  3. Off Topic
  4. InfluxDB
  5. InfluxDB im Query unter _measurement keine Datenpunkte mehr
    1.0k
    6.1k
Geplant Angeheftet Gesperrt Verschoben InfluxDB
126 Beiträge 7 Kommentatoren 23.4k Aufrufe 4 Beobachtet
  • G Geesthachter
    @dp20eic
    Wenn ich das richtig verstehe ist mein Token nicht korrekt?
    Incorrect Usage. flag provided but not defined: -t
    NAME:
       influx - Influx Client
    USAGE:
       influx [command]
    HINT: If you are looking for the InfluxQL shell from 1.x, run "influx v1 shell"
    COMMANDS:
       version              Print the influx CLI version
       write                Write points to InfluxDB
       bucket               Bucket management commands
       completion           Generates completion scripts
       query                Execute a Flux query
       config               Config management commands
       org, organization    Organization management commands
       delete               Delete points from InfluxDB
       user                 User management commands
       task                 Task management commands
       telegrafs            List Telegraf configuration(s). Subcommands manage Telegraf configurations.
       dashboards           List Dashboard(s).
       export               Export existing resources as a template
       secret               Secret management commands
       v1                   InfluxDB v1 management commands
       auth, authorization  Authorization management commands
       apply                Apply a template to manage resources
       stacks               List stack(s) and associated templates. Subcommands manage stacks.
       template             Summarize the provided template
       bucket-schema        Bucket schema management commands
       scripts              Scripts management commands
       ping                 Check the InfluxDB /health endpoint
       setup                Setup instance with initial user, org, bucket
       backup               Backup database
       restore              Restores a backup directory to InfluxDB
       remote               Remote connection management commands
       replication          Replication stream management commands
       server-config        Display server config
       help, h              Shows a list of commands or help for one command
    GLOBAL OPTIONS:
       --help, -h  show help
    Error: flag provided but not defined: -t
    @geesthachter sagte in InfluxDB im Query unter _measurement keine Datenpunkte mehr:
    Moin,
    nein, nur bei dem abgesetzten Befehl, den man leider nicht sieht, gibt es kein -t
    Bernd
    G 1 Antwort Letzte Antwort
      Moin,
      Bernd
      Geesthachter
      @dp20eic
       influx -t wW8syN4VCT9B5uboZnPjxcJqwNvY8rx0DvGpzxPVVU5w9bRs4fW5tmn4a35UdCYnC60zOcTnWoQY-7S3BhG7Fg== org list
      NAME:
      USAGE:
         influx [command]
      COMMANDS:
      GLOBAL OPTIONS:
      • G Geesthachter
        @dp20eic
        Installiert hatte ich es so
        https://www.youtube.com/watch?v=oasYKpkIv1U
        @geesthachter
        Ich hoffe du hast influxdb nicht so wie in dem Clip installiert sondern ein Repository reingezogen und das dann ordentlich über den Paketmanager gemacht.
        • G Geesthachter
          @dp20eic
          NAME:
          USAGE:
             influx [command]
          COMMANDS:
          GLOBAL OPTIONS:
          Moin,
          ja wie gesagt, der Befehl kennt kein flag -t daher
          Bernd
            Moin,
            Bernd
            Marc BergM Offline
            Marc BergM Offline
            Marc Berg
            @dp20eic sagte in InfluxDB im Query unter _measurement keine Datenpunkte mehr:
            Doch, das geht schon, allerdings in der zuerst angenommenen Reihenfolge "influx org list -t <token>". Da das aber nicht funktioniert, nehme ich an, dass @Geesthachter einen Token innerhalb Organisation "A" erstellt hat und nun versucht, damit Organisation "B" zu löschen. Das geht natürlich nicht.
            @Geesthachter: welchen Token nutzt du und wo hast du den her?
            ? G 2 Antworten Letzte Antwort
            • Marc BergM Marc Berg
              @marc-berg sagte in InfluxDB im Query unter _measurement keine Datenpunkte mehr:
              Moin,
              ja, gestern habe ich schon darüber nachgedacht, dass ich ihm vorschlage einen ganz neuen Master/admin Token zu erstellen.
              Scheue mich aber etwas, da ich nicht schuld sein möchte, wenn es in die Hose geht.
              https://docs.influxdata.com/influxdb/v2.7/reference/cli/influx/auth/create/#create-an-api-token-with-specified-read-and-write-permissions
              Bernd
              • Marc BergM Offline
                Marc BergM Offline
                Marc Berg
                ja, das wäre sicher das Beste und man könnte die Config gleich mit glattziehen, um nicht immer wieder den Token eingeben zu müssen. Ist denn sicher, dass der Root Token nicht mehr existiert? Das konnte ich hier noch nicht herauslesen.
                Ja, insbesondere deshalb, da ja ohne Root Token wahrscheinlich auch kein Backup existiert.
                  Geesthachter
                  @marc-berg
                  Ich habe mir einmal den ursprünglichen ersten Token gesichert und dann später, frag mich nicht zu welchem Zeitpunkt und warum einen zweiten.
                  Wie gesagt ich weiß nicht wofür der zweite Token war
                  ? Marc BergM 2 Antworten Letzte Antwort
                  • G Geesthachter
                    @marc-berg
                    Moin,
                    hast Du es denn dann mal mit beiden Tokens versucht?
                    Bernd
                      Moin,
                      Bernd
                      Geesthachter
                      @thomas-braun sagte in InfluxDB im Query unter _measurement keine Datenpunkte mehr:
                      @geesthachter
                      Wenn ich mich recht erinnere dann habe ich es wie hier im Video gezeigt gemacht.
                      Gibt es irgendwo eine bessere Anleitung in deutsch mit Repository und dem Paketmanager?
                      Viel Schwierigkeiten habe ich dann jedenfalls später mit der Sicherung über backitup gehabt, das hat ewig gedauert bis backitup auch die Influx Daten gesichert hat.
                      Wenn es erforderlich sein sollte das ich alles neu machen muss dann wäre ich bereit alles noch mal von vorne neu zu installieren, das bedeutet zwar in Grafana wieder viel Arbeit aber wenn dann alles läuft dann wäre mir lieber das jetzt zu machen als zu einem Zeitpunkt wo ich noch mehr Visualisierungen erstellt habe.
                      Wäre es bei einer Neuinstallation möglich die ganzen Grafana Visualisierungen irgendwie zu sichern und dann nach einem platt machen des Raspberrys wieder einzuspielen?
                        Moin,
                        Bernd
                        Geesthachter
                        Moin,
                        Bernd
                        ja ich habe es mit beiden versucht.
                        • G Geesthachter
                          @marc-berg
                          Marc BergM Offline
                          Marc BergM Offline
                          Marc Berg
                          Da dieser erste Token nicht mehr funktioniert, wird er nicht mehr existieren. Entweder der Token wurde gelöscht, oder der User, unter dem der Token erstellt wurde.
                          Was wird hier angezeigt? Insbesondere der älteste Eintrag?
                          Edit: am besten für ALLE Organizations zeigen.
                          • G Geesthachter
                            @geesthachter
                            @geesthachter
                            Ist zwar jetzt OT, aber
                            apt policy grafana influxdb*
                            sagt?
                            • ? Offline
                              #66
                              Moin,
                              warum haben immer alle so viel Angst vor dem Englischen, ich habe mein Englisch verbessert, seit dem ich mit Computern herumspiele ~1990, mit Linux, es gab da noch so gut wie keine deutschsprachigen Bücher und das Internet lag noch im Dornröschenschlaf :)
                              Der Google - Übersetzer oder die Übersetzung im Browser sollten eigentlich reichen, um die Grundgedanken zu verstehen.
                              Anyway.
                              Soweit mir bekannt, nutze BackitUp nicht, kann man damit Grafana und auch influxDB sichern und auch wieder zurückspielen, oder Du sicherst Dir deine Dashboards händisch.
                              Oder
                              ich glaube, das sollte passen https://grafana.com/docs/grafana/latest/setup-grafana/installation/debian/ aber @Thomas-Braun hat da so eine kleine geniale Sammlung von Repositorys, finde ich aber gerade nicht :
                              Für influxDB hatte ich mal geschaut, das sollte passen, so wie es im YT Video gezeigt wurde -> https://portal.influxdata.com/downloads/
                              # influxdata-archive_compat.key GPG fingerprint:
                              #     9D53 9D90 D332 8DC7 D6C8 D3B9 D8FF 8E1F 7DF8 B07E
                              wget -q https://repos.influxdata.com/influxdata-archive_compat.key
                              echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg > /dev/null
                              echo 'deb [signed-by=/etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
                              sudo apt-get update && sudo apt-get install influxdb2
                              Bernd
                                Moin,
                                Anyway.
                                Oder
                                Bernd
                                #67
                                https://forum.iobroker.net/topic/59231/phantastische-repositories-und-wo-sie-zu-finden-sind?_=1692443708129
                                  Moin,
                                  Anyway.
                                  Oder
                                  Bernd
                                  #68
                                  @dp20eic
                                  Du meinst
                                  vermutlich.
                                  Ich hatte in das Video nur mal kurz reingeschaut und mich mal wieder darüber gewundert, warum ein Video gepostet wird, in dem lediglich immer wieder gezeigt wird wie mal Text von a nach b kopiert. Naja, wer es braucht...
                                  Und entweder bei grafana oder influxdb wurde da wohl nicht das Repo angelegt sondern ein deb statisch in das System gelegt. Klar, steht ja auch so blöd in der Anleitung drin. Ist aber dennoch falsch, wenn man ein Repo zur Verfügung hat.
                                    @dp20eic
                                    Du meinst
                                    vermutlich.
                                    #69
                                    Moin,
                                    Du meinst
                                    vermutlich.
                                    Ja genau, ich sollte mir das endlich mal in die Favoriten aufnehmen :)
                                    @homoran sagte in InfluxDB im Query unter _measurement keine Datenpunkte mehr:
                                    Ja, Dnake :)
                                    Jup, sehe ich ja auch so, aber bei der influxDB Installation hat er tatsächlich das Repo angelegt
                                    Bei Grafana nicht, wenn ich das nicht im Schnelldurchlauf übersehen haben sollte.
                                    Bernd
                                      @geesthachter
                                      sagt?
                                      Geesthachter
                                      #70
                                      @geesthachter
                                      sagt?
                                      pi@raspberrypi:~ $ apt policy grafana influxdb*
                                      grafana:
                                        Installed: (none)
                                        Candidate: 10.0.3
                                        Version table:
                                           10.0.3 500
                                              500 https://apt.grafana.com stable/main arm64 Packages
                                           10.0.2 500
                                           10.0.1 500
                                           10.0.0 500
                                           9.5.8 500
                                           9.5.7 500
                                           9.5.6 500
                                           9.5.5 500
                                           9.5.3 500
                                           9.5.2 500
                                           9.5.1 500
                                           9.5.0 500
                                           9.4.13 500
                                           9.4.12 500
                                           9.4.10 500
                                           9.4.9 500
                                           9.4.7 500
                                           9.4.3 500
                                           9.4.2 500
                                           9.4.1 500
                                           9.4.0 500
                                           9.3.16 500
                                           9.3.15 500
                                           9.3.14 500
                                           9.3.13 500
                                           9.3.11 500
                                           9.3.8 500
                                           9.3.6 500
                                           9.3.4 500
                                           9.3.2 500
                                           9.3.1 500
                                           9.3.0 500
                                           9.2.20 500
                                           9.2.19 500
                                           9.2.18 500
                                           9.2.17 500
                                           9.2.15 500
                                           9.2.13 500
                                           9.2.10 500
                                           9.2.8 500
                                           9.2.7 500
                                           9.2.6 500
                                           9.2.5 500
                                           9.2.4 500
                                           9.2.3 500
                                           9.2.2 500
                                           9.2.1 500
                                           9.2.0 500
                                           9.1.8 500
                                           9.1.7 500
                                           9.1.6 500
                                           9.1.5 500
                                           9.1.4 500
                                           9.1.3 500
                                           9.1.2 500
                                           9.1.1 500
                                           9.1.0 500
                                           9.0.9 500
                                           9.0.8 500
                                           9.0.7 500
                                           9.0.6 500
                                           9.0.5 500
                                           9.0.4 500
                                           9.0.3 500
                                           9.0.2 500
                                           9.0.1 500
                                           9.0.0 500
                                           8.5.27 500
                                           8.5.26 500
                                           8.5.25 500
                                           8.5.24 500
                                           8.5.22 500
                                           8.5.21 500
                                           8.5.20 500
                                           8.5.16 500
                                           8.5.15 500
                                           8.5.14 500
                                           8.5.13 500
                                           8.5.12 500
                                           8.5.10 500
                                           8.5.9 500
                                           8.5.6 500
                                           8.5.5 500
                                           8.5.4 500
                                           8.5.3 500
                                           8.5.2 500
                                           8.5.1 500
                                           8.5.0 500
                                           8.4.11 500
                                           8.4.10 500
                                           8.4.7 500
                                           8.4.6 500
                                           8.4.5 500
                                           8.4.4 500
                                           8.4.3 500
                                           8.4.2 500
                                           8.4.1 500
                                           8.4.0 500
                                           8.3.11 500
                                           8.3.10 500
                                           8.3.7 500
                                           8.3.6 500
                                           8.3.5 500
                                           8.3.4 500
                                           8.3.3 500
                                           8.3.2 500
                                           8.3.1 500
                                           8.3.0 500
                                           8.2.7 500
                                           8.2.6 500
                                           8.2.5 500
                                           8.2.4 500
                                           8.2.3 500
                                           8.2.2 500
                                           8.2.1 500
                                           8.2.0 500
                                           8.1.8 500
                                           8.1.7 500
                                           8.1.6 500
                                           8.1.5 500
                                           8.1.4 500
                                           8.1.3 500
                                           8.1.2 500
                                           8.1.1 500
                                           8.1.0 500
                                           8.0.7 500
                                           8.0.6 500
                                           8.0.5 500
                                           8.0.4 500
                                           8.0.3 500
                                           8.0.2 500
                                           8.0.1 500
                                           8.0.0 500
                                           7.5.16 500
                                           7.5.15 500
                                           7.5.13 500
                                           7.5.12 500
                                           7.5.11 500
                                           7.5.10 500
                                           7.5.9 500
                                           7.5.8 500
                                           7.5.7 500
                                           7.5.6 500
                                           7.5.5 500
                                           7.5.4 500
                                           7.5.3 500
                                           7.5.2 500
                                           7.5.1 500
                                           7.5.0 500
                                           7.4.5 500
                                           7.4.3 500
                                           7.4.2 500
                                           7.4.1 500
                                           7.4.0 500
                                           7.3.10 500
                                           7.3.7 500
                                           7.3.6 500
                                           7.3.5 500
                                           7.3.4 500
                                           7.3.3 500
                                           7.3.2 500
                                           7.3.1 500
                                           7.3.0 500
                                           7.2.2 500
                                           7.2.1 500
                                           7.2.0 500
                                           7.1.5 500
                                           7.1.4 500
                                           7.1.3 500
                                           7.1.2 500
                                           7.1.1 500
                                           7.1.0 500
                                           7.0.6 500
                                           7.0.5 500
                                           7.0.4 500
                                           7.0.3 500
                                           7.0.2 500
                                           7.0.1 500
                                           7.0.0 500
                                           6.7.6 500
                                           6.7.5 500
                                           6.7.4 500
                                           6.7.3 500
                                           6.7.2 500
                                           6.7.1 500
                                           6.7.0 500
                                           6.6.2 500
                                           6.6.1 500
                                           6.6.0 500
                                           6.5.3 500
                                           6.5.2 500
                                           6.5.1 500
                                           6.5.0 500
                                           6.4.5 500
                                           6.4.4 500
                                           6.4.3 500
                                           6.4.2 500
                                           6.4.1 500
                                           6.4.0 500
                                           6.3.7 500
                                           6.3.6 500
                                           6.3.5 500
                                           6.3.4 500
                                           6.3.3 500
                                           6.3.2 500
                                           6.3.1 500
                                           6.3.0 500
                                           6.2.5 500
                                           6.2.4 500
                                           6.2.3 500
                                           6.2.2 500
                                           6.2.1 500
                                           6.2.0 500
                                           6.1.6 500
                                           6.1.5 500
                                           6.1.4 500
                                           6.1.3 500
                                           6.1.2 500
                                           6.1.1 500
                                           6.1.0 500
                                           6.0.2 500
                                           6.0.1 500
                                           6.0.0 500
                                           5.4.5 500
                                           5.4.4 500
                                           5.4.3 500
                                           5.4.2 500
                                           5.4.1 500
                                           5.4.0 500
                                           5.3.4 500
                                           5.3.3 500
                                           5.3.2 500
                                           5.3.1 500
                                           5.3.0 500
                                           5.2.5 500
                                           5.2.4 500
                                           5.2.3 500
                                           5.2.2 500
                                           5.2.1 500
                                           5.2.0 500
                                           0.0.0~test 500
                                      influxdb2-cli:
                                        Installed: 2.7.3-1
                                        Candidate: 2.7.3-1
                                        Version table:
                                       *** 2.7.3-1 500
                                              500 https://repos.influxdata.com/debian stable/main arm64 Packages
                                           2.7.1-2 500
                                           2.6.1 500
                                           2.6.0 500
                                           2.5.0 500
                                           2.4.0 500
                                           2.3.0 500
                                      influxdb-client:
                                        Installed: (none)
                                        Candidate: 1.6.7~rc0-1+b5
                                        Version table:
                                           1.6.7~rc0-1+b5 500
                                              500 http://deb.debian.org/debian bullseye/main arm64 Packages
                                      influxdb-dev:
                                        Installed: (none)
                                        Candidate: (none)
                                        Version table:
                                      influxdb2-client:
                                        Installed: (none)
                                        Candidate: 2.7.1-1
                                        Version table:
                                           2.7.1-1 500
                                      influxdb:
                                        Installed: (none)
                                        Candidate: 1.8.10-1
                                        Version table:
                                           1.8.10-1 500
                                           1.6.7~rc0-1+b5 500
                                      influxdb2:
                                        Installed: 2.7.1-1
                                        Candidate: 2.7.1-1
                                        Version table:
                                       *** 2.7.1-1 500
                                           2.7.0-1 500
                                           2.6.1-1 500
                                           2.6.0-1 500
                                           2.5.1-1 500
                                           2.4.0-1 500
                                           2.3.0-1 500
                                           2.2.0 500
                                      • G Offline
                                        Geesthachter
                                        #71
                                        Das ich absoluter Anfänger bei InfluxDB und Grafana bin habt ihr ja inzwischen gemerkt bevor ich jetzt alles platt mache, noch ein paar Fragen. Du hast hier Stichwörter mit denen ich nichts anfangen kann.
                                        1. "Repository reingezogen"
                                        was ist ein Repository? was macht das Repository? den Link wo ich es finde, wurde ja bereits gepostet.
                                        Wann installiere ich dieses Repository?
                                        1. "ordentlich über den Paketmanager."
                                        was ist ein Paketmanager? wofür ist der Paketmanager? was macht der Paketmanager? wie geht das mit dem Paketmager?
                                        Thomas BraunT ? 2 Antworten Letzte Antwort
                                        • G Geesthachter
                                          #72
                                          @geesthachter
                                          Repository = Menükarte für Software
                                          Paketmanager = Bedienung, die das gewünschte Softwarepaket fertig zubereitet serviert. Und Nachschlag in Form von Updates werden auch darüber angeboten.
                                          Du hast jetzt 'einmal zum mitnehmen' geordert.
                                          Näheres bei der Suchmaschine deiner Wahl oder hier:
                                          https://wiki.ubuntuusers.de/apt/apt/#:~:text=apt ist ein Kommandozeilen-Programm,nur Informationen zu Paketen anzeigen.
