    2. Nicoloma
    • Topics 15
    • Posts 104
    • Groups 2
    Nicoloma
    @Nicoloma
    20
    104
    Nicoloma Follow
    Pro Starter
    Best posts made by Nicoloma
    • RE: Keine VIS Zugriff *GELÖST*
      Nach 2 Monaten habe ich es nun....
      Es war die Firewall 😞 sorry jungs ...
      Nicoloma
      Nicoloma
    Latest posts made by Nicoloma
    • RE: Während Dusche, Handtuchheizung einschalten
      @paul53 Boah Paul!!!! Klasse,
      ich probiere es sofort aus... Wie hast du das so schnell geschafft... Warnsinn!
      Nicoloma
      Nicoloma
        <variables>
          <variable id="nFaszOE_N_;S0AIaL!^7">timer_an_aus</variable>
          <variable id="YUa0(J+Yz1jv$b,HAJnV">heiz_an_timer</variable>
          <variable id="k{urv5:d*$21r3^eU1uH">dusche_an</variable>
          <variable id="G!7EQIfOiucgzA?bY2!+">block_timer1</variable>
          <variable id="m!T2C{3jG}C2+mFo{{+t">tempDifferenz</variable>
          <variable id="C4=te:_+4!*#?$$i`FMI">liste</variable>
          <variable type="interval" id="heiz_timer">heiz_timer</variable>
        </variables>
        <block type="controls_if" id="y}Ujjr5kE+_*BoS/FN?E" x="-637" y="-349">
          <value name="IF0">
            <block type="logic_compare" id="RL(eglY5cWGUwh:T[7EZ">
              <field name="OP">GT</field>
              <value name="A">
                <block type="get_value" id=":pjn]+[z)0voDz+L@aBj">
                  <field name="OID">0_userdata.0.Badezimmer.Timer_Badezimmer</field>
                </block>
              </value>
              <value name="B">
                <block type="math_number" id="#(#SR:Kk.LPuQM(%T%([">
                  <field name="NUM">0</field>
                </block>
              </value>
            </block>
          </value>
          <statement name="DO0">
            <block type="variables_set" id="C/SfZ3lQ~}A4[V``E*=;">
              <field name="VAR" id="nFaszOE_N_;S0AIaL!^7">timer_an_aus</field>
              <value name="VALUE">
                <block type="logic_boolean" id="lZ7-xSSSpT?kHtXljW}l">
                </block>
              </value>
            </block>
          </statement>
          <statement name="ELSE">
            <block type="variables_set" id="%e0af})/=I{5kL+MG2bi">
                <block type="logic_boolean" id="e7*Hm`v:*ge/+SCis?x6">
                </block>
              </value>
            </block>
          </statement>
          <next>
            <block type="update" id="9LL.L*J}Xr70CmO*E6[T">
              <field name="OID">0_userdata.0.Badezimmer.Timer_an</field>
                <block type="variables_get" id="^%F-Wf#KyThw?WRm=f/4">
                </block>
              </value>
              <next>
                <block type="variables_set" id="*8o}a($+Jq37{Hqnf09q">
                  <field name="VAR" id="k{urv5:d*$21r3^eU1uH">dusche_an</field>
                    <block type="get_value" id="RWu?Ij;l/Q~l!S|:~G.:">
                      <field name="OID">0_userdata.0.Badezimmer.dusche_an</field>
                    </block>
                  </value>
                  <next>
                    <block type="variables_set" id="-GBv{H?tO,H}*Dz_YiPD">
                      <field name="VAR" id="m!T2C{3jG}C2+mFo{{+t">tempDifferenz</field>
                        <block type="get_value" id="w6x;Bpn|*#Y5[4Q8!J)F">
                          <field name="OID">0_userdata.0.Badezimmer.feuchtigkeits_diff</field>
                        </block>
                      </value>
                      <next>
                        <block type="variables_set" id="r8t.SQ@@vfv1qBai(dR@">
                          <field name="VAR" id="C4=te:_+4!*#?$$i`FMI">liste</field>
                            <block type="lists_create_with" id="F81YYU`J?1AJ50rRF.bp">
                              <mutation items="0"></mutation>
                            </block>
                          </value>
                          <next>
                            <block type="timeouts_clearinterval" id="2ycD2ZpB:I1._8!(?w]T">
                              <field name="NAME">heiz_timer</field>
                              <next>
                                <block type="variables_set" id="AQ_d!Qwhtcb)[9-jl951">
                                  <field name="VAR" id="YUa0(J+Yz1jv$b,HAJnV">heiz_an_timer</field>
                                    <block type="get_value" id="#8BOo~PcVL}_4)BsKZ_u">
                                    </block>
                                  </value>
                                  <next>
                                    <block type="on" id="=3436}WLW?~-c.9%gYf`">
                                      <field name="OID">mqtt.0.Esp_gross.temp_wohnzimmer.Humidity</field>
                                      <statement name="STATEMENT">
                                        <block type="timeouts_clearinterval" id="w?v%_-q@La|qnDA9a844">
                                          <next>
                                            <block type="lists_setIndex" id="(.,LUkXDr+Q^{oZ!}..n">
                                              <mutation at="false"></mutation>
                                              <field name="MODE">INSERT</field>
                                              <field name="WHERE">LAST</field>
                                              <value name="LIST">
                                                <block type="variables_get" id="_iynJ_0%aO`/HA_^@U$|">
                                                </block>
                                              </value>
                                              <value name="TO">
                                                <block type="get_value" id="=9*16]1))KJ4Eb{D(k{F">
                                                </block>
                                              </value>
                                              <next>
                                                <block type="controls_if" id="D~:?H0_x*C{kk!wvmqTl">
                                                  <value name="IF0">
                                                    <block type="logic_compare" id="-yRnKAY/)Qsg[I|I~g/Q">
                                                      <field name="OP">GTE</field>
                                                      <value name="A">
                                                        <block type="lists_length" id="Ug@_~h+XD.yA+sLUrz39">
                                                            <block type="variables_get" id="#c1}Oe[2lH~1{[U/8b/X">
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                        <block type="math_number" id="U%Bl_`KVXBstplm}E:lf">
                                                          <field name="NUM">5</field>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                    <block type="lists_getIndex" id="e#w~fan2/~5rwgIvoU7j">
                                                      <mutation statement="true" at="false"></mutation>
                                                      <field name="MODE">REMOVE</field>
                                                      <field name="WHERE">FIRST</field>
                                                        <block type="variables_get" id="VA$G%~OlNxs,0j0O|4~f">
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </statement>
                                                  <next>
                                                    <block type="variables_set" id="DhaqVe*A(qLOm3nJl|^8">
                                                        <block type="math_arithmetic" id="z@mk|1g(?zYkPgJ,`+^.">
                                                          <value name="A">
                                                            <shadow type="math_number" id="5!XE|7=}49x?o=zsCs?F">
                                                              <field name="NUM">1</field>
                                                            </shadow>
                                                            <block type="lists_getIndex" id="4!e31@x+ld1qjw;FTcGQ">
                                                              <mutation statement="false" at="false"></mutation>
                                                              <field name="MODE">GET</field>
        <block type="variables_get" id="byHCG?p2J}EQ.=(pQ1~8">
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                            <shadow type="math_number" id="/P%TSO:}^85VloVh8r(B">
                                                            </shadow>
                                                            <block type="lists_getIndex" id="Xgqwkvd0%GQN6]=@SR?0">
        <block type="variables_get" id="VY:ky0a#G8c{4bT.[OP~">
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                      <next>
                                                        <block type="update" id="9}2[}rOmRc@n5-({*Y$e">
                                                            <block type="variables_get" id="M}mZ8v2#JIr,:q:v3/Zb">
                                                            </block>
                                                          </value>
                                                          <next>
                                                            <block type="update" id="C1y?ukyQB?pdq-o~rJ,s">
        <block type="variables_get" id="_,bsgt.fsX3HoPZ,bG)d">
        </block>
                                                              </value>
                                                              <next>
        <block type="controls_if" id="Y2G.j7o+lExReGJX{L8/">
        <mutation elseif="1" else="1"></mutation>
        <value name="IF0">
        <block type="logic_compare" id="UQ#p;i+XpK7q?w7CT7d5" inline="false">
        <value name="A">
        <block type="variables_get" id=":xL;I_83n`HV40)1wxx8">
        </block>
        </value>
        <value name="B">
        <block type="math_number" id="(tRF9mq^FChM6(?wB9v3">
        <field name="NUM">4</field>
        </block>
        </value>
        </block>
        </value>
        <block type="variables_set" id="px/w45?,OuJ07_SrP*H4">
        <block type="logic_boolean" id="KEkuKLsD{0[wNU,-cHV!">
        </block>
        </value>
        </block>
        </statement>
        <value name="IF1">
        <block type="logic_compare" id="k;e;ks$]d,V7yhZ7gD6N" inline="false">
        <field name="OP">LT</field>
        <value name="A">
        <block type="variables_get" id="cd~#X?@H0,DGjWQRnnHL">
        </block>
        </value>
        <value name="B">
        <block type="math_number" id="]K}Y!uF]?AFo9`dH]67F">
        <field name="NUM">-4</field>
        </block>
        </value>
        </block>
        </value>
        <statement name="DO1">
        <block type="comment" id="u.%)g5HsbeS%l*V#3+qB">
        <field name="COMMENT">Dusche zuende_es wurd gelüftet</field>
        <next>
        <block type="variables_set" id="*op|a;%^~(hB$^SJ%UDk">
        <block type="logic_boolean" id="2qoOURaGDc29C|CJc.6/">
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        <block type="variables_set" id="b!ZtkV38/4Csd@(y~]Z-">
        <block type="logic_boolean" id="CwYB7+QGW{0}CKS4Bw%8">
        </block>
        </value>
        </block>
        </statement>
        <next>
        <block type="debug" id="{v_P^e!vmg/,jl).?t$g" disabled="true">
        <field name="Severity">error</field>
        <value name="TEXT">
        <shadow type="text" id="7sstB/Tj$%]n,71NE%4@">
        </shadow>
        <block type="variables_get" id="yn7u9N*XQ#:m_hJ}I?Z[">
        </block>
        </value>
        <next>
        <block type="update" id="KQ@D|~!qh5DVRf1T4QAs">
        <block type="variables_get" id="Y3@5-S6i,@~E5_UV-@~]">
        </block>
        </value>
        <next>
        <block type="debug" id="9[A8RHBuK9C7(CjYsv1)" collapsed="true" disabled="true">
        <field name="Severity">warn</field>
        <value name="TEXT">
        <shadow type="text" id="ffNm4A%)!%3?-L5=N8p#">
        </shadow>
        <block type="get_value" id="G0FJIHibRHZXk0INrT!G">
        </block>
        </value>
        <next>
        <block type="debug" id="C]|R$IM~z%vB*3-.FgLD" disabled="true">
        <value name="TEXT">
        </shadow>
        <block type="variables_get" id="/F11daBSG,_=r}~f/*[(">
        </block>
        </value>
        <next>
        <block type="comment" id="oWZ,asic)[u.{E0Kr^`a">
        <field name="COMMENT">Setze Timer auf 0 und aus wenn 1800 sekunden an</field>
        <next>
        <block type="controls_if" id="a#-)(`_@Zp[0PUXs~;~8">
        <value name="IF0">
        <block type="logic_operation" id="E/4#6`hFuy?`N626:g{f" inline="false">
        <field name="OP">AND</field>
        <value name="A">
        <block type="logic_compare" id="X+#SrT_Gnoj;p-kn~7tl">
        <field name="OP">LTE</field>
        <value name="A">
        <block type="get_value" id="g85MuYUv{`{Lx,Lv2Mg-">
        </block>
        </value>
        <value name="B">
        <block type="math_number" id="~:^1Eflfyi5`s0B#(!0:">
        <field name="NUM">1800</field>
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        <block type="logic_compare" id="rd`Gx0qu+pWl]O%yVWVI">
        <value name="A">
        <block type="get_value" id="+:l~yTb=NkVp@ZSOt93%">
        </block>
        </value>
        <value name="B">
        <block type="math_number" id="r%}Zp;Uwc/Nd[=d#w;A0">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <block type="variables_set" id="x:h4_{fdxFVuW^frO8qT">
        <block type="logic_boolean" id="mud]+!+GZ.y7T,7FFr%j">
        </block>
        </value>
        </block>
        </statement>
        <value name="IF1">
        <block type="logic_operation" id="WD#n}%%X6UkY2yy%sJ,f">
        <field name="OP">OR</field>
        <value name="A">
        <block type="logic_compare" id="6O)1MiB@8D/fb_-8s+Le">
        <field name="OP">EQ</field>
        <value name="A">
        <block type="get_value" id="`}[L2_rC_;K$a,3ZPlcV">
        </block>
        </value>
        <value name="B">
        <block type="math_number" id="-`G3p+e]FsUH:)~~}Q{6">
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        <block type="logic_compare" id="AGa$m(*~kQtdCy(Jr;Q#">
        <value name="A">
        <block type="variables_get" id="+3X/ZIGl[S5Hyej-`JfS">
        </block>
        </value>
        <value name="B">
        <block type="math_number" id="TV`$3~McX4Q0LXqKG/UC">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <block type="timeouts_clearinterval" id="W$#!+|u5+T2,LIHDs*]X">
        <next>
        <block type="variables_set" id="_f5F.0{s$4V`XHZ^BG0U">
        <block type="logic_boolean" id="!4r1`-=L%U,L/!4sCt6f">
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        <block type="variables_set" id="3@^K]j-j;ft3[w4+fw`D">
        <block type="logic_boolean" id="9KeLpUXS4tLq;a%5F4x/">
        </block>
        </value>
        <next>
        <block type="variables_set" id="J:FLiT6Cb5Oxs~+?*.UT">
        <block type="math_number" id="Qlti(`[f;rhQEOjj[uDj">
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        <next>
        <block type="controls_if" id="wS?Vj~b3DY6MQn#BoBX+">
        <value name="IF0">
        <block type="logic_operation" id="T%:F!ybSL3DB+ky_?5(V">
        <value name="A">
        <block type="variables_get" id="oz2,k;1~(@dh)$D_AE%m">
        </block>
        </value>
        <value name="B">
        <block type="variables_get" id="uv2:Zc!ieyN]Z$UAnQkc">
        </block>
        </value>
        </block>
        </value>
        <block type="controls_if" id="f=g,HJ`9Dkc$=CoDk^`n">
        <value name="IF0">
        <block type="logic_compare" id="!D0G2x[,UhkmMR?5?z%b">
        <value name="A">
        <block type="variables_get" id="5!?Yi]8MJY1syV3H_K7!">
        </block>
        </value>
        <value name="B">
        <block type="math_number" id="HoagxsfX3z{Vi)ujti;J">
        </block>
        </value>
        </block>
        </value>
        <block type="procedures_callnoreturn" id="LpV8;*1i~JE4vO!_jZP#">
        <mutation name="Stop_heizen"></mutation>
        </block>
        </statement>
        <block type="variables_set" id="=.uG8oOOgq0XQ^o|z6_D">
        <block type="logic_boolean" id="?THLi3F0]9(qX)fhLGMs">
        </block>
        </value>
        <next>
        <block type="update" id="G-{Y}{1p7+Fi}v^[}N$z" disabled="true">
        <field name="OID">tuya.0.bf2d324fcc025f1ef4swea.2</field>
        <block type="math_number" id="iPRoy;$c[aikdVz4ojjc">
        <field name="NUM">30</field>
        </block>
        </value>
        <next>
        <block type="controls_if" id="=1y]o$`O?S{HmT4wXdcf">
        <value name="IF0">
        <block type="logic_compare" id="j/thX%|3J?BXDRE{NyQB">
        <value name="A">
        <block type="get_value" id="+L3b`.vtY9dBjG~a?yzx">
        </block>
        </value>
        <value name="B">
        <block type="math_number" id="8rS9G4:x{weQ@lLd{zam">
        <field name="NUM">20.1</field>
        </block>
        </value>
        </block>
        </value>
        <block type="control" id="2L!,#^1Y$f`x^r2z`z{S">
        <block type="math_number" id="|Rymy)kvioqTh.,hi)S~">
        </block>
        </value>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </next>
        </block>
        </statement>
        <next>
        <block type="timeouts_clearinterval" id="it9I1FuPb-YLN9)eGVGj">
        <next>
        <block type="timeouts_setinterval" id=")DCko/rL6NjZ0+HHyX@H">
        <field name="INTERVAL">1</field>
        <block type="variables_set" id="MXN(xlU2:O]it/uL]DqJ">
        <block type="logic_boolean" id="3=5t{HoWSBN{t:2E?|:!">
        </block>
        </value>
        <next>
        <block type="math_change" id="y`O0tes!Z3A|VE(/5lGc">
        <value name="DELTA">
        <shadow type="math_number" id="ANCfoU/v0j!_vv*?),G?">
        </shadow>
        <block type="math_number" id="dG4cuG_m2Fk#HyCA(|NR">
        </block>
        </value>
        <next>
        <block type="update" id="+6f0[V5fh}Y@{ovyc^az">
        <block type="variables_get" id="|dT@BHeL;aApN6eY_J,,">
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
        </statement>
        <next>
        <block type="comment" id="$`^{/(x!j?Re.XU!TcbY">
        <field name="COMMENT">dsadas</field>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </statement>
        <value name="IF1">
        <block type="logic_negate" id="/@HvRn`byvBN|[s~2+qo" disabled="true">
        <value name="BOOL">
        <block type="variables_get" id="/AmJ-s?L_^2)X=b7yqX?">
        </block>
        </value>
        </block>
        </value>
        <block type="timeouts_clearinterval" id="B136.Zk0=)dZ^FRB?q2A" disabled="true">
        </block>
        </statement>
        <block type="controls_if" id="@CU~X61P8x}MQCcdEeRN">
        <value name="IF0">
        <block type="logic_compare" id="TGjM7_]x+_fug)zuy[()">
        <value name="A">
        <block type="get_value" id="OIT4brLcHpdS,/KKvmS^">
        </block>
        </value>
        <value name="B">
        <block type="math_number" id=";Bp,:5A(?gCv99_^yqW)">
        </block>
        </value>
        </block>
        </value>
        <block type="control" id="5f.@]AGm}tny;$]c;itg">
        <block type="math_number" id="o=p=I)HQFrWDz5vQn,[G">
        </block>
        </value>
        </block>
        </statement>
        </block>
        </statement>
        <next>
        <block type="update" id="O+}ll3|DgjT}::b*VD`l">
        <block type="variables_get" id="Lc_y6*F)bb9L,Glz:^/!">
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
                                                              </next>
                                                            </block>
                                                          </next>
                                                        </block>
                                                      </next>
                                                    </block>
                                                  </next>
                                                </block>
                                              </next>
                                            </block>
                                          </next>
                                        </block>
                                      </statement>
                                    </block>
                                  </next>
                                </block>
                              </next>
                            </block>
                          </next>
                        </block>
                      </next>
                    </block>
                  </next>
                </block>
              </next>
            </block>
          </next>
        </block>
        <block type="update" id="6FMGBDnU[@lJ;:P)O#*f" disabled="true" x="-37" y="-212">
            <block type="variables_get" id="_vH@ozJNgEF/vnhHG^f@">
            </block>
          </value>
        </block>
        <block type="on_ext" id="lJL!,IPb3Msxa$]eAhu:" disabled="true" x="263" y="-137">
          <field name="CONDITION">gt</field>
          <value name="OID0">
            <shadow type="field_oid" id="yhB223KLuz_.s#9qSmuu">
              <field name="oid">0_userdata.0.Badezimmer.dusche_an</field>
            </shadow>
          </value>
            <block type="controls_if" id="HOH[ZO!/LsEjG}FUmzIc">
              <value name="IF0">
                <block type="variables_get" id="m%@%S$B,%f.(F41#Z/g8">
                  <field name="VAR" id="G!7EQIfOiucgzA?bY2!+">block_timer1</field>
                </block>
              </value>
            </block>
          </statement>
        </block>
        <block type="logic_negate" id="|*bzgKhZe}mZFl3yJNm4" disabled="true" x="662" y="-62"></block>
        <block type="procedures_defnoreturn" id="u7V1g0S71sA0oxy]v,XJ" disabled="true" x="613" y="13">
          <field name="NAME">timer</field>
        </block>
        <block type="procedures_defnoreturn" id="D-8w/%Ws6+S=*7+N(9-U" x="12" y="1138">
          <field name="NAME">Stop_heizen</field>
          <statement name="STACK">
            <block type="timeouts_clearinterval" id="0t=]mztKBNoG+F}#t@5j">
              <next>
                <block type="variables_set" id="G6:Yt2E]%KNJ1gN6#7IU">
                    <block type="math_number" id="f3H[~@T{WIhVZ0Pi[E6|">
                    </block>
                  </value>
                  <next>
                    <block type="variables_set" id="75l3R8$:gJ1(l[L#+jB%">
                        <block type="logic_boolean" id="$?FXySZs_xXoG@X,+r,T">
                        </block>
                      </value>
                      <next>
                        <block type="update" id="By^bTKjkpQ/0.x+~6FH*" disabled="true">
                            <block type="math_number" id="JEGb|tblIyG,cwZ^Csx#">
                              <field name="NUM">20</field>
                            </block>
                          </value>
                          <next>
                            <block type="controls_if" id="XnT7;|/-VK#fEVQwa6m6">
                              <value name="IF0">
                                <block type="logic_compare" id="!n)Z_k4j`)c^AEtTv~q5">
                                  <value name="A">
                                    <block type="get_value" id="~8j0k)r@0pOzBxx7}uoT">
                                    </block>
                                  </value>
                                  <value name="B">
                                    <block type="math_number" id="@Bh{1aiX(by|sg,=6NF_">
                                    </block>
                                  </value>
                                </block>
                              </value>
                                <block type="control" id="Gw-J.hvUKDlu~b3!P{Fx">
                                    <block type="math_number" id="A[n5]MB~@og|=hsUH`Ak">
                                    </block>
                                  </value>
                                </block>
                              </statement>
                            </block>
                          </next>
                        </block>
                      </next>
                    </block>
                  </next>
                </block>
              </next>
            </block>
          </statement>
        </block>
      </xml>
      Nicoloma
      Nicoloma
    • Während Dusche, Handtuchheizung einschalten
      vielleicht kann mir einer helfen habe eine Blockade.
      Ich möchte das eine Handtuchheizungtermostat hoch gestellt wird wenn einer Duscht.
      Das ganze soll 30 minuten lang so bleiben.
      Er soll aber nicht während den Timer, die ganze Zeit Temperatur befehle senden. Sondern nur zu Anfang und zum Ende.
      Der Start wird durch Feuchtigkeitantieg registriert..
      Ich habe ein Script erstell, aber da blicke selbst ich nicht mehr durch 😄
      Ich haue es rein, damit keiner sagt ich habe mir keine Gedanken gemacht!
      var timer_an_aus, heiz_an_timer, dusche_an, block_timer1, tempDifferenz, liste, heiz_timer;
      // Beschreibe diese Funktion …
      async function Stop_heizen() {
        (() => { if (heiz_timer) { clearInterval(heiz_timer); heiz_timer = null; }})();
        heiz_an_timer = 0;
        timer_an_aus = false;
        if (getState('tuya.0.bf2d324fcc025f1ef4swea.2').val == 30) {
          setState('tuya.0.bf2d324fcc025f1ef4swea.2' /* temp_set */, 20.1);
      if (getState('0_userdata.0.Badezimmer.Timer_Badezimmer').val > 0) {
        timer_an_aus = true;
      } else {
      setState('0_userdata.0.Badezimmer.Timer_an' /* Timer_an */, timer_an_aus, true);
      dusche_an = getState('0_userdata.0.Badezimmer.dusche_an').val;
      tempDifferenz = getState('0_userdata.0.Badezimmer.feuchtigkeits_diff').val;
      liste = [];
      heiz_an_timer = getState('0_userdata.0.Badezimmer.Timer_Badezimmer').val;
      on({ id: 'mqtt.0.Esp_gross.temp_wohnzimmer.Humidity' /* Esp_gross/temp wohnzimmer/Humidity */, change: 'any' }, async (obj) => {
        let value = obj.state.val;
        let oldValue = obj.oldState.val;
        liste.push(getState('mqtt.0.Esp_gross.temp_wohnzimmer.Humidity').val);
        if (liste.length >= 5) {
          liste.shift();
        tempDifferenz = liste.slice(-1)[0] - liste[0];
        setState('0_userdata.0.Badezimmer.feuchtigkeits_diff' /* feuchtigkeits_diff */, tempDifferenz, true);
        if (tempDifferenz > 4) {
          dusche_an = true;
        } else if (tempDifferenz < -4) {
          // Dusche zuende_es wurd gelüftet
          dusche_an = false;
        } else {
          dusche_an = false;
        setState('0_userdata.0.Badezimmer.dusche_an' /* dusche_an */, dusche_an, true);
        // Setze Timer auf 0 und aus wenn 1800 sekunden an
        if (getState('0_userdata.0.Badezimmer.Timer_Badezimmer').val <= 1800 && getState('0_userdata.0.Badezimmer.Timer_Badezimmer').val >= 1) {
        } else if (getState('0_userdata.0.Badezimmer.Timer_Badezimmer').val == 0 || heiz_an_timer == 0) {
        } else {
          heiz_an_timer = 0;
        if (timer_an_aus || dusche_an) {
          if (heiz_an_timer >= 1800) {
            await Stop_heizen();
          } else if (false) {
          } else {
            if (getState('tuya.0.bf2d324fcc025f1ef4swea.2').val == 20.1) {
              setState('tuya.0.bf2d324fcc025f1ef4swea.2' /* temp_set */, 30);
          heiz_timer = setInterval(async () => {
            heiz_an_timer = (typeof heiz_an_timer === 'number' ? heiz_an_timer : 0) + 1;
            setState('0_userdata.0.Badezimmer.Timer_Badezimmer' /* Timer_Badezimmer */, heiz_an_timer, true);
          }, 1000);
          // dsadas
        } else if (false) {
        } else {
      Nicoloma
      Nicoloma
    • RE: [Neuer Adapter] mediola-gateway
      @oelison Super danke
      Nicoloma
      Nicoloma
    • *ERLEDIGT*Handtuchheizung, TIMER Problem
      ich schreibe schon seit einiger Zeit an meinem Blockly.
      ABER:
      • Er hört erst bei 1809 Sekunden auf
      • Er startet nach 10 Sekunden wieder den TImer
        <variables>
          <variable id="*VDIMI93Si7+.0,*m?D$">heizbedarf</variable>
        </variables>
        <block type="update" id="6FMGBDnU[@lJ;:P)O#*f" disabled="true" x="-362" y="-162">
            </block>
          </value>
        </block>
        <block type="variables_set" id="*8o}a($+Jq37{Hqnf09q" x="-463" y="-88">
            </block>
          </value>
          <next>
                </block>
              </value>
              <next>
                    </block>
                  </value>
                  <next>
                      <next>
                            </block>
                          </value>
                          <next>
                                <block type="controls_if" id="QJDXSGQ,lvALqN0T5`(s" collapsed="true" disabled="true">
                                  <value name="IF0">
                                    <block type="logic_compare" id="y~u3B*g0o]-9pgpL^#^%">
                                      <value name="A">
                                        <block type="get_value" id="U3g{9w4m8GcEa:BKc7F7">
                                          <field name="OID">tuya.0.bf2d324fcc025f1ef4swea.3</field>
                                        </block>
                                      </value>
                                      <value name="B">
                                        <block type="get_value" id="{d6R:-2qAROHDCgKNtEb">
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                    <block type="variables_set" id="72ImrJ1ARW7VU[`6$bJF">
                                      <field name="VAR" id="*VDIMI93Si7+.0,*m?D$">heizbedarf</field>
                                        <block type="logic_boolean" id=",SeL[`*rC5DE!813)i~l">
                                        </block>
                                      </value>
                                    </block>
                                  </statement>
                                    <block type="variables_set" id="A@A=T9ZpDP3Do|a.aYJ1">
                                        <block type="logic_boolean" id="*CpX4mYAyy#$put1:iY6">
                                        </block>
                                      </value>
                                    </block>
                                  </statement>
                                  <next>
                                    <block type="debug" id="-4?ZpyvExG:MbRmzP!|1" collapsed="true" disabled="true">
                                      <value name="TEXT">
                                        <shadow type="text" id="WhMK}rs~DirtWG9qaygI">
                                        </shadow>
                                        <block type="text_join" id="(@y~(jMSUf(HxL1^mFTA">
                                          <value name="ADD0">
                                            <block type="text" id="iW1x*9QjY/m~0@}0A[@?">
                                              <field name="TEXT">Heizbedarf:</field>
                                            </block>
                                          </value>
                                          <value name="ADD1">
                                            <block type="variables_get" id="Ai#h$ZL/cn:-%nyT~ZR!">
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                      <next>
                                        <block type="debug" id="L;axa0y#O]vgNqmxsZoo" collapsed="true" disabled="true">
                                          <value name="TEXT">
                                            </shadow>
                                            <block type="text_join" id="w:o`5Y2vmz(P,K#ts~gu">
                                              <value name="ADD0">
                                                <block type="text" id="RJEhA_fiFeYmFmQkErTc">
                                                  <field name="TEXT">feuchtigkeit</field>
                                                </block>
                                              </value>
                                              <value name="ADD1">
                                                <block type="get_value" id="=1OD#kP(/5a9Jz!)^[%-">
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                          <next>
                                            <block type="debug" id="iK4oTMchdCobt2?x+.1I" collapsed="true" disabled="true">
                                              <value name="TEXT">
                                                <shadow type="text" id="8W*Tyzn,a-O*N(9T?CBk">
                                                </shadow>
                                              </value>
                                              <next>
                                                  <value name="LIST">
                                                    </block>
                                                  </value>
                                                  <value name="TO">
                                                    </block>
                                                  </value>
                                                  <next>
                                                      <value name="IF0">
                                                          <value name="A">
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </statement>
                                                      <next>
                                                              <value name="A">
        </shadow>
        </block>
        </value>
        </block>
                                                              </value>
                                                              <value name="B">
        </shadow>
        </block>
        </value>
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                          <next>
        </block>
                                                              </value>
                                                              <next>
        <value name="IF0">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        <block type="debug" id="6h^S`xnhaHx3daVj~,Gg" collapsed="true" disabled="true">
        <value name="TEXT">
        <shadow type="text" id="|KZxaQ,]:*kzmZO:3f@T">
        </shadow>
        <block type="text_join" id="]0HSy_vV^2:V#lx+t249">
        <value name="ADD0">
        <block type="text" id="#Le*t:RE_B44..|sR}Gn">
        <field name="TEXT">Feuchtigkeitdifferenz: </field>
        </block>
        </value>
        <value name="ADD1">
        <block type="math_arithmetic" id="~o$+Bkb]~]h30+ZiCU1u">
        <value name="A">
        </shadow>
        <block type="lists_getIndex" id="S9B-PFM]~gcJ,1i3e_p:">
        <block type="variables_get" id="_3m5r{Glrg0=8loaaGP8">
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        </shadow>
        <block type="lists_getIndex" id="YC]eFfa?/SA)=-2!CAa~">
        <block type="variables_get" id="`Isazr*%I{@,T:eeVORP">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        <value name="IF1">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </value>
        </block>
        </statement>
        <next>
        <block type="update" id="@i2$cSGBn(gW,igPr/6U" disabled="true">
        <block type="variables_get" id="/CLaCUl{{|UgMrm0*]my">
        </block>
        </value>
        <next>
        <block type="debug" id="hor#t7q.L%Q3Q/QML$Nk" collapsed="true" disabled="true">
        <value name="TEXT">
        </shadow>
        <block type="variables_get" id="S9W0}rkh=K9N0P)aceu3">
        </block>
        </value>
        <next>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
        <next>
        <block type="debug" id="C]|R$IM~z%vB*3-.FgLD">
        <value name="TEXT">
        </shadow>
        </block>
        </value>
        <next>
        <next>
        <value name="IF0">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </statement>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        <next>
        <value name="IF0">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        <next>
        <value name="IF0">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        <next>
        </block>
        </value>
        <next>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </value>
        <next>
        </block>
        </value>
        <next>
        <block type="control" id="x7ws^y!:Xru;B=)7ZWyy">
        <block type="math_number" id="v+$_mi7j5DcLa@A`y5#@">
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
        </statement>
        <next>
        <next>
        </block>
        </value>
        <next>
        </shadow>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </statement>
        <value name="IF1">
        <block type="logic_negate" id="/@HvRn`byvBN|[s~2+qo">
        <value name="BOOL">
        </block>
        </value>
        </block>
        </value>
        <block type="timeouts_clearinterval" id="B136.Zk0=)dZ^FRB?q2A">
        </block>
        </statement>
        <block type="timeouts_clearinterval" id="fU4QN3#KMisi1vN{-JT[">
        </block>
        </statement>
        <next>
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
                                                              </next>
                                                            </block>
                                                          </next>
                                                        </block>
                                                      </next>
                                                    </block>
                                                  </next>
                                                </block>
                                              </next>
                                            </block>
                                          </next>
                                        </block>
                                      </next>
                                    </block>
                                  </next>
                                </block>
                              </statement>
                            </block>
                          </next>
                        </block>
                      </next>
                    </block>
                  </next>
                </block>
              </next>
            </block>
          </next>
        </block>
      </xml>
      Nicoloma
      Nicoloma
      @oelison
      also ich habs gefunden... es ist die 55. Aber die 55 funktioniert nicht wenn ich es in die States eingebe.0682926b-ea7d-4eed-b9a2-ebfc74c15619-image.png
      Nicoloma
      Nicoloma
      @oelison Hallo,
      also ich weis nicht warum es vor einigen Wochen nicht funktionierte. Aber es funktioniert.
      Aber er kann nicht stoppen. 1,2 funktioniert aber 3 Stoppen nicht.
      Woran kann es liegen?
      Nicoloma
      Nicoloma
      @oelison
      mediola-gateway.0
      2024-01-21 22:16:58.126	debug	state mediola-gateway.0.sysvars.id04 changed: 1 (ack = true)
      mediola-gateway.0
      2024-01-21 22:16:58.126	silly	States user redis pmessage mediola-gateway.0.sysvars.id*/mediola-gateway.0.sysvars.id04:{"val":"1","ack":true,"ts":1705871818125,"q":0,"from":"system.adapter.mediola-gateway.0","user":"system.user.admin","lc":1705615620733}
      mediola-gateway.0
      2024-01-21 22:16:58.042	debug	state mediola-gateway.0.sysvars.id06 changed: 1 (ack = true)
      mediola-gateway.0
      2024-01-21 22:16:58.042	silly	States user redis pmessage mediola-gateway.0.sysvars.id*/mediola-gateway.0.sysvars.id06:{"val":"1","ack":true,"ts":1705871818040,"q":0,"from":"system.adapter.mediola-gateway.0","user":"system.user.admin","lc":1705615620733}
      mediola-gateway.0
      2024-01-21 22:16:58.041	debug	state mediola-gateway.0.sysvars.id03 changed: 1 (ack = true)
      mediola-gateway.0
      2024-01-21 22:16:58.041	silly	States user redis pmessage mediola-gateway.0.sysvars.id*/mediola-gateway.0.sysvars.id03:{"val":"1","ack":true,"ts":1705871818038,"q":0,"from":"system.adapter.mediola-gateway.0","user":"system.user.admin","lc":1705615620733}
      mediola-gateway.0
      2024-01-21 22:16:58.041	debug	state mediola-gateway.0.sysvars.id05 changed: 1 (ack = true)
      mediola-gateway.0
      2024-01-21 22:16:58.040	silly	States user redis pmessage mediola-gateway.0.sysvars.id*/mediola-gateway.0.sysvars.id05:{"val":"1","ack":true,"ts":1705871818038,"q":0,"from":"system.adapter.mediola-gateway.0","user":"system.user.admin","lc":1705615620691}
      mediola-gateway.0
      2024-01-21 22:16:58.040	debug	state mediola-gateway.0.sysvars.id01 changed: 0 (ack = true)
      mediola-gateway.0
      2024-01-21 22:16:58.039	silly	States user redis pmessage mediola-gateway.0.sysvars.id*/mediola-gateway.0.sysvars.id01:{"val":"0","ack":true,"ts":1705871818038,"q":0,"from":"system.adapter.mediola-gateway.0","user":"system.user.admin","lc":1705615620691}
      mediola-gateway.0
      2024-01-21 22:16:58.036	debug	{"type":"EVENT","adr":"04","state":"1"}
      mediola-gateway.0
      2024-01-21 22:16:58.036	debug	{"type":"EVENT","adr":"06","state":"1"}
      mediola-gateway.0
      2024-01-21 22:16:58.036	debug	{"type":"EVENT","adr":"03","state":"1"}
      mediola-gateway.0
      2024-01-21 22:16:58.035	debug	{"type":"EVENT","adr":"05","state":"1"}
      mediola-gateway.0
      2024-01-21 22:16:58.035	debug	{"type":"EVENT","adr":"01","state":"0"}
      mediola-gateway.0
      2024-01-21 22:16:58.034	debug	mediola device found data: [{"type":"EVENT","adr":"01","state":"0"},{"type":"EVENT","adr":"05","state":"1"},{"type":"EVENT","adr":"03","state":"1"},{"type":"EVENT","adr":"06","state":"1"},{"type":"EVENT","adr":"04","state":"1"}]
      mediola-gateway.0
      2024-01-21 22:16:58.034	debug	"{XC_SUC}[{\"type\":\"EVENT\",\"adr\":\"01\",\"state\":\"0\"},{\"type\":\"EVENT\",\"adr\":\"05\",\"state\":\"1\"},{\"type\":\"EVENT\",\"adr\":\"03\",\"state\":\"1\"},{\"type\":\"EVENT\",\"adr\":\"06\",\"state\":\"1\"},{\"type\":\"EVENT\",\"adr\":\"04\",\"state\":\"1\"}]"
      mediola-gateway.0
      2024-01-21 22:16:57.895	debug	Source: onReady
      mediola-gateway.0
      2024-01-21 22:16:57.887	debug	http://192.168.178.144/command?XC_USER=admin&XC_PASS=sagichnicht&XC_FNC=getstates
      mediola-gateway.0
      2024-01-21 22:16:57.887	debug	validMediola: true sysvarInti: false timerRead: false cmd false pull false
      mediola-gateway.0
      2024-01-21 22:16:57.887	info	Mediola connected with ip:192.168.178.144 and mac:40-66-7a-00-6e-3f
      mediola-gateway.0
      2024-01-21 22:16:57.887	debug	code_text
      Nicoloma
      Nicoloma
      @oelison danke dir du bist der beste. ich probiere es sofort aus.
      Nicoloma
      Nicoloma
      @oelison Hmm ich habe aber Codes wie "D70D8CE144" nicht NY....
      GetAll
      {"XC_SUC":[{"sys":"ASTRO","id":"03","days":"1111111","time":"2","dateStart":"2000-00-00","dateEnd":"2099-00-00","delay":"000F","t":"","l":""},{"sys":"ACTION","id":"08","type":"NY","code":"D70D8CE144","rf":"00","ir":"00"},{"sys":"ACTION","id":"09","type":"NY","code":"D70D670144","rf":"00","ir":"00"},{"sys":"ACTION","id":"0A","type":"NY","code":"D60D23C144","rf":"00","ir":"00"},{"sys":"ACTION","id":"0B","type":"NY","code":"D70D37B144","rf":"00","ir":"00"},{"sys":"ACTION","id":"0C","type":"NY","code":"D70D95A144","rf":"00","ir":"00"},
      Nicoloma
      Nicoloma
