  4. IoBroker hängt sich komplett auf
    5.2k
54 Beiträge 9 Kommentatoren 6.3k Aufrufe 7 Beobachtet
    @joeysch
    iob diag
    sagt? Langfassung bitte.
    joeysch
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Architecture    : x86_64
    Docker          : false
    Virtualization  : lxc
    Distributor ID: Debian
    Description:    Debian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     15:09:01 up 57 min,  1 user,  load average: 0.81, 0.80, 1.24
    CPU threads: 4
    *** Time and Time Zones ***
                   Local time: Mon 2023-09-04 15:09:01 UTC
               Universal time: Mon 2023-09-04 15:09:01 UTC
                     RTC time: n/a
                    Time zone: Etc/UTC (UTC, +0000)
                  NTP service: inactive
              RTC in local TZ: no
    *** User and Groups ***
    root
    /root
    root
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:            4.1G        2.7G        739M        0.0K        647M        1.4G
    Swap:           4.1G         60M        4.0G
    Total:          8.2G        2.8G        4.8G
             4096 M total memory
             2710 M used memory
              274 M active memory
             2818 M inactive memory
              738 M free memory
                0 M buffer memory
              647 M swap cache
             4096 M total swap
               60 M used swap
             4035 M free swap
    *** FILESYSTEM ***
    Filesystem                       Type      Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--100--disk--0 ext4       20G  4.2G   15G  23% /
    none                             tmpfs     492K  4.0K  488K   1% /dev
    udev                             devtmpfs  7.8G     0  7.8G   0% /dev/tty
    tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
    tmpfs                            tmpfs     3.2G   92K  3.2G   1% /run
    tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
    dmesg: read kernel buffer failed: Operation not permitted
    TARGET SOURCE                           FSTYPE OPTIONS
    /      /dev/mapper/pve-vm--100--disk--0 ext4   rw,relatime,stripe=16
    /var:
    414M    /var/
    262M    /var/cache
    257M    /var/cache/apt
    190M    /var/cache/apt/archives
    135M    /var/lib
    Archived and active journals take up 16.0M in the file system.
    /opt/iobroker/backups:
    32M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    381M    /opt/iobroker/iobroker-data/
    295M    /opt/iobroker/iobroker-data/files
    52M     /opt/iobroker/iobroker-data/files/javascript.admin
    45M     /opt/iobroker/iobroker-data/files/devices.admin/static
    66M     /opt/iobroker/iobroker-data/objects.jsonl
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.e564fb87.js.map
    20M     /opt/iobroker/iobroker-data/states.jsonl
    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.17.1
    /usr/bin/node           v18.17.1
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    nodejs:
      Installed: 18.17.1-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
     *** 18.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://security.debian.org bullseye-security/main amd64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://ftp.debian.org/debian bullseye/main amd64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    • J joeysch
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Docker          : false
      Release:        11
      Codename:       bullseye
      VERSION_ID="11"
      ID=debian
      CPU threads: 4
                       RTC time: n/a
                RTC in local TZ: no
      root
      /root
      root
      X-Server:       false
      Desktop:
      Terminal:
      *** MEMORY ***
      Swap:           4.1G         60M        4.0G
               4096 M total memory
               2710 M used memory
                274 M active memory
                738 M free memory
                  0 M buffer memory
                647 M swap cache
               4096 M total swap
                 60 M used swap
               4035 M free swap
      *** FILESYSTEM ***
      /var:
      414M    /var/
      262M    /var/cache
      257M    /var/cache/apt
      135M    /var/lib
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      nodejs:
        Version table:
      ioBroker Status
      @joeysch
      Zeitzone setzen, nicht als root herumhampeln.
        @joeysch sagte in IoBroker hängt sich komplett auf:
        Was könnte das sein?
        Moin,
        ist es als Geheimsache erklärt, warum Du uns nicht sagst, worauf das läuft?
        • Hardware Defekt
        • Speichermangel
        Die Briefmarken sind auch nicht optimal, Text immer als Text in Code Tags </> hier posten.
        Bernd
        joeysch
        @dp20eic
        Läuft in lxc auf Proxmox
        Speicher hab ich gerade erhöht.
        • J joeysch
          @dp20eic
          @joeysch
          Neben den ersten Punkten:
          Vollständige Ausgabe posten
            @joeysch
            joeysch
            Was willst du mir damit sagen?
            • J joeysch
              @joeysch
              Das deine Zeitzone nicht gesetzt ist, das du auch in einem lxc nicht als root herumstolperst und das es nicht die vollständige Ausgabe von iob diag gewesen ist.
                @joeysch
                joeysch
                Mehr kommt nicht.
                Skript v.2023-04-16
                *** BASE SYSTEM ***
                Docker          : false
                Release:        11
                Codename:       bullseye
                VERSION_ID="11"
                ID=debian
                 15:18:34 up  1:06,  1 user,  load average: 1.18, 0.93, 1.09
                CPU threads: 4
                               Local time: Mon 2023-09-04 15:18:34 UTC
                           Universal time: Mon 2023-09-04 15:18:34 UTC
                                 RTC time: n/a
                          RTC in local TZ: no
                root
                /root
                root
                X-Server:       false
                Desktop:
                Terminal:
                *** MEMORY ***
                Mem:            4.1G        1.7G        1.7G        0.0K        651M        2.4G
                Swap:           4.1G         60M        4.0G
                Total:          8.2G        1.8G        5.7G
                         4096 M total memory
                         1741 M used memory
                          380 M active memory
                         1813 M inactive memory
                         1702 M free memory
                            0 M buffer memory
                          651 M swap cache
                         4096 M total swap
                           60 M used swap
                         4035 M free swap
                *** FILESYSTEM ***
                /var:
                414M    /var/
                262M    /var/cache
                257M    /var/cache/apt
                135M    /var/lib
                382M    /opt/iobroker/iobroker-data/
                21M     /opt/iobroker/iobroker-data/states.jsonl
                /usr/bin/npm            9.6.7
                /usr/bin/npx            9.6.7
                nodejs:
                  Version table:
                ioBroker Status
                Thomas BraunT GlasfaserG ? 3 Antworten Letzte Antwort
                • J joeysch
                  Mehr kommt nicht.
                  Skript v.2023-04-16
                  *** BASE SYSTEM ***
                  Docker          : false
                  Release:        11
                  Codename:       bullseye
                  VERSION_ID="11"
                  ID=debian
                  CPU threads: 4
                                   RTC time: n/a
                            RTC in local TZ: no
                  root
                  /root
                  root
                  X-Server:       false
                  Desktop:
                  Terminal:
                  *** MEMORY ***
                  Swap:           4.1G         60M        4.0G
                           4096 M total memory
                           1741 M used memory
                            380 M active memory
                           1702 M free memory
                              0 M buffer memory
                            651 M swap cache
                           4096 M total swap
                             60 M used swap
                           4035 M free swap
                  *** FILESYSTEM ***
                  /var:
                  414M    /var/
                  262M    /var/cache
                  257M    /var/cache/apt
                  135M    /var/lib
                  /usr/bin/npm            9.6.7
                  /usr/bin/npx            9.6.7
                  nodejs:
                    Version table:
                  ioBroker Status
                  @joeysch
                  Dann isses kaputt.
                  Installier es nochmal, diesmal richtig. Siehe entsprechende Anleitung für Proxmox/LXC.
                  • J joeysch
                    Mehr kommt nicht.
                    Skript v.2023-04-16
                    *** BASE SYSTEM ***
                    Docker          : false
                    Release:        11
                    Codename:       bullseye
                    VERSION_ID="11"
                    ID=debian
                    CPU threads: 4
                                     RTC time: n/a
                              RTC in local TZ: no
                    root
                    /root
                    root
                    X-Server:       false
                    Desktop:
                    Terminal:
                    *** MEMORY ***
                    Swap:           4.1G         60M        4.0G
                             4096 M total memory
                             1741 M used memory
                              380 M active memory
                             1702 M free memory
                                0 M buffer memory
                              651 M swap cache
                             4096 M total swap
                               60 M used swap
                             4035 M free swap
                    *** FILESYSTEM ***
                    /var:
                    414M    /var/
                    262M    /var/cache
                    257M    /var/cache/apt
                    135M    /var/lib
                    /usr/bin/npm            9.6.7
                    /usr/bin/npx            9.6.7
                    nodejs:
                      Version table:
                    ioBroker Status
                    GlasfaserG Offline
                    GlasfaserG Offline
                    @joeysch
                    Zeige mal die Ausgabe von
                    iobroker status
                    • J joeysch
                      Mehr kommt nicht.
                      Skript v.2023-04-16
                      *** BASE SYSTEM ***
                      Docker          : false
                      Release:        11
                      Codename:       bullseye
                      VERSION_ID="11"
                      ID=debian
                      CPU threads: 4
                                       RTC time: n/a
                                RTC in local TZ: no
                      root
                      /root
                      root
                      X-Server:       false
                      Desktop:
                      Terminal:
                      *** MEMORY ***
                      Swap:           4.1G         60M        4.0G
                               4096 M total memory
                               1741 M used memory
                                380 M active memory
                               1702 M free memory
                                  0 M buffer memory
                                651 M swap cache
                               4096 M total swap
                                 60 M used swap
                               4035 M free swap
                      *** FILESYSTEM ***
                      /var:
                      414M    /var/
                      262M    /var/cache
                      257M    /var/cache/apt
                      135M    /var/lib
                      /usr/bin/npm            9.6.7
                      /usr/bin/npx            9.6.7
                      nodejs:
                        Version table:
                      ioBroker Status
                      Mehr kommt nicht.
                      Moin,
                      ich würde rein prophylaktisch mal folgendes machen
                      # iob stop
                      # iob fix
                      # iob start
                      Wie führst Du denn den Befehl iob diag aus, als welcher User?
                      Bernd
                      J Thomas BraunT 2 Antworten Letzte Antwort
                        @joeysch
                        Dann isses kaputt.
                        joeysch
                        Proxmox konnte das nicht darstellen
                        Skript v.2023-04-16
                        *** BASE SYSTEM ***
                        Docker          : false
                        Release:        11
                        Codename:       bullseye
                        VERSION_ID="11"
                        ID=debian
                         17:30:42 up 8 min,  1 user,  load average: 0.08, 0.84, 1.09
                        CPU threads: 4
                                       Local time: Mon 2023-09-04 17:30:42 CEST
                                   Universal time: Mon 2023-09-04 15:30:42 UTC
                                         RTC time: n/a
                                  RTC in local TZ: no
                        root
                        /root
                        root
                        X-Server:       false
                        Desktop:
                        Terminal:
                        *** MEMORY ***
                        Mem:            4.1G        2.5G        995M        0.0K        576M        1.6G
                        Swap:           4.1G          0B        4.1G
                        Total:          8.2G        2.5G        5.1G
                                 4096 M total memory
                                 2524 M used memory
                                  240 M active memory
                                 2690 M inactive memory
                                  995 M free memory
                                    0 M buffer memory
                                  576 M swap cache
                                 4096 M total swap
                                    0 M used swap
                                 4096 M free swap
                        *** FILESYSTEM ***
                        tmpfs                            tmpfs     3.2G   96K  3.2G   1% /run
                        /var:
                        414M    /var/
                        262M    /var/cache
                        257M    /var/cache/apt
                        135M    /var/lib
                        377M    /opt/iobroker/iobroker-data/
                        58M     /opt/iobroker/iobroker-data/objects.jsonl
                        25M     /opt/iobroker/iobroker-data/states.jsonl
                        /usr/bin/npm            9.6.7
                        /usr/bin/npx            9.6.7
                        nodejs:
                          Version table:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Core adapters versions
                        js-controller:  4.0.24
                        admin:          6.8.0
                        javascript:     7.0.3
                        Adapters from github:   4
                        Adapter State
                        + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: guido
                        + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                        + system.adapter.chromecast.0             : chromecast            : iobroker                                 -  enabled
                          system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
                        + system.adapter.denon.0                  : denon                 : iobroker                                 -  enabled
                          system.adapter.devices.0                : devices               : iobroker                                 - disabled
                        + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                        + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
                        + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
                        + system.adapter.heos.0                   : heos                  : iobroker                                 -  enabled
                        + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled
                          system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
                        + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                        + system.adapter.influxdb.1               : influxdb              : iobroker                                 -  enabled, port: 8086
                        + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                        + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                        + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
                          system.adapter.material.0               : material              : iobroker                                 - disabled
                        + system.adapter.melcloud.0               : melcloud              : iobroker                                 -  enabled
                        + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 8885, bind: 192.168.0.17
                        + system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
                        + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
                        + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                        + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                        + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
                        + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
                        + system.adapter.time-switch.0            : time-switch           : iobroker                                 -  enabled
                        + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
                        + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
                          system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
                        + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
                          system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker                                 - disabled
                          system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
                          system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
                          system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
                          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                          system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                        + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: guido
                        + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
                        + instance is alive
                        ioBroker-Repositories
                        Active repo(s): stable
                        Installed ioBroker-Instances
                        Used repository: stable
                        Adapter    "admin"        : 6.8.0    , installed 6.8.0
                        Adapter    "backitup"     : 2.6.23   , installed 2.6.23
                        Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
                        Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
                        Adapter    "denon"        : 1.15.4   , installed 1.15.3 [Updatable]
                        Adapter    "devices"      : 1.1.5    , installed 1.1.5
                        Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
                        Adapter    "heos"         : 2.1.0    , installed 2.1.0
                        Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
                        Adapter    "ical"         : 1.13.3   , installed 1.13.3
                        Adapter    "iot"          : 1.14.5   , installed 1.14.5
                        Adapter    "javascript"   : 7.0.3    , installed 7.0.3
                        Adapter    "lgtv"         : 1.1.10   , installed 1.1.10
                        Adapter    "material"     : 1.3.1    , installed 1.3.1
                        Adapter    "melcloud"     : 1.3.5    , installed 1.3.5
                        Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
                        Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
                        Adapter    "node-red"     : 4.0.3    , installed 4.0.3
                        Adapter    "socketio"     : 6.5.2    , installed 6.5.2
                        Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
                        Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                        Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
                        Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                        Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
                        Adapter    "web"          : 6.1.0    , installed 6.1.0
                        Adapter    "ws"           : 2.5.3    , installed 2.5.3
                        Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
                        Objects and States
                        Objects:        69004
                        States:         70882
                        Hit:1 http://security.debian.org bullseye-security InRelease
                        Hit:2 http://ftp.debian.org/debian bullseye InRelease
                        Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
                        Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
                        Reading package lists...
                        Pending Updates: 0
                        *** Listening Ports ***
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       658599025  127/iobroker.js-con
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       658595798  127/iobroker.js-con
                        tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      104        658596858  115/systemd-resolve
                        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          658596710  1/init
                        tcp        0      0 192.168.0.17:8885       0.0.0.0:*               LISTEN      1000       658602110  483/io.mqtt.0
                        tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      104        658596864  115/systemd-resolve
                        tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1000       658600996  435/node-red
                        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          658597149  300/master
                        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       658599887  499/io.sonoff.0
                        tcp6       0      0 :::5355                 :::*                    LISTEN      104        658596861  115/systemd-resolve
                        tcp6       0      0 :::111                  :::*                    LISTEN      0          658596712  1/init
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1000       658600065  311/io.admin.0
                        tcp6       0      0 :::8082                 :::*                    LISTEN      1000       658609468  1157/io.web.0
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          658595609  1/init
                        tcp6       0      0 :::8087                 :::*                    LISTEN      1000       658605893  1052/io.simple-api.
                        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          658597150  300/master
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       658598808  394/io.chromecast.0
                        udp        0      0 0.0.0.0:5355            0.0.0.0:*                           104        658596857  115/systemd-resolve
                        udp        0      0 127.0.0.53:53           0.0.0.0:*                           104        658596863  115/systemd-resolve
                        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          658596711  1/init
                        udp        0      0 0.0.0.0:52532           0.0.0.0:*                           1000       658604456  644/io.heos.0
                        udp6       0      0 :::5355                 :::*                                104        658596860  115/systemd-resolve
                        udp6       0      0 :::111                  :::*                                0          658596713  1/init
                        2023-09-04 15:25:46.002  - info: sourceanalytix.0 (1067) Initialization of sonoff.0.Waschmaschine.Wifi_RSSI successfully
                        2023-09-04 15:25:46.002  - info: sourceanalytix.0 (1067) Initialising (553 of 556) "sonoff.0.Waschmaschine.Wifi_SSId"
                        2023-09-04 15:25:46.127  - info: sourceanalytix.0 (1067) Initialization of sonoff.0.Waschmaschine.Wifi_SSId successfully
                        2023-09-04 15:25:46.127  - info: sourceanalytix.0 (1067) Initialising (554 of 556) "sonoff.0.Waschmaschine.Wifi_Signal"
                        2023-09-04 15:25:46.171  - error: sourceanalytix.0 (1067) Check settings for sonoff.0.Waschmaschine.Wifi_Signal ! Known valueAtDeviceReset : (null) > known cumulative value (-78752.64997722192) cannot proceed
                        2023-09-04 15:25:46.171  - error: sourceanalytix.0 (1067) Troubleshoot Data sonoff.0.Waschmaschine.Wifi_Signal custom Data : {"_id":"sonoff.0.Waschmaschine.Wifi_Signal","common":{"type":"number","role":"value","read":true,"write":false,"name":"Waschmaschine Wifi  Signal","custom":{"sourceanalytix.0":{"enabled":true,"selectedPrice":"ElectricityDay","selectedUnit":"kW","costs":true,"consumption":true,"meter_values":false,"start_day":-78617.64726527748,"start_week":-68733.11133305542,"start_month":-75269.80241777757,"start_quarter":0,"start_year":0,"valueAtDeviceInit":null,"valueAtDeviceReset":null,"cumulativeValue":-78617.64726527748}}},"native":{},"type":"state","from":"system.adapter.sourceanalytix.0","user":"system.user.admin","ts":1693692012274,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        2023-09-04 15:25:46.171  - error: sourceanalytix.0 (1067) Cannot handle calculations for sonoff.0.Waschmaschine.Wifi_Signal, check log messages and adjust settings!
                        2023-09-04 15:25:46.171  - error: sourceanalytix.0 (1067) Initialization of sonoff.0.Waschmaschine.Wifi_Signal failed, check warn messages !
                        2023-09-04 15:25:46.171  - info: sourceanalytix.0 (1067) Initialising (555 of 556) "sonoff.0.Waschmaschine.alive"
                        2023-09-04 15:25:46.316  - info: sourceanalytix.0 (1067) Initialization of sonoff.0.Waschmaschine.alive successfully
                        2023-09-04 15:25:46.316  - info: sourceanalytix.0 (1067) Initialising (556 of 556) "sonoff.0.info.connection"
                        2023-09-04 15:25:46.482  - info: sourceanalytix.0 (1067) Initialization of sonoff.0.info.connection successfully
                        2023-09-04 15:25:46.486  - warn: sourceanalytix.0 (1067) Cannot handle calculations for 13 of 556 enabled states, check error messages
                        2023-09-04 15:25:46.486  - info: sourceanalytix.0 (1067) Successfully activated SourceAnalytix for 543 of 556 states, will do my Job until you stop me!
                        2023-09-04 15:26:29.416  - warn: sonoff.0 (499) Client [pvinverter]  has invalid password(undefined) or username(undefined)
                        2023-09-04 15:26:29.418  - warn: sonoff.0 (499) Client [smartmeter]  has invalid password(undefined) or username(undefined)
                        2023-09-04 15:26:38.447  - warn: fullybrowser.0 (629) updateDeviceERROR 192.168.0.225
                        2023-09-04 15:27:41.519  - warn: fullybrowser.0 (629) updateDeviceERROR 192.168.0.225
                        2023-09-04 15:28:29.421  - warn: sonoff.0 (499) Client [pvinverter]  has invalid password(undefined) or username(undefined)
                        2023-09-04 15:28:29.423  - warn: sonoff.0 (499) Client [smartmeter]  has invalid password(undefined) or username(undefined)
                        2023-09-04 15:28:44.591  - warn: fullybrowser.0 (629) updateDeviceERROR 192.168.0.225
                        2023-09-04 15:29:47.663  - warn: fullybrowser.0 (629) updateDeviceERROR 192.168.0.225
                        2023-09-04 15:30:29.426  - warn: sonoff.0 (499) Client [pvinverter]  has invalid password(undefined) or username(undefined)
                        2023-09-04 15:30:29.429  - warn: sonoff.0 (499) Client [smartmeter]  has invalid password(undefined) or username(undefined)
                        2023-09-04 15:30:50.735  - warn: fullybrowser.0 (629) updateDeviceERROR 192.168.0.225
                        iob diag has finished.
                        Press any key for a summary
                        J GlasfaserG 2 Antworten Letzte Antwort
                        • J joeysch
                          Skript v.2023-04-16
                          *** BASE SYSTEM ***
                          Docker          : false
                          Release:        11
                          Codename:       bullseye
                          VERSION_ID="11"
                          ID=debian
                          CPU threads: 4
                                           RTC time: n/a
                                    RTC in local TZ: no
                          root
                          /root
                          root
                          X-Server:       false
                          Desktop:
                          Terminal:
                          *** MEMORY ***
                          Swap:           4.1G          0B        4.1G
                                   4096 M total memory
                                   2524 M used memory
                                    240 M active memory
                                    995 M free memory
                                      0 M buffer memory
                                    576 M swap cache
                                   4096 M total swap
                                      0 M used swap
                                   4096 M free swap
                          *** FILESYSTEM ***
                          /var:
                          414M    /var/
                          262M    /var/cache
                          257M    /var/cache/apt
                          135M    /var/lib
                          /usr/bin/npm            9.6.7
                          /usr/bin/npx            9.6.7
                          nodejs:
                            Version table:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.8.0
                          javascript:     7.0.3
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        69004
                          States:         70882
                          Pending Updates: 0
                          joeysch
                          Und das noch
                          Copy text starting here:
                                               v.2023-04-16
                          Operatingsystem:        Debian GNU/Linux 11 (bullseye)
                          Kernel:                 5.13.19-2-pve
                          Installation:           lxc
                          User-ID:                0
                          X-Server:               false
                          Pending OS-Updates:     0
                          Pending iob updates:    1
                          Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                                                  /usr/bin/npm            9.6.7
                                                  /usr/bin/npx            9.6.7
                          Recommended versions are nodejs 18.x.y and npm 9.x.y
                          MEMORY:
                          Mem:            4.1G        2.6G        918M        0.0K        577M        1.5G
                          Swap:           4.1G          0B        4.1G
                          Total:          8.2G        2.6G        5.0G
                          Active iob-Instances:   30
                          ioBroker Core:          js-controller           4.0.24
                                                  admin                   6.8.0
                          Objects type: jsonl
                          States  type: jsonl
                          Objects:                69004
                          States:                 70882
                          Size of iob-Database:
                            Mehr kommt nicht.
                            Moin,
                            # iob stop
                            # iob fix
                            # iob start
                            Bernd
                            joeysch
                            @dp20eic
                            Mehrfach gemacht, nichts gebracht.
                              Mehr kommt nicht.
                              Moin,
                              # iob stop
                              # iob fix
                              # iob start
                              Bernd
                              @dp20eic sagte in IoBroker hängt sich komplett auf:
                              Na als User Null aka root
                              • J joeysch
                                @dp20eic
                                GlasfaserG Offline
                                GlasfaserG Offline
                                @joeysch
                                In deinen Screenshot kommt der Port 3000
                                Hast du Grafana als Dialog geöffnet , oder was ist auf diesem Port !?
                                J HomoranH 2 Antworten Letzte Antwort
                                • GlasfaserG Glasfaser
                                  @joeysch
                                  joeysch
                                  @glasfaser
                                  Grafana läuft zwar auf Port 3000 hat aber eine eigene IP 192.168.0.22
                                  • J joeysch
                                    @glasfaser
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    @joeysch
                                    ich würde daraus schließen , das der Gui Fehler von da kommt
                                      @joeysch
                                      @glasfaser Das ist das Demo-Bild aus der Meldung, damit der User weiß was ihn erwartet
                                        @joeysch
                                        joeysch
                                        @glasfaser
                                        Die Meldung kommt erst nachdem der Bildschirm 10min so aussah
                                        Der IoBroker lief jetzt am Stück über ein halbes Jahr ohne Probleme
                                        DJMarc75D GlasfaserG 2 Antworten Letzte Antwort
                                        • J joeysch
                                          @glasfaser
                                          DJMarc75D Offline
                                          DJMarc75D Offline
                                          DJMarc75
                                          Na dann hast Du halt irgendwas am System geändert. Bitte Selbstkontrolle was Du gemacht hast.
                                          Lehrling seit 1975 !!!
