  4. (gelöst) Beim öffnen der GUI vermehrt Timeouts.
    6.7k
21 Beiträge 5 Kommentatoren 3.6k Aufrufe 5 Beobachtet
    @esp8266
    Hier in CodeTags eingebettet reinkopieren.
    ESP8266E Offline
    ESP8266E Offline
    ESP8266
    @thomas-braun ,als doch ohne.
    *** ioBroker Diagnosis ***
    Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
    The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
    https://forum.iobroker.net
    Just copy and paste the Summary Page, including the ``` characters at start and end.
    It helps us to help you!
    Press any key to continue
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model		: Raspberry Pi 4 Model B Rev 1.2
    Architecture    : aarch64
    Docker          : false
    Virtualization  : none
    Distributor ID:	Raspbian
    Description:	Raspbian GNU/Linux 11 (bullseye)
    Release:	11
    Codename:	bullseye
    PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
     13:03:30 up  1:35,  3 users,  load average: 3.08, 3.09, 2.72
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=43.8'C
    volt=0.8438V
    *** Time and Time Zones ***
                   Local time: Mon 2023-07-31 13:03:30 CEST
               Universal time: Mon 2023-07-31 11:03:30 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server: 	true
    Desktop:
    Terminal: 	tty
    Boot Target: 	graphical.target
    *** MEMORY ***
    Mem:            3.7G        2.2G        269M         35M        1.3G        1.4G
    Swap:            99M          0B         99M
    Total:          3.8G        2.2G        369M
             3743 M total memory
             2189 M used memory
             2407 M active memory
              644 M inactive memory
              269 M free memory
              139 M buffer memory
             1145 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4      110G  6.0G  101G   6% /
    devtmpfs       devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     1.9G   24K  1.9G   1% /dev/shm
    tmpfs          tmpfs     749M  1.3M  748M   1% /run
    /dev/sda1      vfat      255M   51M  205M  20% /boot
    tmpfs          tmpfs     375M   20K  375M   1% /run/user/1000
    [Mon Jul 31 11:27:49 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:8B:67:E3 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=7df941dc-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Mon Jul 31 11:27:52 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Mon Jul 31 11:27:52 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Mon Jul 31 11:27:54 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
    [Mon Jul 31 11:27:59 2023] EXT4-fs (sda2): resizing filesystem from 1420632 to 29240320 blocks
    [Mon Jul 31 11:28:02 2023] EXT4-fs (sda2): resized filesystem to 29240320
    TARGET  SOURCE    FSTYPE OPTIONS
    /       /dev/sda2 ext4   rw,noatime
    `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    524M	/var/
    182M	/var/log
    177M	/var/log/journal/7c7da7cd88a44588896e76ac0de90413
    125M	/var/lib
    Archived and active journals take up 176.0M in the file system.
    /opt/iobroker/backups:
    4.0K	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    493M	/opt/iobroker/iobroker-data/
    452M	/opt/iobroker/iobroker-data/files
    88M	/opt/iobroker/iobroker-data/files/echarts.admin
    57M	/opt/iobroker/iobroker-data/files/echarts
    51M	/opt/iobroker/iobroker-data/files/javascript.admin
    33M	/opt/iobroker/iobroker-data/objects.jsonl
    33M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    23M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
    23M	/opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
    23M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.eb0afecd.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v18.17.0
    /usr/bin/node 		v18.17.0
    /usr/bin/npm 		9.6.7
    /usr/bin/npx 		9.6.7
    nodejs:
      Installed: 18.17.0-deb-1nodesource1
      Candidate: 18.17.0-deb-1nodesource1
      Version table:
     *** 18.17.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
         12.22.12~dfsg-1~deb11u4 500
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller: 	5.0.11
    admin: 		6.6.4
    javascript: 	7.1.1
    Adapters from github: 	5
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, compact disabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled, compact disabled
    + system.adapter.apsystems-ecu.0          : apsystems-ecu         : iobroker                                 -  enabled, compact disabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled, compact disabled
    + system.adapter.backitup.1               : backitup              : iobroker                                 -  enabled, compact disabled
    + system.adapter.broadlink2.0             : broadlink2            : iobroker                                 -  enabled
      system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled, compact disabled
    + system.adapter.denon.0                  : denon                 : iobroker                                 -  enabled, compact disabled
      system.adapter.device-reminder.0        : device-reminder       : iobroker                                 - disabled, compact disabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled, compact disabled
      system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled, compact disabled
    + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled, compact disabled
    + system.adapter.enigma2.0                : enigma2               : iobroker                                 -  enabled
    + system.adapter.fakeroku.0               : fakeroku              : iobroker                                 -  enabled
      system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled, compact disabled
      system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
    + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled, compact enabled (group 1)
    + system.adapter.g-homa.0                 : g-homa                : iobroker                                 -  enabled, compact disabled
    + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled, compact disabled
    + system.adapter.heizoel.0                : heizoel               : iobroker                                 -  enabled, compact disabled
    + system.adapter.history.0                : history               : iobroker                                 -  enabled, compact disabled
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled, compact disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 - disabled
    + system.adapter.info.0                   : info                  : iobroker                                 -  enabled, compact disabled
    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled, compact disabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled, compact disabled
    + system.adapter.kodi.0                   : kodi                  : iobroker                                 -  enabled, compact enabled (group 1), port: 9090
    + system.adapter.maxcul.0                 : maxcul                : iobroker                                 -  enabled, compact disabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, compact disabled, port: 1884, bind: 192.168.62.15
    + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, compact disabled, port: 1888, bind: 0.0.0.0
    + system.adapter.octoprint.0              : octoprint             : iobroker                                 -  enabled, compact disabled
    + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled, compact disabled
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, compact disabled, port: 1884, bind: 192.168.62.15
    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, compact disabled, port: 1883, bind: 192.168.62.15
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, compact disabled, port: 8443, bind: 0.0.0.0
    + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled, compact disabled
    + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled, compact disabled
    + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled, compact disabled
      system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled, compact disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled, compact disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled, compact disabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
      system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker                                 - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
      system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled, compact disabled
    + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, compact disabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.withings.0               : withings              : iobroker                                 -  enabled, compact disabled
      system.adapter.wled.0                   : wled                  : iobroker                                 - disabled, compact disabled
    + system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled, compact disabled
    + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, compact disabled, port: /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): beta
    Installed ioBroker-Instances
    Used repository: beta
    Adapter    "admin"        : 6.6.4    , installed 6.6.4
    Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
    Adapter    "backitup"     : 2.6.23   , installed 2.6.23
    Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
    Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
    Adapter    "denon"        : 1.15.3   , installed 1.15.3
    Adapter    "device-reminder": 1.2.9  , installed 1.2.9
    Adapter    "discovery"    : 3.2.0    , installed 3.2.0
    Adapter    "echarts"      : 1.5.1    , installed 1.5.1
    Adapter    "enigma2"      : 1.5.0    , installed 1.5.0
    Adapter    "fakeroku"     : 0.2.2    , installed 0.2.2
    Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
    Adapter    "g-homa"       : 0.5.3    , installed 0.5.3
    Adapter    "harmony"      : 1.2.2    , installed 1.2.2
    Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
    Adapter    "history"      : 2.2.4    , installed 2.2.4
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "javascript"   : 7.1.1    , installed 7.1.1
    Controller "js-controller": 5.0.11   , installed 5.0.11
    Adapter    "kodi"         : 2.0.9    , installed 2.0.9
    Adapter    "maxcul"       : 1.3.1    , installed 1.3.1
    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
    Adapter    "octoprint"    : 5.0.1    , installed 5.0.1
    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
    Adapter    "socketio"     : 6.4.0    , installed 6.4.0
    Adapter    "sonoff"       : 2.5.7    , installed 2.5.7
    Adapter    "telegram"     : 1.16.0   , installed 1.16.0
    Adapter    "text2command" : 3.0.2    , installed 3.0.2
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "tuya"         : 3.14.2   , installed 3.14.2
    Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "web"          : 6.0.3    , installed 6.0.3
    Adapter    "withings"     : 0.0.13   , installed 0.0.13
    Adapter    "wled"         : 0.7.0    , installed 0.7.0
    Adapter    "ws"           : 2.4.0    , installed 2.4.0
    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
    Adapter    "zigbee"       : 1.8.18   , installed 1.8.18
    Objects and States
    Objects: 	14839
    States: 	12289
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 https://deb.nodesource.com/node_18.x bullseye InRelease
    Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:8888            0.0.0.0:*               LISTEN      0          845        629/ebusd
    tcp        0      0 0.0.0.0:37509           0.0.0.0:*               LISTEN      1001       94812      18232/io.yahka.0
    tcp        0      0 192.168.62.15:1885      0.0.0.0:*               LISTEN      1001       83890      16433/io.mqtt.0
    tcp        0      0 192.168.62.15:1884      0.0.0.0:*               LISTEN      1001       83889      16433/io.mqtt.0
    tcp        0      0 192.168.62.15:1883      0.0.0.0:*               LISTEN      1001       85303      16566/io.sonoff.0
    tcp        0      0 0.0.0.0:8765            0.0.0.0:*               LISTEN      116        106820     19527/python3
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15826      651/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          51895      1/init
    tcp        0      0 127.0.0.1:7999          0.0.0.0:*               LISTEN      116        106799     19542/motion
    tcp        0      0 192.168.62.15:9095      0.0.0.0:*               LISTEN      1001       83597      16159/io.fakeroku.0
    tcp        0      0 192.168.62.15:9094      0.0.0.0:*               LISTEN      1001       83596      16159/io.fakeroku.0
    tcp        0      0 192.168.62.15:9093      0.0.0.0:*               LISTEN      1001       83595      16159/io.fakeroku.0
    tcp        0      0 0.0.0.0:54805           0.0.0.0:*               LISTEN      106        53321      9137/rpc.statd
    tcp        0      0 0.0.0.0:8011            0.0.0.0:*               LISTEN      116        106798     19542/motion
    tcp        0      0 0.0.0.0:8010            0.0.0.0:*               LISTEN      116        106797     19542/motion
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          17282      1294/cupsd
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       53241      9687/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       55128      9687/iobroker.js-co
    tcp6       0      0 :::61991                :::*                    LISTEN      1001       83659      16231/io.harmony.0
    tcp6       0      0 :::54263                :::*                    LISTEN      106        53325      9137/rpc.statd
    tcp6       0      0 :::50000                :::*                    LISTEN      1001       81744      16217/io.g-homa.0
    tcp6       0      0 :::21                   :::*                    LISTEN      0          15721      615/vsftpd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          15828      651/sshd: /usr/sbin
    tcp6       0      0 :::111                  :::*                    LISTEN      0          51901      1/init
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          17281      1294/cupsd
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       99362      18529/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       86980      17138/io.web.0
    udp        0      0 0.0.0.0:53148           0.0.0.0:*                           1001       84378      16042/io.broadlink2
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15104      531/dhcpcd
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          51897      1/init
    udp        0      0 0.0.0.0:57555           0.0.0.0:*                           1001       81474      16042/io.broadlink2
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       85726      16792/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       85727      16792/io.tuya.0
    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       83660      16231/io.harmony.0
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          18802      1295/cups-browsed
    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       84373      16042/io.broadlink2
    udp        0      0 127.0.0.1:833           0.0.0.0:*                           0          53314      9137/rpc.statd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       94817      18232/io.yahka.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       94816      18232/io.yahka.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15657      447/avahi-daemon: r
    udp        0      0 0.0.0.0:46393           0.0.0.0:*                           106        53319      9137/rpc.statd
    udp        0      0 0.0.0.0:58847           0.0.0.0:*                           108        15659      447/avahi-daemon: r
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       85301      16530/io.shelly.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       83598      16159/io.fakeroku.0
    udp6       0      0 :::111                  :::*                                0          51905      1/init
    udp6       0      0 :::44227                :::*                                108        15660      447/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        15658      447/avahi-daemon: r
    udp6       0      0 :::38260                :::*                                106        53323      9137/rpc.statd
    iob diag has finished.
    Press any key for a summary
    Copy text starting here:
    		     v.2023-04-16
    Operatingsystem: 	Raspbian GNU/Linux 11 (bullseye)
    Kernel: 		6.1.21-v8+
    Installation: 		Native
    Timezone: 		Europe/Berlin (CEST, +0200)
    User-ID: 		1000
    X-Server: 		true
    Pending OS-Updates: 	0
    Pending iob updates: 	0
    Nodejs-Installation: 	/usr/bin/nodejs 	v18.17.0
    			/usr/bin/npm 		9.6.7
    			/usr/bin/npx 		9.6.7
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:            3.7G        2.3G        156M         35M        1.3G        1.3G
    Swap:            99M          0B         99M
    Total:          3.8G        2.3G        256M
    Active iob-Instances: 	37
    ioBroker Core: 		js-controller 		5.0.11
    			admin 			6.6.4
    ioBroker Status: 	iobroker is running on this host.
    Objects type: jsonl
    States  type: jsonl
    Objects: 		14839
    States: 		12289
    Size of iob-Database:
    7.8M	/opt/iobroker/iobroker-data/states.jsonl
    • ESP8266E ESP8266
      @thomas-braun , icxh arbeite mit schon immer mit Putty. Dort kann man kopieren oder in ein Log schreiben.
      @esp8266
      Da läuft einfach zu viel unnötiges Zeuch. Ein voller X-Server mit allem Zipp und Zapp z. B.
      Abschalten, über Terminal bedienen.
      Schalt den Compact Mode aus.
      shelly.0 und mqtt.0 lauschen auf dem gleichen Port.
      ESP8266E 1 Antwort Letzte Antwort
        @esp8266
        ESP8266E Offline
        ESP8266E Offline
        ESP8266
        schrieb am zuletzt editiert von ESP8266
        @thomas-braun, unnötiges Zeug? Für mich ist das alles Relevant. Ich arbeite hier schon allein mit nur einer Fernbedienung. Damit steuere ich 9 Geräte. Dazu brauch ich fakeroku und den Harmony Adaper. 2 Instanzen für Mqtt. Die 2. Instanz allein ist schon für die Wetterstation.
        Unnütziges sehe ich nicht.
        Gut die gleichen Ports werde ich überprüfen.
        Wo lässt sich der Compact Mode ausschalten?
        btw. Im Shelly Adapter lässt sich kein Port ändern. Läuft übrigens nicht mit MQTT sondern Coap.
        • ESP8266E ESP8266
          ESP8266E Offline
          ESP8266E Offline
          ESP8266
          @esp8266 sagte in Beim öffnen der GUI vermehrt Timeouts.:
          @thomas-braun,
          Erledigt.
          Ich setzte es auf gelöst. Erstmal....weiter beobachten.
          • Thomas BraunT Online
            Der mqtt.0 läuft aber auf dem gleichen Port.
            Und ein X-Server (und alles was da dranhängt, cupsd z.B.), ist immer unnütz auf einem iobroker-Server.
            • ESP8266E Offline
              ESP8266E Offline
              ESP8266
              @thomas-braun , Lösung?
              Bin ich jetzt Blind. Wo kann ich die Themenüberschrift ändern?
              Finde keine Option.
              Bitte ein Mod die Überschrift auf (gelöst) abändern.
              • ESP8266E ESP8266
                Finde keine Option.
                bahnuhrB Online
                bahnuhrB Online
                bahnuhr
                in #1
                (hast doch aber auch schon 600 Beiträge; noch nie gemacht ?)
                Danke.
                • bahnuhrB bahnuhr
                  in #1
                  ESP8266E Offline
                  ESP8266E Offline
                  ESP8266
                  @bahnuhr , ich habe auch schon Themen abgeändert. Jahre her....so oft brauchte ich keine Hilfe um welche zu erstellen.
                  Nur finde ich auf der Seite nichts mehr....wenn ich nicht fragen würde, hätte ich die Option schon gefunden....
                  Es gibt hier nur die Option seine Beiträge zu bearbeiten. Das sollte sich mal ein Web-Masteranschauen.
                  Nichts....
                  BBTownB 1 Antwort Letzte Antwort
                  • ESP8266E ESP8266
                    Nichts....
                    BBTownB Online
                    BBTownB Online
                    BBTown
                    @esp8266 Du kannst (als der Ersteller dieses Threads) den ersten Beitrag editieren
                    Somit kannst Du im ersten Beitrag die Überschrift ändern (diese ist relevant für den Titel des Threads)
                    • BBTownB BBTown
                      ESP8266E Offline
                      ESP8266E Offline
                      ESP8266
                      @bbtown , nun ist der Groschen gefallen. Ich mach nicht wegen irgenwas gleich Themen auf.....wenn nur in seltenen Fällen.
                      Nochmals 👍
                      • E Offline
                        e-i-k-e
                        schrieb am zuletzt editiert von e-i-k-e
                        Ich habe auch ab und zu Timeouts.
                        Fällt euch bei meinem "iob diag" etwas auf?
                        Skript v.2023-04-16
                        *** BASE SYSTEM ***
                        Architecture    : x86_64
                        Docker          : false
                        Virtualization  : kvm
                        Distributor ID: Ubuntu
                        Description:    Ubuntu 22.04.2 LTS
                        Release:        22.04
                        Codename:       jammy
                        PRETTY_NAME="Ubuntu 22.04.2 LTS"
                        NAME="Ubuntu"
                        VERSION_ID="22.04"
                        VERSION="22.04.2 LTS (Jammy Jellyfish)"
                        VERSION_CODENAME=jammy
                        ID=ubuntu
                        ID_LIKE=debian
                        HOME_URL="https://www.ubuntu.com/"
                        SUPPORT_URL="https://help.ubuntu.com/"
                        BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
                        PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-poli        cy"
                        UBUNTU_CODENAME=jammy
                         21:52:32 up 3 days,  5:12,  2 users,  load average: 1.10, 1.74, 1.59
                        CPU threads: 8
                                       Local time: Mon 2023-07-31 21:52:32 CEST
                                   Universal time: Mon 2023-07-31 19:52:32 UTC
                                         RTC time: Mon 2023-07-31 19:52:32
                                      NTP service: active
                                  RTC in local TZ: no
                        pi
                        /home/pi
                        pi adm cdrom sudo dip plugdev lxd iobroker
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Mem:            5.9G        4.1G        534M        1.0M        1.3G        1.6G
                        Swap:           2.9G        0.0K        2.9G
                        Total:          8.9G        4.1G        3.5G
                                 5925 M total memory
                                 4073 M used memory
                                  605 M active memory
                                 4360 M inactive memory
                                  534 M free memory
                                  127 M buffer memory
                                 1188 M swap cache
                                 2947 M total swap
                                    0 M used swap
                                 2947 M free swap
                        *** FILESYSTEM ***
                        Filesystem                        Type   Size  Used Avail Use% Mounted on
                        tmpfs                             tmpfs  593M  1.2M  592M   1% /run
                        /dev/mapper/ubuntu--vg-ubuntu--lv ext4    15G   13G 1000M  93% /
                        tmpfs                             tmpfs  2.9G     0  2.9G   0% /dev/shm
                        tmpfs                             tmpfs  5.0M     0  5.0M   0% /run/lock
                        /dev/sda2                         ext4   2.0G  254M  1.6G  14% /boot
                        /dev/sda1                         vfat   1.1G  6.1M  1.1G   1% /boot/efi
                        tmpfs                             tmpfs  593M  4.0K  593M   1% /run/user/1000
                        [Fri Jul 28 16:40:25 2023] EXT4-fs (dm-0): mounted filesystem with ordered data        mode. Opts: (null). Quota mode: none.
                        [Fri Jul 28 16:40:27 2023] EXT4-fs (dm-0): re-mounted. Opts: (null). Quota mode:        none.
                        [Fri Jul 28 16:40:29 2023] EXT4-fs (sda2): mounted filesystem with ordered data        mode. Opts: (null). Quota mode: none.
                        /                   /dev/mapper/ubuntu--vg-ubuntu--lv ext4     rw,relatime
                        |-/snap/core20/1950 /dev/loop0                        squashfs ro,nodev,relatime        ,errors=continue
                        |-/snap/core20/1974 /dev/loop1                        squashfs ro,nodev,relatime        ,errors=continue
                        |-/snap/lxd/24322   /dev/loop2                        squashfs ro,nodev,relatime        ,errors=continue
                        |-/snap/snapd/19457 /dev/loop4                        squashfs ro,nodev,relatime        ,errors=continue
                        |-/snap/snapd/19361 /dev/loop3                        squashfs ro,nodev,relatime        ,errors=continue
                        `-/boot             /dev/sda2                         ext4     rw,relatime
                          `-/boot/efi       /dev/sda1                         vfat     rw,relatime,fmask        =0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount        -ro
                        /var:
                        1.8G    /var/
                        962M    /var/log
                        953M    /var/log/journal/65cc3a3537eb488f8788ce0a60cda8d3
                        665M    /var/lib
                        Archived and active journals take up 952.1M in the file system.
                        607M    /opt/iobroker/backups/
                        125M    /opt/iobroker/iobroker-data/
                        44M     /opt/iobroker/iobroker-data/files
                        40M     /opt/iobroker/iobroker-data/eusec.0/T8010P2322140527/last_live
                        34M     /opt/iobroker/iobroker-data/objects.jsonl
                        7.5M    /opt/iobroker/iobroker-data/states.jsonl
                        7.3M    /opt/iobroker/iobroker-data/files/vis.0/Icons/Mond/Monde.psd
                        6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-n        ode_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_        iobr-99c23e.847b8ad9.chunk.js.map
                        5.1M    /opt/iobroker/iobroker-data/files/vis.0/Beispiel_neu/vis-views.json
                        /usr/bin/npm            9.6.7
                        /usr/bin/npx            9.6.7
                        nodejs:
                          Version table:
                                500 https://deb.nodesource.com/node_18.x jammy/main amd64 Packages
                             12.22.9~dfsg-1ubuntu3 500
                                500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
                        ioBroker Status
                        At least one iobroker host is running.
                        Objects type: redis
                        States  type: redis
                        js-controller:  5.0.9
                        admin:          6.6.4
                        javascript:     7.1.1
                        Adapters from github:   1
                        Adapter State
                        + system.adapter.admin.2                  : admin                 : ioBroker-Rock                            -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                        + system.adapter.admin.3                  : admin                 : ioBroker-Rock                            -  enabled, port: 8900, bind: 0.0.0.0, run as: admin
                        + system.adapter.alarm.0                  : alarm                 : ioBroker-Rock                            -  enabled
                        + system.adapter.alexa2.0                 : alexa2                : ioBroker-Rock                            -  enabled
                        + system.adapter.backitup.0               : backitup              : ioBroker-Rock                            -  enabled
                          system.adapter.boscheasycontrol.0       : boscheasycontrol      : ioBroker-Rock                            - disabled
                        + system.adapter.cloud.0                  : cloud                 : ioBroker-Rock                            -  enabled
                          system.adapter.daswetter.0              : daswetter             : ioBroker-Rock                            -  enabled
                        + system.adapter.device-reminder.0        : device-reminder       : ioBroker-Rock                            -  enabled
                        + system.adapter.device-watcher.0         : device-watcher        : ioBroker-Rock                            -  enabled
                        + system.adapter.discovergy.0             : discovergy            : ioBroker-Rock                            -  enabled
                          system.adapter.discovery.0              : discovery             : ioBroker-Rock                            - disabled
                          system.adapter.dwd.0                    : dwd                   : ioBroker-Rock                            -  enabled
                        + system.adapter.echarts.0                : echarts               : ioBroker-Rock                            -  enabled
                          system.adapter.eusec.0                  : eusec                 : ioBroker-Rock                            - disabled
                          system.adapter.feiertage.0              : feiertage             : ioBroker-Rock                            -  enabled
                          system.adapter.flot.0                   : flot                  : ioBroker-Rock                            -  enabled
                        + system.adapter.heatingcontrol.1         : heatingcontrol        : ioBroker-Rock                            -  enabled
                        + system.adapter.hm-rega.0                : hm-rega               : ioBroker-Rock                            -  enabled
                        + system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker-Rock                            -  enabled, port: 0
                        + system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker-Rock                            -  enabled, port: 0
                        + system.adapter.hm-rpc.2                 : hm-rpc                : ioBroker-Rock                            -  enabled, port: 0
                        + system.adapter.hoover.0                 : hoover                : ioBroker-Rock                            -  enabled
                          system.adapter.ical.0                   : ical                  : ioBroker-Rock                            -  enabled
                          system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: ioBroker-Rock                            -  enabled
                          system.adapter.icons-icons8.0           : icons-icons8          : ioBroker-Rock                            -  enabled
                          system.adapter.icons-material-png.0     : icons-material-png    : ioBroker-Rock                            -  enabled
                          system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker-Rock                            -  enabled
                          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker-Rock                            -  enabled
                          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBroker-Rock                            -  enabled
                        + system.adapter.influxdb.0               : influxdb              : ioBroker-Rock                            -  enabled, port: 8086
                          system.adapter.iqontrol.0               : iqontrol              : ioBroker-Rock                            - disabled
                        + system.adapter.javascript.0             : javascript            : ioBroker-Rock                            -  enabled
                        + system.adapter.javascript.2             : javascript            : raspberrypi-display1                     -  enabled
                        + system.adapter.javascript.3             : javascript            : raspberrypi-display4                     -  enabled
                        + system.adapter.javascript.4             : javascript            : raspberrypi-display2                     -  enabled
                        + system.adapter.javascript.5             : javascript            : raspberrypi-display5                     -  enabled
                        + system.adapter.midea.0                  : midea                 : ioBroker-Rock                            -  enabled
                          system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker-Rock                            - disabled, port: 54321, bind: 0.0.0.0
                          system.adapter.mihome-vacuum.1          : mihome-vacuum         : ioBroker-Rock                            - disabled, port: 54321, bind: 0.0.0.0
                        + system.adapter.mihome.0                 : mihome                : ioBroker-Rock                            -  enabled, port: 9898, bind: 192.168.3.100
                        + system.adapter.milight-smart-light.0    : milight-smart-light   : ioBroker-Rock                            -  enabled
                        + system.adapter.modbus.0                 : modbus                : ioBroker-Rock                            -  enabled
                        + system.adapter.mqtt.0                   : mqtt                  : ioBroker-Rock                            -  enabled, port: 1886, bind: 0.0.0.0
                        + system.adapter.musiccast.0              : musiccast             : ioBroker-Rock                            -  enabled
                        + system.adapter.nut.0                    : nut                   : ioBroker-Rock                            -  enabled
                        + system.adapter.proxmox.0                : proxmox               : ioBroker-Rock                            -  enabled, port: 8006
                        + system.adapter.rpi2.1                   : rpi2                  : raspberrypi-display1                     -  enabled
                        + system.adapter.rpi2.2                   : rpi2                  : raspberrypi-display2                     -  enabled
                        + system.adapter.rpi2.3                   : rpi2                  : raspberrypi-display3                     -  enabled
                        + system.adapter.rpi2.4                   : rpi2                  : raspberrypi-display4                     -  enabled
                        + system.adapter.rpi2.5                   : rpi2                  : raspberrypi-display5                     -  enabled
                        + system.adapter.sainlogic.0              : sainlogic             : ioBroker-Rock                            -  enabled, port: 45000, bind: 192.168.3.100
                        + system.adapter.scenes.0                 : scenes                : ioBroker-Rock                            -  enabled
                        + system.adapter.shelly.0                 : shelly                : ioBroker-Rock                            -  enabled, port: 1890, bind: 0.0.0.0
                        + system.adapter.shelly.1                 : shelly                : ioBroker-Rock                            -  enabled, port: 1899, bind: 0.0.0.0
                        + system.adapter.shuttercontrol.0         : shuttercontrol        : ioBroker-Rock                            -  enabled
                          system.adapter.simple-api.0             : simple-api            : ioBroker-Rock                            - disabled, port: 8087, bind: 0.0.0.0, run as: admin
                        + system.adapter.smartcontrol.0           : smartcontrol          : ioBroker-Rock                            -  enabled
                        + system.adapter.smartmeter.0             : smartmeter            : ioBroker-Rock                            -  enabled
                        + system.adapter.sonoff.0                 : sonoff                : ioBroker-Rock                            -  enabled, port: 1883, bind: 0.0.0.0
                        + system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker-Rock                            -  enabled
                        + system.adapter.sprinklecontrol.0        : sprinklecontrol       : ioBroker-Rock                            -  enabled
                        + system.adapter.statistics.0             : statistics            : ioBroker-Rock                            -  enabled
                          system.adapter.synology.0               : synology              : ioBroker-Rock                            - disabled, port: 5001
                        + system.adapter.telegram.0               : telegram              : ioBroker-Rock                            -  enabled, port: 8443, bind: 0.0.0.0
                        + system.adapter.text2command.0           : text2command          : ioBroker-Rock                            -  enabled
                          system.adapter.unifi.0                  : unifi                 : ioBroker-Rock                            - disabled
                          system.adapter.vis-bars.0               : vis-bars              : ioBroker-Rock                            -  enabled
                          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker-Rock                            -  enabled
                          system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBroker-Rock                            -  enabled
                          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker-Rock                            -  enabled
                          system.adapter.vis-history.0            : vis-history           : ioBroker-Rock                            -  enabled
                          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker-Rock                            -  enabled
                          system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker-Rock                            -  enabled
                        + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker-Rock                            -  enabled
                          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker-Rock                            -  enabled
                          system.adapter.vis-justgage.0           : vis-justgage          : ioBroker-Rock                            -  enabled
                          system.adapter.vis-keyboard.0           : vis-keyboard          : ioBroker-Rock                            -  enabled
                          system.adapter.vis-material.0           : vis-material          : ioBroker-Rock                            -  enabled
                          system.adapter.vis-metro.0              : vis-metro             : ioBroker-Rock                            -  enabled
                          system.adapter.vis-players.0            : vis-players           : ioBroker-Rock                            -  enabled
                          system.adapter.vis-plumb.0              : vis-plumb             : ioBroker-Rock                            -  enabled
                          system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker-Rock                            -  enabled
                          system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker-Rock                            -  enabled
                          system.adapter.vis-weather.0            : vis-weather           : ioBroker-Rock                            -  enabled
                          system.adapter.vis.0                    : vis                   : ioBroker-Rock                            -  enabled
                          system.adapter.web-speedy.0             : web-speedy            : ioBroker-Rock                            - disabled
                        + system.adapter.web.0                    : web                   : ioBroker-Rock                            -  enabled, port: 8082, bind: 192.168.3.100 (SSL), run as: admin
                        + system.adapter.web.1                    : web                   : ioBroker-Rock                            -  enabled, port: 8083, bind: 192.168.3.100, run as: admin
                        + system.adapter.wolf-smartset.0          : wolf-smartset         : ioBroker-Rock                            -  enabled
                        + system.adapter.worx.0                   : worx                  : ioBroker-Rock                            -  enabled
                        + system.adapter.yamaha.0                 : yamaha                : ioBroker-Rock                            -  enabled
                          system.adapter.yeelight-2.0             : yeelight-2            : ioBroker-Rock                            -  enabled
                          system.adapter.yr.0                     : yr                    : ioBroker-Rock                            -  enabled
                        + system.adapter.zigbee.0                 : zigbee                : ioBroker-Rock                            -  enabled, port: /dev/ttyACM0
                        + instance is alive
                        Adapter    "alarm"        : 3.3.12   , installed 3.3.12
                        Adapter    "cloud"        : 4.4.1    , installed 4.4.1
                        Adapter    "device-watcher": 2.9.3   , installed 2.9.3
                        Adapter    "discovergy"   : 0.5.8    , installed 0.5.8
                        Adapter    "eusec"        : 1.0.0    , installed 1.0.0
                        Adapter    "haier"        : 1.0.4    , installed 1.0.4
                        Adapter    "heatingcontrol": 2.11.1  , installed 2.11.1
                        Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
                        Adapter    "hm-rpc"       : 1.15.18  , installed 1.15.18
                        Adapter    "hoover"       : 0.1.0    , installed 0.1.0
                        Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
                        Controller "js-controller": 5.0.11   , installed 5.0.9  [Updatable]
                        Adapter    "lovelace"     : 3.0.1    , installed 3.0.1
                        Adapter    "midea"        : 0.0.7    , installed 0.0.7
                        Adapter    "mihome"       : 1.4.0    , installed 1.4.0
                        Adapter    "mihome-vacuum": 3.11.0   , installed 3.11.0
                        Adapter    "milight-smart-light": 1.2.2, installed 1.2.2
                        Adapter    "modbus"       : 5.0.11   , installed 5.0.11
                        Adapter    "musiccast"    : 1.1.0    , installed 1.1.0
                        Adapter    "nut"          : 1.6.0    , installed 1.6.0
                        Adapter    "proxmox"      : 1.3.5    , installed 1.3.5
                        Adapter    "sainlogic"    : 0.10.5   , installed 0.10.5
                        Adapter    "shuttercontrol": 1.6.1   , installed 1.6.1
                        Adapter    "smartcontrol" : 1.3.2    , installed 1.3.2
                        Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
                        Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
                        Adapter    "sprinklecontrol": 0.2.13 , installed 0.2.13
                        Adapter    "statistics"   : 2.3.0    , installed 2.3.0
                        Adapter    "synology"     : 2.1.13   , installed 2.1.13
                        Adapter    "unifi"        : 0.6.6    , installed 0.6.6
                        Adapter    "vis-material" : 0.1.3    , installed 0.1.3
                        Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                        Adapter    "web-speedy"   : 0.2.0    , installed 0.2.0
                        Adapter    "wolf-smartset": 1.1.1    , installed 1.1.1
                        Adapter    "worx"         : 2.3.2    , installed 2.3.2
                        Adapter    "yamaha"       : 0.5.3    , installed 0.5.3
                        Adapter    "yeelight-2"   : 1.2.1    , installed 1.2.1
                        Adapter    "yr"           : 5.3.0    , installed 5.3.0
                        Adapter    "zigbee"       : 1.8.19   , installed 1.8.19
                        Objects and States
                        Objects:        34001
                        States:         31411
                        Hit:1 http://de.archive.ubuntu.com/ubuntu jammy InRelease
                        Hit:2 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
                        Hit:3 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
                        Hit:4 http://de.archive.ubuntu.com/ubuntu jammy-security InRelease
                        Hit:5 https://deb.nodesource.com/node_18.x jammy InRelease
                        Pending Updates: 32
                        tcp        0      0 192.168.3.100:8082      0.0.0.0:*               LISTEN      1001       25731      1364/io.web.0
                        tcp        0      0 192.168.3.100:8083      0.0.0.0:*               LISTEN      1001       26065      1665/io.web.1
                        tcp        0      0 192.168.3.100:45000     0.0.0.0:*               LISTEN      1001       25891      1540/io.sainlogic.0
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          20970      729/sshd: /usr/sbin
                        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          20517      1/init
                        tcp        0      0 192.168.3.100:8701      0.0.0.0:*               LISTEN      1001       23097      1117/io.hm-rpc.1
                        tcp        0      0 192.168.3.100:2010      0.0.0.0:*               LISTEN      1001       23879      1102/io.hm-rpc.2
                        tcp        0      0 192.168.3.100:2001      0.0.0.0:*               LISTEN      1001       25012      1265/io.hm-rpc.0
                        tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       24757      1085/io.mqtt.0
                        tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       24758      1085/io.mqtt.0
                        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       21394      1203/io.sonoff.0
                        tcp        0      0 0.0.0.0:1899            0.0.0.0:*               LISTEN      1001       21227      1070/io.shelly.1
                        tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        22613      675/systemd-resolve
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       22994      842/io.admin.2
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          20981      729/sshd: /usr/sbin
                        tcp6       0      0 :::111                  :::*                    LISTEN      0          16685      1/init
                        tcp6       0      0 :::8900                 :::*                    LISTEN      1001       23807      969/io.admin.3
                        udp        0      0 0.0.0.0:52119           0.0.0.0:*                           1001       25471      1650/io.milight-sma
                        udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        22612      675/systemd-resolve
                        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          20518      1/init
                        udp        0      0 0.0.0.0:41100           0.0.0.0:*                           1001       27662      1680/io.musiccast.0
                        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       25117      1325/io.shelly.0
                        udp        0      0 0.0.0.0:9898            0.0.0.0:*                           1001       106986     1299/io.mihome.0
                        udp6       0      0 :::111                  :::*                                0          20519      1/init
                        2023-07-31 21:48:59.895  - info: mqtt.0 (1085) Client [] connection closed: disconnected
                        2023-07-31 21:49:02.149  - info: mqtt.0 (1085) Client [] connected with secret 1690832942136_993
                        2023-07-31 21:49:27.904  - info: sonoff.0 (1203) Client [Durchflusszähler_2] connected with secret 1690832967899_7008
                        2023-07-31 21:50:00.108  - info: host.ioBroker-Rock instance system.adapter.dwd.0 started with pid 31383
                        2023-07-31 21:50:01.463  - info: mqtt.0 (1085) Client [] connection closed: disconnected
                        2023-07-31 21:50:01.678  - info: mqtt.0 (1085) Client [] connected with secret 1690833001676_8269
                        2023-07-31 21:50:04.642  - info: dwd.0 (31383) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.0, js-controller: 5.0.9
                        2023-07-31 21:50:05.880  - info: dwd.0 (31383) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                        2023-07-31 21:50:06.418  - info: host.ioBroker-Rock instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        2023-07-31 21:50:18.164  - warn: smartmeter.0 (1250) No or too long answer from Serial Device after last request.
                        2023-07-31 21:51:00.962  - info: mqtt.0 (1085) Client [] connection closed: disconnected
                        2023-07-31 21:51:01.240  - info: mqtt.0 (1085) Client [] connected with secret 1690833061240_2410
                        2023-07-31 21:52:00.147  - info: mqtt.0 (1085) Client [] connection closed: disconnected
                        2023-07-31 21:52:00.385  - info: mqtt.0 (1085) Client [] connected with secret 1690833120385_7205
                        2023-07-31 21:52:03.771  - warn: smartmeter.0 (1250) No or too long answer from Serial Device after last request.
                        2023-07-31 21:52:32.329  - info: influxdb.0 (1009) Store 501 buffered influxDB history points
                        2023-07-31 21:52:33.760  - warn: smartmeter.0 (1250) No or too long answer from Serial Device after last request.
                        2023-07-31 21:52:37.762  - warn: smartmeter.0 (1250) No or too long answer from Serial Device after last request.
                        2023-07-31 21:52:58.670  - info: mqtt.0 (1085) Client [] connection closed: disconnected
                        2023-07-31 21:53:00.917  - info: mqtt.0 (1085) Client [] connected with secret 1690833180916_4500
                        2023-07-31 21:53:11.760  - warn: smartmeter.0 (1250) No or too long answer from Serial Device after last request.
                        2023-07-31 21:53:33.766  - warn: smartmeter.0 (1250) No or too long answer from Serial Device after last request.
                        2023-07-31 21:54:00.204  - info: mqtt.0 (1085) Client [] connection closed: disconnected
                        2023-07-31 21:54:00.466  - info: mqtt.0 (1085) Client [] connected with secret 1690833240465_8793
                        2023-07-31 21:54:11.769  - warn: smartmeter.0 (1250) No or too long answer from Serial Device after last request.
                        • E e-i-k-e
                          Skript v.2023-04-16
                          *** BASE SYSTEM ***
                          Docker          : false
                          Release:        22.04
                          Codename:       jammy
                          NAME="Ubuntu"
                          VERSION_ID="22.04"
                          ID=ubuntu
                          ID_LIKE=debian
                          CPU threads: 8
                                        NTP service: active
                                    RTC in local TZ: no
                          pi
                          /home/pi
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                                   5925 M total memory
                                   4073 M used memory
                                    605 M active memory
                                    534 M free memory
                                    127 M buffer memory
                                   1188 M swap cache
                                   2947 M total swap
                                      0 M used swap
                                   2947 M free swap
                          *** FILESYSTEM ***
                          /var:
                          1.8G    /var/
                          962M    /var/log
                          665M    /var/lib
                          /usr/bin/npm            9.6.7
                          /usr/bin/npx            9.6.7
                          nodejs:
                            Version table:
                          ioBroker Status
                          Objects type: redis
                          States  type: redis
                          admin:          6.6.4
                          javascript:     7.1.1
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        34001
                          States:         31411
                          Pending Updates: 32
                          @e-i-k-e sagte in (gelöst) Beim öffnen der GUI vermehrt Timeouts.:
                          Pending Updates: 32
                          Klopp die rein.
                          Ansonsten seh ich keine dicken Hunde.
                            Pending Updates: 32
                            Klopp die rein.
                            e-i-k-e
                            Erledigt.
                            Wie ist dies zu verstehen?
                            Ich betreibe ein Master/Slave System.
                            • E e-i-k-e
                              Erledigt.
                              Die Abfrage hat sich in das Skript verirrt, funktioniert nicht wie gedacht.
                              Ignorieren.
                                Ignorieren.
                                e-i-k-e
                                Alles klar. ;)
