    2. jvkronenberg78
    J
    • Posts 6
    jvkronenberg78
    @jvkronenberg78
    Email vankronenberg@freenet.de
    jvkronenberg78 Follow
    Latest posts made by jvkronenberg78
    • RE: Neuer Alexa-Skill "iobroker.assistant"
      @apollon77 Ja ist nur V3 aktiviert
      posted in Cloud Dienste
      J
      jvkronenberg78
      @apollon77 Hi, nein ich habe alles wie immer in Kleinbuchstaben eingegeben.
      J
      jvkronenberg78
      @samson71 Hi, habe ich schon getestet. Aber es funktioniert leider nicht. Habe die Instanz auch schon glöscht, bzw. den kompltten Adapter usw. aber es bringt leider nichts. Hier ist das Log.
      iot.1
      	2025-11-01 13:17:31.349	info	Connection changed: disconnect
      iot.1
      	2025-11-01 13:17:11.137	info	Connection changed: disconnect
      iot.1
      	2025-11-01 13:17:00.958	info	Connection changed: disconnect
      iot.1
      	2025-11-01 13:16:55.754	info	Connection changed: disconnect
      iot.1
      	2025-11-01 13:16:55.039	info	Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
      iot.1
      	2025-11-01 13:16:54.825	error	Please write your login only in lowercase!
      iot.1
      	2025-11-01 13:16:54.785	info	starting. Version 5.0.5 in /opt/iobroker/node_modules/iobroker.iot, node: v20.18.3, js-controller: 7.0.7
      iot.1
      	2025-11-01 13:16:30.350	info	terminating
      iot.1
      	2025-11-01 13:16:29.847	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      iot.1
      	2025-11-01 13:16:29.845	info	terminating
      iot.1
      	2025-11-01 13:16:29.843	info	Got terminate signal TERMINATE_YOURSELF
      iot.1
      	2025-11-01 13:16:04.164	error	No cloud credentials found. Please get one on https://iobroker.pro
      iot.1
      	2025-11-01 13:16:04.135	info	starting. Version 5.0.5 in /opt/iobroker/node_modules/iobroker.iot, node: v20.18.3, js-controller: 7.0.7
      iot.1
      	2025-11-01 13:15:40.016	info	terminating
      iot.1
      	2025-11-01 13:15:39.685	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      iot.1
      	2025-11-01 13:15:39.683	info	terminating
      iot.1
      	2025-11-01 13:15:39.493	info	Got terminate signal TERMINATE_YOURSELF
      iot.1
      	2025-11-01 13:15:30.829	info	Connection changed: disconnect
      iot.1
      	2025-11-01 13:15:20.638	info	Connection changed: disconnect
      iot.1
      	2025-11-01 13:15:15.457	info	Connection changed: disconnect
      iot.1
      	2025-11-01 13:15:12.089	info	Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
      iot.1
      	2025-11-01 13:15:11.940	error	Please write your login only in lowercase!
      iot.1
      	2025-11-01 13:15:11.915	info	starting. Version 5.0.5 in /opt/iobroker/node_modules/iobroker.iot, node: v20.18.3, js-controller: 7.0.7
      iot.1
      	2025-11-01 13:14:54.464	info	terminating
      iot.1
      	2025-11-01 13:14:54.129	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      iot.1
      	2025-11-01 13:14:54.126	info	terminating
      iot.1
      	2025-11-01 13:14:53.542	info	Got terminate signal TERMINATE_YOURSELF
      iot.1
      	2025-11-01 13:14:34.796	info	Connection changed: disconnect
      iot.1
      	2025-11-01 13:13:54.597	info	Connection changed: disconnect
      iot.1
      	2025-11-01 13:13:34.410	info	Connection changed: disconnect
      iot.1
      	2025-11-01 13:13:24.095	info	Connection changed: disconnect
      iot.1
      	2025-11-01 13:13:18.827	info	Connection changed: disconnect
      iot.1
      	2025-11-01 13:13:16.986	info	Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
      iot.1
      	2025-11-01 13:13:16.797	error	Please write your login only in lowercase!
      iot.1
      	2025-11-01 13:13:16.756	info	starting. Version 5.0.5 in /opt/iobroker/node_modules/iobroker.iot, node: v20.18.3, js-controller: 7.0.7
      iot.1
      	2025-11-01 13:13:07.557	info	terminating
      iot.1
      	2025-11-01 13:13:07.212	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      iot.1
      	2025-11-01 13:13:07.210	info	terminating
      iot.1
      	2025-11-01 13:13:07.028	info	Got terminate signal TERMINATE_YOURSELF
      iot.1
      	2025-11-01 13:12:06.438	info	Connection changed: disconnect
      iot.1
      	2025-11-01 13:11:26.264	info	Connection changed: disconnect
      iot.1
      	2025-11-01 13:11:06.056	info	Connection changed: disconnect
      iot.1
      	2025-11-01 13:10:55.869	info	Connection changed: disconnect
      iot.1
      	2025-11-01 13:10:50.695	info	Connection changed: disconnect
      iot.1
      	2025-11-01 13:10:50.689	warn	Looks like your connection certificates are invalid. Please renew them via configuration dialog.
      iot.1
      	2025-11-01 13:10:49.220	info	Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
      iot.1
      	2025-11-01 13:10:49.091	error	Please write your login only in lowercase!
      iot.1
      	2025-11-01 13:10:49.061	info	starting. Version 5.0.5 in /opt/iobroker/node_modules/iobroker.iot, node: v20.18.3, js-controller: 7.0.7
      iot.1
      	2025-11-01 13:10:40.334	info	terminating
      iot.1
      	2025-11-01 13:10:39.830	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      iot.1
      	2025-11-01 13:10:39.825	info	terminating
      iot.1
      	2025-11-01 13:10:39.817	info	Got terminate signal TERMINATE_YOURSELF
      iot.1
      	2025-11-01 13:10:39.773	info	Migrating amazonCustom configuration to true
      iot.1
      	2025-11-01 13:10:39.686	info	starting. Version 5.0.5 in /opt/iobroker/node_modules/iobroker.iot, node: v20.18.3, js-controller: 7.0.7
      J
      jvkronenberg78
      Bei mir wird der Adapter nicht grün und im Log steht die ganze Zeit disconnect. Als Fehler steht dort Please write your login only in lowercase!. Der Login vom Pro Account funktioniert und ich habe ihn auch nicht geändert und der Benutzername ist nur in Kleinbuchstaben eingegeben. Im Passwort sind auch Großbuchstaben vorhanden, aber das wird ja damit nicht zu tun haben oder?
      J
      jvkronenberg78
    • RE: Kaco Blueplanet NX3 M2->RS485 TO POE ETH an Modbus Problem
      @mitch23 sagte in Kaco Blueplanet NX3 M2->RS485 TO POE ETH an Modbus Problem:
      @wierer-sigi
      Der Kaco WR lässt sich direkt abfragen, wenn eine WLAN-Verbindung eingerichtet ist. Ein RS485 Adapter auf TCP ist nicht nötig. Die Einstellung habe ich in deinem anderen Thread gepostet.
      Hi, ich nutze den WLAN Stick von Kaco. Kannst du mir sagen, wie ich per WLAN die Daten in den ioBroker bekomme? Habe keinen Adapter dafür gefunden, oder verstehe ich dich da falsch?
      J
      jvkronenberg78
    • Node-Red Adapter GPIO stopped
      Hallo zusammen!
      Ich habe einen ioBroker als Multihost in einem Docker auf meiner QNAP laufen. Ich habe vor ein paar Wochen meinen Raspberry 3 als Slave hinzugefügt.
      Mit diesem habe ich per Node-Red ein paar GPIOs angesteuert um mit diesen später Ventile für die Gartenbewässerung zu steuern. Jetzt wollte ich gestern meinen neuen Raspberry 4 hinzufügen um ihn gegen den Raspberry 3 zu tauschen. Soviel zum Hintergrund.
      Ich hatte erst beide Raspberry als Host am laufen, da ich die Einstellungen usw. von einem zum anderen übertragen wollte. Nachdem das erledigt war, habe ich den Raspberry Slave aus den Hosts entfernt. Alles funktioniert soweit, nur dass die GPIOs, die ich vorher beim Raspberry 3 Slave angesteuert hatte, nicht mehr beim Raspberry 4 Slave funktionieren. Dort steht bei den Ausgängen „Stopped“ und bei den Eingängen „not running“. Wenn ich jetzt andere GPIO Pins benutze, die ich vorher nicht benutzt hatte, funktioniert es. Anscheinend sind diese GPIO Pins irgendwo noch in Benutzung oder ähnliches.
      Hier ist ein Bild des funktionierenden Flows
      Und hier ist ein Bild des NICHT funktionierenden Flows
      Im Log vom ioBroker bekomme ich diese ganze Meldungen wenn ich den nicht funktionierenden Flow aktiviere
      Eine grundsätzliche Frage habe ich da auch noch:
      Ist es eigentlich gar nicht möglich 2 Raspberry’s unabhängig von einander anzusteuern, bzw. dessen GPIOs zu steuern?
      J
      jvkronenberg78
