  4. Javascript Stürtzt ab
33 Beiträge 7 Kommentatoren 3.9k Aufrufe 6 Beobachtet
  • M manrum1
    @thomas-braun Danke für die Hilfe!
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Architecture    : aarch64
    Docker          : false
    Virtualization  : none
    Distributor ID: Debian
    Description:    Debian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     22:19:35 up 48 min,  1 user,  load average: 4.43, 2.38, 1.44
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=62.8'C
    volt=0.9260V
    *** Time and Time Zones ***
                   Local time: Tue 2023-06-13 22:19:35 CEST
               Universal time: Tue 2023-06-13 20:19:35 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    iobroker
    /home/iobroker
    iobroker adm tty dialout cdrom sudo audio video plugdev games users input render netdev bluetooth gpio i2c spi
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            7.8G        1.9G        5.0G        1.0M        905M        5.8G
    Swap:            99M          0B         99M
    Total:          7.9G        1.9G        5.1G
             7812 M total memory
             1876 M used memory
             2081 M active memory
              501 M inactive memory
             5030 M free memory
              105 M buffer memory
              799 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4       29G  8.2G   19G  30% /
    devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     1.6G  1.1M  1.6G   1% /run
    /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
    tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
    [Tue Jun 13 21:31:13 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:DB:77:FD vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=02088660-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Tue Jun 13 21:31:14 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Tue Jun 13 21:31:14 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Tue Jun 13 21:31:16 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    3.2G    /var/
    1.9G    /var/log/journal/54074e39055a46ce8cf0e1657f7640a7
    1.9G    /var/log
    665M    /var/lib
    Archived and active journals take up 1.8G in the file system.
    /opt/iobroker/backups:
    1014M   /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    306M    /opt/iobroker/iobroker-data/
    180M    /opt/iobroker/iobroker-data/files
    86M     /opt/iobroker/iobroker-data/backup-objects
    51M     /opt/iobroker/iobroker-data/files/javascript.admin
    45M     /opt/iobroker/iobroker-data/files/devices.admin/static
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    27M     /opt/iobroker/iobroker-data/objects.jsonl
    20M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.becd2d7c.js.map
    8.6M    /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js
    8.3M    /opt/iobroker/iobroker-data/states.jsonl
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v16.20.0
    /usr/bin/node           v16.20.0
    /usr/bin/npm            8.19.4
    /usr/bin/npx            8.19.4
    nodejs:
      Installed: 16.20.0-deb-1nodesource1
      Candidate: 16.20.0-deb-1nodesource1
      Version table:
     *** 16.20.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.2
    admin:          6.5.8
    javascript:     7.1.0
    Adapters from github:   0
    Adapter State
    + system.adapter.accuweather.0            : accuweather           : iob1                                     -  enabled
    + system.adapter.admin.0                  : admin                 : iob1                                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alias-manager.0          : alias-manager         : iob1                                     - disabled
    + system.adapter.backitup.0               : backitup              : iob1                                     -  enabled
    + system.adapter.cloud.0                  : cloud                 : iob1                                     -  enabled
      system.adapter.daswetter.0              : daswetter             : iob1                                     -  enabled
      system.adapter.daswetter.1              : daswetter             : iob1                                     -  enabled
      system.adapter.devices.0                : devices               : iob1                                     - disabled
    + system.adapter.discovery.0              : discovery             : iob1                                     -  enabled
    + system.adapter.email.0                  : email                 : iob1                                     -  enabled
    + system.adapter.ems-esp.0                : ems-esp               : iob1                                     -  enabled
    + system.adapter.ems-esp.1                : ems-esp               : iob1                                     -  enabled
    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iob1                                     -  enabled
    + system.adapter.fb-checkpresence.1       : fb-checkpresence      : iob1                                     -  enabled
    + system.adapter.fb-checkpresence.2       : fb-checkpresence      : iob1                                     -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : iob1                                     -  enabled
    + system.adapter.fronius-solarweb.0       : fronius-solarweb      : iob1                                     -  enabled
      system.adapter.habpanel.0               : habpanel              : iob1                                     - disabled
    + system.adapter.history.0                : history               : iob1                                     -  enabled
      system.adapter.ical.0                   : ical                  : iob1                                     -  enabled
    + system.adapter.influxdb.0               : influxdb              : iob1                                     -  enabled, port: 8086
    + system.adapter.info.0                   : info                  : iob1                                     -  enabled
    + system.adapter.javascript.0             : javascript            : iob1                                     -  enabled
    + system.adapter.maxcube.0                : maxcube               : iob1                                     -  enabled, port: 62910, bind: 0.0.0.0
      system.adapter.modbus.0                 : modbus                : iob1                                     - disabled
    + system.adapter.mqtt.0                   : mqtt                  : iob1                                     -  enabled, port: 1886, bind: 0.0.0.0
    + system.adapter.net-tools.0              : net-tools             : iob1                                     -  enabled
    + system.adapter.ping.0                   : ping                  : iob1                                     -  enabled
    + system.adapter.shelly.0                 : shelly                : iob1                                     -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.sonoff.0                 : sonoff                : iob1                                     -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.tuya.0                   : tuya                  : iob1                                     -  enabled
      system.adapter.viessmannapi.0           : viessmannapi          : iob1                                     - disabled
    + system.adapter.web.0                    : web                   : iob1                                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    Stable (default): http://download.iobroker.net/sources-dist.json
    Active repo(s): Beta (latest)
    Installed ioBroker-Instances
    Used repository: Beta (latest)
    Adapter    "accuweather"  : 1.2.4    , installed 1.2.4
    Adapter    "admin"        : 6.5.8    , installed 6.5.8
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "backitup"     : 2.6.23   , installed 2.6.23
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "email"        : 1.2.0    , installed 1.2.0
    Adapter    "ems-esp"      : 1.30.0   , installed 1.30.0
    Adapter    "fb-checkpresence": 1.1.26, installed 1.1.26
    Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
    Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
    Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
    Adapter    "history"      : 2.2.4    , installed 2.2.4
    Adapter    "javascript"   : 7.1.0    , installed 7.1.0
    Controller "js-controller": 5.0.2    , installed 5.0.2
    Adapter    "maxcube"      : 1.0.4    , installed 1.0.4
    Adapter    "modbus"       : 5.0.11   , installed 5.0.11
    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "semp"         : 1.3.2    , installed 1.3.2
    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
    Adapter    "socketio"     : 6.3.5    , installed 6.3.5
    Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
    Adapter    "tuya"         : 3.14.2   , installed 3.14.2
    Adapter    "viessmannapi" : 2.1.1    , installed 2.1.1
    Adapter    "web"          : 5.5.3    , installed 5.5.3
    Adapter    "ws"           : 2.3.6    , installed 2.3.6
    Objects and States
    Objects:        31133
    States:         28561
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
    W: Failed to fetch https://repos.influxdata.com/debian/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    W: Some index files failed to download. They have been ignored, or old ones used instead.
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
    Get:6 https://packages.grafana.com/oss/deb stable InRelease [5984 B]
    Get:7 https://repos.influxdata.com/debian stable InRelease [6892 B]
    Err:6 https://packages.grafana.com/oss/deb stable InRelease
    Err:7 https://repos.influxdata.com/debian stable InRelease
    Fetched 6892 B in 2s (3242 B/s)
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       65362      4337/iobroker.js-co
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       63828      4337/iobroker.js-co
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12823      510/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1000       67756      4472/io.mqtt.0
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       67244      4502/io.shelly.0
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       67931      4517/io.sonoff.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          11952      510/sshd: /usr/sbin
    tcp6       0      0 :::3000                 :::*                    LISTEN      111        14637      611/grafana-server
    tcp6       0      0 :::8086                 :::*                    LISTEN      110        13034      615/influxd
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       68370      4849/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       65399      4355/io.admin.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1502       610/dhcpcd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11903      358/avahi-daemon: r
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       64472      4524/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       64473      4524/io.tuya.0
    udp        0      0 0.0.0.0:47825           0.0.0.0:*                           108        11905      358/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        11904      358/avahi-daemon: r
    udp6       0      0 :::53030                :::*                                108        11906      358/avahi-daemon: r
    2023-06-13 22:20:35.083  - warn: shelly.0 (4502) [authEnabled] 192.168.10.35 (shellyswitch25 / shellyswitch25-E098068D2495 / SHSW-25#E098068D2495#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-06-13 22:20:39.626  - warn: shelly.0 (4502) [authEnabled] 192.168.10.58 (shellydimmer2 / shellydimmer2-F4CFA2ECA923 / SHDM-2#F4CFA2ECA923#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-06-13 22:20:39.630  - warn: shelly.0 (4502) [authEnabled] 192.168.10.52 (shellydimmer2 / shellydimmer2-3C6105E53F3E / SHDM-2#3C6105E53F3E#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-06-13 22:20:40.048  - warn: shelly.0 (4502) [authEnabled] 192.168.10.51 (shellydimmer2 / shellydimmer2-F4CFA2ECA892 / SHDM-2#F4CFA2ECA892#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-06-13 22:20:40.359  - warn: shelly.0 (4502) [authEnabled] 192.168.10.35 (shellyswitch25 / shellyswitch25-E098068D2495 / SHSW-25#E098068D2495#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-06-13 22:20:45.482  - warn: shelly.0 (4502) [authEnabled] 192.168.10.52 (shellydimmer2 / shellydimmer2-3C6105E53F3E / SHDM-2#3C6105E53F3E#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-06-13 22:20:45.487  - warn: shelly.0 (4502) [authEnabled] 192.168.10.58 (shellydimmer2 / shellydimmer2-F4CFA2ECA923 / SHDM-2#F4CFA2ECA923#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-06-13 22:20:45.645  - warn: shelly.0 (4502) [authEnabled] 192.168.10.35 (shellyswitch25 / shellyswitch25-E098068D2495 / SHSW-25#E098068D2495#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-06-13 22:20:45.650  - warn: shelly.0 (4502) [authEnabled] 192.168.10.51 (shellydimmer2 / shellydimmer2-F4CFA2ECA892 / SHDM-2#F4CFA2ECA892#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-06-13 22:20:49.428  - error: shelly.0 (4502) [MQTT] Wrong MQTT authentification of client "shelly1-48551902A079"
    2023-06-13 22:20:49.437  - info: shelly.0 (4502) [MQTT] Client Close:  (shelly1 / shelly1-48551902A079 / SHSW-1#48551902A079#1) (false)
    2023-06-13 22:20:50.678  - warn: shelly.0 (4502) [authEnabled] 192.168.10.52 (shellydimmer2 / shellydimmer2-3C6105E53F3E / SHDM-2#3C6105E53F3E#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-06-13 22:20:50.690  - warn: shelly.0 (4502) [authEnabled] 192.168.10.58 (shellydimmer2 / shellydimmer2-F4CFA2ECA923 / SHDM-2#F4CFA2ECA923#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-06-13 22:20:50.948  - warn: shelly.0 (4502) [authEnabled] 192.168.10.35 (shellyswitch25 / shellyswitch25-E098068D2495 / SHSW-25#E098068D2495#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-06-13 22:20:51.050  - warn: shelly.0 (4502) [authEnabled] 192.168.10.51 (shellydimmer2 / shellydimmer2-F4CFA2ECA892 / SHDM-2#F4CFA2ECA892#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-06-13 22:20:55.908  - warn: shelly.0 (4502) [authEnabled] 192.168.10.52 (shellydimmer2 / shellydimmer2-3C6105E53F3E / SHDM-2#3C6105E53F3E#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-06-13 22:20:55.933  - warn: shelly.0 (4502) [authEnabled] 192.168.10.58 (shellydimmer2 / shellydimmer2-F4CFA2ECA923 / SHDM-2#F4CFA2ECA923#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-06-13 22:20:56.260  - warn: shelly.0 (4502) [authEnabled] 192.168.10.35 (shellyswitch25 / shellyswitch25-E098068D2495 / SHSW-25#E098068D2495#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-06-13 22:20:56.294  - info: tuya.0 (4524) bf0774134c70c4201fr04k: Error on Reconnect (7): connect EHOSTUNREACH 192.168.10.82:6668
    2023-06-13 22:20:56.429  - warn: shelly.0 (4502) [authEnabled] 192.168.10.51 (shellydimmer2 / shellydimmer2-F4CFA2ECA892 / SHDM-2#F4CFA2ECA892#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-06-13 22:20:58.437  - info: tuya.0 (4524) bfdff6db2893d4426eyjwq: Error on Reconnect (7): connect EHOSTUNREACH 192.168.10.79:6668
    2023-06-13 22:21:01.043  - warn: shelly.0 (4502) [authEnabled] 192.168.10.52 (shellydimmer2 / shellydimmer2-3C6105E53F3E / SHDM-2#3C6105E53F3E#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-06-13 22:21:01.066  - warn: shelly.0 (4502) [authEnabled] 192.168.10.58 (shellydimmer2 / shellydimmer2-F4CFA2ECA923 / SHDM-2#F4CFA2ECA923#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-06-13 22:21:01.486  - warn: shelly.0 (4502) [authEnabled] 192.168.10.35 (shellyswitch25 / shellyswitch25-E098068D2495 / SHSW-25#E098068D2495#1): This device is not protected via restricted login (see adapter documentation for details)
    2023-06-13 22:21:01.835  - warn: shelly.0 (4502) [authEnabled] 192.168.10.51 (shellydimmer2 / shellydimmer2-F4CFA2ECA892 / SHDM-2#F4CFA2ECA892#1): This device is not protected via restricted login (see adapter documentation for details)
    @manrum1
    Bis auf die Beta-Versionen und den fehlenden Keys für grafana und influxdb soweit keine dicken Hunde.
      @manrum1
      DJMarc75D Offline
      DJMarc75D Offline
      DJMarc75
      @thomas-braun sagte in Javascript Stürtzt ab:
      Naja, der TE spielt ja in der ganz aktuellen Betatester-Liga vom js-controller und javaskriptadapter mit. Da sollte doch zumindest Node auf "empfohlen" gehoben werden ?!
      Lehrling seit 1975 !!!
      • DJMarc75D DJMarc75
        @djmarc75
        Ja, nodejs@18 würde sich empfehlen, aber mit 16 muss es auch rennen. Insgesamt habe ich hier halt auch schon ganz andere Setups gesehen, da ist node16 statt 18 kein 'dicker Hund'.
        Wichtig sind halt die Quellen für influxdb und grafana aktuell laufend zu halten.
          @djmarc75
          @manrum1
          und nicht gerade die bleeding edge Versionen nehmen, an denen gerade geschraubt wird
          • a200A Offline
            a200A Offline
            a200
            schrieb am zuletzt editiert von a200
            @homoran Habe die gleichen Probleme mit Javascript Adapter. Habe downgrade auf die letzte laufende Version durchgeführt, was aber auch nicht geholfen hat.
            Könnt ihr da was sehen?
            BASE SYSTEM:
            Skript v.2023-04-16
            *** BASE SYSTEM ***
            Architecture    : x86_64
            Docker          : false
            Virtualization  : kvm
            Release:        11
            Codename:       bullseye
            VERSION_ID="11"
            ID=debian
            23:06:20 up 12 min,  3 users,  load average: 0.57, 0.80, 0.45
            CPU threads: 2
                          Local time: Thu 2023-06-15 23:06:20 CEST
                      Universal time: Thu 2023-06-15 21:06:20 UTC
                            RTC time: Thu 2023-06-15 21:06:21
                         NTP service: active
                     RTC in local TZ: no
            root
            /root
            root
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:             11G        2.0G        9.3G        0.0K        618M        9.7G
            Swap:           255M          0B        255M
            Total:           12G        2.0G        9.6G
                   11965 M total memory
                    2031 M used memory
                     300 M active memory
                    2130 M inactive memory
                    9315 M free memory
                      74 M buffer memory
                     544 M swap cache
                     255 M total swap
                       0 M used swap
                     255 M free swap
            *** FILESYSTEM ***
            udev           devtmpfs  5.9G     0  5.9G   0% /dev
            tmpfs          tmpfs     1.2G  568K  1.2G   1% /run
            /dev/sdb1      ext4       76G   38G   36G  52% /
            tmpfs          tmpfs     5.9G     0  5.9G   0% /dev/shm
            tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
            tmpfs          tmpfs     1.2G     0  1.2G   0% /run/user/0
            [Thu Jun 15 22:53:53 2023] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: (null)
            [Thu Jun 15 22:53:54 2023] EXT4-fs (sdb1): re-mounted. Opts: errors=remount-ro
            /      /dev/sdb1 ext4   rw,relatime,errors=remount-ro
            /var:
            20G     /var/
            15G     /var/lib/influxdb/.influxdbv2/engine/data/7bf64f61a42d54f8/autogen
            Archived and active journals take up 3.9G in the file system.
            2.0G    /opt/iobroker/backups/
            1.2G    /opt/iobroker/iobroker-data/
            781M    /opt/iobroker/iobroker-data/files
            258M    /opt/iobroker/iobroker-data/files/minuvis
            222M    /opt/iobroker/iobroker-data/files/minuvis/app
            221M    /opt/iobroker/iobroker-data/files/minuvis/app/static
            23M     /opt/iobroker/iobroker-data/objects.jsonl
            23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
            23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
            23M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.eb0afecd.js.map
            /usr/bin/nodejs         v18.16.0
            /usr/bin/node           v18.16.0
            /usr/bin/npm            9.5.1
            /usr/bin/npx            9.5.1
            nodejs:
             Installed: 18.16.0-deb-1nodesource1
             Candidate: 18.16.0-deb-1nodesource1
             Version table:
            *** 18.16.0-deb-1nodesource1 500
                   500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
                   500 http://deb.debian.org/debian bullseye/main amd64 Packages
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            js-controller:  5.0.4
            admin:          6.5.8
            javascript:     7.0.8
            Adapters from github:   4
            Adapter State
             system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
            + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
             system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
             system.adapter.devices.0                : devices               : iobroker                                 -  enabled
            + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
             system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
            + system.adapter.ebus.0                   : ebus                  : iobroker                                 -  enabled
            + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
            + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
            + system.adapter.esphome.0                : esphome               : iobroker                                 -  enabled
            + system.adapter.eventlist.0              : eventlist             : iobroker                                 -  enabled
            + system.adapter.ford.0                   : ford                  : iobroker                                 -  enabled
            + system.adapter.frigate.0                : frigate               : iobroker                                 -  enabled
            + system.adapter.fully-mqtt.0             : fully-mqtt            : iobroker                                 -  enabled
             system.adapter.fully-tablet-control.0   : fully-tablet-control  : iobroker                                 - disabled
             system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 - disabled
             system.adapter.gartenbewaesserung.0     : gartenbewaesserung    : iobroker                                 - disabled
            + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
            + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
            + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
            + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
             system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
             system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
             system.adapter.ical.2                   : ical                  : iobroker                                 -  enabled
             system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
             system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
            + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
             system.adapter.influxdb.1               : influxdb              : iobroker                                 - disabled, port: 8086
             system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
             system.adapter.minuvis.0                : minuvis               : iobroker                                 -  enabled
             system.adapter.mqtt.0                   : mqtt                  : iobroker                                 - disabled, port: 8883, bind: 0.0.0.0
            + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1889, bind: 0.0.0.0
            + system.adapter.mqtt.3                   : mqtt                  : iobroker                                 -  enabled, port: 1888, bind: 0.0.0.0
             system.adapter.mqtt.4                   : mqtt                  : iobroker                                 - disabled, port: 1885, bind: 0.0.0.0
            + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
             system.adapter.pi-hole.0                : pi-hole               : iobroker                                 - disabled
            + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
            + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
             system.adapter.shelly.0                 : shelly                : iobroker                                 - disabled, port: 1882, bind: 0.0.0.0
            + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8187, bind: 0.0.0.0, run as: admin
            + system.adapter.smartmeter.0             : smartmeter            : iobroker                                 -  enabled
             system.adapter.socketio.0               : socketio              : iobroker                                 - disabled, port: 8084, bind: 0.0.0.0, run as: admin
            + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1890, bind: 0.0.0.0
            + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
             system.adapter.sprinklecontrol.0        : sprinklecontrol       : iobroker                                 - disabled
            + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3306
             system.adapter.systeminfo.0             : systeminfo            : iobroker                                 - disabled
            + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
            + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
             system.adapter.tr-064.0                 : tr-064                : iobroker                                 - disabled
            + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
            + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
             system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
             system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
             system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
             system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
             system.adapter.vis-map.0                : vis-map               : iobroker                                 -  enabled
             system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
             system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
             system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
             system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
             system.adapter.vofo-speedtest.0         : vofo-speedtest        : iobroker                                 - disabled
             system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 - disabled
            + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
             system.adapter.zigbee.1                 : zigbee                : iobroker                                 - disabled, port: tcp://192.168.10.109:6638
            + instance is alive
            Active repo(s): beta
            Used repository: beta
            Adapter    "discovery"    : 3.2.0    , installed 3.2.0
            Adapter    "ebus"         : 3.2.1    , installed 3.2.1
            Adapter    "echarts"      : 1.5.1    , installed 1.5.1
            Adapter    "esphome"      : 0.2.4    , installed 0.2.4
            Adapter    "eventlist"    : 1.2.3    , installed 1.2.3
            Adapter    "ford"         : 0.0.14   , installed 0.0.14
            Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
            Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
            Adapter    "hm-rpc"       : 1.15.18  , installed 1.15.18
            Adapter    "javascript"   : 7.1.0    , installed 7.0.8  [Updatable]
            Controller "js-controller": 5.0.4    , installed 5.0.4
            Adapter    "minuvis"      : 2.3.3    , installed 2.3.3
            Adapter    "nut"          : 1.6.0    , installed 1.6.0
            Adapter    "parser"       : 1.3.2    , installed 1.3.2
            Adapter    "pi-hole"      : 1.3.5    , installed 1.3.4  [Updatable]
            Adapter    "proxmox"      : 1.3.5    , installed 1.3.5
            Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
            Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
            Adapter    "sprinklecontrol": 0.2.13 , installed 0.2.13
            Adapter    "systeminfo"   : 0.3.1    , installed 0.3.1
            Adapter    "telegram"     : 1.15.6   , installed 1.15.6
            Adapter    "unifi"        : 0.6.4    , installed 0.6.4
            Adapter    "upnp"         : 1.0.21   , installed 1.0.21
            Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
            Adapter    "vofo-speedtest": 0.0.13  , installed 0.0.13
            Adapter    "weatherunderground": 3.4.2, installed 3.4.2
            Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
            Objects and States
            Objects:        27438
            States:         26557
            Hit:1 http://deb.debian.org/debian bullseye InRelease
            Hit:2 https://repos.influxdata.com/debian stable InRelease
            Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
            Hit:4 https://repos.influxdata.com/debian buster InRelease
            Pending Updates: 0
            tcp        0      0 0.0.0.0:1888            0.0.0.0:*               LISTEN      1001       21487      2083/io.mqtt.3
            tcp        0      0 0.0.0.0:1889            0.0.0.0:*               LISTEN      1001       21405      2060/io.mqtt.1
            tcp        0      0 0.0.0.0:2049            0.0.0.0:*               LISTEN      0          13423      -
            tcp        0      0 0.0.0.0:45921           0.0.0.0:*               LISTEN      0          13353      558/rpc.mountd
            tcp        0      0 0.0.0.0:1890            0.0.0.0:*               LISTEN      1001       21290      2011/io.sonoff.0
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       20009      1714/iobroker.js-co
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       20002      1714/iobroker.js-co
            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          11197      1/init
            tcp        0      0 0.0.0.0:42001           0.0.0.0:*               LISTEN      1001       20602      1854/io.hm-rpc.0
            tcp        0      0 0.0.0.0:33875           0.0.0.0:*               LISTEN      0          13365      558/rpc.mountd
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13738      604/sshd: /usr/sbin
            tcp        0      0 0.0.0.0:43735           0.0.0.0:*               LISTEN      0          13444      -
            tcp        0      0 0.0.0.0:47865           0.0.0.0:*               LISTEN      0          13377      558/rpc.mountd
            tcp        0      0 0.0.0.0:42010           0.0.0.0:*               LISTEN      1001       20706      1884/io.hm-rpc.2
            tcp        0      0 127.0.0.1:6010          0.0.0.0:*               LISTEN      0          14274      666/sshd: root@pts/
            tcp        0      0 127.0.0.1:6011          0.0.0.0:*               LISTEN      0          15227      761/sshd: root@pts/
            tcp        0      0 127.0.0.1:6012          0.0.0.0:*               LISTEN      0          17904      1259/sshd: root@pts
            tcp        0      0 0.0.0.0:8701            0.0.0.0:*               LISTEN      1001       20653      1869/io.hm-rpc.1
            tcp6       0      0 :::2049                 :::*                    LISTEN      0          13435      -
            tcp6       0      0 :::33799                :::*                    LISTEN      0          13446      -
            tcp6       0      0 :::41517                :::*                    LISTEN      0          13384      558/rpc.mountd
            tcp6       0      0 :::47949                :::*                    LISTEN      0          13371      558/rpc.mountd
            tcp6       0      0 :::111                  :::*                    LISTEN      0          11205      1/init
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       20150      1741/io.admin.0
            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       22050      2218/io.web.0
            tcp6       0      0 :::41075                :::*                    LISTEN      0          13359      558/rpc.mountd
            tcp6       0      0 :::22                   :::*                    LISTEN      0          13760      604/sshd: /usr/sbin
            tcp6       0      0 :::3000                 :::*                    LISTEN      1001       22833      2414/io.fully-mqtt.
            tcp6       0      0 ::1:6010                :::*                    LISTEN      0          14273      666/sshd: root@pts/
            tcp6       0      0 :::8187                 :::*                    LISTEN      1001       22103      2229/io.simple-api.
            tcp6       0      0 ::1:6011                :::*                    LISTEN      0          15226      761/sshd: root@pts/
            tcp6       0      0 ::1:6012                :::*                    LISTEN      0          17903      1259/sshd: root@pts
            tcp6       0      0 :::6556                 :::*                    LISTEN      0          13501      1/init
            udp        0      0 0.0.0.0:40655           0.0.0.0:*                           1001       21832      2173/io.upnp.0
            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          11200      1/init
            udp        0      0 0.0.0.0:32923           0.0.0.0:*                           0          13350      558/rpc.mountd
            udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       22105      2173/io.upnp.0
            udp        0      0 0.0.0.0:2049            0.0.0.0:*                           0          13434      -
            udp        0      0 0.0.0.0:36843           0.0.0.0:*                           0          13362      558/rpc.mountd
            udp        0      0 0.0.0.0:45422           0.0.0.0:*                           0          13374      558/rpc.mountd
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       22249      2278/io.esphome.0
            udp        0      0 0.0.0.0:47381           0.0.0.0:*                           0          13443      -
            udp6       0      0 :::57273                :::*                                0          13380      558/rpc.mountd
            udp6       0      0 :::111                  :::*                                0          11210      1/init
            udp6       0      0 :::32953                :::*                                0          13445      -
            udp6       0      0 :::2049                 :::*                                0          13436      -
            udp6       0      0 :::51396                :::*                                0          13368      558/rpc.mountd
            udp6       0      0 :::36744                :::*                                0          13356      558/rpc.mountd
            2023-06-15 23:04:00.027  - info: host.iobroker instance system.adapter.ical.0 started with pid 2446
            2023-06-15 23:04:01.158  - info: ical.0 (2446) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
            2023-06-15 23:04:01.339  - info: ical.0 (2446) starting. Version 1.13.2 in /opt/iobroker/node_modules/iobroker.ical, node: v18.16.0, js-controller: 5.0.4
            2023-06-15 23:04:01.945  - info: ical.0 (2446) processing URL: Geburtstage Marek https://nc.malcherek.com/remote.php/dav/calendars/Marek/geburtstage-marek?export
            2023-06-15 23:04:02.077  - info: ical.0 (2446) processing URL: Geburtstage https://nc.malcherek.com/remote.php/dav/calendars/Marek/geburstage?export
            2023-06-15 23:04:02.079  - info: ical.0 (2446) processing URL: Geburtstage von Kontakten https://nc.malcherek.com/remote.php/dav/calendars/Marek/contact_birthdays?export
            2023-06-15 23:04:07.230  - info: ical.0 (2446) Terminated (NO_ERROR): Without reason
            2023-06-15 23:04:07.761  - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
            2023-06-15 23:05:09.945  - warn: ebus.0 (2359) no update since 2.3.2023, 01:00:43 cc.messages.Mode.lastup
            2023-06-15 23:05:10.164  - warn: ebus.0 (2359) no update since 2.3.2023, 01:00:57 hwc.messages.Params.lastup
            2023-06-15 23:05:10.281  - warn: ebus.0 (2359) no update since 2.3.2023, 01:00:44 mc.messages.Params.lastup
            2023-06-15 23:05:10.770  - info: ebus.0 (2359) installed ebusd version is 23.1
            2023-06-15 23:05:10.802  - info: ebus.0 (2359) all http done
            2023-06-15 23:06:00.018  - info: host.iobroker instance system.adapter.ical.2 started with pid 2489
            2023-06-15 23:06:00.320  - info: smartmeter.0 (1974) Error: No or too long answer from Serial Device after last request.
            2023-06-15 23:06:00.320  - warn: smartmeter.0 (1974) No or too long answer from Serial Device after last request.
            2023-06-15 23:06:01.261  - info: ical.2 (2489) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
            2023-06-15 23:06:01.431  - info: ical.2 (2489) starting. Version 1.13.2 in /opt/iobroker/node_modules/iobroker.ical, node: v18.16.0, js-controller: 5.0.4
            2023-06-15 23:06:02.417  - info: ical.2 (2489) processing URL: Conselite https://nc.malcherek.com/remote.php/dav/calendars/Marek/conselite-1?export
            2023-06-15 23:06:03.647  - info: ical.2 (2489) processing URL: Mika https://nc.malcherek.eu/remote.php/dav/calendars/Marek/mika_shared_by_Mika?export
            2023-06-15 23:06:03.648  - info: ical.2 (2489) processing URL: Kunde https://nc.malcherek.com/remote.php/dav/calendars/Marek/kunde-1?export
            2023-06-15 23:06:03.939  - info: ical.2 (2489) processing URL: Masha https://nc.malcherek.eu/remote.php/dav/calendars/Marek/personal_shared_by_Masha?export
            2023-06-15 23:06:04.196  - info: ical.2 (2489) processing URL: Marek https://nc.malcherek.com/remote.php/dav/calendars/Marek/marek?export
            2023-06-15 23:06:09.433  - info: ical.2 (2489) Terminated (NO_ERROR): Without reason
            2023-06-15 23:06:09.968  - info: host.iobroker instance system.adapter.ical.2 terminated with code 0 (NO_ERROR)
            SUMMARY:
                                v.2023-04-16
            Operatingsystem:        Debian GNU/Linux 11 (bullseye)
            Kernel:                 5.10.0-22-amd64
            Installation:           kvm
            User-ID:                0
            X-Server:               false
            Pending OS-Updates:     0
            Pending iob updates:    2
            Nodejs-Installation:    /usr/bin/nodejs         v18.16.0
                                   /usr/bin/npm            9.5.1
                                   /usr/bin/npx            9.5.1
            Recommended versions are nodejs 18.x.y and npm 9.x.y
            MEMORY:
            Mem:             11G        2.1G        9.0G        0.0K        905M        9.6G
            Swap:           255M          0B        255M
            Total:           12G        2.1G        9.2G
            Active iob-Instances:   33
            ioBroker Core:          js-controller           5.0.4
                                   admin                   6.5.8
            Objects type: jsonl
            States  type: jsonl
            Objects:                27438
            States:                 26557
            Size of iob-Database:
            16M     /opt/iobroker/iobroker-data/objects.json.migrated
            16M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
            9.9M    /opt/iobroker/iobroker-data/states.jsonl
            4.2M    /opt/iobroker/iobroker-data/states.json.migrated
            4.2M    /opt/iobroker/iobroker-data/states.json.bak.migrated
            IoBroker auf QNAP TS-451, Raspi und NUC
            • a200A a200
              BASE SYSTEM:
              Skript v.2023-04-16
              *** BASE SYSTEM ***
              Docker          : false
              Release:        11
              Codename:       bullseye
              VERSION_ID="11"
              ID=debian
              CPU threads: 2
                           NTP service: active
                       RTC in local TZ: no
              root
              /root
              root
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Swap:           255M          0B        255M
                      2031 M used memory
                       300 M active memory
                      9315 M free memory
                        74 M buffer memory
                       544 M swap cache
                       255 M total swap
                         0 M used swap
                       255 M free swap
              *** FILESYSTEM ***
              /var:
              20G     /var/
              /usr/bin/npm            9.5.1
              /usr/bin/npx            9.5.1
              nodejs:
               Version table:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin:          6.5.8
              javascript:     7.0.8
              Adapter State
              + instance is alive
              Objects and States
              Objects:        27438
              States:         26557
              Pending Updates: 0
              SUMMARY:
                                  v.2023-04-16
              Installation:           kvm
              User-ID:                0
              X-Server:               false
                                     /usr/bin/npm            9.5.1
                                     /usr/bin/npx            9.5.1
              MEMORY:
              Swap:           255M          0B        255M
                                     admin                   6.5.8
              Objects type: jsonl
              States  type: jsonl
              Objects:                27438
              States:                 26557
              @a200 sagte in Javascript Stürtzt ab:
              CPU threads: 2
              Spendier dem Ding mal mehr PS.
              root
              Macht man nicht, als user anmelden.
              Gute Wahl?
              Und wenn du schon betatestest, warum dann keine aktuelle Version?
              Die 7.0.8 interessiert keinen mehr.
              Falses Release, du fährst ja ein bullseye, kein buster.
              a200A 1 Antwort Letzte Antwort
                CPU threads: 2
                root
                Gute Wahl?
                a200A Offline
                a200A Offline
                a200
                CPU threads: 2
                An Performance sollte es nicht liegen, kann ich aber gerne versuchen.
                root
                ist historisch gewachsen. Sollte aber auch keinen Einfluss haben. Werde ich ändern.
                Gute Wahl?
                WIe oben beschrieben 7.1.0 ging nicht, deshalb habe ich auf 7.0.8 downgegraded mit der Hoffnung, dass es laufen wird.
                Auch nicht schlimm, die DB ist eh auf einem anderen Host. Die Instanz, die hier lief ist deaktiviert.
                Summa summarum es gibt hier nichts wirklich böses, oder? Mein Web-Adapter schmiert auch ständig ab. Jetzt bleibt nur noch das hier:
                javascript.0	2023-06-16 08:38:33.382	error	request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                javascript.0	2023-06-16 08:38:33.381	error	deprecated
                javascript.0	2023-06-16 08:38:33.380	error
                javascript.0	2023-06-16 08:38:33.379	error	WARN
                javascript.0	2023-06-16 08:38:33.378	error
                javascript.0	2023-06-16 08:38:33.377	error	npm
                javascript.0	2023-06-16 08:38:33.357	error	uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
                javascript.0	2023-06-16 08:38:33.356	error	deprecated
                javascript.0	2023-06-16 08:38:33.355	error
                javascript.0	2023-06-16 08:38:33.354	error	WARN
                javascript.0	2023-06-16 08:38:33.353	error
                javascript.0	2023-06-16 08:38:33.351	error	npm
                javascript.0	2023-06-16 08:38:33.316	error	node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
                javascript.0	2023-06-16 08:38:33.314	error	deprecated
                javascript.0	2023-06-16 08:38:33.313	error
                javascript.0	2023-06-16 08:38:33.312	error	WARN
                javascript.0	2023-06-16 08:38:33.311	error
                javascript.0	2023-06-16 08:38:33.310	error	npm
                javascript.0	2023-06-16 08:38:33.294	error	querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
                javascript.0	2023-06-16 08:38:33.292	error	deprecated
                javascript.0	2023-06-16 08:38:33.291	error
                javascript.0	2023-06-16 08:38:33.290	error	WARN
                javascript.0	2023-06-16 08:38:33.289	error
                javascript.0	2023-06-16 08:38:33.288	error	npm
                javascript.0	2023-06-16 08:38:33.216	error	deprecated har-validator@5.1.5: this library is no longer supported
                javascript.0	2023-06-16 08:38:33.215	error
                javascript.0	2023-06-16 08:38:33.214	error	WARN
                javascript.0	2023-06-16 08:38:33.212	error
                javascript.0	2023-06-16 08:38:33.211	error	npm
                host.iobroker	2023-06-16 08:40:45.186	error	instance system.adapter.javascript.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                javascript.0	2023-06-16 08:40:45.074	info	terminating
                javascript.0	2023-06-16 08:40:44.584	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                javascript.0	2023-06-16 08:40:44.584	debug	Plugin sentry destroyed
                javascript.0	2023-06-16 08:40:44.584	info	terminating
                javascript.0	2023-06-16 08:40:44.570	error	Debug Failure. Invalid cast. The supplied value [object Object] did not pass the test 'isIdentifier'.
                javascript.0	2023-06-16 08:40:44.570	error	Error: Debug Failure. Invalid cast. The supplied value [object Object] did not pass the test 'isIdentifier'. at cast (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:1170:18) at pipelineEmitWithHintWorker (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:111076:31) at pipelineEmitWithHint (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:111061:9) at pipelineEmitWithComments (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:114845:7) at pipelineEmit (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:111010:7) at emitIdentifierName (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:110984:7) at emitClassDeclarationOrExpression (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112891:9) at emitClassDeclaration (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112873:7) at pipelineEmitWithHintWorker (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:111243:20) at pipelineEmitWithHint (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:111061:9) at pipelineEmitWithComments (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:114845:7) at pipelineEmit (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:111010:7) at emit (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:110978:7) at emitListItemWithParenthesizerRule (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:115291:5) at emitNodeListItems (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:114002:9) at emitNodeList (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:113941:9) at emitList (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:113899:7) at emitBlockStatements (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112494:7) at emitModuleBlock (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112989:7) at pipelineEmitWithHintWorker (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:111253:20) at pipelineEmitWithHint (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:111061:9) at pipelineEmitWithComments (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:114845:7) at pipelineEmit (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:111010:7) at emit (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:110978:7) at emitModuleDeclaration (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112984:7) at pipelineEmitWithHintWorker (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:111251:20) at pipelineEmitWithHint (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:111061:9) at pipelineEmitWithComments (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:114845:7) at pipelineEmit (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:111010:7) at emit (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:110978:7) at emitListItemWithParenthesizerRule (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:115291:5) at emitNodeListItems (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:114002:9) at emitNodeList (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:113941:9) at emitList (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:113899:7) at emitSourceFileWorker (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:113579:7) at emitBodyWithDetachedComments (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:114951:9) at emitSourceFile (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:113507:9) at pipelineEmitWithHintWorker (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:111074:16) at pipelineEmitWithHint (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:111061:9) at pipelineEmit (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:111010:7) at print (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:110923:7) at writeFile2 (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:110907:7) at printFile (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:110747:7) at Object.printNode (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:110724:18) at transformGlobalDeclarations (/opt/iobroker/node_modules/iobroker.javascript/lib/typescriptTools.js:501:31) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:1168:64) at processImmediate (node:internal/timers:478:21)
                javascript.0	2023-06-16 08:40:44.570	error	unhandled promise rejection: Debug Failure. Invalid cast. The supplied value [object Object] did not pass the test 'isIdentifier'.
                javascript.0	2023-06-16 08:40:44.570	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                • a200A a200
                  BASE SYSTEM:
                  Skript v.2023-04-16
                  *** BASE SYSTEM ***
                  Docker          : false
                  Release:        11
                  Codename:       bullseye
                  VERSION_ID="11"
                  ID=debian
                  CPU threads: 2
                               NTP service: active
                           RTC in local TZ: no
                  root
                  /root
                  root
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Swap:           255M          0B        255M
                          2031 M used memory
                           300 M active memory
                          9315 M free memory
                            74 M buffer memory
                           544 M swap cache
                           255 M total swap
                             0 M used swap
                           255 M free swap
                  *** FILESYSTEM ***
                  /var:
                  20G     /var/
                  /usr/bin/npm            9.5.1
                  /usr/bin/npx            9.5.1
                  nodejs:
                   Version table:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          6.5.8
                  javascript:     7.0.8
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        27438
                  States:         26557
                  Pending Updates: 0
                  SUMMARY:
                                      v.2023-04-16
                  Installation:           kvm
                  User-ID:                0
                  X-Server:               false
                                         /usr/bin/npm            9.5.1
                                         /usr/bin/npx            9.5.1
                  MEMORY:
                  Swap:           255M          0B        255M
                                         admin                   6.5.8
                  Objects type: jsonl
                  States  type: jsonl
                  Objects:                27438
                  States:                 26557
                  auch du bist im Beta-Test des controllers, bitte dort fragen
                    @a200
                    Wie historisch ist das? root login wird seit Jahrzehnten nicht mehr verwendet.
                    Und natürlich kann das einen Einfluss haben.
                    • a200A a200
                      CPU threads: 2
                      root
                      Gute Wahl?
                      Sinn und Zweck eines Beta-Tests ist es ja nicht, dass du da ein laufendes System hast sondern das Fehler gefunden und in der Folge gefixt werden können.
                      • crunchipC Abwesend
                        crunchipC Abwesend
                        das gab es vor kurzem schon mal hier irgendwo in einem Thread
                        • a200A a200
                          CPU threads: 2
                          root
                          Gute Wahl?
                          Das hat auch mit den iob-Instanzen nichts zu tun sondern mit den Paketen im Betriebssystem. Die Quellen müsssen passen, sonst ziehst du dir das System krumm.
                            @crunchip
                            Hey. Ich habe auch die gleichen Probleme.
                            Meinst du diesen hier?
                            https://forum.iobroker.net/topic/66004/instance-javascript-0-stürzt-immer-ab
                              @crunchip
                              @darkness_08 sagte in Javascript Stürtzt ab:
                              auch die gleichen Beta-Versionen?
                                @homoran sagte in Javascript Stürtzt ab:
                                Welche meinst du alle?
                                Adapter    "javascript"   : 7.1.0    , installed 6.1.4  [Updatable]
                                bei Javascript bin ich von 7.1.0 auf 6.1.4 zurück. Damit läuft es.
                                Gebe aber zu ich habe keine Ahnung ob das so sinvoll war. Bin noch recht neu in iobroker und teste etwas.
                                Bin vorgestern auf den "latest" Branch gewechselt, habe vorhin alle Adapter aktualisiert und verschiedene Probleme gehabt. Der den Rest konnte ich aber soweit lösen.
                                  Macht irgendwie wenig Sinn für einen Test von Software im Beta-Stand, oder?
                                    @darkness_08 du bist ebenfalls Betatester für den noch nicht fertigen Controller.
                                    ich mach jetzt hier zu!
