    2. raVsu
    R
    • Following 1
    • Posts 13
    raVsu
    @raVsu
    14
    raVsu Follow
    Latest posts made by raVsu
    • RE: NPM: 9.2.0 (10.2.3) "Einige Update verfügbar" Update?
      @thomas-braun said in NPM: 9.2.0 (10.2.3) "Einige Update verfügbar" Update?:
      iob nodejs-update
      Alles bestens 😄
      ioBroker nodejs updater 2023-10-13
      Recommended nodejs-version is: 18.19.0
      Checking your installation now. Please be patient!
      Your current setup is:
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      /usr/bin/corepack       0.22.0
      We found these nodejs versions available for installation:
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.0-1nodesource1
        Version table:
           18.19.0+dfsg-6~deb12u1 500
              500 http://security.debian.org/debian-security bookworm-security/main arm64 Packages
       *** 18.19.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
              100 /var/lib/dpkg/status
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0+dfsg1-1 500
              500 http://deb.debian.org/debian bookworm/main arm64 Packages
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
      Nothing to do - Your installation is using the correct paths.
      Nothing to do - Your version is the recommended one.
      posted in Einsteigerfragen
      R
      raVsu
      Vielen, vielen Dank. Jetzt schein alles upgedatet zu sein. 😃
      Besseren support kann man nicht haben.
      Danke an alle.
      R
      raVsu
      danke für den Hinweis, habe etwas gebraucht um herauszufinden wie die code-tags zu setzen sind 🙂
      R
      raVsu
      Danke für den Link.
      Bei dem Befehl
      sudo apt install nodejs=18.19.0-1nodesource1
      wird am ende eine Fehlermeldung geliefert:
      E: Version '18.19.0-1nodesource1' for 'nodejs' was not found
      pi@iobroker:~$ apt policy nodejs
      nodejs:
        Installed: 18.19.0+dfsg-6~deb12u1
        Candidate: 14.21.3-deb-1nodesource1
        Version table:
       *** 18.19.0+dfsg-6~deb12u1 500
           18.13.0+dfsg1-1 500
           14.21.3-deb-1nodesource1 1001
              500 https://deb.nodesource.com/node_14.x bullseye/main arm64 Packages
      pi@iobroker:~$ echo -e "Package: nodejs\nPin: origin deb.nodesource.com\nPin-Priority: 1001" | sudo tee /etc/apt/preferences.d/nodejs.pref
      sudo apt update
      iob stop
      sudo apt remove npm
      iob restart
      Package: nodejs
      Pin-Priority: 1001
      Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
      Hit:2 http://deb.debian.org/debian bookworm InRelease
      Get:3 https://deb.nodesource.com/node_14.x bullseye InRelease [4586 B]
      Fetched 4586 B in 1s (4087 B/s)
      Reading package lists... Done
      Building dependency tree... Done
      All packages are up to date.
      Package 'npm' is not installed, so not removed
      The following packages were automatically installed and are no longer required:
        distro-info-data eslint g++-10 giblib1 gyp handlebars javascript-common libauthen-sasl-perl libcbor0 libclone-perl libdata-dump-perl
        libdrm-amdgpu1 libdrm-common libdrm-nouveau2 libdrm-radeon1 libdrm2 libegl-mesa0 libegl1 libencode-locale-perl libevent-2.1-7
        libfile-basedir-perl libfile-desktopentry-perl libfile-listing-perl libfile-mimeinfo-perl libfont-afm-perl libgbm1 libgl1
        libgl1-mesa-dri libglapi-mesa libgles2 libglvnd0 libglx-mesa0 libglx0 libhtml-form-perl libhtml-format-perl libhtml-parser-perl
        libhtml-tagset-perl libhtml-tree-perl libhttp-cookies-perl libhttp-daemon-perl libhttp-date-perl libhttp-message-perl
        libhttp-negotiate-perl libicu67 libio-html-perl libio-socket-ssl-perl libio-stringy-perl libipc-system-simple-perl libjs-async
        libjs-events libjs-inherits libjs-is-typedarray libjs-prettify libjs-regenerate libjs-source-map libjs-sprintf-js
        libjs-typedarray-to-buffer libjs-util libjsoncpp24 libldap-2.4-2 libllvm15 liblua5.1-0 liblwp-mediatypes-perl
        liblwp-protocol-https-perl libmailtools-perl libmpdec3 libnet-dbus-perl libnet-http-perl libnet-smtp-ssl-perl libnet-ssleay-perl
        libnode-dev libnotify-bin libnotify4 libpcre16-3 libpcre2-posix2 libpcre3-dev libpcre32-3 libpcrecpp0v5 libperl5.32
        libpython3.9-minimal libpython3.9-stdlib libregexp-ipv6-perl libsensors-config libsensors5 libssl-dev libstdc++-10-dev libtevent0
        libtie-ixhash-perl libtiff5 libtimedate-perl libtry-tiny-perl liburi-perl libuv1-dev libwayland-client0 libwayland-server0 libwebp6
        libwww-perl libwww-robotrules-perl libx11-protocol-perl libxaw7 libxcb-dri2-0 libxcb-dri3-0 libxcb-glx0 libxcb-present0 libxcb-randr0
        libxcb-shape0 libxcb-sync1 libxcb-xfixes0 libxcursor1 libxi6 libxkbfile1 libxml-parser-perl libxml-twig-perl libxml-xpathengine-perl
        libxmu6 libxpm4 libxrandr2 libxshmfence1 libxtst6 libxv1 libxxf86dga1 libxxf86vm1 libz3-4 linux-image-5.10.0-21-arm64
        linux-image-5.10.0-23-arm64 linux-image-6.1.0-9-arm64 lua-bitop lua-cjson node-abbrev node-agent-base node-ajv node-ajv-keywords
        node-ampproject-remapping node-ansi-escapes node-ansi-regex node-ansi-styles node-anymatch node-aproba node-archy
        node-are-we-there-yet node-argparse node-arrify node-assert node-async node-async-each node-auto-bind
        node-babel-helper-define-polyfill-provider node-babel-plugin-add-module-exports node-babel-plugin-lodash
        node-babel-plugin-polyfill-corejs2 node-babel-plugin-polyfill-corejs3 node-babel-plugin-polyfill-regenerator node-babel7
        node-babel7-runtime node-balanced-match node-base node-base64-js node-binary-extensions node-brace-expansion node-braces
        node-browserslist node-builtins node-cacache node-cache-base node-camelcase node-caniuse-lite node-chalk node-chokidar node-chownr
        node-chrome-trace-event node-ci-info node-cli-boxes node-cli-cursor node-cli-table node-cli-truncate node-cliui node-clone
        node-clone-deep node-collection-visit node-color-convert node-color-name node-colors node-columnify node-commander node-commondir
        node-concat-stream node-console-control-strings node-convert-source-map node-copy-concurrently node-core-js node-core-js-compat
        node-core-js-pure node-core-util-is node-coveralls node-css-loader node-css-selector-tokenizer node-data-uri-to-buffer
        node-debbundle-es-to-primitive node-debug node-decamelize node-decompress-response node-deep-equal node-deep-is node-defaults
        node-define-properties node-define-property node-defined node-del node-delegates node-depd node-diff node-doctrine
        node-electron-to-chromium node-encoding node-end-of-stream node-enhanced-resolve node-err-code node-errno node-error-ex
        node-es-abstract node-es-module-lexer node-es6-error node-escape-string-regexp node-escodegen node-eslint-scope node-eslint-utils
        node-eslint-visitor-keys node-espree node-esprima node-esquery node-esrecurse node-estraverse node-esutils node-events node-fancy-log
        node-fast-deep-equal node-fast-levenshtein node-fetch node-file-entry-cache node-fill-range node-find-cache-dir node-find-up
        node-flat-cache node-flatted node-for-in node-for-own node-foreground-child node-fs-readdir-recursive node-fs-write-stream-atomic
        node-fs.realpath node-function-bind node-functional-red-black-tree node-gauge node-get-caller-file node-get-stream node-get-value
        node-glob node-glob-parent node-globals node-globby node-got node-graceful-fs node-growl node-gyp node-has-flag node-has-unicode
        node-has-value node-has-values node-hosted-git-info node-https-proxy-agent node-iconv-lite node-icss-utils node-ieee754 node-iferr
        node-ignore node-imurmurhash node-indent-string node-inflight node-inherits node-ini node-interpret node-ip node-ip-regex
        node-is-arrayish node-is-binary-path node-is-buffer node-is-descriptor node-is-extendable node-is-extglob node-is-glob node-is-number
        node-is-path-cwd node-is-path-inside node-is-plain-obj node-is-plain-object node-is-primitive node-is-stream node-is-typedarray
        node-is-windows node-isarray node-isexe node-isobject node-istanbul node-jest-debbundle node-jest-worker node-js-tokens node-js-yaml
        node-jsesc node-json-buffer node-json-parse-better-errors node-json-schema node-json-schema-traverse node-json-stable-stringify
        node-json5 node-jsonify node-jsonparse node-kind-of node-lcov-parse node-levn node-loader-runner node-locate-path node-lodash
        node-lodash-packages node-log-driver node-lowercase-keys node-lru-cache node-make-dir node-map-visit node-memfs node-memory-fs
        node-merge-stream node-micromatch node-mime node-mime-types node-mimic-response node-minimatch node-minimist node-minipass
        node-mixin-deep node-mkdirp node-move-concurrently node-ms node-mute-stream node-n3 node-negotiator node-neo-async node-nopt
        node-normalize-package-data node-normalize-path node-npm-bundled node-npm-package-arg node-npm-run-path node-npmlog node-object-assign
        node-object-inspect node-object-visit node-once node-opener node-optimist node-optionator node-osenv node-p-cancelable node-p-limit
        node-p-locate node-p-map node-parse-json node-pascalcase node-path-dirname node-path-exists node-path-is-absolute node-path-is-inside
        node-path-type node-picocolors node-pify node-pkg-dir node-postcss node-postcss-modules-extract-imports node-postcss-modules-values
        node-postcss-value-parser node-prelude-ls node-process-nextick-args node-progress node-promise-inflight node-promise-retry
        node-promzard node-prr node-pump node-punycode node-quick-lru node-randombytes node-read node-read-package-json node-read-pkg
        node-readable-stream node-readdirp node-rechoir node-regenerate node-regenerate-unicode-properties node-regenerator-runtime
        node-regenerator-transform node-regexpp node-regexpu-core node-regjsgen node-regjsparser node-repeat-string node-require-directory
        node-resolve node-resolve-cwd node-resolve-from node-restore-cursor node-resumer node-retry node-rimraf node-run-queue
        node-safe-buffer node-schema-utils node-sellside-emitter node-semver node-serialize-javascript node-set-blocking
        node-set-immediate-shim node-set-value node-shebang-command node-shebang-regex node-shell-quote node-signal-exit node-slash
        node-slice-ansi node-source-list-map node-source-map node-source-map-support node-spdx-correct node-spdx-exceptions
        node-spdx-expression-parse node-spdx-license-ids node-sprintf-js node-ssri node-stack-utils node-string-decoder node-string-width
        node-strip-ansi node-strip-bom node-strip-json-comments node-supports-color node-tap node-tap-mocha-reporter node-tap-parser
        node-tapable node-tape node-tar node-terser node-text-table node-through node-time-stamp node-to-fast-properties node-to-regex-range
        node-tslib node-type-check node-typedarray node-typedarray-to-buffer node-unicode-canonical-property-names-ecmascript
        node-unicode-match-property-ecmascript node-unicode-match-property-value-ecmascript node-unicode-property-aliases-ecmascript
        node-union-value node-unique-filename node-unset-value node-uri-js node-util node-util-deprecate node-uuid node-v8-compile-cache
        node-v8flags node-validate-npm-package-license node-validate-npm-package-name node-watchpack node-wcwidth.js node-webassemblyjs
        node-webpack-sources node-which node-wide-align node-widest-line node-wordwrap node-wrap-ansi node-wrappy node-write
        node-write-file-atomic node-ws node-y18n node-yallist node-yaml node-yargs node-yargs-parser perl-modules-5.32 perl-openssl-defaults
        pigz python3-pkg-resources python3-six python3.9 python3.9-minimal terser webpack x11-utils x11-xserver-utils x11proto-xext-dev
        xdg-utils zutty
      Use 'sudo apt autoremove' to remove them.
      0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
      Package nodejs is not available, but is referred to by another package.
      This may mean that the package is missing, has been obsoleted, or
      is only available from another source
      However the following packages replace it:
        nodejs-doc
      R
      raVsu
      @glasfaser
      iob stop
      iob fix
      iob start
      dann
      iob nodejs-update
      durchgeführt
      /home/iobroker/.nodejs-update.sh: line 130: npm: command not found
      /home/iobroker/.nodejs-update.sh: line 131: npx: command not found
      /home/iobroker/.nodejs-update.sh: line 147: npm: command not found
      /home/iobroker/.nodejs-update.sh: line 148: npx: command not found
      *** nodejs is NOT correctly installed ***
      nodejs:
        Version table:
           18.13.0+dfsg1-1 500
      Your nodejs-Installation seems to be faulty. Shall we try to fix it?
      Press <y> to continue or any other key to quit
      Fixing your nodejs setup
      *** Deleting  ***
      rm: cannot remove '': No such file or directory
      *** Deleting  ***
      Wrong paths have been fixed. Run 'iob diag' or 'iob nodejs-update' again to check if your installation is fine now
      You can now keep your whole system up-to-date using the usual 'sudo apt update && sudo apt full-upgrade' commands.
      Please DO NOT USE node version managers like 'nvm', 'n' and others in parallel. They will break your current installation!
      jetzt wird folgendes angezeigt:
      R
      raVsu
      pi@iobroker:~$ iob nodejs-update
      iobroker nodejs-update [<major-version>]
      Upgrade the Node.JS installation to the current LTS
      Options:
        --help  Show help  [boolean]
      R
      raVsu
      Hier nochmal die Zusammenfassung:
                              v.2023-10-10
       Static hostname: iobroker
             Icon name: computer
                Kernel: Linux 6.1.0-18-arm64
          Architecture: arm64
      Installation:           native
      Kernel:                 aarch64
      Userland:               arm64
      Timezone:               Europe/Berlin (CET, +0100)
      User-ID:                1000
      X-Server:               false
      Pending OS-Updates:     0
      Pending iob updates:    0
      Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                              /usr/bin/npm            9.2.0
                              /usr/bin/npx            9.2.0
      /home/iobroker/.diag.sh: line 490: corepack: command not found
      Recommended versions are nodejs 18.19.0 and npm 10.2.3
      Wrong installation path detected. This needs to be fixed
      Please check
      https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
      for more information on how to fix these errors.
      MEMORY:
      Mem:            4.0G        3.0G        280M        712K        848M        928M
      Swap:             0B          0B          0B
      Total:          4.0G        3.0G        280M
      Active iob-Instances:   26
      Active repo(s): stable
      ioBroker Core:          js-controller           5.0.17
                              admin                   6.13.16
      Objects type: jsonl
      States  type: redis
      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 192.168.178.64, run as: admin
      Objects:                3554
      States:                 2849
      Size of iob-Database:
      42M     /opt/iobroker/iobroker-data/objects.jsonl
      8.6M    /opt/iobroker/iobroker-data/objects.json.migrated
      8.6M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
      408K    /opt/iobroker/iobroker-data/states.json
      32K     /opt/iobroker/iobroker-data/states.json.bak
      R
      raVsu
      Skript v.2023-10-10
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : arm64
      Systemuptime and Load:
       13:13:27 up 10:12,  2 users,  load average: 0.93, 0.95, 0.90
      CPU threads: 4
      *** Time and Time Zones ***
                     Local time: Sun 2024-02-11 13:13:27 CET
                 Universal time: Sun 2024-02-11 12:13:27 UTC
                       RTC time: n/a
                    NTP service: n/a
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi sudo iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            4.0G        3.0G        437M        704K        676M        924M
      Swap:             0B          0B          0B
      Total:          4.0G        3.0G        437M
               3786 M total memory
               2904 M used memory
                293 M active memory
               2793 M inactive memory
                417 M free memory
                 87 M buffer memory
                557 M swap cache
                  0 M total swap
                  0 M used swap
                  0 M free swap
      *** FAILED SERVICES ***
        UNIT                                 LOAD   ACTIVE SUB    DESCRIPTION
      * systemd-networkd-wait-online.service loaded failed failed Wait for Network to be Configured
      1 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  1.9G     0  1.9G   0% /dev
      tmpfs          tmpfs     379M  696K  378M   1% /run
      /dev/sda2      ext4      118G   23G   90G  20% /
      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      /dev/sda1      vfat      396M  306M   90M  78% /boot/firmware
      tmpfs          tmpfs     379M     0  379M   0% /run/user/1000
      [Sun Feb 11 03:01:11 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
      [Sun Feb 11 03:01:14 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
      TARGET           SOURCE    FSTYPE OPTIONS
      /                /dev/sda2 ext4   rw,relatime
      `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
      /var:
      12G     /var/
      9.4G    /var/lib
      9.3G    /var/lib/influxdb/engine/data
      Archived and active journals take up 15.3M in the file system.
      /opt/iobroker/backups:
      282M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      2.2G    /opt/iobroker/iobroker-data/
      1.4G    /opt/iobroker/iobroker-data/history
      653M    /opt/iobroker/iobroker-data/files
      145M    /opt/iobroker/iobroker-data/files/vis-2
      116M    /opt/iobroker/iobroker-data/backup-objects
      41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
      24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
      24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
      USB-Devices by-id:
      find: '/dev/serial/by-id/': No such file or directory
      *** NodeJS-Installation ***
      /usr/bin/npm            9.2.0
      /usr/bin/npx            9.2.0
      /home/iobroker/.diag.sh: line 281: corepack: command not found
      nodejs:
        Candidate: 18.19.0+dfsg-6~deb12u1
        Version table:
           18.13.0+dfsg1-1 500
           14.21.3-deb-1nodesource1 500
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: redis
      Core adapters versions
      js-controller:  5.0.17
      admin:          6.13.16
      javascript:     7.1.6
      Adapters from github:   0
      Adapter State
      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
      + system.adapter.bring.0                  : bring                 : iobroker                                 -  enabled
      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
      + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
        system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
      + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
      + system.adapter.history.0                : history               : iobroker                                 -  enabled
        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
      + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
      + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
      + system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      + system.adapter.knx.0                    : knx                   : iobroker                                 -  enabled, bind: 192.168.178.64
      + system.adapter.knx.1                    : knx                   : iobroker                                 -  enabled, bind: 192.168.178.64
        system.adapter.material.0               : material              : iobroker                                 -  enabled
      + system.adapter.matrix-org.0             : matrix-org            : iobroker                                 -  enabled
        system.adapter.modbus.0                 : modbus                : iobroker                                 - disabled
      + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
      + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
      + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
      + system.adapter.senec.0                  : senec                 : iobroker                                 -  enabled
      + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        system.adapter.synology.0               : synology              : iobroker                                 - disabled, port: 5678
        system.adapter.telegram.0               : telegram              : iobroker                                 - disabled, port: 8443, bind: 0.0.0.0
      + system.adapter.terminal.0               : terminal              : iobroker                                 -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
        system.adapter.text2command.0           : text2command          : iobroker                                 - disabled
      + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
      + system.adapter.tradfri.0                : tradfri               : iobroker                                 -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
      + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
        system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker                                 -  enabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 -  enabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
      + instance is alive
      ioBroker-Repositories
      __            :
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.13.16  , installed 6.13.16
      Adapter    "backitup"     : 2.9.8    , installed 2.9.8
      Adapter    "bring"        : 1.8.4    , installed 1.8.4
      Adapter    "discovery"    : 4.2.0    , installed 4.2.0
      Adapter    "echarts"      : 1.7.2    , installed 1.7.2
      Adapter    "fakeroku"     : 0.2.2    , installed 0.2.2
      Adapter    "harmony"      : 1.3.0    , installed 1.3.0
      Adapter    "ical"         : 1.13.3   , installed 1.13.3
      Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
      Adapter    "iot"          : 2.0.11   , installed 2.0.11
      Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
      Adapter    "javascript"   : 7.1.6    , installed 7.1.6
      Controller "js-controller": 5.0.17   , installed 5.0.17
      Adapter    "knx"          : 2.0.24   , installed 2.0.24
      Adapter    "material"     : 1.3.1    , installed 1.3.1
      Adapter    "matrix-org"   : 1.0.0    , installed 1.0.0
      Adapter    "modbus"       : 6.1.0    , installed 6.1.0
      Adapter    "node-red"     : 5.1.0    , installed 5.1.0
      Adapter    "scenes"       : 2.3.9    , installed 2.3.9
      Adapter    "socketio"     : 6.6.0    , installed 6.6.0
      Adapter    "synology"     : 3.0.1    , installed 3.0.1
      Adapter    "telegram"     : 3.0.1    , installed 3.0.1
      Adapter    "terminal"     : 1.0.0    , installed 1.0.0
      Adapter    "text2command" : 3.0.3    , installed 3.0.3
      Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
      Adapter    "trashschedule": 2.3.0    , installed 2.3.0
      Adapter    "vis"          : 1.5.4    , installed 1.5.4
      Adapter    "vis-2"        : 2.9.11   , installed 2.9.11
      Adapter    "vis-hqwidgets": 1.4.0    , installed 1.4.0
      Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
      Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
      Adapter    "web"          : 6.2.3    , installed 6.2.3
      Adapter    "ws"           : 2.5.10   , installed 2.5.10
      Objects and States
      Objects:        3554
      States:         2849
      Fetched 4586 B in 1s (4359 B/s)
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          15724      1/init
      tcp        0      0 127.0.0.1:39611         0.0.0.0:*               LISTEN      998        18660      662/influxd
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16987      751/iobroker.js-con
      tcp        0      0 192.168.178.64:8082     0.0.0.0:*               LISTEN      1001       23670      1175/io.web.0
      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       19083      877/node-red
      tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      108        20986      576/redis-server 12
      tcp6       0      0 :::22                   :::*                    LISTEN      0          20904      1/init
      tcp6       0      0 :::111                  :::*                    LISTEN      0          14485      1/init
      tcp6       0      0 :::3000                 :::*                    LISTEN      109        18640      659/grafana-server
      tcp6       0      0 :::61991                :::*                    LISTEN      1001       21531      1032/io.harmony.0
      tcp6       0      0 :::8088                 :::*                    LISTEN      1001       19423      1107/io.terminal.0
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       21588      1088/io.simple-api.
      tcp6       0      0 :::8086                 :::*                    LISTEN      998        21112      662/influxd
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       18733      771/io.admin.0
      tcp6       0      0 ::1:6379                :::*                    LISTEN      108        20987      576/redis-server 12
      udp        0      0 192.168.178.64:49204    0.0.0.0:*                           1001       302103     1077/io.knx.0
      udp        0      0 192.168.178.64:57399    0.0.0.0:*                           1001       330977     1274/io.knx.1
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          19501      488/dhclient
      udp        0      0 192.168.178.64:51293    0.0.0.0:*                           1001       469823     1274/io.knx.1
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          14484      1/init
      udp        0      0 192.168.178.64:123      0.0.0.0:*                           0          19660      657/ntpd
      udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          19658      657/ntpd
      udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          19654      657/ntpd
      udp        0      0 192.168.178.64:57504    0.0.0.0:*                           1001       429548     1077/io.knx.0
      udp        0      0 192.168.178.64:49319    0.0.0.0:*                           1001       470534     1077/io.knx.0
      udp        0      0 192.168.178.64:51367    0.0.0.0:*                           1001       420774     1077/io.knx.0
      udp        0      0 192.168.178.64:53529    0.0.0.0:*                           1001       22704      1274/io.knx.1
      udp        0      0 192.168.178.64:45388    0.0.0.0:*                           1001       321213     1274/io.knx.1
      udp        0      0 0.0.0.0:35299           0.0.0.0:*                           1001       19091      877/node-red
      udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       21532      1032/io.harmony.0
      udp        0      0 192.168.178.64:55965    0.0.0.0:*                           1001       385583     1274/io.knx.1
      udp        0      0 192.168.178.64:49892    0.0.0.0:*                           1001       505627     1274/io.knx.1
      udp        0      0 192.168.178.64:45905    0.0.0.0:*                           1001       253074     1077/io.knx.0
      udp        0      0 192.168.178.64:50041    0.0.0.0:*                           1001       422743     1274/io.knx.1
      udp        0      0 192.168.178.64:48017    0.0.0.0:*                           1001       211583     1274/io.knx.1
      udp        0      0 192.168.178.64:37840    0.0.0.0:*                           1001       418223     1077/io.knx.0
      udp        0      0 192.168.178.64:39931    0.0.0.0:*                           1001       122879     1077/io.knx.0
      udp        0      0 192.168.178.64:54375    0.0.0.0:*                           1001       101212     1274/io.knx.1
      udp        0      0 192.168.178.64:44191    0.0.0.0:*                           1001       293347     1077/io.knx.0
      udp        0      0 192.168.178.64:52430    0.0.0.0:*                           1001       128594     1077/io.knx.0
      udp        0      0 192.168.178.64:5353     0.0.0.0:*                           1001       19984      933/io.tr-064.0
      udp        0      0 192.168.178.64:40188    0.0.0.0:*                           1001       156073     1274/io.knx.1
      udp        0      0 192.168.178.64:44358    0.0.0.0:*                           1001       127381     1077/io.knx.0
      udp        0      0 192.168.178.64:50523    0.0.0.0:*                           1001       77832      1274/io.knx.1
      udp        0      0 192.168.178.64:56678    0.0.0.0:*                           1001       233936     1274/io.knx.1
      udp        0      0 192.168.178.64:38283    0.0.0.0:*                           1001       508554     1274/io.knx.1
      udp        0      0 192.168.178.64:40366    0.0.0.0:*                           1001       312936     1077/io.knx.0
      udp        0      0 192.168.178.64:40379    0.0.0.0:*                           1001       477077     1077/io.knx.0
      udp        0      0 192.168.178.64:46531    0.0.0.0:*                           1001       22542      1077/io.knx.0
      udp        0      0 192.168.178.64:56815    0.0.0.0:*                           1001       161599     1077/io.knx.0
      udp        0      0 192.168.178.64:42485    0.0.0.0:*                           1001       155109     1077/io.knx.0
      udp        0      0 192.168.178.64:40468    0.0.0.0:*                           1001       113953     1077/io.knx.0
      udp        0      0 192.168.178.64:36410    0.0.0.0:*                           1001       459628     1274/io.knx.1
      udp        0      0 192.168.178.64:46655    0.0.0.0:*                           1001       282025     1274/io.knx.1
      udp        0      0 192.168.178.64:58975    0.0.0.0:*                           1001       217741     1274/io.knx.1
      udp        0      0 192.168.178.64:36545    0.0.0.0:*                           1001       196604     1274/io.knx.1
      udp        0      0 192.168.178.64:54978    0.0.0.0:*                           1001       46227      1077/io.knx.0
      udp        0      0 192.168.178.64:49036    0.0.0.0:*                           1001       396197     1274/io.knx.1
      udp        0      0 0.0.0.0:36773           0.0.0.0:*                           1001       22558      1118/io.tradfri.0
      udp        0      0 192.168.178.64:36840    0.0.0.0:*                           1001       501851     1274/io.knx.1
      udp        0      0 192.168.178.64:34820    0.0.0.0:*                           1001       360741     1077/io.knx.0
      udp        0      0 192.168.178.64:38926    0.0.0.0:*                           1001       155789     1274/io.knx.1
      udp6       0      0 :::111                  :::*                                0          15725      1/init
      udp6       0      0 fe80::dea6:32ff:fe3:123 :::*                                0          19666      657/ntpd
      udp6       0      0 2003:c5:171c:2200:d:123 :::*                                0          19664      657/ntpd
      udp6       0      0 ::1:123                 :::*                                0          19662      657/ntpd
      udp6       0      0 :::123                  :::*                                0          19651      657/ntpd
      2024-02-11 13:14:52.815  - info: knx.0 (1077) Change state from STATE_READY(7) to STATE_CONNECTION_STATE_REQUEST(5)
      2024-02-11 13:14:52.817  - info: knx.0 (1077) Received CONNECTIONSTATE_RESPONSE :    06 10 02 08 00 08 c6 00                                                              192.168.178.57:3671 ChID : 198 SeqCntIN : 75 SeqCntOUT : 0  msgCode : [object Object]
      2024-02-11 13:14:52.818  - info: knx.0 (1077) Change state from STATE_CONNECTION_STATE_REQUEST(5) to STATE_CONNECTION_STATE_RESPONSE(6)
      2024-02-11 13:14:52.818  - info: knx.0 (1077) Change state from STATE_CONNECTION_STATE_RESPONSE(6) to STATE_READY(7)
      2024-02-11 13:14:52.857  - info: knx.0 (1077) ( 3.2 ) Received TUNNEL_REQUEST (WRITE - send ACK )         :    06 10 04 20 00 17 04 c6 4c 00 29 00 bc e0 00 07 00 09 03 00 80 14 a6   ChID: 198
      2024-02-11 13:14:52.858  - info: knx.0 (1077) WRITE : mappedName : LichtWert Flur Einganfsbereich    dest : 0/0/9  val: 5286   (DPT7.013) LichtWert_Flur_Einganfsbereich
      2024-02-11 13:14:52.858  - info: knx.0 (1077) Change state from STATE_READY(7) to STATE_TUNNELLING_REQUEST(13)
      2024-02-11 13:14:52.859  - info: knx.0 (1077) Change state from STATE_TUNNELLING_REQUEST(13) to STATE_TUNNELLING_ACK(14)
      2024-02-11 13:14:52.859  - info: knx.0 (1077) =====> STATE_TUNNELING_ACK
      2024-02-11 13:14:52.860  - info: knx.0 (1077) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 c6 4c 00   ChID : 198 SeqCntIN : 76 SeqCntOUT : 0 queue length : 0
      2024-02-11 13:14:52.860  - info: knx.0 (1077) ( 4.b ) return to STATE_READY, processing : false
      2024-02-11 13:14:52.861  - info: knx.0 (1077) Change state from STATE_TUNNELLING_ACK(14) to STATE_READY(7)
      2024-02-11 13:14:54.862  - info: knx.0 (1077) Send : UDP Connection State Request :  06 10 02 07 00 10 c6 00 08 01 00 00 00 00 9d bb     sent from Port:  to 192.168.178.57:3671
      2024-02-11 13:14:54.863  - info: knx.0 (1077) Change state from STATE_READY(7) to STATE_CONNECTION_STATE_REQUEST(5)
      2024-02-11 13:14:54.865  - info: knx.0 (1077) Received CONNECTIONSTATE_RESPONSE :    06 10 02 08 00 08 c6 00                                                              192.168.178.57:3671 ChID : 198 SeqCntIN : 76 SeqCntOUT : 0  msgCode : [object Object]
      2024-02-11 13:14:54.866  - info: knx.0 (1077) Change state from STATE_CONNECTION_STATE_REQUEST(5) to STATE_CONNECTION_STATE_RESPONSE(6)
      2024-02-11 13:14:54.867  - info: knx.0 (1077) Change state from STATE_CONNECTION_STATE_RESPONSE(6) to STATE_READY(7)
      2024-02-11 13:14:55.295  - info: knx.0 (1077) ( 3.2 ) Received TUNNEL_REQUEST (WRITE - send ACK )         :    06 10 04 20 00 19 04 c6 4d 00 29 00 bc e0 00 01 04 0f 05 00 80 42 1c 00 00   ChID: 198
      2024-02-11 13:14:55.296  - info: knx.0 (1077) WRITE : mappedName : Leistung Gesmt Ptot    dest : 0/4/15  val: 39   (DPT14.056) Leistung_Gesmt_Ptot
      2024-02-11 13:14:55.297  - info: knx.0 (1077) Change state from STATE_READY(7) to STATE_TUNNELLING_REQUEST(13)
      2024-02-11 13:14:55.297  - info: knx.0 (1077) Change state from STATE_TUNNELLING_REQUEST(13) to STATE_TUNNELLING_ACK(14)
      2024-02-11 13:14:55.297  - info: knx.0 (1077) =====> STATE_TUNNELING_ACK
      2024-02-11 13:14:55.299  - info: knx.0 (1077) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 c6 4d 00   ChID : 198 SeqCntIN : 77 SeqCntOUT : 0 queue length : 0
      2024-02-11 13:14:55.299  - info: knx.0 (1077) ( 4.b ) return to STATE_READY, processing : false
      2024-02-11 13:14:55.299  - info: knx.0 (1077) Change state from STATE_TUNNELLING_ACK(14) to STATE_READY(7)
      R
      raVsu
      danke. Jetzt habe ich gesehen das nodejs nicht korrekt installiert ist.
      Wie kann ich das korrigieren?
      /usr/bin/npm            9.2.0
      /usr/bin/npx            9.2.0
      nodejs:
        Version table:
           18.13.0+dfsg1-1 500
      Ja, den Befehl habe ich ausgeführt
      R
      raVsu
      @meister-mopper
      danke. Auch in der Konsole stehen die gleichen Versionsnummern:
      R
      raVsu
