@crunchip
ich öffne es mit Fireox, wenn du das meinst
@Homoran
vorher ist es mir jedenfalls nicht aufgefallen, greife nur selten darauf zu.
An Hardware wurde nichts verändert und an der Software bewusst auch nichts, außer evtl updates der adapter etc.
@Glasfaser
pi@raspberrypi4-iob:~ $ cd /opt/iobroker
npm ls | grep -E 'github.com|ERR'
iobroker update -i
sudo ln -s /usr/bin/node /usr/bin/nodejs
uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami        && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejspi        @raspberrypi4-iob:/opt/iobroker $
pi@raspberrypi4-iob:/opt/iobroker $ npm ls | grep -E 'github.com|ERR'
│ └─┬ syno@3.0.0 (git+https://github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
pi@raspberrypi4-iob:/opt/iobroker $ iobroker update -i
Used repository: stable
Adapter    "admin"        : 5.3.8    , installed 5.3.8
Adapter    "backitup"     : 2.4.10   , installed 2.4.10
Adapter    "ble"          : 0.13.0   , installed 0.12.0 [Updatable]
Adapter    "blebox"       : 1.0.0    , installed 1.0.0
Adapter    "cloud"        : 4.1.1    , installed 4.1.1
Adapter    "deconz"       : 1.3.21   , installed 1.3.21
Adapter    "denon"        : 1.13.4   , installed 1.13.4
Adapter    "discovery"    : 3.0.5    , installed 3.0.3  [Updatable]
Adapter    "flot"         : 1.11.0   , installed 1.11.0
Adapter    "fritzdect"    : 2.2.3    , installed 2.2.3
Adapter    "go-e"         : 1.0.23   , installed 1.0.23
Adapter    "history"      : 2.2.0    , installed 1.11.1 [Updatable]
Adapter    "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
Adapter    "icons-icons8" : 0.0.1    , installed 0.0.1
Adapter    "icons-material-png": 0.1.0, installed 0.1.0
Adapter    "icons-mfd-svg": 1.1.0    , installed 1.1.0
Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
Adapter    "info"         : 1.9.19   , installed 1.9.19
Adapter    "iot"          : 1.11.8   , installed 1.11.4 [Updatable]
Adapter    "javascript"   : 5.7.0    , installed 5.7.0
Controller "js-controller": 4.0.23   , installed 4.0.23
Adapter    "mihome-vacuum": 3.4.2    , installed 3.4.2
Adapter    "mpd"          : 1.0.6    , installed 1.0.6
Adapter    "nuki-extended": 2.3.1    , installed 2.3.1
Adapter    "ping"         : 1.5.3    , installed 1.5.3
Adapter    "plex"         : 0.9.1    , installed 0.9.1
Adapter    "sayit"        : 1.12.3   , installed 1.12.3
Adapter    "scenes"       : 2.3.9    , installed 2.3.9
Adapter    "shelly"       : 6.0.0    , installed 5.3.2  [Updatable]
Adapter    "simple-api"   : 2.7.0    , installed 2.6.5  [Updatable]
Adapter    "socketio"     : 4.2.0    , installed 4.2.0
Adapter    "synology"     : 2.1.9    , installed 2.1.7  [Updatable]
Adapter    "telegram"     : 1.13.0   , installed 1.12.6 [Updatable]
Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
Adapter    "tuya"         : 3.6.15   , installed 3.6.15
Adapter    "vis"          : 1.4.15   , installed 1.4.15
Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
Adapter    "vis-icontwo"  : 0.89.0   , installed 0.87.0 [Updatable]
Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
Adapter    "vis-jqui-mfd" : 1.0.12   , installed 1.0.12
Adapter    "web"          : 4.3.0    , installed 4.3.0
Adapter    "ws"           : 1.3.0    , installed 1.3.0
Adapter    "yeelight-2"   : 1.1.2    , installed 1.1.2
pi@raspberrypi4-iob:/opt/iobroker $ sudo ln -s /usr/bin/node /usr/bin/nodejs
ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
pi@raspberrypi4-iob:/opt/iobroker $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
armv7l
/usr/bin/nodejs
/usr/bin/node
/usr/bin/npm
v14.20.0
v14.20.0
6.14.17
pi
/opt/iobroker
OK:1 http://archive.raspberrypi.org/debian buster InRelease
OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
OK:3 https://deb.nodesource.com/node_14.x buster InRelease
OK:4 https://phoscon.de/apt/deconz buster InRelease
Alle Pakete sind aktuell.
nodejs:
  Installiert:           14.20.0-deb-1nodesource1
  Installationskandidat: 14.20.0-deb-1nodesource1
  Versionstabelle:
 *** 14.20.0-deb-1nodesource1 500
        500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
        100 /var/lib/dpkg/status
     10.24.0~dfsg-1~deb10u1 500
Danke für eure Mühe
Was mir ebend aufgefallen ist:
Wenn ich über die Befehle
sudo iobroker stop
sudo iobroker update
sudo iobroker upgrade self
sudo iobroker start
updaten will, erscheint folgende Meldung:
pi@raspberrypi4-iob:/opt/iobroker $ sudo iobroker stop
pi@raspberrypi4-iob:/opt/iobroker $ sudo iobroker update
No connection to databases possible ...
pi@raspberrypi4-iob:/opt/iobroker $ sudo iobroker upgrade self
pi@raspberrypi4-iob:/opt/iobroker $ sudo iobroker start
Ist doch auch nicht normal
