  4. Daikin Cloud Adapter nodejs18 [gelöst]
116 Beiträge 7 Kommentatoren 12.3k Aufrufe 6 Beobachtet
  • Elektroniker86E Elektroniker86
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 3 Model B Plus Rev 1.3
    Architecture    : armv7l
    Docker          : false
    Virtualization  : none
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
     10:10:13 up 2 days, 22:23,  1 user,  load average: 0.93, 0.81, 0.77
    CPU threads: 4
    Raspberry only:
    throttled=0x80008
    Other values than 0x0 hint to temperature/voltage problems
    temp=60.1'C
    volt=1.2625V
    *** Time and Time Zones ***
                   Local time: Wed 2023-06-07 10:10:13 CEST
               Universal time: Wed 2023-06-07 08:10:13 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            921M        236M        440M        0.0K        244M        628M
    Swap:            99M          0B         99M
    Total:          1.0G        236M        540M
              921 M total memory
              237 M used memory
              153 M active memory
              264 M inactive memory
              440 M free memory
               37 M buffer memory
              206 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4       29G  3.5G   25G  13% /
    devtmpfs       devtmpfs  333M     0  333M   0% /dev
    tmpfs          tmpfs     461M     0  461M   0% /dev/shm
    tmpfs          tmpfs     185M  696K  184M   1% /run
    /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
    tmpfs          tmpfs      93M     0   93M   0% /run/user/1000
    sudo: unable to resolve host iobroker-slave-wp: Name or service not known
    [Sun Jun  4 11:46:35 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=c1772fc4-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Sun Jun  4 11:46:38 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Sun Jun  4 11:46:38 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Sun Jun  4 11:46:41 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    /var:
    1.3G    /var/
    973M    /var/log
    969M    /var/log/journal/f100f43d07a54920922b8472f114b5d9
    107M    /var/cache
    Archived and active journals take up 968.2M in the file system.
    /opt/iobroker/backups:
    4.0K    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    3.7M    /opt/iobroker/iobroker-data/
    1.1M    /opt/iobroker/iobroker-data/files
    472K    /opt/iobroker/iobroker-data/files/discovery.admin
    384K    /opt/iobroker/iobroker-data/files/backitup.admin
    252K    /opt/iobroker/iobroker-data/files/admin.admin
    2.5M    /opt/iobroker/iobroker-data/objects.jsonl
    200K    /opt/iobroker/iobroker-data/files/discovery.admin/words.js
    148K    /opt/iobroker/iobroker-data/files/backitup.admin/words.js
    128K    /opt/iobroker/iobroker-data/states.jsonl
    120K    /opt/iobroker/iobroker-data/files/discovery.admin/index_m.html
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.16.0
    /usr/bin/node           v18.16.0
    /usr/bin/npm            9.5.1
    /usr/bin/npx            9.5.1
    nodejs:
      Installed: 18.16.0-deb-1nodesource1
      Candidate: 18.16.0-deb-1nodesource1
      Version table:
     *** 18.16.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
         12.22.12~dfsg-1~deb11u4 500
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    At least one iobroker host is running.
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     "javascript" not found
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.1                  : admin                 : iobroker-slave-wp                        -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alarm.0                  : alarm                 : iobroker                                 - disabled
    + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
    + system.adapter.awtrix-light.0           : awtrix-light          : iobroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.canbus.0                 : canbus                : iobroker-slave-wp                        -  enabled
    + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
    + system.adapter.daikin-cloud.0           : daikin-cloud          : iobroker                                 -  enabled
      system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
    + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 - disabled
    + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
    + system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.linux-control.0          : linux-control         : iobroker                                 -  enabled
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
    + system.adapter.mihome-vacuum.1          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
    + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
    + system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 192.168.1.240
    + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1889, bind: 0.0.0.0
    + system.adapter.mqtt.2                   : mqtt                  : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
    + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
    + system.adapter.s7.0                     : s7                    : iobroker                                 -  enabled
    + system.adapter.s7.1                     : s7                    : iobroker                                 -  enabled
    + system.adapter.s7.2                     : s7                    : iobroker                                 -  enabled
    + system.adapter.s7.3                     : s7                    : iobroker                                 -  enabled
    + system.adapter.s7.4                     : s7                    : iobroker                                 -  enabled
    + system.adapter.s7.5                     : s7                    : iobroker                                 -  enabled
    + system.adapter.s7.6                     : s7                    : iobroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 192.168.1.240
    + system.adapter.smartmeter.0             : smartmeter            : iobroker                                 -  enabled
    + system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
    + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
    + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
    + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
      system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
      system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker                                 - disabled
      system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
      system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
    + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
    + instance is alive
    ioBroker-Repositories
    Stable (default): http://download.iobroker.net/sources-dist.json
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    Installed ioBroker-Instances
    Adapter    "backitup"     : 2.6.19   , installed 2.5.9  [Updatable]
    Adapter    "canbus"       : 1.3.1    , installed 1.3.1
    Adapter    "tuya"         : 3.13.1   , installed 3.12.1 [Updatable]
    Objects and States
    Objects:        18779
    States:         12462
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12851      566/sshd: /usr/sbin
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16833      1052/io.admin.1
    tcp6       0      0 :::22                   :::*                    LISTEN      0          12853      566/sshd: /usr/sbin
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14246      348/avahi-daemon: r
    udp        0      0 0.0.0.0:53596           0.0.0.0:*                           108        14248      348/avahi-daemon: r
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          600        683/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        14247      348/avahi-daemon: r
    udp6       0      0 :::57442                :::*                                108        14249      348/avahi-daemon: r
    2023-06-07 02:32:58.747  - info: host.iobroker-slave-wp Delete log file iobroker.2023-05-30.log.gz
    2023-06-07 07:38:35.973  - error: host.iobroker-slave-wp Invalid request getRepository. "callback" or "from" is null
    2023-06-07 07:42:32.860  - info: host.iobroker-slave-wp Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
    2023-06-07 09:53:08.279  - error: host.iobroker-slave-wp Invalid request getRepository. "callback" or "from" is null
    iob diag has finished.
    Press any key for a summary
    Hab jetzt gesehen das auf dem Host backitup und Tuya installiert ist. Kann ich das per kommandozeile deinstallieren? In der GUI geht das glaub garnicht.
    #73
    @elektroniker86 sagte in Daikin Cloud Adapter nodejs18 [gelöst]:
    throttled=0x80008
    temp=60.1'C
    volt=1.2625V
    Der Kiste wird wohl zu warm, die wird heruntergeregelt.
    Und eine admin-Instanz. Bei richtigen Setup eines Multihosts braucht es nur einen Admin.
    iobroker del admin.1 --host iobroker-slave-wp
    Der gibt mir mehr zu denken:
    Da stimmt was mit den sudo-Rechten nicht.
    Elektroniker86E 1 Antwort Letzte Antwort
      throttled=0x80008
      temp=60.1'C
      volt=1.2625V
      Elektroniker86E Offline
      Elektroniker86
      #74
      @thomas-braun sagte in Daikin Cloud Adapter nodejs18 [gelöst]:
      Das wusste ich auch nicht, wird auch soviel ich weiß in keiner Doku erwähnt.
      -> hab ich deinstalliert.
      Kann ich das andere zeug auch deinstallieren? Tuya und backitup ?
      Temperaturproblem werde ich noch angehen.
      Wie kann ich das lösen?
        #75
        Ich sehe da keine Instanzen auf dem Host.
        Schau dir die Gruppen der user auf dem Host an:
        groups
        sudo -u iobroker groups
          groups
          Elektroniker86
          #76
          Ich dachte weil das hier steht ??
          pi@iobroker-slave-wp:~ $ groups
          sudo: Hostname iobroker-slave-wp kann nicht aufgelöst werden: Der Name oder der Dienst ist nicht bekannt
          iobroker tty dialout audio video bluetooth gpio i2c
            #77
            Hast du den Hostname iobroker-slave-wp mal nachträglich irgendwie angepasst? Das ist offenbar nicht vollständig/richtig gemacht worden.
            Die updatebaren Instanzen liegen auf dem Hauptsystem. Solltest du aber natürlich auch aktualisieren.
              Elektroniker86
              #78
              Ja, bei der Installation habe ich bei raspi-config den hostnamen geändert und bestätigt. Warum der da meckert weiß ich ehrlichgesagt nicht.
              Hier zeigt er mir keine Updates an?
                #79
                Das muss auch noch an anderen Stellen geändert werden. Müsste ich jetzt aber auch nachlesen, so oft mache ich das nicht.
                  #80
                  Hatte ich nicht schon mal gesagt, das GUIs lügen?
                  iobroker update
                  sagt?
                    Elektroniker86
                    #81
                    ok, dann wird es daran liegen. Ich kenne nur die Option, das in dem config Menü vom Pi zu machen.
                      #82
                      ...und anschließend die Änderung iobroker bekannt geben mit iobroker host this bevor iobroker neu gestartet wird.
                        iobroker update
                        sagt?
                        Elektroniker86
                        #83
                        Ok, ich sehe keine Updates. Oder ich interpretiere da etwas falsch?
                        Auf dem Hauptsystem ausgeführt:
                        iobroker@iobroker:~$ iobroker update
                        Adapter    "alarm"        : 3.3.11   , installed 3.3.11
                        Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
                        Adapter    "backitup"     : 2.6.19   , installed 2.6.19
                        Adapter    "cloud"        : 4.3.0    , installed 4.3.0
                        Adapter    "daikin-cloud" : 0.2.3    , installed 0.2.3
                        Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
                        Adapter    "harmony"      : 1.2.2    , installed 1.2.2
                        Adapter    "iot"          : 1.14.2   , installed 1.14.2
                        Adapter    "iqontrol"     : 2.1.0    , installed 2.1.0
                        Adapter    "javascript"   : 6.1.4    , installed 6.1.4
                        Adapter    "linux-control": 1.1.3    , installed 1.1.3
                        Adapter    "mihome-vacuum": 3.9.5    , installed 3.9.5
                        Adapter    "modbus"       : 5.0.11   , installed 5.0.11
                        Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
                        Adapter    "pixelit"      : 0.2.0    , installed 0.2.0
                        Adapter    "s7"           : 1.3.14   , installed 1.3.14
                        Adapter    "shelly"       : 6.3.1    , installed 6.3.1
                        Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
                        Adapter    "sonos"        : 2.2.3    , installed 2.2.3
                        Adapter    "telegram"     : 1.15.2   , installed 1.15.2
                        Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                        Adapter    "tuya"         : 3.13.1   , installed 3.13.1
                        Adapter    "unifi"        : 0.5.10   , installed 0.6.3
                        Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
                        Adapter    "vis-icontwo"  : 0.93.0   , installed 0.93.0
                        Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
                        Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                        Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                        Adapter    "wled"         : 0.6.7    , installed 0.6.7
                          Elektroniker86
                          #84
                          @homoran sagte in Daikin Cloud Adapter nodejs18 [gelöst]:
                          iobroker host this
                          Läuft nicht so?
                          pi@iobroker-slave-wp:~ $ iobroker host this
                          Cannot execute changes on running system. Stop iobroker first.
                          pi@iobroker-slave-wp:~ $ iob stop
                            iobroker host this
                            Läuft nicht so?
                            #85
                            @elektroniker86 was sagt iobroker status?
                              Elektroniker86
                              schrieb am zuletzt editiert von Elektroniker86
                              #86
                              Ich bin ein wenig verwirrt über die Ausgabe ....
                              pi@iobroker-slave-wp:~ $ sudo iobroker status
                              iobroker is not running on this host.
                              Objects type: jsonl
                              States  type: jsonl
                              Objects type: jsonl
                              States  type: jsonl
                              pi@iobroker-slave-wp:~ $ sudo iobroker stop
                              Objects type: jsonl
                              States  type: jsonl
                              Er sagt das ich iobroker erst stoppen soll obwohl der Dienst gestoppt ist im Webif sehe ich auch das der Host nicht läuft.
                              sudo: Hostname iobroker-slave kann nicht aufgelöst werden: Der Name oder der Dienst ist nicht bekannt
                                Objects type: jsonl
                                States  type: jsonl
                                Objects type: jsonl
                                States  type: jsonl
                                Objects type: jsonl
                                States  type: jsonl
                                #87
                                @elektroniker86
                                Niemals das Kommando iobroker zusammen mit sudo ausführen.
                                cat /etc/hosts
                                sagt?
                                  @elektroniker86
                                  cat /etc/hosts
                                  sagt?
                                  Elektroniker86
                                  #88
                                  cat /etc/hosts
                                  pi@iobroker-slave-wp:~ $ cat /etc/hosts
                                  127.0.0.1       localhost
                                  ::1             localhost ip6-localhost ip6-loopback
                                  ff02::1         ip6-allnodes
                                  ff02::2         ip6-allrouters
                                  127.0.1.1       ioBroker slave
                                    cat /etc/hosts
                                    127.0.0.1       localhost
                                    #89
                                    Da liegt der Hund begraben. Da muss
                                    127.0.1.1       iobroker-slave-wp
                                    rein. Nach der Änderung einmal das Netzwerk neustarten, alternativ den ganzen Rechner.
                                      Elektroniker86
                                      #90
                                      Ok, dann muss ich das mit Sicherheit irgendwo in einer config Datei mit nano ändern?
                                        #91
                                        normal nicht!
                                        Da scheint aber einiges bei dir verbogen zu sein.
                                          #92
                                          @elektroniker86
                                          Ja, in der /etc/hosts natürlich. Du hast da ja gerade reingeschaut.
                                          sudo nano /etc/hosts
