  4. [Fehler] RegExp Range out of order in character class
    2.1k
    4.0k
11 Beiträge 4 Kommentatoren 1.3k Aufrufe
  • hg6806H Offline
    hg6806H Offline
    hg6806
    Ja, irgendwie ist mein System gecrashed, da dachte ich das liegt an einer korrupten SD Karte.
    Also, Backup neu aufgespielt und wieder uPnP installiert und konfiguriert und wieder gecrashed.
    D.h. Admin läuft aber kein VIS. Hier die Fehlermeldung:
    host.ioBroker-Pi3	2017-10-22 09:23:25.510	error	instance system.adapter.web.0 terminated with code 0 (OK)
    Caught	2017-10-22 09:23:25.509	error	by controller[0]: at process._tickCallback (internal/process/next_tick.js:104:9)
    Caught	2017-10-22 09:23:25.509	error	by controller[0]: at _combinedTickCallback (internal/process/next_tick.js:73:7)
    Caught	2017-10-22 09:23:25.509	error	by controller[0]: at /opt/iobroker/node_modules/iobroker.web/node_modules/socket.io/lib/socket.js:503:12
    Caught	2017-10-22 09:23:25.509	error	by controller[0]: at Socket.emit (events.js:191:7)
    Caught	2017-10-22 09:23:25.508	error	by controller[0]: at emitTwo (events.js:106:13)
    Caught	2017-10-22 09:23:25.508	error	by controller[0]: at Socket. (/opt/iobroker/node_modules/iobroker.web/node_modules/iobroker.socketio/lib/socket.js:943:25)
    Caught	2017-10-22 09:23:25.508	error	by controller[0]: at subscribe (/opt/iobroker/node_modules/iobroker.web/node_modules/iobroker.socketio/lib/socket.js:285:42)
    Caught	2017-10-22 09:23:25.507	error	by controller[0]: at RegExp (native)
    Caught	2017-10-22 09:23:25.506	error	by controller[0]: SyntaxError: Invalid regular expression: /upnp\.0\.DENON:[AVR-3311]\.MediaRenderer\.Alive/: Range out of order in character class
    web.0	2017-10-22 09:23:25.422	info	terminating
    web.0	2017-10-22 09:23:25.390	info	terminated http server on port 8082
    web.0	2017-10-22 09:23:25.388	info	terminating http server on port 8082
    web.0	2017-10-22 09:23:25.385	error	at process._tickCallback (internal/process/next_tick.js:104:9)
    web.0	2017-10-22 09:23:25.385	error	at _combinedTickCallback (internal/process/next_tick.js:73:7)
    web.0	2017-10-22 09:23:25.385	error	at /opt/iobroker/node_modules/iobroker.web/node_modules/socket.io/lib/socket.js:503:12
    web.0	2017-10-22 09:23:25.385	error	at Socket.emit (events.js:191:7)
    web.0	2017-10-22 09:23:25.385	error	at emitTwo (events.js:106:13)
    web.0	2017-10-22 09:23:25.385	error	at Socket. (/opt/iobroker/node_modules/iobroker.web/node_modules/iobroker.socketio/lib/socket.js:943:25)
    web.0	2017-10-22 09:23:25.385	error	at subscribe (/opt/iobroker/node_modules/iobroker.web/node_modules/iobroker.socketio/lib/socket.js:285:42)
    web.0	2017-10-22 09:23:25.385	error	at RegExp (native)
    web.0	2017-10-22 09:23:25.385	error	SyntaxError: Invalid regular expression: /upnp\.0\.DENON:[AVR-3311]\.MediaRenderer\.Alive/: Range out of order in character class
    web.0	2017-10-22 09:23:25.384	error	uncaught exception: Invalid regular expression: /upnp\.0\.DENON:[AVR-3311]\.MediaRenderer\.Alive/: Range out of order in character class
    Vielleicht kann jemand etwas damit anfangen.
    Habe den Adapter gestoppt, auch das Script und neu gebootet, Fehler bleibt bestehen.
    • AlCalzoneA Offline
      AlCalzoneA Offline
      AlCalzone
      @hg6806:
      /upnp.0.DENON:[AVR-3311].MediaRenderer.Alive/: Range out of order in character class `
      Da hat der Entwickler vergessen, die eckigen Klammern zu escapen.
      • hg6806H Offline
        hg6806H Offline
        hg6806
        ? was meinst du damit?
        • Jey CeeJ Online
          Jey CeeJ Online
          Jey Cee
          @AlCalzone:
          @hg6806:
          /upnp.0.DENON:[AVR-3311].MediaRenderer.Alive/: Range out of order in character class Da hat der Entwickler vergessen, die eckigen Klammern zu escapen.
          Ja das dachte ich mir auch, leider weiss ich nicht wo.
          Aber was mich irritiert:
          @hg6806:
          Habe den Adapter gestoppt, auch das Script und neu gebootet, Fehler bleibt bestehen. `
          Und was noch merkwürdig ist, ich selbst hab ebenfalls ein Gerät wo im Namen Eckige Klammern vorkommen und hatte das Problem noch nie.
          @hg6806: Kannst du bitte mal den Log level des Adapters auf "debug" stellen und das log bereit stellen. Dann finde ich hoffentlich die stelle an der es hackt.
          Persönlicher Support
          Spenden -> paypal.me/J3YC33
            AlCalzoneA Offline
            AlCalzone
            @Jey Cee:
            Ja das dachte ich mir auch, leider weiss ich nicht wo. `
            Na, die eckigen Klammern ;)
            falsch: /upnp\.0\.DENON:[AVR-3311]\.MediaRenderer\.Alive/
            richtig: /upnp\.0\.DENON:\[AVR-3311\]\.MediaRenderer\.Alive/
            Oder um ganz sicher zu gehen:
            /upnp\.0\.DENON\:\[AVR\-3311\]\.MediaRenderer\.Alive/
            • Jey CeeJ Online
              Jey CeeJ Online
              Jey Cee
              :roll: das war mir schon klar, nur wo in dem Code des Adapters das Problem sitzt.
              Im Code des Adapters baue ich nirgendwo eine solche RegExp zusammen.
                AlCalzoneA Offline
                AlCalzone
                Mögliche Zeilen:
                https://github.com/Jey-Cee/ioBroker.upn … n.js#L1597
                https://github.com/Jey-Cee/ioBroker.upn ... n.js#L1340
                https://github.com/Jey-Cee/ioBroker.upn ... n.js#L1650
                • BluefoxB Offline
                  BluefoxB Offline
                  @AlCalzone:
                  @hg6806:
                  Habe es gemacht jetzt:
                  https://github.com/ioBroker/ioBroker.so … 48824eL266
                  • hg6806H Offline
                    hg6806H Offline
                    hg6806
                    So, System neu aufgesetzt. Lag dann wohl doch nicht an der SD Karte, wobei ich das Thema auch mal angehen werde.
                    Wo liegt denn jetzt der Fehler an mir oder dem Adapter?
                    Der Log Level stand auf Debug. Mehr habe ich leider nicht mehr :-(
                    • BluefoxB Offline
                      BluefoxB Offline
                      @hg6806:
                      Der Log Level stand auf Debug. Mehr habe ich leider nicht mehr :-( `
                      Mach mal:
                      cd /opt/iobroker/node_modules/iobroker.web
                      npm i iobroker.socketio@1.8.5 --production
                      cd /opt/iobroker
                      iobroker restart web
                      • hg6806H Offline
                        hg6806H Offline
                        hg6806
                        Erledigt, socket IO Adapter steht im Admin komischerweise trotz Aktualisierung noch immer auf 1.8.3
