  4. Javascript Stürtzt ab
33 Beiträge 7 Kommentatoren 3.9k Aufrufe 6 Beobachtet
  • a200A a200
    @homoran Habe die gleichen Probleme mit Javascript Adapter. Habe downgrade auf die letzte laufende Version durchgeführt, was aber auch nicht geholfen hat.
    Könnt ihr da was sehen?
    BASE SYSTEM:
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Architecture    : x86_64
    Docker          : false
    Virtualization  : kvm
    Distributor ID: Debian
    Description:    Debian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
    23:06:20 up 12 min,  3 users,  load average: 0.57, 0.80, 0.45
    CPU threads: 2
    *** Time and Time Zones ***
                  Local time: Thu 2023-06-15 23:06:20 CEST
              Universal time: Thu 2023-06-15 21:06:20 UTC
                    RTC time: Thu 2023-06-15 21:06:21
                 NTP service: active
             RTC in local TZ: no
    *** User and Groups ***
    root
    /root
    root
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:             11G        2.0G        9.3G        0.0K        618M        9.7G
    Swap:           255M          0B        255M
    Total:           12G        2.0G        9.6G
           11965 M total memory
            2031 M used memory
             300 M active memory
            2130 M inactive memory
            9315 M free memory
              74 M buffer memory
             544 M swap cache
             255 M total swap
               0 M used swap
             255 M free swap
    *** FILESYSTEM ***
    udev           devtmpfs  5.9G     0  5.9G   0% /dev
    tmpfs          tmpfs     1.2G  568K  1.2G   1% /run
    /dev/sdb1      ext4       76G   38G   36G  52% /
    tmpfs          tmpfs     5.9G     0  5.9G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     1.2G     0  1.2G   0% /run/user/0
    [Thu Jun 15 22:53:53 2023] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: (null)
    [Thu Jun 15 22:53:54 2023] EXT4-fs (sdb1): re-mounted. Opts: errors=remount-ro
    TARGET SOURCE    FSTYPE OPTIONS
    /      /dev/sdb1 ext4   rw,relatime,errors=remount-ro
    /var:
    20G     /var/
    15G     /var/lib/influxdb/.influxdbv2/engine/data/7bf64f61a42d54f8/autogen
    Archived and active journals take up 3.9G in the file system.
    /opt/iobroker/backups:
    2.0G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.2G    /opt/iobroker/iobroker-data/
    781M    /opt/iobroker/iobroker-data/files
    258M    /opt/iobroker/iobroker-data/files/minuvis
    222M    /opt/iobroker/iobroker-data/files/minuvis/app
    221M    /opt/iobroker/iobroker-data/files/minuvis/app/static
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    23M     /opt/iobroker/iobroker-data/objects.jsonl
    23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
    23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
    23M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.eb0afecd.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.16.0
    /usr/bin/node           v18.16.0
    /usr/bin/npm            9.5.1
    /usr/bin/npx            9.5.1
    nodejs:
     Installed: 18.16.0-deb-1nodesource1
     Candidate: 18.16.0-deb-1nodesource1
     Version table:
    *** 18.16.0-deb-1nodesource1 500
           500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
        12.22.12~dfsg-1~deb11u3 500
           500 http://deb.debian.org/debian bullseye/main amd64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.4
    admin:          6.5.8
    javascript:     7.0.8
    Adapters from github:   4
    Adapter State
     system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
     system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
     system.adapter.devices.0                : devices               : iobroker                                 -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
     system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
    + system.adapter.ebus.0                   : ebus                  : iobroker                                 -  enabled
    + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
    + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
    + system.adapter.esphome.0                : esphome               : iobroker                                 -  enabled
    + system.adapter.eventlist.0              : eventlist             : iobroker                                 -  enabled
    + system.adapter.ford.0                   : ford                  : iobroker                                 -  enabled
    + system.adapter.frigate.0                : frigate               : iobroker                                 -  enabled
    + system.adapter.fully-mqtt.0             : fully-mqtt            : iobroker                                 -  enabled
     system.adapter.fully-tablet-control.0   : fully-tablet-control  : iobroker                                 - disabled
     system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 - disabled
     system.adapter.gartenbewaesserung.0     : gartenbewaesserung    : iobroker                                 - disabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
     system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
     system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
     system.adapter.ical.2                   : ical                  : iobroker                                 -  enabled
     system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
     system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
     system.adapter.influxdb.1               : influxdb              : iobroker                                 - disabled, port: 8086
     system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
     system.adapter.minuvis.0                : minuvis               : iobroker                                 -  enabled
     system.adapter.mqtt.0                   : mqtt                  : iobroker                                 - disabled, port: 8883, bind: 0.0.0.0
    + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1889, bind: 0.0.0.0
    + system.adapter.mqtt.3                   : mqtt                  : iobroker                                 -  enabled, port: 1888, bind: 0.0.0.0
     system.adapter.mqtt.4                   : mqtt                  : iobroker                                 - disabled, port: 1885, bind: 0.0.0.0
    + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
     system.adapter.pi-hole.0                : pi-hole               : iobroker                                 - disabled
    + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
    + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
     system.adapter.shelly.0                 : shelly                : iobroker                                 - disabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8187, bind: 0.0.0.0, run as: admin
    + system.adapter.smartmeter.0             : smartmeter            : iobroker                                 -  enabled
     system.adapter.socketio.0               : socketio              : iobroker                                 - disabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1890, bind: 0.0.0.0
    + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
     system.adapter.sprinklecontrol.0        : sprinklecontrol       : iobroker                                 - disabled
    + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3306
     system.adapter.systeminfo.0             : systeminfo            : iobroker                                 - disabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
     system.adapter.tr-064.0                 : tr-064                : iobroker                                 - disabled
    + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
    + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
     system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
     system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
     system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
     system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
     system.adapter.vis-map.0                : vis-map               : iobroker                                 -  enabled
     system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
     system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
     system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
     system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
     system.adapter.vofo-speedtest.0         : vofo-speedtest        : iobroker                                 - disabled
     system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 - disabled
    + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
     system.adapter.zigbee.1                 : zigbee                : iobroker                                 - disabled, port: tcp://192.168.10.109:6638
    + instance is alive
    ioBroker-Repositories
    Active repo(s): beta
    Installed ioBroker-Instances
    Used repository: beta
    Adapter    "admin"        : 6.5.8    , installed 6.5.8
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "backitup"     : 2.6.23   , installed 2.6.23
    Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "discovery"    : 3.2.0    , installed 3.2.0
    Adapter    "ebus"         : 3.2.1    , installed 3.2.1
    Adapter    "echarts"      : 1.5.1    , installed 1.5.1
    Adapter    "esphome"      : 0.2.4    , installed 0.2.4
    Adapter    "eventlist"    : 1.2.3    , installed 1.2.3
    Adapter    "ford"         : 0.0.14   , installed 0.0.14
    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
    Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
    Adapter    "hm-rpc"       : 1.15.18  , installed 1.15.18
    Adapter    "javascript"   : 7.1.0    , installed 7.0.8  [Updatable]
    Controller "js-controller": 5.0.4    , installed 5.0.4
    Adapter    "minuvis"      : 2.3.3    , installed 2.3.3
    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
    Adapter    "nut"          : 1.6.0    , installed 1.6.0
    Adapter    "parser"       : 1.3.2    , installed 1.3.2
    Adapter    "pi-hole"      : 1.3.5    , installed 1.3.4  [Updatable]
    Adapter    "proxmox"      : 1.3.5    , installed 1.3.5
    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
    Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
    Adapter    "socketio"     : 6.3.5    , installed 6.3.5
    Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
    Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
    Adapter    "sprinklecontrol": 0.2.13 , installed 0.2.13
    Adapter    "systeminfo"   : 0.3.1    , installed 0.3.1
    Adapter    "telegram"     : 1.15.6   , installed 1.15.6
    Adapter    "unifi"        : 0.6.4    , installed 0.6.4
    Adapter    "upnp"         : 1.0.21   , installed 1.0.21
    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
    Adapter    "vofo-speedtest": 0.0.13  , installed 0.0.13
    Adapter    "weatherunderground": 3.4.2, installed 3.4.2
    Adapter    "web"          : 5.5.3    , installed 5.5.3
    Adapter    "ws"           : 2.3.6    , installed 2.3.6
    Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
    Objects and States
    Objects:        27438
    States:         26557
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 https://repos.influxdata.com/debian stable InRelease
    Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
    Hit:4 https://repos.influxdata.com/debian buster InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:1888            0.0.0.0:*               LISTEN      1001       21487      2083/io.mqtt.3
    tcp        0      0 0.0.0.0:1889            0.0.0.0:*               LISTEN      1001       21405      2060/io.mqtt.1
    tcp        0      0 0.0.0.0:2049            0.0.0.0:*               LISTEN      0          13423      -
    tcp        0      0 0.0.0.0:45921           0.0.0.0:*               LISTEN      0          13353      558/rpc.mountd
    tcp        0      0 0.0.0.0:1890            0.0.0.0:*               LISTEN      1001       21290      2011/io.sonoff.0
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       20009      1714/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       20002      1714/iobroker.js-co
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          11197      1/init
    tcp        0      0 0.0.0.0:42001           0.0.0.0:*               LISTEN      1001       20602      1854/io.hm-rpc.0
    tcp        0      0 0.0.0.0:33875           0.0.0.0:*               LISTEN      0          13365      558/rpc.mountd
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13738      604/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:43735           0.0.0.0:*               LISTEN      0          13444      -
    tcp        0      0 0.0.0.0:47865           0.0.0.0:*               LISTEN      0          13377      558/rpc.mountd
    tcp        0      0 0.0.0.0:42010           0.0.0.0:*               LISTEN      1001       20706      1884/io.hm-rpc.2
    tcp        0      0 127.0.0.1:6010          0.0.0.0:*               LISTEN      0          14274      666/sshd: root@pts/
    tcp        0      0 127.0.0.1:6011          0.0.0.0:*               LISTEN      0          15227      761/sshd: root@pts/
    tcp        0      0 127.0.0.1:6012          0.0.0.0:*               LISTEN      0          17904      1259/sshd: root@pts
    tcp        0      0 0.0.0.0:8701            0.0.0.0:*               LISTEN      1001       20653      1869/io.hm-rpc.1
    tcp6       0      0 :::2049                 :::*                    LISTEN      0          13435      -
    tcp6       0      0 :::33799                :::*                    LISTEN      0          13446      -
    tcp6       0      0 :::41517                :::*                    LISTEN      0          13384      558/rpc.mountd
    tcp6       0      0 :::47949                :::*                    LISTEN      0          13371      558/rpc.mountd
    tcp6       0      0 :::111                  :::*                    LISTEN      0          11205      1/init
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       20150      1741/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       22050      2218/io.web.0
    tcp6       0      0 :::41075                :::*                    LISTEN      0          13359      558/rpc.mountd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          13760      604/sshd: /usr/sbin
    tcp6       0      0 :::3000                 :::*                    LISTEN      1001       22833      2414/io.fully-mqtt.
    tcp6       0      0 ::1:6010                :::*                    LISTEN      0          14273      666/sshd: root@pts/
    tcp6       0      0 :::8187                 :::*                    LISTEN      1001       22103      2229/io.simple-api.
    tcp6       0      0 ::1:6011                :::*                    LISTEN      0          15226      761/sshd: root@pts/
    tcp6       0      0 ::1:6012                :::*                    LISTEN      0          17903      1259/sshd: root@pts
    tcp6       0      0 :::6556                 :::*                    LISTEN      0          13501      1/init
    udp        0      0 0.0.0.0:40655           0.0.0.0:*                           1001       21832      2173/io.upnp.0
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          11200      1/init
    udp        0      0 0.0.0.0:32923           0.0.0.0:*                           0          13350      558/rpc.mountd
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       22105      2173/io.upnp.0
    udp        0      0 0.0.0.0:2049            0.0.0.0:*                           0          13434      -
    udp        0      0 0.0.0.0:36843           0.0.0.0:*                           0          13362      558/rpc.mountd
    udp        0      0 0.0.0.0:45422           0.0.0.0:*                           0          13374      558/rpc.mountd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       22249      2278/io.esphome.0
    udp        0      0 0.0.0.0:47381           0.0.0.0:*                           0          13443      -
    udp6       0      0 :::57273                :::*                                0          13380      558/rpc.mountd
    udp6       0      0 :::111                  :::*                                0          11210      1/init
    udp6       0      0 :::32953                :::*                                0          13445      -
    udp6       0      0 :::2049                 :::*                                0          13436      -
    udp6       0      0 :::51396                :::*                                0          13368      558/rpc.mountd
    udp6       0      0 :::36744                :::*                                0          13356      558/rpc.mountd
    2023-06-15 23:04:00.027  - info: host.iobroker instance system.adapter.ical.0 started with pid 2446
    2023-06-15 23:04:01.158  - info: ical.0 (2446) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2023-06-15 23:04:01.339  - info: ical.0 (2446) starting. Version 1.13.2 in /opt/iobroker/node_modules/iobroker.ical, node: v18.16.0, js-controller: 5.0.4
    2023-06-15 23:04:01.945  - info: ical.0 (2446) processing URL: Geburtstage Marek https://nc.malcherek.com/remote.php/dav/calendars/Marek/geburtstage-marek?export
    2023-06-15 23:04:02.077  - info: ical.0 (2446) processing URL: Geburtstage https://nc.malcherek.com/remote.php/dav/calendars/Marek/geburstage?export
    2023-06-15 23:04:02.079  - info: ical.0 (2446) processing URL: Geburtstage von Kontakten https://nc.malcherek.com/remote.php/dav/calendars/Marek/contact_birthdays?export
    2023-06-15 23:04:07.230  - info: ical.0 (2446) Terminated (NO_ERROR): Without reason
    2023-06-15 23:04:07.761  - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
    2023-06-15 23:05:09.945  - warn: ebus.0 (2359) no update since 2.3.2023, 01:00:43 cc.messages.Mode.lastup
    2023-06-15 23:05:10.164  - warn: ebus.0 (2359) no update since 2.3.2023, 01:00:57 hwc.messages.Params.lastup
    2023-06-15 23:05:10.281  - warn: ebus.0 (2359) no update since 2.3.2023, 01:00:44 mc.messages.Params.lastup
    2023-06-15 23:05:10.770  - info: ebus.0 (2359) installed ebusd version is 23.1
    2023-06-15 23:05:10.802  - info: ebus.0 (2359) all http done
    2023-06-15 23:06:00.018  - info: host.iobroker instance system.adapter.ical.2 started with pid 2489
    2023-06-15 23:06:00.320  - info: smartmeter.0 (1974) Error: No or too long answer from Serial Device after last request.
    2023-06-15 23:06:00.320  - warn: smartmeter.0 (1974) No or too long answer from Serial Device after last request.
    2023-06-15 23:06:01.261  - info: ical.2 (2489) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2023-06-15 23:06:01.431  - info: ical.2 (2489) starting. Version 1.13.2 in /opt/iobroker/node_modules/iobroker.ical, node: v18.16.0, js-controller: 5.0.4
    2023-06-15 23:06:02.417  - info: ical.2 (2489) processing URL: Conselite https://nc.malcherek.com/remote.php/dav/calendars/Marek/conselite-1?export
    2023-06-15 23:06:03.647  - info: ical.2 (2489) processing URL: Mika https://nc.malcherek.eu/remote.php/dav/calendars/Marek/mika_shared_by_Mika?export
    2023-06-15 23:06:03.648  - info: ical.2 (2489) processing URL: Kunde https://nc.malcherek.com/remote.php/dav/calendars/Marek/kunde-1?export
    2023-06-15 23:06:03.939  - info: ical.2 (2489) processing URL: Masha https://nc.malcherek.eu/remote.php/dav/calendars/Marek/personal_shared_by_Masha?export
    2023-06-15 23:06:04.196  - info: ical.2 (2489) processing URL: Marek https://nc.malcherek.com/remote.php/dav/calendars/Marek/marek?export
    2023-06-15 23:06:09.433  - info: ical.2 (2489) Terminated (NO_ERROR): Without reason
    2023-06-15 23:06:09.968  - info: host.iobroker instance system.adapter.ical.2 terminated with code 0 (NO_ERROR)
    SUMMARY:
                        v.2023-04-16
    Operatingsystem:        Debian GNU/Linux 11 (bullseye)
    Kernel:                 5.10.0-22-amd64
    Installation:           kvm
    User-ID:                0
    X-Server:               false
    Pending OS-Updates:     0
    Pending iob updates:    2
    Nodejs-Installation:    /usr/bin/nodejs         v18.16.0
                           /usr/bin/npm            9.5.1
                           /usr/bin/npx            9.5.1
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:             11G        2.1G        9.0G        0.0K        905M        9.6G
    Swap:           255M          0B        255M
    Total:           12G        2.1G        9.2G
    Active iob-Instances:   33
    ioBroker Core:          js-controller           5.0.4
                           admin                   6.5.8
    Objects type: jsonl
    States  type: jsonl
    Objects:                27438
    States:                 26557
    Size of iob-Database:
    16M     /opt/iobroker/iobroker-data/objects.json.migrated
    16M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
    9.9M    /opt/iobroker/iobroker-data/states.jsonl
    4.2M    /opt/iobroker/iobroker-data/states.json.migrated
    4.2M    /opt/iobroker/iobroker-data/states.json.bak.migrated
    @a200 sagte in Javascript Stürtzt ab:
    CPU threads: 2
    Spendier dem Ding mal mehr PS.
    root
    Macht man nicht, als user anmelden.
    Gute Wahl?
    Und wenn du schon betatestest, warum dann keine aktuelle Version?
    Die 7.0.8 interessiert keinen mehr.
    Falses Release, du fährst ja ein bullseye, kein buster.
    a200A 1 Antwort Letzte Antwort
      CPU threads: 2
      root
      Gute Wahl?
      a200A Offline
      a200A Offline
      a200
      @thomas-braun sagte in Javascript Stürtzt ab:
      CPU threads: 2
      An Performance sollte es nicht liegen, kann ich aber gerne versuchen.
      root
      ist historisch gewachsen. Sollte aber auch keinen Einfluss haben. Werde ich ändern.
      Gute Wahl?
      WIe oben beschrieben 7.1.0 ging nicht, deshalb habe ich auf 7.0.8 downgegraded mit der Hoffnung, dass es laufen wird.
      Auch nicht schlimm, die DB ist eh auf einem anderen Host. Die Instanz, die hier lief ist deaktiviert.
      Summa summarum es gibt hier nichts wirklich böses, oder? Mein Web-Adapter schmiert auch ständig ab. Jetzt bleibt nur noch das hier:
      javascript.0	2023-06-16 08:38:33.382	error	request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
      javascript.0	2023-06-16 08:38:33.381	error	deprecated
      javascript.0	2023-06-16 08:38:33.380	error
      javascript.0	2023-06-16 08:38:33.379	error	WARN
      javascript.0	2023-06-16 08:38:33.378	error
      javascript.0	2023-06-16 08:38:33.377	error	npm
      javascript.0	2023-06-16 08:38:33.357	error	uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
      javascript.0	2023-06-16 08:38:33.356	error	deprecated
      javascript.0	2023-06-16 08:38:33.355	error
      javascript.0	2023-06-16 08:38:33.354	error	WARN
      javascript.0	2023-06-16 08:38:33.353	error
      javascript.0	2023-06-16 08:38:33.351	error	npm
      javascript.0	2023-06-16 08:38:33.316	error	node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
      javascript.0	2023-06-16 08:38:33.314	error	deprecated
      javascript.0	2023-06-16 08:38:33.313	error
      javascript.0	2023-06-16 08:38:33.312	error	WARN
      javascript.0	2023-06-16 08:38:33.311	error
      javascript.0	2023-06-16 08:38:33.310	error	npm
      javascript.0	2023-06-16 08:38:33.294	error	querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
      javascript.0	2023-06-16 08:38:33.292	error	deprecated
      javascript.0	2023-06-16 08:38:33.291	error
      javascript.0	2023-06-16 08:38:33.290	error	WARN
      javascript.0	2023-06-16 08:38:33.289	error
      javascript.0	2023-06-16 08:38:33.288	error	npm
      javascript.0	2023-06-16 08:38:33.216	error	deprecated har-validator@5.1.5: this library is no longer supported
      javascript.0	2023-06-16 08:38:33.215	error
      javascript.0	2023-06-16 08:38:33.214	error	WARN
      javascript.0	2023-06-16 08:38:33.212	error
      javascript.0	2023-06-16 08:38:33.211	error	npm
      host.iobroker	2023-06-16 08:40:45.186	error	instance system.adapter.javascript.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      javascript.0	2023-06-16 08:40:45.074	info	terminating
      javascript.0	2023-06-16 08:40:44.584	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      javascript.0	2023-06-16 08:40:44.584	debug	Plugin sentry destroyed
      javascript.0	2023-06-16 08:40:44.584	info	terminating
      javascript.0	2023-06-16 08:40:44.570	error	Debug Failure. Invalid cast. The supplied value [object Object] did not pass the test 'isIdentifier'.
      javascript.0	2023-06-16 08:40:44.570	error	Error: Debug Failure. Invalid cast. The supplied value [object Object] did not pass the test 'isIdentifier'. at cast (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:1170:18) at pipelineEmitWithHintWorker (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:111076:31) at pipelineEmitWithHint (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:111061:9) at pipelineEmitWithComments (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:114845:7) at pipelineEmit (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:111010:7) at emitIdentifierName (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:110984:7) at emitClassDeclarationOrExpression (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112891:9) at emitClassDeclaration (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112873:7) at pipelineEmitWithHintWorker (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:111243:20) at pipelineEmitWithHint (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:111061:9) at pipelineEmitWithComments (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:114845:7) at pipelineEmit (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:111010:7) at emit (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:110978:7) at emitListItemWithParenthesizerRule (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:115291:5) at emitNodeListItems (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:114002:9) at emitNodeList (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:113941:9) at emitList (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:113899:7) at emitBlockStatements (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112494:7) at emitModuleBlock (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112989:7) at pipelineEmitWithHintWorker (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:111253:20) at pipelineEmitWithHint (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:111061:9) at pipelineEmitWithComments (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:114845:7) at pipelineEmit (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:111010:7) at emit (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:110978:7) at emitModuleDeclaration (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112984:7) at pipelineEmitWithHintWorker (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:111251:20) at pipelineEmitWithHint (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:111061:9) at pipelineEmitWithComments (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:114845:7) at pipelineEmit (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:111010:7) at emit (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:110978:7) at emitListItemWithParenthesizerRule (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:115291:5) at emitNodeListItems (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:114002:9) at emitNodeList (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:113941:9) at emitList (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:113899:7) at emitSourceFileWorker (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:113579:7) at emitBodyWithDetachedComments (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:114951:9) at emitSourceFile (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:113507:9) at pipelineEmitWithHintWorker (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:111074:16) at pipelineEmitWithHint (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:111061:9) at pipelineEmit (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:111010:7) at print (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:110923:7) at writeFile2 (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:110907:7) at printFile (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:110747:7) at Object.printNode (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:110724:18) at transformGlobalDeclarations (/opt/iobroker/node_modules/iobroker.javascript/lib/typescriptTools.js:501:31) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:1168:64) at processImmediate (node:internal/timers:478:21)
      javascript.0	2023-06-16 08:40:44.570	error	unhandled promise rejection: Debug Failure. Invalid cast. The supplied value [object Object] did not pass the test 'isIdentifier'.
      javascript.0	2023-06-16 08:40:44.570	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      IoBroker auf QNAP TS-451, Raspi und NUC
      • a200A a200
        BASE SYSTEM:
        Skript v.2023-04-16
        *** BASE SYSTEM ***
        Docker          : false
        Release:        11
        Codename:       bullseye
        VERSION_ID="11"
        ID=debian
        CPU threads: 2
                     NTP service: active
                 RTC in local TZ: no
        root
        /root
        root
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:           255M          0B        255M
                2031 M used memory
                 300 M active memory
                9315 M free memory
                  74 M buffer memory
                 544 M swap cache
                 255 M total swap
                   0 M used swap
                 255 M free swap
        *** FILESYSTEM ***
        /var:
        20G     /var/
        /usr/bin/npm            9.5.1
        /usr/bin/npx            9.5.1
        nodejs:
         Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.5.8
        javascript:     7.0.8
        Adapter State
        + instance is alive
        Objects and States
        Objects:        27438
        States:         26557
        Pending Updates: 0
        SUMMARY:
                            v.2023-04-16
        Installation:           kvm
        User-ID:                0
        X-Server:               false
                               /usr/bin/npm            9.5.1
                               /usr/bin/npx            9.5.1
        MEMORY:
        Swap:           255M          0B        255M
                               admin                   6.5.8
        Objects type: jsonl
        States  type: jsonl
        Objects:                27438
        States:                 26557
        auch du bist im Beta-Test des controllers, bitte dort fragen
          @a200
          Wie historisch ist das? root login wird seit Jahrzehnten nicht mehr verwendet.
          Und natürlich kann das einen Einfluss haben.
          • a200A a200
            CPU threads: 2
            root
            Gute Wahl?
            Sinn und Zweck eines Beta-Tests ist es ja nicht, dass du da ein laufendes System hast sondern das Fehler gefunden und in der Folge gefixt werden können.
            • crunchipC Abwesend
              crunchipC Abwesend
              das gab es vor kurzem schon mal hier irgendwo in einem Thread
              • a200A a200
                CPU threads: 2
                root
                Gute Wahl?
                Das hat auch mit den iob-Instanzen nichts zu tun sondern mit den Paketen im Betriebssystem. Die Quellen müsssen passen, sonst ziehst du dir das System krumm.
                  @crunchip
                  Hey. Ich habe auch die gleichen Probleme.
                  Meinst du diesen hier?
                  https://forum.iobroker.net/topic/66004/instance-javascript-0-stürzt-immer-ab
                    @crunchip
                    @darkness_08 sagte in Javascript Stürtzt ab:
                    auch die gleichen Beta-Versionen?
                      @homoran sagte in Javascript Stürtzt ab:
                      Welche meinst du alle?
                      Adapter    "javascript"   : 7.1.0    , installed 6.1.4  [Updatable]
                      bei Javascript bin ich von 7.1.0 auf 6.1.4 zurück. Damit läuft es.
                      Gebe aber zu ich habe keine Ahnung ob das so sinvoll war. Bin noch recht neu in iobroker und teste etwas.
                      Bin vorgestern auf den "latest" Branch gewechselt, habe vorhin alle Adapter aktualisiert und verschiedene Probleme gehabt. Der den Rest konnte ich aber soweit lösen.
                        Macht irgendwie wenig Sinn für einen Test von Software im Beta-Stand, oder?
                          @darkness_08 du bist ebenfalls Betatester für den noch nicht fertigen Controller.
                          ich mach jetzt hier zu!
