  4. Test Adapter Birthdays
    6.3k
adapterbirthdayerinnerunggeburtstagtester
338 Beiträge 56 Kommentatoren 96.6k Aufrufe 70 Beobachtet
  • Ben1983B Offline
    Ben1983B Offline
    Ben1983
    #259
    @haus-automatisierung Du hast ja mit dem letzt Update das doppelte hinzufügen von Geburtstagen verhindert.
    Nun ist aber meine Frage wieso wird bei mir dieser Geburtstag doppelt erkannt?
    Er ist nur einmal im Kalender drin:
    birthdays.0 2023-06-12 09:07:30.708	warn	[addBirthday] birthday with name "Benjamin Schmidt" has already been added (28.05.2024) - skipping
    birthdays.0 2023-06-12 09:07:30.708	debug	[ical] found birthday: Benjamin Schmidt (1983)
    birthdays.0 2023-06-12 09:07:30.708	debug	[ical] processing event: {"component":["vevent",[["dtstart",{},"date","2023-05-28"],["dtend",{},"date","2023-05-29"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T07:07:30Z"],["uid",{},"text","59p0iv4vn4crf2c544ha2jl368@google.com"],["created",{},"date-time","2023-04-10T19:53:29Z"],["description",{},"text","1983"],["last-modified",{},"date-time","2023-04-10T19:53:29Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Benjamin Schmidt"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
    birthdays.0 2023-06-12 09:07:30.692	debug	[ical] found birthday: Benjamin Schmidt (1983)
    birthdays.0 2023-06-12 09:07:30.692	debug	[ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-05-28"],["dtend",{},"date","2022-05-29"],["dtstamp",{},"date-time","2023-06-12T07:07:30Z"],["uid",{},"text","07jehvfnu7rf2inqdqrmh94tos@google.com"],["created",{},"date-time","2022-03-11T22:47:50Z"],["description",{},"text","1983"],["last-modified",{},"date-time","2022-03-11T23:41:43Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Benjamin Schmidt"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
    Was kann ich tun, um diese Warnung weg zu bekommen? Also was müsste ich am Kalender / Eintrag ändern?
    • Ben1983B Ben1983
      haus-automatisierungH Offline
      #260
      @ben1983 Mh - wie genau sieht der ical Eintrag denn aus? Kannst Du die EVENT Definition aus der Datei mal teilen?
      📚 Meine Dokumentation
        Ben1983B Offline
        Ben1983B Offline
        Ben1983
        #261
        @haus-automatisierung ich habe gerade den Eintrag des Geburtstags gelöscht. die Warnung kommt nicht mehr, aber der Geburtstag steht trotzdem noch im Log drin als erkannt?
        Wieso stehen eigentlich nur manche Geburtstage als "found Birthday" drin?
        Welche Definition meinst Du denn? Die vom Kalender?
        • Ben1983B Ben1983
          #262
          @ben1983 sagte in Test Adapter Birthdays:
          Ich verstehe die Frage nicht. Wenn der Kalendereintrag den Vorgaben (siehe Doku) entspricht, dann sollte diese Meldung für alle Geburtstage auftauchen.
          Wenn Du die ical Datei mit einem Texteditor öffnest, dann suchst Du nach dem EVENT-Abschnitt, welcher den genannten Termin betrifft. Irgendwo müssen die ja doppelt her kommen. Eventuell hast Du ja auch mal einen einzelnen Termin aus einer Termin-Serie gelöscht und dadurch gibt es nun für den gleichen Geburtstag zwei Definitionen.
          Ben1983B 2 Antworten Letzte Antwort
            Ben1983B Offline
            Ben1983B Offline
            Ben1983
            schrieb am zuletzt editiert von Ben1983
            #263
            @haus-automatisierung ich habe ziemlich viele von diesen Einträgen:
            birthdays.0
            2023-06-12 09:30:43.597	debug	[fillPathWithBirthday] path: "month.06.stephanPanz", birthday: {"name":"Stephan Panz","birthYear":1979,"dateFormat":"03.06.2024","age":45,"daysLeft":357,"_birthday":"1979-06-02T23:00:00.000Z","_nextBirthday":"2024-06-02T22:00:00.000Z"}
            birthdays.0
            2023-06-12 09:30:43.593	debug	[fillPathWithBirthday] path: "month.05.maxBreuer", birthday: {"name":"Max Breuer","birthYear":1994,"dateFormat":"25.05.2024","age":30,"daysLeft":348,"_birthday":"1994-05-24T22:00:00.000Z","_nextBirthday":"2024-05-24T22:00:00.000Z"}
            birthdays.0
            2023-06-12 09:30:43.587	debug	[fillPathWithBirthday] path: "month.05.eddiSchmidt", birthday: {"name":"Eddi Schmidt","birthYear":1999,"dateFormat":"20.05.2024","age":25,"daysLeft":343,"_birthday":"1999-05-19T22:00:00.000Z","_nextBirthday":"2024-05-19T22:00:00.000Z"}
            birthdays.0
            2023-06-12 09:30:43.583	debug	[fillPathWithBirthday] path: "month.05.linaGrywnow", birthday: {"name":"Lina Grywnow","birthYear":2013,"dateFormat":"20.05.2024","age":11,"daysLeft":343,"_birthday":"2013-05-19T22:00:00.000Z","_nextBirthday":"2024-05-19T22:00:00.000Z"}
            birthdays.0
            2023-06-12 09:30:43.579	debug	[fillPathWithBirthday] path: "month.05.tabeaMeinhardt", birthday: {"name":"Tabea Meinhardt","birthYear":1996,"dateFormat":"18.05.2024","age":28,"daysLeft":341,"_birthday":"1996-05-17T22:00:00.000Z","_nextBirthday":"2024-05-17T22:00:00.000Z"}
            birthdays.0
            2023-06-12 09:30:43.575	debug	[fillPathWithBirthday] path: "month.05.constantinBreuer", birthday: {"name":"Constantin Breuer","birthYear":1989,"dateFormat":"17.05.2024","age":35,"daysLeft":340,"_birthday":"1989-05-16T22:00:00.000Z","_nextBirthday":"2024-05-16T22:00:00.000Z"}
            birthdays.0
            2023-06-12 09:30:43.568	debug	[fillPathWithBirthday] path: "month.05.valeskaBreuer", birthday: {"name":"Valeska Breuer","birthYear":1989,"dateFormat":"17.05.2024","age":35,"daysLeft":340,"_birthday":"1989-05-16T22:00:00.000Z","_nextBirthday":"2024-05-16T22:00:00.000Z"}
            Der Eintrag war noch doppelt drin, stimm letztes Jahr stand er noch einzeln drin.
              Ben1983B Offline
              Ben1983B Offline
              Ben1983
              #264
              @haus-automatisierung sagte in Test Adapter Birthdays:
              Das zB.
              BEGIN:VEVENT
              DTSTART;VALUE=DATE:20220627
              DTEND;VALUE=DATE:20220628
              RRULE:FREQ=YEARLY
              DTSTAMP:20230612T073725Z
              UID:xyzblablabla@google.com
              CREATED:20220311T233833Z
              DESCRIPTION:1959
              LAST-MODIFIED:20220311T233833Z
              SEQUENCE:0
              STATUS:CONFIRMED
              SUMMARY:Horst Schmidt
              TRANSP:TRANSPARENT
              END:VEVENT
              • Ben1983B Ben1983
                birthdays.0
                birthdays.0
                birthdays.0
                birthdays.0
                birthdays.0
                birthdays.0
                birthdays.0
                #265
                @ben1983 Was ist denn jetzt genau das Problem?
                • Du löschst einzelne Einträge und plötzlich verschwindet die Meldung, aber der Termin bleibt? Also war er vorher doppelt drin und die Meldung hatte recht?
                • Du bekommst Debug-Ausgaben, dass die entsprechenden Objekte angelegt werden (das ist doch alles richtig?)
                • Du teilst ein EVENT von einem ganz anderen Eintrag, als zu dem doppelten vom Anfang.
                Ich kann so nicht helfen. Bitte mal eine konkrete Problembeschreibung von A-Z mit einem Beispiel Kalendereintrag und was genau Du wartet hättest / was Deiner Meinung nach falsch läuft.
                  Ben1983B Offline
                  Ben1983B Offline
                  Ben1983
                  #266
                  Zu 1.
                  Ja, der Termin war doppelt drin und die Meldung hatte recht.
                  Zu 2.
                  Die Debug Meldungen bekomme ich für viele Geburtstage (sagen wir ca. 30 STück),
                  aber das "found Birthday" erscheint nur bei einer hand voll.
                  Zu 3.
                  Diesen Beitrag habe ich genommen, weil dies einer ist, der zwar im log steht,
                  aber ein found Birthday nicht erscheint.
                  Die Geburtstage werden ja angezeigt.
                  Ich hatte mich nur gefragt, warum das "found Birthday" nur bei manchen im log erscheint.
                  • Ben1983B Ben1983
                    Zu 1.
                    Zu 2.
                    Zu 3.
                    #267
                    Kann ja nicht sein: https://github.com/klein0r/ioBroker.birthdays/blob/b8e239334fea3a49d692c217d906e4b87cc3b5d3/main.js#L207
                      Ben1983B Offline
                      Ben1983B Offline
                      Ben1983
                      #268
                      @haus-automatisierung Hier der komplette log:
                      da ist es jetzt öfter drin. Ich schwöre, dass es eben nur 7 mal drin war. Leider habe ich den log von eben nicht mehr.
                      2023-06-12 10:36:40.395 - info: host.buanet-iobroker_8_0_1 stopInstance system.adapter.birthdays.0 (force=false, process=false)
                      2023-06-12 10:36:40.396 - info: host.buanet-iobroker_8_0_1 stopInstance canceled schedule system.adapter.birthdays.0
                      2023-06-12 10:36:43.455 - info: host.buanet-iobroker_8_0_1 instance scheduled system.adapter.birthdays.0 0 0 * * *
                      2023-06-12 10:36:43.482 - info: host.buanet-iobroker_8_0_1 instance system.adapter.birthdays.0 started with pid 7102
                      2023-06-12 10:36:44.088 - debug: birthdays.0 (7102) Redis Objects: Use Redis connection: 127.0.0.1:9001
                      2023-06-12 10:36:44.225 - debug: birthdays.0 (7102) Objects client ready ... initialize now
                      2023-06-12 10:36:44.289 - debug: birthdays.0 (7102) Objects create System PubSub Client
                      2023-06-12 10:36:44.290 - debug: birthdays.0 (7102) Objects create User PubSub Client
                      2023-06-12 10:36:44.342 - debug: birthdays.0 (7102) Objects client initialize lua scripts
                      2023-06-12 10:36:44.349 - debug: birthdays.0 (7102) Objects connected to redis: 127.0.0.1:9001
                      2023-06-12 10:36:44.377 - debug: birthdays.0 (7102) Redis States: Use Redis connection: 127.0.0.1:9000
                      2023-06-12 10:36:44.432 - debug: birthdays.0 (7102) States create System PubSub Client
                      2023-06-12 10:36:44.433 - debug: birthdays.0 (7102) States create User PubSub Client
                      2023-06-12 10:36:44.494 - debug: birthdays.0 (7102) States connected to redis: 127.0.0.1:9000
                      2023-06-12 10:36:44.866 - info: birthdays.0 (7102) starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.birthdays, node: v18.16.0, js-controller: 4.0.24
                      2023-06-12 10:36:44.985 - debug: birthdays.0 (7102) [settings] done
                      2023-06-12 10:36:44.986 - debug: birthdays.0 (7102) [ical] url/path: https://calendar.google.com/calendar/ical/qqp6g7e3v0q26ss82l5o38v2h0%40group.calendar.google.com/private-558febf6616d48bb1091ba66884d5afa/basic.ics
                      2023-06-12 10:36:44.986 - debug: birthdays.0 (7102) [ical] addByCalendar - looks like an http url, performing get request
                      2023-06-12 10:36:45.051 - debug: birthdays.0 (7102) [carddav] done - url not configured - skipped
                      2023-06-12 10:36:45.416 - debug: birthdays.0 (7102) [ical] http(s) request finished with status: 200
                      2023-06-12 10:36:45.422 - debug: birthdays.0 (7102) [ical] found 35 events
                      2023-06-12 10:36:45.424 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-05-17"],["dtend",{},"date","2022-05-18"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","50pbhcvqjg1vb5fujsbfg7ntae@google.com"],["created",{},"date-time","2022-03-11T23:34:25Z"],["description",{},"text","1989"],["last-modified",{},"date-time","2022-03-11T23:34:25Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Constantin Breuer"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                      2023-06-12 10:36:45.424 - debug: birthdays.0 (7102) [ical] found birthday: Constantin Breuer (1989)
                      2023-06-12 10:36:45.427 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-05-12"],["dtend",{},"date","2022-05-13"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","3j95d8maughq65lm97s86dlef4@google.com"],["created",{},"date-time","2022-03-11T23:33:28Z"],["description",{},"text","1987"],["last-modified",{},"date-time","2022-03-11T23:34:40Z"],["sequence",{},"integer",1],["status",{},"text","CONFIRMED"],["summary",{},"text","Valentina Breuer"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                      2023-06-12 10:36:45.428 - debug: birthdays.0 (7102) [ical] found birthday: Valentina Breuer (1987)
                      2023-06-12 10:36:45.429 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-05-17"],["dtend",{},"date","2022-05-18"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","60l37rgp3q8cshqoq26m2vgkho@google.com"],["created",{},"date-time","2022-03-11T23:35:11Z"],["description",{},"text","1989"],["last-modified",{},"date-time","2022-03-11T23:35:11Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Valeska Breuer"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                      2023-06-12 10:36:45.429 - debug: birthdays.0 (7102) [ical] found birthday: Valeska Breuer (1989)
                      2023-06-12 10:36:45.430 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-05-25"],["dtend",{},"date","2022-05-26"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","0kteoi2h3j2p4hmi9mtjkncqbd@google.com"],["created",{},"date-time","2022-03-11T23:36:24Z"],["description",{},"text","1994"],["last-modified",{},"date-time","2022-03-11T23:36:24Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Max Breuer"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                      2023-06-12 10:36:45.430 - debug: birthdays.0 (7102) [ical] found birthday: Max Breuer (1994)
                      2023-06-12 10:36:45.431 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-06-27"],["dtend",{},"date","2022-06-28"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","590ibeb90hk351kc2dn4c5a8n0@google.com"],["created",{},"date-time","2022-03-11T23:38:33Z"],["description",{},"text","1959"],["last-modified",{},"date-time","2022-03-11T23:38:33Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Horst Schmidt"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                      2023-06-12 10:36:45.431 - debug: birthdays.0 (7102) [ical] found birthday: Horst Schmidt (1959)
                      2023-06-12 10:36:45.432 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-06-20"],["dtend",{},"date","2022-06-21"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","6nigji2q38hrqa931ajgd584cf@google.com"],["created",{},"date-time","2022-03-11T23:37:35Z"],["description",{},"text","1977"],["last-modified",{},"date-time","2022-03-11T23:38:43Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Renè Grywnow"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                      2023-06-12 10:36:45.432 - debug: birthdays.0 (7102) [ical] found birthday: Renè Grywnow (1977)
                      2023-06-12 10:36:45.432 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-01-15"],["dtend",{},"date","2022-01-16"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","3upmjklvmuhk9srl2jt9c72stm@google.com"],["created",{},"date-time","2022-03-11T23:39:33Z"],["description",{},"text","1999"],["last-modified",{},"date-time","2022-03-11T23:39:33Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Marick Förster"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                      2023-06-12 10:36:45.433 - debug: birthdays.0 (7102) [ical] found birthday: Marick Förster (1999)
                      2023-06-12 10:36:45.433 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-07-25"],["dtend",{},"date","2022-07-26"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","3hq7bbp8dm1547jd9n37ccg2kf@google.com"],["created",{},"date-time","2022-03-11T23:40:30Z"],["description",{},"text","1956"],["last-modified",{},"date-time","2022-03-11T23:40:30Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Käthe Schmidt"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                      2023-06-12 10:36:45.433 - debug: birthdays.0 (7102) [ical] found birthday: Käthe Schmidt (1956)
                      2023-06-12 10:36:45.434 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-08-20"],["dtend",{},"date","2022-08-21"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","6lt30ui2lg9bkhu62jvs6ig4vb@google.com"],["created",{},"date-time","2022-03-11T22:55:49Z"],["description",{},"text","2017"],["last-modified",{},"date-time","2022-03-11T23:40:54Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Rika Breuer"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                      2023-06-12 10:36:45.434 - debug: birthdays.0 (7102) [ical] found birthday: Rika Breuer (2017)
                      2023-06-12 10:36:45.435 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-03-07"],["dtend",{},"date","2022-03-08"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","3ra6d3h1t9o64hjjt7kfapekru@google.com"],["created",{},"date-time","2022-03-12T01:03:07Z"],["description",{},"text","2021"],["last-modified",{},"date-time","2022-03-12T01:03:07Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Joe Bradtke"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                      2023-06-12 10:36:45.435 - debug: birthdays.0 (7102) [ical] found birthday: Joe Bradtke (2021)
                      2023-06-12 10:36:45.436 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-03-05"],["dtend",{},"date","2022-03-06"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","68avg7vhhdu6e8vbo652uji0s0@google.com"],["created",{},"date-time","2022-03-12T01:04:19Z"],["description",{},"text","1982"],["last-modified",{},"date-time","2022-03-12T01:04:19Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Michael Hannes"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                      2023-06-12 10:36:45.436 - debug: birthdays.0 (7102) [ical] found birthday: Michael Hannes (1982)
                      2023-06-12 10:36:45.436 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-03-19"],["dtend",{},"date","2022-03-20"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","2v96q5qg4vc58u0qaoage2gkcu@google.com"],["created",{},"date-time","2022-03-12T01:05:18Z"],["description",{},"text","1993"],["last-modified",{},"date-time","2022-03-12T01:05:34Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Laura Hannes"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                      2023-06-12 10:36:45.437 - debug: birthdays.0 (7102) [ical] found birthday: Laura Hannes (1993)
                      2023-06-12 10:36:45.437 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-04-02"],["dtend",{},"date","2022-04-03"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","62dqaantph398hp82tboldktf2@google.com"],["created",{},"date-time","2022-03-12T01:06:43Z"],["description",{},"text","1952"],["last-modified",{},"date-time","2022-03-12T01:06:43Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Brigitte Meisinger"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                      2023-06-12 10:36:45.437 - debug: birthdays.0 (7102) [ical] found birthday: Brigitte Meisinger (1952)
                      2023-06-12 10:36:45.438 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-05-20"],["dtend",{},"date","2022-05-21"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","4aiuu3j3e3q1oo1917t9sbruef@google.com"],["created",{},"date-time","2022-03-12T01:10:03Z"],["description",{},"text","1999"],["last-modified",{},"date-time","2022-03-12T01:10:03Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Eddi Schmidt"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                      2023-06-12 10:36:45.438 - debug: birthdays.0 (7102) [ical] found birthday: Eddi Schmidt (1999)
                      2023-06-12 10:36:45.439 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-05-20"],["dtend",{},"date","2022-05-21"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","7sjcb675ks68fc9p8g34on55v7@google.com"],["created",{},"date-time","2022-03-12T01:10:44Z"],["description",{},"text","2013"],["last-modified",{},"date-time","2022-03-12T01:10:44Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Lina Grywnow"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                      2023-06-12 10:36:45.439 - debug: birthdays.0 (7102) [ical] found birthday: Lina Grywnow (2013)
                      2023-06-12 10:36:45.439 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-07-21"],["dtend",{},"date","2022-07-22"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","34sa560m9pomird6r8e2rjlphm@google.com"],["created",{},"date-time","2022-03-12T01:12:41Z"],["description",{},"text","2016"],["last-modified",{},"date-time","2022-03-12T01:12:41Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Lisa Hannes"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                      2023-06-12 10:36:45.440 - debug: birthdays.0 (7102) [ical] found birthday: Lisa Hannes (2016)
                      2023-06-12 10:36:45.440 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-07-26"],["dtend",{},"date","2022-07-27"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","04lc53novck2dntnsgh217hksr@google.com"],["created",{},"date-time","2022-03-12T01:14:22Z"],["description",{},"text","2015"],["last-modified",{},"date-time","2022-03-12T01:14:22Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Louis Eisenreich"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                      2023-06-12 10:36:45.440 - debug: birthdays.0 (7102) [ical] found birthday: Louis Eisenreich (2015)
                      2023-06-12 10:36:45.441 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-08-14"],["dtend",{},"date","2022-08-15"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","34jl36nto17r7ju7fd9tm74fik@google.com"],["created",{},"date-time","2022-03-12T01:16:38Z"],["description",{},"text","1960"],["last-modified",{},"date-time","2022-03-12T01:16:38Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Andrea Schmidt"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                      2023-06-12 10:36:45.441 - debug: birthdays.0 (7102) [ical] found birthday: Andrea Schmidt (1960)
                      2023-06-12 10:36:45.441 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-08-17"],["dtend",{},"date","2022-08-18"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","5gpptvr00j7drj2inrqd2d0n9c@google.com"],["created",{},"date-time","2022-03-11T23:42:29Z"],["description",{},"text","1977"],["last-modified",{},"date-time","2022-03-12T01:17:33Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Tatiana Grywnow"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                      2023-06-12 10:36:45.441 - debug: birthdays.0 (7102) [ical] found birthday: Tatiana Grywnow (1977)
                      2023-06-12 10:36:45.442 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-09-10"],["dtend",{},"date","2022-09-11"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","0tl3bpl7lu936irogi545g34dt@google.com"],["created",{},"date-time","2022-03-11T23:43:07Z"],["description",{},"text","1987"],["last-modified",{},"date-time","2022-03-12T01:18:11Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Rebecca Bradtke"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                      2023-06-12 10:36:45.442 - debug: birthdays.0 (7102) [ical] found birthday: Rebecca Bradtke (1987)
                      2023-06-12 10:36:45.442 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-09-11"],["dtend",{},"date","2022-09-12"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","4c9e477rjccsetgo46qp3js6mj@google.com"],["created",{},"date-time","2022-03-12T01:18:44Z"],["description",{},"text","2011"],["last-modified",{},"date-time","2022-03-12T01:18:44Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Tom Grywnow"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                      2023-06-12 10:36:45.443 - debug: birthdays.0 (7102) [ical] found birthday: Tom Grywnow (2011)
                      2023-06-12 10:36:45.443 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-10-12"],["dtend",{},"date","2022-10-13"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","6r3nr678ei1fg4sva8287qu1iu@google.com"],["created",{},"date-time","2022-03-12T01:19:53Z"],["description",{},"text","1983"],["last-modified",{},"date-time","2022-03-12T01:19:53Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Stefan Bradtke"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                      2023-06-12 10:36:45.443 - debug: birthdays.0 (7102) [ical] found birthday: Stefan Bradtke (1983)
                      2023-06-12 10:36:45.444 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-12-13"],["dtend",{},"date","2022-12-14"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","5o9al65m4b7l7d4a5gf01h7eid@google.com"],["created",{},"date-time","2022-03-12T01:21:29Z"],["description",{},"text","1949"],["last-modified",{},"date-time","2022-03-12T01:21:29Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Alfred Schmidt"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                      2023-06-12 10:36:45.444 - debug: birthdays.0 (7102) [ical] found birthday: Alfred Schmidt (1949)
                      2023-06-12 10:36:45.444 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-01-22"],["dtend",{},"date","2022-01-23"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","3kqfi92bq257bja94b5cgsuarp@google.com"],["created",{},"date-time","2022-03-12T08:02:48Z"],["description",{},"text","1983"],["last-modified",{},"date-time","2022-03-12T08:04:47Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Michael Grebeldinger"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                      2023-06-12 10:36:45.444 - debug: birthdays.0 (7102) [ical] found birthday: Michael Grebeldinger (1983)
                      2023-06-12 10:36:45.445 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-05-08"],["dtend",{},"date","2022-05-09"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","2a4uk2k76pp7qbh7192ufci5ee@google.com"],["created",{},"date-time","2022-03-12T08:11:20Z"],["description",{},"text","1981"],["last-modified",{},"date-time","2022-03-12T08:11:20Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Nils Gerlach"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                      2023-06-12 10:36:45.445 - debug: birthdays.0 (7102) [ical] found birthday: Nils Gerlach (1981)
                      2023-06-12 10:36:45.447 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-06-03"],["dtend",{},"date","2022-06-04"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","5t5qtqsrj65oh154svhj6kvqb5@google.com"],["created",{},"date-time","2022-03-12T08:12:26Z"],["description",{},"text","1979"],["last-modified",{},"date-time","2022-03-12T08:12:26Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Stephan Panz"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                      2023-06-12 10:36:45.448 - debug: birthdays.0 (7102) [ical] found birthday: Stephan Panz (1979)
                      2023-06-12 10:36:45.448 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-08-11"],["dtend",{},"date","2022-08-12"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","6gp1bhjl056fts8327gboftdr1@google.com"],["created",{},"date-time","2022-03-12T08:13:16Z"],["description",{},"text","1979"],["last-modified",{},"date-time","2022-03-12T08:13:16Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Hendrik Müller"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                      2023-06-12 10:36:45.448 - debug: birthdays.0 (7102) [ical] found birthday: Hendrik Müller (1979)
                      2023-06-12 10:36:45.449 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-06-22"],["dtend",{},"date","2022-06-23"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","7ifrrvn7ghq5i30enm1s860ah2@google.com"],["created",{},"date-time","2022-03-12T08:14:40Z"],["description",{},"text","1983"],["last-modified",{},"date-time","2022-03-12T08:14:40Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Oliver Paul"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                      2023-06-12 10:36:45.449 - debug: birthdays.0 (7102) [ical] found birthday: Oliver Paul (1983)
                      2023-06-12 10:36:45.449 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-07-26"],["dtend",{},"date","2022-07-27"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","58r62m8gdbuj68jkdm6v9l6fgq@google.com"],["created",{},"date-time","2022-03-12T01:14:48Z"],["description",{},"text","1960"],["last-modified",{},"date-time","2022-03-12T08:15:52Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Ines"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                      2023-06-12 10:36:45.449 - debug: birthdays.0 (7102) [ical] found birthday: Ines (1960)
                      2023-06-12 10:36:45.450 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-04-05"],["dtend",{},"date","2022-04-06"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","2qh6779fgob5t5bb8rrm0svjrp@google.com"],["created",{},"date-time","2022-03-12T01:07:42Z"],["description",{},"text","1969"],["last-modified",{},"date-time","2022-03-12T08:17:20Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Michael Meisinger"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                      2023-06-12 10:36:45.450 - debug: birthdays.0 (7102) [ical] found birthday: Michael Meisinger (1969)
                      2023-06-12 10:36:45.450 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-01-10"],["dtend",{},"date","2022-01-11"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","1tdpucqq0j3gjqacahqvslqccu@google.com"],["created",{},"date-time","2022-03-12T01:00:23Z"],["description",{},"text","1971"],["last-modified",{},"date-time","2022-03-12T08:18:04Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Juliane Schmidt"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                      2023-06-12 10:36:45.451 - debug: birthdays.0 (7102) [ical] found birthday: Juliane Schmidt (1971)
                      2023-06-12 10:36:45.451 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-01-12"],["dtend",{},"date","2022-01-13"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","422kq5sle3pdg3sb715c83nra1@google.com"],["created",{},"date-time","2022-03-12T01:00:56Z"],["description",{},"text","1999"],["last-modified",{},"date-time","2022-03-12T08:18:21Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Calvin Seum"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                      2023-06-12 10:36:45.451 - debug: birthdays.0 (7102) [ical] found birthday: Calvin Seum (1999)
                      2023-06-12 10:36:45.452 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-05-18"],["dtend",{},"date","2022-05-19"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","1k0p7ckv2046m3rkn378e13kdo@google.com"],["created",{},"date-time","2022-03-12T01:09:22Z"],["description",{},"text","1996"],["last-modified",{},"date-time","2022-03-12T08:19:07Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Tabea Meinhardt"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                      2023-06-12 10:36:45.452 - debug: birthdays.0 (7102) [ical] found birthday: Tabea Meinhardt (1996)
                      2023-06-12 10:36:45.452 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-05-28"],["dtend",{},"date","2022-05-29"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","1v0e13bhbmtirbllobo69r8gq8@google.com"],["created",{},"date-time","2023-06-12T07:32:29Z"],["description",{},"text","1983"],["last-modified",{},"date-time","2023-06-12T07:32:41Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Benjamin Schmidt"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                      2023-06-12 10:36:45.452 - debug: birthdays.0 (7102) [ical] found birthday: Benjamin Schmidt (1983)
                      2023-06-12 10:36:45.453 - debug: birthdays.0 (7102) [ical] processing event: {"component":["vevent",[["dtstart",{},"date","2022-10-15"],["dtend",{},"date","2022-10-16"],["rrule",{},"recur",{"freq":"YEARLY"}],["dtstamp",{},"date-time","2023-06-12T08:36:45Z"],["uid",{},"text","7i0kn2tvjl9n7akcb0k493b8lg@google.com"],["created",{},"date-time","2023-06-12T07:36:01Z"],["description",{},"text","1979"],["last-modified",{},"date-time","2023-06-12T07:36:13Z"],["sequence",{},"integer",0],["status",{},"text","CONFIRMED"],["summary",{},"text","Jennifer Schmidt-Förster"],["transp",{},"text","TRANSPARENT"]],[]],"_rangeExceptionCache":{},"exceptions":{},"rangeExceptions":[]}
                      2023-06-12 10:36:45.453 - debug: birthdays.0 (7102) [ical] found birthday: Jennifer Schmidt-Förster (1979)
                      2023-06-12 10:36:45.453 - debug: birthdays.0 (7102) [ical] processed all events
                      2023-06-12 10:36:45.453 - debug: birthdays.0 (7102) [onReady] everything collected: [0,35,0]
                      2023-06-12 10:36:45.455 - debug: birthdays.0 (7102) [fillStates] birthdays: [{"name":"Renè Grywnow","birthYear":1977,"dateFormat":"20.06.2023","age":46,"daysLeft":8,"_birthday":"1977-06-19T23:00:00.000Z","_nextBirthday":"2023-06-19T22:00:00.000Z"},{"name":"Oliver Paul","birthYear":1983,"dateFormat":"22.06.2023","age":40,"daysLeft":10,"_birthday":"1983-06-21T22:00:00.000Z","_nextBirthday":"2023-06-21T22:00:00.000Z"},{"name":"Horst Schmidt","birthYear":1959,"dateFormat":"27.06.2023","age":64,"daysLeft":15,"_birthday":"1959-06-26T23:00:00.000Z","_nextBirthday":"2023-06-26T22:00:00.000Z"},{"name":"Lisa Hannes","birthYear":2016,"dateFormat":"21.07.2023","age":7,"daysLeft":39,"_birthday":"2016-07-20T22:00:00.000Z","_nextBirthday":"2023-07-20T22:00:00.000Z"},{"name":"Käthe Schmidt","birthYear":1956,"dateFormat":"25.07.2023","age":67,"daysLeft":43,"_birthday":"1956-07-24T23:00:00.000Z","_nextBirthday":"2023-07-24T22:00:00.000Z"},{"name":"Ines","birthYear":1960,"dateFormat":"26.07.2023","age":63,"daysLeft":44,"_birthday":"1960-07-25T23:00:00.000Z","_nextBirthday":"2023-07-25T22:00:00.000Z"},{"name":"Louis Eisenreich","birthYear":2015,"dateFormat":"26.07.2023","age":8,"daysLeft":44,"_birthday":"2015-07-25T22:00:00.000Z","_nextBirthday":"2023-07-25T22:00:00.000Z"},{"name":"Hendrik Müller","birthYear":1979,"dateFormat":"11.08.2023","age":44,"daysLeft":60,"_birthday":"1979-08-10T23:00:00.000Z","_nextBirthday":"2023-08-10T22:00:00.000Z"},{"name":"Andrea Schmidt","birthYear":1960,"dateFormat":"14.08.2023","age":63,"daysLeft":63,"_birthday":"1960-08-13T23:00:00.000Z","_nextBirthday":"2023-08-13T22:00:00.000Z"},{"name":"Tatiana Grywnow","birthYear":1977,"dateFormat":"17.08.2023","age":46,"daysLeft":66,"_birthday":"1977-08-16T23:00:00.000Z","_nextBirthday":"2023-08-16T22:00:00.000Z"},{"name":"Rika Breuer","birthYear":2017,"dateFormat":"20.08.2023","age":6,"daysLeft":69,"_birthday":"2017-08-19T22:00:00.000Z","_nextBirthday":"2023-08-19T22:00:00.000Z"},{"name":"Rebecca Bradtke","birthYear":1987,"dateFormat":"10.09.2023","age":36,"daysLeft":90,"_birthday":"1987-09-09T22:00:00.000Z","_nextBirthday":"2023-09-09T22:00:00.000Z"},{"name":"Tom Grywnow","birthYear":2011,"dateFormat":"11.09.2023","age":12,"daysLeft":91,"_birthday":"2011-09-10T22:00:00.000Z","_nextBirthday":"2023-09-10T22:00:00.000Z"},{"name":"Stefan Bradtke","birthYear":1983,"dateFormat":"12.10.2023","age":40,"daysLeft":122,"_birthday":"1983-10-11T23:00:00.000Z","_nextBirthday":"2023-10-11T22:00:00.000Z"},{"name":"Jennifer Schmidt-Förster","birthYear":1979,"dateFormat":"15.10.2023","age":44,"daysLeft":125,"_birthday":"1979-10-14T23:00:00.000Z","_nextBirthday":"2023-10-14T22:00:00.000Z"},{"name":"Alfred Schmidt","birthYear":1949,"dateFormat":"13.12.2023","age":74,"daysLeft":184,"_birthday":"1949-12-12T23:00:00.000Z","_nextBirthday":"2023-12-12T23:00:00.000Z"},{"name":"Juliane Schmidt","birthYear":1971,"dateFormat":"10.01.2024","age":53,"daysLeft":212,"_birthday":"1971-01-09T23:00:00.000Z","_nextBirthday":"2024-01-09T23:00:00.000Z"},{"name":"Calvin Seum","birthYear":1999,"dateFormat":"12.01.2024","age":25,"daysLeft":214,"_birthday":"1999-01-11T23:00:00.000Z","_nextBirthday":"2024-01-11T23:00:00.000Z"},{"name":"Marick Förster","birthYear":1999,"dateFormat":"15.01.2024","age":25,"daysLeft":217,"_birthday":"1999-01-14T23:00:00.000Z","_nextBirthday":"2024-01-14T23:00:00.000Z"},{"name":"Michael Grebeldinger","birthYear":1983,"dateFormat":"22.01.2024","age":41,"daysLeft":224,"_birthday":"1983-01-21T23:00:00.000Z","_nextBirthday":"2024-01-21T23:00:00.000Z"},{"name":"Michael Hannes","birthYear":1982,"dateFormat":"05.03.2024","age":42,"daysLeft":267,"_birthday":"1982-03-04T23:00:00.000Z","_nextBirthday":"2024-03-04T23:00:00.000Z"},{"name":"Joe Bradtke","birthYear":2021,"dateFormat":"07.03.2024","age":3,"daysLeft":269,"_birthday":"2021-03-06T23:00:00.000Z","_nextBirthday":"2024-03-06T23:00:00.000Z"},{"name":"Laura Hannes","birthYear":1993,"dateFormat":"19.03.2024","age":31,"daysLeft":281,"_birthday":"1993-03-18T23:00:00.000Z","_nextBirthday":"2024-03-18T23:00:00.000Z"},{"name":"Brigitte Meisinger","birthYear":1952,"dateFormat":"02.04.2024","age":72,"daysLeft":295,"_birthday":"1952-04-01T23:00:00.000Z","_nextBirthday":"2024-04-01T22:00:00.000Z"},{"name":"Michael Meisinger","birthYear":1969,"dateFormat":"05.04.2024","age":55,"daysLeft":298,"_birthday":"1969-04-04T23:00:00.000Z","_nextBirthday":"2024-04-04T22:00:00.000Z"},{"name":"Nils Gerlach","birthYear":1981,"dateFormat":"08.05.2024","age":43,"daysLeft":331,"_birthday":"1981-05-07T22:00:00.000Z","_nextBirthday":"2024-05-07T22:00:00.000Z"},{"name":"Valentina Breuer","birthYear":1987,"dateFormat":"12.05.2024","age":37,"daysLeft":335,"_birthday":"1987-05-11T22:00:00.000Z","_nextBirthday":"2024-05-11T22:00:00.000Z"},{"name":"Valeska Breuer","birthYear":1989,"dateFormat":"17.05.2024","age":35,"daysLeft":340,"_birthday":"1989-05-16T22:00:00.000Z","_nextBirthday":"2024-05-16T22:00:00.000Z"},{"name":"Constantin Breuer","birthYear":1989,"dateFormat":"17.05.2024","age":35,"daysLeft":340,"_birthday":"1989-05-16T22:00:00.000Z","_nextBirthday":"2024-05-16T22:00:00.000Z"},{"name":"Tabea Meinhardt","birthYear":1996,"dateFormat":"18.05.2024","age":28,"daysLeft":341,"_birthday":"1996-05-17T22:00:00.000Z","_nextBirthday":"2024-05-17T22:00:00.000Z"},{"name":"Lina Grywnow","birthYear":2013,"dateFormat":"20.05.2024","age":11,"daysLeft":343,"_birthday":"2013-05-19T22:00:00.000Z","_nextBirthday":"2024-05-19T22:00:00.000Z"},{"name":"Eddi Schmidt","birthYear":1999,"dateFormat":"20.05.2024","age":25,"daysLeft":343,"_birthday":"1999-05-19T22:00:00.000Z","_nextBirthday":"2024-05-19T22:00:00.000Z"},{"name":"Max Breuer","birthYear":1994,"dateFormat":"25.05.2024","age":30,"daysLeft":348,"_birthday":"1994-05-24T22:00:00.000Z","_nextBirthday":"2024-05-24T22:00:00.000Z"},{"name":"Benjamin Schmidt","birthYear":1983,"dateFormat":"28.05.2024","age":41,"daysLeft":351,"_birthday":"1983-05-27T22:00:00.000Z","_nextBirthday":"2024-05-27T22:00:00.000Z"},{"name":"Stephan Panz","birthYear":1979,"dateFormat":"03.06.2024","age":45,"daysLeft":357,"_birthday":"1979-06-02T23:00:00.000Z","_nextBirthday":"2024-06-02T22:00:00.000Z"}]
                      2023-06-12 10:36:45.545 - debug: birthdays.0 (7102) [fillStates] birthdays significant: [{"name":"Oliver Paul","birthYear":1983,"dateFormat":"22.06.2023","age":40,"daysLeft":10,"_birthday":"1983-06-21T22:00:00.000Z","_nextBirthday":"2023-06-21T22:00:00.000Z"},{"name":"Stefan Bradtke","birthYear":1983,"dateFormat":"12.10.2023","age":40,"daysLeft":122,"_birthday":"1983-10-11T23:00:00.000Z","_nextBirthday":"2023-10-11T22:00:00.000Z"},{"name":"Max Breuer","birthYear":1994,"dateFormat":"25.05.2024","age":30,"daysLeft":348,"_birthday":"1994-05-24T22:00:00.000Z","_nextBirthday":"2024-05-24T22:00:00.000Z"},{"name":"Louis Eisenreich","birthYear":2015,"dateFormat":"26.07.2025","age":10,"daysLeft":775,"_birthday":"2015-07-25T22:00:00.000Z","_nextBirthday":"2025-07-25T22:00:00.000Z"},{"name":"Tabea Meinhardt","birthYear":1996,"dateFormat":"18.05.2026","age":30,"daysLeft":1071,"_birthday":"1996-05-17T22:00:00.000Z","_nextBirthday":"2026-05-17T22:00:00.000Z"},{"name":"Lisa Hannes","birthYear":2016,"dateFormat":"21.07.2026","age":10,"daysLeft":1135,"_birthday":"2016-07-20T22:00:00.000Z","_nextBirthday":"2026-07-20T22:00:00.000Z"},{"name":"Käthe Schmidt","birthYear":1956,"dateFormat":"25.07.2026","age":70,"daysLeft":1139,"_birthday":"1956-07-24T23:00:00.000Z","_nextBirthday":"2026-07-24T22:00:00.000Z"},{"name":"Valentina Breuer","birthYear":1987,"dateFormat":"12.05.2027","age":40,"daysLeft":1430,"_birthday":"1987-05-11T22:00:00.000Z","_nextBirthday":"2027-05-11T22:00:00.000Z"},{"name":"Renè Grywnow","birthYear":1977,"dateFormat":"20.06.2027","age":50,"daysLeft":1469,"_birthday":"1977-06-19T23:00:00.000Z","_nextBirthday":"2027-06-19T22:00:00.000Z"},{"name":"Tatiana Grywnow","birthYear":1977,"dateFormat":"17.08.2027","age":50,"daysLeft":1527,"_birthday":"1977-08-16T23:00:00.000Z","_nextBirthday":"2027-08-16T22:00:00.000Z"},{"name":"Rika Breuer","birthYear":2017,"dateFormat":"20.08.2027","age":10,"daysLeft":1530,"_birthday":"2017-08-19T22:00:00.000Z","_nextBirthday":"2027-08-19T22:00:00.000Z"},{"name":"Rebecca Bradtke","birthYear":1987,"dateFormat":"10.09.2027","age":40,"daysLeft":1551,"_birthday":"1987-09-09T22:00:00.000Z","_nextBirthday":"2027-09-09T22:00:00.000Z"},{"name":"Calvin Seum","birthYear":1999,"dateFormat":"12.01.2029","age":30,"daysLeft":2041,"_birthday":"1999-01-11T23:00:00.000Z","_nextBirthday":"2029-01-11T23:00:00.000Z"},{"name":"Marick Förster","birthYear":1999,"dateFormat":"15.01.2029","age":30,"daysLeft":2044,"_birthday":"1999-01-14T23:00:00.000Z","_nextBirthday":"2029-01-14T23:00:00.000Z"},{"name":"Michael Meisinger","birthYear":1969,"dateFormat":"05.04.2029","age":60,"daysLeft":2124,"_birthday":"1969-04-04T23:00:00.000Z","_nextBirthday":"2029-04-04T22:00:00.000Z"},{"name":"Valeska Breuer","birthYear":1989,"dateFormat":"17.05.2029","age":40,"daysLeft":2166,"_birthday":"1989-05-16T22:00:00.000Z","_nextBirthday":"2029-05-16T22:00:00.000Z"},{"name":"Constantin Breuer","birthYear":1989,"dateFormat":"17.05.2029","age":40,"daysLeft":2166,"_birthday":"1989-05-16T22:00:00.000Z","_nextBirthday":"2029-05-16T22:00:00.000Z"},{"name":"Eddi Schmidt","birthYear":1999,"dateFormat":"20.05.2029","age":30,"daysLeft":2169,"_birthday":"1999-05-19T22:00:00.000Z","_nextBirthday":"2029-05-19T22:00:00.000Z"},{"name":"Stephan Panz","birthYear":1979,"dateFormat":"03.06.2029","age":50,"daysLeft":2183,"_birthday":"1979-06-02T23:00:00.000Z","_nextBirthday":"2029-06-02T22:00:00.000Z"},{"name":"Horst Schmidt","birthYear":1959,"dateFormat":"27.06.2029","age":70,"daysLeft":2207,"_birthday":"1959-06-26T23:00:00.000Z","_nextBirthday":"2029-06-26T22:00:00.000Z"},{"name":"Hendrik Müller","birthYear":1979,"dateFormat":"11.08.2029","age":50,"daysLeft":2252,"_birthday":"1979-08-10T23:00:00.000Z","_nextBirthday":"2029-08-10T22:00:00.000Z"},{"name":"Jennifer Schmidt-Förster","birthYear":1979,"dateFormat":"15.10.2029","age":50,"daysLeft":2317,"_birthday":"1979-10-14T23:00:00.000Z","_nextBirthday":"2029-10-14T22:00:00.000Z"},{"name":"Alfred Schmidt","birthYear":1949,"dateFormat":"13.12.2029","age":80,"daysLeft":2376,"_birthday":"1949-12-12T23:00:00.000Z","_nextBirthday":"2029-12-12T23:00:00.000Z"},{"name":"Ines","birthYear":1960,"dateFormat":"26.07.2030","age":70,"daysLeft":2601,"_birthday":"1960-07-25T23:00:00.000Z","_nextBirthday":"2030-07-25T22:00:00.000Z"},{"name":"Andrea Schmidt","birthYear":1960,"dateFormat":"14.08.2030","age":70,"daysLeft":2620,"_birthday":"1960-08-13T23:00:00.000Z","_nextBirthday":"2030-08-13T22:00:00.000Z"},{"name":"Juliane Schmidt","birthYear":1971,"dateFormat":"10.01.2031","age":60,"daysLeft":2769,"_birthday":"1971-01-09T23:00:00.000Z","_nextBirthday":"2031-01-09T23:00:00.000Z"},{"name":"Joe Bradtke","birthYear":2021,"dateFormat":"07.03.2031","age":10,"daysLeft":2825,"_birthday":"2021-03-06T23:00:00.000Z","_nextBirthday":"2031-03-06T23:00:00.000Z"},{"name":"Nils Gerlach","birthYear":1981,"dateFormat":"08.05.2031","age":50,"daysLeft":2887,"_birthday":"1981-05-07T22:00:00.000Z","_nextBirthday":"2031-05-07T22:00:00.000Z"},{"name":"Tom Grywnow","birthYear":2011,"dateFormat":"11.09.2031","age":20,"daysLeft":3013,"_birthday":"2011-09-10T22:00:00.000Z","_nextBirthday":"2031-09-10T22:00:00.000Z"},{"name":"Michael Hannes","birthYear":1982,"dateFormat":"05.03.2032","age":50,"daysLeft":3189,"_birthday":"1982-03-04T23:00:00.000Z","_nextBirthday":"2032-03-04T23:00:00.000Z"},{"name":"Brigitte Meisinger","birthYear":1952,"dateFormat":"02.04.2032","age":80,"daysLeft":3217,"_birthday":"1952-04-01T23:00:00.000Z","_nextBirthday":"2032-04-01T22:00:00.000Z"},{"name":"Michael Grebeldinger","birthYear":1983,"dateFormat":"22.01.2033","age":50,"daysLeft":3512,"_birthday":"1983-01-21T23:00:00.000Z","_nextBirthday":"2033-01-21T23:00:00.000Z"},{"name":"Laura Hannes","birthYear":1993,"dateFormat":"19.03.2033","age":40,"daysLeft":3568,"_birthday":"1993-03-18T23:00:00.000Z","_nextBirthday":"2033-03-18T23:00:00.000Z"},{"name":"Lina Grywnow","birthYear":2013,"dateFormat":"20.05.2033","age":20,"daysLeft":3630,"_birthday":"2013-05-19T22:00:00.000Z","_nextBirthday":"2033-05-19T22:00:00.000Z"},{"name":"Benjamin Schmidt","birthYear":1983,"dateFormat":"28.05.2033","age":50,"daysLeft":3638,"_birthday":"1983-05-27T22:00:00.000Z","_nextBirthday":"2033-05-27T22:00:00.000Z"}]
                      2023-06-12 10:36:45.573 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.06.renèGrywnow", birthday: {"name":"Renè Grywnow","birthYear":1977,"dateFormat":"20.06.2023","age":46,"daysLeft":8,"_birthday":"1977-06-19T23:00:00.000Z","_nextBirthday":"2023-06-19T22:00:00.000Z"}
                      2023-06-12 10:36:45.580 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.06.oliverPaul", birthday: {"name":"Oliver Paul","birthYear":1983,"dateFormat":"22.06.2023","age":40,"daysLeft":10,"_birthday":"1983-06-21T22:00:00.000Z","_nextBirthday":"2023-06-21T22:00:00.000Z"}
                      2023-06-12 10:36:45.584 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.06.horstSchmidt", birthday: {"name":"Horst Schmidt","birthYear":1959,"dateFormat":"27.06.2023","age":64,"daysLeft":15,"_birthday":"1959-06-26T23:00:00.000Z","_nextBirthday":"2023-06-26T22:00:00.000Z"}
                      2023-06-12 10:36:45.590 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.07.lisaHannes", birthday: {"name":"Lisa Hannes","birthYear":2016,"dateFormat":"21.07.2023","age":7,"daysLeft":39,"_birthday":"2016-07-20T22:00:00.000Z","_nextBirthday":"2023-07-20T22:00:00.000Z"}
                      2023-06-12 10:36:45.595 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.07.kätheSchmidt", birthday: {"name":"Käthe Schmidt","birthYear":1956,"dateFormat":"25.07.2023","age":67,"daysLeft":43,"_birthday":"1956-07-24T23:00:00.000Z","_nextBirthday":"2023-07-24T22:00:00.000Z"}
                      2023-06-12 10:36:45.600 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.07.ines", birthday: {"name":"Ines","birthYear":1960,"dateFormat":"26.07.2023","age":63,"daysLeft":44,"_birthday":"1960-07-25T23:00:00.000Z","_nextBirthday":"2023-07-25T22:00:00.000Z"}
                      2023-06-12 10:36:45.604 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.07.louisEisenreich", birthday: {"name":"Louis Eisenreich","birthYear":2015,"dateFormat":"26.07.2023","age":8,"daysLeft":44,"_birthday":"2015-07-25T22:00:00.000Z","_nextBirthday":"2023-07-25T22:00:00.000Z"}
                      2023-06-12 10:36:45.612 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.08.hendrikMüller", birthday: {"name":"Hendrik Müller","birthYear":1979,"dateFormat":"11.08.2023","age":44,"daysLeft":60,"_birthday":"1979-08-10T23:00:00.000Z","_nextBirthday":"2023-08-10T22:00:00.000Z"}
                      2023-06-12 10:36:45.617 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.08.andreaSchmidt", birthday: {"name":"Andrea Schmidt","birthYear":1960,"dateFormat":"14.08.2023","age":63,"daysLeft":63,"_birthday":"1960-08-13T23:00:00.000Z","_nextBirthday":"2023-08-13T22:00:00.000Z"}
                      2023-06-12 10:36:45.623 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.08.tatianaGrywnow", birthday: {"name":"Tatiana Grywnow","birthYear":1977,"dateFormat":"17.08.2023","age":46,"daysLeft":66,"_birthday":"1977-08-16T23:00:00.000Z","_nextBirthday":"2023-08-16T22:00:00.000Z"}
                      2023-06-12 10:36:45.628 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.08.rikaBreuer", birthday: {"name":"Rika Breuer","birthYear":2017,"dateFormat":"20.08.2023","age":6,"daysLeft":69,"_birthday":"2017-08-19T22:00:00.000Z","_nextBirthday":"2023-08-19T22:00:00.000Z"}
                      2023-06-12 10:36:45.631 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.09.rebeccaBradtke", birthday: {"name":"Rebecca Bradtke","birthYear":1987,"dateFormat":"10.09.2023","age":36,"daysLeft":90,"_birthday":"1987-09-09T22:00:00.000Z","_nextBirthday":"2023-09-09T22:00:00.000Z"}
                      2023-06-12 10:36:45.635 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.09.tomGrywnow", birthday: {"name":"Tom Grywnow","birthYear":2011,"dateFormat":"11.09.2023","age":12,"daysLeft":91,"_birthday":"2011-09-10T22:00:00.000Z","_nextBirthday":"2023-09-10T22:00:00.000Z"}
                      2023-06-12 10:36:45.641 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.10.stefanBradtke", birthday: {"name":"Stefan Bradtke","birthYear":1983,"dateFormat":"12.10.2023","age":40,"daysLeft":122,"_birthday":"1983-10-11T23:00:00.000Z","_nextBirthday":"2023-10-11T22:00:00.000Z"}
                      2023-06-12 10:36:45.646 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.10.jenniferSchmidtFörster", birthday: {"name":"Jennifer Schmidt-Förster","birthYear":1979,"dateFormat":"15.10.2023","age":44,"daysLeft":125,"_birthday":"1979-10-14T23:00:00.000Z","_nextBirthday":"2023-10-14T22:00:00.000Z"}
                      2023-06-12 10:36:45.650 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.12.alfredSchmidt", birthday: {"name":"Alfred Schmidt","birthYear":1949,"dateFormat":"13.12.2023","age":74,"daysLeft":184,"_birthday":"1949-12-12T23:00:00.000Z","_nextBirthday":"2023-12-12T23:00:00.000Z"}
                      2023-06-12 10:36:45.654 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.01.julianeSchmidt", birthday: {"name":"Juliane Schmidt","birthYear":1971,"dateFormat":"10.01.2024","age":53,"daysLeft":212,"_birthday":"1971-01-09T23:00:00.000Z","_nextBirthday":"2024-01-09T23:00:00.000Z"}
                      2023-06-12 10:36:45.658 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.01.calvinSeum", birthday: {"name":"Calvin Seum","birthYear":1999,"dateFormat":"12.01.2024","age":25,"daysLeft":214,"_birthday":"1999-01-11T23:00:00.000Z","_nextBirthday":"2024-01-11T23:00:00.000Z"}
                      2023-06-12 10:36:45.662 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.01.marickFörster", birthday: {"name":"Marick Förster","birthYear":1999,"dateFormat":"15.01.2024","age":25,"daysLeft":217,"_birthday":"1999-01-14T23:00:00.000Z","_nextBirthday":"2024-01-14T23:00:00.000Z"}
                      2023-06-12 10:36:45.668 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.01.michaelGrebeldinger", birthday: {"name":"Michael Grebeldinger","birthYear":1983,"dateFormat":"22.01.2024","age":41,"daysLeft":224,"_birthday":"1983-01-21T23:00:00.000Z","_nextBirthday":"2024-01-21T23:00:00.000Z"}
                      2023-06-12 10:36:45.672 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.03.michaelHannes", birthday: {"name":"Michael Hannes","birthYear":1982,"dateFormat":"05.03.2024","age":42,"daysLeft":267,"_birthday":"1982-03-04T23:00:00.000Z","_nextBirthday":"2024-03-04T23:00:00.000Z"}
                      2023-06-12 10:36:45.676 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.03.joeBradtke", birthday: {"name":"Joe Bradtke","birthYear":2021,"dateFormat":"07.03.2024","age":3,"daysLeft":269,"_birthday":"2021-03-06T23:00:00.000Z","_nextBirthday":"2024-03-06T23:00:00.000Z"}
                      2023-06-12 10:36:45.680 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.03.lauraHannes", birthday: {"name":"Laura Hannes","birthYear":1993,"dateFormat":"19.03.2024","age":31,"daysLeft":281,"_birthday":"1993-03-18T23:00:00.000Z","_nextBirthday":"2024-03-18T23:00:00.000Z"}
                      2023-06-12 10:36:45.684 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.04.brigitteMeisinger", birthday: {"name":"Brigitte Meisinger","birthYear":1952,"dateFormat":"02.04.2024","age":72,"daysLeft":295,"_birthday":"1952-04-01T23:00:00.000Z","_nextBirthday":"2024-04-01T22:00:00.000Z"}
                      2023-06-12 10:36:45.690 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.04.michaelMeisinger", birthday: {"name":"Michael Meisinger","birthYear":1969,"dateFormat":"05.04.2024","age":55,"daysLeft":298,"_birthday":"1969-04-04T23:00:00.000Z","_nextBirthday":"2024-04-04T22:00:00.000Z"}
                      2023-06-12 10:36:45.694 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.05.nilsGerlach", birthday: {"name":"Nils Gerlach","birthYear":1981,"dateFormat":"08.05.2024","age":43,"daysLeft":331,"_birthday":"1981-05-07T22:00:00.000Z","_nextBirthday":"2024-05-07T22:00:00.000Z"}
                      2023-06-12 10:36:45.699 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.05.valentinaBreuer", birthday: {"name":"Valentina Breuer","birthYear":1987,"dateFormat":"12.05.2024","age":37,"daysLeft":335,"_birthday":"1987-05-11T22:00:00.000Z","_nextBirthday":"2024-05-11T22:00:00.000Z"}
                      2023-06-12 10:36:45.703 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.05.valeskaBreuer", birthday: {"name":"Valeska Breuer","birthYear":1989,"dateFormat":"17.05.2024","age":35,"daysLeft":340,"_birthday":"1989-05-16T22:00:00.000Z","_nextBirthday":"2024-05-16T22:00:00.000Z"}
                      2023-06-12 10:36:45.709 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.05.constantinBreuer", birthday: {"name":"Constantin Breuer","birthYear":1989,"dateFormat":"17.05.2024","age":35,"daysLeft":340,"_birthday":"1989-05-16T22:00:00.000Z","_nextBirthday":"2024-05-16T22:00:00.000Z"}
                      2023-06-12 10:36:45.713 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.05.tabeaMeinhardt", birthday: {"name":"Tabea Meinhardt","birthYear":1996,"dateFormat":"18.05.2024","age":28,"daysLeft":341,"_birthday":"1996-05-17T22:00:00.000Z","_nextBirthday":"2024-05-17T22:00:00.000Z"}
                      2023-06-12 10:36:45.717 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.05.linaGrywnow", birthday: {"name":"Lina Grywnow","birthYear":2013,"dateFormat":"20.05.2024","age":11,"daysLeft":343,"_birthday":"2013-05-19T22:00:00.000Z","_nextBirthday":"2024-05-19T22:00:00.000Z"}
                      2023-06-12 10:36:45.721 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.05.eddiSchmidt", birthday: {"name":"Eddi Schmidt","birthYear":1999,"dateFormat":"20.05.2024","age":25,"daysLeft":343,"_birthday":"1999-05-19T22:00:00.000Z","_nextBirthday":"2024-05-19T22:00:00.000Z"}
                      2023-06-12 10:36:45.725 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.05.maxBreuer", birthday: {"name":"Max Breuer","birthYear":1994,"dateFormat":"25.05.2024","age":30,"daysLeft":348,"_birthday":"1994-05-24T22:00:00.000Z","_nextBirthday":"2024-05-24T22:00:00.000Z"}
                      2023-06-12 10:36:45.729 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.05.benjaminSchmidt", birthday: {"name":"Benjamin Schmidt","birthYear":1983,"dateFormat":"28.05.2024","age":41,"daysLeft":351,"_birthday":"1983-05-27T22:00:00.000Z","_nextBirthday":"2024-05-27T22:00:00.000Z"}
                      2023-06-12 10:36:45.733 - debug: birthdays.0 (7102) [fillPathWithBirthday] path: "month.06.stephanPanz", birthday: {"name":"Stephan Panz","birthYear":1979,"dateFormat":"03.06.2024","age":45,"daysLeft":357,"_birthday":"1979-06-02T23:00:00.000Z","_nextBirthday":"2024-06-02T22:00:00.000Z"}
                      2023-06-12 10:36:45.738 - debug: birthdays.0 (7102) [fillAfter] filling next with 8 days left
                      2023-06-12 10:36:45.749 - debug: birthdays.0 (7102) [fillAfter] filling nextAfter with 10 days left
                      2023-06-12 10:36:45.759 - debug: birthdays.0 (7102) [fillAfter] filling nextSignificant with 10 days left
                      2023-06-12 10:36:45.775 - debug: birthdays.0 (7102) [onReady] Everything done
                      2023-06-12 10:36:45.776 - debug: birthdays.0 (7102) [onReady] Finally shutting down
                      2023-06-12 10:36:45.776 - debug: birthdays.0 (7102) cleaned everything up...
                      2023-06-12 10:36:45.819 - info: birthdays.0 (7102) Terminated (NO_ERROR): Without reason
                      2023-06-12 10:36:46.364 - info: host.buanet-iobroker_8_0_1 instance system.adapter.birthdays.0 terminated with code 0 (NO_ERROR)
                      • Ben1983B Ben1983
                        #269
                        Wie soll das technisch gehen? Du siehst doch, dass es im Code keinen Weg gibt, dass ein Geburtstag hinzugefügt wird, ohne dass die Meldung geschrieben wird.
                          Ben1983B Offline
                          Ben1983B Offline
                          Ben1983
                          #270
                          @haus-automatisierung Keine Ahnung, aber es klappt ja jetzt.
                          Danke für den Tipp mit dem einzeln raus gelöscht.
                            Aktuelle Test Version 0.1.1
                            Veröffentlichungsdatum 05.11.2021
                            Github Link https://github.com/klein0r/ioBroker.birthdays
                            Viele bauen sich ja scheinbar eigene Logiken für Geburtstagserinnerungen zusammen. So wird auch der "trashschedule" Adapter schon fleißig dafür vergewaltigt - was ja nicht Sinn der Sache ist. Daher gibt es für Geburtstage jetzt einen neuen Adapter.
                            Dieser ist aber gerade noch sehr sehr jung. Was bisher klappt:
                            • iCal Import
                            • Eigene Geburtstage direkt in der Konfiguration hinterlegen
                            Für iCal ist wichtig, dass es ganztägige Termine sind, welche sich jährlich wiederholen und in der Beschreibung das Geburtsjahr enthalten.
                            Dann wird das Alter berechnet und wie lange es bis zum Geburtstag noch dauert. Aktuell wird dann nur ein json bereitgestellt, welches ein Array mit allen Geburtstagen enthält.
                            Daher die Fragen: Wie sollen die Daten Eurer Meinung nach am besten aufbereitet werden?
                            1. Interessieren Euch nur die nächsten Geburtstage? Wieviele? Konfigurierbar? Filter wie weit in der Zukunft?
                            2. Was soll passieren, wenn mehrere Leute am gleichen Tag Geburtstag haben? In einem Datenpunkt zusammenfassen?
                            3. Soll für jeden Kontakt ein Datenpunkt angelegt werden? Interessiert doch heute eigentlich niemanden, dass Tante Erna in 273 Tagen 54 wird, oder?
                            Ich könnte z.B. Datenpunkte für heute, morgen, nächste Woche, nächsten Monat anbieten und dort alle Kontakte irgendwie sammeln.
                            Bin auf Euren Input gespannt! Am besten mit der "Fragenummer" antworten ;)
                            sigi234S Online
                            sigi234S Online
                            #271
                            kannst du eine Json für die Monate einbauen?
                            Also, wer hat im Jan,Feb, ...usw. aller Geburtstag
                            • sigi234S sigi234
                              #272
                              @sigi234 sagte in Test Adapter Birthdays:
                              Ja das ist schnell gemacht.
                                sigi234S Online
                                sigi234S Online
                                #273
                                Super, ev. mit Zähler. Also im Jänner haben XY Personen Geburtstag.
                                Ist natürlich alles nice to have 😀
                                • V Offline
                                  V Offline
                                  valbuz
                                  #274
                                  Hallo Matthias
                                  Habe seit kurzem ein Problem mit dem Adapter.
                                  Ich benutze 2 Instanzen davon.
                                  Die 2. benutze ich für einige wichtige Termine. Ich weiss ist nicht dazu gedacht, aber es funzte bis anhin.
                                  Ich mache ebenfalls Einträge im Kalender mit Name/Datum/Ganztägig und Betreff das aktuelle Jahr.
                                  Wiederholung einmalig oder jährlich verursacht dasselbe Problem.
                                  Da es zum Teil Termine mit demselben Namen sind kommen diese mehrmals mit unterschiedlichem Datum vor.
                                  Seit nun einer Woche wird lediglich nur noch ein Termin mit selben Namen angezeigt. Ändere ich testhalber ein Name, erscheint dieser dann korrekt im Object Baum. Es wird also seit kurzem nur noch ein Eintrag gemacht mit demselben Namen
                                  Wie gesagt dies lief bis vor kurzem ohne Probleme.
                                  Kannst Du mir eine Hilfe geben wo ich suchen soll?
                                  2xProxmox auf NUC
                                  E3DC 13kWh Speicher via RCSP an ioBroker
                                  • V valbuz
                                    Hallo Matthias
                                    da_WoodyD Offline
                                    da_WoodyD Offline
                                    #275
                                    @valbuz sagte in Test Adapter Birthdays:
                                    warum dann nicht den ical?
                                    der birthday ist entstanden, weil einige den ical für geburtstage missbraucht habn.
                                    V 1 Antwort Letzte Antwort
                                    • da_WoodyD da_Woody
                                      V Offline
                                      V Offline
                                      valbuz
                                      #276
                                      @da_woody sagte in Test Adapter Birthdays:
                                      Dann kann ich ja auch den birthday für ical missbrauchen 😊
                                      Wie geschrieben ist mir klar, aber es hat funktioniert und jetzt nicht mehr.
                                      Falls es ev. ein Problem mit dem Adapter oder Anpassungen im Google Kalender wären, ist es sicherlich für alle sinnvoll.
                                      2xProxmox auf NUC
                                      • V valbuz
                                        da_WoodyD Offline
                                        da_WoodyD Offline
                                        #277
                                        sorry, das siehst du so.
                                        ich verwende adapter für das, wofür sie gemacht wurden.
                                        mag sein, bei einem update halt dann nicht mehr.
                                        ist nicht böse gemeint, aber wenn du was verwendest für das nicht gedacht ist, ist der DEV nicht schuld.
                                          V Offline
                                          V Offline
                                          valbuz
                                          #278
                                          @da_woody Ich will hier niemanden beschuldigen! Hoffe nicht, dass dies so rüberkam.
                                          Wollte lediglich auf Hilfe und Tipp's hier im Forum hoffen.
                                          2xProxmox auf NUC
