Oh wie peinlich und doof von mir.Sorry
Latest posts made by Sebi_7_6
    RE: [HowTo] ioBroker Restore unter Linux durchführenposted in ioBroker Allgemein
Hab jetzt VIS & HabPanel als Instanz und Objekt entfernt und auch die Reste in den Ordnern files und node_modules gelöscht. Habe dann VIS neu installiert.
und wieder...
Click ich drauf.
URIError: Failed to decode param '%web_protocol%://%web_bind%:%web_port%/vis/index.html' at decodeURIComponent (<anonymous>) at decode_param (/opt/iobroker/node_modules/express/lib/router/layer.js:172:12) at Layer.match (/opt/iobroker/node_modules/express/lib/router/layer.js:148:15) at matchLayer (/opt/iobroker/node_modules/express/lib/router/index.js:585:18) at next (/opt/iobroker/node_modules/express/lib/router/index.js:226:15) at compression (/opt/iobroker/node_modules/compression/index.js:220:5) at Layer.handle [as handle_request] (/opt/iobroker/node_modules/express/lib/router/layer.js:95:5) at trim_prefix (/opt/iobroker/node_modules/express/lib/router/index.js:328:13) at /opt/iobroker/node_modules/express/lib/router/index.js:286:9 at Function.process_params (/opt/iobroker/node_modules/express/lib/router/index.js:346:12) -
Beides
Adapter State system.adapter.accuweather.0 : accuweather : raspberrypi - disabled + system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.alexa2.0 : alexa2 : raspberrypi - enabled + system.adapter.backitup.0 : backitup : raspberrypi - enabled + system.adapter.bring.0 : bring : raspberrypi - enabled system.adapter.cloud.0 : cloud : raspberrypi - disabled system.adapter.daswetter.0 : daswetter : raspberrypi - enabled system.adapter.discovery.0 : discovery : raspberrypi - disabled system.adapter.dwd.0 : dwd : raspberrypi - enabled system.adapter.feiertage.0 : feiertage : raspberrypi - enabled system.adapter.hue-extended.0 : hue-extended : raspberrypi - disabled system.adapter.ical.0 : ical : raspberrypi - disabled + system.adapter.iot.0 : iot : raspberrypi - enabled system.adapter.javascript.0 : javascript : raspberrypi - disabled + system.adapter.lg-thinq.0 : lg-thinq : raspberrypi - enabled system.adapter.lgtv.0 : lgtv : raspberrypi - disabled system.adapter.openweathermap.0 : openweathermap : raspberrypi - disabled + system.adapter.ping.0 : ping : raspberrypi - enabled + system.adapter.pushbullet.0 : pushbullet : raspberrypi - enabled system.adapter.schoolfree.0 : schoolfree : raspberrypi - disabled system.adapter.smartthings.0 : smartthings : raspberrypi - disabled + system.adapter.spotify-premium.0 : spotify-premium : raspberrypi - enabled system.adapter.tankerkoenig.0 : tankerkoenig : raspberrypi - disabled system.adapter.tr-064.0 : tr-064 : raspberrypi - disabled + system.adapter.trashschedule.0 : trashschedule : raspberrypi - enabled + system.adapter.tuya.0 : tuya : raspberrypi - enabled system.adapter.vis.0 : vis : raspberrypi - disabled system.adapter.web.0 : web : raspberrypi - disabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.wled.0 : wled : raspberrypi - enabled + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0, run as: admin ioBroker-Repositories stable : http://download.iobroker.net/sources-dist.json beta : http://download.iobroker.net/sources-dist-latest.json Active repo(s): stable Installed ioBroker-Instances Used repository: stable Adapter "accuweather" : 1.2.1 , installed 1.2.1 Adapter "admin" : 6.3.5 , installed 6.2.17 [Updatable] Adapter "alexa2" : 3.23.2 , installed 3.19.9 [Updatable] Adapter "backitup" : 2.6.16 , installed 2.4.10 [Updatable] Adapter "bring" : 1.8.1 , installed 1.8.1 Adapter "cloud" : 4.3.0 , installed 4.2.2 [Updatable] Adapter "daswetter" : 3.1.7 , installed 3.1.7 Adapter "discovery" : 3.1.0 , installed 3.0.3 [Updatable] Adapter "dwd" : 2.8.3 , installed 2.8.3 Adapter "feiertage" : 1.1.0 , installed 1.1.0 Adapter "hue-extended" : 2.0.0 , installed 2.0.0 Adapter "ical" : 1.13.2 , installed 1.13.2 Adapter "iot" : 1.14.2 , installed 1.11.9 [Updatable] Adapter "javascript" : 6.1.4 , installed 6.0.0 [Updatable] Controller "js-controller": 4.0.24 , installed 4.0.23 [Updatable] Adapter "lg-thinq" : 0.1.4 , installed 0.0.7 [Updatable] Adapter "lgtv" : 1.1.10 , installed 1.1.10 Adapter "openweathermap": 0.3.3 , installed 0.3.3 Adapter "ping" : 1.5.3 , installed 1.5.3 Adapter "pushbullet" : 0.0.11 , installed 0.0.11 Adapter "schoolfree" : 1.1.1 , installed 1.0.1 [Updatable] Adapter "simple-api" : 2.7.2 , installed 2.7.2 Adapter "smartthings" : 0.0.4 , installed 0.0.3 [Updatable] Adapter "socketio" : 4.2.0 , installed 4.2.0 Adapter "spotify-premium": 1.2.1 , installed 1.2.1 Adapter "tankerkoenig" : 3.3.7 , installed 3.3.7 Adapter "tr-064" : 4.2.18 , installed 4.2.16 [Updatable] Adapter "trashschedule": 2.2.0 , installed 2.2.0 Adapter "tuya" : 3.13.1 , installed 3.13.1 Adapter "vis" : 1.4.16 , installed 1.4.15 [Updatable] Adapter "web" : 4.3.0 , installed 4.3.0 Adapter "wled" : 0.6.7 , installed 0.6.7 Adapter "ws" : 1.3.0 , installed 1.3.0 Objects and States Please stand by - This may take a while Objects: 9978 States: 8091Wie ich gesehen habe ist es bei der VIS genauso.
Hab jetzt beide deinstalliert und nur HABPanel wieder installiert.
Aber es erscheint wieder 2x im Dashboard und dann der Fehler wenn man ihn aufruft.
da ist auch nichts zum starten oder Einstellungen usw.
Das Backup hat soweit funktioniert nur das HABPanel nicht. Hab es entfernt und die Instanz wieder neu installiert.
Aber es steht immer 2x drinn. Clicke ich drauf kommt so etwas ..URIError: Failed to decode param '%web_protocol%://%web_bind%:%web_port%/habpanel/index.html' at decodeURIComponent (<anonymous>) at decode_param (/opt/iobroker/node_modules/express/lib/router/layer.js:172:12) at Layer.match (/opt/iobroker/node_modules/express/lib/router/layer.js:148:15) at matchLayer (/opt/iobroker/node_modules/express/lib/router/index.js:585:18) at next (/opt/iobroker/node_modules/express/lib/router/index.js:226:15) at compression (/opt/iobroker/node_modules/compression/index.js:220:5) at Layer.handle [as handle_request] (/opt/iobroker/node_modules/express/lib/router/layer.js:95:5) at trim_prefix (/opt/iobroker/node_modules/express/lib/router/index.js:328:13) at /opt/iobroker/node_modules/express/lib/router/index.js:286:9 at Function.process_params (/opt/iobroker/node_modules/express/lib/router/index.js:346:12) -
Danke für den Hinweis.
Ich danke dir aufjedenfall recht Herzlich für deine Hilfe! -
Jaja
 Warum sagt er mir das in der GUI nicht. Denke jeder hat nich immer sein Version aktuell obwohl ich es eigentlich dachte, dass sie es wäre.
Und was mache ich jetzt ? -
iobroker controller daemon is not running host.raspberrypi OK. The current version of js-controller differs from the version in the backup. The js-controller version of the backup can not be restored automatically. To restore the js-controller version of the backup, execute "npm i iobroker.js-controller@4.0.23 --production" inside your ioBroker directory If you really want to restore the backup with the current installed js-controller, execute the restore command with the --force flag -
@thomas-braun said in [HowTo] ioBroker Restore unter Linux durchführen:
iob logs --watch | uniq
irgendwie stoppt er nur alles...Ab 18:23:30 habe ich die Wiederherstellung gestartet.
2023-04-22 18:23:30.999 - info: bring.0 (10071) [END] Stopping Bring! adapter... 2023-04-22 18:23:31.013 - info: host.raspberrypi received SIGTERM 2023-04-22 18:23:31.019 - info: backitup.0 (9766) cleaned everything up... 2023-04-22 18:23:30.999 - info: trashschedule.0 (9969) cleaned everything up... 2023-04-22 18:23:31.033 - info: admin.0 (9373) terminating http server on port 8081 2023-04-22 18:23:31.034 - info: wled.0 (10341) cleaned everything up... 2023-04-22 18:23:31.025 - info: accuweather.0 (9854) cleaned everything up... 2023-04-22 18:23:31.022 - info: host.raspberrypi stopInstance system.adapter.admin.0 (force=false, process=true) 2023-04-22 18:23:31.025 - info: host.raspberrypi stopInstance system.adapter.alexa2.0 (force=false, process=true) 2023-04-22 18:23:31.028 - info: host.raspberrypi stopInstance system.adapter.ical.0 (force=false, process=false) 2023-04-22 18:23:31.030 - info: host.raspberrypi stopInstance system.adapter.tuya.0 (force=false, process=true) 2023-04-22 18:23:31.033 - info: host.raspberrypi stopInstance system.adapter.discovery.0 (force=false, process=true) 2023-04-22 18:23:31.035 - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=true) 2023-04-22 18:23:31.037 - info: host.raspberrypi stopInstance system.adapter.accuweather.0 (force=false, process=true) 2023-04-22 18:23:31.040 - info: host.raspberrypi stopInstance system.adapter.iot.0 (force=false, process=false) 2023-04-22 18:23:31.047 - info: host.raspberrypi stopInstance system.adapter.trashschedule.0 (force=false, process=true) 2023-04-22 18:23:31.049 - info: host.raspberrypi stopInstance system.adapter.bring.0 (force=false, process=true) 2023-04-22 18:23:31.050 - info: host.raspberrypi stopInstance system.adapter.daswetter.0 (force=false, process=false) 2023-04-22 18:23:31.053 - info: host.raspberrypi stopInstance canceled schedule system.adapter.daswetter.0 2023-04-22 18:23:31.054 - info: host.raspberrypi stopInstance system.adapter.web.0 (force=false, process=true) 2023-04-22 18:23:31.056 - info: host.raspberrypi stopInstance system.adapter.habpanel.0 (force=false, process=false) 2023-04-22 18:23:31.057 - info: host.raspberrypi stopInstance system.adapter.wled.0 (force=false, process=true) 2023-04-22 18:23:31.160 - info: bring.0 (10071) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason 2023-04-22 18:23:31.182 - info: alexa2.0 (9495) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason 2023-04-22 18:23:31.188 - info: admin.0 (9373) Got terminate signal TERMINATE_YOURSELF 2023-04-22 18:23:31.200 - info: backitup.0 (9766) Got terminate signal TERMINATE_YOURSELF 2023-04-22 18:23:31.202 - info: accuweather.0 (9854) Got terminate signal TERMINATE_YOURSELF 2023-04-22 18:23:31.208 - info: bring.0 (10071) Got terminate signal TERMINATE_YOURSELF 2023-04-22 18:23:31.195 - info: tuya.0 (9601) Got terminate signal TERMINATE_YOURSELF 2023-04-22 18:23:31.205 - info: trashschedule.0 (9969) Got terminate signal TERMINATE_YOURSELF 2023-04-22 18:23:31.192 - info: alexa2.0 (9495) Got terminate signal TERMINATE_YOURSELF 2023-04-22 18:23:31.230 - info: web.0 (10270) Got terminate signal TERMINATE_YOURSELF 2023-04-22 18:23:31.220 - info: wled.0 (10341) Got terminate signal TERMINATE_YOURSELF 2023-04-22 18:23:31.237 - info: admin.0 (9373) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason 2023-04-22 18:23:31.224 - info: discovery.0 (9680) Got terminate signal TERMINATE_YOURSELF 2023-04-22 18:23:31.244 - info: backitup.0 (9766) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason 2023-04-22 18:23:31.244 - info: wled.0 (10341) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason 2023-04-22 18:23:31.253 - info: trashschedule.0 (9969) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason 2023-04-22 18:23:31.276 - info: discovery.0 (9680) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason 2023-04-22 18:23:31.286 - info: accuweather.0 (9854) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason 2023-04-22 18:23:31.289 - info: host.raspberrypi stopInstance system.adapter.admin.0 send kill signal 2023-04-22 18:23:31.305 - info: host.raspberrypi stopInstance system.adapter.alexa2.0 send kill signal 2023-04-22 18:23:31.307 - info: host.raspberrypi stopInstance system.adapter.tuya.0 send kill signal 2023-04-22 18:23:31.309 - info: host.raspberrypi stopInstance system.adapter.discovery.0 send kill signal 2023-04-22 18:23:31.310 - info: host.raspberrypi stopInstance system.adapter.backitup.0 send kill signal 2023-04-22 18:23:31.311 - info: host.raspberrypi stopInstance system.adapter.accuweather.0 send kill signal 2023-04-22 18:23:31.312 - info: host.raspberrypi stopInstance system.adapter.trashschedule.0 send kill signal 2023-04-22 18:23:31.313 - info: host.raspberrypi stopInstance system.adapter.bring.0 send kill signal 2023-04-22 18:23:31.314 - info: host.raspberrypi stopInstance system.adapter.web.0 send kill signal 2023-04-22 18:23:31.315 - info: host.raspberrypi stopInstance system.adapter.wled.0 send kill signal 2023-04-22 18:23:31.496 - info: web.0 (10270) terminated http server on port 8082 2023-04-22 18:23:31.510 - info: web.0 (10270) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason 2023-04-22 18:23:31.808 - info: host.raspberrypi instance system.adapter.bring.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP) 2023-04-22 18:23:31.917 - info: host.raspberrypi instance system.adapter.alexa2.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP) 2023-04-22 18:23:32.107 - info: host.raspberrypi instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP) 2023-04-22 18:23:32.115 - info: host.raspberrypi instance system.adapter.wled.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP) 2023-04-22 18:23:32.227 - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP) 2023-04-22 18:23:32.229 - info: host.raspberrypi instance system.adapter.accuweather.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP) 2023-04-22 18:23:32.231 - info: host.raspberrypi instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP) 2023-04-22 18:23:32.272 - info: host.raspberrypi instance system.adapter.trashschedule.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP) 2023-04-22 18:23:32.349 - info: host.raspberrypi instance system.adapter.web.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP) 2023-04-22 18:23:30.999 - info: bring.0 (10071) [END] Stopping Bring! adapter... 2023-04-22 18:23:31.013 - info: host.raspberrypi received SIGTERM 2023-04-22 18:23:31.019 - info: backitup.0 (9766) cleaned everything up... 2023-04-22 18:23:30.999 - info: trashschedule.0 (9969) cleaned everything up... 2023-04-22 18:23:31.033 - info: admin.0 (9373) terminating http server on port 8081 2023-04-22 18:23:31.034 - info: wled.0 (10341) cleaned everything up... 2023-04-22 18:23:31.025 - info: accuweather.0 (9854) cleaned everything up... 2023-04-22 18:23:31.022 - info: host.raspberrypi stopInstance system.adapter.admin.0 (force=false, process=true) 2023-04-22 18:23:31.025 - info: host.raspberrypi stopInstance system.adapter.alexa2.0 (force=false, process=true) 2023-04-22 18:23:31.028 - info: host.raspberrypi stopInstance system.adapter.ical.0 (force=false, process=false) 2023-04-22 18:23:31.030 - info: host.raspberrypi stopInstance system.adapter.tuya.0 (force=false, process=true) 2023-04-22 18:23:31.033 - info: host.raspberrypi stopInstance system.adapter.discovery.0 (force=false, process=true) 2023-04-22 18:23:31.035 - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=true) 2023-04-22 18:23:31.037 - info: host.raspberrypi stopInstance system.adapter.accuweather.0 (force=false, process=true) 2023-04-22 18:23:31.040 - info: host.raspberrypi stopInstance system.adapter.iot.0 (force=false, process=false) 2023-04-22 18:23:31.047 - info: host.raspberrypi stopInstance system.adapter.trashschedule.0 (force=false, process=true) 2023-04-22 18:23:31.049 - info: host.raspberrypi stopInstance system.adapter.bring.0 (force=false, process=true) 2023-04-22 18:23:31.050 - info: host.raspberrypi stopInstance system.adapter.daswetter.0 (force=false, process=false) 2023-04-22 18:23:31.053 - info: host.raspberrypi stopInstance canceled schedule system.adapter.daswetter.0 2023-04-22 18:23:31.054 - info: host.raspberrypi stopInstance system.adapter.web.0 (force=false, process=true) 2023-04-22 18:23:31.056 - info: host.raspberrypi stopInstance system.adapter.habpanel.0 (force=false, process=false) 2023-04-22 18:23:31.057 - info: host.raspberrypi stopInstance system.adapter.wled.0 (force=false, process=true) 2023-04-22 18:23:31.160 - info: bring.0 (10071) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason 2023-04-22 18:23:31.182 - info: alexa2.0 (9495) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason 2023-04-22 18:23:31.188 - info: admin.0 (9373) Got terminate signal TERMINATE_YOURSELF 2023-04-22 18:23:31.200 - info: backitup.0 (9766) Got terminate signal TERMINATE_YOURSELF 2023-04-22 18:23:31.202 - info: accuweather.0 (9854) Got terminate signal TERMINATE_YOURSELF 2023-04-22 18:23:31.208 - info: bring.0 (10071) Got terminate signal TERMINATE_YOURSELF 2023-04-22 18:23:31.195 - info: tuya.0 (9601) Got terminate signal TERMINATE_YOURSELF 2023-04-22 18:23:31.205 - info: trashschedule.0 (9969) Got terminate signal TERMINATE_YOURSELF 2023-04-22 18:23:31.192 - info: alexa2.0 (9495) Got terminate signal TERMINATE_YOURSELF 2023-04-22 18:23:31.230 - info: web.0 (10270) Got terminate signal TERMINATE_YOURSELF 2023-04-22 18:23:31.220 - info: wled.0 (10341) Got terminate signal TERMINATE_YOURSELF 2023-04-22 18:23:31.237 - info: admin.0 (9373) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason 2023-04-22 18:23:31.224 - info: discovery.0 (9680) Got terminate signal TERMINATE_YOURSELF 2023-04-22 18:23:31.244 - info: backitup.0 (9766) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason 2023-04-22 18:23:31.244 - info: wled.0 (10341) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason 2023-04-22 18:23:31.253 - info: trashschedule.0 (9969) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason 2023-04-22 18:23:31.276 - info: discovery.0 (9680) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason 2023-04-22 18:23:31.286 - info: accuweather.0 (9854) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason 2023-04-22 18:23:31.289 - info: host.raspberrypi stopInstance system.adapter.admin.0 send kill signal 2023-04-22 18:23:31.305 - info: host.raspberrypi stopInstance system.adapter.alexa2.0 send kill signal 2023-04-22 18:23:31.307 - info: host.raspberrypi stopInstance system.adapter.tuya.0 send kill signal 2023-04-22 18:23:31.309 - info: host.raspberrypi stopInstance system.adapter.discovery.0 send kill signal 2023-04-22 18:23:31.310 - info: host.raspberrypi stopInstance system.adapter.backitup.0 send kill signal 2023-04-22 18:23:31.311 - info: host.raspberrypi stopInstance system.adapter.accuweather.0 send kill signal 2023-04-22 18:23:31.312 - info: host.raspberrypi stopInstance system.adapter.trashschedule.0 send kill signal 2023-04-22 18:23:31.313 - info: host.raspberrypi stopInstance system.adapter.bring.0 send kill signal 2023-04-22 18:23:31.314 - info: host.raspberrypi stopInstance system.adapter.web.0 send kill signal 2023-04-22 18:23:31.315 - info: host.raspberrypi stopInstance system.adapter.wled.0 send kill signal 2023-04-22 18:23:31.496 - info: web.0 (10270) terminated http server on port 8082 2023-04-22 18:23:31.510 - info: web.0 (10270) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason 2023-04-22 18:23:31.808 - info: host.raspberrypi instance system.adapter.bring.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP) 2023-04-22 18:23:31.917 - info: host.raspberrypi instance system.adapter.alexa2.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP) 2023-04-22 18:23:32.107 - info: host.raspberrypi instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP) 2023-04-22 18:23:32.115 - info: host.raspberrypi instance system.adapter.wled.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP) 2023-04-22 18:23:32.227 - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP) 2023-04-22 18:23:32.229 - info: host.raspberrypi instance system.adapter.accuweather.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP) 2023-04-22 18:23:32.231 - info: host.raspberrypi instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP) 2023-04-22 18:23:32.272 - info: host.raspberrypi instance system.adapter.trashschedule.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP) 2023-04-22 18:23:32.349 - info: host.raspberrypi instance system.adapter.web.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP) 2023-04-22 18:23:34.043 - info: tuya.0 (9601) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason 2023-04-22 18:23:34.663 - info: host.raspberrypi instance system.adapter.tuya.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP) 2023-04-22 18:23:34.665 - info: host.raspberrypi All instances are stopped. 2023-04-22 18:23:34.804 - info: host.raspberrypi terminated 2023-04-22 18:23:34.663 - info: host.raspberrypi instance system.adapter.tuya.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP) 2023-04-22 18:23:34.665 - info: host.raspberrypi All instances are stopped. 2023-04-22 18:23:34.804 - info: host.raspberrypi terminated -
Nix.
backitup.0 2023-04-22 18:13:34.853 info [iobroker] backup was activated at 02:40 every 1 day(s) backitup.0 2023-04-22 18:13:34.561 info starting. Version 2.6.16 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.16.0, js-controller: 4.0.24 backitup.0 2023-04-22 17:58:20.510 info Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason backitup.0 2023-04-22 17:58:20.476 info Got terminate signal TERMINATE_YOURSELF backitup.0 2023-04-22 17:58:20.342 info cleaned everything up...
