    2. kobe67
    K
    • Posts 8
    kobe67
    @kobe67
    kobe67 Follow
    Latest posts made by kobe67
    • RE: Host entfernen/umbenennen - iobroker
      @homoran said in Host entfernen/umbenennen - iobroker:
      @kobe67 sagte in Host entfernen/umbenennen - iobroker:
      Das ergibt bei mir folgendes
      dann versuch es anders herum: iobroker host iob-pi4 this
      Hatte leider das gleiche Ergebnis
      pi@iobroker-pi3:/opt/iobroker/log $ iobroker host iob-pi4 this
      A host with the name "iobroker-pi3" already exists!
      Mir ist nicht ganz klar wie der eigentliche Betriebsystem-Hostname eine Rolle in dem ganzen spielt.
      Ich habe jetzt den Hostnamen des PI im OS nochmal umgestellt auf PI4 (also etwas wo es noch keine iobroker host gibt)
      Dann habe ich ausgeführt
      pi@pi4:~ $ iobroker host iobroker-pi3
      Host "iobroker-pi3" successfully renamed to "pi4".
      The host for instance "system.adapter.admin.0" was changed from "iobroker-pi3" to "pi4".
      The host for instance "system.adapter.backitup.0" was changed from "iobroker-pi3" to "pi4".
      The host for instance "system.adapter.web.0" was changed from "iobroker-pi3" to "pi4".
      The host for instance "system.adapter.vis.0" was changed from "iobroker-pi3" to "pi4".
      The host for instance "system.adapter.sonoff.0" was changed from "iobroker-pi3" to "pi4".
      The host for instance "system.adapter.javascript.0" was changed from "iobroker-pi3" to "pi4".
      The host for instance "system.adapter.icons-icons8.0" was changed from "iobroker-pi3" to "pi4".
      The host for instance "system.adapter.icons-fatcow-hosting.0" was changed from "iobroker-pi3" to "pi4".
      The host for instance "system.adapter.icons-open-icon-library-png.0" was changed from "iobroker-pi3" to "pi4".
      The host for instance "system.adapter.icons-material-png.0" was changed from "iobroker-pi3" to "pi4".
      The host for instance "system.adapter.vis-colorpicker.0" was changed from "iobroker-pi3" to "pi4".
      The host for instance "system.adapter.vis-hqwidgets.0" was changed from "iobroker-pi3" to "pi4".
      The host for instance "system.adapter.vis-jqui-mfd.0" was changed from "iobroker-pi3" to "pi4".
      The host for instance "system.adapter.vis-justgage.0" was changed from "iobroker-pi3" to "pi4".
      The host for instance "system.adapter.vis-metro.0" was changed from "iobroker-pi3" to "pi4".
      The host for instance "system.adapter.iot.0" was changed from "iobroker-pi3" to "pi4".
      The host for instance "system.adapter.zigbee.0" was changed from "iobroker-pi3" to "pi4".
      The host for instance "system.adapter.vis-map.0" was changed from "iobroker-pi3" to "pi4".
      Siehe da, läuft wieder.
      Hab jetzt eine "orphan" iobroker host in der Admin Oberfläche iob-pi4 Der sollte sich aber entfernen lassen.
      Und alles nur weil ich mich an pi3 gestört habe durch den Umzug vom PI3 auf einen PI4.
      Danke @homoran für Deine Hilfe !!!
      Bernd
      K
      kobe67
      früher wurde da eine Liste der verfügbaren Hosts gezeigt, wo man einen auswählen konnte.
      Das musst du ja auch, da ioBroker sonst nicht weiß welchen Host du umbenennen willst
      Wie da im Moment der "richtige" Weg ist weiß ich auswendig nicht
      Möglicherweise iobroker host iobroker-pi3 this
      pi@iobroker-pi3:/opt/iobroker/log $ iobroker host iobroker-pi3 this
      wenn ich dann starte zeigt er im Logfile
      2022-03-10 15:14:00.457  - info: host.iob-pi4 iobroker.js-controller version 4.0.15 js-controller starting
      2022-03-10 15:14:00.463  - info: host.iob-pi4 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
      2022-03-10 15:14:00.464  - info: host.iob-pi4 hostname: iob-pi4, node: v14.19.0
      2022-03-10 15:14:00.464  - info: host.iob-pi4 ip addresses: 192.168.178.140 2003:c6:ef06:fc00:79e5:25c3:1af7:5119 fe80::5f59:b880:410c:a030
      2022-03-10 15:14:01.589  - info: host.iob-pi4 connected to Objects and States
      2022-03-10 15:14:01.620  - info: host.iob-pi4 added notifications configuration of host
      2022-03-10 15:14:01.831  - info: host.iob-pi4 Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      2022-03-10 15:14:01.901  - info: host.iob-pi4 33 instances found
      2022-03-10 15:14:01.912  - warn: host.iob-pi4 does not start any instances on this host
      Es ist immer noch der iob-pi4 (neuer Name) auf dem er starten will. Der hat natürlich keine Adapter assigned.
      K
      kobe67
      @homoran Bei mir offensichtlich nicht. @thomas-braun, hab ich versucht.... erfolglos
      pi@iobroker-pi3:/opt/iobroker/log $ iobroker host this
      Cannot use this command in multihost!
      iobroker host this
      Initialize current host
      Options:
        --help  Show help  [boolean]
      K
      kobe67
    • Host entfernen/umbenennen - iobroker
      Hallo, ich hab einen Multihost iobroker aufgesetzt. Jetzt wollte ich auf dem Master den Hostnamen (via Admin-Oberfläche) ändern. Danach starten die Adapter nicht mehr. Wie kann ich die Adapter auf den "neuen" host assignen ?
      Ich hab auch versucht es wieder über Kommandozeilen rückgängig zu machen. Befehle wie iobroker host set <alter name>
      iobroker list hosts ergibt bei mir folgendes. Wobie iob-pi4 der neue Name ist, iobroker-pi3 der alte. Es wäre für mich ok wenn alles einfach wieder unter iobroker-pi3 läuft.
      iobroker list hosts
      iob-pi4             iob-pi4 (version: 4.0.15, hostname: iob-pi4       ,  dead, uptime: 64)
      iobroker-pi3        iobroker-pi3 (version: 4.0.15, hostname: iobroker-pi3  ,  dead, uptime: 9302)
      rock64              rock64 (version: 4.0.15, hostname: rock64        , alive, uptime: 80)
      Entfernen geht auch nicht
      iobroker host remove iob-pi4
      Cannot remove host "iob-pi4" from itself!
      Danke für jegliche Hilfe
      Bernd
      K
      kobe67
    • RE: RFID-Reader Fehler PN532: Read error:
      Jetzt funktioniert es mit OpenHab-MQTT !!
      Vielen herzlichen Dank !
      K
      kobe67
      siehe Anhänge
      K
      kobe67
    • RE: [Vorlage] IoBroker Funktionen steuern durch RFID
      ich hab das jetzt auch mal nachgebaut, ich sehe allerdings im MQTT Adapter nur den Datenpunkt out unter mqtt.0.domoticz. Es fehlt der Datenpunkt in.
      Zusätzlich sehe ich im ESP Easy Log Fehlermeldungen : PN532: Read error: nnn
      Kennt das jemand ? Hab ich etwas falsch verkabelt. Kann die Node MCU defekt sein ?
      Auf dem Reader ist der Modus I2C eingestellt (Schalter 1 oben, Schalter 2 unten)
      Danke für eure Hilfe
      K
      kobe67
      Hallo, konntest du das Problem lösen. Ich hab den gleichen Fehler
      K
      kobe67
