  5. [gelöst] Payload Daten in Objekte schreiben
78 Beiträge 4 Kommentatoren 9.7k Aufrufe 2 Beobachtet
  • Marc BergM Marc Berg
    @homoran sagte in Payload Daten in Objekte schreiben:
    das ist wohl fett kursiv in rot
    Okay.... Das hat aber im TTN Payload mal so gar nichts verloren! :-)
    GregorSG Offline
    GregorSG Offline
    GregorS
    schrieb am zuletzt editiert von GregorS
    Habe jetzt mal den Payload-Formater aus dem Github bearbeitet.
    {"end_device_ids":{"device_id":"eui-a840414601871305","application_ids":{"application_id":"gs-mg-dragino-01"},"dev_eui":"A840414601871305","join_eui":"A840410000000101","dev_addr":"260BE9CF"},"correlation_ids":["as:up:01H5Z2SA3QYET8CA17EXT5JBTW","gs:conn:01H5CGRTDQJ3EW5BPQ15D9SVP8","gs:up:host:01H5CGRTDY5KEGKQ0AQZ22XD9M","gs:uplink:01H5Z2S9XAF07SYS81675AYS9E","ns:uplink:01H5Z2S9XA7M8VZFX5JQQYWM6H","rpc:/ttn.lorawan.v3.GsNs/HandleUplink:01H5Z2S9XAH04P0Z8XWMYHP6RC","rpc:/ttn.lorawan.v3.NsAs/HandleUplink:01H5Z2SA3P57YV40D8MQMJFC70"],"received_at":"2023-07-22T15:16:43.254682567Z","uplink_message":{"session_key_id":"AYlu5XV3aMaeiMVAq8yISw==","f_port":2,"f_cnt":4272,"frm_payload":"NhUAAAAAAAA0/0E=","decoded_payload":{"ACI1_mA":"0.000", "ACI2_mA":"0.000", "AVI1_V":"13.845", "AVI2_V":"0.000", "Acount_times":null, "Count1_times":null, "Count2_times":null, "DI1_status":"L", "DI2_status":"H", "DI3_status":null, "DO1_status":"H", "DO2_status":"H", "DO3_status":null, "First_status":null, "Hardware_mode":"LT22222", "RO1_status":"OFF", "RO2_status":"OFF", "Work_mode":"2ACI+2AVI"},"rx_metadata":[{"gateway_ids":{"gateway_id":"eui-503139534e7d4750","eui":"503139534E7D4750"},"time":"2023-07-22T15:16:35.538289Z","timestamp":1683586436,"rssi":-104,"channel_rssi":-104,"snr":-15.5,"uplink_token":"CiIKIAoUZXVpLTUwMzEzOTUzNGU3ZDQ3NTASCFAxOVNOfUdQEIT75aIGGgsI2+XvpQYQyq/mFyCgl8ns//2NAQ==","channel_index":4,"received_at":"2023-07-22T15:16:43.049911754Z"}],"settings":{"data_rate":{"lora":{"bandwidth":125000, "spreading_factor":12, "coding_rate":"4/5"}}, "frequency":"867300000", "timestamp":1683586436, "time":"2023-07-22T15:16:35.538289Z"},"received_at":"2023-07-22T15:16:43.050935418Z","consumed_airtime":"1.482752s","version_ids":{"brand_id":"dragino", "model_id":"lt22222-l", "hardware_version":"_unknown_hw_version_", "firmware_version":"1.5.6", "band_id":"EU_863_870"},"network_ids":{"net_id":"000013","tenant_id":"ttn","cluster_id":"eu1","cluster_address":"eu1.cloud.thethings.network"}}}
    Konnte jetzt keine Asterix erkennen.
    Aber schreiben will er immer noch nicht
    INTEL NUC i7, Sonoff, hmIP, AVM, Jeelink, T-Link, Alexa, Saia-Burgess, uvm.
    • GregorSG GregorS
      @gregors sagte: schreiben will er immer noch nicht
      Dann bau mal Log-Ausgaben ein.
      on('mqtt.2.v3.gs-mg-dragino-01@ttn.devices.eui-a840414601871305.up', function (dp) {
          log(dp.state.val);
          let payload = JSON.parse(dp.state.val).uplink_message.decoded_paylod;
          log(payload);
      GregorSG 1 Antwort Letzte Antwort
            log(dp.state.val);
            log(payload);
        GregorSG Offline
        GregorSG Offline
        GregorS
        Habe ich gemacht.
        Wo finde ich das Log?
        • GregorSG GregorS
          Habe ich gemacht.
          @gregors sagte: Wo finde ich das Log?
          Im Fenster unterhalb des Skript-Editors und im Tab "Protokolle".
          Das Skript ist aktiviert und hoffentlich nicht unter der Gruppe "global" erstellt?
            GregorSG Offline
            GregorSG Offline
            GregorS
            Das Script läuft und ist nicht unter "Global".
            Im Log steht nichts drin. Komplett leer.
            Mir scheint, als ob es nicht getriggert wird
            paul53P HomoranH 2 Antworten Letzte Antwort
            • GregorSG GregorS
              @gregors sagte: Mir scheint, als ob es nicht getriggert wird
              Die Datenpunkt-ID des Triggers stimmt? Der Wert (JSON) des Datenpunktes ändert sich?
              • GregorSG GregorS
                @gregors sagte in Payload Daten in Objekte schreiben:
                der Datenpunkt heisst auch genau so:
                  GregorSG Offline
                  GregorSG Offline
                  GregorS
                  Bin auf Objekt-ID gegangen, und er hat mir zur Auswahl das Objekt angeboten.
                  Der Datenpunkt wird alle 2 Minuten neu eingelsen (Zeitstempel). Der Wert von AVI1_V ändert sich immer maginal.
                  • GregorSG GregorS
                    @gregors sagte: Der Wert von AVI1_V ändert sich immer maginal.
                    Das genügt zum Triggern.
                    Was ergibt außerhalb des Triggers?
                    log(getState('mqtt.2.v3.gs-mg-dragino-01@ttn.devices.eui-a840414601871305.up').val);
                      GregorSG Offline
                      GregorSG Offline
                      GregorS
                      Nichts.
                      Gähnende Leere im Log
                      //'mqtt.2.v3.gs-mg-dragino-01@ttn.devices.eui-a840414601871305.up'/*v3/gs-mg-dragino-01@ttn/devices/eui-a840414601871305/up*/
                          log(dp.state.val);
                          log(payload);
                          if(payload && payload.AVI1_V != undefined) {
                      • GregorSG GregorS
                        Nichts.
                            log(dp.state.val);
                            log(payload);
                        @gregors sagte: Gähnende Leere im Log
                        Das Log mit getState() außerhalb des Triggers ausführen!!
                          GregorSG Offline
                          GregorSG Offline
                          GregorS
                          Kann ich das getState() unterhalb des Scripts einfügen, oder muss ich ein Neues Script erstellen?
                          • GregorSG GregorS
                            @gregors sagte: Kann ich das getState() unterhalb des Scripts einfügen
                            Ja, unterhalb oder oberhalb des Triggers.
                              GregorSG Offline
                              GregorSG Offline
                              GregorS
                                  log(dp.state.val);
                                  log(payload);
                                      setState("0_userdata.0.LoRaWAN.eui-a840414601871305.ACI1_mA", Math.round(payload.ACI1_mA * 100) / 100, true);
                                      setState("0_userdata.0.LoRaWAN.eui-a840414601871305.ACI2_mA", Math.round(payload.ACI2_mA * 100) / 100, true);
                                      setState("0_userdata.0.LoRaWAN.eui-a840414601871305.AVI1_V", Math.round(payload.AVI1_V * 100) / 100, true);
                                      setState("0_userdata.0.LoRaWAN.eui-a840414601871305.AVI2_V", Math.round(payload.AVI2_V * 100) / 100, true);
                              • GregorSG GregorS
                                    log(dp.state.val);
                                    log(payload);
                                @gregors
                                Gut, und das JSON ist in der Log-Ausgabe zu sehen? Sie muss beim Skriptstart erzeugt werden.
                                  @gregors
                                  GregorSG Offline
                                  GregorSG Offline
                                  GregorS
                                  Nein, gar nichts
                                  • GregorSG GregorS
                                    Nein, gar nichts
                                    @gregors sagte: Nein, gar nichts
                                    Nicht einmal, dass das Skript gestartet wurde?
                                      GregorSG Offline
                                      GregorSG Offline
                                      GregorS
                                      • GregorSG GregorS
                                        @gregors
                                        Auch nicht im Tab "Protokolle"?
                                          @gregors
                                          GregorSG Offline
                                          GregorSG Offline
                                          GregorS
                                          So sieht die Struktur aus:
