24.852	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/build/node_snap7.node
    host.IoBrokerLXC
    2023-09-11 17:41:24.852	error	Caught by controller[0]: Error: Could not locate the bindings file. Tried:
    host.IoBrokerLXC
    2023-09-11 17:41:24.852	error	Caught by controller[0]: ^
    host.IoBrokerLXC
    2023-09-11 17:41:24.852	error	Caught by controller[0]: throw err;
    host.IoBrokerLXC
    2023-09-11 17:41:24.852	error	Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:135
    host.IoBrokerLXC
    2023-09-11 17:41:22.039	error	iobroker npm-rebuild: Rebuilding native modules failed
    host.IoBrokerLXC
    2023-09-11 17:41:13.912	error	instance system.adapter.s7.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.IoBrokerLXC
    2023-09-11 17:41:13.912	error	Caught by controller[0]: Node.js v18.17.1
    host.IoBrokerLXC
    2023-09-11 17:41:13.912	error	Caught by controller[0]: }
    host.IoBrokerLXC
    2023-09-11 17:41:13.912	error	Caught by controller[0]: ]
    host.IoBrokerLXC
    2023-09-11 17:41:13.912	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/lib/binding/node-v108-linux-x64/node_snap7.node'
    host.IoBrokerLXC
    2023-09-11 17:41:13.912	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/addon-build/default/install-root/node_snap7.node',
    host.IoBrokerLXC
    2023-09-11 17:41:13.912	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/addon-build/debug/install-root/node_snap7.node',
    host.IoBrokerLXC
    2023-09-11 17:41:13.912	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/addon-build/release/install-root/node_snap7.node',
    host.IoBrokerLXC
    2023-09-11 17:41:13.912	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/compiled/18.17.1/linux/x64/node_snap7.node',
    host.IoBrokerLXC
    2023-09-11 17:41:13.912	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/build/default/node_snap7.node',
    host.IoBrokerLXC
    2023-09-11 17:41:13.912	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/Release/node_snap7.node',
    host.IoBrokerLXC
    2023-09-11 17:41:13.912	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/out/Release/node_snap7.node',
    host.IoBrokerLXC
    2023-09-11 17:41:13.912	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/Debug/node_snap7.node',
    host.IoBrokerLXC
    2023-09-11 17:41:13.912	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/out/Debug/node_snap7.node',
    host.IoBrokerLXC
    2023-09-11 17:41:13.912	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/build/Release/node_snap7.node',
    host.IoBrokerLXC
    2023-09-11 17:41:13.912	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/build/Debug/node_snap7.node',
    host.IoBrokerLXC
    2023-09-11 17:41:13.911	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/build/node_snap7.node',
    host.IoBrokerLXC
    2023-09-11 17:41:13.911	error	Caught by controller[0]: tries: [
    host.IoBrokerLXC
    2023-09-11 17:41:13.911	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14) {
    host.IoBrokerLXC
    2023-09-11 17:41:13.911	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.s7/main.js:9:21)
    host.IoBrokerLXC
    2023-09-11 17:41:13.911	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:121:18)
    host.IoBrokerLXC
    2023-09-11 17:41:13.911	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
    host.IoBrokerLXC
    2023-09-11 17:41:13.911	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:960:12)
    host.IoBrokerLXC
    2023-09-11 17:41:13.911	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
    host.IoBrokerLXC
    2023-09-11 17:41:13.911	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
    host.IoBrokerLXC
    host.IoBrokerLXC
    2023-09-11 17:41:13.911	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/node-snap7/lib/node-snap7.js:8:45)
    host.IoBrokerLXC
    2023-09-11 17:41:13.911	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:126:9)
    host.IoBrokerLXC
    2023-09-11 17:41:13.911	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/lib/binding/node-v108-linux-x64/node_snap7.node
    host.IoBrokerLXC
    2023-09-11 17:41:13.911	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/addon-build/default/install-root/node_snap7.node
    host.IoBrokerLXC
    2023-09-11 17:41:13.911	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/addon-build/debug/install-root/node_snap7.node
    host.IoBrokerLXC
    2023-09-11 17:41:13.911	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/addon-build/release/install-root/node_snap7.node
    host.IoBrokerLXC
    2023-09-11 17:41:13.911	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/compiled/18.17.1/linux/x64/node_snap7.node
    host.IoBrokerLXC
    2023-09-11 17:41:13.911	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/build/default/node_snap7.node
    host.IoBrokerLXC
    2023-09-11 17:41:13.911	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/Release/node_snap7.node
    host.IoBrokerLXC
    2023-09-11 17:41:13.911	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/out/Release/node_snap7.node
    host.IoBrokerLXC
    2023-09-11 17:41:13.911	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/Debug/node_snap7.node
    host.IoBrokerLXC
    2023-09-11 17:41:13.911	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/out/Debug/node_snap7.node
    host.IoBrokerLXC
    2023-09-11 17:41:13.911	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/build/Release/node_snap7.node
    host.IoBrokerLXC
    2023-09-11 17:41:13.911	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/build/Debug/node_snap7.node
    host.IoBrokerLXC
    2023-09-11 17:41:13.911	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/build/node_snap7.node
    host.IoBrokerLXC
    2023-09-11 17:41:13.911	error	Caught by controller[0]: Error: Could not locate the bindings file. Tried:
    host.IoBrokerLXC
    2023-09-11 17:41:13.911	error	Caught by controller[0]: ^
    host.IoBrokerLXC
    2023-09-11 17:41:13.911	error	Caught by controller[0]: throw err;
    host.IoBrokerLXC
    2023-09-11 17:41:13.911	error	Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:135
    host.IoBrokerLXC
    2023-09-11 17:41:11.932	error	iobroker npm-rebuild: Rebuilding native modules failed
    host.IoBrokerLXC
    2023-09-11 17:41:01.913	error	instance system.adapter.s7.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.IoBrokerLXC
    2023-09-11 17:41:01.913	error	Caught by controller[1]: Node.js v18.17.1
    host.IoBrokerLXC
    2023-09-11 17:41:01.913	error	Caught by controller[0]: }
    host.IoBrokerLXC
    2023-09-11 17:41:01.913	error	Caught by controller[0]: code: 'ERR_DLOPEN_FAILED'
    host.IoBrokerLXC
    2023-09-11 17:41:01.913	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32) {
    host.IoBrokerLXC
    2023-09-11 17:41:01.913	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
    host.IoBrokerLXC
    2023-09-11 17:41:01.913	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
    host.IoBrokerLXC
    2023-09-11 17:41:01.913	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/node-snap7/lib/node-snap7.js:8:45)
    host.IoBrokerLXC
    2023-09-11 17:41:01.913	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:112:48)
    host.IoBrokerLXC
    2023-09-11 17:41:01.913	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:121:18)
    host.IoBrokerLXC
    2023-09-11 17:41:01.913	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
    host.IoBrokerLXC
    2023-09-11 17:41:01.913	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:960:12)
    host.IoBrokerLXC
    host.IoBrokerLXC
    2023-09-11 17:41:01.913	error	Caught by controller[0]: at Module._extensions..node (node:internal/modules/cjs/loader:1340:18)
    host.IoBrokerLXC
    2023-09-11 17:41:01.913	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
    host.IoBrokerLXC
    2023-09-11 17:41:01.913	error	Caught by controller[0]: NODE_MODULE_VERSION 108. Please try re-compiling or re-installing
    host.IoBrokerLXC
    2023-09-11 17:41:01.913	error	Caught by controller[0]: NODE_MODULE_VERSION 93. This version of Node.js requires
    host.IoBrokerLXC
    2023-09-11 17:41:01.913	error	Caught by controller[0]: was compiled against a different Node.js version using
    host.IoBrokerLXC
    2023-09-11 17:41:01.913	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/node-snap7/build/Release/node_snap7.node'
    host.IoBrokerLXC
    2023-09-11 17:41:01.913	error	Caught by controller[0]: ^
    host.IoBrokerLXC
    2023-09-11 17:41:01.913	error	Caught by controller[0]: throw e;
    host.IoBrokerLXC
    2023-09-11 17:41:01.913	error	Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:121
    host.IoBrokerLXC
    2023-09-11 17:40:59.316	error	iobroker npm-rebuild: Rebuilding native modules failed
    host.IoBrokerLXC
    2023-09-11 17:40:43.510	error	instance system.adapter.s7.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.IoBrokerLXC
    2023-09-11 17:40:43.510	error	Caught by controller[0]: Node.js v18.17.1
    host.IoBrokerLXC
    2023-09-11 17:40:43.510	error	Caught by controller[0]: }
    host.IoBrokerLXC
    2023-09-11 17:40:43.510	error	Caught by controller[0]: code: 'ERR_DLOPEN_FAILED'
    host.IoBrokerLXC
    2023-09-11 17:40:43.509	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32) {
    host.IoBrokerLXC
    2023-09-11 17:40:43.509	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
    host.IoBrokerLXC
    2023-09-11 17:40:43.509	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
    host.IoBrokerLXC
    2023-09-11 17:40:43.509	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/node-snap7/lib/node-snap7.js:8:45)
    host.IoBrokerLXC
    2023-09-11 17:40:43.509	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:112:48)
    host.IoBrokerLXC
    2023-09-11 17:40:43.509	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:121:18)
    host.IoBrokerLXC
    2023-09-11 17:40:43.509	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
    host.IoBrokerLXC
    2023-09-11 17:40:43.509	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:960:12)
    host.IoBrokerLXC
    host.IoBrokerLXC
    2023-09-11 17:40:43.509	error	Caught by controller[0]: at Module._extensions..node (node:internal/modules/cjs/loader:1340:18)
    host.IoBrokerLXC
    2023-09-11 17:40:43.509	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
    host.IoBrokerLXC
    2023-09-11 17:40:43.509	error	Caught by controller[0]: NODE_MODULE_VERSION 108. Please try re-compiling or re-installing
    host.IoBrokerLXC
    2023-09-11 17:40:43.509	error	Caught by controller[0]: NODE_MODULE_VERSION 93. This version of Node.js requires
    host.IoBrokerLXC
    2023-09-11 17:40:43.509	error	Caught by controller[0]: was compiled against a different Node.js version using
    host.IoBrokerLXC
    2023-09-11 17:40:43.509	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/node-snap7/build/Release/node_snap7.node'
    host.IoBrokerLXC
    2023-09-11 17:40:43.509	error	Caught by controller[0]: ^
    host.IoBrokerLXC
    2023-09-11 17:40:43.509	error	Caught by controller[0]: throw e;
    host.IoBrokerLXC
    2023-09-11 17:40:43.509	error	Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:121
    • J Jacke
      /usr/bin/npm            8.19.2
      /usr/bin/npx            8.19.2
      nodejs:
        Version table:
      lxc
      Package: nodejs
      Pin-Priority: 1001
        nodejs
        nodejs python3-gdbm
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      host.IoBrokerLXC
      @jacke
      hirsute ist steinalt und wird nicht mehr aktiv gepflegt.
      Installier da die aktuelle LTS oder gleich ein Debian. Und dann ohne graphische Oberfläche.
      Hast du den Rat befolgt?
        @jacke
        Jacke
        schrieb am zuletzt editiert von Jacke
        @thomas-braun Ich habe den S7 adapter gestoppt und dann gesatrtet gleiches ergebnis.
        dann Habe ich die ganze Maschiene neu gestartet.
        Evtl. setze ich ein neues System auf und spiel dann alles über den Backitup Adapter neu ein
        • Thomas BraunT Online
          @jacke
          Das wird dir vermutlich nichts nutzen, bei mir baut das Ding mit aktuellem nodejs auch nicht mehr. Mit nodes@16 funktioniert es allerdings noch.
          https://forum.iobroker.net/topic/60999/simatic-s7-adapter-fehlermeldung
          https://github.com/mathiask88/node-snap7/issues/88
            @jacke
            Jacke
            Das ist natürlich schlecht hoffe da kommt ein update für den Adapter. dann warte ich mal aktuell kann ich nur Ring nicht mehr aktualisieren.
            • J Jacke
              @jacke sagte in s7 Adapter funktioniert nicht mehr noch node update:
              Das hat mit dem Adapter direkt auch nicht zu tun, das klemmt bei einer Dependency (node-snap7). Und die ist seit Jahren nicht mehr angepackt worden. Das sieht fürchte ich schlecht aus, in der derzeitigen Konstellation.
              • J Offline
                Jacke
                Ich habe gerade den Adapter auf einer frischen Installation gesartet und es funktioniert nun wollte ich ein Backup meiner alten installation auf dem neuen system einspielen hier mecker er mir den JS controller an
                host.IoBrokerDeb Using backup file 2023_09_12-09_16_32_backupiobroker.tar.gz
                iobroker controller daemon is not running
                host.IoBrokerDeb OK.
                The current version of js-controller differs from the version in the backup.
                The js-controller version of the backup can not be restored automatically.
                To restore the js-controller version of the backup, execute "npm i iobroker.js-controller@5.0.12 --production" inside your ioBroker directory
                If you really want to restore the backup with the current installed js-controller, execute the restore command with the --force flag
                nils@IoBrokerDeb:~$ iobroker update
                Used repository: stable
                Adapter    "admin"        : 6.8.0    , installed 6.3.5  [Updatable]
                Adapter    "backitup"     : 2.6.23   , installed 2.6.23
                Adapter    "s7"           : 1.3.15   , installed 1.3.15
                gestern hat er auf meinem alten system von 4 auf 5 geupgraded
                • J Jacke
                  mcm1957M Online
                  mcm1957M Online
                  mcm1957
                  @jacke
                  Welchen js-controller hat den das Zielsystem?
                  Soweit ich weiß kann ein js-controller 5 backup NUR auf einem js-controller 5 System restauriert werden.
                  https://forum.iobroker.net/topic/66108/js-controller-5-0-x-jetzt-in-der-beta
                  ACHTUNG backups inkompatibel bei Downgrades!!
                  Neben der Node.js Version gibt es eine wichtige Inkompatibilität: Backups die mit der 5.0 des js-controller erstellt wurden lassen sich nicht mit einem js-controller 4 oder kleiner wieder restoren!
                  Support Repositoryverwaltung.
                  LESEN - gute Forenbeitrage
                  • mcm1957M mcm1957
                    @jacke
                    Jacke
                    @mcm57
                    habe einen snapshot von gestern eingespielt mein altes system hat jetzt 4.0.23 das neue 4.0.24
                    npm i iobroker.js-controller@4.0.23 --production
                    mir wurde dieser befehl vorgeschlagen.
                    das IoBroker backup beinhaltet das auch NodeRed zigbee und javascript oder muss ich da noch ein einzelnes Backup einspielen?
                    • J Jacke
                      @mcm57
                      mcm1957M Online
                      mcm1957M Online
                      mcm1957
                      @jacke
                      Sorry,
                      da kann ich nicht helfen. Mir war nur die js-controller 5 breaking change Info bekannt auf die ich hinweisen wollte.
                      • tugsiT Offline
                        tugsiT Offline
                        tugsi
                        Da ich den S7-Adapter auch brauche, kurz nachgefragt, ist mir jetzt noch nicht so klar geworden.
                        Läuft der Adapter noch, wenn ich den JS-Controller auf die 5er-Version hochziehe?
                        Liegt es nur daran, wenn ich node auf 18 hochrüste?
                        Gruß Thomas
                        Master ioBroker in Proxmox als LXC auf 1. Tiny-Lenovo, Proxmox-VM als Slave auf 2. Tinyi-Lenovo mit Zigbee und Monitor zur Visualisierung, Hauptautomatisierung über S7 auf Beckhoff CX, dazu noch Shelly, Homematic...
                        • tugsiT tugsi
                          Gruß Thomas
                          mcm1957M Online
                          mcm1957M Online
                          mcm1957
                          @tugsi
                          Leider kann ich deine Frage nicht beantworten.
                          Aber wenn jemand definitiv ein Problem mit Node 18 dokumentieren kann, dann bitte unbedingt ein passendes Issue incl. aktueller Logs beim Adapter anlegen, da node 16 seit 11.9.2023 EOL ist und in der nächsten Zeit von immer mehr Adaptern nicht mehr unterstützt werden wird. Ein Adapter der nicht mit node 18 läuft, ist daher ein Problemfall...
                          Das oben referenzierte Issue bezieht sich auf node 19 welches einerseits ein (veralteter) Nachfolger von node 18 ist und andrerseits ein unstable release. Dieses Issue wird sicher nicht intensiv beachtet. Relevant sind derzeit node 18 und node 20
                          • mcm1957M mcm1957
                            @tugsi
                            @mcm57
                            Die Dependency node-snap7 baut nicht mit nodejs >18, mit 18 rumpelt es ein wenig. Jedenfalls auf meinem Testsystem.
                            Issue ist ja auch aus 12/2022. Damals war das aktuell und nodejs@20 noch nicht released.
                            tugsiT 1 Antwort Letzte Antwort
                              @mcm57
                              tugsiT Offline
                              tugsiT Offline
                              tugsi
                              @thomas-braun @mcm57
                              Ok, dann heißt es also einfach ausprobieren, in wieweit Probleme mit node18 und/oder JS-Controller 5.x auftreten.
                              Werde ich mal auf meine Agenda legen, wenn ich etwas mehr Zeit habe, widme ich mich dem, denn ich wollte mein System auf den neuesten Stand mal wieder bringen.
                              Danke für die Antworten.
                              • Basti97B Offline
                                Basti97B Offline
                                Basti97
                                Ich wollte mein Nodejs aktualisieren mit dem Befehl iob nodejs-update aber irgendwie funktioniert das bei diesen Adapter nicht alle anderen laufen nach dem update.
                                host.SmartHomeMira
                                2025-11-09 16:41:08.287 error instance system.adapter.s7.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                host.SmartHomeMira
                                2025-11-09 16:41:08.287 error Caught by controller[1]: Node.js v22.21.0
                                host.SmartHomeMira
                                2025-11-09 16:41:08.287 error Caught by controller[0]: }
                                host.SmartHomeMira
                                2025-11-09 16:41:08.287 error Caught by controller[0]: code: 'ERR_DLOPEN_FAILED'
                                host.SmartHomeMira
                                2025-11-09 16:41:08.287 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1706:14) {
                                host.SmartHomeMira
                                2025-11-09 16:41:08.287 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/node-snap7/lib/node-snap7.js:8:45)
                                host.SmartHomeMira
                                2025-11-09 16:41:08.287 error Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:112:48)
                                host.SmartHomeMira
                                2025-11-09 16:41:08.287 error Caught by controller[0]: at require (node:internal/modules/helpers:147:16)
                                host.SmartHomeMira
                                2025-11-09 16:41:08.287 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1463:12)
                                host.SmartHomeMira
                                2025-11-09 16:41:08.287 error Caught by controller[0]: at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                                host.SmartHomeMira
                                2025-11-09 16:41:08.287 error Caught by controller[0]: at TracingChannel.traceSync (node:diagnostics_channel:328:14)
                                host.SmartHomeMira
                                2025-11-09 16:41:08.287 error Caught by controller[0]: at Function._load (node:internal/modules/cjs/loader:1263:12)
                                host.SmartHomeMira
                                2025-11-09 16:41:08.287 error Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1441:32)
                                host.SmartHomeMira
                                2025-11-09 16:41:08.287 error Caught by controller[0]: at Object..node (node:internal/modules/cjs/loader:1865:18)
                                host.SmartHomeMira
                                2025-11-09 16:41:08.287 error Caught by controller[0]: the module (for instance, using npm rebuild or npm install).
                                host.SmartHomeMira
                                2025-11-09 16:41:08.287 error Caught by controller[0]: NODE_MODULE_VERSION 127. Please try re-compiling or re-installing
                                host.SmartHomeMira
                                2025-11-09 16:41:08.287 error Caught by controller[0]: NODE_MODULE_VERSION 115. This version of Node.js requires
                                host.SmartHomeMira
                                2025-11-09 16:41:08.287 error Caught by controller[0]: was compiled against a different Node.js version using
                                host.SmartHomeMira
                                2025-11-09 16:41:08.287 error Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/node-snap7/build/Release/node_snap7.node'
                                host.SmartHomeMira
                                2025-11-09 16:41:08.287 error Caught by controller[0]: ^
                                host.SmartHomeMira
                                2025-11-09 16:41:08.286 error Caught by controller[0]: throw e;
                                host.SmartHomeMira
                                2025-11-09 16:41:08.286 error Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:121
                                host.SmartHomeMira
                                2025-11-09 16:41:07.842 info instance system.adapter.s7.0 in version "1.4.3" started with pid 5406
                                Iobroker läuft als VM auf Proxmoxserver x folgende Hersteller im Einsatz Sonoff, Gosund, Siemens x Aofo über Tasmota x Zigbee x das Smarthome wächst und wächst
                                Thomas BraunT Ro75R 2 Antworten Letzte Antwort
                                • Basti97B Basti97
                                  host.SmartHomeMira
                                  host.SmartHomeMira
                                  host.SmartHomeMira
                                  host.SmartHomeMira
                                  host.SmartHomeMira
                                  host.SmartHomeMira
                                  host.SmartHomeMira
                                  host.SmartHomeMira
                                  host.SmartHomeMira
                                  host.SmartHomeMira
                                  host.SmartHomeMira
                                  host.SmartHomeMira
                                  host.SmartHomeMira
                                  host.SmartHomeMira
                                  host.SmartHomeMira
                                  host.SmartHomeMira
                                  host.SmartHomeMira
                                  host.SmartHomeMira
                                  host.SmartHomeMira
                                  host.SmartHomeMira
                                  host.SmartHomeMira
                                  host.SmartHomeMira
                                  host.SmartHomeMira
                                  @basti97 sagte in s7 Adapter funktioniert nicht mehr noch node update:
                                  host.SmartHomeMira
                                  host.SmartHomeMira
                                  host.SmartHomeMira
                                  Liest sich blöd, oder? Dreh die Ausgabe um, wenn du schon aus dem GUI kopierst.
                                  Besser das Log aus
                                  iob logs
                                  verwenden.
                                  Zum Problem: Installier den Adapter nochmal neu.
                                  • Basti97B Basti97
                                    host.SmartHomeMira
                                    host.SmartHomeMira
                                    host.SmartHomeMira
                                    host.SmartHomeMira
                                    host.SmartHomeMira
                                    host.SmartHomeMira
                                    host.SmartHomeMira
                                    host.SmartHomeMira
                                    host.SmartHomeMira
                                    host.SmartHomeMira
                                    host.SmartHomeMira
                                    host.SmartHomeMira
                                    host.SmartHomeMira
                                    host.SmartHomeMira
                                    host.SmartHomeMira
                                    host.SmartHomeMira
                                    host.SmartHomeMira
                                    host.SmartHomeMira
                                    host.SmartHomeMira
                                    host.SmartHomeMira
                                    host.SmartHomeMira
                                    host.SmartHomeMira
                                    host.SmartHomeMira
                                    Ro75R Offline
                                    Ro75R Offline
                                    Ro75
                                    @basti97 wenn ich das aus vorherigen Posts richtig gesehen habe, ist dein OS uralt.
                                    Ro75.
                                    • Ro75R Ro75
                                      Ro75.
                                      @ro75 sagte in s7 Adapter funktioniert nicht mehr noch node update:
                                      Nee, die Postings sind uralt...
                                      Basti97B 1 Antwort Letzte Antwort
                                      • Basti97B Offline
                                        Basti97B Offline
                                        Basti97
                                        2025-11-09 17:04:20.278 - error: host.SmartHomeMira Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:135
                                        2025-11-09 17:04:20.278 - error: host.SmartHomeMira Caught by controller[0]: throw err;
                                        2025-11-09 17:04:20.278 - error: host.SmartHomeMira Caught by controller[0]: ^
                                        2025-11-09 17:04:20.278 - error: host.SmartHomeMira Caught by controller[0]: Error: Could not locate the bindings file. Tried:
                                        2025-11-09 17:04:20.278 - error: host.SmartHomeMira Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/build/node_snap7.node
                                        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/build/Debug/node_snap7.node
                                        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/build/Release/node_snap7.node
                                        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/out/Debug/node_snap7.node
                                        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/Debug/node_snap7.node
                                        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/out/Release/node_snap7.node
                                        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/Release/node_snap7.node
                                        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/build/default/node_snap7.node
                                        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/compiled/22.21.0/linux/x64/node_snap7.node
                                        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/addon-build/release/install-root/node_snap7.node
                                        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/addon-build/debug/install-root/node_snap7.node
                                        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/addon-build/default/install-root/node_snap7.node
                                        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/lib/binding/node-v127-linux-x64/node_snap7.node
                                        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:126:9)
                                        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: at Object. (/opt/iobroker/node_modules/node-snap7/lib/node-snap7.js:8:45)
                                        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1706:14)
                                        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: at Object..js (node:internal/modules/cjs/loader:1839:10)
                                        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1441:32)
                                        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: at Function._load (node:internal/modules/cjs/loader:1263:12)
                                        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: at TracingChannel.traceSync (node:diagnostics_channel:328:14)
                                        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                                        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1463:12)
                                        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: at require (node:internal/modules/helpers:147:16) {
                                        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: tries: [
                                        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/build/node_snap7.node',
                                        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/build/Debug/node_snap7.node',
                                        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/build/Release/node_snap7.node',
                                        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/out/Debug/node_snap7.node',
                                        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/Debug/node_snap7.node',
                                        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/out/Release/node_snap7.node',
                                        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/Release/node_snap7.node',
                                        2025-11-09 17:04:20.279 - error: host.SmartHomeMira Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/build/default/node_snap7.node',
                                        2025-11-09 17:04:20.280 - error: host.SmartHomeMira Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/compiled/22.21.0/linux/x64/node_snap7.node',
                                        2025-11-09 17:04:20.280 - error: host.SmartHomeMira Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/addon-build/release/install-root/node_snap7.node',
                                        2025-11-09 17:04:20.280 - error: host.SmartHomeMira Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/addon-build/debug/install-root/node_snap7.node',
                                        2025-11-09 17:04:20.280 - error: host.SmartHomeMira Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/addon-build/default/install-root/node_snap7.node',
                                        2025-11-09 17:04:20.280 - error: host.SmartHomeMira Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/lib/binding/node-v127-linux-x64/node_snap7.node'
                                        2025-11-09 17:04:20.280 - error: host.SmartHomeMira Caught by controller[0]: ]
                                        2025-11-09 17:04:20.280 - error: host.SmartHomeMira Caught by controller[0]: }
                                        2025-11-09 17:04:20.280 - error: host.SmartHomeMira Caught by controller[1]: Node.js v22.21.0
                                        2025-11-09 17:04:20.280 - error: host.SmartHomeMira instance system.adapter.s7.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                        2025-11-09 17:04:20.280 - info: host.SmartHomeMira Rebuild for adapter system.adapter.s7.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                                        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:135
                                        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: throw err;
                                        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: ^
                                        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: Error: Could not locate the bindings file. Tried:
                                        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/build/node_snap7.node
                                        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/build/Debug/node_snap7.node
                                        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/build/Release/node_snap7.node
                                        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/out/Debug/node_snap7.node
                                        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/Debug/node_snap7.node
                                        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/out/Release/node_snap7.node
                                        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/Release/node_snap7.node
                                        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/build/default/node_snap7.node
                                        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/compiled/22.21.0/linux/x64/node_snap7.node
                                        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/addon-build/release/install-root/node_snap7.node
                                        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/addon-build/debug/install-root/node_snap7.node
                                        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/addon-build/default/install-root/node_snap7.node
                                        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/lib/binding/node-v127-linux-x64/node_snap7.node
                                        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:126:9)
                                        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: at Object. (/opt/iobroker/node_modules/node-snap7/lib/node-snap7.js:8:45)
                                        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1706:14)
                                        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: at Object..js (node:internal/modules/cjs/loader:1839:10)
                                        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1441:32)
                                        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: at Function._load (node:internal/modules/cjs/loader:1263:12)
                                        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: at TracingChannel.traceSync (node:diagnostics_channel:328:14)
                                        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                                        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1463:12)
                                        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: at require (node:internal/modules/helpers:147:16) {
                                        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: tries: [
                                        2025-11-09 17:04:20.344 - error: host.SmartHomeMira Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/build/node_snap7.node',
                                        2025-11-09 17:04:20.345 - error: host.SmartHomeMira Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/build/Debug/node_snap7.node',
                                        2025-11-09 17:04:20.345 - error: host.SmartHomeMira Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/build/Release/node_snap7.node',
                                        2025-11-09 17:04:20.345 - error: host.SmartHomeMira Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/out/Debug/node_snap7.node',
                                        2025-11-09 17:04:20.345 - error: host.SmartHomeMira Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/Debug/node_snap7.node',
                                        2025-11-09 17:04:20.345 - error: host.SmartHomeMira Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/out/Release/node_snap7.node',
                                        2025-11-09 17:04:20.345 - error: host.SmartHomeMira Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/Release/node_snap7.node',
                                        2025-11-09 17:04:20.345 - error: host.SmartHomeMira Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/build/default/node_snap7.node',
                                        2025-11-09 17:04:20.345 - error: host.SmartHomeMira Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/compiled/22.21.0/linux/x64/node_snap7.node',
                                        2025-11-09 17:04:20.345 - error: host.SmartHomeMira Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/addon-build/release/install-root/node_snap7.node',
                                        2025-11-09 17:04:20.345 - error: host.SmartHomeMira Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/addon-build/debug/install-root/node_snap7.node',
                                        2025-11-09 17:04:20.345 - error: host.SmartHomeMira Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/addon-build/default/install-root/node_snap7.node',
                                        2025-11-09 17:04:20.345 - error: host.SmartHomeMira Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/lib/binding/node-v127-linux-x64/node_snap7.node'
                                        2025-11-09 17:04:20.345 - error: host.SmartHomeMira Caught by controller[0]: ]
                                        2025-11-09 17:04:20.345 - error: host.SmartHomeMira Caught by controller[0]: }
                                        2025-11-09 17:04:20.345 - error: host.SmartHomeMira Caught by controller[0]: Node.js v22.21.0
                                        2025-11-09 17:04:20.345 - error: host.SmartHomeMira instance system.adapter.s7.1 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                        2025-11-09 17:04:20.345 - info: host.SmartHomeMira Rebuild for adapter system.adapter.s7.1 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production"
                                          Basti97B Offline
                                          Basti97B Offline
                                          Basti97
                                          @thomas-braun so hier wenn ich den Adapter lösche dann sind ja die Konfigurrationen auch weg. Denn in dem S7 Adapter kann man leider die konfigurrationen so nicht sichern wie bei den anderen
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.915 error Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:135
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.915 error Caught by controller[0]: throw err;
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.915 error Caught by controller[0]: ^
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.915 error Caught by controller[0]: Error: Could not locate the bindings file. Tried:
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.915 error Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/build/node_snap7.node
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.915 error Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/build/Debug/node_snap7.node
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.915 error Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/build/Release/node_snap7.node
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.915 error Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/out/Debug/node_snap7.node
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.915 error Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/Debug/node_snap7.node
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.915 error Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/out/Release/node_snap7.node
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.915 error Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/Release/node_snap7.node
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.915 error Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/build/default/node_snap7.node
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.915 error Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/compiled/22.21.0/linux/x64/node_snap7.node
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.916 error Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/addon-build/release/install-root/node_snap7.node
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.916 error Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/addon-build/debug/install-root/node_snap7.node
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.916 error Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/addon-build/default/install-root/node_snap7.node
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.916 error Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/lib/binding/node-v127-linux-x64/node_snap7.node
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.916 error Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:126:9)
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.916 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/node-snap7/lib/node-snap7.js:8:45)
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.916 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1706:14)
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.916 error Caught by controller[0]: at Object..js (node:internal/modules/cjs/loader:1839:10)
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.916 error Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1441:32)
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.916 error Caught by controller[0]: at Function._load (node:internal/modules/cjs/loader:1263:12)
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.916 error Caught by controller[0]: at TracingChannel.traceSync (node:diagnostics_channel:328:14)
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.916 error Caught by controller[0]: at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.916 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1463:12)
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.916 error Caught by controller[0]: at require (node:internal/modules/helpers:147:16) {
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.916 error Caught by controller[0]: tries: [
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.916 error Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/build/node_snap7.node',
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.916 error Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/build/Debug/node_snap7.node',
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.916 error Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/build/Release/node_snap7.node',
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.916 error Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/out/Debug/node_snap7.node',
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.916 error Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/Debug/node_snap7.node',
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.916 error Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/out/Release/node_snap7.node',
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.916 error Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/Release/node_snap7.node',
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.916 error Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/build/default/node_snap7.node',
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.916 error Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/compiled/22.21.0/linux/x64/node_snap7.node',
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.916 error Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/addon-build/release/install-root/node_snap7.node',
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.916 error Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/addon-build/debug/install-root/node_snap7.node',
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.916 error Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/addon-build/default/install-root/node_snap7.node',
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.916 error Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/lib/binding/node-v127-linux-x64/node_snap7.node'
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.916 error Caught by controller[0]: ]
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.916 error Caught by controller[0]: }
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.916 error Caught by controller[0]: Node.js v22.21.0
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.916 error instance system.adapter.s7.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.916 info Adapter system.adapter.s7.0 needs rebuild and will be restarted afterwards.
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.916 info system.adapter.s7.0 will be rebuilt
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.916 warn adapter "s7" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.917 info iobroker rebuild
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.976 error Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:135
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.976 error Caught by controller[0]: throw err;
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.976 error Caught by controller[0]: ^
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.976 error Caught by controller[0]: Error: Could not locate the bindings file. Tried:
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.976 error Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/build/node_snap7.node
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.976 error Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/build/Debug/node_snap7.node
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.976 error Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/build/Release/node_snap7.node
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.976 error Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/out/Debug/node_snap7.node
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.977 error Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/Debug/node_snap7.node
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.977 error Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/out/Release/node_snap7.node
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.977 error Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/Release/node_snap7.node
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.977 error Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/build/default/node_snap7.node
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.977 error Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/compiled/22.21.0/linux/x64/node_snap7.node
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.977 error Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/addon-build/release/install-root/node_snap7.node
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.977 error Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/addon-build/debug/install-root/node_snap7.node
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.977 error Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/addon-build/default/install-root/node_snap7.node
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.977 error Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/lib/binding/node-v127-linux-x64/node_snap7.node
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.977 error Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:126:9)
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.977 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/node-snap7/lib/node-snap7.js:8:45)
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.977 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1706:14)
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.977 error Caught by controller[0]: at Object..js (node:internal/modules/cjs/loader:1839:10)
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.977 error Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1441:32)
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.977 error Caught by controller[0]: at Function._load (node:internal/modules/cjs/loader:1263:12)
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.977 error Caught by controller[0]: at TracingChannel.traceSync (node:diagnostics_channel:328:14)
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.977 error Caught by controller[0]: at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.977 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1463:12)
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.977 error Caught by controller[0]: at require (node:internal/modules/helpers:147:16) {
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.977 error Caught by controller[0]: tries: [
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.977 error Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/build/node_snap7.node',
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.977 error Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/build/Debug/node_snap7.node',
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.977 error Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/build/Release/node_snap7.node',
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.977 error Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/out/Debug/node_snap7.node',
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.977 error Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/Debug/node_snap7.node',
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.977 error Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/out/Release/node_snap7.node',
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.977 error Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/Release/node_snap7.node',
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.977 error Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/build/default/node_snap7.node',
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.977 error Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/compiled/22.21.0/linux/x64/node_snap7.node',
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.977 error Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/addon-build/release/install-root/node_snap7.node',
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.977 error Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/addon-build/debug/install-root/node_snap7.node',
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.977 error Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/addon-build/default/install-root/node_snap7.node',
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.977 error Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/lib/binding/node-v127-linux-x64/node_snap7.node'
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.977 error Caught by controller[0]: ]
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.977 error Caught by controller[0]: }
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.977 error Caught by controller[0]: Node.js v22.21.0
                                          host.SmartHomeMira
                                          2025-11-09 17:03:45.977 error instance system.adapter.s7.1 terminated with code 1 (JS_CONTROLLER_STOPPED)
