  4. js-controller 5.0.x jetzt in der BETA
    6.7k
580 Beiträge 71 Kommentatoren 247.0k Aufrufe 67 Beobachtet
    @tom2323 sagte in js-controller 5.0.x jetzt in der BETA:
    sudo iobroker
    NIE, NIE, NIEMALS den iobroker in Verbindung mit sudo verwenden.
    iobroker stop
    iobroker fix
    iobroker start
    Dann
    iob diag
    anschauen.
    Ist aber auch was für einen separaten Thread.
    Tom2323
    #557
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model		: Raspberry Pi 4 Model B Rev 1.1
    Architecture    : armv7l
    Docker          : false
    Virtualization  : none
    Distributor ID:	Raspbian
    Description:	Raspbian GNU/Linux 11 (bullseye)
    Release:	11
    Codename:	bullseye
    PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
     14:54:07 up  3:37,  2 users,  load average: 1.65, 0.72, 0.66
    CPU threads: 4
    Raspberry only:
    throttled=0x50000
    Other values than 0x0 hint to temperature/voltage problems
    temp=40.9'C
    volt=0.8500V
    *** Time and Time Zones ***
                   Local time: Tue 2023-08-29 14:54:07 CEST
               Universal time: Tue 2023-08-29 12:54:07 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server: 	false
    Desktop:
    Terminal: 	tty
    Boot Target: 	multi-user.target
    *** MEMORY ***
    Mem:            3.8G        730M        717M        0.0K        2.4G        3.0G
    Swap:            99M        2.0M         97M
    Total:          3.9G        732M        814M
             3838 M total memory
              730 M used memory
              490 M active memory
             2379 M inactive memory
              716 M free memory
              144 M buffer memory
             2246 M swap cache
               99 M total swap
                2 M used swap
               97 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4       29G  9.0G   19G  33% /
    devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
    tmpfs          tmpfs     768M  828K  767M   1% /run
    /dev/mmcblk0p1 vfat      253M   50M  203M  20% /boot
    tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
    [Tue Aug 29 11:16:23 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:2D:8B:89 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=96904d48-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Tue Aug 29 11:16:24 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
    [Tue Aug 29 11:16:24 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
    [Tue Aug 29 11:16:24 2023] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
    [Tue Aug 29 11:16:24 2023] EXT4-fs (mmcblk0p2): 1 truncate cleaned up
    [Tue Aug 29 11:16:24 2023] EXT4-fs (mmcblk0p2): recovery complete
    [Tue Aug 29 11:16:24 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
    [Tue Aug 29 11:16:24 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Tue Aug 29 11:16:26 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    /var:
    1.6G	/var/
    1005M	/var/log
    1001M	/var/log/journal/bd463378997f44f088b185e90db76a13
    414M	/var/cache
    Archived and active journals take up 1000.1M in the file system.
    /opt/iobroker/backups:
    2.7G	/opt/iobroker/backups/
    4.0K	/opt/iobroker/backups/redistmp
    /opt/iobroker/iobroker-data:
    566M	/opt/iobroker/iobroker-data/
    456M	/opt/iobroker/iobroker-data/files
    88M	/opt/iobroker/iobroker-data/files/echarts.admin
    78M	/opt/iobroker/iobroker-data/backup-objects
    72M	/opt/iobroker/iobroker-data/files/telegram.admin
    23M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
    23M	/opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
    23M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.eb0afecd.js.map
    21M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.e564fb87.js.map
    20M	/opt/iobroker/iobroker-data/files/cameras.admin/static/js/main.9f324f1d.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v14.20.0
    /usr/bin/node 		v14.20.0
    /usr/bin/npm 		6.14.17
    /usr/bin/npx 		6.14.17
    nodejs:
      Installed: 14.20.0-deb-1nodesource1
      Candidate: 14.21.3-deb-1nodesource1
      Version table:
         14.21.3-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_14.x bullseye/main armhf Packages
     *** 14.20.0-deb-1nodesource1 100
         12.22.12~dfsg-1~deb11u4 500
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller: 	4.0.24
    admin: 		6.2.23
    javascript: 	7.1.4
    npm ERR! peer dep missing: @iobroker/types@^5.0.11, required by @iobroker/adapter-core@3.0.3
    npm ERR! peer dep missing: tough-cookie@^4.0.0, required by http-cookie-agent@4.0.2
    Adapters from github: 	11
    Adapter State
    + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.apple-find-me.0          : apple-find-me         : ioBroker                                 - disabled
      system.adapter.apple-find-me.1          : apple-find-me         : ioBroker                                 - disabled
      system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
      system.adapter.blueconnect.0            : blueconnect           : ioBroker                                 - disabled
      system.adapter.bshb.0                   : bshb                  : ioBroker                                 - disabled
      system.adapter.bshb.1                   : bshb                  : ioBroker                                 - disabled
      system.adapter.cameras.0                : cameras               : ioBroker                                 - disabled, port: 8200, bind: 192.168.1.86
      system.adapter.daswetter.0              : daswetter             : ioBroker                                 - disabled
    + system.adapter.daswetter.1              : daswetter             : ioBroker                                 -  enabled
      system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 -  enabled
    + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
      system.adapter.ds18b20.0                : ds18b20               : ioBroker                                 -  enabled
      system.adapter.echarts.0                : echarts               : ioBroker                                 -  enabled
      system.adapter.find-my-iphone.0         : find-my-iphone        : ioBroker                                 - disabled
      system.adapter.firetv.0                 : firetv                : ioBroker                                 - disabled
      system.adapter.fritzbox.0               : fritzbox              : ioBroker                                 - disabled
      system.adapter.fritzdect.0              : fritzdect             : ioBroker                                 - disabled
      system.adapter.history.0                : history               : ioBroker                                 - disabled
      system.adapter.homeconnect.0            : homeconnect           : ioBroker                                 - disabled
      system.adapter.homeconnect.1            : homeconnect           : ioBroker                                 - disabled
      system.adapter.ical.0                   : ical                  : ioBroker                                 - disabled
      system.adapter.ical.1                   : ical                  : ioBroker                                 - disabled
      system.adapter.influxdb.0               : influxdb              : ioBroker                                 - disabled, port: 8086
      system.adapter.info.0                   : info                  : ioBroker                                 - disabled
    + system.adapter.innogy-smarthome.0       : innogy-smarthome      : ioBroker                                 -  enabled
      system.adapter.jarvis.0                 : jarvis                : ioBroker                                 - disabled
      system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
      system.adapter.mclighting.0             : mclighting            : ioBroker                                 - disabled, port: 81
    + system.adapter.mielecloudservice.0      : mielecloudservice     : ioBroker                                 -  enabled
      system.adapter.net-tools.0              : net-tools             : ioBroker                                 - disabled
      system.adapter.node-red.0               : node-red              : ioBroker                                 - disabled, port: 1880, bind: 0.0.0.0
    + system.adapter.owntracks.0              : owntracks             : ioBroker                                 -  enabled, port: 1884, bind: 0.0.0.0
      system.adapter.pi-hole.0                : pi-hole               : ioBroker                                 - disabled
      system.adapter.ping.0                   : ping                  : ioBroker                                 - disabled
      system.adapter.ping.1                   : ping                  : ioBroker                                 - disabled
    + system.adapter.places.0                 : places                : ioBroker                                 -  enabled
      system.adapter.plex.0                   : plex                  : ioBroker                                 - disabled
      system.adapter.plex.1                   : plex                  : ioBroker                                 - disabled
      system.adapter.plex.2                   : plex                  : ioBroker                                 - disabled
      system.adapter.pushover.0               : pushover              : ioBroker                                 - disabled
      system.adapter.pushover.1               : pushover              : ioBroker                                 - disabled
      system.adapter.pushover.2               : pushover              : ioBroker                                 - disabled
      system.adapter.radar2.0                 : radar2                : ioBroker                                 - disabled
      system.adapter.roomba.0                 : roomba                : ioBroker                                 - disabled
    + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1886, bind: 0.0.0.0
      system.adapter.signal-cmb.0             : signal-cmb            : ioBroker                                 - disabled
      system.adapter.smartgarden.0            : smartgarden           : ioBroker                                 -  enabled
      system.adapter.smartthings.0            : smartthings           : ioBroker                                 -  enabled
    + system.adapter.sonoff.0                 : sonoff                : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.synology.0               : synology              : ioBroker                                 -  enabled, port: 5000
    + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.1               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.2               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.terminal.0               : terminal              : ioBroker                                 - disabled, port: 8088, bind: 0.0.0.0, run as: admin
      system.adapter.text2command.0           : text2command          : ioBroker                                 - disabled
      system.adapter.time-switch.0            : time-switch           : ioBroker                                 - disabled
    + system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
      system.adapter.tr-064.1                 : tr-064                : ioBroker                                 - disabled
      system.adapter.tr-064.2                 : tr-064                : ioBroker                                 - disabled
      system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 - disabled
      system.adapter.tuya.0                   : tuya                  : ioBroker                                 - disabled
      system.adapter.vis-bars.0               : vis-bars              : ioBroker                                 -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker                                 -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBroker                                 -  enabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker                                 -  enabled
      system.adapter.vis-history.0            : vis-history           : ioBroker                                 -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 -  enabled
      system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : ioBroker                                 -  enabled
      system.adapter.vis-map.0                : vis-map               : ioBroker                                 -  enabled
      system.adapter.vis-material.0           : vis-material          : ioBroker                                 -  enabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker                                 -  enabled
      system.adapter.vis-plumb.0              : vis-plumb             : ioBroker                                 -  enabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker                                 -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 -  enabled
      system.adapter.vis-weather.0            : vis-weather           : ioBroker                                 -  enabled
      system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
      system.adapter.vw-connect.0             : vw-connect            : ioBroker                                 - disabled
      system.adapter.weatherunderground.0     : weatherunderground    : ioBroker                                 - disabled
      system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : ioBroker                                 - disabled
      system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : ioBroker                                 - disabled
      system.adapter.wifilight.0              : wifilight             : ioBroker                                 - disabled
      system.adapter.yahka.0                  : yahka                 : ioBroker                                 -  enabled
      system.adapter.yr.0                     : yr                    : ioBroker                                 -  enabled
      system.adapter.zigbee.0                 : zigbee                : ioBroker                                 -  enabled, port: /dev/ttyACM0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): beta
    Installed ioBroker-Instances
    Used repository: beta
    Adapter    "admin"        : 6.9.1    , installed 6.2.23 [Updatable]
    Adapter    "apple-find-me": 0.0.15   , installed 0.0.15
    Adapter    "backitup"     : 2.7.0    , installed 2.7.0
    Adapter    "bshb"         : 0.2.4    , installed 0.2.1  [Updatable]
    Adapter    "cameras"      : 1.2.2    , installed 1.2.2
    Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
    Adapter    "device-reminder": 2.0.1  , installed 2.0.1
    Adapter    "discovery"    : 3.2.0    , installed 3.2.0
    Adapter    "ds18b20"      : 2.0.4    , installed 1.6.1  [Updatable]
    Adapter    "echarts"      : 1.5.1    , installed 1.5.1
    Adapter    "firetv"       : 1.0.0    , installed 1.0.0
    Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
    Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
    Adapter    "history"      : 2.2.6    , installed 2.2.6
    Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "innogy-smarthome": 1.2.6 , installed 1.2.6
    Adapter    "jarvis"       : 3.1.8    , installed 3.0.15 [Updatable]
    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
    Controller "js-controller": 5.0.12   , installed 4.0.24 [Updatable]
    Adapter    "mclighting"   : 0.1.2    , installed 0.1.2
    Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "node-red"     : 4.0.3    , installed 4.0.3
    Adapter    "owntracks"    : 1.0.5    , installed 1.0.5
    Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
    Adapter    "places"       : 1.1.2    , installed 1.1.2
    Adapter    "plex"         : 1.0.4    , installed 0.9.1  [Updatable]
    Adapter    "pushover"     : 3.0.4    , installed 3.0.4
    Adapter    "radar2"       : 2.0.7    , installed 2.0.7
    Adapter    "roomba"       : 1.2.1    , installed 1.1.4  [Updatable]
    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
    Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
    Adapter    "smartgarden"  : 2.0.0    , installed 2.0.0
    Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
    Adapter    "socketio"     : 6.5.2    , installed 6.5.2
    Adapter    "sonoff"       : 2.5.7    , installed 2.5.7
    Adapter    "synology"     : 2.1.13   , installed 2.1.13
    Adapter    "telegram"     : 1.16.0   , installed 1.16.0
    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
    Adapter    "text2command" : 3.0.2    , installed 3.0.2
    Adapter    "time-switch"  : 2.2.2    , installed 2.2.2
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "tuya"         : 3.14.2   , installed 3.14.2
    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
    Adapter    "vis-material" : 0.1.3    , installed 0.1.3
    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
    Adapter    "vw-connect"   : 0.0.72   , installed 0.0.72
    Adapter    "weatherunderground": 3.4.3, installed 3.4.3
    Adapter    "web"          : 6.1.0    , installed 6.1.0
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
    Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
    Adapter    "ws"           : 2.5.3    , installed 2.5.3
    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
    Adapter    "yr"           : 5.3.0    , installed 5.3.0
    Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
    Objects and States
    Objects: 	18899
    States: 	16649
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_14.x bullseye InRelease
    Reading package lists...
    Pending Updates: 149
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12799      531/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:38129         0.0.0.0:*               LISTEN      1001       98225      27630/io.yahka.0
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       95956      26829/iobroker.js-c
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       95963      26829/iobroker.js-c
    tcp        0      0 127.0.0.1:46417         0.0.0.0:*               LISTEN      1001       98230      27630/io.yahka.0
    tcp        0      0 127.0.0.1:37239         0.0.0.0:*               LISTEN      1001       99034      27630/io.yahka.0
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       97100      26969/io.sonoff.0
    tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       98041      27431/io.shelly.0
    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       99599      27443/io.owntracks.
    tcp6       0      0 :::42227                :::*                    LISTEN      1001       98883      27630/io.yahka.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          12801      531/sshd: /usr/sbin
    tcp6       0      0 :::41431                :::*                    LISTEN      1001       98881      27630/io.yahka.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       95010      26847/io.admin.0
    tcp6       0      0 :::35131                :::*                    LISTEN      1001       98879      27630/io.yahka.0
    udp        0      0 192.168.1.86:5353       0.0.0.0:*                           1001       100460     27257/io.tr-064.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        10496      346/avahi-daemon: r
    udp        0      0 0.0.0.0:52729           0.0.0.0:*                           108        10498      346/avahi-daemon: r
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14105      714/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        10497      346/avahi-daemon: r
    udp6       0      0 :::50745                :::*                                108        10499      346/avahi-daemon: r
    2023-08-29 14:55:18.766  - info: host.ioBroker iobroker npm-rebuild:   SOLINK_MODULE(target) Release/obj.target/sharp-linux-armv7.node
    2023-08-29 14:55:19.075  - info: echarts.0 (27690) starting. Version 1.5.1 in /opt/iobroker/node_modules/iobroker.echarts, node: v14.20.0, js-controller: 4.0.24
    2023-08-29 14:55:19.212  - info: host.ioBroker iobroker npm-rebuild:   COPY Release/sharp-linux-armv7.node
    2023-08-29 14:55:19.246  - info: host.ioBroker iobroker npm-rebuild: make: Leaving directory '/opt/iobroker/node_modules/sharp/build'
    2023-08-29 14:55:20.511  - info: host.ioBroker iobroker npm-rebuild: > @serialport/bindings-cpp@11.0.3 install /opt/iobroker/node_modules/@serialport/bindings-cpp> node-gyp-build
    2023-08-29 14:55:20.808  - info: host.ioBroker instance system.adapter.vis-inventwo.0 started with pid 27772
    2023-08-29 14:55:23.528  - info: host.ioBroker iobroker npm-rebuild: > iobroker.js-controller@4.0.24 preinstall /opt/iobroker/node_modules/iobroker.js-controller> node lib/preinstallCheck.js
    2023-08-29 14:55:24.459  - info: host.ioBroker iobroker npm-rebuild: NPM version: 6.14.17> iobroker.js-controller@4.0.24 install /opt/iobroker/node_modules/iobroker.js-controller> node iobroker.js setup first
    2023-08-29 14:55:24.999  - info: host.ioBroker instance system.adapter.smartthings.0 started with pid 27807
    2023-08-29 14:55:25.729  - info: vis-inventwo.0 (27772) starting. Version 3.3.3 in /opt/iobroker/node_modules/iobroker.vis-inventwo, node: v14.20.0, js-controller: 4.0.24
    2023-08-29 14:55:30.737  - info: smartthings.0 (27807) starting. Version 0.0.4 in /opt/iobroker/node_modules/iobroker.smartthings, node: v14.20.0, js-controller: 4.0.24
    2023-08-29 14:55:31.246  - info: smartthings.0 (27807) 0 devices detected
    2023-08-29 14:55:36.111  - info: daswetter.1 (27528) still wrong data structure from server received! repaired...
    2023-08-29 14:55:42.228  - info: daswetter.1 (27528) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2023-08-29 14:55:42.760  - info: daswetter.1 (27528) cleaned everything up...
    2023-08-29 14:55:42.864  - info: host.ioBroker instance system.adapter.daswetter.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-08-29 14:55:44.286  - info: host.ioBroker iobroker npm-rebuild: Successfully migrated 18902 objects to Redis Sets
    2023-08-29 14:55:44.309  - info: host.ioBroker iobroker npm-rebuild: Existing earlier generated certificate is invalid (too old, validity longer then 345 days or keylength too short). Generating new Certificate!
    2023-08-29 14:55:46.702  - info: host.ioBroker iobroker npm-rebuild: object system.certificates updated
    2023-08-29 14:55:47.576  - info: host.ioBroker iobroker npm-rebuild: object _design/system updated
    2023-08-29 14:55:49.018  - info: host.ioBroker iobroker npm-rebuild: {  "defaultPrivate": "-----BEGIN RSA PRIVATE KEY-----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\r\n0fWjmAXokGV42KJyMjRwTDxSI4X8Uo63zGmtoZ7swMsD4YhycEM=\r\n-----END RSA PRIVATE KEY-----\r\n",  "defaultPublic": "-----BEGIN CERTIFICATE-----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\r\nQ3EPwH537zTdmgUA+ZAWiapFngRvgSvNF5dJuxup9OC5NQ==\r\n-----END CERTIFICATE-----\r\n"}
    2023-08-29 14:55:49.023  - info: host.ioBroker iobroker npm-rebuild: Update certificate defaultPrivate
    2023-08-29 14:55:49.090  - info: host.ioBroker iobroker npm-rebuild: The object "system.certificates" was updated successfully.Update certificate defaultPublic
    2023-08-29 14:55:49.212  - info: host.ioBroker iobroker npm-rebuild: The object "system.certificates" was updated successfully.
    2023-08-29 14:55:51.751  - info: host.ioBroker iobroker npm-rebuild: > esbuild@0.11.23 postinstall /opt/iobroker/node_modules/esbuild> node install.js
    Thomas BraunT ? 2 Antworten Letzte Antwort
    • T Tom2323
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Docker          : false
      Release:	11
      Codename:	bullseye
      VERSION_ID="11"
      ID=raspbian
      ID_LIKE=debian
      CPU threads: 4
      Raspberry only:
      throttled=0x50000
      temp=40.9'C
      volt=0.8500V
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server: 	false
      Desktop:
      Terminal: 	tty
      *** MEMORY ***
      Swap:            99M        2.0M         97M
               3838 M total memory
                730 M used memory
                490 M active memory
                716 M free memory
                144 M buffer memory
               2246 M swap cache
                 99 M total swap
                  2 M used swap
                 97 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      1.6G	/var/
      1005M	/var/log
      414M	/var/cache
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin: 		6.2.23
      javascript: 	7.1.4
      Adapter State
      + instance is alive
      Objects and States
      Objects: 	18899
      States: 	16649
      #558
      @tom2323
      nodejs@14 ist zu alt, installier da nodejs@18.
        Tom2323
        #559
        @thomas-braun said in js-controller 5.0.x jetzt in der BETA:
        Das hat geholfen.
        Danke an alle!
        • T Tom2323
          Skript v.2023-04-16
          *** BASE SYSTEM ***
          Docker          : false
          Release:	11
          Codename:	bullseye
          VERSION_ID="11"
          ID=raspbian
          ID_LIKE=debian
          CPU threads: 4
          Raspberry only:
          throttled=0x50000
          temp=40.9'C
          volt=0.8500V
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          pi
          /home/pi
          X-Server: 	false
          Desktop:
          Terminal: 	tty
          *** MEMORY ***
          Swap:            99M        2.0M         97M
                   3838 M total memory
                    730 M used memory
                    490 M active memory
                    716 M free memory
                    144 M buffer memory
                   2246 M swap cache
                     99 M total swap
                      2 M used swap
                     97 M free swap
          Raspberry only:
          oom events: 0
          *** FILESYSTEM ***
          /var:
          1.6G	/var/
          1005M	/var/log
          414M	/var/cache
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin: 		6.2.23
          javascript: 	7.1.4
          Adapter State
          + instance is alive
          Objects and States
          Objects: 	18899
          States: 	16649
          #560
          Raspberry only:
          Moin,
          Hat nichts mit Deinem Problem zu tun, ist mir nur so aufgefallen.
          Deine Kiste trödelt :)
          Raspberry only:
          throttled=0x50000
          temp=40.9'C
          volt=0.8500V
          Die Temperatur ist wohl ok, aber die Spannung ist wohl etwas zu wenig, falsches Netzteil?
          Bernd
          • H Offline
            Heinz2100
            #561
            Mein Homekit-Controller streikt mit beiliegender Meldung. Es kommt immer zum Bootloop. Jemand eine Idee?
            Schon einmal tausend Dank
            Node JS v18.17.1
            Controller 5.0.12
            Error: undefined is not a valid state value at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/maybeCallback.js:35:17) at HomekitController._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5439:49) at HomekitController.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5400:21) at /opt/iobroker/node_modules/iobroker.homekit-controller/build/main.js:745:26 at Array.forEach (<anonymous>) at HomekitController.setCharacteristicValues (/opt/iobroker/node_modules/iobroker.homekit-controller/build/main.js:734:32) at Timeout.<anonymous> (/opt/iobroker/node_modules/iobroker.homekit-controller/build/main.js:702:30) at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
            • H Heinz2100
              Node JS v18.17.1
              Controller 5.0.12
              foxriver76F Offline
              foxriver76F Offline
              foxriver76
              #562
              @heinz2100 bitte issue im repo des adapters melden
              Videotutorials & mehr
              • foxriver76F foxriver76
                JB_SullivanJ Offline
                JB_Sullivan
                schrieb am zuletzt editiert von JB_Sullivan
                #563
                Guten MOrgen,
                kann mir jemand einen Hinweis geben, in welcher Richtung ich ggf. suchen muss.
                Was bedeutet "Pattern"? Der Host Controller stürzt ab, sobald diese Webseite mit einem iframe und der darin enthaltenen Verknüpfung zu Grafana aufgerufen wird.
                Der Punkt ist, das ich genau solche Verknüpfungen dutzendfach verwende, der Absturz aber nur bei diesem einem Grafana Trend Diagramm passiert.
                Node: 18.17.0
                NPM: 9.6.7
                js-controller: 5.0.12
                host.GLT
                2023-09-07 07:47:30.274	info	Restart adapter system.adapter.web.0 because enabled
                host.GLT
                2023-09-07 07:47:30.274	error	instance system.adapter.web.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                host.GLT
                2023-09-07 07:47:30.274	error	Caught by controller[0]: at parseType (C:\ioBroker\GLT\node_modules\redis-parser\lib\parser.js:302:14)
                host.GLT
                2023-09-07 07:47:30.273	error	Caught by controller[0]: at parseError (C:\ioBroker\GLT\node_modules\redis-parser\lib\parser.js:179:12)
                host.GLT
                2023-09-07 07:47:30.273	error	Caught by controller[0]: ?orgId=1&refresh=10s&from=now-12h&to=now&kiosk" is not a valid ID pattern
                host.GLT
                2023-09-07 07:47:30.273	error	Caught by controller[0]: ReplyError: Error The pattern "http://10.122.60.87:3000/d/3oeu6gyVK/bmw-jahresfahrleistung
                host.GLT
                2023-09-07 07:47:30.272	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                sigi234S 2 Antworten Letzte Antwort
                • arteckA Offline
                  arteckA Offline
                  arteck
                  #564
                  @jb_sullivan sagte in js-controller 5.0.x jetzt in der BETA:
                  http://10.122.60.87:3000/d/3oeu6gyVK/bmw-jahresfahrleistung?orgId=1&refresh=10s&from=now-12h&to=now&kiosk
                  rufmal auf.. geht das ?
                  • JB_SullivanJ JB_Sullivan
                    Guten MOrgen,
                    Node: 18.17.0
                    NPM: 9.6.7
                    host.GLT
                    host.GLT
                    host.GLT
                    host.GLT
                    host.GLT
                    host.GLT
                    host.GLT
                    sigi234S Online
                    sigi234S Online
                    #565
                    @jb_sullivan
                    Das habe ich auch:
                    web.0
                    2023-08-27 12:02:52.754    error    Error The pattern "Last Check <p>27.08.2023 - 12:02:52" is not a valid ID pattern
                      Guten MOrgen,
                      Node: 18.17.0
                      NPM: 9.6.7
                      host.GLT
                      host.GLT
                      host.GLT
                      host.GLT
                      host.GLT
                      host.GLT
                      host.GLT
                      sigi234S Online
                      sigi234S Online
                      #566
                      Bei mir ist es nur bei einer bestimmten View.
                      JB_SullivanJ 2 Antworten Letzte Antwort
                      • sigi234S sigi234
                        JB_Sullivan
                        #567
                        @sigi234 Ist bei mir auch - nur eine VIEW die dieses iframe mit der URL enthält. Allerdings wird bei mir die URL "zusammen gebaut", da ich pullDown Menüs verwende. Das ist aber in div. anderen VIEW`s genauso aufgebaut und da passiert es nicht.
                        • sigi234S sigi234
                          JB_Sullivan
                          #568
                          @sigi234
                          Möglicherweise habe ich den Fehler gefunden - Hast du in deinen Grafana Diagrammen auch oben rechts ein blaues "Time Info" Icon?
                          Ich hatte das nur in diesen Diagrammen. Habe das jetzt mal entfernt und aktuell stürzt das View nicht mehr ab.
                            @sigi234
                            sigi234S Online
                            sigi234S Online
                            #569
                            Hast du in deinen Grafana Diagrammen auch oben recht ein blaues "Time Info" Icon?
                            Bei mir kommt der Fehler nicht von Grafana, sondern via bindings (denke ich)
                            • JB_SullivanJ Offline
                              JB_Sullivan
                              #570
                              Mist - zu früh gefreut - trotz deaktivierter Time Icons ist der host Controller beim 10. oder 20. hin und her schalten zwischen den Diagrammen wieder abgestürzt.
                              Fehlermeldung war die selbe. Ich sehe gerade das dieses mal noch ein Sack voll mehr Meldungen auch vom Web Adapter gekommen sind.
                              web.0
                              2023-09-07 09:50:03.752	warn	Timeout by termination of web-extensions!
                              web.0
                              2023-09-07 09:50:03.226	error	Error The pattern "http://10.122.60.87:3000/d/3oeu6gyVK/bmw-jahresfahrleistung?orgId=1&refresh=10s&from=now-12h&to=now&kiosk" is not a valid ID pattern
                              web.0
                              2023-09-07 09:50:03.226	error	ReplyError: Error The pattern "http://10.122.60.87:3000/d/3oeu6gyVK/bmw-jahresfahrleistung?orgId=1&refresh=10s&from=now-12h&to=now&kiosk" is not a valid ID pattern at parseError (C:\ioBroker\GLT\node_modules\redis-parser\lib\parser.js:179:12) at parseType (C:\ioBroker\GLT\node_modules\redis-parser\lib\parser.js:302:14)
                              web.0
                              2023-09-07 09:50:03.223	error	unhandled promise rejection: Error The pattern "http://10.122.60.87:3000/d/3oeu6gyVK/bmw-jahresfahrleistung?orgId=1&refresh=10s&from=now-12h&to=now&kiosk" is not a valid ID pattern
                              web.0
                              2023-09-07 09:50:03.221	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              host.GLT-Server
                              2023-09-07 09:50:03.207	warn	States 127.0.0.1:50169 Error from InMemDB: Error: The pattern "http://10.122.60.87:3000/d/3oeu6gyVK/bmw-jahresfahrleistung?orgId=1&refresh=10s&from=now-12h&to=now&kiosk" is not a valid ID pattern at Object.pattern2RegEx (C:\ioBroker\GLT\node_modules\@iobroker\js-controller-common\src\lib\common\tools.ts:2497:15) at StatesInMemoryServer.handleSubscribe (C:\ioBroker\GLT\node_modules\@iobroker\db-base\src\lib\inMemFileDB.ts:324:59) at StatesInMemoryServer._subscribeForClient (C:\ioBroker\GLT\node_modules\@iobroker\db-states-file\src\lib\states\statesInMemFileDB.js:258:14) at RedisHandler.<anonymous> (C:\ioBroker\GLT\node_modules\@iobroker\db-states-jsonl\src\lib\states\statesInMemServerRedis.js:395:26) at RedisHandler.emit (node:events:514:28) at RedisHandler.emit (node:domain:489:12) at Immediate._onImmediate (C:\ioBroker\GLT\node_modules\@iobroker\db-base\src\lib\redisHandler.ts:209:37) at processImmediate (node:internal/timers:476:21)
                              javascript.0
                              2023-09-07 09:50:02.635	info	script.js.Aktiv.Grafana_Enyaq: http://10.122.60.87:3000/d/3oeu6gyVK/bmw-jahresfahrleistung?orgId=1&refresh=10s&from=now-12h&to=now&kiosk
                              • F Offline
                                frickeldave
                                #571
                                Hi, ich benutze iobroker ausschliesslich im docker container. Ich habe aktuell das Image 8.1.0 im Einsatz, was aber noch mit js-controller 4 daher kommt. Da ich auch vis-2 nutze, stehe cih nun vor dem Problem, dass ich nicht mehr vis-2 updaten kann, da js-controller 5 Vorasusetzung geworden ist. Gibt es schon einen docker container mit js-controller 5?
                                • F frickeldave
                                  haselchenH Offline
                                  haselchenH Offline
                                  haselchen
                                  #572
                                  @frickeldave
                                  Ähm, natürlich kannst Du im Terminal vom Container den JS Controller Updaten!?
                                  Einfach den Anweisungen hier folgen.
                                  https://forum.iobroker.net/topic/68290/js-controller-5-0-x-jetzt-für-alle-user-im-stable
                                  • haselchenH haselchen
                                    @frickeldave
                                    frickeldave
                                    #573
                                    @haselchen Nein geht eben nicht, wie in der Anleitung weil kein daemon Prozess da ist den iobroker erwartet. Also es geht bestimmt irgendwie, aber dafür ist erstmal ein bisschen Tüftelei notwendig. Wenn keiner hier schon einen Weg ausgetüftelt hat, würde ich eher warten, bis buanet ne neue Image Version zur Verfügung stellt.
                                    • F frickeldave
                                      Marc BergM Offline
                                      Marc BergM Offline
                                      Marc Berg
                                      #574
                                      @frickeldave sagte in js-controller 5.0.x jetzt in der BETA:
                                      Ohne viel tüfteln (innerhalb des Containers):
                                      m on
                                      iob upgrade self
                                      m off
                                      https://docs.buanet.de/iobroker-docker-image/docs/#use-maintenance-script
                                        sunny9999
                                        #575
                                        so update auf js-controller Version 5.0.12 vollzogen, alles soweit glatt....aber neben dem bereits bekannten Linux-Control Problem starten bei mir folgende Instanzen nicht :
                                        email
                                        folgende Fehler im Log :
                                        host.IOBROKER-MASTER
                                        2023-09-15 12:25:01.226	info	Rebuild for adapter system.adapter.email.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                                        2023-09-15 12:25:01.226	error	instance system.adapter.email.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                        2023-09-15 12:25:01.226	error	Caught by controller[0]: Node.js v18.16.1
                                        2023-09-15 12:25:01.226	error	Caught by controller[0]: }
                                        2023-09-15 12:25:01.226	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.email/main.js' ]
                                        2023-09-15 12:25:01.226	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                                        2023-09-15 12:25:01.226	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) {
                                        2023-09-15 12:25:01.226	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:960:12)
                                        2023-09-15 12:25:01.226	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
                                        2023-09-15 12:25:01.226	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
                                        2023-09-15 12:25:01.226	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
                                        2023-09-15 12:25:01.226	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.email/main.js:13:15)
                                        2023-09-15 12:25:01.226	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:110:18)
                                        2023-09-15 12:25:01.226	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
                                        2023-09-15 12:25:01.226	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:922:27)
                                        2023-09-15 12:25:01.226	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
                                        2023-09-15 12:25:01.226	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.email/main.js
                                        2023-09-15 12:25:01.226	error	Caught by controller[0]: Require stack:
                                        2023-09-15 12:25:01.226	error	Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js'
                                        2023-09-15 12:25:01.226	error	Caught by controller[0]: ^
                                        2023-09-15 12:25:01.226	error	Caught by controller[0]: throw err;
                                        2023-09-15 12:25:01.225	error	Caught by controller[0]: node:internal/modules/cjs/loader:1080
                                        sowie samsung_tizen
                                        2023-09-15 12:27:21.913	info	Rebuild for adapter system.adapter.samsung_tizen.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                                        2023-09-15 12:27:21.913	error	instance system.adapter.samsung_tizen.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                        2023-09-15 12:27:21.913	error	Caught by controller[0]: Node.js v18.16.1
                                        2023-09-15 12:27:21.913	error	Caught by controller[0]: }
                                        2023-09-15 12:27:21.913	error	Caught by controller[0]: ]
                                        2023-09-15 12:27:21.913	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.samsung_tizen/main.js'
                                        2023-09-15 12:27:21.913	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.samsung_tizen/lib/utils.js',
                                        2023-09-15 12:27:21.913	error	Caught by controller[0]: requireStack: [
                                        2023-09-15 12:27:21.913	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                                        2023-09-15 12:27:21.913	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19) {
                                        2023-09-15 12:27:21.913	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:960:12)
                                        2023-09-15 12:27:21.913	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
                                        2023-09-15 12:27:21.913	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
                                        2023-09-15 12:27:21.913	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
                                        2023-09-15 12:27:21.913	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.samsung_tizen/lib/utils.js:46:25)
                                        2023-09-15 12:27:21.913	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:110:18)
                                        2023-09-15 12:27:21.913	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:922:27)
                                        2023-09-15 12:27:21.913	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
                                        2023-09-15 12:27:21.913	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.samsung_tizen/main.js
                                        2023-09-15 12:27:21.913	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.samsung_tizen/lib/utils.js
                                        2023-09-15 12:27:21.913	error	Caught by controller[0]: Require stack:
                                        2023-09-15 12:27:21.913	error	Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js'
                                        2023-09-15 12:27:21.913	error	Caught by controller[0]: ^
                                        2023-09-15 12:27:21.913	error	Caught by controller[0]: throw err;
                                        2023-09-15 12:27:21.912	error	Caught by controller[0]: node:internal/modules/cjs/loader:1080
                                        Jemand ne Idee ?
                                        Sunny
                                        DJMarc75D OmnedonO 2 Antworten Letzte Antwort
                                        • S sunny9999
                                          email
                                          sowie samsung_tizen
                                          Jemand ne Idee ?
                                          Sunny
                                          DJMarc75D Offline
                                          DJMarc75D Offline
                                          DJMarc75
                                          #576
                                          @sunny9999 sagte in js-controller 5.0.x jetzt in der BETA:
                                          Welches Problem ist da bekannt ? Also bei mir läuft der Adapter.
                                          Lehrling seit 1975 !!!
