  4. jarvis v3.1.x - just another remarkable vis
1.9k Beiträge 94 Kommentatoren 927.0k Aufrufe 77 Beobachtet
    marsmännchen
    schrieb am zuletzt editiert von marsmännchen
    #851
    @mcu
    Hallo @MCU
    Wenn ich das Script zum erstellen von den DPs für timeTable:
    // Anlegen der Objekt für ein WochenTimeTable
    // timeTable v1.0.0
    // Copyright ©MCU
    let timeTableDP = '0_userdata.0.jarvis.timeTable';
    let weekDP      = timeTableDP + '.week';
    let weekArr = ['monday','tuesday','wednesday','thursday','friday','saturday','sunday'];
    let dpArr       = [{'name':'activeOn','text':'Tag aktivieren'   ,'type':'boolean','initial':false},
                       {'name':'timeOn'  ,'text':'Zeit einschalten' ,'type':'string' ,'initial':''},
                       {'name':'timeOff' ,'text':'Zeit ausschalten' ,'type':'string' ,'initial':''},
                       {'name':'duration','text':'Zeit Dauer'       ,'type':'number' ,'initial':0},
                       {'name':'option'  ,'text':'Kanten aktivieren','type':'boolean','initial':false},
                       {'name':'worked'  ,'text':'Genutzt'          ,'type':'boolean','initial':false}]
    let selektorOffDPs = '0_userdata.0.jarvis.timeTable.week.*.timeOff';
    let selektorOnDPs  = '0_userdata.0.jarvis.timeTable.week.*.timeOn';
    let todayDP        = weekDP + '.today';
    createStateAsync(todayDP,{read: true, write: true, name: 'Heute' , type: 'string', role: "", def: ''});
    // jeden Tag um 00:01 Uhr Tagesnamen setzen
    schedule('1 0 * * *', async function () {
      todaySetDP();
    function todaySetDP(){
        let dateNow = new Date();
        let dateDay  = getDateObject(dateNow).getDay();
        //log(dateDay); // 0 = Su, 1=Mo, 2=Di, 3=Mi, 4=Do 5=Fr 6=Sa usw.
        let dateStr = '';
        if (dateDay == 0){
            dateStr=weekArr[6];
        }else {
            dateStr=weekArr[dateDay-1];
        setState(todayDP, dateStr, false);
    //createDPs();
    function createDPs(){
        for (let day in weekArr){
            let x = parseInt(day) +1;
            log(x +' ' +weekArr[day]);
            for (let dp in dpArr){
                //log(dpArr[dp].name);
                let dpCreate = weekDP+'.'+ x +'_'+weekArr[day]+'.'+dpArr[dp].name;
                //log(weekDP+'.'+weekArr[day]+'.'+dpArr[dp].name);
                let nameCreate = dpArr[dp].text;
                //log(dpArr[dp].text);
                let typeCreate = dpArr[dp].type;
                //log(typeCreate);
                let defCreate = dpArr[dp].initial;
                log(dpCreate +' - '+nameCreate+' - ' + typeCreate+' - '+defCreate);
                createStateAsync(dpCreate,{read: true, write: true, name: nameCreate , type: typeCreate, role: "", def: defCreate});
            //break;
    $(selektorOnDPs).on(function (obj) {
        //let value = obj.state.val;
        //log(obj.channelId);
        duration(obj.channelId);
    $(selektorOffDPs).on(function (obj) {
    function duration(channelid){
        let timeOn = getState(channelid+'.timeOn').val;
        let timeOff = getState(channelid+'.timeOff').val;
        //log(timeOn +' - '+ timeOff);
        let dateOn = getDateObject(timeOn).getTime();
        let dateOff = getDateObject(timeOff).getTime();
        let diffDate = (dateOff - dateOn)/60000; // minutes
        //log (dateOn + ' - '+ dateOff + ' - '+diffDate);
        setStateAsync(channelid+'.duration',diffDate,false);
    starte, wird bei mir nur der Datenpunkt "0_userdata.0.jarvis.timeTable2.week.today"
    erstellt. Mehr nicht.
    Sollte das Script nicht komplett von Montag bis Sonntag, mit activeOn,...... erstellen? Oder hab ich da wieder mal etwas falsch verstanden?
    MfG
    Patrick
    P.S.: Sorry, hätte eigentlich in https://forum.iobroker.net/topic/52228/howto-zusatz-programme-fuer-jarvis-v3 sollen
    Raspberry Pi 4 8GB, Debian 11, js-controller: 5.0.12, Nodejs: v18.18.2, NPM: 9.8.1 (Multihost),
    Wago PFC200 mit Dali Lichtsteuerung.
    • M marsmännchen
      @mcu
      Hallo @MCU
      // timeTable v1.0.0
      // Copyright ©MCU
        todaySetDP();
          let dateStr = '';
          if (dateDay == 0){
              dateStr=weekArr[6];
          }else {
      //createDPs();
                  //log(typeCreate);
              //break;
      MfG
      Patrick
      M Online
      M Online
      MCU
      #852
      @marsmännchen Man muss das createDPs laufen lassen:
      createDPs();
      U 1 Antwort Letzte Antwort
      • M MCU
        createDPs();
        U Offline
        U Offline
        uwe72
        #853
        @mcu
        Ich suche irgendwie eine Matrix aufzubauen. Weiß nicht, ob es was besseres gibt als die statelist-Horizontal?!
        Aktuell habe ich das Problem, dass die Widget unterschiedlich breit sind und somit nicht alle Widgets einer "Column" gleich breit sind.
        Kannst Du mich in die richtige Richtung stoßen wie ich am besten so eine Matrix aufbauen kann?
        Es geht um eine Gartenbewässerung. Es gibt 8 Ventile und pro Ventil sollen pro Tag bis zu 3 Zeitbereiche konfiguriert werden können. Ggf. hat jemand auch schon mal so was in der Art gemacht.
        • U uwe72
          @mcu
          M Online
          M Online
          MCU
          #854
          @uwe72
          https://mcuiobroker.gitbook.io/jarvis-infos/jarvis-v3/system-effektprog./timetable
          GrizzelbeeG 1 Antwort Letzte Antwort
          • M MCU
            @uwe72
            GrizzelbeeG Offline
            GrizzelbeeG Offline
            Grizzelbee
            schrieb am zuletzt editiert von Grizzelbee
            #855
            @MCU
            Ich kasper hier gerade mit Bindings in der Anzeigevariante herum und hätte da jetzt gerne mal eine Frage:
            In mein VPN können sich User über mehrere Devices gleichzeitig einwählen - mir reicht aber eigentlich ein einziges mal die Anzeige, ob jemand online ist.
            Aktuell habe ich für jedes Device (Smartphone, Notebook, Tablet, ...) einen eigenen Datenpunkt im secondaryState und das führt zur Anzeige von "Online, Online, Online" falls alle Devices eingewählt sind - das ist einfach overkill.
            Jetzt möchte ich das über einen neuen Datenpunkt Online-State lösen, der alle drei Datenpunkte über ein Binding ODER-Verknüpft.
            Problem:
            Für zwei Datenpunkte funktioniert die ODER Verknüpfung - bei drei geht die kaputt und es wird nur der Status des Basis-DPs angezeigt:
              "{wireguard.0.callisto-wg0.peers.UD18Lv/aVO2DXV0VFd3ELLpuE630pBhHd3tTfjXEnBg=.connected}=true
            || {wireguard.0.callisto-wg0.peers.N5rCZqLgpqJCeQP0RcuqZr3AGEkrBz3wzhCZ/DOCnUE=.connected}=true
            || {wireguard.0.callisto-wg0.peers.VzpXgjo+tSK+5+C2XUc5WAdJmyVoowruBRKS9JOu6V8=.connected}=true": "Online",
              "default": ""
            Sobald ich nur 2 DPs ODER verknüpfe geht das:
            { "{wireguard.0.callisto-wg0.peers.UD18Lv/aVO2DXV0VFd3ELLpuE630pBhHd3tTfjXEnBg=.connected}=true
            || {wireguard.0.callisto-wg0.peers.N5rCZqLgpqJCeQP0RcuqZr3AGEkrBz3wzhCZ/DOCnUE=.connected}=true ":"Online"
            ,"default":""}
            Kann das Binding nur zwei DPs verknüpfen? Ich habe schon in den github-issue und in die Doku dazu(https://github.com/Zefau/ioBroker.jarvis/issues/158) geschaut , bin dabei aber nicht schlauer geworden.
            https://mcuiobroker.gitbook.io/jarvis-infos/jarvis-v3/besonderheiten-v3/geraet/binding/fenster-mit-2-haelften
            • M Online
              M Online
              MCU
              #856
              @grizzelbee Welche Version nutzt du?
              Sinnvoll wäre da ein eigenes javascript oder Blockly mit dem man dann einen eigenen DP befüllt und diesen in Jarvis darstellt?
              • GrizzelbeeG Offline
                GrizzelbeeG Offline
                Grizzelbee
                #857
                @mcu
                Oh! Sorry- vergessen: v3.1.9-beta.2
                Wenn jarvis das partout nicht kann, werde ich darüber nachdenken, auch wenn ich solche Kunstgriffe echt hässlich finde.
                Ich wollte nur erst einmal klären ob das ein Bug oder ein Feature ist. Ich fand es halt nicht intuitiv, das 2 funktioneren und drei nicht. ;)
                • GrizzelbeeG Grizzelbee
                  @mcu
                  M Online
                  M Online
                  MCU
                  #858
                  @grizzelbee Also momentan gibt es mit der Anzeigevariante auch in anderen Varianten ( false Wert setzen) Probleme.
                  Da war die Alternative über die Datenpunkt-Eigenschaften zu gehen. Muss ich aber erst noch probieren, ob es mit mehreren boolean geht.
                  Sonst halt eigener DP.
                  • M MCU
                    M Online
                    M Online
                    MCU
                    #859
                    @mcu Bekomme es auch dort nicht hin, also bleibt nur die Alternative mit eigenem DP.
                    Bei mir funktioniert es aber mit 3 boolean in der Anzeigevariante?
                    Vielleicht hilft ein Upload
                    iob upload jarvis
                    • M MCU
                      @dominik-f
                      1. Issue unter github erstellen?
                      2. Sind alle Updates gemacht worden? Welche webview Version im Einsatz?
                      Dominik F.D Offline
                      Dominik F.D Offline
                      Dominik F.
                      #860
                      @mcu sagte in jarvis v3.1.x - just another remarkable vis:
                      @dominik-f
                      Sorry für die späte Rückmeldung. Ich konnte das Problem nun lösen. In Chrome konnte ich den Zoom einstellen. Ich schätze, der hat sich bei nem Update von Chrome auf Standard oder sowas in der Art zurück gestellt.
                      • M MCU
                        iob upload jarvis
                        U Offline
                        U Offline
                        uwe72
                        #861
                        @mcu Frage, die Bezeichnungen der Items einer Dropdownlist kann man nicht zufällig auch über Binding beziehen?
                        Aktuell statisch:
                        Dachte an sowas:
                        Sieht dann allerdings so aus:
                        Grüße!
                        • U uwe72
                          Aktuell statisch:
                          Dachte an sowas:
                          Grüße!
                          M Online
                          M Online
                          MCU
                          #862
                          @uwe72 Laut Doku hat es mal funktioniert.
                          https://mcuiobroker.gitbook.io/jarvis-infos/jarvis-v3/besonderheiten-v3/geraet/anzeigevariante
                          Sehr wahrscheinlich nicht im Zusammenhang mit der DropDownAction?
                          -> Feature Request
                          • M MCU
                            -> Feature Request
                            U Offline
                            U Offline
                            uwe72
                            #863
                            @mcu
                            Kurze Frage, habs im wiki nicht gefunden. Kann man per URL der Jarvisseite Parameter mitgeben, welche man irgendwie mit JavaScript auswerten kann?
                            • U uwe72
                              @mcu
                              M Online
                              M Online
                              MCU
                              #864
                              @uwe72 Gib mal ein Beispiel und wofür ist es gedacht?
                              • M MCU
                                U Offline
                                U Offline
                                uwe72
                                #865
                                @mcu
                                Ich möchte in der unteren Tabelle (dynamisch erstelltes HTML) pro Zeile einen Button haben. Wenn ich auf den Button klicke:
                                • sollen zuerst 3 Datenpunkte befüllt werden (steuert den Inhalt der Dropdowns im übernächsten Screenshot)
                                und auf einen anderen Reiter navigieren:
                                Vermutlich nicht so einfach.
                                Andere Frage: Wenn ich beide Screens zu einem zusammenführe, zu einer Jarvis-Statelist. Ich kann die Einträge filtern, das habe ich schon gesehen. Kann ich sie auch sortieren?
                                • U uwe72
                                  @mcu
                                  M Online
                                  M Online
                                  MCU
                                  #866
                                  @uwe72 Sortieren geht nur mit Extraprogramm.Dieses?
                                  https://mcuiobroker.gitbook.io/jarvis-infos/jarvis-v3/system-effektprog./v3-systemprogramme/statelistsort
                                  Zeitbereiche natürlich nicht, bislang nur Zahlenwerte.
                                  Die HTML erstellst du selber?
                                  Wenn ja dann kann man sie schon so aufbauen, dass man eine "javascript"(SCRIPTS) Funktion nutzt und diese bei Klick aufruft.
                                  Diese Scripts-Funktion kann dann die Werte von States füllen / setzen.
                                  • M MCU
                                    marsmännchen
                                    #867
                                    @mcu
                                    Grüße euch.
                                    Gibt es eigentlich eine Möglichkeit mit Jarvis auf einem Touchscreen ohne Hardwaretastatur Buchstaben und Ziffern einzugeben?
                                    Ein keyboard wie bei Vis z. B?
                                    Mfg Patrick
                                    • M marsmännchen
                                      @mcu
                                      Grüße euch.
                                      Mfg Patrick
                                      M Online
                                      M Online
                                      MCU
                                      #868
                                      @marsmännchen Meinst du ein Software Keyboard auf dem PC? Windows-PC mit Touchscreen?
                                      • M MCU
                                        marsmännchen
                                        #869
                                        @mcu
                                        Ich rufe über einen raspberry im kiosk Modus die jarvis Vis auf, und habe über hdmi einen Dell Touchmonitor am raspberry.
                                        Und dort dann eine Software Tastatur.
                                        • M marsmännchen
                                          @mcu
                                          M Online
                                          M Online
                                          MCU
                                          #870
                                          @marsmännchen Und das funktioniert nicht? Oder hast du es noch nicht probiert?
                                          Welchen Browser?
