  3. Einsteigerfragen
  4. Nodejs und Vis Probleme
    5.5k
47 Beiträge 4 Kommentatoren 5.6k Aufrufe 3 Beobachtet
    @wurschtbrot
    Das vollständige, 'richtige' log. Gibt es mit
    iob logs --watch
    W Offline
    W Offline
    wurschtbrot
    2023-07-09 20:34:32.842  - error: systeminfo.0 (29931) unhandled promise rejection: Cannot read properties of undefined (reading 'getObjectList')
    2023-07-09 20:34:32.845  - error: systeminfo.0 (29931) TypeError: Cannot read properties of undefined (reading 'getObjectList')
        at MyAdapter.initAdapter (/opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js:44:55)
        at Adapter.<anonymous> (/opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js:118:37)
        at Adapter.emit (node:events:513:28)
        at /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8232:26
    2023-07-09 20:34:32.847  - error: systeminfo.0 (29931) Cannot read properties of undefined (reading 'getObjectList')
    2023-07-09 20:34:33.366  - info: host.iobr22 stopInstance system.adapter.systeminfo.0 (force=false, process=true)
    2023-07-09 20:34:33.372  - info: systeminfo.0 (29931) terminating
    2023-07-09 20:34:33.374  - warn: systeminfo.0 (29931) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2023-07-09 20:34:33.414  - info: systeminfo.0 (29931) Got terminate signal TERMINATE_YOURSELF
    2023-07-09 20:34:33.591  - info: host.iobr22 stopInstance system.adapter.systeminfo.0 send kill signal
    2023-07-09 20:34:33.995  - info: host.iobr22 instance system.adapter.systeminfo.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2023-07-09 20:34:32.795  - info: systeminfo.0 (29931) starting. Version 0.3.1 in /opt/iobroker/node_modules/iobroker.systeminfo, node: v18.16.1, js-controller: 4.0.24
    2023-07-09 20:34:32.840  - error: systeminfo.0 (29931) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2023-07-09 20:34:36.631  - info: host.iobr22 instance system.adapter.systeminfo.0 started with pid 30008
    2023-07-09 20:34:39.474  - info: systeminfo.0 (30008) starting. Version 0.3.1 in /opt/iobroker/node_modules/iobroker.systeminfo, node: v18.16.1, js-controller: 4.0.24
    2023-07-09 20:34:39.515  - error: systeminfo.0 (30008) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2023-07-09 20:34:39.516  - error: systeminfo.0 (30008) unhandled promise rejection: Cannot read properties of undefined (reading 'getObjectList')
    2023-07-09 20:34:39.519  - error: systeminfo.0 (30008) TypeError: Cannot read properties of undefined (reading 'getObjectList')
    2023-07-09 20:34:39.520  - error: systeminfo.0 (30008) Cannot read properties of undefined (reading 'getObjectList')
    2023-07-09 20:34:40.052  - info: systeminfo.0 (30008) terminating
    2023-07-09 20:34:40.053  - warn: systeminfo.0 (30008) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2023-07-09 20:34:40.705  - error: host.iobr22 instance system.adapter.systeminfo.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2023-07-09 20:34:40.707  - info: host.iobr22 Restart adapter system.adapter.systeminfo.0 because enabled
    2023-07-09 20:34:40.708  - warn: host.iobr22 Do not restart adapter system.adapter.systeminfo.0 because restart loop detected
    ich hoffe das reicht so
    • W wurschtbrot
      Zeit
      error
      Nachricht
      host.iobr22
      2023-07-09 20:29:51.605	error	instance system.adapter.systeminfo.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      systeminfo.0
      2023-07-09 20:29:50.394	error	Cannot read properties of undefined (reading 'getObjectList')
      systeminfo.0
      2023-07-09 20:29:50.392	error	TypeError: Cannot read properties of undefined (reading 'getObjectList') at MyAdapter.initAdapter (/opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js:44:55) at Adapter.<anonymous> (/opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js:118:37) at Adapter.emit (node:events:513:28) at /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8232:26
      systeminfo.0
      2023-07-09 20:29:50.389	error	unhandled promise rejection: Cannot read properties of undefined (reading 'getObjectList')
      systeminfo.0
      2023-07-09 20:29:50.388	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      host.iobr22
      2023-07-09 20:29:17.242	error	instance system.adapter.systeminfo.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      systeminfo.0
      2023-07-09 20:29:16.048	error	Cannot read properties of undefined (reading 'getObjectList')
      systeminfo.0
      2023-07-09 20:29:16.046	error	TypeError: Cannot read properties of undefined (reading 'getObjectList') at MyAdapter.initAdapter (/opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js:44:55) at Adapter.<anonymous> (/opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js:118:37) at Adapter.emit (node:events:513:28) at /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8232:26
      systeminfo.0
      2023-07-09 20:29:16.043	error	unhandled promise rejection: Cannot read properties of undefined (reading 'getObjectList')
      systeminfo.0
      2023-07-09 20:29:16.042	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      crunchipC Offline
      crunchipC Offline
      @wurschtbrot https://forum.iobroker.net/post/770008
      W 1 Antwort Letzte Antwort
        W Offline
        W Offline
        wurschtbrot
        @crunchip bin da nicht so fit was genau muss ich da machen
        • W wurschtbrot
          Dürfte das sein:
          https://github.com/iobroker-community-adapters/ioBroker.systeminfo/issues/35
          Wundert mich nur, dass da so lange nichts passiert ist. Der Adapter scheint aber auch verwaist zu sein.
          • W wurschtbrot
            @wurschtbrot
            Ich zitiere mal:
            du musst /opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js öffnen und dort in Zeile 44 das "object." vor dem getObjectList entfernen.
            W crunchipC 2 Antworten Letzte Antwort
              @wurschtbrot
              Ich zitiere mal:
              W Offline
              W Offline
              wurschtbrot
              : No such file or directoryiobroker.systeminfo/myAdapter.js: line 1: /**
              /opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js: line 2: node_modules: command not found
              /opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js: line 3: syntax error near unexpected token `c'
              /opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js: line 3: ` *      (c' 2016- <frankjoke@hotmail.com>
              das kommt dann
              • W wurschtbrot
                das kommt dann
                @wurschtbrot sagte in Nodejs und Vis Probleme:
                das kommt dann
                Wann kommt das? Bitte immer vollständige Eingabezeilen posten.
                  @wurschtbrot
                  Ich zitiere mal:
                  crunchipC Offline
                  crunchipC Offline
                  @thomas-braun finde ich bei mir gar nicht
                  W Thomas BraunT 2 Antworten Letzte Antwort
                    W Offline
                    W Offline
                    wurschtbrot
                    @crunchip
                    pi@iobr22:~ $ /opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js
                    pi@iobr22:~ $
                    • W wurschtbrot
                      @crunchip
                      pi@iobr22:~ $
                      @wurschtbrot
                      Du musst auch einen Editor angeben, mit dem du werkeln willst.
                      nano ist z. B. einer.
                      Oder du installierst den Adapter aus dem github, da dürfte das bereinigt sein.
                        @crunchip
                        Im Master scheint es auch behoben zu sein:
                        https://github.com/iobroker-community-adapters/ioBroker.systeminfo/blob/master/myAdapter.js
                          @crunchip
                          crunchipC Offline
                          crunchipC Offline
                          @thomas-braun bei mir gibt es aber auch kein
                            @crunchip
                            Zu warm? Hast du den Adapter installiert?
                              @crunchip
                              crunchipC Offline
                              crunchipC Offline
                              @thomas-braun ja der Adapter läuft bei mir, hab ihn nur in der Regel aus und schalt gelegentlich die Instanz mal ein
                              gibt vllt mit dem neuen Js-controller/admin nicht mehr
                                @crunchip
                                Hier gibt es das:
                                echad@chet:/opt/iobroker $ ls -lAh /opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js
                                -rw-rw-r--+ 1 iobroker iobroker 25K Jul  9 21:08 /opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js
                                  @crunchip
                                  Hier gibt es das:
                                  crunchipC Offline
                                  crunchipC Offline
                                  @thomas-braun sagte in Nodejs und Vis Probleme:
                                  Zugriff auf '/opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js' nicht möglich: Datei oder Verzeichnis nicht gefunden
                                    :räusper:
                                    wir befinden uns in den Einsteigerfragen!
                                    crunchipC Thomas BraunT 2 Antworten Letzte Antwort
                                      @crunchip
                                      In der Version aus dem Beta-Repo:
                                              this.D(`Adapter ${this.ains} starting.`);
                                              this.getObjectList = this.c2p(adapter.objects.getObjectList).bind(adapter.objects);
                                              this.getForeignState = this.c2p(adapter.getForeignState).bind(adapter);
                                      Da ist der Fehler noch drin.
                                      Github kommt so daher:
                                          static initAdapter() {
                                              states = {};
                                              this.getObjectList = this.c2p(adapter.getObjectList);
                                              this.getForeignState = this.c2p(adapter.getForeignState);
                                              this.setForeignState = this.c2p(adapter.setForeignState);
                                              this.getState = this.c2p(adapter.getState);
                                        :räusper:
                                        crunchipC Offline
                                        crunchipC Offline
                                        @homoran hihi, gar nicht darauf geachtet
                                          :räusper:
                                          @homoran sagte in Nodejs und Vis Probleme:
                                          Ich helf dem @crunchip doch gerade... :-P
