    2. xT1GeRx
    X
    • Posts 15
    xT1GeRx
    @xT1GeRx
    15
    xT1GeRx Follow
    Best posts made by xT1GeRx
    • RE: Backup wiederherstellen auf js-controller 4.0
      @thomas-braun Hat alles geklappt. Js auf 7 und node v20. Alle Updates ohne Fehlermeldung. Komme überall drauf und alles ist vorhanden wie davor.
      VIELEN VIELEN DANK für deine Hilfe und Zeit @thomas-braun 🎉
      X
      xT1GeRx
    Latest posts made by xT1GeRx
      @thomas-braun ist mir nicht aufgefallen. Danke. Erledigt.
      admin@iobroker:~ $ sudo apt update
      Hit:1 http://deb.debian.org/debian bookworm InRelease
      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists... Done
      Building dependency tree... Done
      All packages are up to date.
      X
      xT1GeRx
      ```bash
      Script v.2025-03-08
      *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer
                Kernel: Linux 6.12.25+rpt-rpi-v8
          Architecture: arm64
      OS is similar to:
      Model           : Raspberry Pi 4 Model B Rev 1.2
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 64 bit
      Systemuptime and Load:
       20:21:41 up  1:02,  1 user,  load average: 0.22, 0.21, 0.20
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'bookworm'!
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** TIME AND TIMEZONES ***
                     Local time: Mon 2025-06-09 20:21:42 CEST
                 Universal time: Mon 2025-06-09 18:21:42 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      admin
      HOME=/home/admin
      GROUPS=admin adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            4.0G        1.4G        1.0G        6.2M        1.7G        2.6G
      Swap:           536M          0B        536M
      Total:          4.5G        1.4G        1.5G
      Active iob-Instances:   15
               3797 M total memory
               1357 M used memory
               1340 M active memory
               1294 M inactive memory
                958 M free memory
                 72 M buffer memory
               1501 M swap cache
                511 M total swap
                  0 M used swap
                511 M free swap
      top - 20:21:42 up  1:02,  1 user,  load average: 0.22, 0.21, 0.20
      Tasks: 179 total,   1 running, 178 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 16.7 us, 16.7 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   3797.4 total,    956.8 free,   1359.0 used,   1574.6 buff/cache
      MiB Swap:    512.0 total,    512.0 free,      0.0 used.   2438.4 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      udev           devtmpfs  1.6G     0  1.6G   0% /dev
      tmpfs          tmpfs     380M  5.9M  374M   2% /run
      /dev/mmcblk0p2 ext4      117G  4.2G  107G   4% /
      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
      tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
      /dev/mmcblk0p1 vfat      510M   56M  455M  11% /boot/firmware
      tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
      [Mon Jun  9 19:19:06 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave snd_bcm2835.enable_h                                     eadphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 smsc95xx.macaddr=DC:A6:32:B9:D2:87 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size                                     =0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=ed3ceec2-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Mon Jun  9 19:19:07 2025] EXT4-fs (mmcblk0p2): mounted filesystem d4cc7d63-da78-48ad-9bdd-64ffbba449a8 ro with ordered data mode. Quota mode: none.
      [Mon Jun  9 19:19:08 2025] EXT4-fs (mmcblk0p2): re-mounted d4cc7d63-da78-48ad-9bdd-64ffbba449a8 r/w. Quota mode: none.
      Show mounted filesystems:
      TARGET           SOURCE         FSTYPE OPTIONS
      /                /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      890M    /var/
      214M    /var/cache
      208M    /var/cache/apt
      164M    /var/lib
      135M    /var/lib/apt/lists
      Archived and active journals take up 4.7M in the file system.
      /opt/iobroker/backups:
      11M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      235M    /opt/iobroker/iobroker-data/
      194M    /opt/iobroker/iobroker-data/files
      47M     /opt/iobroker/iobroker-data/files/admin.admin
      46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
      32M     /opt/iobroker/iobroker-data/objects.jsonl
      27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
      9.2M    /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js
      8.9M    /opt/iobroker/iobroker-data/states.jsonl
      8.1M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BFvcOIQE.js
      USB-Devices by-id:
      /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CDD3476-if00
      *** ZigBee Settings ***
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.19.2
      /usr/bin/node           v20.19.2
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.31.0
      nodejs:
        Installed: 20.19.2-1nodesource1
        Candidate: 20.19.2-1nodesource1
        Version table:
       *** 20.19.2-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
              100 /var/lib/dpkg/status
           20.19.1-1nodesource1 1001
           20.19.0-1nodesource1 1001
           20.18.3-1nodesource1 1001
           20.18.2-1nodesource1 1001
           20.18.1-1nodesource1 1001
           20.18.0-1nodesource1 1001
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
              500 http://deb.debian.org/debian bookworm/main arm64 Packages
           18.19.0+dfsg-6~deb12u1 500
              500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 3429)
      Core adapters versions
      js-controller:  7.0.6
      admin:          7.6.17
      javascript:     8.9.2
      nodejs modules from github:     0
      Adapter State
      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
        system.adapter.birthdays.0              : birthdays             : iobroker                                 -  enabled
        system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
        system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
      + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
      + system.adapter.hmip.0                   : hmip                  : iobroker                                 -  enabled
      + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 443
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
      + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
      + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
      + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled
      + instance is alive
      + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 400
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: stable
      Adapter    "admin"        : 7.6.17   , installed 7.6.17
      Adapter    "backitup"     : 3.2.2    , installed 3.2.2
      Adapter    "birthdays"    : 4.0.0    , installed 4.0.0
      Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
      Adapter    "fullybrowser" : 3.1.1    , installed 3.1.1
      Adapter    "hmip"         : 1.27.0   , installed 1.27.0
      Adapter    "hue"          : 3.16.1   , installed 3.16.1
      Adapter    "javascript"   : 8.9.2    , installed 8.9.2
      Controller "js-controller": 7.0.6    , installed 7.0.6
      Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
      Adapter    "pushover"     : 4.1.0    , installed 4.1.0
      Adapter    "rpi2"         : 2.4.0    , installed 2.4.0
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
      Adapter    "vis-icontwo"  : 1.11.0   , installed 1.11.0
      Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
      Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
      Adapter    "web"          : 7.0.8    , installed 7.0.8
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Adapter    "zigbee"       : 2.0.5    , installed 2.0.5
      Objects and States
      Objects:        8929
      States:         8070
      Pending Updates: 1
      Danke nochmals. Ich werde es jetzt nicht mehr schleifen lassen mit den Updates.
      X
      xT1GeRx
      X
      xT1GeRx
      @thomas-braun alles war rauskam
      ```bash
      Script v.2025-03-08
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      OS is similar to:
      Docker          : false
      Kernel          : aarch64
      Userland        : 64 bit
       19:01:35 up  2:30,  1 user,  load average: 0.37, 0.08, 0.03
      CPU threads: 4
      Current issues:
                     Local time: Mon 2025-06-09 19:01:35 CEST
                 Universal time: Mon 2025-06-09 17:01:35 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      admin
      HOME=/home/admin
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            4.0G        385M        1.8G        6.2M        1.9G        3.6G
      Swap:           536M          0B        536M
      Total:          4.5G        385M        2.3G
      Active iob-Instances:   2
               3791 M total memory
                367 M used memory
                406 M active memory
               1464 M inactive memory
               1712 M free memory
                 99 M buffer memory
               1693 M swap cache
                511 M total swap
                  0 M used swap
                511 M free swap
      top - 19:01:36 up  2:30,  1 user,  load average: 0.37, 0.08, 0.03
      Tasks: 165 total,   1 running, 164 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us, 25.0 sy,  0.0 ni, 75.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   3791.4 total,   1712.3 free,    367.5 used,   1793.1 buff/cache
      MiB Swap:    512.0 total,    512.0 free,      0.0 used.   3423.9 avail Mem
      *** FILESYSTEM ***
      /dev/mmcblk0p2 ext4      117G  4.1G  107G   4% /
      [Mon Jun  9 16:30:57 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave snd_bcm28        35.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:B9:D2:87 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  c        onsole=ttyS0,115200 console=tty1 root=PARTUUID=ed3ceec2-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Mon Jun  9 16:30:58 2025] EXT4-fs (mmcblk0p2): mounted filesystem d4cc7d63-da78-48ad-9bdd-64ffbba449a8 ro with ordered data mode. Quota mode: none.
      [Mon Jun  9 16:31:00 2025] EXT4-fs (mmcblk0p2): re-mounted d4cc7d63-da78-48ad-9bdd-64ffbba449a8 r/w. Quota mode: none.
      /var:
      889M    /var/
      213M    /var/cache
      208M    /var/cache/apt
      164M    /var/lib
      198M    /opt/iobroker/iobroker-data/
      169M    /opt/iobroker/iobroker-data/files
      48M     /opt/iobroker/iobroker-data/files/javascript.admin
      26M     /opt/iobroker/iobroker-data/objects.jsonl
      12M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js/790.1eb1f33b.chunk.js.map
      6.2M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/790.1eb1f33b.chunk.js
      4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
      USB-Devices by-id:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      iobroker            iobroker (version: 4.0.23, hostname: iobroker      , alive, uptime: 2058)
      js-controller:  4.0.23
      admin:          6.3.5
      javascript:     6.0.3
      Adapter State
        system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.birthdays.0              : birthdays             : iobroker                                 - disabled
        system.adapter.daswetter.0              : daswetter             : iobroker                                 - disabled
        system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
        system.adapter.dwd.0                    : dwd                   : iobroker                                 - disabled
        system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 - disabled
        system.adapter.hmip.0                   : hmip                  : iobroker                                 - disabled
        system.adapter.hue.0                    : hue                   : iobroker                                 - disabled, port: 443
        system.adapter.javascript.0             : javascript            : iobroker                                 - disabled
        system.adapter.pollenflug.0             : pollenflug            : iobroker                                 - disabled
        system.adapter.pushover.0               : pushover              : iobroker                                 - disabled
        system.adapter.rpi2.0                   : rpi2                  : iobroker                                 - disabled
        system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 - disabled
        system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 - disabled
        system.adapter.vis.0                    : vis                   : iobroker                                 - disabled
        system.adapter.web.0                    : web                   : iobroker                                 - disabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.zigbee.0                 : zigbee                : iobroker                                 - disabled
      + instance is alive
      Adapter    "admin"        : 7.6.17   , installed 6.3.5  [Updatable]
      Adapter    "backitup"     : 3.2.2    , installed 2.5.12 [Updatable]
      Adapter    "birthdays"    : 4.0.0    , installed 2.2.0  [Updatable]
      Adapter    "daswetter"    : 3.2.3    , installed 3.1.7  [Updatable]
      Adapter    "discovery"    : 5.0.0    , installed 3.1.0  [Updatable]
      Adapter    "dwd"          : 2.8.5    , installed 2.8.3  [Updatable]
      Adapter    "fullybrowser" : 3.1.1    , installed 2.1.2  [Updatable]
      Adapter    "hmip"         : 1.27.0   , installed 1.20.0 [Updatable]
      Adapter    "hue"          : 3.16.1   , installed 3.7.1  [Updatable]
      Adapter    "javascript"   : 8.9.2    , installed 6.0.3  [Updatable]
      Controller "js-controller": 7.0.6    , installed 4.0.23 [Updatable]
      Adapter    "pollenflug"   : 2.0.0    , installed 1.0.6  [Updatable]
      Adapter    "pushover"     : 4.1.0    , installed 3.0.3  [Updatable]
      Adapter    "rpi2"         : 2.4.0    , installed 1.3.2  [Updatable]
      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
      Adapter    "socketio"     : 6.7.1    , installed 4.2.0  [Updatable]
      Adapter    "tankerkoenig" : 3.4.0    , installed 2.1.1  [Updatable]
      Adapter    "vis"          : 1.5.6    , installed 1.4.16 [Updatable]
      Adapter    "vis-hqwidgets": 1.5.1    , installed 1.3.0  [Updatable]
      Adapter    "vis-icontwo"  : 1.11.0   , installed 0.90.0 [Updatable]
      Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.1  [Updatable]
      Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.0.12 [Updatable]
      Adapter    "web"          : 7.0.8    , installed 4.3.0  [Updatable]
      Adapter    "ws"           : 2.6.2    , installed 1.3.0  [Updatable]
      Adapter    "zigbee"       : 2.0.5    , installed 1.8.10 [Updatable]
      Objects and States
      Objects:        8811
      States:         7998
      Pending Updates: 48
      2025-06-09 18:27:17.755  - info: host.iobroker hostname: iobroker, node: v20.19.2
      2025-06-09 18:27:17.757  - info: host.iobroker ip addresses: 192.168.178.37 2003:d0:6700:2e00:d638:5401:7be0:ba73 fe80::76d4:1422:ca5b:b545
      2025-06-09 18:27:19.448  - info: host.iobroker connected to Objects and States
      2025-06-09 18:27:19.500  - info: host.iobroker added notifications configuration of host
      2025-06-09 18:27:20.179  - info: host.iobroker Delete state "system.host.iobroker.versions.nodeCurrent"
      2025-06-09 18:27:20.181  - info: host.iobroker 22 instances found
      2025-06-09 18:27:20.218  - info: host.iobroker starting 2 instances
      2025-06-09 18:27:20.313  - info: host.iobroker Delete state "system.host.iobroker.versions.nodeNewest"
      2025-06-09 18:27:20.328  - info: host.iobroker instance system.adapter.admin.0 started with pid 4479
      2025-06-09 18:27:20.340  - info: host.iobroker Some obsolete host states deleted.
      2025-06-09 18:27:22.763  - info: admin.0 (4479) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v20.19.2, js-controller: 4.0.23
      2025-06-09 18:27:22.809  - info: admin.0 (4479) requesting all states
      2025-06-09 18:27:22.810  - info: admin.0 (4479) requesting all objects
      2025-06-09 18:27:24.173  - info: admin.0 (4479) received all objects
      2025-06-09 18:27:24.286  - info: host.iobroker instance system.adapter.backitup.0 started with pid 4506
      2025-06-09 18:27:24.227  - error: admin.0 (4479) Cannot create web-server: TypeError: Cannot read properties of undefined (reading 'createServerAsync')
      2025-06-09 18:27:24.230  - info: admin.0 (4479) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-06-09 18:27:24.501  - info: admin.0 (4479) Request actual repository...
      2025-06-09 18:27:24.778  - warn: admin.0 (4479) Cannot check node.js/npm version
      2025-06-09 18:27:25.039  - info: admin.0 (4479) terminating http server on port 8081
      2025-06-09 18:27:25.449  - info: host.iobroker Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
      2025-06-09 18:27:25.514  - error: host.iobroker instance system.adapter.admin.0 terminated by request of the instance itself and will not be restarted, before user res        tarts it.
      2025-06-09 18:27:25.514  - info: host.iobroker Do not restart adapter system.adapter.admin.0 because desired by instance
      2025-06-09 18:27:26.456  - info: backitup.0 (4506) starting. Version 2.5.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.19.2, js-controller: 4.0.23
      2025-06-09 18:27:26.557  - info: backitup.0 (4506) [iobroker] backup was activated at 02:30 every 1 day(s)
      iob diag has finished.
      X
      xT1GeRx
      @thomas-braun ich würde sagen das das backup geladen ist. Verstehe ich das richtig, dass ich zuerst alles updaten soll bevor der Webzugang wieder geht? Wenn ja, hättest du mir eine sichere anleitung, bevor ich wieder was versaue?
      X
      xT1GeRx
      @Thomas-Braun
      aktuell die letzten. Kann auch die komplette Liste einfügen?
      2025-06-09 18:27:25.514  - error: host.iobroker instance system.adapter.admin.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
      X
      xT1GeRx
      @homoran ich habe mal die warnings rausgesucht. Die Liste ist aktuell über 1000 Zeilen Lang.
      2025-06-09 17:56:41.710  - error: admin.0 (2990) Cannot create web-server: TypeError: Cannot read properties of undefined (reading 'createServerAsync')
      2025-06-09 17:56:42.746  - error: host.iobroker instance system.adapter.admin.0 terminated by request of the instance itself and will not be restarted, before user resarts it.
      2025-06-09 17:57:31.161  - warn: host.iobroker startInstance cannot find adapter "javascript@6.0.3". Try to install it... 1 attempt
      2025-06-09 18:00:28.860  - error: admin.0 (3429) Cannot create web-server: TypeError: Cannot read properties of undefined (reading 'createServerAsync')
      2025-06-09 18:00:29.853  - error: host.iobroker instance system.adapter.admin.0 terminated by request of the instance itself and will not be restarted, before user rest        arts it.
      2025-06-09 18:11:13.453  - error: admin.0 (4020) Cannot create web-server: TypeError: Cannot read properties of undefined (reading 'createServerAsync')
      2025-06-09 18:11:13.455  - info: admin.0 (4020) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-06-09 18:11:13.768  - info: admin.0 (4020) Request actual repository...
      2025-06-09 18:11:14.024  - warn: admin.0 (4020) Cannot check node.js/npm version
      2025-06-09 18:11:14.048  - info: admin.0 (4020) terminating http server on port 8081
      2025-06-09 18:11:14.533  - error: host.iobroker instance system.adapter.admin.0 terminated by request of the instance itself and will not be restarted, before user rest        arts it.
      2025-06-09 18:27:25.514  - error: host.iobroker instance system.adapter.admin.0 terminated by request of the instance itself and will not be restarted, before user rest        arts it.
      Wie es aussieht gibt es ein Problem mit dem Admin Web Zugang oder?
      X
      xT1GeRx
      Alles klar. Ich warte dann mal bis 20 Uhr ab und melde mich dann nochmals. Vielen Dank @Thomas-Braun
      Danke auch @Homoran
      X
      xT1GeRx
      @Thomas-Braun
      Es hat mal soweit alles funktioniert. Ich komme jedoch nicht auf die ioBroker Seite. Weder mit dem Port 8081 noch mit 8082. Habe mal einen check gemacht und das kam raus. Ein paar Instanzen fehlen, ist jedoch nicht so wild.
      admin@iobroker:~ $ iobroker status
      Objects type: jsonl
      States  type: jsonl
      admin@iobroker:~ $ iobroker list instances
        system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bi                        nd: 0.0.0.0, run as: admin
        system.adapter.web.0                    : web                   : iobroker                                 - disabled, port: 8082, bi                        nd: 0.0.0.0, run as: admin
      + instance is alive
      X
      xT1GeRx
      @Thomas-Braun
      admin@iobroker:~ $ iobroker restore iobroker_2025_06_07-23_23_27_backupiobroker
      host.iobroker Restore legacy backup.
      The current version of js-controller differs from the version in the backup.
      The js-controller version of the backup can not be restored automatically.
      To restore the js-controller version of the backup, execute "npm i iobroker.js-controller@4.0.23 --omit=dev" insid                     e your ioBroker directory
      If you really want to restore the backup with the current installed js-controller, execute the restore command wit                     h the --force flag
      X
      xT1GeRx
