@meister-mopper habe ich gemacht; sieht wie folgt aus:
zigbee.0
2023-12-10 20:36:39.413 warn Terminated (UNCAUGHT_EXCEPTION): Without reason
zigbee.0
2023-12-10 20:36:39.412 debug Plugin sentry destroyed
zigbee.0
2023-12-10 20:36:39.409 info terminating
zigbee.0
2023-12-10 20:36:39.408 warn Failed to stop zigbee during startup
zigbee.0
2023-12-10 20:36:39.168 info Zigbee: disabling joining new devices.
zigbee.0
2023-12-10 20:36:39.155 info cleaned everything up...
zigbee.0
2023-12-10 20:36:39.115 error Reset error: Error: {"sequence":-1} after 10000ms
zigbee.0
2023-12-10 20:36:39.114 error Error: Reset error: Error: {"sequence":-1} after 10000ms at /opt/iobroker/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/uart.ts:299:23 at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32)
zigbee.0
2023-12-10 20:36:39.003 error unhandled promise rejection: Reset error: Error: {"sequence":-1} after 10000ms
zigbee.0
2023-12-10 20:36:39.001 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
zigbee.0
2023-12-10 20:36:29.005 debug Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2023_12_10-19_36_27.tar.gz success
zigbee.0
2023-12-10 20:36:28.188 info Installed Version: iobroker.zigbee@1.8.24
zigbee.0
2023-12-10 20:36:27.678 debug Starting zigbee-herdsman...
zigbee.0
2023-12-10 20:36:27.612 info Starting Zigbee npm ...
zigbee.0
2023-12-10 20:36:27.608 info delete old Backup files. keep only last 10
zigbee.0
2023-12-10 20:36:27.470 debug Using zigbee-herdsman with settings: {"network":{"panID":6754,"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13],"extenedPanID":[197,41,47,42,0,75,18,0]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_30e9aa87ca45ed1185dd97a40a86e0b4-if00-port0","adapter":"ezsp"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false}}
zigbee.0
2023-12-10 20:36:27.418 info starting. Version 1.8.24 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.16
zigbee.0
2023-12-10 20:36:26.509 debug Plugin sentry Initialize Plugin (enabled=true)
zigbee.0
2023-12-10 19:35:48.692 info terminating
zigbee.0
2023-12-10 19:35:48.103 warn Terminated (UNCAUGHT_EXCEPTION): Without reason
zigbee.0
2023-12-10 19:35:48.102 debug Plugin sentry destroyed
zigbee.0
2023-12-10 19:35:48.100 info terminating
zigbee.0
2023-12-10 19:35:48.098 warn Failed to stop zigbee during startup
zigbee.0
2023-12-10 19:35:47.678 info Zigbee: disabling joining new devices.
zigbee.0
2023-12-10 19:35:47.665 info cleaned everything up...
zigbee.0
2023-12-10 19:35:47.627 error Reset error: Error: {"sequence":-1} after 10000ms
zigbee.0
2023-12-10 19:35:47.626 error Error: Reset error: Error: {"sequence":-1} after 10000ms at /opt/iobroker/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/uart.ts:299:23 at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32)
zigbee.0
2023-12-10 19:35:47.514 error unhandled promise rejection: Reset error: Error: {"sequence":-1} after 10000ms
zigbee.0
2023-12-10 19:35:47.513 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
zigbee.0
2023-12-10 19:35:37.514 debug Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2023_12_10-19_35_35.tar.gz success
zigbee.0
2023-12-10 19:35:36.608 info Installed Version: iobroker.zigbee@1.8.24
zigbee.0
2023-12-10 19:35:36.052 debug Starting zigbee-herdsman...
zigbee.0
2023-12-10 19:35:35.975 info Starting Zigbee npm ...
zigbee.0
2023-12-10 19:35:35.972 info delete old Backup files. keep only last 10
zigbee.0
2023-12-10 19:35:35.828 debug Using zigbee-herdsman with settings: {"network":{"panID":6754,"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13],"extenedPanID":[197,41,47,42,0,75,18,0]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_30e9aa87ca45ed1185dd97a40a86e0b4-if00-port0","adapter":"ezsp"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false}}
zigbee.0
2023-12-10 19:35:35.780 info starting. Version 1.8.24 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.16
zigbee.0
2023-12-10 19:35:34.901 debug Plugin sentry Initialize Plugin (enabled=true)
zigbee.0
2023-12-10 19:35:34.833 debug States connected to redis: 127.0.0.1:9000
zigbee.0
2023-12-10 19:35:34.769 debug States create User PubSub Client
zigbee.0
2023-12-10 19:35:34.766 debug States create System PubSub Client
zigbee.0
2023-12-10 19:35:34.750 debug Redis States: Use Redis connection: 127.0.0.1:9000
zigbee.0
2023-12-10 19:35:34.707 debug Objects connected to redis: 127.0.0.1:9001
zigbee.0
2023-12-10 19:35:34.690 debug Objects client initialize lua scripts
zigbee.0
2023-12-10 19:35:34.651 debug Objects create User PubSub Client
zigbee.0
2023-12-10 19:35:34.648 debug Objects create System PubSub Client
zigbee.0
2023-12-10 19:35:34.644 debug Objects client ready ... initialize now
zigbee.0
2023-12-10 19:35:34.580 debug Redis Objects: Use Redis connection: 127.0.0.1:9001
