  4. RPI & Nginx & Ports
    5.4k
RPI & Nginx & Ports
31 Beiträge 3 Kommentatoren 6.8k Aufrufe
  • BluefoxB Offline
    BluefoxB Offline
    Habe jetzt noch mal versucht zu installieren und es hat geklappt.
    • Z Offline
      Z Offline
      z000ao8q
      die inMem Server scheinen zu laufen auf den 9000ern
      ` > root@testserver:~# netstat -lnptu
      Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
      tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 2180/nginx
      tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 2123/sshd
      tcp 0 0 0.0.0.0:443 0.0.0.0:* LISTEN 2180/nginx
      tcp 0 0 0.0.0.0:9000 0.0.0.0:* LISTEN 23295/io.js-control
      tcp 0 0 0.0.0.0:9001 0.0.0.0:* LISTEN 23295/io.js-control
      tcp 0 0 127.0.0.1:3306 0.0.0.0:* LISTEN 2549/mysqld
      udp 0 0 0.0.0.0:68 0.0.0.0:* 1984/dhcpcd
      udp 0 0 192.168.0.23:123 0.0.0.0:* 2039/ntpd
      udp 0 0 0.0.0.0:123 0.0.0.0:* 2039/ntpd
      udp 0 0 0.0.0.0:5353 0.0.0.0:* 2098/avahi-daemon:
      udp 0 0 0.0.0.0:56664 0.0.0.0:* 2098/avahi-daemon: > sudo iobroker stop beendet sie > root@testserver:/opt/iobroker# sudo node node_modules/iobroker.js-controller/controller.js
      2015-08-04 20:57:08.628 - info: host.testserver ioBroker.js-controller version 0.7.5 js-controller starting
      2015-08-04 20:57:08.640 - info: host.testserver Copyright © 2014-2015 bluefox, hobbyquaker
      2015-08-04 20:57:08.642 - info: host.testserver hostname: testserver
      2015-08-04 20:57:08.644 - info: host.testserver ip addresses: 192.168.0.23
      2015-08-04 20:57:08.695 - info: inMem-states listening on port 9000
      2015-08-04 20:57:08.743 - info: inMem-objects listening on port 9001
      2015-08-04 20:57:08.755 - info: host.testserver InMemoryDB connected
      2015-08-04 20:57:08.777 - info: host.testserver 2 instances found
      2015-08-04 20:57:08.780 - info: host.testserver starting 2 instances
      2015-08-04 20:57:08.870 - info: host.testserver instance system.adapter.admin.0 started with pid 8798
      2015-08-04 20:57:12.801 - info: host.testserver instance system.adapter.admin.1 started with pid 8836
      2015-08-04 20:57:18.474 - error: admin.0 no connection to objects DB
      2015-08-04 20:57:22.397 - error: admin.1 no connection to objects DB `
      danach sind sie im netstat auch wieder sichtbar
      • Z Offline
        Z Offline
        z000ao8q
        @Bluefox:
        Habe jetzt noch mal versucht zu installieren und es hat geklappt. `
        auf nem PI? mit Raspberian?
        vielleicht irgendwas an den apt-gets die ich installiert hab (oder auch nicht)?
        hab jetzt keinen Bock mehr.
        schreibe mir grad nen neues Raspberian auf die SD-Karte und versuche es auf na sauberen Installation
        • Z Offline
          Z Offline
          z000ao8q
          mir ist gerade was aufgefallen.
          Die Anleitung bei GIT unterscheidet zwischen zwei node-downloads.
          iobroker.net nicht
          ` > Node.js (Node.js version >= 0.8, including npm)
          Debian package for ARM (Raspbian, Cubian, …) `
          ich habe die erste Version von ioBroker.net verwendet
          • Z Offline
            Z Offline
            z000ao8q
            Bingo!
            ein sauberes Image + das zweite Node-Package klappen!
            …werde jetzt nach und nach meine alten Settings vornehmen und berichten, wo der Übeltäter liegt...
            • Z Offline
              Z Offline
              z000ao8q
              OK, here is the Issue.
              um den PI "headless" zu betreiben ist es üblich die X11 Komponenten zu entfernt.
              apt-get -y purge x11-common
              dazu gehören die folgenden. Sobald die weg sind, geht ioBroker nicht mehr.
              ` > cups-bsd cups-client esound-common fonts-droid fonts-roboto ghostscript libaudiofile1 libaudit0
              libcupsimage2 libcwiid1 libdirectfb-1.2-9 libesd0 libfile-copy-recursive-perl libgs9 libgs9-common
              libijs-0.35 libjbig2dec0 libmad0 libmikmod2 libpaper-utils libpaper1 libpciaccess0 libpoppler19
              libportmidi0 libqt4-network libruby1.9.1 libsclang1 libscsynth1 libts-0.0-0 libvorbisfile3 libxfce4util-bin
              libxfce4util-common libxfce4util4 libxfconf-0-2 libxkbfile1 libxp6 libyaml-0-2 poppler-data poppler-utils
              pypy-upstream-doc ruby1.9.1 supercollider supercollider-common supercollider-server tcl8.4 tcl8.5 tk8.4
              tsconf update-inetd xfce-keyboard-shortcuts xfconf > blt* epiphany-browser* gsfonts-x11* gstreamer1.0-plugins-bad* gvfs* gvfs-backends* gvfs-daemons* gvfs-fuse*
              idle* idle-python2.7* idle-python3.2* idle3* lesstif2* libaudio2* libfluidsynth1* libice6*
              liblightdm-gobject-1-0* libobrender27* libpulse0* libqscintilla2-8* libqt4-svg* libqtgui4* libqtwebkit4*
              libsdl-image1.2* libsdl-mixer1.2* libsdl-ttf2.0-0* libsdl1.2debian* libsm6* libsmpeg0* libwebkitgtk-3.0-0*
              libxaw7* libxfce4ui-1-0* libxklavier16* libxmu6* libxss1* libxt6* libxtst6* libzbar0* lightdm*
              lightdm-gtk-greeter* lxde* lxde-core* obconf* openbox* oracle-java8-jdk* pipanel* pistore* pypy-setuptools*
              pypy-upstream* pypy-upstream-dev* python-pygame* python-tk* python3-pygame* python3-tk* qjackctl*
              raspberrypi-net-mods* raspberrypi-ui-mods* sonic-pi* timidity* tk8.5* wolfram-engine* wpagui* x11-common*
              x11-utils* x11-xkb-utils* x11-xserver-utils* x2x* xfce4-mixer* xfonts-encodings* xfonts-utils* xinit* xpdf*
              xserver-common* xserver-xorg* xserver-xorg-core* xserver-xorg-input-all* xserver-xorg-input-evdev*
              xserver-xorg-input-synaptics* xserver-xorg-video-fbdev* xserver-xorg-video-fbturbo* zenity* `
              Hast Du eine Idee welcher Teil das Problem darstellen könnte?
              • BluefoxB Offline
                BluefoxB Offline
                Habe jetzt auf pi2 aufgerufen:
                sudo apt-get -y purge x11-common
                cd /opt/iobroker
                sudo iobroker start
                und es geht.
                Probier mal beim gestoppten ioBroker:
                cd /opt/iobroker
                Was kommt da?
                Bei mir:
                pi@raspberrypi /opt/iobroker $ sudo node node_modules/iobroker.js-controller/controller.js
                2015-08-05 21:30:12.753  - info: host.raspberrypi ioBroker.js-controller version 0.7.3 js-controller starting
                2015-08-05 21:30:12.766  - info: host.raspberrypi Copyright (c) 2014-2015 bluefox, hobbyquaker
                2015-08-05 21:30:12.769  - info: host.raspberrypi hostname: raspberrypi
                2015-08-05 21:30:12.770  - info: host.raspberrypi ip addresses: 192.168.1.86
                2015-08-05 21:30:12.822  - info: inMem-states listening on port 9000
                2015-08-05 21:30:12.868  - info: inMem-objects listening on port 9001
                2015-08-05 21:30:12.880  - info: host.raspberrypi InMemoryDB connected
                2015-08-05 21:30:12.900  - info: host.raspberrypi 1 instance found
                2015-08-05 21:30:12.903  - info: host.raspberrypi starting 1 instance
                2015-08-05 21:30:12.996  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 25986
                2015-08-05 21:30:18.016  - info: admin.0 starting. Version 0.5.6 in /opt/iobroker/node_modules/iobroker.admin
                2015-08-05 21:30:18.146  - info: admin.0 requesting all states
                2015-08-05 21:30:18.150  - info: admin.0 requesting all objects
                2015-08-05 21:30:18.155  - info: admin.0 http server listening on port 8081
                2015-08-05 21:30:18.156  - info: admin.0 Use link "http://localhost:8081" to configure.
                2015-08-05 21:30:18.246  - info: admin.0 received all objects
                2015-08-05 21:30:18.252  - info: admin.0 received all states
                2015-08-05 21:30:32.134  - info: host.raspberrypi Update repository "default" under "conf/sources-dist.json"
                • Z Offline
                  Z Offline
                  z000ao8q
                  interessant.
                  bei mir Back to the Roots
                  ` > pi@raspberrypi /opt/iobroker $ sudo node node_modules/iobroker.js-controller/controller.js
                  2015-08-05 20:50:25.141 - info: host.raspberrypi ioBroker.js-controller version 0.7.5 js-controller starting
                  2015-08-05 20:50:25.153 - info: host.raspberrypi Copyright © 2014-2015 bluefox, hobbyquaker
                  2015-08-05 20:50:25.155 - info: host.raspberrypi hostname: raspberrypi
                  2015-08-05 20:50:25.156 - info: host.raspberrypi ip addresses: 192.168.0.23
                  2015-08-05 20:50:25.211 - info: inMem-states listening on port 9000
                  2015-08-05 20:50:25.346 - info: inMem-objects listening on port 9001
                  2015-08-05 20:50:25.358 - info: host.raspberrypi InMemoryDB connected
                  2015-08-05 20:50:25.383 - info: host.raspberrypi 8 instances found
                  2015-08-05 20:50:25.386 - info: host.raspberrypi starting 6 instances
                  2015-08-05 20:50:25.481 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 14207
                  2015-08-05 20:50:29.408 - info: host.raspberrypi instance system.adapter.hm-rpc.0 started with pid 14245
                  2015-08-05 20:50:33.408 - info: host.raspberrypi instance system.adapter.web.0 started with pid 14283
                  ****2015-08-05 20:50:35.108 - error: admin.0 no connection to objects DB
                  2015-08-05 20:50:36.145 - error: hm-rpc.0 no connection to objects DB
                  2015-08-05 20:50:40.585 - error: web.0 no connection to objects DB
                  2015-08-05 20:50:44.011 - error: vis.0 no connection to objects DB****
                  2015-08-05 20:50:45.402 - info: host.raspberrypi instance system.adapter.history.0 started with pid 14411
                  2015-08-05 20:50:51.975 - error: history.0 no connection to objects DB `
                  hast Du nen Reboot nach dem purge gemacht?
                  auch auf dem neuen kernel?
                  Linux raspberrypi 4.0.9-v7+ #807
                  ich habe oben einen Fehler gemacht.
                  ich habe auch "sonic-pi" entfernt und oben nicht gepostet.
                  Dieser Teil ist für die ganzen Removes verantwortlich. Wenn ich "sonic-pi" wieder installiere, klappt es aber trotzdem nicht.
                  • BluefoxB Offline
                    BluefoxB Offline
                    3.18.7-v7+
                    Geht auch nach reboot.
                    • Z Offline
                      Z Offline
                      z000ao8q
                      ich gebe langsam auf.
                      habe ein weiteres neues Image geschrieben.
                      apt-get -y update && apt-get -y upgrade && apt-get -y autoremove
                      node & iobroker installiert
                      =>funktioniert
                      =>funktioniert
                      reboot -h
                      => bekannter Fehler. geht nicht mehr.
                      Irgend was aus dem X11 Package fehlt ihm :-(
                      • Z Offline
                        Z Offline
                        z000ao8q
                        and the winner is…
                        node.js scheint von diesem Package abhängig zu sein.
                        Sobald man es deinstalliert, geht es nicht mehr.
                        Sobald man es neu-installiert (nach einem kompletten X11-Cleanup z.B.) läuft wieder alles!
