  4. Problem bei JS Adapter 4.0.6
    5.8k
17 Beiträge 5 Kommentatoren 2.6k Aufrufe
  • J Offline
    Jan1
    Ich bekomme eine Fehlermeldung, wenn ich ein simplen CRON Trigger mit Blockly anlege:
    error javascript.0 script.js.common.Test.Skript1 compile failed: at script.js.common.Test.Skript1:1
    Das ballert mir dann auch schon das Log voll:
    javascript.0	2018-12-26 15:30:26.876	error	at TCP.onread (net.js:601:20)
    javascript.0	2018-12-26 15:30:26.876	error	at Socket.Readable.push (_stream_readable.js:208:10)
    javascript.0	2018-12-26 15:30:26.876	error	at readableAddChunk (_stream_readable.js:250:11)
    javascript.0	2018-12-26 15:30:26.876	error	at addChunk (_stream_readable.js:263:12)
    javascript.0	2018-12-26 15:30:26.876	error	at Socket.emit (events.js:211:7)
    javascript.0	2018-12-26 15:30:26.875	error	at emitOne (events.js:116:13)
    javascript.0	2018-12-26 15:30:26.875	error	at Socket.realHandler (/opt/iobroker/node_modules/ws/lib/WebSocket.js:825:20)
    javascript.0	2018-12-26 15:30:26.875	error	at Receiver.add (/opt/iobroker/node_modules/ws/lib/Receiver.js:103:24)
    javascript.0	2018-12-26 15:30:26.875	error	at Receiver.expectHandler (/opt/iobroker/node_modules/ws/lib/Receiver.js:499:31)
    javascript.0	2018-12-26 15:30:26.875	error	at Receiver.finish (/opt/iobroker/node_modules/ws/lib/Receiver.js:541:12)
    javascript.0	2018-12-26 15:30:26.875	error	at Receiver.flush (/opt/iobroker/node_modules/ws/lib/Receiver.js:347:3)
    javascript.0	2018-12-26 15:30:26.874	error	at /opt/iobroker/node_modules/ws/lib/Receiver.js:508:14
    javascript.0	2018-12-26 15:30:26.874	error	at Receiver.applyExtensions (/opt/iobroker/node_modules/ws/lib/Receiver.js:371:5)
    javascript.0	2018-12-26 15:30:26.874	error	at /opt/iobroker/node_modules/ws/lib/Receiver.js:536:18
    javascript.0	2018-12-26 15:30:26.874	error	at Receiver.ontext (/opt/iobroker/node_modules/ws/lib/WebSocket.js:841:10)
    javascript.0	2018-12-26 15:30:26.874	error	at WebSocket.emit (events.js:214:7)
    javascript.0	2018-12-26 15:30:26.874	error	at emitTwo (events.js:126:13)
    javascript.0	2018-12-26 15:30:26.873	error	at WebSocket.onMessage (/opt/iobroker/node_modules/ws/lib/WebSocket.js:442:14)
    javascript.0	2018-12-26 15:30:26.873	error	at WebSocket.ws.onmessage (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
    javascript.0	2018-12-26 15:30:26.873	error	at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8)
    javascript.0	2018-12-26 15:30:26.873	error	at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8)
    javascript.0	2018-12-26 15:30:26.873	error	at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0	2018-12-26 15:30:26.873	error	at WS. <anonymous>(/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
    javascript.0	2018-12-26 15:30:26.872	error	at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
    javascript.0	2018-12-26 15:30:26.872	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0	2018-12-26 15:30:26.872	error	at Socket. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
    javascript.0	2018-12-26 15:30:26.872	error	at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
    javascript.0	2018-12-26 15:30:26.872	error	at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
    javascript.0	2018-12-26 15:30:26.871	error	at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
    javascript.0	2018-12-26 15:30:26.871	error	at Decoder. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
    javascript.0	2018-12-26 15:30:26.871	error	at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
    javascript.0	2018-12-26 15:30:26.871	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0	2018-12-26 15:30:26.871	error	at Manager. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
    javascript.0	2018-12-26 15:30:26.871	error	at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
    javascript.0	2018-12-26 15:30:26.870	error	at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
    javascript.0	2018-12-26 15:30:26.870	error	at Socket.adapter.getForeignState (/opt/iobroker/node_modules/iobroker.javascript/main.js:823:17)
    javascript.0	2018-12-26 15:30:26.870	error	at createActiveObject (/opt/iobroker/node_modules/iobroker.javascript/main.js:1200:20)
    javascript.0	2018-12-26 15:30:26.870	error	at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1146:37)
    javascript.0	2018-12-26 15:30:26.870	error	at compile (/opt/iobroker/node_modules/iobroker.javascript/main.js:957:28)
    javascript.0	2018-12-26 15:30:26.869	error	at Object.createScript (vm.js:80:10)
    javascript.0	2018-12-26 15:30:26.869	error	SyntaxError: missing ) after argument list
    javascript.0	2018-12-26 15:30:26.869	error	^
    javascript.0	2018-12-26 15:30:26.869	error	schedule(0 12 * * *, function () {
    javascript.0	2018-12-26 15:30:26.869	error	at script.js.common.Test.Skript1:1
    javascript.0	2018-12-26 15:30:26.869	error	script.js.common.Test.Skript1 compile failed:
    javascript.0	2018-12-26 15:30:26.865	info	Start javascript script.js.common.Test.Skript1</anonymous></anonymous></anonymous></anonymous>
    Ich bin der Meinung, das war erst nach dem Update auf die Version 4.0.6. Leider komme ich von dieser Version auch nicht mehr auf eine tiefere. 4.0.5 wird eh nicht angeboten nur 3.7.0 und selbst wenn ich den Mülleimer klicke, wird nur die Instanz gelöscht, nicht der Adapter.
    pi@raspberrypi:~ $ node -v
    v8.14.1
    pi@raspberrypi:~ $ nodejs -v
    v8.14.1
    pi@raspberrypi:~ $ npm -v
    6.4.1
    • DutchmanD Offline
      DutchmanD Offline
      Dutchman
      Klicke Mal bitte oben rechts auf blockly/JavaScript und poste den Code hier der aus deinen blockly rauskommt.
      Sieht so aus als ob der cron nicht richtig verarbeitet wird
      • paul53P Offline
        @Jan1:
        Während in den Vorgängerversionen (4.0.x) doppelte Hochkommata erzeugt wurden, fehlen jetzt die Hochkommata komplett. Da muss wohl @Bluefox noch mal ran.
        • J Offline
          Jan1
          @Dutchman
          hier mal de Code:
            setState("wifilight.0.192_168_100_28.on"/*on*/, true);
            setStateDelayed("wifilight.0.192_168_100_28.on"/*on*/, false, 1000, false);
          //JTNDeG1sJTIweG1sbnMlM0QlMjJodHRwJTNBJTJGJTJGd3d3LnczLm9yZyUyRjE5OTklMkZ4aHRtbCUyMiUzRSUzQ2Jsb2NrJTIwdHlwZSUzRCUyMnNjaGVkdWxlJTIyJTIwaWQlM0QlMjJiUGVkIWlTdlBXJTVFWm8qYk5oNChhJTIyJTIweCUzRCUyMjEzJTIyJTIweSUzRCUyMi0xMzclMjIlM0UlM0NmaWVsZCUyMG5hbWUlM0QlMjJTQ0hFRFVMRSUyMiUzRTAlMjAxMiUyMColMjAqJTIwKiUzQyUyRmZpZWxkJTNFJTNDc3RhdGVtZW50JTIwbmFtZSUzRCUyMlNUQVRFTUVOVCUyMiUzRSUzQ2Jsb2NrJTIwdHlwZSUzRCUyMmNvbnRyb2wlMjIlMjBpZCUzRCUyMjBaa0kpdyklN0NsNnglN0ROKi40VVhiWCUyMiUzRSUzQ211dGF0aW9uJTIwZGVsYXlfaW5wdXQlM0QlMjJmYWxzZSUyMiUzRSUzQyUyRm11dGF0aW9uJTNFJTNDZmllbGQlMjBuYW1lJTNEJTIyT0lEJTIyJTNFd2lmaWxpZ2h0LjAuMTkyXzE2OF8xMDBfMjgub24lM0MlMkZmaWVsZCUzRSUzQ2ZpZWxkJTIwbmFtZSUzRCUyMldJVEhfREVMQVklMjIlM0VGQUxTRSUzQyUyRmZpZWxkJTNFJTNDdmFsdWUlMjBuYW1lJTNEJTIyVkFMVUUlMjIlM0UlM0NibG9jayUyMHR5cGUlM0QlMjJsb2dpY19ib29sZWFuJTIyJTIwaWQlM0QlMjIoJTNBISlPTVdoJTdCZiUzRChZJTQwNFNqJTJCTiU3QiUyMiUzRSUzQ2ZpZWxkJTIwbmFtZSUzRCUyMkJPT0wlMjIlM0VUUlVFJTNDJTJGZmllbGQlM0UlM0MlMkZibG9jayUzRSUzQyUyRnZhbHVlJTNFJTNDbmV4dCUzRSUzQ2Jsb2NrJTIwdHlwZSUzRCUyMmNvbnRyb2wlMjIlMjBpZCUzRCUyMiUzRGclNjBJVVolMjV3JTdDUG8lN0RBVU4lMkMlMkJrYSUyMyUyMiUzRSUzQ211dGF0aW9uJTIwZGVsYXlfaW5wdXQlM0QlMjJ0cnVlJTIyJTNFJTNDJTJGbXV0YXRpb24lM0UlM0NmaWVsZCUyMG5hbWUlM0QlMjJPSUQlMjIlM0V3aWZpbGlnaHQuMC4xOTJfMTY4XzEwMF8yOC5vbiUzQyUyRmZpZWxkJTNFJTNDZmllbGQlMjBuYW1lJTNEJTIyV0lUSF9ERUxBWSUyMiUzRVRSVUUlM0MlMkZmaWVsZCUzRSUzQ2ZpZWxkJTIwbmFtZSUzRCUyMkRFTEFZX01TJTIyJTNFMSUzQyUyRmZpZWxkJTNFJTNDZmllbGQlMjBuYW1lJTNEJTIyVU5JVCUyMiUzRXNlYyUzQyUyRmZpZWxkJTNFJTNDZmllbGQlMjBuYW1lJTNEJTIyQ0xFQVJfUlVOTklORyUyMiUzRUZBTFNFJTNDJTJGZmllbGQlM0UlM0N2YWx1ZSUyMG5hbWUlM0QlMjJWQUxVRSUyMiUzRSUzQ2Jsb2NrJTIwdHlwZSUzRCUyMmxvZ2ljX2Jvb2xlYW4lMjIlMjBpZCUzRCUyMklzSzElNjBHTiUyQ19IJTJDU0FpJTYwdyUzRjR+SyUyMiUzRSUzQ2ZpZWxkJTIwbmFtZSUzRCUyMkJPT0wlMjIlM0VGQUxTRSUzQyUyRmZpZWxkJTNFJTNDJTJGYmxvY2slM0UlM0MlMkZ2YWx1ZSUzRSUzQyUyRmJsb2NrJTNFJTNDJTJGbmV4dCUzRSUzQyUyRmJsb2NrJTNFJTNDJTJGc3RhdGVtZW50JTNFJTNDJTJGYmxvY2slM0UlM0MlMkZ4bWwlM0U=
          sieht dann nach nem Bug aus, oder?
          Erklärt aber auch warum es nur passiert, wenn man einen neuen CRON anlegt. Alte Scripte mit nem CRON machen keinen Ärger.
          • DutchmanD Offline
            DutchmanD Offline
            Dutchman
            Kannst du bitte ein issue dazu auf github erstellen?
            • J Offline
              Jan1
              Ja mach ich und kopiere den Post von Paul rein
              • DutchmanD Offline
                DutchmanD Offline
                Dutchman
                @Jan1:
                Ja mach ich und kopiere den Post von Paul rein `
                Danke!
                • J Offline
                  jf62
                  Gibt es hier schon ein Zeitfenster? Bekomme nämlich kein downgrade hin und so funktioniert leider meine Heizungssteuerung nicht mwhr.
                  Bitte nicht stressen, nur eine Frage wie lange es etwa dauern wird, da ich sonst anderweitig etwas unternehmen muss
                  • liv-in-skyL Offline
                    liv-in-skyL Offline
                    liv-in-sky
                    habe das selbe problem nach update auf 4.0.6
                    auch meine heizsteuerung hat jetzt probleme, weil ich etwas neu hinzufügen wollte
                    würde mich auch über info zum zeitfenster interessieren
                    • paul53P Offline
                      @liv-in-sky:
                      meine heizsteuerung hat jetzt probleme, `
                      Wenn Du ioBroker produktiv einsetzt, dann mach einen https://forum.iobroker.net/viewtopic.php?f=21&t=19440&p=205458#p205458 des JS-Adapters auf Version 3.6.4.
                        liv-in-skyL Offline
                        liv-in-sky
                        habe mir das übersetzte blockly script kopiert und ein neues jscript daraus gemacht - überall die anführungszeichen eingesetzt - damit geht erst mal die heizung wieder
                        ich warte erstmal, vielleicht gibt es ja bald eine lösung - hört sich nicht nach großem problem an
                        bei dem neuem iot-adapter hat blockly auch ein problem - da wird bei "sendto iot.0" bei der übersetzung "sendto cloud.0" eingesetzt.
                        danke für den downgrade link - wäre meine nächste frage gewesen - falls ich noch andere probleme finde
                        • J Offline
                          Jan1
                          So nun habe ich auch das Downgrade auf 3.6.4 durchgeführt. Was mich dann doch wundert, dass so ein Fehler nicht früher bemerkt wird, scheint ja jede Version ab 4.x zu betreffen.
                            liv-in-skyL Offline
                            liv-in-sky
                            habe 4.0.7 aufgespielt und jetzt geht der cron block wieder
                            danke
                            • J Offline
                              Jan1
                              der normal schon, wenn was exotisches mit dem Wizard bastelst, dann kommt der alte Fehler ;)
                                liv-in-skyL Offline
                                liv-in-sky
                                was meinst du mit wizard ?
                                • J Offline
                                  Jan1
                                  Na den Assistent der so exotische Zeitpläne erstellt. Mach mal einen wie alle 2 Wochen montags um 2 und speicher das, kommt sofort ne Fehlermeldung
                                    liv-in-skyL Offline
                                    liv-in-sky
                                    weiß jetzt was du meinst - und bei mir ist da auch noch ein fehler
