  4. Nach update js-controller Probleme mit Viesmann Adapter
    6.3k
2 Beiträge 2 Kommentatoren 463 Aufrufe
  • E Offline
    ehome
    hat jemand ein ähnliches Problem nach dem Update auf js-controller v5.0.3 mit dem Viesmann
    Adapter ?
    Da die Probleme nach dem Update des js-controllers auftauchten vermute ich den Fehler irgendwo dort - kann es aber nicht genau sagen. Deshalb wäre es interessant ob jemand den Adapter mit der js-controller version laufen hat.
    Bei mir installiert:
    js-controller v5.0.3 (docker based)
    viessmann v1.4.3
    npm: 18.16.09.5.1
    Fehler im Log:
    2023-06-15 21:55:06.489  - info: host.iobroker instance system.adapter.viessmann.0 started with pid 55242
    2023-06-15 21:55:07.969  - error: viessmann.0 (55242) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2023-06-15 21:55:07.970  - error: viessmann.0 (55242) unhandled promise rejection: Parameter "options" needs to be a real object but type "boolean" has been passed
    2023-06-15 21:55:07.972  - error: viessmann.0 (55242) Error: Parameter "options" needs to be a real object but type "boolean" has been passed
        at Viessmann.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5331:35)
        at Viessmann.setStateAsync (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js:2006:16)
        at Viessmann.main (/opt/iobroker/node_modules/iobroker.viessmann/main.js:588:8)
        at Viessmann.startAdapter (/opt/iobroker/node_modules/iobroker.viessmann/main.js:116:15)
        at Viessmann.onReady (/opt/iobroker/node_modules/iobroker.viessmann/main.js:55:9)
        at Viessmann.emit (node:events:513:28)
        at Viessmann._callReadyHandler (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:9017:18)
    2023-06-15 21:55:07.972  - error: viessmann.0 (55242) Parameter "options" needs to be a real object but type "boolean" has been passed
    2023-06-15 21:55:07.995  - warn: viessmann.0 (55242) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2023-06-15 21:55:08.596  - error: host.iobroker instance system.adapter.viessmann.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2023-06-15 21:55:08.596  - info: host.iobroker Restart adapter system.adapter.viessmann.0 because enabled
    Der Adapter wird dann in einer Endlosschleife neu gestartet.
    lg Olli
    • E ehome
      Adapter ?
      viessmann v1.4.3
      npm: 18.16.09.5.1
      Fehler im Log:
      lg Olli
      @ehome bitte im Beta-Tester Thread posten!
