  4. [gefixed]Update S7 Adapter auf 1.0.3 fehlgeschlagen
8 Beiträge 4 Kommentatoren 1.5k Aufrufe
  • blauholstenB Offline
    blauholsten
    die "neuste" Version vom S7 Adapter scheint nicht zu funktionieren….
    2017-11-29 15:54:51.737  - [32minfo[39m: host.iobroker instance system.adapter.s7.0 started with pid 6857
    2017-11-29 15:54:52.143  - [32minfo[39m: s7.0 starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.s7, node: v8.9.1
    2017-11-29 15:54:52.419  - [31merror[39m: s7.0 Writing DB. Code #TypeError: Cannot read property 'lsb' of undefined
    2017-11-29 15:54:52.449  - [31merror[39m: s7.0 uncaught exception: Cannot read property 'lsb' of undefined
    2017-11-29 15:54:52.449  - [31merror[39m: s7.0 TypeError: Cannot read property 'lsb' of undefined
        at /opt/iobroker/node_modules/iobroker.s7/main.js:1187:74
        at /opt/iobroker/node_modules/iobroker.s7/node_modules/async/lib/async.js:52:16
        at done (/opt/iobroker/node_modules/iobroker.s7/node_modules/async/lib/async.js:246:17)
        at /opt/iobroker/node_modules/iobroker.s7/node_modules/async/lib/async.js:44:16
        at /opt/iobroker/node_modules/iobroker.s7/main.js:1158:33
    Sorry für den komischen Log, aber musste es aus der Datei raus kopieren….
    Entwickler vom: - Viessman Adapter
    - Alarm Adapter
    • inlineI Offline
      inlineI Offline
      inline
      Bei mir klappt der Update ebenfalls nicht.
      Hier ein Log:
      ! root:/opt/iobroker# ./iobroker upgrade s7@1.0.3
      ! Update s7 from @1.0.2 to @1.0.3
      ! npm install iobroker.s7@1.0.3 –production --prefix "/opt/iobroker" (System call)
      ! npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.s7"
      ! prebuild-install info begin Prebuild-install version 2.3.0
      ! prebuild-install info looking for local prebuild @ prebuilds/node-snap7-v0.4.0-node-v48-linux-arm.tar.gz
      ! prebuild-install info looking for cached prebuild @ /root/.npm/_prebuilds/https-github.com-mathiask88-node-snap7-releases-download-v0.4.0-node-snap7-v0.4.0-node-v48-linux-arm.tar.gz
      ! prebuild-install http request GET https://github.com/mathiask88/node-snap ... arm.tar.gz
      ! prebuild-install http 404 https://github.com/mathiask88/node-snap ... arm.tar.gz
      ! prebuild-install WARN install No prebuilt binaries found (target=6.11.2 runtime=node arch=arm platform=linux)
      ! ../deps/snap7/src/core/s7_isotcp.cpp: In member function ‘int TIsoTcpSocket::IsoConfirmConnection(u_char)’:
      ! ../deps/snap7/src/core/s7_isotcp.cpp:163:10: warning: variable ‘TempRef’ set but not used [-Wunused-but-set-variable]
      ! u_short TempRef;
      ! ../deps/snap7/src/core/s7_server.cpp: In member function ‘word TS7Worker::ReadArea(PResFunReadItem, PReqFunReadItem, int&, TEv&)’:
      ! ../deps/snap7/src/core/s7_server.cpp:454:44: warning: ‘BitIndex’ may be used uninitialized in this function [-Wmaybe-uninitialized]
      ! if ((ByteVal & BitMask[BitIndex])!=0)
      ! ../deps/snap7/src/core/s7_server.cpp: In member function ‘byte TS7Worker::WriteArea(PReqFunWriteDataItem, PReqFunWriteItem, TEv&)’:
      ! ../deps/snap7/src/core/s7_server.cpp:698:41: warning: ‘BitIndex’ may be used uninitialized in this function [-Wmaybe-uninitialized]
      ! *Target=*Target | BitMask[BitIndex];
      ! ../deps/snap7/src/core/s7_micro_client.cpp: In member function ‘int TSnap7MicroClient::opUpload()’:
      ! ../deps/snap7/src/core/s7_micro_client.cpp:1225:13: warning: ‘BlockLength’ may be used uninitialized in this function [-Wmaybe-uninitialized]
      ! if (opSize<1)
      ! ../src/node_snap7_server.cpp: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE node_snap7::S7Server::RWBufferCallback(Nan::NAN_METHOD_ARGS_TYPE)’:
      ! ../src/node_snap7_server.cpp:720:56: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
      ! if (node::Buffer::Length(info[0].Asv8::object()) < size) {
      ! got /opt/iobroker/node_modules/iobroker.s7/admin
      ! upload [11] s7.admin /opt/iobroker/node_modules/iobroker.s7/admin/words.js words.js application/javascript
      ! upload [10] s7.admin /opt/iobroker/node_modules/iobroker.s7/admin/lib/js/jsgrid.min.js lib/js/jsgrid.min.js application/javascript
      ! upload [9] s7.admin /opt/iobroker/node_modules/iobroker.s7/admin/lib/js/jsgrid.js lib/js/jsgrid.js application/javascript
      ! upload [8] s7.admin /opt/iobroker/node_modules/iobroker.s7/admin/lib/js/grid.locale-ru.js lib/js/grid.locale-ru.js application/javascript
      ! upload [7] s7.admin /opt/iobroker/node_modules/iobroker.s7/admin/lib/js/grid.locale-de.js lib/js/grid.locale-de.js application/javascript
      ! upload [6] s7.admin /opt/iobroker/node_modules/iobroker.s7/admin/lib/css/jsgrid.min.css lib/css/jsgrid.min.css text/css
      ! upload [5] s7.admin /opt/iobroker/node_modules/iobroker.s7/admin/lib/css/jsgrid.css lib/css/jsgrid.css text/css
      ! upload [4] s7.admin /opt/iobroker/node_modules/iobroker.s7/admin/lib/css/jsgrid-theme.min.css lib/css/jsgrid-theme.min.css text/css
      ! upload [3] s7.admin /opt/iobroker/node_modules/iobroker.s7/admin/lib/css/jsgrid-theme.css lib/css/jsgrid-theme.css text/css
      ! upload [2] s7.admin /opt/iobroker/node_modules/iobroker.s7/admin/index.html index.html text/html
      ! upload [1] s7.admin /opt/iobroker/node_modules/iobroker.s7/admin/img/plc_back.png img/plc_back.png image/png
      ! upload [0] s7.admin /opt/iobroker/node_modules/iobroker.s7/admin/S7.png S7.png image/png
      ! Adapter "s7" updated
      ! root@mother:/opt/iobroker#</v8::object>
      LG
      Ralf
      Aufgrund technischer Beschränkungen befindet sich die Signatur auf der Rückseite
      • BluefoxB Offline
        BluefoxB Offline
        @inline:
        Hier ein Log:
        ! u_short TempRef;
        ! if (opSize<1)
        LG
        Ralf `
        Das sind nur Warnungen.
        • BluefoxB Offline
          BluefoxB Offline
          @blauholsten:
          Sorry für den komischen Log, aber musste es aus der Datei raus kopieren…. `
          Bitte 1.0.4 ausprobieren
          • inlineI Offline
            inlineI Offline
            inline
            @Bluefox:
            Bitte 1.0.4 ausprobieren `
            Update hat jetzt geklappt - Danke!
            Getestet habe ich noch nicht.
              blauholsten
              @Bluefox:
              Installation hat erstmal geklappt…..gehe davon aus das der Rest auch geht
              - Alarm Adapter
              • VumerV Offline
                VumerV Offline
                Vumer
                Funktioniert.
                Danke!!!
                • inlineI Offline
                  inlineI Offline
                  inline
                  @inline:
                  @Bluefox:
                  Getestet habe ich noch nicht. `
                  Update: Funktioniert alles.
                  Nochmals Danke!
                  LG
                  Ralf
