  4. IoBroker hängt sich komplett auf
    5.2k
54 Beiträge 9 Kommentatoren 6.3k Aufrufe 7 Beobachtet
  • J joeysch
    Mehr kommt nicht.
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Architecture    : x86_64
    Docker          : false
    Virtualization  : lxc
    Distributor ID: Debian
    Description:    Debian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     15:18:34 up  1:06,  1 user,  load average: 1.18, 0.93, 1.09
    CPU threads: 4
    *** Time and Time Zones ***
                   Local time: Mon 2023-09-04 15:18:34 UTC
               Universal time: Mon 2023-09-04 15:18:34 UTC
                     RTC time: n/a
                    Time zone: Etc/UTC (UTC, +0000)
                  NTP service: inactive
              RTC in local TZ: no
    *** User and Groups ***
    root
    /root
    root
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:            4.1G        1.7G        1.7G        0.0K        651M        2.4G
    Swap:           4.1G         60M        4.0G
    Total:          8.2G        1.8G        5.7G
             4096 M total memory
             1741 M used memory
              380 M active memory
             1813 M inactive memory
             1702 M free memory
                0 M buffer memory
              651 M swap cache
             4096 M total swap
               60 M used swap
             4035 M free swap
    *** FILESYSTEM ***
    Filesystem                       Type      Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--100--disk--0 ext4       20G  4.2G   15G  23% /
    none                             tmpfs     492K  4.0K  488K   1% /dev
    udev                             devtmpfs  7.8G     0  7.8G   0% /dev/tty
    tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
    tmpfs                            tmpfs     3.2G   92K  3.2G   1% /run
    tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
    dmesg: read kernel buffer failed: Operation not permitted
    TARGET SOURCE                           FSTYPE OPTIONS
    /      /dev/mapper/pve-vm--100--disk--0 ext4   rw,relatime,stripe=16
    /var:
    414M    /var/
    262M    /var/cache
    257M    /var/cache/apt
    190M    /var/cache/apt/archives
    135M    /var/lib
    Archived and active journals take up 16.0M in the file system.
    /opt/iobroker/backups:
    32M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    382M    /opt/iobroker/iobroker-data/
    295M    /opt/iobroker/iobroker-data/files
    52M     /opt/iobroker/iobroker-data/files/javascript.admin
    45M     /opt/iobroker/iobroker-data/files/devices.admin/static
    66M     /opt/iobroker/iobroker-data/objects.jsonl
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    21M     /opt/iobroker/iobroker-data/states.jsonl
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.e564fb87.js.map
    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.17.1
    /usr/bin/node           v18.17.1
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    nodejs:
      Installed: 18.17.1-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
     *** 18.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://security.debian.org bullseye-security/main amd64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://ftp.debian.org/debian bullseye/main amd64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    GlasfaserG Offline
    GlasfaserG Offline
    @joeysch
    Zeige mal die Ausgabe von
    iobroker status
    • J joeysch
      Mehr kommt nicht.
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Docker          : false
      Release:        11
      Codename:       bullseye
      VERSION_ID="11"
      ID=debian
      CPU threads: 4
                       RTC time: n/a
                RTC in local TZ: no
      root
      /root
      root
      X-Server:       false
      Desktop:
      Terminal:
      *** MEMORY ***
      Swap:           4.1G         60M        4.0G
               4096 M total memory
               1741 M used memory
                380 M active memory
               1702 M free memory
                  0 M buffer memory
                651 M swap cache
               4096 M total swap
                 60 M used swap
               4035 M free swap
      *** FILESYSTEM ***
      /var:
      414M    /var/
      262M    /var/cache
      257M    /var/cache/apt
      135M    /var/lib
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      nodejs:
        Version table:
      ioBroker Status
      @joeysch sagte in IoBroker hängt sich komplett auf:
      Mehr kommt nicht.
      Moin,
      ich würde rein prophylaktisch mal folgendes machen
      # iob stop
      # iob fix
      # iob start
      Wie führst Du denn den Befehl iob diag aus, als welcher User?
      Bernd
      J Thomas BraunT 2 Antworten Letzte Antwort
        @joeysch
        Dann isses kaputt.
        Installier es nochmal, diesmal richtig. Siehe entsprechende Anleitung für Proxmox/LXC.
        joeysch
        Proxmox konnte das nicht darstellen
        Skript v.2023-04-16
        *** BASE SYSTEM ***
        Docker          : false
        Release:        11
        Codename:       bullseye
        VERSION_ID="11"
        ID=debian
         17:30:42 up 8 min,  1 user,  load average: 0.08, 0.84, 1.09
        CPU threads: 4
                       Local time: Mon 2023-09-04 17:30:42 CEST
                   Universal time: Mon 2023-09-04 15:30:42 UTC
                         RTC time: n/a
                  RTC in local TZ: no
        root
        /root
        root
        X-Server:       false
        Desktop:
        Terminal:
        *** MEMORY ***
        Mem:            4.1G        2.5G        995M        0.0K        576M        1.6G
        Swap:           4.1G          0B        4.1G
        Total:          8.2G        2.5G        5.1G
                 4096 M total memory
                 2524 M used memory
                  240 M active memory
                 2690 M inactive memory
                  995 M free memory
                    0 M buffer memory
                  576 M swap cache
                 4096 M total swap
                    0 M used swap
                 4096 M free swap
        *** FILESYSTEM ***
        tmpfs                            tmpfs     3.2G   96K  3.2G   1% /run
        /var:
        414M    /var/
        262M    /var/cache
        257M    /var/cache/apt
        135M    /var/lib
        377M    /opt/iobroker/iobroker-data/
        58M     /opt/iobroker/iobroker-data/objects.jsonl
        25M     /opt/iobroker/iobroker-data/states.jsonl
        /usr/bin/npm            9.6.7
        /usr/bin/npx            9.6.7
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  4.0.24
        admin:          6.8.0
        javascript:     7.0.3
        Adapters from github:   4
        Adapter State
        + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: guido
        + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
        + system.adapter.chromecast.0             : chromecast            : iobroker                                 -  enabled
          system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
        + system.adapter.denon.0                  : denon                 : iobroker                                 -  enabled
          system.adapter.devices.0                : devices               : iobroker                                 - disabled
        + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
        + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
        + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
        + system.adapter.heos.0                   : heos                  : iobroker                                 -  enabled
        + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled
          system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
        + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
        + system.adapter.influxdb.1               : influxdb              : iobroker                                 -  enabled, port: 8086
        + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
        + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
        + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
          system.adapter.material.0               : material              : iobroker                                 - disabled
        + system.adapter.melcloud.0               : melcloud              : iobroker                                 -  enabled
        + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 8885, bind: 192.168.0.17
        + system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
        + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
        + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
        + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
        + system.adapter.time-switch.0            : time-switch           : iobroker                                 -  enabled
        + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
        + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
          system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker                                 - disabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
          system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
          system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
          system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
        + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: guido
        + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 6.8.0    , installed 6.8.0
        Adapter    "backitup"     : 2.6.23   , installed 2.6.23
        Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
        Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
        Adapter    "denon"        : 1.15.4   , installed 1.15.3 [Updatable]
        Adapter    "devices"      : 1.1.5    , installed 1.1.5
        Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
        Adapter    "heos"         : 2.1.0    , installed 2.1.0
        Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
        Adapter    "ical"         : 1.13.3   , installed 1.13.3
        Adapter    "iot"          : 1.14.5   , installed 1.14.5
        Adapter    "javascript"   : 7.0.3    , installed 7.0.3
        Adapter    "lgtv"         : 1.1.10   , installed 1.1.10
        Adapter    "material"     : 1.3.1    , installed 1.3.1
        Adapter    "melcloud"     : 1.3.5    , installed 1.3.5
        Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
        Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
        Adapter    "node-red"     : 4.0.3    , installed 4.0.3
        Adapter    "socketio"     : 6.5.2    , installed 6.5.2
        Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
        Adapter    "trashschedule": 2.2.0    , installed 2.2.0
        Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
        Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
        Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
        Adapter    "web"          : 6.1.0    , installed 6.1.0
        Adapter    "ws"           : 2.5.3    , installed 2.5.3
        Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
        Objects and States
        Objects:        69004
        States:         70882
        Hit:1 http://security.debian.org bullseye-security InRelease
        Hit:2 http://ftp.debian.org/debian bullseye InRelease
        Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
        Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       658599025  127/iobroker.js-con
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       658595798  127/iobroker.js-con
        tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      104        658596858  115/systemd-resolve
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          658596710  1/init
        tcp        0      0 192.168.0.17:8885       0.0.0.0:*               LISTEN      1000       658602110  483/io.mqtt.0
        tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      104        658596864  115/systemd-resolve
        tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1000       658600996  435/node-red
        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          658597149  300/master
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       658599887  499/io.sonoff.0
        tcp6       0      0 :::5355                 :::*                    LISTEN      104        658596861  115/systemd-resolve
        tcp6       0      0 :::111                  :::*                    LISTEN      0          658596712  1/init
        tcp6       0      0 :::8081                 :::*                    LISTEN      1000       658600065  311/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1000       658609468  1157/io.web.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          658595609  1/init
        tcp6       0      0 :::8087                 :::*                    LISTEN      1000       658605893  1052/io.simple-api.
        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          658597150  300/master
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       658598808  394/io.chromecast.0
        udp        0      0 0.0.0.0:5355            0.0.0.0:*                           104        658596857  115/systemd-resolve
        udp        0      0 127.0.0.53:53           0.0.0.0:*                           104        658596863  115/systemd-resolve
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          658596711  1/init
        udp        0      0 0.0.0.0:52532           0.0.0.0:*                           1000       658604456  644/io.heos.0
        udp6       0      0 :::5355                 :::*                                104        658596860  115/systemd-resolve
        udp6       0      0 :::111                  :::*                                0          658596713  1/init
        2023-09-04 15:25:46.002  - info: sourceanalytix.0 (1067) Initialization of sonoff.0.Waschmaschine.Wifi_RSSI successfully
        2023-09-04 15:25:46.002  - info: sourceanalytix.0 (1067) Initialising (553 of 556) "sonoff.0.Waschmaschine.Wifi_SSId"
        2023-09-04 15:25:46.127  - info: sourceanalytix.0 (1067) Initialization of sonoff.0.Waschmaschine.Wifi_SSId successfully
        2023-09-04 15:25:46.127  - info: sourceanalytix.0 (1067) Initialising (554 of 556) "sonoff.0.Waschmaschine.Wifi_Signal"
        2023-09-04 15:25:46.171  - error: sourceanalytix.0 (1067) Check settings for sonoff.0.Waschmaschine.Wifi_Signal ! Known valueAtDeviceReset : (null) > known cumulative value (-78752.64997722192) cannot proceed
        2023-09-04 15:25:46.171  - error: sourceanalytix.0 (1067) Troubleshoot Data sonoff.0.Waschmaschine.Wifi_Signal custom Data : {"_id":"sonoff.0.Waschmaschine.Wifi_Signal","common":{"type":"number","role":"value","read":true,"write":false,"name":"Waschmaschine Wifi  Signal","custom":{"sourceanalytix.0":{"enabled":true,"selectedPrice":"ElectricityDay","selectedUnit":"kW","costs":true,"consumption":true,"meter_values":false,"start_day":-78617.64726527748,"start_week":-68733.11133305542,"start_month":-75269.80241777757,"start_quarter":0,"start_year":0,"valueAtDeviceInit":null,"valueAtDeviceReset":null,"cumulativeValue":-78617.64726527748}}},"native":{},"type":"state","from":"system.adapter.sourceanalytix.0","user":"system.user.admin","ts":1693692012274,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
        2023-09-04 15:25:46.171  - error: sourceanalytix.0 (1067) Cannot handle calculations for sonoff.0.Waschmaschine.Wifi_Signal, check log messages and adjust settings!
        2023-09-04 15:25:46.171  - error: sourceanalytix.0 (1067) Initialization of sonoff.0.Waschmaschine.Wifi_Signal failed, check warn messages !
        2023-09-04 15:25:46.171  - info: sourceanalytix.0 (1067) Initialising (555 of 556) "sonoff.0.Waschmaschine.alive"
        2023-09-04 15:25:46.316  - info: sourceanalytix.0 (1067) Initialization of sonoff.0.Waschmaschine.alive successfully
        2023-09-04 15:25:46.316  - info: sourceanalytix.0 (1067) Initialising (556 of 556) "sonoff.0.info.connection"
        2023-09-04 15:25:46.482  - info: sourceanalytix.0 (1067) Initialization of sonoff.0.info.connection successfully
        2023-09-04 15:25:46.486  - warn: sourceanalytix.0 (1067) Cannot handle calculations for 13 of 556 enabled states, check error messages
        2023-09-04 15:25:46.486  - info: sourceanalytix.0 (1067) Successfully activated SourceAnalytix for 543 of 556 states, will do my Job until you stop me!
        2023-09-04 15:26:29.416  - warn: sonoff.0 (499) Client [pvinverter]  has invalid password(undefined) or username(undefined)
        2023-09-04 15:26:29.418  - warn: sonoff.0 (499) Client [smartmeter]  has invalid password(undefined) or username(undefined)
        2023-09-04 15:26:38.447  - warn: fullybrowser.0 (629) updateDeviceERROR 192.168.0.225
        2023-09-04 15:27:41.519  - warn: fullybrowser.0 (629) updateDeviceERROR 192.168.0.225
        2023-09-04 15:28:29.421  - warn: sonoff.0 (499) Client [pvinverter]  has invalid password(undefined) or username(undefined)
        2023-09-04 15:28:29.423  - warn: sonoff.0 (499) Client [smartmeter]  has invalid password(undefined) or username(undefined)
        2023-09-04 15:28:44.591  - warn: fullybrowser.0 (629) updateDeviceERROR 192.168.0.225
        2023-09-04 15:29:47.663  - warn: fullybrowser.0 (629) updateDeviceERROR 192.168.0.225
        2023-09-04 15:30:29.426  - warn: sonoff.0 (499) Client [pvinverter]  has invalid password(undefined) or username(undefined)
        2023-09-04 15:30:29.429  - warn: sonoff.0 (499) Client [smartmeter]  has invalid password(undefined) or username(undefined)
        2023-09-04 15:30:50.735  - warn: fullybrowser.0 (629) updateDeviceERROR 192.168.0.225
        iob diag has finished.
        Press any key for a summary
        J GlasfaserG 2 Antworten Letzte Antwort
        • J joeysch
          Skript v.2023-04-16
          *** BASE SYSTEM ***
          Docker          : false
          Release:        11
          Codename:       bullseye
          VERSION_ID="11"
          ID=debian
          CPU threads: 4
                           RTC time: n/a
                    RTC in local TZ: no
          root
          /root
          root
          X-Server:       false
          Desktop:
          Terminal:
          *** MEMORY ***
          Swap:           4.1G          0B        4.1G
                   4096 M total memory
                   2524 M used memory
                    240 M active memory
                    995 M free memory
                      0 M buffer memory
                    576 M swap cache
                   4096 M total swap
                      0 M used swap
                   4096 M free swap
          *** FILESYSTEM ***
          /var:
          414M    /var/
          262M    /var/cache
          257M    /var/cache/apt
          135M    /var/lib
          /usr/bin/npm            9.6.7
          /usr/bin/npx            9.6.7
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.8.0
          javascript:     7.0.3
          Adapter State
          + instance is alive
          Objects and States
          Objects:        69004
          States:         70882
          Pending Updates: 0
          joeysch
          Und das noch
          Copy text starting here:
                               v.2023-04-16
          Operatingsystem:        Debian GNU/Linux 11 (bullseye)
          Kernel:                 5.13.19-2-pve
          Installation:           lxc
          User-ID:                0
          X-Server:               false
          Pending OS-Updates:     0
          Pending iob updates:    1
          Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                                  /usr/bin/npm            9.6.7
                                  /usr/bin/npx            9.6.7
          Recommended versions are nodejs 18.x.y and npm 9.x.y
          MEMORY:
          Mem:            4.1G        2.6G        918M        0.0K        577M        1.5G
          Swap:           4.1G          0B        4.1G
          Total:          8.2G        2.6G        5.0G
          Active iob-Instances:   30
          ioBroker Core:          js-controller           4.0.24
                                  admin                   6.8.0
          Objects type: jsonl
          States  type: jsonl
          Objects:                69004
          States:                 70882
          Size of iob-Database:
            Mehr kommt nicht.
            Moin,
            # iob stop
            # iob fix
            # iob start
            Bernd
            joeysch
            @dp20eic
            Mehrfach gemacht, nichts gebracht.
              Mehr kommt nicht.
              Moin,
              # iob stop
              # iob fix
              # iob start
              Bernd
              @dp20eic sagte in IoBroker hängt sich komplett auf:
              Na als User Null aka root
              • J joeysch
                @dp20eic
                GlasfaserG Offline
                GlasfaserG Offline
                @joeysch
                In deinen Screenshot kommt der Port 3000
                Hast du Grafana als Dialog geöffnet , oder was ist auf diesem Port !?
                J HomoranH 2 Antworten Letzte Antwort
                • GlasfaserG Glasfaser
                  @joeysch
                  joeysch
                  @glasfaser
                  Grafana läuft zwar auf Port 3000 hat aber eine eigene IP 192.168.0.22
                  • J joeysch
                    @glasfaser
                    GlasfaserG Offline
                    GlasfaserG Offline
                    @joeysch
                    ich würde daraus schließen , das der Gui Fehler von da kommt
                      @joeysch
                      @glasfaser Das ist das Demo-Bild aus der Meldung, damit der User weiß was ihn erwartet
                        @joeysch
                        joeysch
                        @glasfaser
                        Die Meldung kommt erst nachdem der Bildschirm 10min so aussah
                        Der IoBroker lief jetzt am Stück über ein halbes Jahr ohne Probleme
                        DJMarc75D GlasfaserG 2 Antworten Letzte Antwort
                        • J joeysch
                          @glasfaser
                          DJMarc75D Offline
                          DJMarc75D Offline
                          DJMarc75
                          Na dann hast Du halt irgendwas am System geändert. Bitte Selbstkontrolle was Du gemacht hast.
                          Lehrling seit 1975 !!!
                          • DJMarc75D DJMarc75
                            joeysch
                            @djmarc75
                            Definitiv "Nein"
                            Bin zurzeit an meinem 3D Drucker am fummeln.
                            • J joeysch
                              @glasfaser
                              GlasfaserG Offline
                              GlasfaserG Offline
                              Nimm mal bitte einen Browser ,mit dem du noch nie ioBroker geöffnet hast !
                              Was ist dann !?
                                Was ist dann !?
                                joeysch
                                @glasfaser
                                Genau dasselbe!
                                • J joeysch
                                  @glasfaser
                                  Genau dasselbe!
                                  @glasfaser
                                  Genau dasselbe!
                                  und hast du mal gemacht was in der Meldung steht?
                                    @glasfaser
                                    Genau dasselbe!
                                    joeysch
                                    Was meinst du?
                                    • J joeysch
                                      Was meinst du?
                                      Was meinst du?
                                      genau das was ich schrieb.
                                      in der Meldung steht Schritt für Schritt was zu tun ist
                                      • J joeysch
                                        Skript v.2023-04-16
                                        *** BASE SYSTEM ***
                                        Docker          : false
                                        Release:        11
                                        Codename:       bullseye
                                        VERSION_ID="11"
                                        ID=debian
                                        CPU threads: 4
                                                         RTC time: n/a
                                                  RTC in local TZ: no
                                        root
                                        /root
                                        root
                                        X-Server:       false
                                        Desktop:
                                        Terminal:
                                        *** MEMORY ***
                                        Swap:           4.1G          0B        4.1G
                                                 4096 M total memory
                                                 2524 M used memory
                                                  240 M active memory
                                                  995 M free memory
                                                    0 M buffer memory
                                                  576 M swap cache
                                                 4096 M total swap
                                                    0 M used swap
                                                 4096 M free swap
                                        *** FILESYSTEM ***
                                        /var:
                                        414M    /var/
                                        262M    /var/cache
                                        257M    /var/cache/apt
                                        135M    /var/lib
                                        /usr/bin/npm            9.6.7
                                        /usr/bin/npx            9.6.7
                                        nodejs:
                                          Version table:
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        admin:          6.8.0
                                        javascript:     7.0.3
                                        Adapter State
                                        + instance is alive
                                        Objects and States
                                        Objects:        69004
                                        States:         70882
                                        Pending Updates: 0
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        • system.adapter.influxdb.0 : influxdb : iobroker - enabled, port: 8086
                                        • system.adapter.influxdb.1 : influxdb : iobroker - enabled, port: 8086
                                        Kann das sein das dein Arbeitsspeicher immer rauf und runtergeht , laut deinen Ausgaben .
                                        Wieviel Datenpunkte loggst du mit Influx !?
                                        EDIT :
                                        Objects and States
                                        Objects:        69004
                                        States:         70882
                                        das sind auch nicht wenige Objects / States als allgemeiner Zusatnd .
                                          EDIT :
                                          Objects and States
                                          Objects:        69004
                                          States:         70882
                                          joeysch
                                          @glasfaser
                                          ich habe ihn eben 2x erhöht.
                                          Das mit den Datenpunkten ist mir gerade beim überprüfen auch aufgefallen.
                                          2 Punkt fallen hier auf
                                          1x ich bekomme per MQTT Daten von Heishamon (Wärmepumpe rein).
                                          Neben den Normale die letzte Zeit auch einige Kryptische, die ich dann auch immer wieder lösche.
                                          Dann habe ich mir ein Skript geschrieben welches mir DP's für die Heizkurve der Wärmepumpe anlegt.
                                          Das sollten so was an die 25 sein, sind aber über 5000. Ich komme bei den Ojekte aber nicht mehr dran um die zu löschen.
                                          Hier scheint sich das System aufzuhängen.
                                          Kann man DP's über die Shell löschen?
