  3. Einsteigerfragen
  4. Einbindung von Geräten
  5. Zigbee/Conbee2 funktioniert nach Update nicht mehr (udev)
    6.7k
conbee 2usb portzigbee2mqtt
361 Beiträge 42 Kommentatoren 113.4k Aufrufe 41 Beobachtet
  • J Offline
    JensBHB
    #180
    Irgendwie klappt es bei mir nicht. Liegt wohl daran, dass ich Raspbian installiert habe?
    udev:
      Installed: 247.3-7+rpi1+deb11u2
      Candidate: 247.3-7+rpi1+deb11u2
      Version table:
     *** 247.3-7+rpi1+deb11u2 500
    Jemand eine Idee wie ich an die "proposed-updates" von Raspbian rankomme? Oder habe ich einen Denkfehler?
    pi@iobroker-master:/etc/apt/sources.list.d $ sudo apt update
    Get:1 http://deb.debian.org/debian bullseye-proposed-updates InRelease [54.0 kB]
    Get:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15.0 kB]
    Hit:3 http://phoscon.de/apt/deconz bullseye InRelease
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
    Err:1 http://deb.debian.org/debian bullseye-proposed-updates InRelease
      The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 648ACFD622F3D138 NO_PUBKEY 0E98404D386FA1D9
    Reading package lists... Done
    W: GPG error: http://deb.debian.org/debian bullseye-proposed-updates InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 648ACFD622F3D138 NO_PUBKEY 0E98404D386FA1D9
    E: The repository 'http://deb.debian.org/debian bullseye-proposed-updates InRelease' is not signed.
    N: Updating from such a repository can't be done securely, and is therefore disabled by default.
    N: See apt-secure(8) manpage for repository creation and user configuration details.
    pi@iobroker-master:/etc/apt/sources.list.d $ sudo apt -t bullseye-proposed-updates install udev
    E: The value 'bullseye-proposed-updates' is invalid for APT::Default-Release as such a release is not available in the sources
    • Thomas BraunT Online
      #181
      @jensbhb
      Da muss der Schlüssel angelegt werden. Steht aber irgendwo hier im Thread schon drin.
        @jensbhb
        JensBHB
        #182
        @thomas-braun Vielen Dank. Ich hab das überlesen... Der Wald - lauter Bäume :-)
        • J JensBHB
          #183
          @jensbhb
          sudo apt update
          apt policy udev
          wirft nun was raus?
            @jensbhb
            sudo apt update
            apt policy udev
            wirft nun was raus?
            JensBHB
            #184
            @thomas-braun Ich hab die Nerven verloren und ein Image eingespielt und die 1. Variante genutzt. Danke für die Hilfe!
            • J JensBHB
              #185
              @jensbhb sagte in Zigbee/Conbee2 funktioniert nach Update nicht mehr (udev):
              Warum?
                Warum?
                JensBHB
                #186
                @thomas-braun Naja ich hab das Image eingespielt bevor Du mir den Hinweis auf den Schlüssel gegeben hast.
                • J JensBHB
                  #187
                  @jensbhb
                  Image einspielen ist halt irgendwie immer nur die hilfloseste Aktion. Lernste nix bei und bei der nächsten Meldung stehste dann genauso im kurzen Hemd da
                  Gilt genauso für die tapferen Ritter von der Beta-Tafelrunde. 'Oh, da klemmt irgendwas... Schnell ein Image einspielen'
                  Bringt halt nur keinem was.
                    @jensbhb
                    JensBHB
                    schrieb am zuletzt editiert von JensBHB
                    #188
                    @thomas-braun Das sehe ich schon anders. Mein Raspi läuft im Produktiveinsatz, da ging es um eine schnelle Abhilfe. Bin ja froh, dass ich hier schon eine Menge gelernt habe - aber ich gebe zu, ich profitiere von Experten hier. Bei diesem Fehler war es ja schon fast ein Zufall, dass ich hier einen Lösungsansatz gefunden habe. Ich dachte es lag an meinem Umzug auf eine SSD (in dessen Folge ist der Fehler bei mir aufgetreten, weil ich da apt update / upgrade gemacht habe). Und es war für mich nicht zu erkennen, dass mir hier ein Schlüssel fehlen könnte, damit der vorgeschlagene 2. Lösungsweg funktioniert.
                    • J JensBHB
                      #189
                      Deswegen steht der Hinweis auch sehr eindeutig in der Meldung.
                      Der Key ist auch sehr bekannt, da kommt beim ersten Treffer bei deiner bevorzugten Suchmaschine schon was bei herum. Und hier im Forum findet sich der auch bereits in diversen Einträgen. Also weniger Panik schieben, mehr Struktur bei der Suche.
                        JensBHB
                        #190
                        @thomas-braun sagte in Zigbee/Conbee2 funktioniert nach Update nicht mehr (udev):
                        Natürlich habe ich gesucht und bei Stack Overflow eine Lösung für den fehlenden Public Key gefunden. Und dann hab ich halt danach den hier vorgeschlagenen 1. Lösungsweg verfolgt und nicht den zweiten. Ich bin halt davon ausgegangen, dass der zweite Lösungsweg für meine Konfig nicht passt, aufgrund der abweichenden Quelle. Den Zusammenhang habe ich erst durch Deinen Hinweis realisiert. Somit habe ich etwas dazu gelernt, falls es erneut Probleme mit UDEV gibt.
                        Vielleicht findet der OP die Zeit die Thematik des Public Keys im Eingangspost unterzubringen, das wäre ja zumindest hilfreich für Andere, die wie ich den Zusammenhang nicht gleich erkennen, aber den zweiten Lösungsweg verfolgen.
                        • J JensBHB
                          mickymM Offline
                          mickymM Offline
                          mickym
                          #191
                          Habe ich gestern bereits gemacht. :)
                            kleh58
                            #192
                            Moin aus Hamburg.
                            Auch ich bin von diesem Update betroffen und bekomme den Conbee nicht wieder zum laufen.
                            Da ich das Update schon ausgeführt hatte, bin ich nach Punkt 2 vorgegangen. Auch die Geschichte mit dem Schlüssel habe ich befolgt. Alles erfolglos.
                            Ich bin noch Einsteiger und nicht so bewandert.
                            Kann da mal Jemand drüber Schauen.
                            MfG```
                            code_text
                            ```pi@raspberrypi:~ $ sudo apt update
                            OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                            Holen:2 http://deb.debian.org/debian bullseye-proposed-updates InRelease [54,0 kB]
                            OK:3 http://phoscon.de/apt/deconz bullseye InRelease
                            OK:4 http://archive.raspberrypi.org/debian bullseye InRelease
                            Holen:5 https://repos.influxdata.com/debian stretch InRelease [7.039 B]
                            OK:6 https://deb.nodesource.com/node_18.x bullseye InRelease
                            Holen:7 https://packages.grafana.com/oss/deb stable InRelease [5.984 B]
                            Fehl:2 http://deb.debian.org/debian bullseye-proposed-updates InRelease
                              Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131
                            Fehl:5 https://repos.influxdata.com/debian stretch InRelease
                              Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY D8FF8E1F7DF8B07E
                            Fehl:7 https://packages.grafana.com/oss/deb stable InRelease
                              Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 9E439B102CF3C0C6
                            W: GPG-Fehler: http://deb.debian.org/debian bullseye-proposed-updates InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131
                            E: Das Depot »http://deb.debian.org/debian bullseye-proposed-updates InRelease« ist nicht signiert.
                            N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert.
                            N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8).
                            W: Während der Überprüfung der Signatur trat ein Fehler auf. Das Depot wurde nicht aktualisiert und die vorherigen Indexdateien werden verwendet. GPG-Fehler: https://repos.influxdata.com/debian stretch InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY D8FF8E1F7DF8B07E
                            W: Während der Überprüfung der Signatur trat ein Fehler auf. Das Depot wurde nicht aktualisiert und die vorherigen Indexdateien werden verwendet. GPG-Fehler: https://packages.grafana.com/oss/deb stable InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 9E439B102CF3C0C6
                            pi@raspberrypi:~ $ ^C
                            • K kleh58
                              Moin aus Hamburg.
                              MfG```
                              code_text
                              #193
                              @kleh58
                              Da sind insgesamt 3 Schlüssel nicht richtig. Für Grafana + Influx siehe:
                              https://forum.iobroker.net/topic/62040/linux-debian-grafana-repo-muss-aktualisiert-werden
                              Wenn die drin sind schau nochmal nach dem key für die proposed-updates
                              • K kleh58
                                Moin aus Hamburg.
                                MfG```
                                code_text
                                #194
                                @kleh58 sagte in Zigbee/Conbee2 funktioniert nach Update nicht mehr (udev):
                                Bitte dann auch die vollständigen Ein- wie Ausgaben zu den Aktionen sehen lassen. So kann man nur raten was du da gemacht hast.
                                  kleh58
                                  #195
                                  @thomas-braun Danke für die schnelle Antwort. Außer dem hier beschriebenen Befehl für den Schlüssel, habe ich null Ahnung wo und wie ich die beiden Anderen her bekomme.
                                  MfG
                                  • K kleh58
                                    MfG
                                    #196
                                    Hatte ich nicht einen Thread verlinkt, wo das alles drin steht? Egal, kann ich auch nochmal aus dem Hut zaubern:
                                      kleh58
                                      #197
                                      @thomas-braun Danke, ich glaube es hat hingehauen.```
                                      code_text
                                      Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
                                      ****Fettschrift****
                                      • K kleh58
                                        code_text
                                        ****Fettschrift****
                                        #198
                                        Woran machst du das fest?
                                        Die Zeile sagt eigentlich nur aus, das es da noch irgendwo klemmt, sonst würde die nämlich nicht ausgegeben.
                                          kleh58
                                          #199
                                          @thomas-braun dachte die 0 soll da stehen```
                                          codepi@raspberrypi:~ $ apt-key list | grep -i grafana | wc -l
                                          _text
