  4. IoBroker hängt sich komplett auf
    5.2k
54 Beiträge 9 Kommentatoren 6.3k Aufrufe 7 Beobachtet
  • J joeysch
    Mehr kommt nicht.
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Architecture    : x86_64
    Docker          : false
    Virtualization  : lxc
    Distributor ID: Debian
    Description:    Debian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     15:18:34 up  1:06,  1 user,  load average: 1.18, 0.93, 1.09
    CPU threads: 4
    *** Time and Time Zones ***
                   Local time: Mon 2023-09-04 15:18:34 UTC
               Universal time: Mon 2023-09-04 15:18:34 UTC
                     RTC time: n/a
                    Time zone: Etc/UTC (UTC, +0000)
                  NTP service: inactive
              RTC in local TZ: no
    *** User and Groups ***
    root
    /root
    root
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:            4.1G        1.7G        1.7G        0.0K        651M        2.4G
    Swap:           4.1G         60M        4.0G
    Total:          8.2G        1.8G        5.7G
             4096 M total memory
             1741 M used memory
              380 M active memory
             1813 M inactive memory
             1702 M free memory
                0 M buffer memory
              651 M swap cache
             4096 M total swap
               60 M used swap
             4035 M free swap
    *** FILESYSTEM ***
    Filesystem                       Type      Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--100--disk--0 ext4       20G  4.2G   15G  23% /
    none                             tmpfs     492K  4.0K  488K   1% /dev
    udev                             devtmpfs  7.8G     0  7.8G   0% /dev/tty
    tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
    tmpfs                            tmpfs     3.2G   92K  3.2G   1% /run
    tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
    dmesg: read kernel buffer failed: Operation not permitted
    TARGET SOURCE                           FSTYPE OPTIONS
    /      /dev/mapper/pve-vm--100--disk--0 ext4   rw,relatime,stripe=16
    /var:
    414M    /var/
    262M    /var/cache
    257M    /var/cache/apt
    190M    /var/cache/apt/archives
    135M    /var/lib
    Archived and active journals take up 16.0M in the file system.
    /opt/iobroker/backups:
    32M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    382M    /opt/iobroker/iobroker-data/
    295M    /opt/iobroker/iobroker-data/files
    52M     /opt/iobroker/iobroker-data/files/javascript.admin
    45M     /opt/iobroker/iobroker-data/files/devices.admin/static
    66M     /opt/iobroker/iobroker-data/objects.jsonl
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    21M     /opt/iobroker/iobroker-data/states.jsonl
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.e564fb87.js.map
    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.17.1
    /usr/bin/node           v18.17.1
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    nodejs:
      Installed: 18.17.1-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
     *** 18.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://security.debian.org bullseye-security/main amd64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://ftp.debian.org/debian bullseye/main amd64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    @joeysch
    Dann isses kaputt.
    Installier es nochmal, diesmal richtig. Siehe entsprechende Anleitung für Proxmox/LXC.
    • J joeysch
      Mehr kommt nicht.
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Docker          : false
      Release:        11
      Codename:       bullseye
      VERSION_ID="11"
      ID=debian
      CPU threads: 4
                       RTC time: n/a
                RTC in local TZ: no
      root
      /root
      root
      X-Server:       false
      Desktop:
      Terminal:
      *** MEMORY ***
      Swap:           4.1G         60M        4.0G
               4096 M total memory
               1741 M used memory
                380 M active memory
               1702 M free memory
                  0 M buffer memory
                651 M swap cache
               4096 M total swap
                 60 M used swap
               4035 M free swap
      *** FILESYSTEM ***
      /var:
      414M    /var/
      262M    /var/cache
      257M    /var/cache/apt
      135M    /var/lib
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      nodejs:
        Version table:
      ioBroker Status
      GlasfaserG Offline
      GlasfaserG Offline
      @joeysch
      Zeige mal die Ausgabe von
      iobroker status
      • J joeysch
        Mehr kommt nicht.
        Skript v.2023-04-16
        *** BASE SYSTEM ***
        Docker          : false
        Release:        11
        Codename:       bullseye
        VERSION_ID="11"
        ID=debian
        CPU threads: 4
                         RTC time: n/a
                  RTC in local TZ: no
        root
        /root
        root
        X-Server:       false
        Desktop:
        Terminal:
        *** MEMORY ***
        Swap:           4.1G         60M        4.0G
                 4096 M total memory
                 1741 M used memory
                  380 M active memory
                 1702 M free memory
                    0 M buffer memory
                  651 M swap cache
                 4096 M total swap
                   60 M used swap
                 4035 M free swap
        *** FILESYSTEM ***
        /var:
        414M    /var/
        262M    /var/cache
        257M    /var/cache/apt
        135M    /var/lib
        /usr/bin/npm            9.6.7
        /usr/bin/npx            9.6.7
        nodejs:
          Version table:
        ioBroker Status
        @joeysch sagte in IoBroker hängt sich komplett auf:
        Mehr kommt nicht.
        Moin,
        ich würde rein prophylaktisch mal folgendes machen
        # iob stop
        # iob fix
        # iob start
        Wie führst Du denn den Befehl iob diag aus, als welcher User?
        Bernd
        J Thomas BraunT 2 Antworten Letzte Antwort
          @joeysch
          Dann isses kaputt.
          joeysch
          Proxmox konnte das nicht darstellen
          Skript v.2023-04-16
          *** BASE SYSTEM ***
          Docker          : false
          Release:        11
          Codename:       bullseye
          VERSION_ID="11"
          ID=debian
           17:30:42 up 8 min,  1 user,  load average: 0.08, 0.84, 1.09
          CPU threads: 4
                         Local time: Mon 2023-09-04 17:30:42 CEST
                     Universal time: Mon 2023-09-04 15:30:42 UTC
                           RTC time: n/a
                    RTC in local TZ: no
          root
          /root
          root
          X-Server:       false
          Desktop:
          Terminal:
          *** MEMORY ***
          Mem:            4.1G        2.5G        995M        0.0K        576M        1.6G
          Swap:           4.1G          0B        4.1G
          Total:          8.2G        2.5G        5.1G
                   4096 M total memory
                   2524 M used memory
                    240 M active memory
                   2690 M inactive memory
                    995 M free memory
                      0 M buffer memory
                    576 M swap cache
                   4096 M total swap
                      0 M used swap
                   4096 M free swap
          *** FILESYSTEM ***
          tmpfs                            tmpfs     3.2G   96K  3.2G   1% /run
          /var:
          414M    /var/
          262M    /var/cache
          257M    /var/cache/apt
          135M    /var/lib
          377M    /opt/iobroker/iobroker-data/
          58M     /opt/iobroker/iobroker-data/objects.jsonl
          25M     /opt/iobroker/iobroker-data/states.jsonl
          /usr/bin/npm            9.6.7
          /usr/bin/npx            9.6.7
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:  4.0.24
          admin:          6.8.0
          javascript:     7.0.3
          Adapters from github:   4
          Adapter State
          + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: guido
          + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
          + system.adapter.chromecast.0             : chromecast            : iobroker                                 -  enabled
            system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
          + system.adapter.denon.0                  : denon                 : iobroker                                 -  enabled
            system.adapter.devices.0                : devices               : iobroker                                 - disabled
          + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
          + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
          + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
          + system.adapter.heos.0                   : heos                  : iobroker                                 -  enabled
          + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled
            system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
          + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
          + system.adapter.influxdb.1               : influxdb              : iobroker                                 -  enabled, port: 8086
          + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
          + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
          + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
          + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
            system.adapter.material.0               : material              : iobroker                                 - disabled
          + system.adapter.melcloud.0               : melcloud              : iobroker                                 -  enabled
          + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 8885, bind: 192.168.0.17
          + system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
          + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
          + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
          + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
          + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
          + system.adapter.time-switch.0            : time-switch           : iobroker                                 -  enabled
          + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
          + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
          + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
            system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker                                 - disabled
            system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
            system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
            system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
            system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
          + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: guido
          + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 6.8.0    , installed 6.8.0
          Adapter    "backitup"     : 2.6.23   , installed 2.6.23
          Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
          Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
          Adapter    "denon"        : 1.15.4   , installed 1.15.3 [Updatable]
          Adapter    "devices"      : 1.1.5    , installed 1.1.5
          Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
          Adapter    "heos"         : 2.1.0    , installed 2.1.0
          Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
          Adapter    "ical"         : 1.13.3   , installed 1.13.3
          Adapter    "iot"          : 1.14.5   , installed 1.14.5
          Adapter    "javascript"   : 7.0.3    , installed 7.0.3
          Adapter    "lgtv"         : 1.1.10   , installed 1.1.10
          Adapter    "material"     : 1.3.1    , installed 1.3.1
          Adapter    "melcloud"     : 1.3.5    , installed 1.3.5
          Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
          Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
          Adapter    "node-red"     : 4.0.3    , installed 4.0.3
          Adapter    "socketio"     : 6.5.2    , installed 6.5.2
          Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
          Adapter    "trashschedule": 2.2.0    , installed 2.2.0
          Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
          Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
          Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
          Adapter    "web"          : 6.1.0    , installed 6.1.0
          Adapter    "ws"           : 2.5.3    , installed 2.5.3
          Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
          Objects and States
          Objects:        69004
          States:         70882
          Hit:1 http://security.debian.org bullseye-security InRelease
          Hit:2 http://ftp.debian.org/debian bullseye InRelease
          Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
          Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       658599025  127/iobroker.js-con
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       658595798  127/iobroker.js-con
          tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      104        658596858  115/systemd-resolve
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          658596710  1/init
          tcp        0      0 192.168.0.17:8885       0.0.0.0:*               LISTEN      1000       658602110  483/io.mqtt.0
          tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      104        658596864  115/systemd-resolve
          tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1000       658600996  435/node-red
          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          658597149  300/master
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       658599887  499/io.sonoff.0
          tcp6       0      0 :::5355                 :::*                    LISTEN      104        658596861  115/systemd-resolve
          tcp6       0      0 :::111                  :::*                    LISTEN      0          658596712  1/init
          tcp6       0      0 :::8081                 :::*                    LISTEN      1000       658600065  311/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1000       658609468  1157/io.web.0
          tcp6       0      0 :::22                   :::*                    LISTEN      0          658595609  1/init
          tcp6       0      0 :::8087                 :::*                    LISTEN      1000       658605893  1052/io.simple-api.
          tcp6       0      0 ::1:25                  :::*                    LISTEN      0          658597150  300/master
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       658598808  394/io.chromecast.0
          udp        0      0 0.0.0.0:5355            0.0.0.0:*                           104        658596857  115/systemd-resolve
          udp        0      0 127.0.0.53:53           0.0.0.0:*                           104        658596863  115/systemd-resolve
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          658596711  1/init
          udp        0      0 0.0.0.0:52532           0.0.0.0:*                           1000       658604456  644/io.heos.0
          udp6       0      0 :::5355                 :::*                                104        658596860  115/systemd-resolve
          udp6       0      0 :::111                  :::*                                0          658596713  1/init
          2023-09-04 15:25:46.002  - info: sourceanalytix.0 (1067) Initialization of sonoff.0.Waschmaschine.Wifi_RSSI successfully
          2023-09-04 15:25:46.002  - info: sourceanalytix.0 (1067) Initialising (553 of 556) "sonoff.0.Waschmaschine.Wifi_SSId"
          2023-09-04 15:25:46.127  - info: sourceanalytix.0 (1067) Initialization of sonoff.0.Waschmaschine.Wifi_SSId successfully
          2023-09-04 15:25:46.127  - info: sourceanalytix.0 (1067) Initialising (554 of 556) "sonoff.0.Waschmaschine.Wifi_Signal"
          2023-09-04 15:25:46.171  - error: sourceanalytix.0 (1067) Check settings for sonoff.0.Waschmaschine.Wifi_Signal ! Known valueAtDeviceReset : (null) > known cumulative value (-78752.64997722192) cannot proceed
          2023-09-04 15:25:46.171  - error: sourceanalytix.0 (1067) Troubleshoot Data sonoff.0.Waschmaschine.Wifi_Signal custom Data : {"_id":"sonoff.0.Waschmaschine.Wifi_Signal","common":{"type":"number","role":"value","read":true,"write":false,"name":"Waschmaschine Wifi  Signal","custom":{"sourceanalytix.0":{"enabled":true,"selectedPrice":"ElectricityDay","selectedUnit":"kW","costs":true,"consumption":true,"meter_values":false,"start_day":-78617.64726527748,"start_week":-68733.11133305542,"start_month":-75269.80241777757,"start_quarter":0,"start_year":0,"valueAtDeviceInit":null,"valueAtDeviceReset":null,"cumulativeValue":-78617.64726527748}}},"native":{},"type":"state","from":"system.adapter.sourceanalytix.0","user":"system.user.admin","ts":1693692012274,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
          2023-09-04 15:25:46.171  - error: sourceanalytix.0 (1067) Cannot handle calculations for sonoff.0.Waschmaschine.Wifi_Signal, check log messages and adjust settings!
          2023-09-04 15:25:46.171  - error: sourceanalytix.0 (1067) Initialization of sonoff.0.Waschmaschine.Wifi_Signal failed, check warn messages !
          2023-09-04 15:25:46.171  - info: sourceanalytix.0 (1067) Initialising (555 of 556) "sonoff.0.Waschmaschine.alive"
          2023-09-04 15:25:46.316  - info: sourceanalytix.0 (1067) Initialization of sonoff.0.Waschmaschine.alive successfully
          2023-09-04 15:25:46.316  - info: sourceanalytix.0 (1067) Initialising (556 of 556) "sonoff.0.info.connection"
          2023-09-04 15:25:46.482  - info: sourceanalytix.0 (1067) Initialization of sonoff.0.info.connection successfully
          2023-09-04 15:25:46.486  - warn: sourceanalytix.0 (1067) Cannot handle calculations for 13 of 556 enabled states, check error messages
          2023-09-04 15:25:46.486  - info: sourceanalytix.0 (1067) Successfully activated SourceAnalytix for 543 of 556 states, will do my Job until you stop me!
          2023-09-04 15:26:29.416  - warn: sonoff.0 (499) Client [pvinverter]  has invalid password(undefined) or username(undefined)
          2023-09-04 15:26:29.418  - warn: sonoff.0 (499) Client [smartmeter]  has invalid password(undefined) or username(undefined)
          2023-09-04 15:26:38.447  - warn: fullybrowser.0 (629) updateDeviceERROR 192.168.0.225
          2023-09-04 15:27:41.519  - warn: fullybrowser.0 (629) updateDeviceERROR 192.168.0.225
          2023-09-04 15:28:29.421  - warn: sonoff.0 (499) Client [pvinverter]  has invalid password(undefined) or username(undefined)
          2023-09-04 15:28:29.423  - warn: sonoff.0 (499) Client [smartmeter]  has invalid password(undefined) or username(undefined)
          2023-09-04 15:28:44.591  - warn: fullybrowser.0 (629) updateDeviceERROR 192.168.0.225
          2023-09-04 15:29:47.663  - warn: fullybrowser.0 (629) updateDeviceERROR 192.168.0.225
          2023-09-04 15:30:29.426  - warn: sonoff.0 (499) Client [pvinverter]  has invalid password(undefined) or username(undefined)
          2023-09-04 15:30:29.429  - warn: sonoff.0 (499) Client [smartmeter]  has invalid password(undefined) or username(undefined)
          2023-09-04 15:30:50.735  - warn: fullybrowser.0 (629) updateDeviceERROR 192.168.0.225
          iob diag has finished.
          Press any key for a summary
          J GlasfaserG 2 Antworten Letzte Antwort
          • J joeysch
            Skript v.2023-04-16
            *** BASE SYSTEM ***
            Docker          : false
            Release:        11
            Codename:       bullseye
            VERSION_ID="11"
            ID=debian
            CPU threads: 4
                             RTC time: n/a
                      RTC in local TZ: no
            root
            /root
            root
            X-Server:       false
            Desktop:
            Terminal:
            *** MEMORY ***
            Swap:           4.1G          0B        4.1G
                     4096 M total memory
                     2524 M used memory
                      240 M active memory
                      995 M free memory
                        0 M buffer memory
                      576 M swap cache
                     4096 M total swap
                        0 M used swap
                     4096 M free swap
            *** FILESYSTEM ***
            /var:
            414M    /var/
            262M    /var/cache
            257M    /var/cache/apt
            135M    /var/lib
            /usr/bin/npm            9.6.7
            /usr/bin/npx            9.6.7
            nodejs:
              Version table:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          6.8.0
            javascript:     7.0.3
            Adapter State
            + instance is alive
            Objects and States
            Objects:        69004
            States:         70882
            Pending Updates: 0
            joeysch
            Und das noch
            Copy text starting here:
                                 v.2023-04-16
            Operatingsystem:        Debian GNU/Linux 11 (bullseye)
            Kernel:                 5.13.19-2-pve
            Installation:           lxc
            User-ID:                0
            X-Server:               false
            Pending OS-Updates:     0
            Pending iob updates:    1
            Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                                    /usr/bin/npm            9.6.7
                                    /usr/bin/npx            9.6.7
            Recommended versions are nodejs 18.x.y and npm 9.x.y
            MEMORY:
            Mem:            4.1G        2.6G        918M        0.0K        577M        1.5G
            Swap:           4.1G          0B        4.1G
            Total:          8.2G        2.6G        5.0G
            Active iob-Instances:   30
            ioBroker Core:          js-controller           4.0.24
                                    admin                   6.8.0
            Objects type: jsonl
            States  type: jsonl
            Objects:                69004
            States:                 70882
            Size of iob-Database:
              Mehr kommt nicht.
              Moin,
              # iob stop
              # iob fix
              # iob start
              Bernd
              joeysch
              @dp20eic
              Mehrfach gemacht, nichts gebracht.
                Mehr kommt nicht.
                Moin,
                # iob stop
                # iob fix
                # iob start
                Bernd
                @dp20eic sagte in IoBroker hängt sich komplett auf:
                Na als User Null aka root
                • J joeysch
                  @dp20eic
                  GlasfaserG Offline
                  GlasfaserG Offline
                  @joeysch
                  In deinen Screenshot kommt der Port 3000
                  Hast du Grafana als Dialog geöffnet , oder was ist auf diesem Port !?
                  J HomoranH 2 Antworten Letzte Antwort
                  • GlasfaserG Glasfaser
                    @joeysch
                    joeysch
                    @glasfaser
                    Grafana läuft zwar auf Port 3000 hat aber eine eigene IP 192.168.0.22
                    • J joeysch
                      @glasfaser
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @joeysch
                      ich würde daraus schließen , das der Gui Fehler von da kommt
                        @joeysch
                        @glasfaser Das ist das Demo-Bild aus der Meldung, damit der User weiß was ihn erwartet
                          @joeysch
                          joeysch
                          @glasfaser
                          Die Meldung kommt erst nachdem der Bildschirm 10min so aussah
                          Der IoBroker lief jetzt am Stück über ein halbes Jahr ohne Probleme
                          DJMarc75D GlasfaserG 2 Antworten Letzte Antwort
                          • J joeysch
                            @glasfaser
                            DJMarc75D Offline
                            DJMarc75D Offline
                            DJMarc75
                            Na dann hast Du halt irgendwas am System geändert. Bitte Selbstkontrolle was Du gemacht hast.
                            Lehrling seit 1975 !!!
                            • DJMarc75D DJMarc75
                              joeysch
                              @djmarc75
                              Definitiv "Nein"
                              Bin zurzeit an meinem 3D Drucker am fummeln.
                              • J joeysch
                                @glasfaser
                                GlasfaserG Offline
                                GlasfaserG Offline
                                Nimm mal bitte einen Browser ,mit dem du noch nie ioBroker geöffnet hast !
                                Was ist dann !?
                                  Was ist dann !?
                                  joeysch
                                  @glasfaser
                                  Genau dasselbe!
                                  • J joeysch
                                    @glasfaser
                                    Genau dasselbe!
                                    @glasfaser
                                    Genau dasselbe!
                                    und hast du mal gemacht was in der Meldung steht?
                                      @glasfaser
                                      Genau dasselbe!
                                      joeysch
                                      Was meinst du?
                                      • J joeysch
                                        Was meinst du?
                                        Was meinst du?
                                        genau das was ich schrieb.
                                        in der Meldung steht Schritt für Schritt was zu tun ist
                                        • J joeysch
                                          Skript v.2023-04-16
                                          *** BASE SYSTEM ***
                                          Docker          : false
                                          Release:        11
                                          Codename:       bullseye
                                          VERSION_ID="11"
                                          ID=debian
                                          CPU threads: 4
                                                           RTC time: n/a
                                                    RTC in local TZ: no
                                          root
                                          /root
                                          root
                                          X-Server:       false
                                          Desktop:
                                          Terminal:
                                          *** MEMORY ***
                                          Swap:           4.1G          0B        4.1G
                                                   4096 M total memory
                                                   2524 M used memory
                                                    240 M active memory
                                                    995 M free memory
                                                      0 M buffer memory
                                                    576 M swap cache
                                                   4096 M total swap
                                                      0 M used swap
                                                   4096 M free swap
                                          *** FILESYSTEM ***
                                          /var:
                                          414M    /var/
                                          262M    /var/cache
                                          257M    /var/cache/apt
                                          135M    /var/lib
                                          /usr/bin/npm            9.6.7
                                          /usr/bin/npx            9.6.7
                                          nodejs:
                                            Version table:
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          admin:          6.8.0
                                          javascript:     7.0.3
                                          Adapter State
                                          + instance is alive
                                          Objects and States
                                          Objects:        69004
                                          States:         70882
                                          Pending Updates: 0
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          • system.adapter.influxdb.0 : influxdb : iobroker - enabled, port: 8086
                                          • system.adapter.influxdb.1 : influxdb : iobroker - enabled, port: 8086
                                          Kann das sein das dein Arbeitsspeicher immer rauf und runtergeht , laut deinen Ausgaben .
                                          Wieviel Datenpunkte loggst du mit Influx !?
                                          EDIT :
                                          Objects and States
                                          Objects:        69004
                                          States:         70882
                                          das sind auch nicht wenige Objects / States als allgemeiner Zusatnd .
