  4. Status vom Kostal Wechselrichter auslesen?
    6.3k
331 Beiträge 34 Kommentatoren 115.0k Aufrufe 26 Beobachtet
  • M MartyBr
    @Homoran
    Hier noch Log-Meldungen:
    javascript.0
    2021-10-04 16:08:22.003	error	at processTimers (internal/timers.js:500:7)
    javascript.0
    2021-10-04 16:08:22.002	error	at listOnTimeout (internal/timers.js:557:17)
    javascript.0
    2021-10-04 16:08:22.002	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:228:7)
    javascript.0
    2021-10-04 16:08:22.002	error	at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:268:28
    javascript.0
    2021-10-04 16:08:22.002	error	at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Job.js:168:15)
    javascript.0
    2021-10-04 16:08:22.002	error	at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1313:34)
    javascript.0
    2021-10-04 16:08:22.002	error	at Object.Piko (script.js.Photovoltaik.Kostal-Piko-Test:133:21)
    javascript.0
    2021-10-04 16:08:22.002	error	Error in callback: ReferenceError: ID_DC3Leistung is not defined
    javascript.0
    2021-10-04 16:08:11.003	error	at processTimers (internal/timers.js:500:7)
    javascript.0
    2021-10-04 16:08:11.003	error	at listOnTimeout (internal/timers.js:557:17)
    javascript.0
    2021-10-04 16:08:11.003	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:228:7)
    javascript.0
    2021-10-04 16:08:11.003	error	at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:268:28
    javascript.0
    2021-10-04 16:08:11.003	error	at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Job.js:168:15)
    javascript.0
    2021-10-04 16:08:11.003	error	at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1313:34)
    javascript.0
    2021-10-04 16:08:11.003	error	at Object.Piko (script.js.Photovoltaik.Kostal-Piko-Test:133:21)
    javascript.0
    2021-10-04 16:08:11.002	error	Error in callback: ReferenceError: ID_DC3Leistung is not defined
    javascript.0
    javascript.0
    javascript.0
    javascript.0
    javascript.0
    javascript.0
    javascript.0
    javascript.0
    #241
    @martybr was ergibt bei dir:
    <IP>/api/dxs.json?dxsEntries=33555459
      MartyBr
      #242
      @homoran sagte in Status vom Kostal Wechselrichter auslesen?:
      {"dxsEntries":[{"dxsId":33555459,"value":163.961151}],"session":{"sessionId":0,"roleId":0},"status":{"code":0}}
      Martin
      Intel NUCs mit Proxmox / Iobroker als VM unter Debian
      Raspeberry mit USB Leseköpfen für Smartmeter
      Homematic und Homematic IP
      GlasfaserG HomoranH 2 Antworten Letzte Antwort
      • M MartyBr
        @Homoran
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        #243
        @martybr
        // Ausleseskript Wechselrichter Kostal Piko ab Firmware v05.31 (12.10.2015)
        //Variable
        var url = '192.168.178.77'; // IP der Photovoltaik-Anlage eintragen
        var IPAnlage = url + '/api/dxs.json';
        //Leistungswerte
           ID_DCEingangGesamt = 33556736;         // in W
           ID_Ausgangsleistung = 67109120;        // in W
           ID_Eigenverbrauch = 83888128;          // in W
           //Status
           ID_Status = 16780032;                  // 0:Off
           //Statistik - Tag
           ID_Ertrag_d = 251658754;               // in Wh
           ID_Hausverbrauch_d = 251659010;        // in Wh
           ID_Eigenverbrauch_d = 251659266;       // in Wh
           ID_Eigenverbrauchsquote_d = 251659278; // in %
           ID_Autarkiegrad_d = 251659279;         // in %
           //Statistik - Gesamt
           ID_Ertrag_G = 251658753;               // in kWh
           ID_Hausverbrauch_G = 251659009;        // in kWh
           ID_Eigenverbrauch_G = 251659265;       // in kWh
           ID_Eigenverbrauchsquote_G = 251659280; // in %
           ID_Autarkiegrad_G = 251659281;         // in %
           ID_Betriebszeit = 251658496;           // in h
           //Momentanwerte - PV Generator
           ID_DC1Spannung = 33555202;             // in V
           ID_DC1Strom = 33555201;                // in A
           ID_DC1Leistung = 33555203;             // in W
           ID_DC2Spannung = 33555458;             // in V
           ID_DC2Strom = 33555457;                // in A
           ID_DC2Leistung = 33555459;             // in W
           ID_DC3Spannung = 33555714;             // in V
           ID_DC3Strom = 33555713;                // in A
           ID_DC3Leistung = 33555715;             // in W
           //Momentanwerte Haus
           ID_HausverbrauchSolar = 83886336;      // in W
           ID_HausverbrauchBatterie = 83886592;   // in W
           ID_HausverbrauchNetz = 83886848;       // in W
           ID_HausverbrauchPhase1 = 83887106;     // in W
           ID_HausverbrauchPhase2 = 83887362;     // in W
           ID_HausverbrauchPhase3 = 83887618;     // in W
           //Netz Netzparameter
           ID_NetzAusgangLeistung = 67109120;     // in W
           ID_NetzFrequenz = 67110400;            // in Hz
           ID_NetzCosPhi = 67110656;
           //Netz Phase 1
           ID_P1Spannung = 67109378;              // in V
           ID_P1Strom = 67109377;                 // in A
           ID_P1Leistung = 67109379;              // in W
           //Netz Phase 2
           ID_P2Spannung = 67109634;              // in V
           ID_P2Strom = 67109633;                 // in A
           ID_P2Leistung = 67109635;              // in W
           //Netz Phase 3
           ID_P3Spannung = 67109890;              // in V
           ID_P3Strom = 67109889;                 // in A
           ID_P3Leistung = 67109891;              // in W
        createState('Solaranlage.Momentanwerte.Leistung_AC_aktuell', 0);
        createState('Solaranlage.Summenwerte.Autarkiegrad_d',0);
        createState('Solaranlage.Summenwerte.Autarkiegrad_G',0);
        createState('Solaranlage.Summenwerte.Betriebszeit',0);
        createState('Solaranlage.Momentanwerte.Status','aus');
        createState('Solaranlage.Momentanwerte.Leistung_DC_aktuell',0);
        createState('Solaranlage.Momentanwerte.Eigenverbrauch',0);
        createState('Solaranlage.Summenwerte.Eigenverbrauch_d');
        createState('Solaranlage.Summenwerte.Eigenverbrauch_G', 0);
        createState('Solaranlage.Summenwerte.Eigenverbrauchsquote_d', 0);
        createState('Solaranlage.Summenwerte.Eigenverbrauchsquote_G', 0);
        createState('Solaranlage.Summenwerte.Tagesertrag', 0);
        createState('Solaranlage.Summenwerte.Gesamtertrag', 0);
        createState('Solaranlage.Summenwerte.Hausverbrauch_d', 0);
        createState('Solaranlage.Summenwerte.Hausverbrauch_G', 0);
        createState('Solaranlage.Momentanwerte.P1Spannung');
        createState('Solaranlage.Momentanwerte.P2Spannung');
        createState('Solaranlage.Momentanwerte.P3Spannung');
        createState('Solaranlage.Momentanwerte.P1Strom');
        createState('Solaranlage.Momentanwerte.P2Strom');
        createState('Solaranlage.Momentanwerte.P3Strom');
        createState('Solaranlage.Momentanwerte.P1Leistung');
        createState('Solaranlage.Momentanwerte.P2Leistung');
        createState('Solaranlage.Momentanwerte.P3Leistung');
        createState('Solaranlage.Momentanwerte.Leistung_String1');
        createState('Solaranlage.Momentanwerte.Leistung_String2');
        createState('Solaranlage.Momentanwerte.Leistung_String3');
        var logging = false;
        function Piko() {
           if (logging) log("Piko 5.5 auslesen");
           request('http://' + IPAnlage +
           '?dxsEntries=' + ID_DCEingangGesamt +
           '&dxsEntries=' + ID_Ausgangsleistung +
           '&dxsEntries=' + ID_Eigenverbrauch +
           '&dxsEntries=' + ID_Eigenverbrauch_d +
           '&dxsEntries=' + ID_Eigenverbrauch_G +
           '&dxsEntries=' + ID_Eigenverbrauchsquote_d +
           '&dxsEntries=' + ID_Eigenverbrauchsquote_G +
           '&dxsEntries=' + ID_Ertrag_d +
           '&dxsEntries=' + ID_Ertrag_G +
           '&dxsEntries=' + ID_Hausverbrauch_d +
           '&dxsEntries=' + ID_Hausverbrauch_G +
           '&dxsEntries=' + ID_Autarkiegrad_G +
           '&dxsEntries=' + ID_Autarkiegrad_d +
           '&dxsEntries=' + ID_Betriebszeit +
           '&dxsEntries=' + ID_P1Spannung +
           '&dxsEntries=' + ID_P2Spannung +
           '&dxsEntries=' + ID_P1Strom +
           '&dxsEntries=' + ID_P2Strom +
           '&dxsEntries=' + ID_P1Leistung +
           '&dxsEntries=' + ID_P2Leistung +
           '&dxsEntries=' + ID_Status +
           '&dxsEntries=' + ID_DC1Leistung +
           '&dxsEntries=' + ID_DC2Leistung +
           '&dxsEntries=' + ID_P3Spannung +    // 23
           '&dxsEntries=' + ID_P3Strom +       // 24
           '&dxsEntries=' + ID_DC3Leistung,    //25
           function (error, response, body) {
               if(!error && response.statusCode ==200) {
                   if(logging) log(body);
                   var result = JSON.parse(body).dxsEntries;
           		var Zustand = 'aus';
           		if (result[20].val == 0) {
                   Zustand = 'aus';
                   } else if (result[20].value== 1) {
                   Zustand = 'Leerlauf';
                   } else if (result[20].value == 2) {
                   Zustand = 'Anfahren';
                   } else if (result[20].value == 3) {
                   Zustand = 'Einspeisen MPP';
                   } else if (result[20].value == 4) {
                   Zustand = 'Einspeisen abgeregelt';
                   } else if (result[20].value == 7) {
                   Zustand = 'Isolationsmessung';
                   } else {
                   Zustand = (String('Code ') + String('' + result[20].value));
                   setState('Solaranlage.Momentanwerte.Leistung_DC_aktuell', result[0].value || 0, true);
                   setState('Solaranlage.Momentanwerte.Leistung_AC_aktuell', result[1].value || 0, true);
                   setState('Solaranlage.Momentanwerte.Eigenverbrauch', result[2].value || 0, true);
                   setState('Solaranlage.Summenwerte.Eigenverbrauch_d', result[3].value || 0, true);
                   setState('Solaranlage.Summenwerte.Eigenverbrauch_G', result[4].value || 0, true);
                   setState('Solaranlage.Summenwerte.Eigenverbrauchsquote_d', result[5].value || 0, true);
                   setState('Solaranlage.Summenwerte.Eigenverbrauchsquote_G', result[6].value || 0, true);
                   setState('Solaranlage.Summenwerte.Tagesertrag', result[7].value || 0, true);
                   setState('Solaranlage.Summenwerte.Gesamtertrag', result[8].value || 0, true);
                   setState('Solaranlage.Summenwerte.Hausverbrauch_d', result[9].value || 0, true);
                   setState('Solaranlage.Summenwerte.Hausverbrauch_G', result[10].value || 0, true);
                   setState('Solaranlage.Summenwerte.Autarkiegrad_G', result[11].value || 0, true);
                   setState('Solaranlage.Summenwerte.Autarkiegrad_d', result[12].value || 0, true);
                   setState('Solaranlage.Summenwerte.Betriebszeit', result[13].value || 0, true);
                   setState('Solaranlage.Momentanwerte.P1Spannung', result[14].value || 0, true);
                   setState('Solaranlage.Momentanwerte.P2Spannung', result[15].value || 0, true);
                   setState('Solaranlage.Momentanwerte.P1Strom', result[16].value || 0, true);
                   setState('Solaranlage.Momentanwerte.P2Strom', result[17].value || 0, true);
                   setState('Solaranlage.Momentanwerte.P1Leistung', result[18].value || 0, true);
                   setState('Solaranlage.Momentanwerte.P2Leistung', result[19].value || 0, true);
                   setState('Solaranlage.Momentanwerte.Status', Zustand || 0, true);
                   setState('Solaranlage.Momentanwerte.Leistung_String1', result[21].value || 0, true);
                   setState('Solaranlage.Momentanwerte.Leistung_String2', result[22].value || 0, true);
                   setState('Solaranlage.Momentanwerte.P3Spannung', result[23].value || 0, true);
                   setState('Solaranlage.Momentanwerte.P3Strom', result[24].value || 0, true);
                   setState('Solaranlage.Momentanwerte.Leistung_String3', result[25].value || 0, true);
               } else {
                   log("Fehler: " + error + " bei Abfrage von: " + url, "warn");
        schedule("*/11 * 5-23 * * *", Piko);
        //on('smartmeter.0.1-0:16_7_0__255.value', Piko); // triggert bei Wertänderung;
        • M MartyBr
          GlasfaserG Offline
          GlasfaserG Offline
          Glasfaser
          #244
          @martybr
          ID_DC3Leistung fehlt
             ID_DC3Leistung =                              // in W
          • M MartyBr
            #245
            @martybr ist das die Leistung von String 2?
            wenn ja mal mit <IP>/api/dxs.json?dxsEntries=33555715 versuchen
            • GlasfaserG Glasfaser
              @martybr
              #246
              @glasfaser sach ich doch!
              ich habe google bemüht und bastel gerade -
                GlasfaserG Offline
                GlasfaserG Offline
                Glasfaser
                #247
                Sorry ;)
                  Sorry ;)
                  #248
                  @glasfaser klar doch!
                  siehe edit und spoiler
                    Sorry ;)
                    #249
                    @glasfaser du kannst gerne gleich übernehmen.
                    Als Programmiernoob bin ich gleich am Ende meiner Kenntnisse, zumal ich nicht per trial und error bei mir so lange testen kann bis es läuft
                    Der Spoiler müsste jetzt soweit passen hoffe ich
                    kannst du dir den mal ansehen, bitte.
                      GlasfaserG Offline
                      GlasfaserG Offline
                      Glasfaser
                      #250
                                 setState('Solaranlage.Momentanwerte.Leistung_String3', result[27].value || 0, true);
                      kommt da nicht 23 , 24 , result 25
                        MartyBr
                        schrieb am zuletzt editiert von MartyBr
                        #251
                        nein !! Das ist String 3. Ihr so so verdammt schnell, da komme ich nicht mit 😀
                        Martin
                        HomoranH GlasfaserG 2 Antworten Letzte Antwort
                          #252
                          @glasfaser sagte in Status vom Kostal Wechselrichter auslesen?:
                          eben nicht. das stand darin.
                          ich habe ja 3 Elemente zugefügt (Spannung, Strom und Leistung)
                          obwohl:
                          das sind ja nur die IDS, ich hab mir das array gar nicht angesehen 😳
                          EDIT:
                          du hast recht, es muss doch 25 sein, da Spannung und Strom nicht im array sind
                          • werde ich sofort ändern
                          • M MartyBr
                            #253
                            @martybr sagte in Status vom Kostal Wechselrichter auslesen?:
                            das war ja auch so geplant!
                            die Frage war ob die Zahl zuvor die Leistung von String 2 brachte
                              MartyBr
                              #254
                              Sorry, das finde ich nicht mehr raus.
                              Martin
                              • M MartyBr
                                #255
                                dann nimm mal das Skript aus dem Spoiler, ändere die IP und lass mal laufen.
                                Triggerst du auch auf Smartmeter?
                                  MartyBr
                                  #256
                                  Ich habe das Auslesen des KSEM noch nicht geschafft und war froh, dieses Script zu finden.
                                  Das Problem beim KSEM und dem PIKO ist, dass die Verbindung beider das Auslesen des PIKO via MODBUS verhindert.
                                  Ich habe das Script genommen:
                                  //Variable
                                  //Leistungswerte
                                     //Status
                                     //Statistik - Tag
                                     //Netz Phase 1
                                     //Netz Phase 2
                                     //Netz Phase 3
                                  function Piko() {
                                             Zustand = 'aus';
                                             } else {
                                         } else {
                                  Leider fehlen immer noch die Werte für den String 3:
                                  Martin
                                  • M MartyBr
                                    //Variable
                                    //Leistungswerte
                                       //Status
                                       //Statistik - Tag
                                       //Netz Phase 1
                                       //Netz Phase 2
                                       //Netz Phase 3
                                    function Piko() {
                                               Zustand = 'aus';
                                               } else {
                                           } else {
                                    #257
                                    keine Fehler im log?
                                    oder triggert das Skript bei dir gar nicht?
                                      MartyBr
                                      #258
                                      Hier Log:
                                      javascript.0
                                      2021-10-04 17:12:11.050	error	Error in request callback: TypeError: Cannot read property 'value' of undefined
                                      javascript.0
                                      2021-10-04 17:12:00.130	error	Error in request callback: TypeError: Cannot read property 'value' of undefined
                                      javascript.0
                                      2021-10-04 17:11:55.048	error	Error in request callback: TypeError: Cannot read property 'value' of undefined
                                      javascript.0
                                      2021-10-04 17:11:44.048	error	Error in request callback: TypeError: Cannot read property 'value' of undefined
                                      javascript.0
                                      2021-10-04 17:11:33.057	error	Error in request callback: TypeError: Cannot read property 'value' of undefined
                                      javascript.0
                                      2021-10-04 17:11:22.049	error	Error in request callback: TypeError: Cannot read property 'value' of undefined
                                      javascript.0
                                      2021-10-04 17:11:11.051	error	Error in request callback: TypeError: Cannot read property 'value' of undefined
                                      javascript.0
                                      2021-10-04 17:11:00.119	error	Error in request callback: TypeError: Cannot read property 'value' of undefined
                                      javascript.0
                                      2021-10-04 17:10:55.048	error	Error in request callback: TypeError: Cannot read property 'value' of undefined
                                      javascript.0
                                      2021-10-04 17:10:44.049	error	Error in request callback: TypeError: Cannot read property 'value' of undefined
                                      javascript.0
                                      2021-10-04 17:10:33.049	error	Error in request callback: TypeError: Cannot read property 'value' of undefined
                                      javascript.0
                                      2021-10-04 17:10:22.049	error	Error in request callback: TypeError: Cannot read property 'value' of undefined
                                      javascript.0
                                      2021-10-04 17:10:11.051	error	Error in request callback: TypeError: Cannot read property 'value' of undefined
                                      Martin
                                      • M MartyBr
                                        Hier Log:
                                        javascript.0
                                        javascript.0
                                        javascript.0
                                        javascript.0
                                        javascript.0
                                        javascript.0
                                        javascript.0
                                        javascript.0
                                        javascript.0
                                        javascript.0
                                        javascript.0
                                        javascript.0
                                        javascript.0
                                        #259
                                        @martybr
                                        das nutzt nicht viel.
                                        bitte Adapter auf logstufe debug stellen und/oder im logfenster unter dem Skript im Editor nachsehen
                                        und die Frage nach dem Trigger bitte endlich beantworten
                                          @martybr
                                          MartyBr
                                          #260
                                          Der Javascript Adapter läuft auf debug. Das Script triggert im Sekundenrythmus, die Werte werden geliefert.
                                          Im Log ändert sich trotz Debug nichts.
                                          ipt.0
                                          2021-10-04 17:17:55.048	error	Error in request callback: TypeError: Cannot read property 'value' of undefined
                                          javascript.0
                                          2021-10-04 17:17:44.050	error	Error in request callback: TypeError: Cannot read property 'value' of undefined
                                          javascript.0
                                          2021-10-04 17:17:33.124	error	Error in request callback: TypeError: Cannot read property 'value' of undefined
                                          javascript.0
                                          2021-10-04 17:17:22.050	error	Error in request callback: TypeError: Cannot read property 'value' of undefined
                                          javascript.0
                                          2021-10-04 17:17:11.050	error	Error in request callback: TypeError: Cannot read property 'value' of undefined
                                          javascript.0
                                          2021-10-04 17:17:00.138	error	Error in request callback: TypeError: Cannot read property 'value' of undefined
                                          javascript.0
                                          2021-10-04 17:16:55.051	error	Error in request callback: TypeError: Cannot read property 'value' of undefined
                                          javascript.0
                                          2021-10-04 17:16:44.052	error	Error in request callback: TypeError: Cannot read property 'value' of undefined
                                          javascript.0
                                          2021-10-04 17:16:33.050	error	Error in request callback: TypeError: Cannot read property 'value' of undefined
                                          javascript.0
                                          2021-10-04 17:16:22.053	error	Error in request callback: TypeError: Cannot read property 'value' of undefined
                                          javascript.0
                                          2021-10-04 17:16:11.049	error	Error in request callback: TypeError: Cannot read property 'value' of undefined
                                          javascript.0
                                          2021-10-04 17:16:00.116	error	Error in request callback: TypeError: Cannot read property 'value' of undefined
                                          javascript.0
                                          2021-10-04 17:15:55.051	error	Error in request callback: TypeError: Cannot read property 'value' of undefined
                                          Im Script-Editor kommt kein Fehler:
                                          Martin
