  4. Problem bei JS Adapter 4.0.6
    5.8k
17 Beiträge 5 Kommentatoren 2.6k Aufrufe
  • paul53P Offline
    @Jan1:
    javascript.0 2018-12-26 15:30:26.869 error schedule(0 12 * * *, function () {
    Während in den Vorgängerversionen (4.0.x) doppelte Hochkommata erzeugt wurden, fehlen jetzt die Hochkommata komplett. Da muss wohl @Bluefox noch mal ran.
    • J Offline
      Jan1
      @Dutchman
      hier mal de Code:
        setState("wifilight.0.192_168_100_28.on"/*on*/, true);
        setStateDelayed("wifilight.0.192_168_100_28.on"/*on*/, false, 1000, false);
      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
      sieht dann nach nem Bug aus, oder?
      Erklärt aber auch warum es nur passiert, wenn man einen neuen CRON anlegt. Alte Scripte mit nem CRON machen keinen Ärger.
      • DutchmanD Offline
        DutchmanD Offline
        Dutchman
        Kannst du bitte ein issue dazu auf github erstellen?
        • J Offline
          Jan1
          Ja mach ich und kopiere den Post von Paul rein
          • DutchmanD Offline
            DutchmanD Offline
            Dutchman
            @Jan1:
            Ja mach ich und kopiere den Post von Paul rein `
            Danke!
            • J Offline
              jf62
              Gibt es hier schon ein Zeitfenster? Bekomme nämlich kein downgrade hin und so funktioniert leider meine Heizungssteuerung nicht mwhr.
              Bitte nicht stressen, nur eine Frage wie lange es etwa dauern wird, da ich sonst anderweitig etwas unternehmen muss
              • liv-in-skyL Offline
                liv-in-skyL Offline
                habe das selbe problem nach update auf 4.0.6
                auch meine heizsteuerung hat jetzt probleme, weil ich etwas neu hinzufügen wollte
                würde mich auch über info zum zeitfenster interessieren
                • paul53P Offline
                  @liv-in-sky:
                  meine heizsteuerung hat jetzt probleme, `
                  Wenn Du ioBroker produktiv einsetzt, dann mach einen https://forum.iobroker.net/viewtopic.php?f=21&t=19440&p=205458#p205458 des JS-Adapters auf Version 3.6.4.
                    liv-in-skyL Offline
                    habe mir das übersetzte blockly script kopiert und ein neues jscript daraus gemacht - überall die anführungszeichen eingesetzt - damit geht erst mal die heizung wieder
                    ich warte erstmal, vielleicht gibt es ja bald eine lösung - hört sich nicht nach großem problem an
                    bei dem neuem iot-adapter hat blockly auch ein problem - da wird bei "sendto iot.0" bei der übersetzung "sendto cloud.0" eingesetzt.
                    danke für den downgrade link - wäre meine nächste frage gewesen - falls ich noch andere probleme finde
                    • J Offline
                      Jan1
                      So nun habe ich auch das Downgrade auf 3.6.4 durchgeführt. Was mich dann doch wundert, dass so ein Fehler nicht früher bemerkt wird, scheint ja jede Version ab 4.x zu betreffen.
                        liv-in-skyL Offline
                        habe 4.0.7 aufgespielt und jetzt geht der cron block wieder
                        danke
                        • J Offline
                          Jan1
                          der normal schon, wenn was exotisches mit dem Wizard bastelst, dann kommt der alte Fehler ;)
                            liv-in-skyL Offline
                            was meinst du mit wizard ?
                            • J Offline
                              Jan1
                              Na den Assistent der so exotische Zeitpläne erstellt. Mach mal einen wie alle 2 Wochen montags um 2 und speicher das, kommt sofort ne Fehlermeldung
                                liv-in-skyL Offline
                                weiß jetzt was du meinst - und bei mir ist da auch noch ein fehler
