Ohne bewusst etwas verändert zu haben startet der admin Adapter nicht mehr.
Hier der log vom startenden und gleich wieder terminierenden admin Adapter:
admin.0 (21460) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v18.20.4, js-controller: 4.0.24
admin.0 (21460) requesting all states
admin.0 (21460) requesting all objects
admin.0 (21460) received all objects
admin.0 (21460) Cannot create web-server: TypeError: Cannot read properties of undefined (reading 'createServerAsync')
admin.0 (21460) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
admin.0 (21460) get state error: Connection is closed.
admin.0 (21460) get state error: DB closed
admin.0 (21460) Cannot check node.js/npm version
admin.0 (21460) terminating http server on port 8081
- Adaptername: Admin
- Link zu Adapterrepository: https://github.com/ioBroker/ioBroker.admin
- Adapterversion: 6.3.5
- js-controller Version: 4.0.24
- Hardwaresystem: Raspberry Pi 4 Model B Rev 1.1
- Arbeitsspeicher: 1.8GB
- Festplattenart: SD-Karte
- Betriebssystem: Raspbian GNU/Linux 10 (buster)
- Nodejs-Version: v18.20.4
- NPM-Version: 10.7.0
Linux User bitte hier den Output von iob diag einfügen.
v.2025-02-23
Static hostname: raspberrypi
Icon name: computer
Kernel: Linux 5.10.103-v7l+
Architecture: arm
Installation: native
Kernel: armv7l
Userland: 32 bit
Timezone: Europe/Berlin (CET, +0100)
User-ID: 1000
Display-Server: false
Boot Target: multi-user.target
Pending OS-Updates: 1
Pending iob updates: 36
Nodejs-Installation:
/usr/bin/nodejs v18.20.4
/usr/bin/node v18.20.4
/usr/bin/npm 10.7.0
/usr/bin/npx 10.7.0
/usr/bin/corepack 0.28.0
Recommended versions are nodejs and npm
nodeJS installation is correct
MEMORY:
Mem: 1.9G 994M 206M 20M 670M 757M
Swap: 99M 81M 18M
Total: 2.0G 1.1G 225M
Active iob-Instances: 14
Active repo(s): stable
ioBroker Core: js-controller 4.0.24
admin 6.3.5
ioBroker Status: iobroker is running on this host.
Objects type: jsonl
States type: jsonl
system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0, run as: admin
system.adapter.admin.1 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0, run as: admin
+ system.adapter.web.0 : web : raspberrypi - enabled, port: 8082, bind: 0.0.0.0, run as: admin
Objects: 9002
States: 6404
Size of iob-Database:
14M /opt/iobroker/iobroker-data/objects.jsonl
7.1M /opt/iobroker/iobroker-data/objects.json.migrated
7.1M /opt/iobroker/iobroker-data/objects.json.bak.migrated
0 /opt/iobroker/iobroker-data/objects.json.broken
3.3M /opt/iobroker/iobroker-data/states.jsonl
996K /opt/iobroker/iobroker-data/states.json.migrated
992K /opt/iobroker/iobroker-data/states.json.bak.migrated
0 /opt/iobroker/iobroker-data/states.json.broken
Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
