  4. js-controller 5.0.x jetzt in der BETA
    6.3k
580 Beiträge 71 Kommentatoren 245.4k Aufrufe 67 Beobachtet
    @foxriver76
    Ja, der js-controller ist von alleine wieder auf die Beine gekommen. Musste nur den 'Neu laden' Button klicken. Vielleicht an der Stelle noch einen Hinweis auf eine Wartezeit bevor man das tut?
    Das Log sagte:
    2023-06-15 18:45:50.548  - info: host.chet Controller will upgrade itself to version 5.0.4
    2023-06-15 18:45:52.709  - info: host.chet [CONTROLLER_AUTO_UPGRADE] Stopping controller
    2023-06-15 18:45:52.779  - info: followthesun.0 (386726) cleaned everything up...
    2023-06-15 18:45:52.805  - info: javascript.0 (386415) Stop script script.js.common.dwd_uwz_nina_warnungen
    2023-06-15 18:45:52.816  - info: host.chet received SIGTERM
    2023-06-15 18:45:52.793  - info: miio.0 (387823) cleaned everything up...
    2023-06-15 18:45:52.789  - info: ws.0 (387741) terminating http server on port 8084
    2023-06-15 18:45:52.781  - info: backitup.0 (386608) cleaned everything up...
    2023-06-15 18:45:52.889  - info: iot.0 (426655) Connection changed: disconnect
    2023-06-15 18:45:52.786  - info: cloud.0 (386663) Connection changed: disconnect
    2023-06-15 18:45:52.868  - info: cloud.0 (386663) Connection lost
    2023-06-15 18:45:52.791  - info: tado.0 (387348) cleaned everything up...
    2023-06-15 18:45:52.891  - info: iot.0 (426655) Connection lost
    2023-06-15 18:45:52.820  - info: host.chet stopInstance system.adapter.admin.0 (force=false, process=true)
    2023-06-15 18:45:52.823  - info: host.chet stopInstance system.adapter.history.0 (force=false, process=true)
    2023-06-15 18:45:52.829  - info: host.chet stopInstance system.adapter.javascript.0 (force=false, process=true)
    [Adapterstopmeldungen gelöscht]
    2023-06-15 18:45:57.746  - info: host.chet All instances are stopped.
    2023-06-15 18:45:57.960  - info: host.chet terminated
    2023-06-15 18:46:02.134  - info: host.chet [CONTROLLER_AUTO_UPGRADE] Successfully stopped js-controller
    2023-06-15 18:46:02.160  - info: host.chet [CONTROLLER_AUTO_UPGRADE] Server is running on http://localhost:8081
    2023-06-15 18:46:54.496  - info: host.chet [CONTROLLER_AUTO_UPGRADE]
    changed 118 packages in 51s
    105 packages are looking for funding
      run `npm fund` for details
    2023-06-15 18:46:54.545  - info: host.chet [CONTROLLER_AUTO_UPGRADE] Final information delivered
    2023-06-15 18:46:59.675  - info: host.chet [CONTROLLER_AUTO_UPGRADE] Successfully started js-controller
    2023-06-15 18:47:01.300  - info: host.chet iobroker.js-controller version 5.0.4 js-controller starting
    2023-06-15 18:47:01.307  - info: host.chet Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
    2023-06-15 18:47:01.309  - info: host.chet hostname: chet, node: v18.16.0
    2023-06-15 18:47:01.309  - info: host.chet ip addresses: 192.168.178.48 2a02:908:390:33a0:219:fc3:4df3:ca0c fe80::5dfa:749b:670a:bb22 192.168.178.36 2a02:908:390:33a0:4e4e:ad2c:9a1b:dc1a fe80::2b1a:9d51:8ab7:86a8 100.86.19.122 fd7a:115c:a1e0:ab12:4843:cd96:6256:137a fe80::9b3:64c2:a9fd:95d9
    2023-06-15 18:47:03.550  - info: host.chet connected to Objects and States
    2023-06-15 18:47:03.606  - info: host.chet added notifications configuration of host
    2023-06-15 18:47:04.350  - info: host.chet Delete state "system.host.chet.versions.nodeCurrent"
    2023-06-15 18:47:04.353  - info: host.chet 40 instances found
    2023-06-15 18:47:04.427  - info: host.chet starting 36 instances
    foxriver76F Offline
    foxriver76F Offline
    foxriver76
    #196
    @thomas-braun Cool, das schaut sehr gut aus.
    @crunchip ich schaue mir das nochmal an, eigentlich wollten wir verhindern, dass DB closed throwed, evtl. haben wir da aus Versehen was kaputt gemacht bei diversen Portierungsarbeiten
    Videotutorials & mehr
    • foxriver76F foxriver76
      #197
      @foxriver76
      Willst du bei mir auch die ungekürzte Ausgabe sehen?
      War aber soweit ich das sehe nichts ungewöhnliches drin, normaler Stop der einzelnen Adapter.
      • apollon77A apollon77
        Hallo ioBroker-Community,
        Heute möchte ich Euch den js-controller 5.0 auch als Beta zur Verfügung stellen. Dieser Post enthält alle wichtigen Infos. Bitte unbedingt lesen!!
        Ich bedanke mich bei allen Usern die bisher die neue Version bereits als Alpha getestet und Feedback gegeben haben.
        Node.js Versions-Anforderungen
        In diesem Release entfällt Node.js 12.x welches seit April letztem Jahr nicht mehr gepflegt wird und Node.js 14.x welches seit April diesem Jahres EOL ist. Node.js 18.x ist dazugekommen. Die unterstützten Node.js Versionen sind: 16.4.0+ und 18.x und nach aktuellem Stand auf Node.js 20.x, wobei hier noch erfahrungen fehlen. Die empfohlene Node.js Version für ioBroker haben wir vor kurzem auf 18.x angehoben.
        Bitte beachtet weiterhin bei Node.js Updates die Anleitung im Forum unter https://forum.iobroker.net/topic/64032/update-nodejs-best-practise-supported-14-16-und-18 !
        Informationen zur Version
        Es gibt EINIGE Adapter die aktualisiert werden müssen!! Bitte weiter unten lesen!
        In dieser Version wurde die Umstellung des Quellcodes auf TypeScript sehr stark vorangetrieben (inzwischen bei 76%), wodurch am Ende die Stabilität weiter steigt weil viele Code-Fehler nicht mehr auftreten können. Natürlich sind neben Optimierungen und Fehlerbehebungen auch ein paar neue Features hinzugekommen. Auch wenn mit dieser Version keine neuen Prüfungen hinzukommen, die zu Log-Ausgaben bei Adaptern führen, meldet aktuelle Logausgaben bitte weiterhin bei den Adaptern.
        Detailliertere Informationen zu allen Änderungen und Features findet Ihr weiter unten und im Changelog. Ich hoffe auch diesmal auf Eure tatkräftige Unterstützung, sodass der Latest-Release dann genau so reibungslos verläuft wie bei den letzten Versionen.
        Für die aktive Mitarbeit an dieser Version des js-controller bedanke mich diesmal wieder besonders bei foxriver76, AlCalzone und natürlich Bluefox und auch ein paar weiteren Entwicklern!
        ACHTUNG backups inkompatibel bei Downgrades!!
        Neben der Node.js Version gibt es eine wichtige Inkompatibilität: Backups die mit der 5.0 des js-controller erstellt wurden lassen sich nicht mit einem js-controller 4 oder kleiner wieder restoren!
        Darüber hinaus ist der js-controller 5.0 generell kompatibel mit allen bestehenden ioBroker-Systemen. Ein Update von der 2.0/2.1/2.2/3.x ist problemlos möglich. Wir empfehlen allerings vor dem Update auf die 5.0 idealerweise ein Update auf die 4.0 und vorher auf 3.3.x durchzuführen, da ein Downgrade nach einem erfolgten Update nur auf eine 3.3.x möglich ist (siehe FAQ)! Nur die Node.js Version muss weiterhin mindestens 16.x sein, wie oben bereits ausgeführt. Wer überlegt die Node.js Version anzuheben bitte weiter unten im Abschnitt "Was ist zu testen" lesen 🙂
        Aufgrund einiger internen Umstellungen brauchen wieder einige Adapter Updates. Diese sollten am besten VOR dem Update installiert werden!
        Bitte dazu die Informationen weiter unten beachten!
        Installation
        VOR der Installation
        Wie bei jedem Test dieser Art: Bitte macht ein Backup! iobroker backup bzw kopieren des iobroker-data Verzeichnisses reichen an sich aus. Bitte nicht das node_modules Verzeichnis einfach kopieren, da sonst symbolische Links kaputt gehen können, was zu größeren Problemen danach führt. Eine alte 4.0.x-Version des js-controller kann im Notfall einfach wieder per npm install iobroker.js-controller@version ("version" durch die gewünschte Versionsnummer ersetzen) installiert werden und sollte alles wieder herstellen (Letzter Stable Stand ist die 4.0.24)
        Nötige Adapter-Aktualisierungen
        Am besten dennoch VOR dem js-controller Update alle verfügbaren Adapter-Updates prüfen und alle Updates installieren, die im Changelog auf Optimierungen oder Anpassungen für den js-controller 4.0 oder höher hinweisen.
        Diesmal sind doch einige Adapter auf der Liste die man updaten muss! Siehe Spoiler!
        • admin -> v6.2.23+
        • backitup v2.6.16+
        • cloud v4.2.3+
        • discovery v3.0.6+
        • email v1.1.4+
        • enigma2 (GitHub version fixed)
        • fitbit-fitness - noch kein Fix
        • history v2.2.4+
        • hmrega v3.0.46+
        • iquontrol v2.2.1+
        • lgtv from https://github.com/foxriver76/ioBroker.lgtv nutzen bis Entwickler angepasst hat
        • lovelace - > v2.2.0+
        • mercury - released v0.1.6+
        • mqtt: v4.1.1+
        • nibeuplink v1.2.1+
        • node-red v4.0.1+
        • onvif 1.0.1+
        • owntracks v1.0.5+
        • pimatic v0.3.1+
        • rest-api -> v1.0.5+
        • ring - released in v3.2.7+
        • sayit v1.13.0+
        • simple-api v2.7.2+
        • smart-visu GitHub
        • socketio -> v6.2.0+
        • sonos v2.3.1+
        • synology v2.1.13+
        • tado v???? (issue opened)
        • telegram v1.15.1+
        • terminal v1.0.0+
        • tr-064 v4.2.18+
        • tuya v3.7.0+
        • unifi-protect v0.0.12+
        • web v5.2.10+
        • ws -> v2.2.0+
        • vis-google-fonts v1.0.4+
        • xterm v1.1.0+
        • yahka - v1.0.0+
        Achtung: MASTER-Systeme Reihenfolgen beachten!
        Bei einem Multi-Host-System, welches auf js-controller 2.2, 3.x oder 4.0.x läuft, ist es beim Update auf Version 5.0 empfohlen, zuerst das Master-System zu aktualisieren. Der Master muss dann wieder gestartet werden. Die Slaves werden danach aktualisiert!
        Bei Updates von Master/Slave-Systemen mit js-controller 1.5 oder früher Bitte die jeweiligen Update Threads der empfohlenen Zwischenversionen prüfen.
        Windows
        Generell muss das Update manuell via npm installiert werden.
        Hierzu im ioBroker-Verzeichnis nach stoppen des ioBroker den Befehl iob upgrade self ausführen.
        Linux
        • ioBroker stoppen (iobroker stop)
        • Prüfen das keine Prozesse (Adapter, Backups) mehr laufen (ps auxww|grep io und auch ps auxww|grep backup ). Es passiert manchmal das trotz dem Stoppen noch Zombies zurückbleiben
        • cd /opt/iobroker
        • Das Update erfolgt via iob upgrade self
        • ioBroker starten (iobroker start)
        Bei Fehlern:
        Wenn bei der Installation Fehler wegen fehlender Zugriffsrechte auftreten, am besten den Installation-Fixer (iobroker fix wer schon einen js-controller 2.x oder höher hat, alternativ weiterhin manuell via curl -sL https://iobroker.net/fix.sh | bash -) nutzen und die Installation wiederholen.
        Falls es auch danach noch Fehler gibt, bitte die Installation erneut mittels sudo -H -u iobroker npm install iobroker.js-controller versuchen. Bitte berichtet solche Fälle hier im Thread.
        NACH der Installation
        Wenn alles klappt merkt Ihr ausser der höheren Versionsnummer in der Host-Ansicht im Admin keinen Unterschied. Alles funktioniert weiterhin wie vorher. Alle Adapterinstanzen starten und funktionieren. Wenn das so ist hat alles geklappt.
        Falls im Log Warn-Meldungen auftauchen mit dem Hinweis diese an den Entwickler zu senden, dann bitte schauen welcher Adapter es ist und entsprechend dort Issues bitte anlegen!
        Was hat sich geändert, was besonders ansehen/beachten?
        Neben einiger weiterer Bugfixes gibt es folgende Änderungen und Fixes zu erwähnen:
        • generell siehe Changelog, speziell auch für die Features
        • generell bitte im CLI und auch sonst überall drüber schauen. Die Typescript Umstellungen haben sehr viel Code angefasst.
        • Falls jemand sporadisch Alias Fehler im Log hatte bitte versuchen diese mit der neuen version wieder zu provoziere und rückmelden
        Speziell die Entwickler sollten bitte die genannten Deprecations und neuen Features anschauen und beachten.
        Wie bereits gesagt, viele Änderungen fanden hinter den Kulissen statt. Hier für Interessierte als Spoiler eine Zusammenfassung:
        5.0. Release Jana
        BREAKING CHANGES
        • Support for Node.js 12 and 14 is dropped! Supported are Node.js 16.4.0+ and 18.x and hopefully 20.x
        • Backups created with the new js-controller version cannot be restored on hosts with lower js-controller version!
        • Update recommended npm version to 8
        • Deprecate binary states, Adapters will change to use Files instead!
        Features
        • (foxriver76) Show npm error message on failing adapter installations and update also without debug parameter
        • (foxriver76) Introduce iobroker setting (dnsResolution) to choose between verbatim and ipv4 first dns resolution order
        • (foxriver76) Add support for windows for iob fix
        • (bluefox) Added CLI option to restart/start/stop all instances of an adapter (e.g. iob stop admin now also works)
        • (foxriver76) Allow to use iob host oldname command when new host already exists but has no instances
        • (foxriver76) Added an admin notification if redis is misconfigured and info how to fix it
        • (foxriver76) Enable upgrade of js-controller via Admin UI (Linux only)
        Optimizations and Fixes
        • (foxriver76) Speedup "getStates" calls with many IDs often used by visualizations: JSONL 17 times faster, Redis 23 times faster
        • (foxriver76) significantly reduce backup size
        • (foxriver76) Enhance CLI help for list command to show all possible types to list
        • (foxriver76) Also stop instances before updating from GitHub
        • (foxriver76) Conversion of big parts of the js-controller codebase to typeScript and address all found issues
        • (Apollon77) Only log error on "enable/disable via .alive" if there is an error
        • (foxriver76) Optimize adapter unload and stop handling for edge cases
        • (AlCalzone) Carefully normalize jsonlOptions
        • (bluefox) Do not show warning on a requested adapter stop/termination
        • (bluefox) Make sure that the first log line is not missing in Admin
        • (foxriver76) Fix wrong formatting of cli get binary state if no encoding is passed
        • (foxriver76) Fix restoring backups from pre js-controller 4.x which were created without config.system
        • (foxriver76) Preserve tier setting on adapter upload
        • (foxriver76) update apt sources before installing os dependencies
        • (foxriver76) Only skip erase on upload if opted out explicitly to always cleanup unneeded files
        • (foxriver76) Try to fix strange alias errors, inform us if it happens again!
        • (foxriver76) Remove windows bat files completely, installer will create them when needed
        • (AlCalzone/Apollon77) Update jsonl db to prevent locking issues
        • (foxriver76) Fixes iob file sync not working for jsonl
        • (foxriver76) Do not crash if we cannot initialize db backup directory on start
        • (foxriver76) Fixed issue with certificate validity on leap years
        • (Apollon77/foxriver76) Make sure that all relevant files are removed when eraseOnUpload is used
        • (foxriver76) fix wrong hostname after backup restore
        • (bluefox) allow CLI vendor update without explicitly specifying vendor file (default file is used)
        • (Apollon77, foxriver76, bluefox, AlCalzone) Several fixes and refactorings to prevent potential crash cases reported by Sentry and other sources
        Developer relevant DEPRECATIONS/WARNINGS
        • Deprecate binary states, Migrate your adapters to use Files instead!
        • If you need to access special js-controller common tools please use adapter-core instead of js-controller directly - see https://github.com/ioBroker/adapter-core#commontools
        • Parameter that contain patterns (e.g. mqtt.*) are now checked for allowed characters and general correctness!
        Developer relevant new Features
        • (bluefox) Added options to subscribe to file changes: subscribeForeignFiles, unsubscribeForeignFiles, onAdapterFileChanged (event contains id, fileName, size and not the whole content of the file!)
        • (foxriver76) Introduce on("install") handler for adapter which is automatically called when adapter process is started with --install
        • (foxriver76) Introduce io-package flag common.nodeProcessParams to allow to pass adapter specific nodejs process parameters (disables compact mode for the adapter!)
        • (foxriver76) Respect dns resolution (ipv4/ipv6 first) from config internally and provide relevant methods via adapter-core
        • (foxriver76) Add JSON-Schema for iobroker.json
        • (bluefox) Allowed export of password.js (to be used with adapter-core)
        • (bluefox) Added _design/chart to the system designs
        • (foxriver76) Automatically generated Code-Docs for Adapter class https://github.com/ioBroker/ioBroker.js-controller/tree/master/packages/controller/doc
        • (foxriver76) Added (foreign)objectExists to adapter methods
        • (bluefox) Extend getSuitableLicenses to look for other licenses
        • (buefox/foxriver76) Added new category for notifications: blocked and respect js-controller common.blockedVersions to block versions from starting
        • (bluefox) Added new system view "custom-full" to return the full objects for objects with a custom part and not only the custom details
        • (foxriver76) Added support for getForeignObjects with an array of strings as pattern
        • (AlCalzone) Preparations to allow js-controller Dev version to be used with dev-server
        • (foxriver76) Validate max timeout value (max 32bit max number) on setTimeout/setInterval and throw on error to prevent issues
        • (foxriver76) new io-package flag common.supportedMessages to replace messagebox and other messagebox-related properties
        • (foxriver76) adapter.sendTo now accepts an optional timeout argument
        • Developer relevant Optimizations and Fixes
        • (foxriver76) Ensure setObjectNotExists returns id on success
        • (foxriver76) Fix Typings for sendTo/sendToHost
        • (Bluefox) Add User permission check to requireLog
        • (foxriver76) added nonEdit property of objects to types and document functionality
        • (foxriver76) introduced constants for state quality
        • (foxriver76) subscribeStates now also accepts an array of ids
        • general dependency updates
        • code style optimizations and streamline code
        Generell ist zu testen, ob alles noch so funktioniert wie vorher auch. Das ist das wichtigste!
        Wie Fehler melden?
        Wer sich unsicher ist, ob ein Fehler vorliegt, sollte am besten hier im Thread das Problem beschreiben. So können wir alle versuchen, das Problem nachzuvollziehen und ggf. einzugrenzen.
        Bitte checkt auch die "Known issues Liste" (zweiter Post).
        Sobald ein Fehler auftritt der in einer Fehlermeldung oder einen Crash mit Fehlerdetails im Log oder auf Kommandozeile endet, dann dazu am besten direkt ein GitHub-Issue im js-controller Projekt öffnen und zusätzlich hier im Thread posten. Je detaillierter die Angaben im Issue sind (genaue Fehlermeldungen/Logs, Infos zur OS- und Node.js-Umgebung sowie genaue Schritte zur Reproduktion des Problems), umso schneller können wir Fehler einkreisen und beheben.
        Bitte postet auch die Ausgabe von iob diag mit rein.
        Wir wünschen allen viel Spaß beim Testen und vielen Dank für Eure Unterstützung!
        Ingo
        ehome
        #198
        @apollon77 So ich oute mich mal als Voll-Honk....
        habe heute morgen den upgrade js-controller gemacht, da er mir als neu im Webinterface unter Hosts angezeigt wurde. Mir war nicht bewusst, dass ich mit dem Update zum Beta-Tester werde, ich dachte immer da müsste man das entsprechende repo eingebunden haben .....
        root@iobroker:/opt/iobroker# iob repo list
        Stable (default): http://download.iobroker.net/sources-dist-latest.json
        In meinem Multi-Host System habe ich dann den Master und anschließend den Client upgedatet - ging über das CLI fehlerlos.
        Dann gingen die Probleme mit dem Viessmann-Adapter los....
        Meinen Post: Nach update js-controller Probleme mit Viesmann Adapter in "Iobroker Allgemein" hat @Homoran daraufhin gesperrt (er hat natürlich recht - is ja beta) mit dem Verweis den Post in diesem Bereich zu erstellen.
        Jetzt meine Fragen:
        1. wie verschiebe ich den Post - er ist gesperrt und ich kann nichts daran ändern
        2. gibt es einen einfachen Weg zurück
        3. wieso wird mir das Update angezeigt obwohl ich kein beta-repo eingebunden habe...
        Fragen über Fragen .....
        crunchipC Thomas BraunT 2 Antworten Letzte Antwort
        • E ehome
          Jetzt meine Fragen:
          crunchipC Offline
          crunchipC Offline
          #199
          @ehome sagte in js-controller 5.0.x jetzt in der BETA:
          stable>>latest
          dein repo ist falsch, somit bist du beta Tester
          brauchst du nicht
          steht im ersten Beitrag
          • E ehome
            Jetzt meine Fragen:
            #200
            @ehome
            'latest' ist das Beta-Repo, egal ob du das für dich 'Stable' nennst.
            So wird ein Schuh draus:
            echad@chet:~ $ iob repo list
            live-stable   : http://iobroker.live/repo/sources-dist.json
            live-beta     : http://iobroker.live/repo/sources-dist-latest.json
            E 1 Antwort Letzte Antwort
            • F Online
              F Online
              fastfoot
              #201
              Versuch des Upgrades 5.0.3-->5.0.4 via GUI schlägt fehl unter Windows:
              ein anschliessendes Upgrade via Konsole funktioniert problemlos
              OS: Windows 10
              Node: 18.15.0
              NPM: 9.5.0
              IOB: Alles neueste Betas
              • F fastfoot
                OS: Windows 10
                Node: 18.15.0
                NPM: 9.5.0
                foxriver76F Offline
                foxriver76F Offline
                foxriver76
                #202
                @fastfoot Windows wird nicht unterstützt für UI Upgrade, da brauchts allerdings noch ein Admin Update, sollte er nicht anzeigen.
                  F Online
                  F Online
                  fastfoot
                  #203
                  @foxriver76 sagte in js-controller 5.0.x jetzt in der BETA:
                  ah ok, danke, wollte es nur gemeldet haben, habe evtl. auch entsprechende Info hier überlesen
                    @ehome
                    ehome
                    schrieb am zuletzt editiert von ehome
                    #204
                    @thomas-braun @crunchip danke für die Aufklärung, hab mich mal aus dem beta-Programm abgemeldet ;) und einen downgrade durchgeführt. Warte dann bis alle "stable" ist.
                    • F fastfoot
                      foxriver76F Offline
                      foxriver76F Offline
                      foxriver76
                      #205
                      @fastfoot Ist gut, ich hätte erwartet, dass Admin es auch gar nicht anzeigt ;-)
                        Marty56
                        schrieb am zuletzt editiert von Marty56
                        #206
                        5.0.4 installiert. Derzeit Betrieb ohne Probleme.
                        Bisher ist der "Alias Error Burst" noch nicht aufgetreten.
                        Mein Problem mit Yakha war die Referenz auf einen nicht existierenden Datenpunkt, der wohl im Yakha Adapter unter der 4.x Version von js-controller ignoriert wurde und jetzt unter 5.0.4 zu riesigen Menge von fatalen Fehlern geführt hat.
                        HW:NUC (16 GB Ram)
                        OS: Debian Bullseye, Promox V7, node v16.x npm 8.19.3
                        • UweRLPU UweRLP
                          Hallo.
                          Reihe ich mich mal hier ein.
                          Heute update js-controller 4.0.24 von auf 5.0.3 gefahren.
                          Will gleich hinterher schicken, dass das System schon mehrer controller Updates mitgemacht hat...
                          System:
                          - Windows 10 x64
                          - NodeJS 18.16.0 (global keine instanzen Installation)
                          iobroker liegt bei mit unter c:\iobroker
                          enigma2.0 v1.3.3 Adapter läuft nicht mehrer, hat allerdings für mich nicht Priorität.
                          Im VIS werden nicht mehr alle Grafiken geladen.
                          Aus alter Installation hatte ich eigene Grafiken in
                          c:\iobroker\iobroker-data\files\vis\img\ !Diese wurden übernommen
                          c:\iobroker\iobroker-data\files\vis\img\Garage\ !Nicht übernommen
                          c:\iobroker\iobroker-data\files\vis\img\Homematic\ !Nicht übernommen
                          c:\iobroker\iobroker-data\files\vis\img\Wohnung\ !Nicht übernommen
                          Nach dem upgrade waren die Verzeichnisse vorhanden die Grafiken aber gelöscht.
                          iobroker gestoppt und die Grafiken wieder zurück kopiert hilft leider auch nicht.
                          Diese werden nicht mehr gelöscht aber in der VIS auch nicht angezeigt.
                          Einen Vorschlag diese wieder "anzeigbar" zu machen ohne alles anfassen zu müssen?
                          UweRLPU Offline
                          UweRLPU Offline
                          UweRLP
                          #207
                          @uwerlp sagte in js-controller 5.0.x jetzt in der BETA:
                          enigma2.0 v1.5.0 startet dann auch unter 5.x 👍
                          Ist in 5.0.4 behoben, Grafiken werden nicht mehr gelöscht und in vis angezeigt.
                          Danke!
                          • mcm1957M Offline
                            mcm1957M Offline
                            mcm1957
                            #208
                            @apollon77
                            Betrifft Problemliste:
                            Ist der Adapter Vissmann in der Queue? Im Comment am Anfang hab ich ihn noch nicht gefunden.
                            Problem:
                            https://forum.iobroker.net/topic/66187/nach-update-js-controller-probleme-mit-viesmann-adapter
                            Issue: https://github.com/misanorot/ioBroker.viessmann/issues/121
                            Support Repositoryverwaltung.
                            LESEN - gute Forenbeitrage
                              Sandy
                              #209
                              Hallo
                              Also bei mir zeigen nach dem Update alle Wetter Instanzen eine Warnung an.
                              Gruss Sandy
                              • S Sandy
                                Hallo
                                Gruss Sandy
                                #210
                                @sandy
                                Kann es sein, dass 'daswetter' ein Scheduled-Adapter ist und der einfach nur im eingestellten Intervall startet?
                                S sigi234S 2 Antworten Letzte Antwort
                                  @sandy
                                  Sandy
                                  #211
                                  @thomas-braun da kenne ich mich leider nicht so mit aus :-(
                                    @sandy
                                    sigi234S Online
                                    sigi234S Online
                                    #212
                                    @thomas-braun sagte in js-controller 5.0.x jetzt in der BETA:
                                    Jupp
                                    • sigi234S sigi234
                                      Jupp
                                      Sandy
                                      #213
                                      @sigi234 was kann ich denn dagegen machen ?
                                      M sigi234S 2 Antworten Letzte Antwort
                                      • S Sandy
                                        #214
                                        @sandy sagte in js-controller 5.0.x jetzt in der BETA:
                                        Aber mit Beta-Zeug herummachen.
                                        Wenig sinnig.
                                        Nichts, das ist so richtig und soll so sein.
                                          Upgrade von 5.0.3 auf 5.0.4 über GUI hat bei mir funktioniert.
                                          Wollte ich nur mal verkünden.
                                          Monger71
                                          schrieb am zuletzt editiert von Monger71
                                          #215
                                          Bei mir klappt es noch nicht. Wird zwar angezeigt, dass 5.0.4 verfügbar ist (im Info-Bereich), bei Host, steht eine (1), dort steht noch, dass nur 5.0.3 verfügbar und auch installiert ist. (Linux-Umgebung)
                                          Denke mal, dass es aus dem Host-Bereich installierbar sein sollte, oder?
                                          Nebenbei ist mir gerade noch aufgefallen, dass auch ein Adapter als hochrüstbar gemeldet wurde, das Update aber auch nicht in der Adapter-Liste angezeigt wurde. War Discovery 3.1.0 => 3.2.0. Per Konsole ging es.
                                          5.0.4 war übrigens dann auch per Konsole möglich..
