  3. Einsteigerfragen
  4. Ical - Google kalender Error Reading
    5.5k
76 Beiträge 6 Kommentatoren 11.4k Aufrufe 3 Beobachtet
  • E Entraax
    @crunchip said in Ical - Google kalender Error Reading:
    @entraax sagte in Ical - Google kalender Error Reading:
    *** NodeJS-Installation *** /usr/bin/nodejs v16.20.0 /usr/local/bin/node v18.16.0 /usr/local/bin/npm 9.5.1 /usr/local/bin/npx 9.5.1 *** nodejs is NOT correctly installed *** nodejs: Installed: 16.20.0-deb-1nodesource1 Candidate: 16.20.1-deb-1nodesource1 Version table: 16.20.1-deb-1nodesource1 500 500 https://deb.nodesource.com/node_16.x jammy/main amd64 Packages *** 16.20.0-deb-1nodesource1 100 100 /var/lib/dpkg/status 12.22.9~dfsg-1ubuntu3 500 500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
    ist falsch installiert
    https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian/2?_=1688280686179
    Ich habe ein Backup eingespielt.
    Teil 1
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Architecture    : x86_64
    Docker          : false
    Virtualization  : kvm
    Distributor ID: Ubuntu
    Description:    Ubuntu 22.04.2 LTS
    Release:        22.04
    Codename:       jammy
    PRETTY_NAME="Ubuntu 22.04.2 LTS"
    NAME="Ubuntu"
    VERSION_ID="22.04"
    VERSION="22.04.2 LTS (Jammy Jellyfish)"
    VERSION_CODENAME=jammy
    ID=ubuntu
    ID_LIKE=debian
    HOME_URL="https://www.ubuntu.com/"
    SUPPORT_URL="https://help.ubuntu.com/"
    BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
    PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-poli        cy"
    UBUNTU_CODENAME=jammy
    Systemuptime and Load:
     18:18:03 up 0 min,  2 users,  load average: 0.30, 0.08, 0.02
    CPU threads: 2
    *** Time and Time Zones ***
                   Local time: Sun 2023-07-02 18:18:03 UTC
               Universal time: Sun 2023-07-02 18:18:03 UTC
                     RTC time: Sun 2023-07-02 18:18:03
                    Time zone: Etc/UTC (UTC, +0000)
    System clock synchronized: no
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    admin123
    /home/admin123
    admin123 adm cdrom sudo dip plugdev lxd iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            2.0G        249M        1.3G        1.0M        366M        1.6G
    Swap:           1.8G          0B        1.8G
    Total:          3.8G        249M        3.2G
             1963 M total memory
              249 M used memory
              102 M active memory
              345 M inactive memory
             1347 M free memory
               27 M buffer memory
              339 M swap cache
             1840 M total swap
                0 M used swap
             1840 M free swap
    *** FILESYSTEM ***
    Filesystem                        Type   Size  Used Avail Use% Mounted on
    tmpfs                             tmpfs  197M  1.1M  196M   1% /run
    /dev/mapper/ubuntu--vg-ubuntu--lv ext4    18G  7.2G  9.9G  43% /
    tmpfs                             tmpfs  982M     0  982M   0% /dev/shm
    tmpfs                             tmpfs  5.0M     0  5.0M   0% /run/lock
    /dev/sda2                         ext4   1.8G  252M  1.4G  16% /boot
    tmpfs                             tmpfs  197M  4.0K  197M   1% /run/user/1000
    [Sun Jul  2 18:17:32 2023] EXT4-fs (dm-0): mounted filesystem with ordered data        mode. Opts: (null). Quota mode: none.
    [Sun Jul  2 18:17:32 2023] EXT4-fs (dm-0): re-mounted. Opts: (null). Quota mode:        none.
    [Sun Jul  2 18:17:34 2023] EXT4-fs (sda2): mounted filesystem with ordered data        mode. Opts: (null). Quota mode: none.
    TARGET              SOURCE                            FSTYPE   OPTIONS
    /                   /dev/mapper/ubuntu--vg-ubuntu--lv ext4     rw,relatime
    |-/snap/snapd/19457 /dev/loop2                        squashfs ro,nodev,relatime        ,errors=continue
    |-/snap/lxd/24322   /dev/loop0                        squashfs ro,nodev,relatime        ,errors=continue
    |-/snap/snapd/18357 /dev/loop1                        squashfs ro,nodev,relatime        ,errors=continue
    |-/snap/core20/1822 /dev/loop3                        squashfs ro,nodev,relatime        ,errors=continue
    |-/snap/core20/1950 /dev/loop4                        squashfs ro,nodev,relatime        ,errors=continue
    |-/snap/lxd/22923   /dev/loop5                        squashfs ro,nodev,relatime        ,errors=continue
    `-/boot             /dev/sda2                         ext4     rw,relatime
    /var:
    1.1G    /var/
    731M    /var/lib
    532M    /var/lib/snapd
    422M    /var/lib/snapd/snaps
    225M    /var/cache
    Archived and active journals take up 104.0M in the file system.
    /opt/iobroker/backups:
    4.0K    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    141M    /opt/iobroker/iobroker-data/
    105M    /opt/iobroker/iobroker-data/files
    52M     /opt/iobroker/iobroker-data/files/javascript.admin
    34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
    33M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    7.1M    /opt/iobroker/iobroker-data/objects.jsonl
    6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.312d98a        8.chunk.js.map
    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-n        ode_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_        iobr-99c23e.847b8ad9.chunk.js.map
    5.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/44.59b48e42        .chunk.js.map
    5.6M    /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    /usr/bin/nodejs         v16.20.1
    /usr/bin/node           v16.20.1
    /usr/bin/npm            8.19.4
    /usr/bin/npx            8.19.4
    nodejs:
      Installed: 16.20.1-deb-1nodesource1
      Version table:
     *** 16.20.1-deb-1nodesource1 500
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     7.0.3
    Adapters from github:   0
    Adapter State
      system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 192.168.30.5 (SSL), run as: admin
      system.adapter.alexa2.0                 : alexa2                : iobroker                                 - disabled
      system.adapter.backitup.0               : backitup              : iobroker                                 - disabled
      system.adapter.daswetter.0              : daswetter             : iobroker                                 - disabled
      system.adapter.device-reminder.0        : device-reminder       : iobroker                                 - disabled
      system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
      system.adapter.hm-rega.0                : hm-rega               : iobroker                                 - disabled
      system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 - disabled, port: 0
      system.adapter.ical.0                   : ical                  : iobroker                                 - disabled
      system.adapter.influxdb.0               : influxdb              : iobroker                                 - disabled, port: 8086
      system.adapter.javascript.0             : javascript            : iobroker                                 - disabled
      system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 - disabled, port: 54321
      system.adapter.mqtt-client.0            : mqtt-client           : iobroker                                 - disabled, port: 1883
      system.adapter.nuki.0                   : nuki                  : iobroker                                 - disabled
      system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 - disabled
      system.adapter.trashschedule.0          : trashschedule         : iobroker                                 - disabled
      system.adapter.vis.0                    : vis                   : iobroker                                 - disabled
      system.adapter.web.0                    : web                   : iobroker                                 - disabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
    Adapter    "backitup"     : 2.6.23   , installed 2.6.23
    Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
    Adapter    "device-reminder": 1.2.9  , installed 1.2.9
    Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
    Adapter    "hm-rpc"       : 1.15.18  , installed 1.15.18
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "javascript"   : 7.0.3    , installed 7.0.3
    Adapter    "mihome-vacuum": 3.11.0   , installed 3.11.0
    Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
    Adapter    "nuki"         : 1.6.0    , installed 1.6.0
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Objects and States
    Objects:        846
    States:         590
    Hit:1 http://de.archive.ubuntu.com/ubuntu jammy InRelease
    Hit:2 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
    Hit:3 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
    Hit:4 https://deb.nodesource.com/node_16.x jammy InRelease
    Hit:5 http://de.archive.ubuntu.com/ubuntu jammy-security InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          17954      1/init
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          21387      680/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       21950      628/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       21830      628/iobroker.js-con
    tcp        0      0 192.168.30.5:8081       0.0.0.0:*               LISTEN      1001       23647      1216/io.admin.0
    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        20811      609/systemd-resolve
    tcp6       0      0 :::111                  :::*                    LISTEN      0          17960      1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          21405      680/sshd: /usr/sbin
    udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        20810      609/systemd-resolve
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          17957      1/init
    udp6       0      0 :::111                  :::*                                0          17963      1/init
    2023-07-02 18:17:47.809  - info: host.iobroker Delete state "system.host.iobroker.versions.nodeCurrent"
    2023-07-02 18:17:47.810  - info: host.iobroker 18 instances found
    2023-07-02 18:17:47.832  - info: host.iobroker starting 1 instance
    2023-07-02 18:17:47.886  - info: host.iobroker Delete state "system.host.iobroker.versions.nodeNewest"
    2023-07-02 18:17:47.936  - info: host.iobroker instance system.adapter.admin.0 started with pid 852
    2023-07-02 18:17:47.946  - info: host.iobroker Delete state "system.host.iobroker.versions.nodeNewestNext"
    2023-07-02 18:17:48.011  - info: host.iobroker Delete state "system.host.iobroker.versions.npmCurrent"
    2023-07-02 18:17:48.056  - info: host.iobroker Delete state "system.host.iobroker.versions.npmNewest"
    2023-07-02 18:17:48.101  - info: host.iobroker Delete state "system.host.iobroker.versions.npmNewestNext"
    2023-07-02 18:17:48.145  - info: host.iobroker Some obsolete host states deleted.
    2023-07-02 18:17:48.666  - error: admin.0 (852) admin.0 already running
    2023-07-02 18:17:48.667  - warn: admin.0 (852) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-07-02 18:17:49.188  - error: host.iobroker instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-07-02 18:17:49.188  - info: host.iobroker Restart adapter system.adapter.admin.0 because enabled
    2023-07-02 18:18:20.345  - info: host.iobroker instance system.adapter.admin.0 started with pid 1216
    2023-07-02 18:18:20.982  - info: admin.0 (1216) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v16.20.1, js-controller: 4.0.24
    2023-07-02 18:18:21.025  - info: admin.0 (1216) requesting all states
    2023-07-02 18:18:21.025  - info: admin.0 (1216) requesting all objects
    2023-07-02 18:18:21.194  - info: admin.0 (1216) Request actual repository...
    2023-07-02 18:18:21.353  - info: admin.0 (1216) received all objects
    2023-07-02 18:18:21.526  - info: host.iobroker Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2023-07-02 18:18:21.597  - info: admin.0 (1216) https server listening on port 8081
    2023-07-02 18:18:21.598  - info: admin.0 (1216) Use link "https://localhost:8081" to configure.
    2023-07-02 18:18:21.601  - info: admin.0 (1216) Secure socket.io server listening on port 8081
    2023-07-02 18:18:22.517  - info: admin.0 (1216) Repository received successfully.
    Teil 2
                         v.2023-04-16
    Operatingsystem:        Ubuntu 22.04.2 LTS
    Kernel:                 5.15.0-76-generic
    Installation:           kvm
    Timezone:               Etc/UTC (UTC, +0000)
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     0
    Pending iob updates:    0
    Nodejs-Installation:    /usr/bin/nodejs         v16.20.1
                            /usr/bin/npm            8.19.4
                            /usr/bin/npx            8.19.4
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:            2.0G        313M        960M        1.0M        689M        1.5G
    Swap:           1.8G          0B        1.8G
    Total:          3.8G        313M        2.8G
    Active iob-Instances:   2
    ioBroker Core:          js-controller           4.0.24
                            admin                   6.3.5
    Objects type: jsonl
    States  type: jsonl
    + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 192.168.30.5 (SSL), run as: admin
    Objects:                846
    States:                 590
    Size of iob-Database:
    2.7M    /opt/iobroker/iobroker-data/states.jsonl
    Es kommt immer noch die Fehlermeldung im Log.
    @bahnuhr said in Ical - Google kalender Error Reading:
    Bei mir steht es so.
    Das ist nicht hilfreich.
    Und so kommen wir auch nicht weiter.
    Ich bin jetzt raus.
    Kannst du mir dann zeigen, wie du das machts mit einem neuen Kalender?
    bahnuhrB Online
    bahnuhrB Online
    bahnuhr
    Danke.
    E 1 Antwort Letzte Antwort
    • haselchenH haselchen
      @entraax
      Was ist dieses group.calendar.google.com?
      Hat mich vorhin schon stutzig gemacht. In der URL ist die Googlemail Adresse mit drin.
      Bei dir kommt das mit dem group.calendar.....
      crunchipC Offline
      crunchipC Offline
      @haselchen sagte in Ical - Google kalender Error Reading:
      hab grad meinen link vom Müllkalender angesehen, bei mir ist das auch im Link enthalten
      .....%40group.calendar.google.com/private-......
      • bahnuhrB bahnuhr
        Entraax
        schrieb am zuletzt editiert von Entraax
        #66
        Genau so habe ich es gemacht gehabt.
        Okay, dann ist es bei mir nicht falsch mit Group.calendar
        Ich habe es eben nochmal auf einen anderen IoBroker getestet, der läuft auf einen Raspberry Pi noch. Es kommt dort ebenfalls die selbe Fehlermeldung.
        • E Offline
          Entraax
          #67
          Ich habe auch noch eine separate Firewall nach meiner Fritzbox. Im Log ist eine IP-Adresse und Port zu sehen. Ist das zufällig die IP:Port für den google Kalender?
          2023-07-02 06:44:02.860	debug	States connected to redis: 127.0.0.1:9000
          Ich konnte vom IoBroker bzw. VM die IP-Adresse anpingen. Ich frage mich, ob ich noch zusätzlich den Port freigeben muss in der Firewall?
          • E Entraax
            bahnuhrB Online
            bahnuhrB Online
            bahnuhr
            #68
            @entraax
            warum beta ?
            warum redis ?
            warum extra firewall hinter fritzbox (fritz hat doch eine, oder nicht ?)
            Port freigeben ! (macht man sowas ?)
            Danke.
            • crunchipC Offline
              crunchipC Offline
              #69
              @entraax das ist die interne redis Datenbank des js-controllers
              @bahnuhr sagte in Ical - Google kalender Error Reading:
              warum redis ?
              kein redis, redis wäre Port 6379
                warum redis ?
                bahnuhrB Online
                bahnuhrB Online
                bahnuhr
                #70
                @crunchip sagte in Ical - Google kalender Error Reading:
                steht aber doch da
                ..... States connected to redis: .....
                Danke.
                • bahnuhrB bahnuhr
                  steht aber doch da
                  crunchipC Offline
                  crunchipC Offline
                  #71
                  @bahnuhr
                  Da auch die ioBroker eigenen Datenbanken das Redis-Protokoll für die Kommunikation nutzen, kann es manchmal verwirren, wenn man im Log etwas von Redis liest. So lange dabei aber Port 9000/9001 genannt sind deutet auf die interne Datenbank hin und hat nichts mit der externen Redis Datenbank zu tun.
                  https://www.iobroker.net/#de/documentation/config/redis.md
                  • bahnuhrB bahnuhr
                    @entraax
                    warum beta ?
                    warum redis ?
                    Entraax
                    #72
                    @entraax
                    warum beta ?
                    warum redis ?
                    Ich habe ein altes Backup reingespielt, wie oben geschrieben (auch im iob Diag), bin ich wieder bei Stable.
                    Ich habe hinter der Ubiquiti UDM-Pro diverse Netzwerke, diverse access point und später Kameras. Das spielt aber keine Rolle hier beim Problem.
                    Das mit dem Port freigaben war nur noch eine Idee, da es auf dem PI4 (Produktionsumgebung noch) auch nicht geht und ebenfalls hinter UDM hängt. Es ist dort ebenfalls auf Stable.
                    Achso, danke für die Info.
                      @bahnuhr
                      bahnuhrB Online
                      bahnuhrB Online
                      bahnuhr
                      #73
                      Danke für die Info.
                      Danke.
                      • E Offline
                        Entraax
                        #74
                        Ich habe den Fehler gefunden. Danke für eure Hilfe, jetzt geht es.
                        • E Entraax
                          #75
                          und der war was?
                            und der war was?
                            Entraax
                            #76
                            @homoran said in Ical - Google kalender Error Reading:
                            und der war was?
                            Ich habe noch einen AdGuard im Netzwerk, der hat es raus geblockt. Ich hätte darauf selber kommen können, jedoch habe ich nicht an ihn gedacht.
                            Trotzdem vielen Dank.
