maxcul ist komplett unbrauchbar (geloest mit 0.5.2)
Forum zum Mitteilen von Fehlern
skraw.iobroker
professional
Re: maxcul ist komplett unbrauchbar (geloest, oder doch nicht)
Beitrag von skraw.iobroker » 24.02.2018, 01:36
Es tut mir leid, aber:
Code: Alles auswählen
maxcul.0	2018-02-24 01:25:43.593	debug	enable MAX! Mode of the CUL868
maxcul.0	2018-02-24 01:25:42.593	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":453,"ack":true,"ts":1519431942588,"q":0,"from":"system.adapter.maxcul.0","lc":1519431942588}
maxcul.0	2018-02-24 01:25:42.591	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.limitOverflow {"val":false,"ack":true,"ts":1519431942585,"q":0,"from":"system.adapter.maxcul.0","lc":1519431770879}
maxcul.0	2018-02-24 01:25:39.631	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.connection {"val":true,"ack":true,"ts":1519431939624,"q":0,"from":"system.adapter.maxcul.0","lc":1519431939624}
maxcul.0	2018-02-24 01:25:39.629	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.version {"val":"V 1.67 nanoCUL868","ack":true,"ts":1519431939622,"q":0,"from":"system.adapter.maxcul.0","lc":1519041256179}
maxcul.0	2018-02-24 01:25:39.614	info	CUL FW Version: V 1.67 nanoCUL868
maxcul.0	2018-02-24 01:25:39.611	debug	incoming raw data from CUL: V 1.67 nanoCUL868
maxcul.0	2018-02-24 01:25:39.589	debug	Requested CUL Version...
maxcul.0	2018-02-24 01:25:39.581	debug	check CUL Firmware version
maxcul.0	2018-02-24 01:25:37.585	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.connection {"val":false,"ack":true,"ts":1519431937582,"q":0,"from":"system.adapter.maxcul.0","lc":1519431809659}
maxcul.0	2018-02-24 01:25:37.575	info	serialPort /dev/ttyUSB0 is open!
maxcul.0	2018-02-24 01:25:37.554	info	using serial device /dev/ttyUSB0@38400
maxcul.0	2018-02-24 01:25:37.025	info	starting. Version 0.5.0 in /opt/iobroker/node_modules/iobroker.maxcul, node: v6.12.0
maxcul.0	2018-02-24 01:25:36.967	info	States connected to redis: 127.0.0.1:6379
maxcul.0	2018-02-24 01:25:36.955	debug	statesDB connected
maxcul.0	2018-02-24 01:25:36.903	debug	objectDB connected
host.ioBroker-Pi	2018-02-24 01:25:35.225	info	instance system.adapter.maxcul.0 started with pid 25975
host.ioBroker-Pi	2018-02-24 01:25:35.171	info	object change system.adapter.maxcul.0
und steht ...
Auch nach einem Reset das gleiche Bild. Nach dem "enable MAX mode" ists aus ...
geändert: Code in Code-Tags; Homoran (Mod)
Benutzeravatar
guru
Beitrag von apollon77 » 24.02.2018, 08:36
ich kapiere es nicht ... Ich hab nochmal Debug eingebaut. Bitte schick nochmal log.
Ansonsten muss ich wirklich auf serialport 3 zurück und verlieren damit halt node8 support ...
How-to:
* Debug-Log für einen Adapter/Instanz einschalten? -> Instanzen -> Expertenomodus -> Spalte Loglevel
skraw.iobroker
professional
Beitrag von skraw.iobroker » 24.02.2018, 13:01
Ok, da geht mehr. Das hat es bisher noch nie getan. Hast Du ausser dem Debug noch was geaendert?
Ich bin erst morgen wieder zum Testen in der Lage, Du kannst noch ueberlegen :-)
maxcul.0	2018-02-24 12:58:17.516	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":383,"ack":true,"ts":1519473497506,"q":0,"from":"system.adapter.maxcul.0","lc":1519473497506}
maxcul.0	2018-02-24 12:58:12.494	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":378,"ack":true,"ts":1519473492488,"q":0,"from":"system.adapter.maxcul.0","lc":1519473492488}
maxcul.0	2018-02-24 12:58:07.858	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":374,"ack":true,"ts":1519473487853,"q":0,"from":"system.adapter.maxcul.0","lc":1519473487853}
maxcul.0	2018-02-24 12:58:07.840	debug	got OK-ACK Packet from 16fb8f
maxcul.0	2018-02-24 12:58:07.840	debug	RSSI for Message: -40.5
maxcul.0	2018-02-24 12:58:07.839	debug	decoding Message Z0E01020216FB8F123456000139643443
maxcul.0	2018-02-24 12:58:07.839	debug	incoming raw data from CUL: Z0E01020216FB8F123456000139643443
maxcul.0	2018-02-24 12:58:06.739	debug	serial port buffer have been drained
maxcul.0	2018-02-24 12:58:06.723	debug	Send Packet to CUL: 0b01004012345616fb8f0074, awaiting drain event
maxcul.0	2018-02-24 12:58:06.701	debug	sendTemperature(maxcul.0.NKF0003406, 26, 1)
maxcul.0	2018-02-24 12:58:05.686	debug	redis pmessage io.maxcul.0.* io.maxcul.0.NKF0003406.desiredTemperature {"val":26,"ack":false,"ts":1519473485684,"q":0,"from":"system.adapter.admin.0","lc":1519473485684}
maxcul.0	2018-02-24 12:58:02.494	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":478,"ack":true,"ts":1519473482490,"q":0,"from":"system.adapter.maxcul.0","lc":1519473482490}
maxcul.0	2018-02-24 12:57:57.507	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":473,"ack":true,"ts":1519473477499,"q":0,"from":"system.adapter.maxcul.0","lc":1519473477499}
maxcul.0	2018-02-24 12:57:52.480	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":468,"ack":true,"ts":1519473472478,"q":0,"from":"system.adapter.maxcul.0","lc":1519473472478}
maxcul.0	2018-02-24 12:57:47.478	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":463,"ack":true,"ts":1519473467475,"q":0,"from":"system.adapter.maxcul.0","lc":1519473467475}
maxcul.0	2018-02-24 12:57:42.476	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":458,"ack":true,"ts":1519473462474,"q":0,"from":"system.adapter.maxcul.0","lc":1519473462474}
maxcul.0	2018-02-24 12:57:38.502	debug	Za drained
maxcul.0	2018-02-24 12:57:38.496	debug	Za written
maxcul.0	2018-02-24 12:57:38.492	debug	Zr drained
maxcul.0	2018-02-24 12:57:38.488	debug	Zr written
maxcul.0	2018-02-24 12:57:38.485	debug	X20 drained
maxcul.0	2018-02-24 12:57:38.481	debug	X20 written
maxcul.0	2018-02-24 12:57:38.477	debug	enable MAX! Mode of the CUL868
maxcul.0	2018-02-24 12:57:37.484	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":453,"ack":true,"ts":1519473457478,"q":0,"from":"system.adapter.maxcul.0","lc":1519473457478}
maxcul.0	2018-02-24 12:57:37.482	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.limitOverflow {"val":false,"ack":true,"ts":1519473457475,"q":0,"from":"system.adapter.maxcul.0","lc":1519464560648}
maxcul.0	2018-02-24 12:57:34.510	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.connection {"val":true,"ack":true,"ts":1519473454502,"q":0,"from":"system.adapter.maxcul.0","lc":1519473454502}
maxcul.0	2018-02-24 12:57:34.508	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.version {"val":"V 1.67 nanoCUL868","ack":true,"ts":1519473454500,"q":0,"from":"system.adapter.maxcul.0","lc":1519041256179}
maxcul.0	2018-02-24 12:57:34.492	info	CUL FW Version: V 1.67 nanoCUL868
maxcul.0	2018-02-24 12:57:34.489	debug	incoming raw data from CUL: V 1.67 nanoCUL868
maxcul.0	2018-02-24 12:57:34.473	debug	Requested CUL Version...
maxcul.0	2018-02-24 12:57:34.465	debug	check CUL Firmware version
maxcul.0	2018-02-24 12:57:32.470	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.connection {"val":false,"ack":true,"ts":1519473452466,"q":0,"from":"system.adapter.maxcul.0","lc":1519473339719}
maxcul.0	2018-02-24 12:57:32.458	info	serialPort /dev/ttyUSB0 is open!
maxcul.0	2018-02-24 12:57:32.438	info	using serial device /dev/ttyUSB0@38400
maxcul.0	2018-02-24 12:57:31.923	info	starting. Version 0.5.0 in /opt/iobroker/node_modules/iobroker.maxcul, node: v6.12.0
maxcul.0	2018-02-24 12:57:31.862	info	States connected to redis: 127.0.0.1:6379
maxcul.0	2018-02-24 12:57:31.850	debug	statesDB connected
maxcul.0	2018-02-24 12:57:31.796	debug	objectDB connected
Nachtrag Thema Wandthermostat:
Abgesehen von dem Kommando 42 habe ich noch nicht verstanden wie man dieses Thermostat mit dem Broker pairt. Mir scheint naemlich diese Broadcasts an "000000" bringen die in der Naehe befindlichen Heizungsthermostate durcheinander, die versuchen dann dieser Anweisung zu folgen und nicht den Broker-Einstellungen...
skraw.iobroker
professional
Beitrag von skraw.iobroker » 24.02.2018, 13:04
Jetzt ist was passiert, das hatten wir noch nie:
host.ioBroker-Pi	2018-02-24 13:02:36.028	error	instance system.adapter.maxcul.0 terminated with code 0 (OK)
host.ioBroker-Pi	2018-02-24 13:02:36.028	error	Caught by controller[0]: at FSReqWrap.wrapper [as oncomplete] (fs.js:683:17)
host.ioBroker-Pi	2018-02-24 13:02:36.028	error	Caught by controller[0]: at SerialPort. (/opt/iobroker/node_modules/serialport/lib/serialport.js:306:7)
host.ioBroker-Pi	2018-02-24 13:02:36.027	error	Caught by controller[0]: at SerialPort. (/opt/iobroker/node_modules/serialport/lib/serialport.js:293:14)
host.ioBroker-Pi	2018-02-24 13:02:36.027	error	Caught by controller[0]: at SerialPort._emitData (/opt/iobroker/node_modules/serialport/lib/serialport.js:313:18)
host.ioBroker-Pi	2018-02-24 13:02:36.027	error	Caught by controller[0]: at SerialPort. (/opt/iobroker/node_modules/serialport/lib/parsers.js:23:13)
host.ioBroker-Pi	2018-02-24 13:02:36.026	error	Caught by controller[0]: at Array.forEach (native)
host.ioBroker-Pi	2018-02-24 13:02:36.025	error	Caught by controller[0]: at /opt/iobroker/node_modules/serialport/lib/parsers.js:24:17
host.ioBroker-Pi	2018-02-24 13:02:36.025	error	Caught by controller[0]: at SerialPort.emit (events.js:188:7)
host.ioBroker-Pi	2018-02-24 13:02:36.025	error	Caught by controller[0]: at emitOne (events.js:96:13)
host.ioBroker-Pi	2018-02-24 13:02:36.025	error	Caught by controller[0]: at SerialPort. (/opt/iobroker/node_modules/iobroker.maxcul/lib/communication-layer.js:93:42)
host.ioBroker-Pi	2018-02-24 13:02:36.024	error	Caught by controller[0]: at CommunicationServiceLayer.emit (events.js:188:7)
host.ioBroker-Pi	2018-02-24 13:02:36.024	error	Caught by controller[0]: at emitOne (events.js:96:13)
host.ioBroker-Pi	2018-02-24 13:02:36.024	error	Caught by controller[0]: at CommunicationServiceLayer. (/opt/iobroker/node_modules/iobroker.maxcul/lib/maxcul.js:46:34)
host.ioBroker-Pi	2018-02-24 13:02:36.024	error	Caught by controller[0]: at MaxDriver.handleIncommingMessage (/opt/iobroker/node_modules/iobroker.maxcul/lib/maxcul.js:151:57)
host.ioBroker-Pi	2018-02-24 13:02:36.024	error	Caught by controller[0]: at MaxDriver.ThermostatState (/opt/iobroker/node_modules/iobroker.maxcul/lib/maxcul.js:486:38)
host.ioBroker-Pi	2018-02-24 13:02:36.023	error	Caught by controller[0]: TypeError: rawBitData.getRange is not a function
maxcul.0	2018-02-24 13:02:35.969	error	TypeError: rawBitData.getRange is not a function at MaxDriver.ThermostatState (/opt/iobroker/node_modules/iobroker.maxcul/lib/maxcul.js:486:38) at MaxDriver.handleIncommingMessage (/opt/iobrok
maxcul.0	2018-02-24 13:02:35.969	error	uncaught exception: rawBitData.getRange is not a function
maxcul.0	2018-02-24 13:02:35.968	debug	got data from heatingelement 16fbae with payload 39002D00FB
maxcul.0	2018-02-24 13:02:35.967	debug	RSSI for Message: -80
maxcul.0	2018-02-24 13:02:35.967	debug	decoding Message Z0F00046016FBAE0000000039002D00FBF4
maxcul.0	2018-02-24 13:02:35.966	debug	incoming raw data from CUL: Z0F00046016FBAE0000000039002D00FBF4
Benutzeravatar
guru
Beitrag von apollon77 » 24.02.2018, 13:53
skraw.iobroker hat geschrieben:Ok, da geht mehr. Das hat es bisher noch nie getan. Hast Du ausser dem Debug noch was geaendert?
Ja ich habe noch ein was geändert: Es wird jetzt bei der Initialisierung nach jedem senden einer Nachricht gewartet das die auch wirklich gesendet wurde (draining). Das war vorher nicht so. Da wurde einfach alles direkt nacheinander gesendet.
skraw.iobroker hat geschrieben: Jetzt ist was passiert, das hatten wir noch nie:
Da ist scheinbar ein Bug im Code der eine Funktion aufruft die es nicht gibt. Habe bei der "Quelle" (ja habe inzwischen gefunden wo die Logik herkommt und könnte daher auch auf die aktuellste Version updaten) nachgesehen und fix ist auf Github.
Bitte versuchen und mal laufen lassen. Wenn das erstmal wieder so tut wie in der 0.3.0 dann machen wir es erstmal so live.
Dann kann ich in einer 0.6 mal die Logik aktualisieren auf den aktuellen Stand (Kommunikation nicht anfassen) und wir sehen was da so geht
How-to:
skraw.iobroker
professional
Beitrag von skraw.iobroker » 25.02.2018, 12:00
Hab die neue Version jetzt gerade installiert und laeuft. Auf die Schnelle kann ich keinen Absturz mehr produzieren wie beim letzten Mal. Ich lass es jetzt mal laufen, solange ich mich nicht melde kannst Du davon ausgehen dass es noch fehlerfrei laeuft...
Benutzeravatar
guru
Beitrag von apollon77 » 25.02.2018, 12:08
Ok dann veröffentliche ich die 0.5.0 heute Abend um erstmal was funktionierendes live zu haben. Dann versuche ich die Tage mal eine 0.6 mit Logikaktualisierungen
How-to:
skraw.iobroker
professional
Beitrag von skraw.iobroker » 25.02.2018, 13:32
Welchen?
Benutzeravatar
guru
Re: maxcul ist komplett unbrauchbar (geloest)
Beitrag von apollon77 » 25.02.2018, 13:40
Mindestens Unterstützung für die Message 42 von oben und anderem Kram.
How-to:
Mickbaer
starter
Beitrag von Mickbaer » 25.02.2018, 18:49
skraw.iobroker hat geschrieben: Koennte es sein dass das sowas simples wie ein <CR><LF> Problem ist? (Also ein fehlendes <CR> oder andersherum)?
(Ich hab den betreffenden Code bis dato nicht gelesen...)
das befürchte Ich bei dem CUL-Adapter, der am naoCUL nicht initialisiert wird auch. :cry:
Das läßt sich mit mit Terminal PRG nur schwer debuggen.
Aber mal sehen was apolon77 da antwortet.
Gruß Mickbaer aus Berlin
Benutzeravatar
guru
Beitrag von apollon77 » 25.02.2018, 19:17
Hab ich doch schon in dem cul Thread. Bitte auch da mal cul vom github testen.
How-to:
skraw.iobroker
professional
Beitrag von skraw.iobroker » 28.02.2018, 08:13
Auch nach drei Tagen Laufzeit ist mir nichts ungewoehnliches mehr aufgefallen. Alles sieht gut aus.
skraw.iobroker
professional
Beitrag von skraw.iobroker » 02.03.2018, 23:25
Hier hab ich noch so ein Phaenomen, dass aber wahrscheinlich nicht mit neuer/alter Version zusammenhaengt.
Aus unbekannten Gruenden haengt sich der nanoCUL manchmal auf. Erkennbar ist das am schnellen Blinken der Uebertragungs-LED.
Adapter stoppen und wieder starten bringt:
maxcul.0 2018-03-02 23:24:00.535 info Timeout on CUL connect, cul is available but not responding
maxcul.0 2018-03-02 23:23:36.571 debug Za drained
maxcul.0 2018-03-02 23:23:36.566 debug Za written
maxcul.0 2018-03-02 23:23:36.560 debug Zr drained
maxcul.0 2018-03-02 23:23:36.554 debug Zr written
maxcul.0 2018-03-02 23:23:36.549 debug X20 drained
maxcul.0 2018-03-02 23:23:36.543 debug X20 written
maxcul.0 2018-03-02 23:23:36.536 debug enable MAX! Mode of the CUL868
maxcul.0 2018-03-02 23:23:32.533 debug Requested CUL Version...
maxcul.0 2018-03-02 23:23:32.529 debug check CUL Firmware version
maxcul.0 2018-03-02 23:23:29.919 info starting. Version 0.5.0 in /opt/iobroker/node_modules/iobroker.maxcul, node: v6.12.0
maxcul.0 2018-03-02 23:23:29.855 info States connected to redis: 127.0.0.1:6379
maxcul.0 2018-03-02 23:23:29.843 debug statesDB connected
maxcul.0 2018-03-02 23:23:29.790 debug objectDB connected
Das Ding haengt scheinbar einfach. Vielleicht koennen wir dafuer eine Loesung finden?
Benutzeravatar
guru
Beitrag von apollon77 » 02.03.2018, 23:31
Wie resettet man "das Ding" denn wenn es sowwas tut?
How-to:
skraw.iobroker
professional
Beitrag von skraw.iobroker » 02.03.2018, 23:50
Man stoppt den Adapter und steckt den nanoCUL vom USB ab und wieder an, dann startet man den Adapter wieder...
Benutzeravatar
guru
Beitrag von apollon77 » 02.03.2018, 23:52
Aaaaaaaaaaahja :-)
Keine Ahnung wie der Adapter das regeln soll ...
How-to:
skraw.iobroker
professional
Beitrag von skraw.iobroker » 02.03.2018, 23:58
Eigentlich waers ja besser festzustellen was da eigentlich abkackt. Ich hab jetzt mal debug eingeschaltet, vielleicht sieht man ja was wenn er wieder haengenbleiben wuerde.
Mir scheint es koennte etwas mit der Auslastung zu tun haben. Ich habe heute nochmal 3 Fensterkontakte dazugenommen und er ist mir allein heute schon dreimal stehengeblieben. Vielleicht findet sich was im debug-log...
(hatte ich vorhin noch nicht an)
skraw.iobroker
professional
Beitrag von skraw.iobroker » 03.03.2018, 00:09
Und schon ists passiert:
Spoiler: Show hidden text
maxcul.0	2018-03-03 00:00:03.037	debug	serial port buffer have been drained
maxcul.0	2018-03-03 00:00:03.036	debug	serial port buffer have been drained
maxcul.0	2018-03-03 00:00:03.001	debug	Send Packet to CUL: 0b0100401234561b7c2e0026, awaiting drain event
maxcul.0	2018-03-03 00:00:03.000	debug	Send Packet to CUL: 0b0100401234561b7bbd0026, awaiting drain event
maxcul.0	2018-03-03 00:00:03.000	debug	serial port buffer have been drained
maxcul.0	2018-03-03 00:00:03.000	debug	Send Packet to CUL: 0b0100401234561b7e310022, awaiting drain event
maxcul.0	2018-03-03 00:00:02.999	debug	Send Packet to CUL: 0b0100401234561b7d410022, awaiting drain event
maxcul.0	2018-03-03 00:00:02.999	debug	got OK-ACK Packet from 16fbae
maxcul.0	2018-03-03 00:00:02.999	debug	RSSI for Message: -72
maxcul.0	2018-03-03 00:00:02.999	debug	decoding Message Z0E01020216FBAE123456000138002204
maxcul.0	2018-03-03 00:00:02.998	debug	incoming raw data from CUL: Z0E01020216FBAE123456000138002204
maxcul.0	2018-03-03 00:00:01.877	debug	sendTemperature(maxcul.0.OEQ2604915, 19, 0)
maxcul.0	2018-03-03 00:00:01.871	debug	sendTemperature(maxcul.0.OEQ2604801, 19, 0)
maxcul.0	2018-03-03 00:00:01.868	debug	sendTemperature(maxcul.0.OEQ2605429, 17, 0)
maxcul.0	2018-03-03 00:00:01.865	debug	serial port buffer have been drained
maxcul.0	2018-03-03 00:00:01.853	debug	Send Packet to CUL: 0b01004012345616fbae0022, awaiting drain event
maxcul.0	2018-03-03 00:00:01.851	debug	sendTemperature(maxcul.0.OEQ2605190, 17, 0)
maxcul.0	2018-03-03 00:00:01.851	debug	sendTemperature(maxcul.0.NKF0003377, 17, 0)
maxcul.0	2018-03-03 00:00:00.876	debug	redis pmessage io.maxcul.0.* io.maxcul.0.OEQ2604915.desiredTemperature {"val":19,"ack":false,"ts":1520031600873,"q":0,"from":"system.adapter.javascript.0","lc":1520031600873}
maxcul.0	2018-03-03 00:00:00.868	debug	redis pmessage io.maxcul.0.* io.maxcul.0.OEQ2604801.desiredTemperature {"val":19,"ack":false,"ts":1520031600864,"q":0,"from":"system.adapter.javascript.0","lc":1520031600864}
maxcul.0	2018-03-03 00:00:00.865	debug	redis pmessage io.maxcul.0.* io.maxcul.0.OEQ2605429.desiredTemperature {"val":17,"ack":false,"ts":1520031600864,"q":0,"from":"system.adapter.javascript.0","lc":1520028000856}
maxcul.0	2018-03-03 00:00:00.845	debug	redis pmessage io.maxcul.0.* io.maxcul.0.OEQ2605190.desiredTemperature {"val":17,"ack":false,"ts":1520031600831,"q":0,"from":"system.adapter.javascript.0","lc":1520031600831}
maxcul.0	2018-03-03 00:00:00.844	debug	redis pmessage io.maxcul.0.* io.maxcul.0.NKF0003377.desiredTemperature {"val":17,"ack":false,"ts":1520031600820,"q":0,"from":"system.adapter.javascript.0","lc":1520028000802}
javascript.0	2018-03-03 00:00:00.830	info	script.js.Skript-Heizung-Esszimmer: setForeignState(id=maxcul.0.OEQ2605190.desiredTemperature, state=17)
javascript.0	2018-03-03 00:00:00.827	info	script.js.Skript-Heizung-Wohnzimmer: setForeignState(id=maxcul.0.NKF0003377.desiredTemperature, state=17)
maxcul.0	2018-03-02 23:59:58.914	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031598899,"q":0,"from":"system.adapter.maxcul.0","lc":1520031458787}
maxcul.0	2018-03-02 23:59:53.899	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031593896,"q":0,"from":"system.adapter.maxcul.0","lc":1520031458787}
maxcul.0	2018-03-02 23:59:48.897	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031588894,"q":0,"from":"system.adapter.maxcul.0","lc":1520031458787}
maxcul.0	2018-03-02 23:59:43.898	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031583894,"q":0,"from":"system.adapter.maxcul.0","lc":1520031458787}
maxcul.0	2018-03-02 23:59:38.881	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031578877,"q":0,"from":"system.adapter.maxcul.0","lc":1520031458787}
maxcul.0	2018-03-02 23:59:33.877	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031573873,"q":0,"from":"system.adapter.maxcul.0","lc":1520031458787}
maxcul.0	2018-03-02 23:58:48.844	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031528835,"q":0,"from":"system.adapter.maxcul.0","lc":1520031458787}
maxcul.0	2018-03-02 23:58:43.840	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031523831,"q":0,"from":"system.adapter.maxcul.0","lc":1520031458787}
maxcul.0	2018-03-02 23:58:38.831	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031518829,"q":0,"from":"system.adapter.maxcul.0","lc":1520031458787}
maxcul.0	2018-03-02 23:58:33.831	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031513827,"q":0,"from":"system.adapter.maxcul.0","lc":1520031458787}
maxcul.0	2018-03-02 23:58:28.829	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031508825,"q":0,"from":"system.adapter.maxcul.0","lc":1520031458787}
maxcul.0	2018-03-02 23:58:23.829	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031503823,"q":0,"from":"system.adapter.maxcul.0","lc":1520031458787}
maxcul.0	2018-03-02 23:58:18.827	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031498821,"q":0,"from":"system.adapter.maxcul.0","lc":1520031458787}
maxcul.0	2018-03-02 23:58:13.811	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031493804,"q":0,"from":"system.adapter.maxcul.0","lc":1520031458787}
maxcul.0	2018-03-02 23:58:08.809	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031488802,"q":0,"from":"system.adapter.maxcul.0","lc":1520031458787}
maxcul.0	2018-03-02 23:58:03.808	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031483799,"q":0,"from":"system.adapter.maxcul.0","lc":1520031458787}
maxcul.0	2018-03-02 23:58:01.280	debug	redis pmessage io.maxcul.0.* io.maxcul.0.OEQ2604915.rssi {"val":-66.5,"ack":true,"ts":1520031481275,"q":0,"from":"system.adapter.maxcul.0","lc":1520031481275}
maxcul.0	2018-03-02 23:58:01.274	debug	redis pmessage io.maxcul.0.* io.maxcul.0.OEQ2604915.batteryLow {"val":false,"ack":true,"ts":1520031481267,"q":0,"from":"system.adapter.maxcul.0","lc":1519979406969}
maxcul.0	2018-03-02 23:58:01.269	debug	redis pmessage io.maxcul.0.* io.maxcul.0.OEQ2604915.rfError {"val":false,"ack":true,"ts":1520031481260,"q":0,"from":"system.adapter.maxcul.0","lc":1519979406964}
maxcul.0	2018-03-02 23:58:01.263	debug	redis pmessage io.maxcul.0.* io.maxcul.0.OEQ2604915.measuredTemperature {"val":20.1,"ack":true,"ts":1520031481253,"q":0,"from":"system.adapter.maxcul.0","lc":1520031481253}
maxcul.0	2018-03-02 23:58:01.256	debug	redis pmessage io.maxcul.0.* io.maxcul.0.OEQ2604915.valvePosition {"val":22,"ack":true,"ts":1520031481247,"q":0,"from":"system.adapter.maxcul.0","lc":1520031481247}
maxcul.0	2018-03-02 23:58:01.248	debug	redis pmessage io.maxcul.0.* io.maxcul.0.OEQ2604915.desiredTemperature {"val":20,"ack":true,"ts":1520031481241,"q":0,"from":"system.adapter.maxcul.0","lc":1520030166413}
maxcul.0	2018-03-02 23:58:01.240	debug	redis pmessage io.maxcul.0.* io.maxcul.0.OEQ2604915.mode {"val":null,"ack":true,"ts":1520031481232,"q":0,"from":"system.adapter.maxcul.0","lc":1520031481232}
maxcul.0	2018-03-02 23:58:01.236	debug	ThermostatStateReceived: {"src":"1b7c2e","desiredTemperature":20,"valvePosition":22,"measuredTemperature":20.1,"dstSetting":1,"lanGateway":1,"panel":1,"rfError":0,"batteryLow":0,"untilString":"","rssi
maxcul.0	2018-03-02 23:58:01.235	debug	got data from heatingelement 1b7c2e with payload 39162800C9
maxcul.0	2018-03-02 23:58:01.235	debug	RSSI for Message: -66.5
maxcul.0	2018-03-02 23:58:01.234	debug	decoding Message Z0F0004601B7C2E0000000039162800C90F
maxcul.0	2018-03-02 23:58:01.234	debug	incoming raw data from CUL: Z0F0004601B7C2E0000000039162800C90F
maxcul.0	2018-03-02 23:57:58.804	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031478797,"q":0,"from":"system.adapter.maxcul.0","lc":1520031458787}
maxcul.0	2018-03-02 23:57:53.799	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031473796,"q":0,"from":"system.adapter.maxcul.0","lc":1520031458787}
maxcul.0	2018-03-02 23:57:48.795	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031468792,"q":0,"from":"system.adapter.maxcul.0","lc":1520031458787}
maxcul.0	2018-03-02 23:57:43.793	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031463790,"q":0,"from":"system.adapter.maxcul.0","lc":1520031458787}
maxcul.0	2018-03-02 23:57:38.795	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031458787,"q":0,"from":"system.adapter.maxcul.0","lc":1520031458787}
maxcul.0	2018-03-02 23:57:33.792	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":895,"ack":true,"ts":1520031453785,"q":0,"from":"system.adapter.maxcul.0","lc":1520031453785}
maxcul.0	2018-03-02 23:57:30.114	debug	redis pmessage io.maxcul.0.* io.maxcul.0.MEQ1480497.rssi {"val":-75.5,"ack":true,"ts":1520031450110,"q":0,"from":"system.adapter.maxcul.0","lc":1520031450110}
maxcul.0	2018-03-02 23:57:30.106	debug	redis pmessage io.maxcul.0.* io.maxcul.0.MEQ1480497.batteryLow {"val":false,"ack":true,"ts":1520031450104,"q":0,"from":"system.adapter.maxcul.0","lc":1518824069530}
maxcul.0	2018-03-02 23:57:30.103	debug	redis pmessage io.maxcul.0.* io.maxcul.0.MEQ1480497.rfError {"val":false,"ack":true,"ts":1520031450100,"q":0,"from":"system.adapter.maxcul.0","lc":1519997246688}
maxcul.0	2018-03-02 23:57:30.099	debug	redis pmessage io.maxcul.0.* io.maxcul.0.MEQ1480497.isOpen {"val":false,"ack":true,"ts":1520031450095,"q":0,"from":"system.adapter.maxcul.0","lc":1520002444590}
maxcul.0	2018-03-02 23:57:30.098	debug	ShutterContactStateReceived: {"src":"133721","isOpen":0,"rfError":0,"batteryLow":0,"rssi":-75.5}
maxcul.0	2018-03-02 23:57:30.098	debug	got data from shutter contact 133721 10000
maxcul.0	2018-03-02 23:57:30.097	debug	RSSI for Message: -75.5
maxcul.0	2018-03-02 23:57:30.097	debug	decoding Message Z0B5106301337211234560010FD
maxcul.0	2018-03-02 23:57:30.097	debug	incoming raw data from CUL: Z0B5106301337211234560010FD
maxcul.0	2018-03-02 23:57:30.097	debug	ignored auto-ack packet
maxcul.0	2018-03-02 23:57:30.097	debug	RSSI for Message: -74
maxcul.0	2018-03-02 23:57:30.097	debug	decoding Message Z0B510002123456133721000000
maxcul.0	2018-03-02 23:57:30.096	debug	incoming raw data from CUL: Z0B510002123456133721000000
maxcul.0	2018-03-02 23:57:28.786	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031448783,"q":0,"from":"system.adapter.maxcul.0","lc":1520031208598}
maxcul.0	2018-03-02 23:57:23.780	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031443778,"q":0,"from":"system.adapter.maxcul.0","lc":1520031208598}
maxcul.0	2018-03-02 23:57:18.783	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031438776,"q":0,"from":"system.adapter.maxcul.0","lc":1520031208598}
maxcul.0	2018-03-02 23:57:13.779	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031433773,"q":0,"from":"system.adapter.maxcul.0","lc":1520031208598}
maxcul.0	2018-03-02 23:57:08.778	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031428770,"q":0,"from":"system.adapter.maxcul.0","lc":1520031208598}
maxcul.0	2018-03-02 23:57:03.761	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031423753,"q":0,"from":"system.adapter.maxcul.0","lc":1520031208598}
maxcul.0	2018-03-02 23:56:58.757	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031418750,"q":0,"from":"system.adapter.maxcul.0","lc":1520031208598}
maxcul.0	2018-03-02 23:56:53.753	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031413748,"q":0,"from":"system.adapter.maxcul.0","lc":1520031208598}
maxcul.0	2018-03-02 23:56:48.753	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031408747,"q":0,"from":"system.adapter.maxcul.0","lc":1520031208598}
So schauts aus, hilft uns das was?
Koennte es sein dass man beim Senden eines Paketes auch auf seine "Fertigstellung" (sprich kompletten Versand) warten sollte?
skraw.iobroker
professional
Beitrag von skraw.iobroker » 03.03.2018, 07:37
Hier ist das Problem:
Zeile 150 communication-layer.js:
        CommunicationServiceLayer.prototype.serialWrite = function(data) {
            var command;
            if (this._serialDeviceInstance.isOpen()) {
                command = 'Zs' + data + '\n';
                return this._serialDeviceInstance.writeAsync(command).then((function(_this) {
                    return function() {
                        env.logger.debug('Send Packet to CUL: ' + data + ', awaiting drain event');
                        return _this._serialDeviceInstance.drainAsync().then(function() {
                            return env.logger.debug('serial port buffer have been drained');
                })(this));
            } else {
                env.logger.debug('Can not send packet because serial port is not open');
                return Promise.reject('Error: serial port is not open');
Diese Funktion braucht ein Locking. Am besten innerhalb des ersten if.
Damit serialisiert man das Handling des Devices und alles wird funktionieren ...
Gibts in dieser Umgebung ein Lock/Unlock? Falls nein einfach "von Hand".
Eine statische Variable hochzaehlen und danach ueberpruefen ob sie 1 ist (0 init). Falls nicht 1 Sekunde warten und nochmal pruefen.
Unlock per Variable--.
Oder sowas ginge auch:
https://github.com/kirill-konshin/mutex-promise
Benutzeravatar
guru
Re: maxcul ist komplett unbrauchbar (ungeloest, noch ein BUG)
Beitrag von apollon77 » 03.03.2018, 21:31
naja, das macht man in nodejs etwas anders/einfacher :-)
Ich schaue mal wann ich Zeit finde
How-to:
