  4. dyson Air purifier Adapter - Tester gesucht
dyson hot pure cool humidifyer
247 Beiträge 33 Kommentatoren 64.5k Aufrufe 30 Beobachtet
    M1R0O
    schrieb am zuletzt editiert von M1R0O
    #175
    Hi zusammen,
    ich nutze seit heute den Dyson Pure Cool Link Tower TP02 und habe den Adapter ausprobieren wollen.
    Die Anmeldung klappte problemlos, allerdings verbindet sich der Adapter nicht mit dem Gerät.
    Hier das Protokoll:
    dysonairpurifier.0
    2023-04-18 20:51:36.628	debug	NN2-EU-MGA0627A - MQTT error: Error: getaddrinfo ENOTFOUND nn2-eu-mga0627a
    dysonairpurifier.0
    2023-04-18 20:51:36.582	info	NN2-EU-MGA0627A - MQTT reconnecting.
    dysonairpurifier.0
    2023-04-18 20:51:35.582	info	NN2-EU-MGA0627A - MQTT disconnected.
    dysonairpurifier.0
    2023-04-18 20:51:35.581	info	NN2-EU-MGA0627A - MQTT offline.
    dysonairpurifier.0
    2023-04-18 20:51:35.568	debug	NN2-EU-MGA0627A - MQTT error: Error: getaddrinfo ENOTFOUND nn2-eu-mga0627a
    dysonairpurifier.0
    2023-04-18 20:51:35.559	info	NN2-EU-MGA0627A - MQTT connection requested for [NN2-EU-MGA0627A].
    dysonairpurifier.0
    2023-04-18 20:51:35.489	info	Trying to connect to device [NN2-EU-MGA0627A] via MQTT on host address [NN2-EU-MGA0627A].
    dysonairpurifier.0
    2023-04-18 20:51:35.488	debug	Subscribing for state changes on :NN2-EU-MGA0627A.hostAddress
    dysonairpurifier.0
    2023-04-18 20:51:35.488	info	No host address given. Trying to connect to the device with it's default hostname [NN2-EU-MGA0627A]. This should work if you haven't changed it and if you're running a DNS.
    dysonairpurifier.0
    2023-04-18 20:51:35.487	debug	Result of CreateOrUpdateDevice: [{"Serial":"NN2-EU-MGA0627A","Name":"Wohnzimmer","Version":"21.04.03","LocalCredentials":"OWfUlFHQFhy6EwFKHUDWxjdnRJCk58F84TvdwFL+altOqBScOXCdJ16oxqILlACsD+hDvmmykHcD73gVyQyl/tz4YKy9lDsnWoCLbcq+z+K7qn8pJZjuPDeZLNRzooaw+1d4t6llKU9urmYutS5uIUV6PFrBCRsLAC//NyHMc+FDhWV+yxf5ysLWcy/QBMI8","AutoUpdate":true,"NewVersionAvailable":false,"ProductType":"475","ConnectionType":"wss","mqttClient":null,"mqttPassword":"76o2xveDE5CBv4TDJeMOHohlmZncC2iUmjiZxc5ZIdIYmmwBzHYtn05ca4tW0+AaGA6nwIK80rYeirlHpsPbUQ==","updateIntervalHandle":null}]
    dysonairpurifier.0
    2023-04-18 20:51:35.487	debug	Got Host-Address-object [{"val":"","ack":true,"ts":1681843075261,"q":0,"from":"system.adapter.dysonairpurifier.0","user":"system.user.admin","lc":1681838179636}] for device: NN2-EU-MGA0627A
    dysonairpurifier.0
    2023-04-18 20:51:35.481	debug	Querying Host-Address of device: NN2-EU-MGA0627A
    dysonairpurifier.0
    2023-04-18 20:51:35.476	debug	Data received from dyson API: {"Serial":"NN2-EU-MGA0627A","Name":"Wohnzimmer","Version":"21.04.03","LocalCredentials":"OWfUlFHQFhy6EwFKHUDWxjdnRJCk58F84TvdwFL+altOqBScOXCdJ16oxqILlACsD+hDvmmykHcD73gVyQyl/tz4YKy9lDsnWoCLbcq+z+K7qn8pJZjuPDeZLNRzooaw+1d4t6llKU9urmYutS5uIUV6PFrBCRsLAC//NyHMc+FDhWV+yxf5ysLWcy/QBMI8","AutoUpdate":true,"NewVersionAvailable":false,"ProductType":"475","ConnectionType":"wss"}
    dysonairpurifier.0
    2023-04-18 20:51:34.999	info	Querying devices from dyson API.
    dysonairpurifier.0
    2023-04-18 20:51:34.920	info	starting. Version 2.5.7 in /opt/iobroker/node_modules/iobroker.dysonairpurifier, node: v18.15.0, js-controller: 4.0.24
    dysonairpurifier.0
    2023-04-18 20:51:34.436	debug	Plugin sentry Initialize Plugin (enabled=true)
    dysonairpurifier.0
    2023-04-18 20:51:34.234	debug	States connected to redis: 127.0.0.1:9000
    dysonairpurifier.0
    2023-04-18 20:51:34.177	debug	States create User PubSub Client
    dysonairpurifier.0
    2023-04-18 20:51:34.176	debug	States create System PubSub Client
    dysonairpurifier.0
    2023-04-18 20:51:34.144	debug	Redis States: Use Redis connection: 127.0.0.1:9000
    dysonairpurifier.0
    2023-04-18 20:51:34.087	debug	Objects connected to redis: 127.0.0.1:9001
    dysonairpurifier.0
    2023-04-18 20:51:34.076	debug	Objects client initialize lua scripts
    dysonairpurifier.0
    2023-04-18 20:51:33.960	debug	Objects create User PubSub Client
    dysonairpurifier.0
    2023-04-18 20:51:33.957	debug	Objects create System PubSub Client
    dysonairpurifier.0
    2023-04-18 20:51:33.943	debug	Objects client ready ... initialize now
    dysonairpurifier.0
    2023-04-18 20:51:33.853	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
    Ich glaube, das PRoblem ist
    Wenn es das ist, wie ändere ich das?
    Danke!
    FabioF 1 Antwort Letzte Antwort
    • M M1R0O
      Hi zusammen,
      Hier das Protokoll:
      dysonairpurifier.0
      dysonairpurifier.0
      dysonairpurifier.0
      dysonairpurifier.0
      dysonairpurifier.0
      dysonairpurifier.0
      dysonairpurifier.0
      dysonairpurifier.0
      dysonairpurifier.0
      dysonairpurifier.0
      dysonairpurifier.0
      dysonairpurifier.0
      dysonairpurifier.0
      dysonairpurifier.0
      dysonairpurifier.0
      dysonairpurifier.0
      dysonairpurifier.0
      dysonairpurifier.0
      dysonairpurifier.0
      dysonairpurifier.0
      dysonairpurifier.0
      dysonairpurifier.0
      dysonairpurifier.0
      dysonairpurifier.0
      dysonairpurifier.0
      dysonairpurifier.0
      Danke!
      FabioF Offline
      FabioF Offline
      Fabio
      schrieb am zuletzt editiert von Fabio
      #176
      @m1r0o du hast unter den Datenpunkten die angelegt werden noch den Hostaddress trage da mal die IP vom Gerät ein und starte dann den Adapter noch mal.
      Zitat Anleitung:
      So konfigurieren Sie den Adapter
      Beim ersten regulären Start dieses Adapters wird die Dyson API für alle Ihre Geräte abgefragt und alle unterstützten Geräte werden im Gerätebaum angelegt – mit ihren von der API bereitgestellten Grundinformationen und einem zusätzlichen Feld Hostaddress.
      Führen Sie den Adapter also bitte einmal aus, und Ihre Dyson-Geräte werden mit ihren Grundeinstellungen im Gerätebaum angelegt.
      Stoppen Sie dann den Adapter, geben Sie die IP(s) in die HostaddressFelder im Gerätebaum ein und starten Sie den Adapter neu. Danach sollten Ihre Dyson-Geräte im Gerätebaum mit Daten gefüllt sein.* Zitat Ende
      Iobroker:
      • Matter over Thread Hilfe
      • FabioF Fabio
        M1R0O
        #177
        @fa-bio Hat geklappt! Danke 👍 👍
        • M M1R0O
          FabioF Offline
          FabioF Offline
          Fabio
          #178
          @m1r0o prima dann viel Spass. 👍
          Iobroker:
            mike2712
            #179
            Hallo, ich habe 2 Dyson Geräte, es funktioniert bis auf eine Sache alles, ich bekomme allerdings bei dem "Dyson Pure Hot+Cool Link" nicht die Target Temperature gesteuert.
            Damit überhaupt unter den Datenpunkten etwas ankommt muss ich "Bestätigt" mit anhaken, nach kurzer Zeit wird der Wert vom Gerät wieder auf den ursprünglichen Wert überschrieben. Ohne Wert setzen steht in dem Datenpunkt immer 0.45 °C.
            Habe versucht als String, Nummer usw. zu schreiben, immer ohne Erfolg, ist das Problem bekannt, oder mache ich etwas grundlegendes falsch?
            Alles andere Lüfter Ein/Aus/Automatik, alle Werte, etc. funktioniert einwandfrei.
            Jemand eine Idee?
            ioBroker im Docker auf Qnap TS-453A 16GB Ram 4-Bay
            GrizzelbeeG 1 Antwort Letzte Antwort
            • M mike2712
              Jemand eine Idee?
              GrizzelbeeG Offline
              GrizzelbeeG Offline
              Grizzelbee
              #180
              Hallo Mike
              @mike2712 sagte in dyson Air purifier Adapter - Tester gesucht:
              Es ist durchaus möglich, dass diese Funktion noch ungetestet oder einfach ungenutzt ist. Ich selber habe kein Dyson Gerät das heizt - will sagen: ich selbst kann diese Funktion nicht testen. Insofern kann es durchaus sein das das fehlerhaft implementiert ist. Im Moment kann ich da allerdings nicht viel helfen - aber in ca zwei Wochen wieder gerne. Dann können wir das gemeinsam angehen und debuggen.
              Bis dahin möchte ich dich bitten einen issue auf GitHub zu öffnen und ein debug Log anzuhängen das den Schaltvorgang zeigt. Ach ja - in dem Zusammenhang: wenn du möchtest das ein ioBroker Adapter etwas schaltet darfst du den Haken bei "Bestätigt" NICHT setzen - denn genau diese unbestätigte Änderung ist es an der der Adapter erkennt daß er etwas tun soll. Den Status "Bestätigt" setzt der Adapter wenn er die Änderung erfolgreich durchgeführt hat.
              Viele Grüße - ich melde mich wieder sobald ich mich um den Bug kümmern kann.
              • GrizzelbeeG Grizzelbee
                Hallo Mike
                mike2712
                #181
                @grizzelbee
                danke für die Information, okay deswegen passiert dann auch nichts, ausser das der Datenpunkt nicht zum Gerät gesendet wird, von daher nach ein paar Sekunden wieder der alte Wert, ,ohne bestätigt empfängt das Gerät, egal was ich sende 0.45 °C, der datenpunkt ist original als string, habe string gesendet, number, alles mögliche.
                Im Log vom Debug steht leider nichts, das hatte ich schon vermutet, wenn ich am Gerät die Temperatur ändere, ändert sich auch der Datenpunkt im ioBroker, denke ich mache irgendetwas beim senden falsch, vielleicht muss man den Wert anderes interpretieren, für 30°C eine 3000 als string oder so was senden, ich spiele mal etwas weiter rum, vielen Dank schon mal für die Info.
                • M mike2712
                  @grizzelbee
                  GrizzelbeeG Offline
                  GrizzelbeeG Offline
                  Grizzelbee
                  #182
                  Das Problem dürfte sein, das die Dyson Geräte intern alle Temperaturen in Kelvin verarbeiten. Das rechne ich im Adapter jeweils um. Ich vermute dass dabei etwas schief geht.
                    mike2712
                    schrieb am zuletzt editiert von mike2712
                    #183
                    @grizzelbee
                    Das Problem mit der Temperatur stellt sich wie folgt da, die Anzeige des Datenpunktes ist korrekt, stimmt mit Gerät / App überein.
                    Es sieht so aus als ob ein fester Offset irgendwie verwendet wird,
                    sende ich einen Wert (string)
                    • 250 - Gerät geht auf 4,15°C
                    • 260 - Gerät geht auf 14,15°C
                    • 270 - Gerät geht auf 24,15°C
                    Allerdings scheint der Adapter jetzt doch etwas Stress zu machen, das ist mehr erst aufgefallen seit dem ich das 2. Gerät welches auch heizen kann mit eingebunden habe, hier mal ein LOG, ich kann da leider nicht schlau raus werden:
                    nairpurifier.0
                    2023-07-15 09:51:28.066	debug	C4H-EU-NHB8749A - MQTT message received: {"msg":"CURRENT-FAULTS","time":"2023-07-15T07:51:28.000Z","product-errors":{"amf1":"OK","amf2":"OK","amf3":"OK","amf4":"OK","amf5":"OK","amf6":"OK","amf7":"OK","amf8":"OK","amf9":"OK","com4":"OK","com1":"OK","iuh0":"OK","iup0":"OK","iuw0":"OK","iuh1":"OK","iuu1":"OK","iuc1":"OK","iuw1":"OK","iua1":"OK","iuh2":"OK","iuu2":"OK","iuc2":"OK","iuw2":"OK","iua2":"OK","iuh4":"OK","iuu4":"OK","iuc4":"OK","iuw4":"OK","iua4":"OK","ui01":"OK","ui02":"FAIL","ui03":"OK","uid1":"OK","uid2":"OK","fs01":"OK","fs02":"OK","fs03":"OK","fs04":"OK","fs05":"OK","fs06":"OK","fs07":"OK","fs08":"OK","fs09":"OK","fs0a":"OK","fs0b":"OK","fs0c":"OK","psu1":"OK","psu2":"OK","sen1":"OK","sen2":"OK","sen3":"OK","sen4":"OK","com5":"OK","com2":"OK","com9":"OK","coma":"OK","bosl":"OK","bosr":"OK","etws":"OK","wpmp":"OK","prot":"OK","uled":"OK"},"product-warnings":{"fltr":"OK","tnke":"OK","tnkp":"OK","cldu":"OK","etwd":"OK"},"module-errors":{"szme":"OK","szmw":"OK","szps":"OK","szpe":"OK","szpw":"OK","szed":"OK","lspd":"OK","szpi":"OK","szpp":"OK","szhv":"OK","szbv":"OK","szav":"OK"},"module-warnings":{"srnk":"OK","stac":"OK","strs":"OK","srmi":"OK","srmu":"OK","nwcs":"OK","nwts":"OK","nwps":"OK","nwss":"OK"}}
                    dysonairpurifier.0
                    2023-07-15 09:51:28.066	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [module-warnings] Value:[{"srnk":"OK","stac":"OK","strs":"OK","srmi":"OK","srmu":"OK","nwcs":"OK","nwts":"OK","nwps":"OK","nwss":"OK"}]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.065	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [nwss] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.065	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [nwps] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.065	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [nwts] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.065	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [nwcs] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.065	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [srmu] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.064	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [srmi] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.064	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [strs] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.064	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [stac] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.064	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [srnk] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.063	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [module-errors] Value:[{"szme":"OK","szmw":"OK","szps":"OK","szpe":"OK","szpw":"OK","szed":"OK","lspd":"OK","szpi":"OK","szpp":"OK","szhv":"OK","szbv":"OK","szav":"OK"}]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.063	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [szav] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.063	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [szbv] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.062	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [szhv] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.062	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [szpp] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.062	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [szpi] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.062	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [lspd] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.062	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [szed] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.061	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [szpw] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.061	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [szpe] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.061	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [szps] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.061	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [szmw] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.061	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [szme] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.060	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [product-warnings] Value:[{"fltr":"OK","tnke":"OK","tnkp":"OK","cldu":"OK","etwd":"OK"}]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.060	debug	EVAPORATION_TRAY_OVERFLOW_DETECTED is a bool switch. Current state: [OK] --> returnvalue for further processing: false
                    dysonairpurifier.0
                    2023-07-15 09:51:28.059	debug	CLEAN_CYCLE_OVERDUE is a bool switch. Current state: [OK] --> returnvalue for further processing: false
                    dysonairpurifier.0
                    2023-07-15 09:51:28.057	debug	TANK_UNDETECTED is a bool switch. Current state: [OK] --> returnvalue for further processing: false
                    dysonairpurifier.0
                    2023-07-15 09:51:28.057	debug	TANK_EMPTY is a bool switch. Current state: [OK] --> returnvalue for further processing: false
                    dysonairpurifier.0
                    2023-07-15 09:51:28.057	debug	FILTER_REPLACEMENT is a bool switch. Current state: [OK] --> returnvalue for further processing: false
                    dysonairpurifier.0
                    2023-07-15 09:51:28.056	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [product-errors] Value:[{"amf1":"OK","amf2":"OK","amf3":"OK","amf4":"OK","amf5":"OK","amf6":"OK","amf7":"OK","amf8":"OK","amf9":"OK","com4":"OK","com1":"OK","iuh0":"OK","iup0":"OK","iuw0":"OK","iuh1":"OK","iuu1":"OK","iuc1":"OK","iuw1":"OK","iua1":"OK","iuh2":"OK","iuu2":"OK","iuc2":"OK","iuw2":"OK","iua2":"OK","iuh4":"OK","iuu4":"OK","iuc4":"OK","iuw4":"OK","iua4":"OK","ui01":"OK","ui02":"FAIL","ui03":"OK","uid1":"OK","uid2":"OK","fs01":"OK","fs02":"OK","fs03":"OK","fs04":"OK","fs05":"OK","fs06":"OK","fs07":"OK","fs08":"OK","fs09":"OK","fs0a":"OK","fs0b":"OK","fs0c":"OK","psu1":"OK","psu2":"OK","sen1":"OK","sen2":"OK","sen3":"OK","sen4":"OK","com5":"OK","com2":"OK","com9":"OK","coma":"OK","bosl":"OK","bosr":"OK","etws":"OK","wpmp":"OK","prot":"OK","uled":"OK"}]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.056	debug	UVC_LED is a bool switch. Current state: [OK] --> returnvalue for further processing: false
                    dysonairpurifier.0
                    2023-07-15 09:51:28.056	debug	PUMP_ROTOR is a bool switch. Current state: [OK] --> returnvalue for further processing: false
                    dysonairpurifier.0
                    2023-07-15 09:51:28.056	debug	WATER_PUMP_FAILURE is a bool switch. Current state: [OK] --> returnvalue for further processing: false
                    dysonairpurifier.0
                    2023-07-15 09:51:28.055	debug	EVAPORATION_TRAY_OVERFLOW_EXTENDED is a bool switch. Current state: [OK] --> returnvalue for further processing: false
                    dysonairpurifier.0
                    2023-07-15 09:51:28.055	debug	BARREL_OSCILLATION_RIGHT is a bool switch. Current state: [OK] --> returnvalue for further processing: false
                    dysonairpurifier.0
                    2023-07-15 09:51:28.055	debug	BARREL_OSCILLATION_LEFT is a bool switch. Current state: [OK] --> returnvalue for further processing: false
                    dysonairpurifier.0
                    2023-07-15 09:51:28.055	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [coma] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.055	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [com9] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.055	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [com2] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.054	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [com5] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.054	debug	HUMIDITY_SENSOR is a bool switch. Current state: [OK] --> returnvalue for further processing: false
                    dysonairpurifier.0
                    2023-07-15 09:51:28.054	debug	TEMPERATURE_SENSOR is a bool switch. Current state: [OK] --> returnvalue for further processing: false
                    dysonairpurifier.0
                    2023-07-15 09:51:28.054	debug	GAS_SENSOR is a bool switch. Current state: [OK] --> returnvalue for further processing: false
                    dysonairpurifier.0
                    2023-07-15 09:51:28.054	debug	DUST_SENSOR is a bool switch. Current state: [OK] --> returnvalue for further processing: false
                    dysonairpurifier.0
                    2023-07-15 09:51:28.054	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [psu2] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.053	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [psu1] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.053	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [fs0c] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.053	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [fs0b] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.053	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [fs0a] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.053	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [fs09] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.053	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [fs08] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.052	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [fs07] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.052	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [fs06] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.052	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [fs05] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.052	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [fs04] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.052	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [fs03] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.051	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [fs02] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.051	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [fs01] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.051	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [uid2] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.051	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [uid1] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.051	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [ui03] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.050	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [ui02] Value:[FAIL]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.050	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [ui01] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.050	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [iua4] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.050	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [iuw4] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.050	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [iuc4] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.050	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [iuu4] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.049	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [iuh4] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.049	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [iua2] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.049	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [iuw2] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.049	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [iuc2] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.048	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [iuu2] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.048	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [iuh2] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.048	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [iua1] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.048	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [iuw1] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.048	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [iuc1] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.047	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [iuu1] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.047	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [iuh1] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.047	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [iuw0] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.047	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [iup0] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.047	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [iuh0] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.047	debug	COMMS_AFM is a bool switch. Current state: [OK] --> returnvalue for further processing: false
                    dysonairpurifier.0
                    2023-07-15 09:51:28.046	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [com4] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.046	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [amf9] Value:[OK]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.046	debug	AFM_SW_ERROR is a bool switch. Current state: [OK] --> returnvalue for further processing: false
                    dysonairpurifier.0
                    2023-07-15 09:51:28.046	debug	AFM_OVER_CURRENT is a bool switch. Current state: [OK] --> returnvalue for further processing: false
                    dysonairpurifier.0
                    2023-07-15 09:51:28.046	debug	AFM_SPEED_FDBK is a bool switch. Current state: [OK] --> returnvalue for further processing: false
                    dysonairpurifier.0
                    2023-07-15 09:51:28.046	debug	AFM_START_UP is a bool switch. Current state: [OK] --> returnvalue for further processing: false
                    dysonairpurifier.0
                    2023-07-15 09:51:28.045	debug	AFM_OVER_TEMP is a bool switch. Current state: [OK] --> returnvalue for further processing: false
                    dysonairpurifier.0
                    2023-07-15 09:51:28.045	debug	AFM_UNDER_VOLT is a bool switch. Current state: [OK] --> returnvalue for further processing: false
                    dysonairpurifier.0
                    2023-07-15 09:51:28.045	debug	AFM_OVER_VOLT is a bool switch. Current state: [OK] --> returnvalue for further processing: false
                    dysonairpurifier.0
                    2023-07-15 09:51:28.045	debug	AFM_FOC_DURATION is a bool switch. Current state: [OK] --> returnvalue for further processing: false
                    dysonairpurifier.0
                    2023-07-15 09:51:28.045	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [time] Value:[2023-07-15T07:51:28.000Z]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.044	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [msg] Value:[CURRENT-FAULTS]
                    dysonairpurifier.0
                    2023-07-15 09:51:28.044	debug	MessageType: CURRENT-FAULTS
                    dysonairpurifier.0
                    2023-07-15 09:51:27.992	debug	C4H-EU-NHB8749A - MQTT message received: {"msg":"ENVIRONMENTAL-CURRENT-SENSOR-DATA","time":"2023-07-15T07:51:28.000Z","data":{"tact":"2984","hact":"0053","pm25":"0006","pm10":"0004","va10":"0007","noxl":"0024","p25r":"0007","p10r":"0007","sltm":"OFF"}}
                    dysonairpurifier.0
                    2023-07-15 09:51:27.991	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [time] Value:[2023-07-15T07:51:28.000Z]
                    dysonairpurifier.0
                    2023-07-15 09:51:27.991	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [msg] Value:[ENVIRONMENTAL-CURRENT-SENSOR-DATA]
                    dysonairpurifier.0
                    2023-07-15 09:51:27.991	debug	MessageType: ENVIRONMENTAL-CURRENT-SENSOR-DATA
                    dysonairpurifier.0
                    2023-07-15 09:51:27.949	debug	C4H-EU-NHB8749A - MQTT message received: {"msg":"CURRENT-STATE","time":"2023-07-15T07:51:28.000Z","mode-reason":"NONE","state-reason":"MODE","rssi":"-65","channel":"11","fqhp":"61048","fghp":"48600","product-state":{"fpwr":"ON","auto":"OFF","oscs":"OFF","oson":"OFF","nmod":"OFF","rhtm":"ON","fnst":"FAN","ercd":"31U2","wacd":"NONE","nmdv":"0004","fnsp":"0002","bril":"0002","corf":"ON","cflr":"INV","hflr":"0055","cflt":"NONE","hflt":"GCOM","sltm":"OFF","osal":"0180","osau":"0180","ancp":"0090","hume":"HUMD","haut":"ON","humt":"0030","rect":"0035","msta":"OFF","clcr":"CLNO","cdrr":"0060","cltr":"0395","wath":"0675","psta":"OFF","fdir":"ON"},"scheduler":{"srsc":"0000000061771266","dstv":"0001","tzid":"0001"}}
                    • M mike2712
                      @grizzelbee
                      nairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      dysonairpurifier.0
                      GrizzelbeeG Offline
                      GrizzelbeeG Offline
                      Grizzelbee
                      #184
                      @mike2712
                      Okay. Habe mir das Log gerade einmal angeschaut.
                      Da macht eigentlich nichts Stress. Das sind normale Debug-Log-Ausgaben - wenn auch zugegebenermaßen ziemlich viele. Das ist nur etwas unübersichtlich aber nicht problematisch.
                      Ich habe die beiden schlimmsten "Spammer" mal für die nächste Version auf "Silly" gesetzt - dann wird das wieder besser. ;)
                      Aber wie auch immer.
                      Ich brauche bitte nach wie vor ein Log in dem ich eine Änderung der Temperatur sehen kann.
                      Also bitte einmal: Adapter starten, Temperatur ändern, Adapter stoppen - Log posten.
                        @mike2712
                        mike2712
                        #185
                        @grizzelbee Hier der Log wie beschrieben, normal ist das aber sicherlich nicht, der Adapter startet und stoppt ständig, ich muss ihn leider wieder deaktivieren, in ~ 5 Minuten
                        deutlich über 1000 Einträge, war zuviel um es hier dem Post komplett einzusetzen.
                        ysonairpurifier.0
                        2023-08-02 07:52:06.913	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                        dysonairpurifier.0
                        2023-08-02 07:52:06.912	debug	Plugin sentry destroyed
                        dysonairpurifier.0
                        2023-08-02 07:52:06.911	info	terminating
                        dysonairpurifier.0
                        2023-08-02 07:52:06.910	info	Cleaned up everything...
                        dysonairpurifier.0
                        2023-08-02 07:52:06.910	info	Cleaned up timeout for PT4-EU-PAA2268B.
                        dysonairpurifier.0
                        2023-08-02 07:52:06.909	info	Cleaned up timeout for C4H-EU-NHB8749A.
                        dysonairpurifier.0
                        2023-08-02 07:52:06.908	info	Got terminate signal TERMINATE_YOURSELF
                        dysonairpurifier.0
                        2023-08-02 07:52:01.338	debug	C4H-EU-NHB8749A - MQTT message received: {"msg":"CURRENT-FAULTS","time":"2023-08-02T05:52:02.000Z","product-errors":{"amf1":"OK","amf2":"OK","amf3":"OK","amf4":"OK","amf5":"OK","amf6":"OK","amf7":"OK","amf8":"OK","amf9":"OK","com4":"OK","com1":"OK","iuh0":"OK","iup0":"OK","iuw0":"OK","iuh1":"OK","iuu1":"OK","iuc1":"OK","iuw1":"OK","iua1":"OK","iuh2":"OK","iuu2":"OK","iuc2":"OK","iuw2":"OK","iua2":"OK","iuh4":"OK","iuu4":"OK","iuc4":"OK","iuw4":"OK","iua4":"OK","ui01":"OK","ui02":"FAIL","ui03":"OK","uid1":"OK","uid2":"OK","fs01":"OK","fs02":"OK","fs03":"OK","fs04":"OK","fs05":"OK","fs06":"OK","fs07":"OK","fs08":"OK","fs09":"OK","fs0a":"OK","fs0b":"OK","fs0c":"OK","psu1":"OK","psu2":"OK","sen1":"OK","sen2":"OK","sen3":"OK","sen4":"OK","com5":"OK","com2":"OK","com9":"OK","coma":"OK","bosl":"OK","bosr":"OK","etws":"OK","wpmp":"OK","prot":"OK","uled":"OK"},"product-warnings":{"fltr":"OK","tnke":"OK","tnkp":"OK","cldu":"OK","etwd":"OK"},"module-errors":{"szme":"OK","szmw":"OK","szps":"OK","szpe":"OK","szpw":"OK","szed":"OK","lspd":"OK","szpi":"OK","szpp":"OK","szhv":"OK","szbv":"OK","szav":"OK"},"module-warnings":{"srnk":"OK","stac":"OK","strs":"OK","srmi":"OK","srmu":"OK","nwcs":"OK","nwts":"OK","nwps":"OK","nwss":"OK"}}
                        dysonairpurifier.0
                        2023-08-02 07:52:01.337	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [module-warnings] Value:[{"srnk":"OK","stac":"OK","strs":"OK","srmi":"OK","srmu":"OK","nwcs":"OK","nwts":"OK","nwps":"OK","nwss":"OK"}]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.337	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [nwss] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.337	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [nwps] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.336	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [nwts] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.336	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [nwcs] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.335	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [srmu] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.333	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [srmi] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.333	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [strs] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.333	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [stac] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.332	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [srnk] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.332	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [module-errors] Value:[{"szme":"OK","szmw":"OK","szps":"OK","szpe":"OK","szpw":"OK","szed":"OK","lspd":"OK","szpi":"OK","szpp":"OK","szhv":"OK","szbv":"OK","szav":"OK"}]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.331	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [szav] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.331	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [szbv] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.331	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [szhv] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.331	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [szpp] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.330	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [szpi] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.330	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [lspd] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.330	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [szed] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.330	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [szpw] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.329	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [szpe] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.329	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [szps] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.329	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [szmw] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.329	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [szme] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.329	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [product-warnings] Value:[{"fltr":"OK","tnke":"OK","tnkp":"OK","cldu":"OK","etwd":"OK"}]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.328	debug	EVAPORATION_TRAY_OVERFLOW_DETECTED is a bool switch. Current state: [OK] --> returnvalue for further processing: false
                        dysonairpurifier.0
                        2023-08-02 07:52:01.328	debug	CLEAN_CYCLE_OVERDUE is a bool switch. Current state: [OK] --> returnvalue for further processing: false
                        dysonairpurifier.0
                        2023-08-02 07:52:01.327	debug	TANK_UNDETECTED is a bool switch. Current state: [OK] --> returnvalue for further processing: false
                        dysonairpurifier.0
                        2023-08-02 07:52:01.327	debug	TANK_EMPTY is a bool switch. Current state: [OK] --> returnvalue for further processing: false
                        dysonairpurifier.0
                        2023-08-02 07:52:01.327	debug	FILTER_REPLACEMENT is a bool switch. Current state: [OK] --> returnvalue for further processing: false
                        dysonairpurifier.0
                        2023-08-02 07:52:01.326	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [product-errors] Value:[{"amf1":"OK","amf2":"OK","amf3":"OK","amf4":"OK","amf5":"OK","amf6":"OK","amf7":"OK","amf8":"OK","amf9":"OK","com4":"OK","com1":"OK","iuh0":"OK","iup0":"OK","iuw0":"OK","iuh1":"OK","iuu1":"OK","iuc1":"OK","iuw1":"OK","iua1":"OK","iuh2":"OK","iuu2":"OK","iuc2":"OK","iuw2":"OK","iua2":"OK","iuh4":"OK","iuu4":"OK","iuc4":"OK","iuw4":"OK","iua4":"OK","ui01":"OK","ui02":"FAIL","ui03":"OK","uid1":"OK","uid2":"OK","fs01":"OK","fs02":"OK","fs03":"OK","fs04":"OK","fs05":"OK","fs06":"OK","fs07":"OK","fs08":"OK","fs09":"OK","fs0a":"OK","fs0b":"OK","fs0c":"OK","psu1":"OK","psu2":"OK","sen1":"OK","sen2":"OK","sen3":"OK","sen4":"OK","com5":"OK","com2":"OK","com9":"OK","coma":"OK","bosl":"OK","bosr":"OK","etws":"OK","wpmp":"OK","prot":"OK","uled":"OK"}]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.326	debug	UVC_LED is a bool switch. Current state: [OK] --> returnvalue for further processing: false
                        dysonairpurifier.0
                        2023-08-02 07:52:01.325	debug	PUMP_ROTOR is a bool switch. Current state: [OK] --> returnvalue for further processing: false
                        dysonairpurifier.0
                        2023-08-02 07:52:01.325	debug	WATER_PUMP_FAILURE is a bool switch. Current state: [OK] --> returnvalue for further processing: false
                        dysonairpurifier.0
                        2023-08-02 07:52:01.324	debug	EVAPORATION_TRAY_OVERFLOW_EXTENDED is a bool switch. Current state: [OK] --> returnvalue for further processing: false
                        dysonairpurifier.0
                        2023-08-02 07:52:01.324	debug	BARREL_OSCILLATION_RIGHT is a bool switch. Current state: [OK] --> returnvalue for further processing: false
                        dysonairpurifier.0
                        2023-08-02 07:52:01.324	debug	BARREL_OSCILLATION_LEFT is a bool switch. Current state: [OK] --> returnvalue for further processing: false
                        dysonairpurifier.0
                        2023-08-02 07:52:01.324	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [coma] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.324	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [com9] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.323	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [com2] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.323	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [com5] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.322	debug	HUMIDITY_SENSOR is a bool switch. Current state: [OK] --> returnvalue for further processing: false
                        dysonairpurifier.0
                        2023-08-02 07:52:01.322	debug	TEMPERATURE_SENSOR is a bool switch. Current state: [OK] --> returnvalue for further processing: false
                        dysonairpurifier.0
                        2023-08-02 07:52:01.322	debug	GAS_SENSOR is a bool switch. Current state: [OK] --> returnvalue for further processing: false
                        dysonairpurifier.0
                        2023-08-02 07:52:01.321	debug	DUST_SENSOR is a bool switch. Current state: [OK] --> returnvalue for further processing: false
                        dysonairpurifier.0
                        2023-08-02 07:52:01.321	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [psu2] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.321	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [psu1] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.321	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [fs0c] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.321	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [fs0b] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.320	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [fs0a] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.320	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [fs09] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.319	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [fs08] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.319	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [fs07] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.319	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [fs06] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.319	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [fs05] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.319	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [fs04] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.318	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [fs03] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.318	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [fs02] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.318	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [fs01] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.318	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [uid2] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.317	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [uid1] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.317	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [ui03] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.316	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [ui02] Value:[FAIL]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.316	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [ui01] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.316	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [iua4] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.316	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [iuw4] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.315	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [iuc4] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.315	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [iuu4] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.315	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [iuh4] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.315	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [iua2] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.314	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [iuw2] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.314	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [iuc2] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.313	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [iuu2] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.311	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [iuh2] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.311	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [iua1] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.310	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [iuw1] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.310	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [iuc1] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.310	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [iuu1] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.310	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [iuh1] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.309	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [iuw0] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.309	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [iup0] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.309	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [iuh0] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.308	debug	COMMS_AFM is a bool switch. Current state: [OK] --> returnvalue for further processing: false
                        dysonairpurifier.0
                        2023-08-02 07:52:01.308	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [com4] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.308	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [amf9] Value:[OK]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.307	debug	AFM_SW_ERROR is a bool switch. Current state: [OK] --> returnvalue for further processing: false
                        dysonairpurifier.0
                        2023-08-02 07:52:01.307	debug	AFM_OVER_CURRENT is a bool switch. Current state: [OK] --> returnvalue for further processing: false
                        dysonairpurifier.0
                        2023-08-02 07:52:01.307	debug	AFM_SPEED_FDBK is a bool switch. Current state: [OK] --> returnvalue for further processing: false
                        dysonairpurifier.0
                        2023-08-02 07:52:01.307	debug	AFM_START_UP is a bool switch. Current state: [OK] --> returnvalue for further processing: false
                        dysonairpurifier.0
                        2023-08-02 07:52:01.306	debug	AFM_OVER_TEMP is a bool switch. Current state: [OK] --> returnvalue for further processing: false
                        dysonairpurifier.0
                        2023-08-02 07:52:01.306	debug	AFM_UNDER_VOLT is a bool switch. Current state: [OK] --> returnvalue for further processing: false
                        dysonairpurifier.0
                        2023-08-02 07:52:01.305	debug	AFM_OVER_VOLT is a bool switch. Current state: [OK] --> returnvalue for further processing: false
                        dysonairpurifier.0
                        2023-08-02 07:52:01.305	debug	AFM_FOC_DURATION is a bool switch. Current state: [OK] --> returnvalue for further processing: false
                        dysonairpurifier.0
                        2023-08-02 07:52:01.305	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [time] Value:[2023-08-02T05:52:02.000Z]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.305	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [msg] Value:[CURRENT-FAULTS]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.304	debug	MessageType: CURRENT-FAULTS
                        dysonairpurifier.0
                        2023-08-02 07:52:01.253	debug	C4H-EU-NHB8749A - MQTT message received: {"msg":"ENVIRONMENTAL-CURRENT-SENSOR-DATA","time":"2023-08-02T05:52:02.000Z","data":{"tact":"2945","hact":"0064","pm25":"0024","pm10":"0017","va10":"0011","noxl":"0019","p25r":"0023","p10r":"0025","sltm":"OFF"}}
                        dysonairpurifier.0
                        2023-08-02 07:52:01.252	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [time] Value:[2023-08-02T05:52:02.000Z]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.252	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [msg] Value:[ENVIRONMENTAL-CURRENT-SENSOR-DATA]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.251	debug	MessageType: ENVIRONMENTAL-CURRENT-SENSOR-DATA
                        dysonairpurifier.0
                        2023-08-02 07:52:01.211	debug	C4H-EU-NHB8749A - MQTT message received: {"msg":"CURRENT-STATE","time":"2023-08-02T05:52:02.000Z","mode-reason":"LSCH","state-reason":"MODE","rssi":"-62","channel":"11","fqhp":"89936","fghp":"81872","product-state":{"fpwr":"ON","auto":"ON","oscs":"OFF","oson":"OFF","nmod":"OFF","rhtm":"ON","fnst":"FAN","ercd":"31U2","wacd":"NONE","nmdv":"0004","fnsp":"AUTO","bril":"0002","corf":"ON","cflr":"INV","hflr":"0046","cflt":"NONE","hflt":"GCOM","sltm":"OFF","osal":"0180","osau":"0180","ancp":"0090","hume":"HUMD","haut":"ON","humt":"0030","rect":"0045","msta":"OFF","clcr":"CLNO","cdrr":"0060","cltr":"0395","wath":"0675","psta":"CLNG","fdir":"ON"},"scheduler":{"srsc":"0000000061771266","dstv":"0001","tzid":"0001"}}
                        dysonairpurifier.0
                        2023-08-02 07:52:01.211	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [psta] Value:[CLNG]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.209	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [bril] Value:[0002]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.207	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [fghp] Value:[81872]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.207	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [fqhp] Value:[89936]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.207	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [state-reason] Value:[MODE]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.206	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [mode-reason] Value:[LSCH]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.206	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [time] Value:[2023-08-02T05:52:02.000Z]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.205	debug	Skipped creating unknown data field for Device:[C4H-EU-NHB8749A], Field: [msg] Value:[CURRENT-STATE]
                        dysonairpurifier.0
                        2023-08-02 07:52:01.205	debug	MessageType: CURRENT-STATE
                        dysonairpurifier.0
                        2023-08-02 07:52:01.097	debug	Updating device [C4H-EU-NHB8749A] (polling API scheduled).
                        • M mike2712
                          ysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          dysonairpurifier.0
                          GrizzelbeeG Offline
                          GrizzelbeeG Offline
                          Grizzelbee
                          #186
                          Das liegt im Auge des Betrachters. Das sind ja keine "normalen" Info Meldungen, sondern Debug Ausgaben. Da entscheidet der Entwickler was er braucht und was nicht. Aber wie dem auch sei - ab der nächsten Version wird es ja wieder weniger.
                          Wenn er ständig startet und stoppt liegt ein größeres Problem vor - das sollte als Error Meldung im Log auftauchen. Guck da bitte mal nach.
                          in ~ 5 Minuten> deutlich über 1000 Einträge, war zuviel um es hier dem Post komplett einzusetzen.
                          Soweit ich weiß kann man hier auch Dateien hochladen. Das Problem ist nämlich, das ich auch hier wieder nichts sehe, was mit dem Schalten der Temperatur zusammen hängt.
                          Neue Idee: Wenn Du den Poll-Intervall auf 5 Minuten stellst, kommt logischerweise nicht so viel Spam. Dann sollte das übersichtlicher werden. Ansonsten schau mal nach dem Dateiupload. Dann kannst Du alles in eine Textdatei packen und die hier posten.
                          M 2 Antworten Letzte Antwort
                            mike2712
                            #187
                            @grizzelbee die maximale Dateigröße ist 5120 kb, das log file von heute hat 6460 kb.
                            Das komische ist das keine Fehlermeldungen gekommen sind, ich versuche das noch mal mit dem Intervall auf 5 Minuten.
                            Der Adapter ist ständig neu gestart,der Status war wechselnd grün/rot.
                              mike2712
                              #188
                              @grizzelbee
                              so log komplett gelöscht, Adapter auf 5 Minuten gestellt, den Wert für Temperatur auf 400 geändert - > Ergebnis was angekommen ist waren 37.05 °C.
                              Trotz der 5 Minuten kommen Meldungen ohne Ende reingeflogen.
                              iobroker.2023-08-02.log.html
                              2023-08-02 16:24:57.406 - debug: dysonairpurifier.0 (1029) MANUAL CHANGE: device [PT4-EU-PAA2268B] -> [TemperatureTarget] -> [400
                              Das sind offensichtlich die Meldungen wenn der Adapter kurz stoppt, der Adapter war kurz rot oder gelb?
                              dysonairpurifier.0
                              2023-08-02 16:36:50.762 info Starting Polltimer with a 300 seconds interval.
                              dysonairpurifier.0
                              2023-08-02 16:36:50.761 info PT4-EU-PAA2268B - MQTT connection established.
                              dysonairpurifier.0
                              2023-08-02 16:36:49.705 info PT4-EU-PAA2268B - MQTT offline.
                              Nach nur wenigen Minuten ist die Log Datei erneut auf 2235 kb angestiegen, gefühlt 95 % vom Dyson Adapter.
                              Ich bekomme die LOGS leider nicht nach Excel, weiß nicht wie man damit anderweitig vernünftig weiterarbeiten kann.
                              iobroker.2023-08-02-1.log
                              • M mike2712
                                @grizzelbee
                                dysonairpurifier.0
                                dysonairpurifier.0
                                dysonairpurifier.0
                                GrizzelbeeG Offline
                                GrizzelbeeG Offline
                                Grizzelbee
                                #189
                                @mike2712
                                Das html Log ist schon soweit okay. Kein Ding.
                                Ein Tipp vielleicht noch dazu: Das Log kann man über die Header auch Filtern:
                                Bei "Nachricht" kann sogar Text frei eingegeben werden.
                                Zum eigentlichen Thema:
                                2023-08-02 16:24:57.403 - debug: dysonairpurifier.0 (1029) onStateChange: Using dysonAction: [hmax]
                                ], id: [dysonairpurifier.0.PT4-EU-PAA2268B.TemperatureTarget]
                                2023-08-02 16:24:57.406 - debug: dysonairpurifier.0 (1029) SENDING this data to device (PT4-EU-PAA2268B): {"msg":"STATE-SET","time":"2023-08-02T14:24:57.405Z","mode-reason":"LAPP","state-reason":"MODE","data":{"hmax":"4273"}}
                                2023-08-02 16:24:57.508 - debug: dysonairpurifier.0 (1029) requesting new state of device (PT4-EU-PAA2268B).
                                2023-08-02 16:24:57.838 - debug: dysonairpurifier.0 (1029) MessageType: CURRENT-STATE
                                2023-08-02 16:24:57.845 - debug: dysonairpurifier.0 (1029) PT4-EU-PAA2268B - MQTT message received: {"msg":"CURRENT-STATE","time":"2023-08-02T14:24:58.000Z","mode-reason":"LAPP","state-reason":"MODE","dial":"OFF","rssi":"-58","product-state":{"fmod":"FAN","fnst":"OFF","fnsp":"0004","qtar":"0003","oson":"OFF","rhtm":"ON","filf":"4272","ercd":"NONE","nmod":"OFF","wacd":"NONE","hmod":"HEAT","hmax":"3102","hsta":"OFF","ffoc":"ON","tilt":"OK"},"scheduler":{"srsc":"6f74","dstv":"0001","tzid":"0001"}}
                                2023-08-02 16:24:57.936 - debug: dysonairpurifier.0 (1029) MessageType: CURRENT-STATE
                                2023-08-02 16:24:57.946 - debug: dysonairpurifier.0 (1029) PT4-EU-PAA2268B - MQTT message received: {"msg":"CURRENT-STATE","time":"2023-08-02T14:24:58.001Z","mode-reason":"LAPP","state-reason":"MODE","dial":"OFF","rssi":"-58","product-state":{"fmod":"FAN","fnst":"OFF","fnsp":"0004","qtar":"0003","oson":"OFF","rhtm":"ON","filf":"4272","ercd":"NONE","nmod":"OFF","wacd":"NONE","hmod":"HEAT","hmax":"3102","hsta":"OFF","ffoc":"ON","tilt":"OK"},"scheduler":{"srsc":"6f74","dstv":"0001","tzid":"0001"}}
                                2023-08-02 16:24:58.044 - debug: dysonairpurifier.0 (1029) MessageType: ENVIRONMENTAL-CURRENT-SENSOR-DATA
                                2023-08-02 16:24:58.053 - debug: dysonairpurifier.0 (1029) PT4-EU-PAA2268B - MQTT message received: {"msg":"ENVIRONMENTAL-CURRENT-SENSOR-DATA","time":"2023-08-02T14:24:58.002Z","data":{"tact":"2978","hact":"0056","pact":"0002","vact":"INIT","sltm":"OFF"}}
                                2023-08-02 16:24:58.239 - debug: dysonairpurifier.0 (1029) MessageType: STATE-CHANGE
                                2023-08-02 16:24:58.241 - debug: dysonairpurifier.0 (1029) Values for [FanMode] are equal. No update required. Skipping.
                                2023-08-02 16:24:58.241 - debug: dysonairpurifier.0 (1029) Value is an object. Converting to value: ["FAN"] --> [FAN]
                                2023-08-02 16:24:58.242 - debug: dysonairpurifier.0 (1029) Values for [AirQualityTarget] are equal. No update required. Skipping.
                                2023-08-02 16:24:58.243 - debug: dysonairpurifier.0 (1029) Values for [LastErrorCode] are equal. No update required. Skipping.
                                2023-08-02 16:24:58.244 - debug: dysonairpurifier.0 (1029) Values for [LastWarningCode] are equal. No update required. Skipping.
                                2023-08-02 16:24:58.245 - debug: dysonairpurifier.0 (1029) Value is an object. Converting to value: ["HEAT"] --> [HEAT]
                                2023-08-02 16:24:58.249 - debug: dysonairpurifier.0 (1029) PT4-EU-PAA2268B - MQTT message received: {"msg":"STATE-CHANGE","time":"2023-08-02T14:24:58.003Z","mode-reason":"LAPP","state-reason":"MODE","product-state":{"fmod":["FAN","FAN"],"fnst":["OFF","FAN"],"fnsp":["0004","0004"],"qtar":["0003","0003"],"oson":["OFF","OFF"],"rhtm":["ON","ON"],"filf":["4272","4272"],"ercd":["NONE","NONE"],"nmod":["OFF","OFF"],"wacd":["NONE","NONE"],"hmod":["HEAT","HEAT"],"hmax":["3102","3102"],"hsta":["OFF","HEAT"],"ffoc":["ON","ON"],"tilt":["OK","OK"]},"scheduler":{"srsc":"6f74","dstv":"0001","tzid":"0001"}}
                                Das ist im Grunde der Teil, um den es gerade wirklich geht.
                                Manual Change ist, wie Du richtige erkannt hast, deine manuelle Änderung des Datenpunktes.
                                Und "SENDING this data to device (PT4-EU-PAA2268B): {"msg":"STATE-SET","time":"2023-08-02T14:24:57.405Z","mode-reason":"LAPP","state-reason":"MODE","data":{"hmax":"4273"}}" zeigt das was genau an das Gerät gesendet wird.
                                Hier wird hmax (400°C) in Kelvin umgerechnet - und da liegt offensichtlich schon ein Fehler vor. Den fixe ich mal als erstes und dann testen wir am besten mit der nächsten Version weiter.
                                Aber eine Frage dazu: Warum versuchst Du den Lüfter auf 400°C zu stellen? Ich gehe mal davon aus, das der gar nicht so heiß werden kann und die Firmware des dyson aus Sicherheitsgründen massiv runterregelt - das würde das beobachtete Verhalten erklären.
                                Gib doch bitte mal einen sinnvollen Wert (am besten etwas was Du auch über die App oder die Fernbedienung einstellen kannst) ein - und dann sehen wir was dann passiert.
                                  mike2712
                                  #190
                                  @grizzelbee
                                  Die 400 sind totaler quatsch, aber den Test hatte ich ja zuvor schon mal gemacht:
                                  Werte die ich gesendet habe, schicke ich relaistische Temperaturwerte von 20-30, dann kommt immer 0.45°C.
                                  Das ist aber meines erachtens keine Umrechnung auf Kelvin, da würde ja der Wert 273,15 als Offset vorliegen.
                                  Es liegt ein fester Offset von 245,85 vor, warum auch immer.
                                  Zu Deinem Tipp
                                  danke, das mit dem Filtern kenne ich, aber wenn ich den Log aufmache habe ich doch nie den ganzen Log im Fenster, das ist irgendwie immer nur ein sehr kleiner Teil, kann ich dort direkt auch Logs laden?
                                  • M mike2712
                                    @grizzelbee
                                    Zu Deinem Tipp
                                    GrizzelbeeG Offline
                                    GrizzelbeeG Offline
                                    Grizzelbee
                                    #191
                                    @mike2712
                                    Da waren tatsächlich Bugs in der Berechnung. Habe gerade die V2.5.8 im Beta Repo hochgeladen. Bitte teste die mal, ob die jetzt richtig funktioniert. Richtig rechnen tut sie zumindest jetzt.
                                    Ach ja: Der dyson erwartet immer vierstellige Werte; deshalb multipliziere ich das Ergebnis der Umrechnung mit 10 um die erste Nachkommastelle mitzunehmen.
                                    Mal sehen was jetzt passiert.
                                      mike2712
                                      #192
                                      @grizzelbee werde es versuchen zeitnah zu testen, aktuell ziemlich im Stress und größtenteils ausserhalb, melde mich. Danke
                                        @mike2712
                                        mike2712
                                        #193
                                        @grizzelbee Top, das sieht nach dem ersten testen jetzt gut aus, vielen Dank
                                          Moin Zusammen,
                                          ich habe einen neuen Adapter für die verschiedenen dyson Lüfter (pure Cool, Hot & Cool, Humidifyer ...) geschrieben.
                                          Aktuell noch rein auf Github - ist halt der erste Wurf.
                                          https://github.com/Grizzelbee/iobroker.dysonairpurifier
                                          Das Auslesen der Geräte sollte soweit funktionieren - ein paar Details sind aber noch offen und es sind noch nicht alle Datenfelder der Geräte komplett gedeutet. Steuern funktioniert allerdings noch nicht - das habe ich für eine der nächsten Versionen auf dem Plan.
                                          Ich suche jetzt also Leute, die Bock haben sich da ein bisschen einzubringen. Da ich selber "nur" einen 2018er pure Cool Tower [TP04] habe, kann ich noch nichts über die Funktionsfähigkeit auf anderen Geräten sagen. Aufgrund der verfügbaren Quellen darf ich aber davon ausgehen, dass die anderen Geräte das eine oder andere Lebenszeichen von sich geben sollte. Die Tests und Datenfelder interessieren mich natürlich um die die Unterstützung auszubauen und auch ob mehrere Geräte sauber unterstützt werden.
                                          Kurzum: Ich bin an jedem Feedback interessiert.
                                          Viele Grüße
                                          Grizzelbee
                                          FabioF Offline
                                          FabioF Offline
                                          Fabio
                                          #194
                                          @grizzelbee ich danke dir herzlich für die neue Version 2.5.9 👍
                                          Iobroker:
