Best posts made by O S
Latest posts made by O S
RE: Neuer Alexa-Skill "iobroker.assistant"posted in Cloud Dienste
Herzlichen Dank für das "how-to". Habe mich exakt an die Beschreibung gehalten und alles lief perfekt. Super Arbeit von allen Beteiligten. DANKE!
Gruß Otto -
RE: TESTER gesucht / Backup auf Fritz.nas - node 18.18.0posted in Tester
Ich nutze opt/iobroker/node_modules
Controller: 5.0.12
Backitup: 2.8.1 -
@fastfoot
Hier meine Ausgabe deines Testscriptes:umount not possible
mount not possible: Error: Command failed: sudo mount -t cifs -o username=iobroker,password=iobrokertest,noserverino,rw,file_mode=0777,dir_mode=0777,vers=3.1.1 //fritz.box/fritz.nas/Backup /opt/iobroker/backups
mount error(13): Permission denied
Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)file test_standard.tar.gz created
file test_standard.tar.gz done
number of files in test_standard.tar.gz: 155file test_nocompression.tar created
file test_nocompression.tar done
number of files in test_nocompression.tar: 155file test_alternative.tar.gz created
file test_alternative.tar.gz done
number of files in test_alternative.tar.gz: 155listing of created files in /opt/iobroker/backups
-rw-rw-r--+ 1 pi pi 10724080 Oct 4 12:50 /opt/iobroker/backups/test_alternative.tar.gz
-rw-rw-r--+ 1 pi pi 41432576 Oct 4 12:50 /opt/iobroker/backups/test_nocompression.tar
-rw-rw-r--+ 1 pi pi 10724080 Oct 4 12:50 /opt/iobroker/backups/test_standard.tar.gzGruß Otto
End of output to copy -
Besser habe ich es nicht gekonnt!
Gruß Otto -
Habe das gleiche Problem.
Skript v.2023-06-20 *** BASE SYSTEM *** Static hostname: iobroker6 Icon name: computer Machine ID: 6cdd9ef1128b465193e49cc4ea80f5af Boot ID: 41b5da8e46ba4fd897de0fa6a4711922 Operating System: Debian GNU/Linux 11 (bullseye) Kernel: Linux 6.1.21-v8+ Architecture: arm64 Model : Raspberry Pi 4 Model B Rev 1.2 Docker : false Virtualization : none Kernel : aarch64 Userland : arm64 Systemuptime and Load: 17:43:34 up 3:51, 1 user, load average: 0.84, 0.88, 0.88 CPU threads: 4 Raspberry only: throttled=0x0 Other values than 0x0 hint to temperature/voltage problems temp=67.6'C volt=0.8438V *** Time and Time Zones *** Local time: Tue 2023-10-03 17:43:34 CEST Universal time: Tue 2023-10-03 15:43:34 UTC RTC time: n/a Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** User and Groups *** pi /home/pi pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker *** X-Server-Setup *** X-Server: false Desktop: Terminal: tty Boot Target: multi-user.target *** MEMORY *** total used free shared buff/cache available Mem: 3.8G 1.8G 1.6G 1.0M 419M 1.9G Swap: 99M 0B 99M Total: 3.9G 1.8G 1.7G 3793 M total memory 1803 M used memory 1851 M active memory 250 M inactive memory 1570 M free memory 54 M buffer memory 364 M swap cache 99 M total swap 0 M used swap 99 M free swap Raspberry only: oom events: 0 lifetime oom required: 0 Mbytes total time in oom handler: 0 ms max time spent in oom handler: 0 ms *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on /dev/root ext4 28G 3.2G 24G 12% / devtmpfs devtmpfs 1.7G 0 1.7G 0% /dev tmpfs tmpfs 1.9G 0 1.9G 0% /dev/shm tmpfs tmpfs 759M 1.2M 758M 1% /run tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock /dev/sdb1 vfat 255M 31M 225M 13% /boot tmpfs tmpfs 380M 0 380M 0% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Tue Oct 3 13:52:15 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 smsc95xx.macaddr=E4:5F:01:05:E5:E6 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000 console=ttyS0,115200 console=tty1 root=PARTUUID=85bcf00a-02 rootfstype=ext4 fsck.repair=yes rootwait [Tue Oct 3 13:52:18 2023] EXT4-fs (sdb2): mounted filesystem with ordered data mode. Quota mode: none. [Tue Oct 3 13:52:18 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:18. [Tue Oct 3 13:52:20 2023] EXT4-fs (sdb2): re-mounted. Quota mode: none. Show mounted filesystems (real ones only): TARGET SOURCE FSTYPE OPTIONS / /dev/sdb2 ext4 rw,noatime `-/boot /dev/sdb1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 535M /var/ 182M /var/cache 176M /var/cache/apt 147M /var/lib 122M /var/lib/apt/lists Archived and active journals take up 104.0M in the file system. /opt/iobroker/backups: 4.0K /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 196M /opt/iobroker/iobroker-data/ 165M /opt/iobroker/iobroker-data/files 52M /opt/iobroker/iobroker-data/files/javascript.admin 34M /opt/iobroker/iobroker-data/files/javascript.admin/static 33M /opt/iobroker/iobroker-data/files/javascript.admin/static/js The five largest files in iobroker-data are: 25M /opt/iobroker/iobroker-data/objects.jsonl 21M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.e564fb87.js.map 19M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map 8.3M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.e564fb87.js 8.2M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js *** NodeJS-Installation *** /usr/bin/nodejs v18.17.1 /usr/bin/node v18.17.1 /usr/bin/npm 9.6.7 /usr/bin/npx 9.6.7 nodejs: Installed: 18.17.1-deb-1nodesource1 Candidate: 18.17.1-deb-1nodesource1 Version table: *** 18.17.1-deb-1nodesource1 500 500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages 100 /var/lib/dpkg/status 12.22.12~dfsg-1~deb11u4 500 500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages 12.22.12~dfsg-1~deb11u3 500 500 http://deb.debian.org/debian bullseye/main arm64 Packages Temp directories causing npm8 problem: 0 No problems detected Errors in npm tree: 0 *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl No configuration change needed. Multihost discovery server: disabled Discovery authentication: enabled Persistent activation: disabled Objects: jsonl on 0.0.0.0 States: jsonl on 0.0.0.0 Core adapters versions js-controller: 5.0.12 admin: 6.10.1 javascript: 7.1.4 Adapters from github: 0 Adapter State + system.adapter.admin.0 : admin : iobroker - enabled, port: 7777, bind: 0.0.0.0, run as: admin + system.adapter.alexa2.0 : alexa2 : iobroker - enabled + system.adapter.backitup.0 : backitup : iobroker - enabled + system.adapter.discovery.0 : discovery : iobroker - enabled system.adapter.flot.0 : flot : iobroker - enabled + system.adapter.fritzbox.0 : fritzbox : iobroker - enabled + system.adapter.fritzdect.0 : fritzdect : iobroker - enabled + system.adapter.history.0 : history : iobroker - enabled + system.adapter.info.0 : info : iobroker - enabled + system.adapter.iot.0 : iot : iobroker - enabled + system.adapter.javascript.0 : javascript : iobroker - enabled system.adapter.mobile.0 : mobile : iobroker - enabled + system.adapter.net-tools.0 : net-tools : iobroker - enabled + system.adapter.octoprint.0 : octoprint : iobroker - enabled + system.adapter.ping.0 : ping : iobroker - enabled + system.adapter.shelly.0 : shelly : iobroker - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.sonoff.0 : sonoff : iobroker - enabled, port: 1884, bind: 0.0.0.0 + system.adapter.tankerkoenig.0 : tankerkoenig : iobroker - enabled + system.adapter.telegram.0 : telegram : iobroker - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.tr-064.0 : tr-064 : iobroker - enabled system.adapter.vis-canvas-gauges.0 : vis-canvas-gauges : iobroker - enabled system.adapter.vis-fancyswitch.0 : vis-fancyswitch : iobroker - enabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : iobroker - enabled system.adapter.vis-justgage.0 : vis-justgage : iobroker - enabled system.adapter.vis.0 : vis : iobroker - enabled + system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.ws.0 : ws : iobroker - enabled, port: 8085, bind: 0.0.0.0, run as: admin + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : iobroker - enabled, port: 7777, bind: 0.0.0.0, run as: admin + system.adapter.shelly.0 : shelly : iobroker - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.sonoff.0 : sonoff : iobroker - enabled, port: 1884, bind: 0.0.0.0 + system.adapter.telegram.0 : telegram : iobroker - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.ws.0 : ws : iobroker - enabled, port: 8085, bind: 0.0.0.0, run as: admin ioBroker-Repositories Stable (default): http://download.iobroker.net/sources-dist.json Beta (latest) : http://download.iobroker.net/sources-dist-latest.json Active repo(s): Stable (default) Installed ioBroker-Instances Used repository: Stable (default) Adapter "admin" : 6.10.1 , installed 6.10.1 Adapter "alexa2" : 3.25.2 , installed 3.25.2 Adapter "backitup" : 2.8.1 , installed 2.8.1 Adapter "discovery" : 3.1.0 , installed 3.1.0 Adapter "flot" : 1.12.0 , installed 1.12.0 Adapter "fritzbox" : 0.5.0 , installed 0.5.0 Adapter "fritzdect" : 2.3.1 , installed 2.3.1 Adapter "history" : 2.2.6 , installed 2.2.6 Adapter "info" : 2.0.0 , installed 2.0.0 Adapter "iot" : 1.14.5 , installed 1.14.5 Adapter "javascript" : 7.1.4 , installed 7.1.4 Controller "js-controller": 5.0.12 , installed 5.0.12 Adapter "mobile" : 1.0.1 , installed 1.0.1 Adapter "net-tools" : 0.2.0 , installed 0.2.0 Adapter "octoprint" : 4.0.0 , installed 4.0.0 Adapter "ping" : 1.6.2 , installed 1.6.2 Adapter "shelly" : 6.4.1 , installed 6.4.1 Adapter "simple-api" : 2.7.2 , installed 2.7.2 Adapter "socketio" : 6.5.5 , installed 6.5.5 Adapter "sonoff" : 2.5.3 , installed 2.5.3 Adapter "tankerkoenig" : 3.3.7 , installed 3.3.7 Adapter "telegram" : 1.16.0 , installed 1.16.0 Adapter "tr-064" : 4.2.18 , installed 4.2.18 Adapter "vis" : 1.4.16 , installed 1.4.16 Adapter "vis-canvas-gauges": 1.0.1, installed 1.0.1 Adapter "vis-fancyswitch": 1.1.0 , installed 1.1.0 Adapter "vis-hqwidgets": 1.4.0 , installed 1.4.0 Adapter "vis-justgage" : 1.0.2 , installed 1.0.2 Adapter "web" : 6.1.2 , installed 6.1.0 [Updatable] Adapter "ws" : 2.5.5 , installed 2.5.5 Objects and States Please stand by - This may take a while Objects: 6978 States: 12775 *** OS-Repositories and Updates *** Hit:1 http://security.debian.org/debian-security bullseye-security InRelease Hit:2 http://deb.debian.org/debian bullseye InRelease Hit:3 http://deb.debian.org/debian bullseye-updates InRelease Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease Reading package lists... Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 15401 544/sshd: /usr/sbin tcp 0 0 0.0.0.0:9001 0.0.0.0:* LISTEN 1001 14593 508/iobroker.js-con tcp 0 0 0.0.0.0:9000 0.0.0.0:* LISTEN 1001 15434 508/iobroker.js-con tcp 0 0 0.0.0.0:1884 0.0.0.0:* LISTEN 1001 15751 1171/io.sonoff.0 tcp6 0 0 :::22 :::* LISTEN 0 15403 544/sshd: /usr/sbin tcp6 0 0 :::8082 :::* LISTEN 1001 300189 15081/io.web.0 tcp6 0 0 :::8085 :::* LISTEN 1001 297932 15070/io.ws.0 tcp6 0 0 :::7777 :::* LISTEN 1001 299942 15273/io.admin.0 udp 0 0 0.0.0.0:68 0.0.0.0:* 0 12530 810/dhcpcd udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 14543 399/avahi-daemon: r udp 0 0 0.0.0.0:58602 0.0.0.0:* 108 14545 399/avahi-daemon: r udp 0 0 0.0.0.0:5683 0.0.0.0:* 1001 13024 1148/io.shelly.0 udp6 0 0 :::546 :::* 0 15429 810/dhcpcd udp6 0 0 :::5353 :::* 108 14544 399/avahi-daemon: r udp6 0 0 :::42372 :::* 108 14546 399/avahi-daemon: r *** Log File - Last 25 Lines *** 2023-10-03 16:48:52.372 - info: web.0 (15081) ==> Connected system.user.admin from ::ffff:192.168.178.203 2023-10-03 16:48:53.170 - info: admin.0 (15273) ==> Connected system.user.admin from ::ffff:192.168.178.203 2023-10-03 16:48:54.431 - info: admin.0 (15273) ==> Connected system.user.admin from ::ffff:192.168.178.203 2023-10-03 16:49:00.673 - info: web.0 (15081) ==> Connected system.user.admin from ::ffff:192.168.178.203 2023-10-03 16:51:14.699 - info: admin.0 (15273) <== Disconnect system.user.admin from ::ffff:192.168.178.203 2023-10-03 16:51:14.699 - info: web.0 (15081) <== Disconnect system.user.admin from ::ffff:192.168.178.203 vis.0 2023-10-03 16:51:14.701 - info: admin.0 (15273) <== Disconnect system.user.admin from ::ffff:192.168.178.203 admin 2023-10-03 16:51:14.701 - info: web.0 (15081) <== Disconnect system.user.admin from ::ffff:192.168.178.203 flot 2023-10-03 17:29:27.500 - warn: octoprint.0 (1324) received 502 response from /api/version with content: "<html><body><h1>502 Bad Gateway</h1>\nThe server returned an invalid or incomplete response.\n</body></html>\n" 2023-10-03 17:30:18.149 - info: web.0 (15081) ==> Connected system.user.admin from ::ffff:192.168.178.203 2023-10-03 17:30:18.677 - info: web.0 (15081) <== Disconnect system.user.admin from ::ffff:192.168.178.203 flot 2023-10-03 17:30:19.290 - info: web.0 (15081) ==> Connected system.user.admin from ::ffff:192.168.178.203 2023-10-03 17:30:20.314 - info: web.0 (15081) ==> Connected system.user.admin from ::ffff:192.168.178.203 2023-10-03 17:30:45.434 - info: admin.0 (15273) ==> Connected system.user.admin from ::ffff:192.168.178.203 2023-10-03 17:30:46.614 - info: admin.0 (15273) ==> Connected system.user.admin from ::ffff:192.168.178.203 2023-10-03 17:31:00.543 - info: admin.0 (15273) <== Disconnect system.user.admin from ::ffff:192.168.178.203 2023-10-03 17:40:42.148 - info: admin.0 (15273) <== Disconnect system.user.admin from ::ffff:192.168.178.203 admin 2023-10-03 17:40:42.148 - info: web.0 (15081) <== Disconnect system.user.admin from ::ffff:192.168.178.203 flot 2023-10-03 17:40:42.153 - info: web.0 (15081) <== Disconnect system.user.admin from ::ffff:192.168.178.203 vis.0 2023-10-03 17:40:48.430 - info: admin.0 (15273) ==> Connected system.user.admin from ::ffff:192.168.178.203 2023-10-03 17:40:49.815 - info: web.0 (15081) ==> Connected system.user.admin from ::ffff:192.168.178.203 2023-10-03 17:40:58.838 - info: web.0 (15081) ==> Connected system.user.admin from ::ffff:192.168.178.203 2023-10-03 17:42:44.448 - info: admin.0 (15273) <== Disconnect system.user.admin from ::ffff:192.168.178.203 admin 2023-10-03 17:42:44.451 - info: web.0 (15081) <== Disconnect system.user.admin from ::ffff:192.168.178.203 vis.0 2023-10-03 17:42:44.455 - info: web.0 (15081) <== Disconnect system.user.admin from ::ffff:192.168.178.203 flo======================= SUMMARY ======================= v.2023-06-20 Static hostname: iobroker Icon name: computer Machine ID: 6cdd9ef1128b465193e49cc4ea80f5af Boot ID: 41b5da8e46ba4fd897de0fa6a4711922 Operating System: Debian GNU/Linux 11 (bullseye) Kernel: Linux 6.1.21-v8+ Architecture: arm64 Installation: native Kernel: aarch64 Userland: arm64 Timezone: Europe/Berlin (CEST, +0200) User-ID: 1000 X-Server: false Boot Target: multi-user.target Pending OS-Updates: 0 Pending iob updates: 1 Nodejs-Installation: /usr/bin/nodejs v18.17.1 /usr/bin/node v18.17.1 /usr/bin/npm 9.6.7 /usr/bin/npx 9.6.7 Recommended versions are nodejs 18.x.y and npm 9.x.y Your nodejs installation is correct MEMORY: total used free shared buff/cache available Mem: 3.8G 1.8G 1.3G 1.0M 676M 1.9G Swap: 99M 0B 99M Total: 3.9G 1.8G 1.4G Active iob-Instances: 21 Active repo(s): Stable (default) ioBroker Core: js-controller 5.0.12 admin 6.10.1 ioBroker Status: iobroker is running on this host. Objects type: jsonl States type: jsonl Status admin and web instance: + system.adapter.admin.0 : admin : iobroker - enabled, port: 7777, bind: 0.0.0.0, run as: admin + system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin Objects: 6978 States: 12775 Size of iob-Database: 25M /opt/iobroker/iobroker-data/objects.jsonl 4.2M /opt/iobroker/iobroker-data/states.jsonl Hoffentlich hilft das.
