  4. (gelöst) Beim öffnen der GUI vermehrt Timeouts.
    6.7k
21 Beiträge 5 Kommentatoren 3.6k Aufrufe 5 Beobachtet
    @esp8266
    Das wird eh in eine Datei geloggt...
    Schau in /home/iobroker danach.
    Man kann das auch direkt aus dem Terminal kopieren.
    Bei gescheiten Terminals jedenfalls.
    ESP8266E Offline
    ESP8266E Offline
    ESP8266
    schrieb am zuletzt editiert von ESP8266
    @thomas-braun , icxh arbeite mit schon immer mit Putty. Dort kann man kopieren oder in ein Log schreiben.
    • ESP8266E ESP8266
      @esp8266
      Hier in CodeTags eingebettet reinkopieren.
      ESP8266E 1 Antwort Letzte Antwort
        @esp8266
        ESP8266E Offline
        ESP8266E Offline
        ESP8266
        @thomas-braun ,als doch ohne.
        *** ioBroker Diagnosis ***
        Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
        The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
        https://forum.iobroker.net
        Just copy and paste the Summary Page, including the ``` characters at start and end.
        It helps us to help you!
        Press any key to continue
        Skript v.2023-04-16
        *** BASE SYSTEM ***
        Model		: Raspberry Pi 4 Model B Rev 1.2
        Architecture    : aarch64
        Docker          : false
        Virtualization  : none
        Distributor ID:	Raspbian
        Description:	Raspbian GNU/Linux 11 (bullseye)
        Release:	11
        Codename:	bullseye
        PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
        NAME="Raspbian GNU/Linux"
        VERSION_ID="11"
        VERSION="11 (bullseye)"
        VERSION_CODENAME=bullseye
        ID=raspbian
        ID_LIKE=debian
        HOME_URL="http://www.raspbian.org/"
        SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
        BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
        Systemuptime and Load:
         13:03:30 up  1:35,  3 users,  load average: 3.08, 3.09, 2.72
        CPU threads: 4
        Raspberry only:
        throttled=0x0
        Other values than 0x0 hint to temperature/voltage problems
        temp=43.8'C
        volt=0.8438V
        *** Time and Time Zones ***
                       Local time: Mon 2023-07-31 13:03:30 CEST
                   Universal time: Mon 2023-07-31 11:03:30 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server: 	true
        Desktop:
        Terminal: 	tty
        Boot Target: 	graphical.target
        *** MEMORY ***
        Mem:            3.7G        2.2G        269M         35M        1.3G        1.4G
        Swap:            99M          0B         99M
        Total:          3.8G        2.2G        369M
                 3743 M total memory
                 2189 M used memory
                 2407 M active memory
                  644 M inactive memory
                  269 M free memory
                  139 M buffer memory
                 1145 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /dev/root      ext4      110G  6.0G  101G   6% /
        devtmpfs       devtmpfs  1.6G     0  1.6G   0% /dev
        tmpfs          tmpfs     1.9G   24K  1.9G   1% /dev/shm
        tmpfs          tmpfs     749M  1.3M  748M   1% /run
        /dev/sda1      vfat      255M   51M  205M  20% /boot
        tmpfs          tmpfs     375M   20K  375M   1% /run/user/1000
        [Mon Jul 31 11:27:49 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:8B:67:E3 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=7df941dc-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
        [Mon Jul 31 11:27:52 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
        [Mon Jul 31 11:27:52 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
        [Mon Jul 31 11:27:54 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
        [Mon Jul 31 11:27:59 2023] EXT4-fs (sda2): resizing filesystem from 1420632 to 29240320 blocks
        [Mon Jul 31 11:28:02 2023] EXT4-fs (sda2): resized filesystem to 29240320
        TARGET  SOURCE    FSTYPE OPTIONS
        /       /dev/sda2 ext4   rw,noatime
        `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        524M	/var/
        182M	/var/log
        177M	/var/log/journal/7c7da7cd88a44588896e76ac0de90413
        125M	/var/lib
        Archived and active journals take up 176.0M in the file system.
        /opt/iobroker/backups:
        4.0K	/opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        493M	/opt/iobroker/iobroker-data/
        452M	/opt/iobroker/iobroker-data/files
        88M	/opt/iobroker/iobroker-data/files/echarts.admin
        57M	/opt/iobroker/iobroker-data/files/echarts
        51M	/opt/iobroker/iobroker-data/files/javascript.admin
        33M	/opt/iobroker/iobroker-data/objects.jsonl
        33M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
        23M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
        23M	/opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
        23M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.eb0afecd.js.map
        *** NodeJS-Installation ***
        /usr/bin/nodejs 	v18.17.0
        /usr/bin/node 		v18.17.0
        /usr/bin/npm 		9.6.7
        /usr/bin/npx 		9.6.7
        nodejs:
          Installed: 18.17.0-deb-1nodesource1
          Candidate: 18.17.0-deb-1nodesource1
          Version table:
         *** 18.17.0-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
             12.22.12~dfsg-1~deb11u4 500
        No problems detected
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller: 	5.0.11
        admin: 		6.6.4
        javascript: 	7.1.1
        Adapters from github: 	5
        Adapter State
        + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, compact disabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled, compact disabled
        + system.adapter.apsystems-ecu.0          : apsystems-ecu         : iobroker                                 -  enabled, compact disabled
        + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled, compact disabled
        + system.adapter.backitup.1               : backitup              : iobroker                                 -  enabled, compact disabled
        + system.adapter.broadlink2.0             : broadlink2            : iobroker                                 -  enabled
          system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled, compact disabled
        + system.adapter.denon.0                  : denon                 : iobroker                                 -  enabled, compact disabled
          system.adapter.device-reminder.0        : device-reminder       : iobroker                                 - disabled, compact disabled
        + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled, compact disabled
          system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled, compact disabled
        + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled, compact disabled
        + system.adapter.enigma2.0                : enigma2               : iobroker                                 -  enabled
        + system.adapter.fakeroku.0               : fakeroku              : iobroker                                 -  enabled
          system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled, compact disabled
          system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
        + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled, compact enabled (group 1)
        + system.adapter.g-homa.0                 : g-homa                : iobroker                                 -  enabled, compact disabled
        + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled, compact disabled
        + system.adapter.heizoel.0                : heizoel               : iobroker                                 -  enabled, compact disabled
        + system.adapter.history.0                : history               : iobroker                                 -  enabled, compact disabled
          system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled, compact disabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 - disabled
        + system.adapter.info.0                   : info                  : iobroker                                 -  enabled, compact disabled
        + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled, compact disabled
        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled, compact disabled
        + system.adapter.kodi.0                   : kodi                  : iobroker                                 -  enabled, compact enabled (group 1), port: 9090
        + system.adapter.maxcul.0                 : maxcul                : iobroker                                 -  enabled, compact disabled
        + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, compact disabled, port: 1884, bind: 192.168.62.15
        + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, compact disabled, port: 1888, bind: 0.0.0.0
        + system.adapter.octoprint.0              : octoprint             : iobroker                                 -  enabled, compact disabled
        + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled, compact disabled
        + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, compact disabled, port: 1884, bind: 192.168.62.15
        + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, compact disabled, port: 1883, bind: 192.168.62.15
        + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, compact disabled, port: 8443, bind: 0.0.0.0
        + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled, compact disabled
        + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled, compact disabled
        + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled, compact disabled
          system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
          system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled, compact disabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled, compact disabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled, compact disabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
          system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
          system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker                                 - disabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
          system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
          system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
          system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled, compact disabled
        + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, compact disabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.withings.0               : withings              : iobroker                                 -  enabled, compact disabled
          system.adapter.wled.0                   : wled                  : iobroker                                 - disabled, compact disabled
        + system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled, compact disabled
        + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, compact disabled, port: /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
        + instance is alive
        ioBroker-Repositories
        Active repo(s): beta
        Installed ioBroker-Instances
        Used repository: beta
        Adapter    "admin"        : 6.6.4    , installed 6.6.4
        Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
        Adapter    "backitup"     : 2.6.23   , installed 2.6.23
        Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
        Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
        Adapter    "denon"        : 1.15.3   , installed 1.15.3
        Adapter    "device-reminder": 1.2.9  , installed 1.2.9
        Adapter    "discovery"    : 3.2.0    , installed 3.2.0
        Adapter    "echarts"      : 1.5.1    , installed 1.5.1
        Adapter    "enigma2"      : 1.5.0    , installed 1.5.0
        Adapter    "fakeroku"     : 0.2.2    , installed 0.2.2
        Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
        Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
        Adapter    "g-homa"       : 0.5.3    , installed 0.5.3
        Adapter    "harmony"      : 1.2.2    , installed 1.2.2
        Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
        Adapter    "history"      : 2.2.4    , installed 2.2.4
        Adapter    "ical"         : 1.13.3   , installed 1.13.3
        Adapter    "iot"          : 2.0.11   , installed 2.0.11
        Adapter    "javascript"   : 7.1.1    , installed 7.1.1
        Controller "js-controller": 5.0.11   , installed 5.0.11
        Adapter    "kodi"         : 2.0.9    , installed 2.0.9
        Adapter    "maxcul"       : 1.3.1    , installed 1.3.1
        Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
        Adapter    "octoprint"    : 5.0.1    , installed 5.0.1
        Adapter    "shelly"       : 6.4.1    , installed 6.4.1
        Adapter    "socketio"     : 6.4.0    , installed 6.4.0
        Adapter    "sonoff"       : 2.5.7    , installed 2.5.7
        Adapter    "telegram"     : 1.16.0   , installed 1.16.0
        Adapter    "text2command" : 3.0.2    , installed 3.0.2
        Adapter    "trashschedule": 2.2.0    , installed 2.2.0
        Adapter    "tuya"         : 3.14.2   , installed 3.14.2
        Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
        Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
        Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
        Adapter    "web"          : 6.0.3    , installed 6.0.3
        Adapter    "withings"     : 0.0.13   , installed 0.0.13
        Adapter    "wled"         : 0.7.0    , installed 0.7.0
        Adapter    "ws"           : 2.4.0    , installed 2.4.0
        Adapter    "yahka"        : 1.0.3    , installed 1.0.3
        Adapter    "zigbee"       : 1.8.18   , installed 1.8.18
        Objects and States
        Objects: 	14839
        States: 	12289
        Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:2 https://deb.nodesource.com/node_18.x bullseye InRelease
        Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:8888            0.0.0.0:*               LISTEN      0          845        629/ebusd
        tcp        0      0 0.0.0.0:37509           0.0.0.0:*               LISTEN      1001       94812      18232/io.yahka.0
        tcp        0      0 192.168.62.15:1885      0.0.0.0:*               LISTEN      1001       83890      16433/io.mqtt.0
        tcp        0      0 192.168.62.15:1884      0.0.0.0:*               LISTEN      1001       83889      16433/io.mqtt.0
        tcp        0      0 192.168.62.15:1883      0.0.0.0:*               LISTEN      1001       85303      16566/io.sonoff.0
        tcp        0      0 0.0.0.0:8765            0.0.0.0:*               LISTEN      116        106820     19527/python3
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15826      651/sshd: /usr/sbin
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          51895      1/init
        tcp        0      0 127.0.0.1:7999          0.0.0.0:*               LISTEN      116        106799     19542/motion
        tcp        0      0 192.168.62.15:9095      0.0.0.0:*               LISTEN      1001       83597      16159/io.fakeroku.0
        tcp        0      0 192.168.62.15:9094      0.0.0.0:*               LISTEN      1001       83596      16159/io.fakeroku.0
        tcp        0      0 192.168.62.15:9093      0.0.0.0:*               LISTEN      1001       83595      16159/io.fakeroku.0
        tcp        0      0 0.0.0.0:54805           0.0.0.0:*               LISTEN      106        53321      9137/rpc.statd
        tcp        0      0 0.0.0.0:8011            0.0.0.0:*               LISTEN      116        106798     19542/motion
        tcp        0      0 0.0.0.0:8010            0.0.0.0:*               LISTEN      116        106797     19542/motion
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          17282      1294/cupsd
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       53241      9687/iobroker.js-co
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       55128      9687/iobroker.js-co
        tcp6       0      0 :::61991                :::*                    LISTEN      1001       83659      16231/io.harmony.0
        tcp6       0      0 :::54263                :::*                    LISTEN      106        53325      9137/rpc.statd
        tcp6       0      0 :::50000                :::*                    LISTEN      1001       81744      16217/io.g-homa.0
        tcp6       0      0 :::21                   :::*                    LISTEN      0          15721      615/vsftpd
        tcp6       0      0 :::22                   :::*                    LISTEN      0          15828      651/sshd: /usr/sbin
        tcp6       0      0 :::111                  :::*                    LISTEN      0          51901      1/init
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          17281      1294/cupsd
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       99362      18529/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       86980      17138/io.web.0
        udp        0      0 0.0.0.0:53148           0.0.0.0:*                           1001       84378      16042/io.broadlink2
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15104      531/dhcpcd
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          51897      1/init
        udp        0      0 0.0.0.0:57555           0.0.0.0:*                           1001       81474      16042/io.broadlink2
        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       85726      16792/io.tuya.0
        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       85727      16792/io.tuya.0
        udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       83660      16231/io.harmony.0
        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          18802      1295/cups-browsed
        udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       84373      16042/io.broadlink2
        udp        0      0 127.0.0.1:833           0.0.0.0:*                           0          53314      9137/rpc.statd
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       94817      18232/io.yahka.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       94816      18232/io.yahka.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15657      447/avahi-daemon: r
        udp        0      0 0.0.0.0:46393           0.0.0.0:*                           106        53319      9137/rpc.statd
        udp        0      0 0.0.0.0:58847           0.0.0.0:*                           108        15659      447/avahi-daemon: r
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       85301      16530/io.shelly.0
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       83598      16159/io.fakeroku.0
        udp6       0      0 :::111                  :::*                                0          51905      1/init
        udp6       0      0 :::44227                :::*                                108        15660      447/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                108        15658      447/avahi-daemon: r
        udp6       0      0 :::38260                :::*                                106        53323      9137/rpc.statd
        iob diag has finished.
        Press any key for a summary
        Copy text starting here:
        		     v.2023-04-16
        Operatingsystem: 	Raspbian GNU/Linux 11 (bullseye)
        Kernel: 		6.1.21-v8+
        Installation: 		Native
        Timezone: 		Europe/Berlin (CEST, +0200)
        User-ID: 		1000
        X-Server: 		true
        Pending OS-Updates: 	0
        Pending iob updates: 	0
        Nodejs-Installation: 	/usr/bin/nodejs 	v18.17.0
        			/usr/bin/npm 		9.6.7
        			/usr/bin/npx 		9.6.7
        Recommended versions are nodejs 18.x.y and npm 9.x.y
        MEMORY:
        Mem:            3.7G        2.3G        156M         35M        1.3G        1.3G
        Swap:            99M          0B         99M
        Total:          3.8G        2.3G        256M
        Active iob-Instances: 	37
        ioBroker Core: 		js-controller 		5.0.11
        			admin 			6.6.4
        ioBroker Status: 	iobroker is running on this host.
        Objects type: jsonl
        States  type: jsonl
        Objects: 		14839
        States: 		12289
        Size of iob-Database:
        7.8M	/opt/iobroker/iobroker-data/states.jsonl
        • ESP8266E ESP8266
          @esp8266
          Da läuft einfach zu viel unnötiges Zeuch. Ein voller X-Server mit allem Zipp und Zapp z. B.
          Abschalten, über Terminal bedienen.
          Schalt den Compact Mode aus.
          shelly.0 und mqtt.0 lauschen auf dem gleichen Port.
            @esp8266
            ESP8266E Offline
            ESP8266E Offline
            ESP8266
            @thomas-braun, unnötiges Zeug? Für mich ist das alles Relevant. Ich arbeite hier schon allein mit nur einer Fernbedienung. Damit steuere ich 9 Geräte. Dazu brauch ich fakeroku und den Harmony Adaper. 2 Instanzen für Mqtt. Die 2. Instanz allein ist schon für die Wetterstation.
            Unnütziges sehe ich nicht.
            Gut die gleichen Ports werde ich überprüfen.
            Wo lässt sich der Compact Mode ausschalten?
            btw. Im Shelly Adapter lässt sich kein Port ändern. Läuft übrigens nicht mit MQTT sondern Coap.
            • ESP8266E ESP8266
              ESP8266E Offline
              ESP8266E Offline
              ESP8266
              @esp8266 sagte in Beim öffnen der GUI vermehrt Timeouts.:
              @thomas-braun,
              Erledigt.
              Ich setzte es auf gelöst. Erstmal....weiter beobachten.
              • Thomas BraunT Online
                Der mqtt.0 läuft aber auf dem gleichen Port.
                Und ein X-Server (und alles was da dranhängt, cupsd z.B.), ist immer unnütz auf einem iobroker-Server.
                • ESP8266E Offline
                  ESP8266E Offline
                  ESP8266
                  @thomas-braun , Lösung?
                  Bin ich jetzt Blind. Wo kann ich die Themenüberschrift ändern?
                  Finde keine Option.
                  Bitte ein Mod die Überschrift auf (gelöst) abändern.
                  • ESP8266E ESP8266
                    Finde keine Option.
                    bahnuhrB Online
                    bahnuhrB Online
                    bahnuhr
                    in #1
                    (hast doch aber auch schon 600 Beiträge; noch nie gemacht ?)
                    Danke.
                    • bahnuhrB bahnuhr
                      in #1
                      ESP8266E Offline
                      ESP8266E Offline
                      ESP8266
                      @bahnuhr , ich habe auch schon Themen abgeändert. Jahre her....so oft brauchte ich keine Hilfe um welche zu erstellen.
                      Nur finde ich auf der Seite nichts mehr....wenn ich nicht fragen würde, hätte ich die Option schon gefunden....
                      Es gibt hier nur die Option seine Beiträge zu bearbeiten. Das sollte sich mal ein Web-Masteranschauen.
                      Nichts....
                      BBTownB 1 Antwort Letzte Antwort
                      • ESP8266E ESP8266
                        Nichts....
                        BBTownB Online
                        BBTownB Online
                        BBTown
                        @esp8266 Du kannst (als der Ersteller dieses Threads) den ersten Beitrag editieren
                        Somit kannst Du im ersten Beitrag die Überschrift ändern (diese ist relevant für den Titel des Threads)
                        • BBTownB BBTown
                          ESP8266E Offline
                          ESP8266E Offline
                          ESP8266
                          @bbtown , nun ist der Groschen gefallen. Ich mach nicht wegen irgenwas gleich Themen auf.....wenn nur in seltenen Fällen.
                          Nochmals 👍
                          • E Offline
                            e-i-k-e
                            schrieb am zuletzt editiert von e-i-k-e
                            Ich habe auch ab und zu Timeouts.
                            Fällt euch bei meinem "iob diag" etwas auf?
                            Skript v.2023-04-16
                            *** BASE SYSTEM ***
                            Architecture    : x86_64
                            Docker          : false
                            Virtualization  : kvm
                            Distributor ID: Ubuntu
                            Description:    Ubuntu 22.04.2 LTS
                            Release:        22.04
                            Codename:       jammy
                            PRETTY_NAME="Ubuntu 22.04.2 LTS"
                            NAME="Ubuntu"
                            VERSION_ID="22.04"
                            VERSION="22.04.2 LTS (Jammy Jellyfish)"
                            VERSION_CODENAME=jammy
                            ID=ubuntu
                            ID_LIKE=debian
                            HOME_URL="https://www.ubuntu.com/"
                            SUPPORT_URL="https://help.ubuntu.com/"
                            BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
                            PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-poli        cy"
                            UBUNTU_CODENAME=jammy
                             21:52:32 up 3 days,  5:12,  2 users,  load average: 1.10, 1.74, 1.59
                            CPU threads: 8
                                           Local time: Mon 2023-07-31 21:52:32 CEST
                                       Universal time: Mon 2023-07-31 19:52:32 UTC
                                             RTC time: Mon 2023-07-31 19:52:32
                                          NTP service: active
                                      RTC in local TZ: no
                            pi
                            /home/pi
                            pi adm cdrom sudo dip plugdev lxd iobroker
                            X-Server:       false
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Mem:            5.9G        4.1G        534M        1.0M        1.3G        1.6G
                            Swap:           2.9G        0.0K        2.9G
                            Total:          8.9G        4.1G        3.5G
                                     5925 M total memory
                                     4073 M used memory
                                      605 M active memory
                                     4360 M inactive memory
                                      534 M free memory
                                      127 M buffer memory
                                     1188 M swap cache
                                     2947 M total swap
                                        0 M used swap
                                     2947 M free swap
                            *** FILESYSTEM ***
                            Filesystem                        Type   Size  Used Avail Use% Mounted on
                            tmpfs                             tmpfs  593M  1.2M  592M   1% /run
                            /dev/mapper/ubuntu--vg-ubuntu--lv ext4    15G   13G 1000M  93% /
                            tmpfs                             tmpfs  2.9G     0  2.9G   0% /dev/shm
                            tmpfs                             tmpfs  5.0M     0  5.0M   0% /run/lock
                            /dev/sda2                         ext4   2.0G  254M  1.6G  14% /boot
                            /dev/sda1                         vfat   1.1G  6.1M  1.1G   1% /boot/efi
                            tmpfs                             tmpfs  593M  4.0K  593M   1% /run/user/1000
                            [Fri Jul 28 16:40:25 2023] EXT4-fs (dm-0): mounted filesystem with ordered data        mode. Opts: (null). Quota mode: none.
                            [Fri Jul 28 16:40:27 2023] EXT4-fs (dm-0): re-mounted. Opts: (null). Quota mode:        none.
                            [Fri Jul 28 16:40:29 2023] EXT4-fs (sda2): mounted filesystem with ordered data        mode. Opts: (null). Quota mode: none.
                            /                   /dev/mapper/ubuntu--vg-ubuntu--lv ext4     rw,relatime
                            |-/snap/core20/1950 /dev/loop0                        squashfs ro,nodev,relatime        ,errors=continue
                            |-/snap/core20/1974 /dev/loop1                        squashfs ro,nodev,relatime        ,errors=continue
                            |-/snap/lxd/24322   /dev/loop2                        squashfs ro,nodev,relatime        ,errors=continue
                            |-/snap/snapd/19457 /dev/loop4                        squashfs ro,nodev,relatime        ,errors=continue
                            |-/snap/snapd/19361 /dev/loop3                        squashfs ro,nodev,relatime        ,errors=continue
                            `-/boot             /dev/sda2                         ext4     rw,relatime
                              `-/boot/efi       /dev/sda1                         vfat     rw,relatime,fmask        =0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount        -ro
                            /var:
                            1.8G    /var/
                            962M    /var/log
                            953M    /var/log/journal/65cc3a3537eb488f8788ce0a60cda8d3
                            665M    /var/lib
                            Archived and active journals take up 952.1M in the file system.
                            607M    /opt/iobroker/backups/
                            125M    /opt/iobroker/iobroker-data/
                            44M     /opt/iobroker/iobroker-data/files
                            40M     /opt/iobroker/iobroker-data/eusec.0/T8010P2322140527/last_live
                            34M     /opt/iobroker/iobroker-data/objects.jsonl
                            7.5M    /opt/iobroker/iobroker-data/states.jsonl
                            7.3M    /opt/iobroker/iobroker-data/files/vis.0/Icons/Mond/Monde.psd
                            6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-n        ode_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_        iobr-99c23e.847b8ad9.chunk.js.map
                            5.1M    /opt/iobroker/iobroker-data/files/vis.0/Beispiel_neu/vis-views.json
                            /usr/bin/npm            9.6.7
                            /usr/bin/npx            9.6.7
                            nodejs:
                              Version table:
                                    500 https://deb.nodesource.com/node_18.x jammy/main amd64 Packages
                                 12.22.9~dfsg-1ubuntu3 500
                                    500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
                            ioBroker Status
                            At least one iobroker host is running.
                            Objects type: redis
                            States  type: redis
                            js-controller:  5.0.9
                            admin:          6.6.4
                            javascript:     7.1.1
                            Adapters from github:   1
                            Adapter State
                            + system.adapter.admin.2                  : admin                 : ioBroker-Rock                            -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                            + system.adapter.admin.3                  : admin                 : ioBroker-Rock                            -  enabled, port: 8900, bind: 0.0.0.0, run as: admin
                            + system.adapter.alarm.0                  : alarm                 : ioBroker-Rock                            -  enabled
                            + system.adapter.alexa2.0                 : alexa2                : ioBroker-Rock                            -  enabled
                            + system.adapter.backitup.0               : backitup              : ioBroker-Rock                            -  enabled
                              system.adapter.boscheasycontrol.0       : boscheasycontrol      : ioBroker-Rock                            - disabled
                            + system.adapter.cloud.0                  : cloud                 : ioBroker-Rock                            -  enabled
                              system.adapter.daswetter.0              : daswetter             : ioBroker-Rock                            -  enabled
                            + system.adapter.device-reminder.0        : device-reminder       : ioBroker-Rock                            -  enabled
                            + system.adapter.device-watcher.0         : device-watcher        : ioBroker-Rock                            -  enabled
                            + system.adapter.discovergy.0             : discovergy            : ioBroker-Rock                            -  enabled
                              system.adapter.discovery.0              : discovery             : ioBroker-Rock                            - disabled
                              system.adapter.dwd.0                    : dwd                   : ioBroker-Rock                            -  enabled
                            + system.adapter.echarts.0                : echarts               : ioBroker-Rock                            -  enabled
                              system.adapter.eusec.0                  : eusec                 : ioBroker-Rock                            - disabled
                              system.adapter.feiertage.0              : feiertage             : ioBroker-Rock                            -  enabled
                              system.adapter.flot.0                   : flot                  : ioBroker-Rock                            -  enabled
                            + system.adapter.heatingcontrol.1         : heatingcontrol        : ioBroker-Rock                            -  enabled
                            + system.adapter.hm-rega.0                : hm-rega               : ioBroker-Rock                            -  enabled
                            + system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker-Rock                            -  enabled, port: 0
                            + system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker-Rock                            -  enabled, port: 0
                            + system.adapter.hm-rpc.2                 : hm-rpc                : ioBroker-Rock                            -  enabled, port: 0
                            + system.adapter.hoover.0                 : hoover                : ioBroker-Rock                            -  enabled
                              system.adapter.ical.0                   : ical                  : ioBroker-Rock                            -  enabled
                              system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: ioBroker-Rock                            -  enabled
                              system.adapter.icons-icons8.0           : icons-icons8          : ioBroker-Rock                            -  enabled
                              system.adapter.icons-material-png.0     : icons-material-png    : ioBroker-Rock                            -  enabled
                              system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker-Rock                            -  enabled
                              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker-Rock                            -  enabled
                              system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBroker-Rock                            -  enabled
                            + system.adapter.influxdb.0               : influxdb              : ioBroker-Rock                            -  enabled, port: 8086
                              system.adapter.iqontrol.0               : iqontrol              : ioBroker-Rock                            - disabled
                            + system.adapter.javascript.0             : javascript            : ioBroker-Rock                            -  enabled
                            + system.adapter.javascript.2             : javascript            : raspberrypi-display1                     -  enabled
                            + system.adapter.javascript.3             : javascript            : raspberrypi-display4                     -  enabled
                            + system.adapter.javascript.4             : javascript            : raspberrypi-display2                     -  enabled
                            + system.adapter.javascript.5             : javascript            : raspberrypi-display5                     -  enabled
                            + system.adapter.midea.0                  : midea                 : ioBroker-Rock                            -  enabled
                              system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker-Rock                            - disabled, port: 54321, bind: 0.0.0.0
                              system.adapter.mihome-vacuum.1          : mihome-vacuum         : ioBroker-Rock                            - disabled, port: 54321, bind: 0.0.0.0
                            + system.adapter.mihome.0                 : mihome                : ioBroker-Rock                            -  enabled, port: 9898, bind: 192.168.3.100
                            + system.adapter.milight-smart-light.0    : milight-smart-light   : ioBroker-Rock                            -  enabled
                            + system.adapter.modbus.0                 : modbus                : ioBroker-Rock                            -  enabled
                            + system.adapter.mqtt.0                   : mqtt                  : ioBroker-Rock                            -  enabled, port: 1886, bind: 0.0.0.0
                            + system.adapter.musiccast.0              : musiccast             : ioBroker-Rock                            -  enabled
                            + system.adapter.nut.0                    : nut                   : ioBroker-Rock                            -  enabled
                            + system.adapter.proxmox.0                : proxmox               : ioBroker-Rock                            -  enabled, port: 8006
                            + system.adapter.rpi2.1                   : rpi2                  : raspberrypi-display1                     -  enabled
                            + system.adapter.rpi2.2                   : rpi2                  : raspberrypi-display2                     -  enabled
                            + system.adapter.rpi2.3                   : rpi2                  : raspberrypi-display3                     -  enabled
                            + system.adapter.rpi2.4                   : rpi2                  : raspberrypi-display4                     -  enabled
                            + system.adapter.rpi2.5                   : rpi2                  : raspberrypi-display5                     -  enabled
                            + system.adapter.sainlogic.0              : sainlogic             : ioBroker-Rock                            -  enabled, port: 45000, bind: 192.168.3.100
                            + system.adapter.scenes.0                 : scenes                : ioBroker-Rock                            -  enabled
                            + system.adapter.shelly.0                 : shelly                : ioBroker-Rock                            -  enabled, port: 1890, bind: 0.0.0.0
                            + system.adapter.shelly.1                 : shelly                : ioBroker-Rock                            -  enabled, port: 1899, bind: 0.0.0.0
                            + system.adapter.shuttercontrol.0         : shuttercontrol        : ioBroker-Rock                            -  enabled
                              system.adapter.simple-api.0             : simple-api            : ioBroker-Rock                            - disabled, port: 8087, bind: 0.0.0.0, run as: admin
                            + system.adapter.smartcontrol.0           : smartcontrol          : ioBroker-Rock                            -  enabled
                            + system.adapter.smartmeter.0             : smartmeter            : ioBroker-Rock                            -  enabled
                            + system.adapter.sonoff.0                 : sonoff                : ioBroker-Rock                            -  enabled, port: 1883, bind: 0.0.0.0
                            + system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker-Rock                            -  enabled
                            + system.adapter.sprinklecontrol.0        : sprinklecontrol       : ioBroker-Rock                            -  enabled
                            + system.adapter.statistics.0             : statistics            : ioBroker-Rock                            -  enabled
                              system.adapter.synology.0               : synology              : ioBroker-Rock                            - disabled, port: 5001
                            + system.adapter.telegram.0               : telegram              : ioBroker-Rock                            -  enabled, port: 8443, bind: 0.0.0.0
                            + system.adapter.text2command.0           : text2command          : ioBroker-Rock                            -  enabled
                              system.adapter.unifi.0                  : unifi                 : ioBroker-Rock                            - disabled
                              system.adapter.vis-bars.0               : vis-bars              : ioBroker-Rock                            -  enabled
                              system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker-Rock                            -  enabled
                              system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBroker-Rock                            -  enabled
                              system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker-Rock                            -  enabled
                              system.adapter.vis-history.0            : vis-history           : ioBroker-Rock                            -  enabled
                              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker-Rock                            -  enabled
                              system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker-Rock                            -  enabled
                            + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker-Rock                            -  enabled
                              system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker-Rock                            -  enabled
                              system.adapter.vis-justgage.0           : vis-justgage          : ioBroker-Rock                            -  enabled
                              system.adapter.vis-keyboard.0           : vis-keyboard          : ioBroker-Rock                            -  enabled
                              system.adapter.vis-material.0           : vis-material          : ioBroker-Rock                            -  enabled
                              system.adapter.vis-metro.0              : vis-metro             : ioBroker-Rock                            -  enabled
                              system.adapter.vis-players.0            : vis-players           : ioBroker-Rock                            -  enabled
                              system.adapter.vis-plumb.0              : vis-plumb             : ioBroker-Rock                            -  enabled
                              system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker-Rock                            -  enabled
                              system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker-Rock                            -  enabled
                              system.adapter.vis-weather.0            : vis-weather           : ioBroker-Rock                            -  enabled
                              system.adapter.vis.0                    : vis                   : ioBroker-Rock                            -  enabled
                              system.adapter.web-speedy.0             : web-speedy            : ioBroker-Rock                            - disabled
                            + system.adapter.web.0                    : web                   : ioBroker-Rock                            -  enabled, port: 8082, bind: 192.168.3.100 (SSL), run as: admin
                            + system.adapter.web.1                    : web                   : ioBroker-Rock                            -  enabled, port: 8083, bind: 192.168.3.100, run as: admin
                            + system.adapter.wolf-smartset.0          : wolf-smartset         : ioBroker-Rock                            -  enabled
                            + system.adapter.worx.0                   : worx                  : ioBroker-Rock                            -  enabled
                            + system.adapter.yamaha.0                 : yamaha                : ioBroker-Rock                            -  enabled
                              system.adapter.yeelight-2.0             : yeelight-2            : ioBroker-Rock                            -  enabled
                              system.adapter.yr.0                     : yr                    : ioBroker-Rock                            -  enabled
                            + system.adapter.zigbee.0                 : zigbee                : ioBroker-Rock                            -  enabled, port: /dev/ttyACM0
                            + instance is alive
                            Adapter    "alarm"        : 3.3.12   , installed 3.3.12
                            Adapter    "cloud"        : 4.4.1    , installed 4.4.1
                            Adapter    "device-watcher": 2.9.3   , installed 2.9.3
                            Adapter    "discovergy"   : 0.5.8    , installed 0.5.8
                            Adapter    "eusec"        : 1.0.0    , installed 1.0.0
                            Adapter    "haier"        : 1.0.4    , installed 1.0.4
                            Adapter    "heatingcontrol": 2.11.1  , installed 2.11.1
                            Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
                            Adapter    "hm-rpc"       : 1.15.18  , installed 1.15.18
                            Adapter    "hoover"       : 0.1.0    , installed 0.1.0
                            Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
                            Controller "js-controller": 5.0.11   , installed 5.0.9  [Updatable]
                            Adapter    "lovelace"     : 3.0.1    , installed 3.0.1
                            Adapter    "midea"        : 0.0.7    , installed 0.0.7
                            Adapter    "mihome"       : 1.4.0    , installed 1.4.0
                            Adapter    "mihome-vacuum": 3.11.0   , installed 3.11.0
                            Adapter    "milight-smart-light": 1.2.2, installed 1.2.2
                            Adapter    "modbus"       : 5.0.11   , installed 5.0.11
                            Adapter    "musiccast"    : 1.1.0    , installed 1.1.0
                            Adapter    "nut"          : 1.6.0    , installed 1.6.0
                            Adapter    "proxmox"      : 1.3.5    , installed 1.3.5
                            Adapter    "sainlogic"    : 0.10.5   , installed 0.10.5
                            Adapter    "shuttercontrol": 1.6.1   , installed 1.6.1
                            Adapter    "smartcontrol" : 1.3.2    , installed 1.3.2
                            Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
                            Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
                            Adapter    "sprinklecontrol": 0.2.13 , installed 0.2.13
                            Adapter    "statistics"   : 2.3.0    , installed 2.3.0
                            Adapter    "synology"     : 2.1.13   , installed 2.1.13
                            Adapter    "unifi"        : 0.6.6    , installed 0.6.6
                            Adapter    "vis-material" : 0.1.3    , installed 0.1.3
                            Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                            Adapter    "web-speedy"   : 0.2.0    , installed 0.2.0
                            Adapter    "wolf-smartset": 1.1.1    , installed 1.1.1
                            Adapter    "worx"         : 2.3.2    , installed 2.3.2
                            Adapter    "yamaha"       : 0.5.3    , installed 0.5.3
                            Adapter    "yeelight-2"   : 1.2.1    , installed 1.2.1
                            Adapter    "yr"           : 5.3.0    , installed 5.3.0
                            Adapter    "zigbee"       : 1.8.19   , installed 1.8.19
                            Objects and States
                            Objects:        34001
                            States:         31411
                            Hit:1 http://de.archive.ubuntu.com/ubuntu jammy InRelease
                            Hit:2 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
                            Hit:3 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
                            Hit:4 http://de.archive.ubuntu.com/ubuntu jammy-security InRelease
                            Hit:5 https://deb.nodesource.com/node_18.x jammy InRelease
                            Pending Updates: 32
                            tcp        0      0 192.168.3.100:8082      0.0.0.0:*               LISTEN      1001       25731      1364/io.web.0
                            tcp        0      0 192.168.3.100:8083      0.0.0.0:*               LISTEN      1001       26065      1665/io.web.1
                            tcp        0      0 192.168.3.100:45000     0.0.0.0:*               LISTEN      1001       25891      1540/io.sainlogic.0
                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          20970      729/sshd: /usr/sbin
                            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          20517      1/init
                            tcp        0      0 192.168.3.100:8701      0.0.0.0:*               LISTEN      1001       23097      1117/io.hm-rpc.1
                            tcp        0      0 192.168.3.100:2010      0.0.0.0:*               LISTEN      1001       23879      1102/io.hm-rpc.2
                            tcp        0      0 192.168.3.100:2001      0.0.0.0:*               LISTEN      1001       25012      1265/io.hm-rpc.0
                            tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       24757      1085/io.mqtt.0
                            tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       24758      1085/io.mqtt.0
                            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       21394      1203/io.sonoff.0
                            tcp        0      0 0.0.0.0:1899            0.0.0.0:*               LISTEN      1001       21227      1070/io.shelly.1
                            tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        22613      675/systemd-resolve
                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       22994      842/io.admin.2
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          20981      729/sshd: /usr/sbin
                            tcp6       0      0 :::111                  :::*                    LISTEN      0          16685      1/init
                            tcp6       0      0 :::8900                 :::*                    LISTEN      1001       23807      969/io.admin.3
                            udp        0      0 0.0.0.0:52119           0.0.0.0:*                           1001       25471      1650/io.milight-sma
                            udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        22612      675/systemd-resolve
                            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          20518      1/init
                            udp        0      0 0.0.0.0:41100           0.0.0.0:*                           1001       27662      1680/io.musiccast.0
                            udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       25117      1325/io.shelly.0
                            udp        0      0 0.0.0.0:9898            0.0.0.0:*                           1001       106986     1299/io.mihome.0
                            udp6       0      0 :::111                  :::*                                0          20519      1/init
                            2023-07-31 21:48:59.895  - info: mqtt.0 (1085) Client [] connection closed: disconnected
                            2023-07-31 21:49:02.149  - info: mqtt.0 (1085) Client [] connected with secret 1690832942136_993
                            2023-07-31 21:49:27.904  - info: sonoff.0 (1203) Client [Durchflusszähler_2] connected with secret 1690832967899_7008
                            2023-07-31 21:50:00.108  - info: host.ioBroker-Rock instance system.adapter.dwd.0 started with pid 31383
                            2023-07-31 21:50:01.463  - info: mqtt.0 (1085) Client [] connection closed: disconnected
                            2023-07-31 21:50:01.678  - info: mqtt.0 (1085) Client [] connected with secret 1690833001676_8269
                            2023-07-31 21:50:04.642  - info: dwd.0 (31383) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.0, js-controller: 5.0.9
                            2023-07-31 21:50:05.880  - info: dwd.0 (31383) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                            2023-07-31 21:50:06.418  - info: host.ioBroker-Rock instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                            2023-07-31 21:50:18.164  - warn: smartmeter.0 (1250) No or too long answer from Serial Device after last request.
                            2023-07-31 21:51:00.962  - info: mqtt.0 (1085) Client [] connection closed: disconnected
                            2023-07-31 21:51:01.240  - info: mqtt.0 (1085) Client [] connected with secret 1690833061240_2410
                            2023-07-31 21:52:00.147  - info: mqtt.0 (1085) Client [] connection closed: disconnected
                            2023-07-31 21:52:00.385  - info: mqtt.0 (1085) Client [] connected with secret 1690833120385_7205
                            2023-07-31 21:52:03.771  - warn: smartmeter.0 (1250) No or too long answer from Serial Device after last request.
                            2023-07-31 21:52:32.329  - info: influxdb.0 (1009) Store 501 buffered influxDB history points
                            2023-07-31 21:52:33.760  - warn: smartmeter.0 (1250) No or too long answer from Serial Device after last request.
                            2023-07-31 21:52:37.762  - warn: smartmeter.0 (1250) No or too long answer from Serial Device after last request.
                            2023-07-31 21:52:58.670  - info: mqtt.0 (1085) Client [] connection closed: disconnected
                            2023-07-31 21:53:00.917  - info: mqtt.0 (1085) Client [] connected with secret 1690833180916_4500
                            2023-07-31 21:53:11.760  - warn: smartmeter.0 (1250) No or too long answer from Serial Device after last request.
                            2023-07-31 21:53:33.766  - warn: smartmeter.0 (1250) No or too long answer from Serial Device after last request.
                            2023-07-31 21:54:00.204  - info: mqtt.0 (1085) Client [] connection closed: disconnected
                            2023-07-31 21:54:00.466  - info: mqtt.0 (1085) Client [] connected with secret 1690833240465_8793
                            2023-07-31 21:54:11.769  - warn: smartmeter.0 (1250) No or too long answer from Serial Device after last request.
                            • E e-i-k-e
                              Skript v.2023-04-16
                              *** BASE SYSTEM ***
                              Docker          : false
                              Release:        22.04
                              Codename:       jammy
                              NAME="Ubuntu"
                              VERSION_ID="22.04"
                              ID=ubuntu
                              ID_LIKE=debian
                              CPU threads: 8
                                            NTP service: active
                                        RTC in local TZ: no
                              pi
                              /home/pi
                              X-Server:       false
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                                       5925 M total memory
                                       4073 M used memory
                                        605 M active memory
                                        534 M free memory
                                        127 M buffer memory
                                       1188 M swap cache
                                       2947 M total swap
                                          0 M used swap
                                       2947 M free swap
                              *** FILESYSTEM ***
                              /var:
                              1.8G    /var/
                              962M    /var/log
                              665M    /var/lib
                              /usr/bin/npm            9.6.7
                              /usr/bin/npx            9.6.7
                              nodejs:
                                Version table:
                              ioBroker Status
                              Objects type: redis
                              States  type: redis
                              admin:          6.6.4
                              javascript:     7.1.1
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        34001
                              States:         31411
                              Pending Updates: 32
                              @e-i-k-e sagte in (gelöst) Beim öffnen der GUI vermehrt Timeouts.:
                              Pending Updates: 32
                              Klopp die rein.
                              Ansonsten seh ich keine dicken Hunde.
                                Pending Updates: 32
                                Klopp die rein.
                                e-i-k-e
                                Erledigt.
                                Wie ist dies zu verstehen?
                                Ich betreibe ein Master/Slave System.
                                • E e-i-k-e
                                  Erledigt.
                                  Die Abfrage hat sich in das Skript verirrt, funktioniert nicht wie gedacht.
                                  Ignorieren.
                                    Ignorieren.
                                    e-i-k-e
                                    Alles klar. ;)
