  4. InfluxDB Error: 404 page not found
17 Beiträge 4 Kommentatoren 2.7k Aufrufe 4 Beobachtet
  • F FreakyJ
    Danke für die schnelle Rückmeldung, hier ist der output:
    pi@raspberrypi:~ $ sudo apt update
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Get:3 https://packages.grafana.com/oss/deb stable InRelease [5,984 B]
    Hit:4 https://deb.nodesource.com/node_20.x bullseye InRelease
    Hit:5 https://repos.influxdata.com/debian stable InRelease
    Err:3 https://packages.grafana.com/oss/deb stable InRelease
      The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
    Reading package lists... Done
    All packages are up to date.
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
    W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
    W: Some index files failed to download. They have been ignored, or old ones used instead.
    pi@raspberrypi:~ $ apt policy influxdb*
    N: Unable to locate package influxdb.key
    N: Couldn't find any package by glob 'influxdb.key'
    Hier noch die Node-JS version:
    pi@raspberrypi:~ $ node -v
    v20.5.1
    @freakyj sagte in InfluxDB Error: 404 page not found:
    influxdb.key
    rm influxdb.key
    Dann diesen Thread lesen:
    https://forum.iobroker.net/topic/67822/grafana-repo-braucht-neuen-schlüssel
    Und nodejs20 ist NICHT die für ioBroker vorgesehene und empfohlene Version (und vermutlich der Grund für die Meldung). Installier nodejs@18.
    • F Offline
      FreakyJ
      Danke Danke Danke! Es lag echt nur an der nodeJS Version... argh...
      Thomas BraunT T H 3 Antworten Letzte Antwort
      • F FreakyJ
        Natürlich. Warum glaubst du denn, dass nodejs@18 die Empfehlung ist und noch nicht 20?
        Hast du die beiden anderen Dinge auch erledigt?
        F 1 Antwort Letzte Antwort
          FreakyJ
          Nee das war nicht nötig, nur nodeJS. Nun klappt alles :)
          • F FreakyJ
            Das ist nötig für ein ordentlich laufendes System. Das war nichts optionales...
              FreakyJ
              Sieht aber glaube ich gut aus, vielleicht habe ich es auch ausversehen gefixt...
              influxdb-client:
                Installed: (none)
                Candidate: 1.6.7~rc0-1
                Version table:
                   1.6.7~rc0-1 500
              influxdb-dev:
                Installed: (none)
                Candidate: (none)
                Version table:
              influxdb:
                Installed: 1.8.10-1
                Candidate: 1.8.10-1
                Version table:
               *** 1.8.10-1 500
                      500 https://repos.influxdata.com/debian stable/main armhf Packages
                      500 https://repos.influxdata.com/debian bullseye/stable armhf Packages
                   1.6.7~rc0-1 500
              pi@raspberrypi:~ $
              • F FreakyJ
                influxdb-client:
                  Installed: (none)
                  Version table:
                     1.6.7~rc0-1 500
                influxdb-dev:
                  Installed: (none)
                  Candidate: (none)
                  Version table:
                influxdb:
                  Installed: 1.8.10-1
                  Candidate: 1.8.10-1
                  Version table:
                 *** 1.8.10-1 500
                     1.6.7~rc0-1 500
                pi@raspberrypi:~ $
                @freakyj
                grafana-key auch aktualisiert?
                sudo apt update
                läuft ohne großartige Meldungen durch?
                • F Offline
                  FreakyJ
                  Musste ich doch noch machen^^
                  Nun klappt alles sauber:
                  Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                  Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                  Get:3 https://apt.grafana.com stable InRelease [5,984 B]
                  Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
                  Hit:6 https://repos.influxdata.com/debian bullseye InRelease
                  Get:7 https://apt.grafana.com stable/main armhf Packages [92.4 kB]
                  Fetched 98.3 kB in 1s (72.3 kB/s)
                  1 package can be upgraded. Run 'apt list --upgradable' to see it.
                  pi@raspberrypi:~ $
                  allerdings bin ich nach dieser Anleitung vorgegangen:
                  https://forum.iobroker.net/topic/62040/linux-debian-grafana-repo-muss-aktualisiert-werden
                  Die andere hatte für mich nicht funktioniert.
                  • Thomas BraunT Online
                    Macht genau das gleiche. Nur der zurückgezogene Schlüssel ist natürlich ein anderer.
                    Wenn die andere Anleitung funktioniert hat, dann hast du die Meldung auch schon Monate mitgeschleppt.
                    • F FreakyJ
                      T Nicht stören
                      T Nicht stören
                      ticaki
                      Es hätte vielleicht auch das deaktivieren von Sentry ausreichen können.
                      https://github.com/ioBroker/ioBroker.influxdb/issues/342
                      Spenden
                      • T ticaki
                        @ticaki
                        nodejs@20 ist allerdings auch noch an anderen Stellen zickig.
                          FreakyJ
                          Das ist korrekt :) Ich habe ein Loxone Smart Home und mache eigentlich alles in Loxone. Den ioBroker habe ich nur für zusätzliches Logging der PV Daten (parallel zu Loxone) und zum auslesen der maximalen Zelltemperatur meines Batteriespeichers. Ist also eher spielerei statt eines kritischen Systems^^
                          Man kann auch ganz gut Daten in InfluxDB schreiben mit dem ioBroker und dann über Python weitere Auswertungen machen. Schaue gerade ob ich aus den Loxone Wetterdaten (Strahlung absolut) eine gute Korrelation zu meinem PV Ertrag hinbekomme. Läuft aber erst seit Sonntag und ich muss noch ein paar Daten sammeln.
                          • F FreakyJ
                            Hady
                            @freakyj Hi, könntest du mir sagen, mit welchen befehl du Node18 installiert hast, bitte?
                            • H Hady
                              @hady
                              Mittlerweile ist nodejs@20 die vorgesehene und empfohlene Version.
                              Installiert man per
                              iob nodejs-update
                              Wenn aus irgendwelchen Gründen eine bestimmte Major-Version gewünscht ist kann man die als Option mitgeben:
                              iob nodejs-update 18
