  4. [HowTo] ioBroker Restore unter Linux durchführen
    6.7k
restorerestore backupbackituphow-to
527 Beiträge 80 Kommentatoren 198.9k Aufrufe 76 Beobachtet
  • H Habedere
    hier nochmal neu - obdiag
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Architecture    : x86_64
    Docker          : false
    Virtualization  : lxc
    Distributor ID: Debian
    Description:    Debian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     21:54:02 up 6 min,  1 user,  load average: 0.13, 0.11, 0.08
    CPU threads: 8
    *** Time and Time Zones ***
                   Local time: Tue 2023-06-27 21:54:03 CEST
               Universal time: Tue 2023-06-27 19:54:03 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** User and Groups ***
    admin
    /home/admin
    admin adm sudo iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            4.1G        127M        2.9G        0.0K        1.1G        4.0G
    Swap:           512M          0B        512M
    Total:          4.6G        127M        3.4G
             4096 M total memory
              127 M used memory
              229 M active memory
              942 M inactive memory
             2851 M free memory
                0 M buffer memory
             1117 M swap cache
              512 M total swap
                0 M used swap
              512 M free swap
    *** FILESYSTEM ***
    Filesystem                       Type   Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--100--disk--1 ext4    63G  2.3G   57G   4% /
    none                             tmpfs  492K  4.0K  488K   1% /dev
    tmpfs                            tmpfs  7.8G     0  7.8G   0% /dev/shm
    tmpfs                            tmpfs  3.1G  132K  3.1G   1% /run
    tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
    tmpfs                            tmpfs  1.6G     0  1.6G   0% /run/user/1000
    [Mon Jun 19 16:20:05 2023] EXT4-fs (dm-1): mounted filesystem with ordered data        mode. Opts: (null). Quota mode: none.
    [Mon Jun 19 16:20:06 2023] EXT4-fs (dm-1): re-mounted. Opts: errors=remount-ro.        Quota mode: none.
    [Tue Jun 27 18:40:35 2023] EXT4-fs (dm-6): mounted filesystem with ordered data        mode. Opts: (null). Quota mode: none.
    [Tue Jun 27 20:47:38 2023] EXT4-fs (dm-6): mounted filesystem with ordered data        mode. Opts: (null). Quota mode: none.
    [Tue Jun 27 20:52:55 2023] EXT4-fs warning (device dm-6): ext4_multi_mount_prote        ct:326: MMP interval 42 higher than expected, please wait.
    [Tue Jun 27 20:53:40 2023] EXT4-fs (dm-6): 1 orphan inode deleted
    [Tue Jun 27 20:53:40 2023] EXT4-fs (dm-6): recovery complete
    [Tue Jun 27 20:53:40 2023] EXT4-fs (dm-6): mounted filesystem with ordered data        mode. Opts: (null). Quota mode: none.
    [Tue Jun 27 21:46:42 2023] EXT4-fs warning (device dm-6): ext4_multi_mount_prote        ct:326: MMP interval 42 higher than expected, please wait.
    [Tue Jun 27 21:47:26 2023] EXT4-fs (dm-6): 1 orphan inode deleted
    [Tue Jun 27 21:47:26 2023] EXT4-fs (dm-6): recovery complete
    [Tue Jun 27 21:47:26 2023] EXT4-fs (dm-6): mounted filesystem with ordered data        mode. Opts: (null). Quota mode: none.
    TARGET SOURCE                           FSTYPE OPTIONS
    /      /dev/mapper/pve-vm--100--disk--1 ext4   rw,relatime,stripe=16
    /var:
    409M    /var/
    224M    /var/cache
    220M    /var/cache/apt
    153M    /var/cache/apt/archives
    136M    /var/lib
    Archived and active journals take up 48.0M in the file system.
    /opt/iobroker/backups:
    392M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    33M     /opt/iobroker/iobroker-data/
    15M     /opt/iobroker/iobroker-data/files
    13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
    17M     /opt/iobroker/iobroker-data/objects.jsonl
    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-n        ode_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_        iobr-99c23e.847b8ad9.chunk.js.map
    2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-n        ode_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_        iobr-99c23e.847b8ad9.chunk.js
    1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-n        ode_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionD        etai-57e02d.0886b730.chunk.js.map
    1.5M    /opt/iobroker/iobroker-data/states.jsonl
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.16.1
    /usr/bin/node           v18.16.1
    /usr/bin/npm            9.5.1
    /usr/bin/npx            9.5.1
    nodejs:
      Installed: 18.16.1-deb-1nodesource1
      Candidate: 18.16.1-deb-1nodesource1
      Version table:
     *** 18.16.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://security.debian.org bullseye-security/main amd64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://ftp.debian.org/debian bullseye/main amd64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
     Cannot read system.config: null (OK when migrating or restoring)
    Objects type: file
    States  type: redis
    Uncaught Rejection: Error: Cannot find view "system"
        at ObjectsInRedisClient._getObjectView (/opt/iobroker/node_modules/@iobroker        /db-objects-redis/lib/objects/objectsInRedisClient.js:3841:59)
        at process.processTicksAndRejections (node:internal/process/task_queues:95:5        )
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     "javascript" not found
    Adapters from github:   0
    Adapter State
    + instance is alive
    ioBroker-Repositories
    List is empty
    Installed ioBroker-Instances
    Error: Object "system.config" not found
    Objects and States
    Objects:        33
    States:         25
    Hit:1 http://ftp.debian.org/debian bullseye InRelease
    Hit:2 http://security.debian.org bullseye-security InRelease
    Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
    Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      109        8072231    1813/redis-server 1
    tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      104        8047162    108/systemd-resolve
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          8047223    313/master
    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      104        8047168    108/systemd-resolve
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       8070683    1945/iobroker.js-co
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          8054435    1/init
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          8047224    313/master
    tcp6       0      0 :::5355                 :::*                    LISTEN      104        8047165    108/systemd-resolve
    tcp6       0      0 ::1:6379                :::*                    LISTEN      109        8072232    1813/redis-server 1
    tcp6       0      0 :::111                  :::*                    LISTEN      0          8047060    1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          8052412    1/init
    udp        0      0 0.0.0.0:5355            0.0.0.0:*                           104        8047161    108/systemd-resolve
    udp        0      0 127.0.0.53:53           0.0.0.0:*                           104        8047167    108/systemd-resolve
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          8056836    1/init
    udp6       0      0 :::5355                 :::*                                104        8047164    108/systemd-resolve
    udp6       0      0 :::111                  :::*                                0          8055870    1/init
    2023-06-27 21:53:46.393  - info: host.IoBroker received SIGTERM
    2023-06-27 21:53:46.396  - info: host.IoBroker iobroker exit null
    2023-06-27 21:53:46.397  - warn: host.IoBroker get state error: Connection is closed.
    2023-06-27 21:53:46.398  - info: host.IoBroker terminated
    2023-06-27 21:53:47.393  - info: host.IoBroker iobroker.js-controller version 4.0.24 js-controller starting
    2023-06-27 21:53:47.395  - info: host.IoBroker Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2023-06-27 21:53:47.395  - info: host.IoBroker hostname: IoBroker, node: v18.16.1
    2023-06-27 21:53:47.395  - info: host.IoBroker ip addresses: 192.168.178.100 fdc8:6d06:a691:4a6d:f434:68ff:fe39:49bc fe80::f434:68ff:fe39:49bc
    2023-06-27 21:53:47.462  - error: host.IoBroker Cannot read system.config: null (OK when migrating or restoring)
    2023-06-27 21:53:47.508  - error: host.IoBroker Cannot find view "system" for search "host"
    2023-06-27 21:53:47.521  - info: host.IoBroker connected to Objects and States
    2023-06-27 21:53:47.524  - info: host.IoBroker Node.js version has changed from unknown to 18.16.1
    2023-06-27 21:53:47.533  - info: host.IoBroker added notifications configuration of host
    2023-06-27 21:53:47.534  - error: host.IoBroker Cannot find view "system" for search "instance"
    2023-06-27 21:53:47.534  - error: host.IoBroker Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
    2023-06-27 21:53:47.537  - info: host.IoBroker Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2023-06-27 21:53:47.538  - info: host.IoBroker Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
    2023-06-27 21:53:47.539  - error: host.IoBroker Cannot find view "system" for search "host"
    2023-06-27 21:53:47.604  - error: host.IoBroker Cannot find view "system" for search "state"
    2023-06-27 21:53:47.604  - error: host.IoBroker Cannot find view "system" for search "instance"
    2023-06-27 21:53:47.605  - error: host.IoBroker Could not collect system.host.IoBroker states to check for obsolete states: Error: Cannot find view "system"
    2023-06-27 21:53:47.605  - error: host.IoBroker  _design/system missing - call node iobroker.js setup
    2023-06-27 21:53:47.605  - info: host.IoBroker  no instances found
    2023-06-27 21:53:47.751  - info: host.IoBroker Created UUID: 0f610e92-bb95-3196-4662-047ef0e42f92
    den ext4 Fehler bekomme ich nicht weg :(
    hier noch iob setup custom config
    Current configuration:
    - Objects database:
      - Type: file
      - Host/Unix Socket: 127.0.0.1
      - Port: 9001
    - States database:
      - Type: redis
      - Port: 6379
    - Data Directory: ../../iobroker-data/
    hatte da beim letzten mal auf redis umgestellt wenn ich mich nicht irre
    #454
    @habedere sagte in [HowTo] ioBroker Restore unter Linux durchführen:
    Kann es sein, dass du da irgendwas doppelt mountest?
    Das wäre dann allerdings komplett OT hier in diesem HowTo.
    H 1 Antwort Letzte Antwort
      Habedere
      schrieb am zuletzt editiert von Habedere
      #455
      Nicht dass ich wüsste. Weiß nicht mal ob ich das Problem über das Backup rein gezogen habe. Hätte ich vorher mal testen sollen.
      Evtl kommt das vom Snapshot Rollback. Kenne mich da ebenso wenig aus und hangel mich da überall durch :) nicht schön - aber klappt meistens
      Jetzt muss ich noch Objects Database Filetyp auf Redis umstellen oder?
      • Thomas BraunT Online
        #456
        @habedere
        Jedenfalls sehe ich bei anderen LXC solche Meldungen nicht:
        [Tue Jun 27 20:52:55 2023] EXT4-fs warning (device dm-6): ext4_multi_mount_protect:326: MMP interval 42 higher than expected, please wait.
        Da ist bestimmt irgendwas falsch.
        Nein, man kann auch file/redis fahren.
          @habedere
          Habedere
          #457
          Ok danke. Hmm leider springt die Kiste immer noch nicht an…
          + instance is alive
          Hast du eine Idee was ich probieren könnte?
          • H Habedere
            + instance is alive
            #458
            @habedere
            Schau mal ob du damit weiterkommst:
            https://forum.iobroker.net/topic/43325/mini-howto-cannot-find-view-system-for-search-host?_=1687976199911
              @habedere
              Habedere
              #459
              Nicht wirklich…
              admin@IoBroker:~$ ls -lh /opt/iobroker/iobroker-data/backup-objects/ | grep objects
              -rw-rw-r--+ 1 iobroker iobroker   64 Jun 27 21:51 2023-06-27_21-51_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 3.6K Jun 27 21:53 2023-06-27_21-53_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 3.6K Jun 28 20:14 2023-06-28_20-14_objects.json.gz
              Bei den States kommt garnichts…
              • H Habedere
                Nicht wirklich…
                #460
                @habedere
                Dann weiß ich auch nicht.
                • H Offline
                  Habedere
                  #461
                  Schade - aber trotzdem vielen Dank!
                  Gute Nachricht -> ich habe ein etwas älteres Backup verwendet - das hat geklappt! jetzt nur noch die DatenBackups einspielen...
                  PS: beim komplett neu aufgesetzten, Snapshot zurück gesetzten ioBroker ist beim Diag wieder der ext4 Fehler drin
                  • H Habedere
                    #462
                    Von Containern hab ich keine Ahnung. Sieht aber für mich nach etwas aus, das man sich mal anschauen sollte.
                    • H Habedere
                      crunchipC Offline
                      crunchipC Offline
                      #463
                      @habedere das liegt wohl an deinem snapshot zurück spielen disk1, normal wäre disk0
                      Bin aber gerade nur am Handy
                        Habedere
                        #464
                        @crunchip
                        ahh ok - die wichtigste Frage - ist das schlimm?! bzw. kann ich das so lassen?
                        würde gerade laufen - zumindest grob ;)
                        • H Habedere
                          @crunchip
                          #465
                          @habedere
                          Gelöschte inodes sind schlimm.
                            ticaki
                            #466
                            Hallo, ziehe langsam mit meinem iobroker um von pi4 auf nuc beelink(proxmox). Beim restore von redis bekomme ich
                            "Not configured"
                            als Meldung und nichts passiert. Oder ist redis wurscht?
                            At least one iobroker host is running.
                            Objects type: redis
                            States  type: redis
                            Spenden
                            • crunchipC Offline
                              crunchipC Offline
                              #467
                              @ticaki der pi lief mit redis/redis?
                              dann musst du bei deinem beelink ebenfalls vor dem restore redis installieren und glaub auch umstellen bevor du dann das backup einspielst
                                ticaki
                                #468
                                @crunchip
                                der Pi läuft problemlos... bin ja nicht blöd :)
                                -redis ist installiert, ist umgestellt,
                                -iobroker backup ist drin,
                                -https läuft
                                -die hälfte der Adapter ist grün
                                Ich mache einen Adapter nach dem anderen grün und ein paar kann ich erst wenn alles fürs umschalten vorbereitet ist testen.
                                Im Moment frage ich mich ob das redis backup wichtig ist. Hab glaube ich keine Dateien im ioBroker abgelegt, dann sollte es doch egal sein oder?
                                Spenden
                                • T ticaki
                                  @crunchip
                                  -https läuft
                                  #469
                                  @ticaki
                                  In der redis-Datenbank werden die States / Objects abgelegt.
                                  • T ticaki
                                    @crunchip
                                    -https läuft
                                    crunchipC Offline
                                    crunchipC Offline
                                    #470
                                    @ticaki sagte in [HowTo] ioBroker Restore unter Linux durchführen:
                                    @thomas-braun sagte in [HowTo] ioBroker Restore unter Linux durchführen:
                                    wenn du den iobroker installierst, steht er ja default auf jsonl, daher musst du auf redis umstellen dein backup einspielen und auch den restore der Datenbank vollziehen
                                      ticaki
                                      #471
                                      @crunchip
                                      Objects type: redis
                                      States  type: redis
                                      ist umgestellt, daher verstehe ich die Fehlermeldung eben nicht.
                                      Spenden
                                      • T ticaki
                                        @crunchip
                                        Objects type: redis
                                        States  type: redis
                                        crunchipC Offline
                                        crunchipC Offline
                                        #472
                                        @ticaki läuft redis mit darauf oder separat?
                                        https://www.iobroker.net/#de/documentation/config/redis.md
                                          ticaki
                                          #473
                                          @crunchip
                                          redis in der gleichen Instanz also Pi gleicher Rechner/proxmox gleicher container
                                          Spenden
