  4. EVCC wird nicht grün
83 Beiträge 4 Kommentatoren 783 Aufrufe 3 Beobachtet
  • K Karl-Heinz1
    Das ist das Ergebnis von iob diag
    Ob iob diag funktioniert muss du jetzt sagen. Ich mache jetzt nichts, warte ab, was ich tun soll.
    ```bash
    Script v.2026-08-30
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)
     Static hostname: meinbroker
           Icon name: computer
              Kernel: Linux 6.18.39+rpt-rpi-v8
        Architecture: arm64
    OS is similar to:
    Model		: Raspberry Pi 400 Rev 1.1
    Docker          : false
    Virtualization  : none
    Unknown
    Kernel          : aarch64
    Userland        : 64bit
    System was installed 81 days ago (on 2026-06-18).
    Systemuptime and Load:
     19:57:19 up  2:22,  3 users,  load average: 0.81, 0.38, 0.36
    CPU threads     : 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'trixie'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Mon 2026-09-07 19:57:20 CEST
               Universal time: Mon 2026-09-07 17:57:20 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    karl-heinz
    HOME=/home/karl-heinz
    GROUPS=karl-heinz adm dialout cdrom sudo audio video plugdev games users netdev lpadmin gpio i2c spi render input iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server:		Unknown
    Display-Manager: 	* lightdm.service - Light Display Manager
    Desktop:
    Session:		tty
    Boot Target: 		graphical.target
    System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'.
    Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
    *** MEMORY ***
    Mem:            4.0G        2.8G        367M         34M        908M        1.2G
    Swap:           2.1G          0B        2.1G
    Total:          6.1G        2.8G        2.5G
    Active iob-Instances: 	22
             3795 M total memory
             2698 M used memory
             1917 M active memory
             1188 M inactive memory
              349 M free memory
              115 M buffer memory
              750 M swap cache
             2047 M total swap
                0 M used swap
             2047 M free swap
    top - 19:57:20 up  2:22,  3 users,  load average: 0.81, 0.38, 0.36
    Tasks: 221 total,   1 running, 220 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  2.2 us,  2.2 sy,  0.0 ni, 95.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3795.8 total,    349.7 free,   2698.4 used,    867.2 buff/cache
    MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   1097.4 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     760M  9.3M  750M   2% /run
    /dev/mmcblk0p2 ext4       29G   12G   16G  44% /
    tmpfs          tmpfs     1.9G  360K  1.9G   1% /dev/shm
    tmpfs          tmpfs     5.0M   12K  5.0M   1% /run/lock
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
    /dev/mmcblk0p1 vfat      505M   79M  426M  16% /boot/firmware
    tmpfs          tmpfs     1.9G  2.6M  1.9G   1% /tmp
    tmpfs          tmpfs     380M   64K  380M   1% /run/user/1000
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
    Messages concerning filesystems in dmesg (Last 15 lines only):
    [Mon Sep  7 17:35:12 2026] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
    [Mon Sep  7 17:35:12 2026] EXT4-fs (mmcblk0p2): mounted filesystem 8abab6b9-ef90-4fee-ae3d-91079bfae7c1 ro with ordered data mode. Quota mode: none.
    [Mon Sep  7 17:35:15 2026] EXT4-fs (mmcblk0p2): re-mounted 8abab6b9-ef90-4fee-ae3d-91079bfae7c1 r/w.
    Show mounted filesystems:
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    2.5G	/var/
    220M	/var/lib
    216M	/var/cache
    203M	/var/cache/apt
    149M	/var/lib/apt
    Archived and active journals take up 8M in the file system.
    /opt/iobroker/backups:
    37M	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    885M	/opt/iobroker/iobroker-data/
    814M	/opt/iobroker/iobroker-data/files
    493M	/opt/iobroker/iobroker-data/files/javascript.admin
    461M	/opt/iobroker/iobroker-data/files/javascript.admin/static
    460M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
    43M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.c9e0f545.js.map
    24M	/opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
    19M	/opt/iobroker/iobroker-data/objects.jsonl
    19M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.6964fae2.js.map
    11M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.c9e0f545.js
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_B0043WH9-if00-port0
    /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
    /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_B00332GV-if00-port0
    No nvbackup.json found.
    *** NodeJS-Installation ***
    /usr/bin/nodejs		v22.23.2
    /usr/bin/node		v22.23.2
    /usr/bin/npm		10.9.8
    /usr/bin/npx		10.9.8
    ✓ Node.js installation is correct
    nodejs:
      Installed: 22.23.2-1nodesource1
      Candidate: 22.23.2-1nodesource1
      Version table:
     *** 22.23.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
            100 /var/lib/dpkg/status
         22.23.1-1nodesource1 1001
         22.23.0-1nodesource1 1001
         22.22.3-1nodesource1 1001
         22.22.2-1nodesource1 1001
         22.22.1-1nodesource1 1001
         22.22.0-1nodesource1 1001
         22.21.0-1nodesource1 1001
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         20.19.2+dfsg-1+deb13u2 500
            500 http://deb.debian.org/debian trixie/main arm64 Packages
            500 http://deb.debian.org/debian-security trixie-security/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    No known Vulnerabilities detected!
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    meinbroker          meinbroker (version: 7.2.2, hostname: meinbroker    , alive, uptime: 2569)
    Core adapters versions
    js-controller: 	7.2.2
    admin: 		7.8.23
    javascript: 	8.8.2
    nodejs modules from github: 	1
    +-- iobroker.icons-open-icon-library-png@0.1.3 (git+ssh://git@github.com/ioBroker/ioBroker.icons-open-icon-library-png.git#0847a79d713ee6725ccb6ccfb044c025b73ec946)
    Adapter State
    + system.adapter.admin.0                  : admin                 : meinbroker                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.backitup.0               : backitup              : meinbroker                               -  enabled
    + system.adapter.chromecast.0             : chromecast            : meinbroker                               -  enabled
      system.adapter.cloud.0                  : cloud                 : meinbroker                               - disabled
    + system.adapter.discovery.0              : discovery             : meinbroker                               -  enabled
    + system.adapter.ds18b20.0                : ds18b20               : meinbroker                               -  enabled
    + system.adapter.echarts.0                : echarts               : meinbroker                               -  enabled
    + system.adapter.evcc.0                   : evcc                  : meinbroker                               -  enabled, port: 7070
      system.adapter.flot.0                   : flot                  : meinbroker                               - disabled
    + system.adapter.growatt.0                : growatt               : meinbroker                               -  enabled
    + system.adapter.history.0                : history               : meinbroker                               -  enabled
      system.adapter.icons-material-png.0     : icons-material-png    : meinbroker                               - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : meinbroker                               - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: meinbroker                               - disabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : meinbroker                               - disabled
    + system.adapter.iot.0                    : iot                   : meinbroker                               -  enabled
    + system.adapter.jarvis.0                 : jarvis                : meinbroker                               -  enabled
      system.adapter.javascript.0             : javascript            : meinbroker                               -  enabled
    + system.adapter.modbus.0                 : modbus                : meinbroker                               -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : meinbroker                               -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.net-tools.0              : net-tools             : meinbroker                               -  enabled
    + system.adapter.node-red.0               : node-red              : meinbroker                               -  enabled, port: 1880, bind: 0.0.0.0
    + system.adapter.pushover.0               : pushover              : meinbroker                               -  enabled
    + system.adapter.shelly.0                 : shelly                : meinbroker                               -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : meinbroker                               -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : meinbroker                               -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.smartcontrol.0           : smartcontrol          : meinbroker                               -  enabled
    + system.adapter.sonoff.0                 : sonoff                : meinbroker                               -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.telegram.0               : telegram              : meinbroker                               - disabled, port: 8443, bind: 0.0.0.0
      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : meinbroker                               - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : meinbroker                               - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : meinbroker                               - disabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : meinbroker                               - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : meinbroker                               - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : meinbroker                               - disabled
      system.adapter.vis.0                    : vis                   : meinbroker                               -  enabled
    + system.adapter.web.0                    : web                   : meinbroker                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    │ (index) │ id                                           │ name                          │ version  │ upgrade policy │
    │ 0       │ 'system.adapter.admin'                       │ 'admin'                       │ '7.8.23' │ 'none'         │
    │ 1       │ 'system.adapter.backitup'                    │ 'backitup'                    │ '4.0.3'  │ 'none'         │
    │ 2       │ 'system.adapter.chromecast'                  │ 'chromecast'                  │ '3.4.1'  │ 'none'         │
    │ 3       │ 'system.adapter.cloud'                       │ 'cloud'                       │ '5.0.1'  │ 'none'         │
    │ 4       │ 'system.adapter.discovery'                   │ 'discovery'                   │ '5.0.0'  │ 'none'         │
    │ 5       │ 'system.adapter.ds18b20'                     │ 'ds18b20'                     │ '2.0.5'  │ 'none'         │
    │ 6       │ 'system.adapter.echarts'                     │ 'echarts'                     │ '1.9.2'  │ 'none'         │
    │ 7       │ 'system.adapter.evcc'                        │ 'evcc'                        │ '0.2.4'  │ 'none'         │
    │ 8       │ 'system.adapter.flot'                        │ 'flot'                        │ '1.12.0' │ 'none'         │
    │ 9       │ 'system.adapter.growatt'                     │ 'growatt'                     │ '3.3.1'  │ 'none'         │
    │ 10      │ 'system.adapter.history'                     │ 'history'                     │ '3.0.1'  │ 'none'         │
    │ 11      │ 'system.adapter.icons-material-png'          │ 'icons-material-png'          │ '0.1.0'  │ 'none'         │
    │ 12      │ 'system.adapter.icons-mfd-svg'               │ 'icons-mfd-svg'               │ '1.2.0'  │ 'none'         │
    │ 13      │ 'system.adapter.icons-open-icon-library-png' │ 'icons-open-icon-library-png' │ '0.1.3'  │ 'none'         │
    │ 14      │ 'system.adapter.icons-ultimate-png'          │ 'icons-ultimate-png'          │ '1.0.1'  │ 'none'         │
    │ 15      │ 'system.adapter.iot'                         │ 'iot'                         │ '3.4.2'  │ 'none'         │
    │ 16      │ 'system.adapter.jarvis'                      │ 'jarvis'                      │ '3.1.8'  │ 'none'         │
    │ 17      │ 'system.adapter.javascript'                  │ 'javascript'                  │ '8.8.2'  │ 'none'         │
    │ 18      │ 'system.adapter.modbus'                      │ 'modbus'                      │ '6.3.2'  │ 'none'         │
    │ 19      │ 'system.adapter.mqtt'                        │ 'mqtt'                        │ '6.1.1'  │ 'none'         │
    │ 20      │ 'system.adapter.net-tools'                   │ 'net-tools'                   │ '1.0.11' │ 'none'         │
    │ 21      │ 'system.adapter.node-red'                    │ 'node-red'                    │ '5.2.1'  │ 'none'         │
    │ 22      │ 'system.adapter.pushover'                    │ 'pushover'                    │ '4.1.0'  │ 'none'         │
    │ 23      │ 'system.adapter.shelly'                      │ 'shelly'                      │ '8.2.1'  │ 'none'         │
    │ 24      │ 'system.adapter.simple-api'                  │ 'simple-api'                  │ '2.8.0'  │ 'none'         │
    │ 25      │ 'system.adapter.smartcontrol'                │ 'smartcontrol'                │ '2.0.1'  │ 'none'         │
    │ 26      │ 'system.adapter.socketio'                    │ 'socketio'                    │ '6.7.1'  │ 'none'         │
    │ 27      │ 'system.adapter.sonoff'                      │ 'sonoff'                      │ '3.1.2'  │ 'none'         │
    │ 28      │ 'system.adapter.telegram'                    │ 'telegram'                    │ '3.9.0'  │ 'none'         │
    │ 29      │ 'system.adapter.vis'                         │ 'vis'                         │ '1.5.6'  │ 'none'         │
    │ 30      │ 'system.adapter.vis-2-widgets-gauges'        │ 'vis-2-widgets-gauges'        │ '1.1.0'  │ 'none'         │
    │ 31      │ 'system.adapter.vis-colorpicker'             │ 'vis-colorpicker'             │ '2.0.3'  │ 'none'         │
    │ 32      │ 'system.adapter.vis-justgage'                │ 'vis-justgage'                │ '2.1.7'  │ 'none'         │
    │ 33      │ 'system.adapter.vis-material-advanced'       │ 'vis-material-advanced'       │ '1.7.4'  │ 'none'         │
    │ 34      │ 'system.adapter.vis-materialdesign'          │ 'vis-materialdesign'          │ '0.5.9'  │ 'none'         │
    │ 35      │ 'system.adapter.vis-rgraph'                  │ 'vis-rgraph'                  │ '0.0.2'  │ 'none'         │
    │ 36      │ 'system.adapter.web'                         │ 'web'                         │ '6.3.1'  │ 'none'         │
    │ 37      │ 'system.adapter.ws'                          │ 'ws'                          │ '2.6.2'  │ 'none'         │
    ioBroker-Adapter Versions and update status
    Used repository: stable
    Adapter    "admin"        : 8.0.11   , installed 7.8.23 [Updatable]
    Adapter    "backitup"     : 4.0.3    , installed 4.0.3
    Adapter    "chromecast"   : 4.2.0    , installed 3.4.1  [Updatable]
    Adapter    "cloud"        : 6.0.1    , installed 5.0.1  [Updatable]
    Adapter    "ds18b20"      : 3.1.1    , installed 2.0.5  [Updatable]
    Adapter    "echarts"      : 3.1.0    , installed 1.9.2  [Updatable]
    Adapter    "evcc"         : 0.2.4    , installed 0.2.4
    Adapter    "growatt"      : 3.3.1    , installed 3.3.1
    Adapter    "history"      : 4.0.0    , installed 3.0.1  [Updatable]
    Adapter    "icons-material-png": 0.1.0, installed 0.1.0
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
    Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
    Adapter    "iot"          : 6.0.3    , installed 3.4.2  [Updatable]
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
    Adapter    "javascript"   : 10.1.3   , installed 8.8.2  [Updatable]
    Controller "js-controller": 7.2.2    , installed 7.2.2
    Adapter    "modbus"       : 8.0.3    , installed 6.3.2  [Updatable]
    Adapter    "mqtt"         : 6.1.4    , installed 6.1.1  [Updatable]
    Adapter    "net-tools"    : 1.2.3    , installed 1.0.11 [Updatable]
    Adapter    "node-red"     : 6.0.7    , installed 5.2.1  [Updatable]
    Adapter    "pushover"     : 5.0.0    , installed 4.1.0  [Updatable]
    Adapter    "shelly"       : 10.6.1   , installed 8.2.1  [Updatable]
    Adapter    "simple-api"   : 3.0.7    , installed 2.8.0  [Updatable]
    Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
    Adapter    "socketio"     : 7.1.3    , installed 6.7.1  [Updatable]
    Adapter    "sonoff"       : 3.3.0    , installed 3.1.2  [Updatable]
    Adapter    "telegram"     : 5.0.5    , installed 3.9.0  [Updatable]
    Adapter    "vis-2-widgets-gauges": 2.0.2, installed 1.1.0 [Updatable]
    Adapter    "vis-colorpicker": 2.1.0  , installed 2.0.3  [Updatable]
    Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
    Adapter    "web"          : 8.0.0    , installed 6.3.1  [Updatable]
    Adapter    "ws"           : 4.1.0    , installed 2.6.2  [Updatable]
    Objects and States
    Objects: 	4938
    States: 	4382
    W: https://dl.evcc.io/public/evcc/stable/deb/debian/dists/bookworm/InRelease: The key(s) in the keyring /etc/apt/trusted.gpg.d/evcc-stable.asc are ignored as the file has an unsupported filetype.
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. OpenPGP signature verification failed: https://dl.evcc.io/public/evcc/stable/deb/debian bookworm InRelease: Sub-process /usr/bin/sqv returned an error code (1), error message is: Missing key 99685CA9149A5389F6AC7B06EAD5D0E07B0EC0FD, which is needed to verify signature.
    W: Failed to fetch https://dl.evcc.io/public/evcc/stable/deb/debian/dists/bookworm/InRelease  Sub-process /usr/bin/sqv returned an error code (1), error message is: Missing key 99685CA9149A5389F6AC7B06EAD5D0E07B0EC0FD, which is needed to verify signature.
    W: Some index files failed to download. They have been ignored, or old ones used instead.
    Hit:1 http://deb.debian.org/debian trixie InRelease
    Hit:2 http://deb.debian.org/debian trixie-updates InRelease
    Hit:3 http://archive.raspberrypi.com/debian trixie InRelease
    Hit:4 http://deb.debian.org/debian-security trixie-security InRelease
    Get:5 https://dl.evcc.io/public/evcc/stable/deb/debian trixie InRelease
    Get:6 https://dl.evcc.io/public/evcc/stable/deb/debian bookworm InRelease
    Hit:7 https://deb.nodesource.com/node_22.x nodistro InRelease
    Err:6 https://dl.evcc.io/public/evcc/stable/deb/debian bookworm InRelease
    Fetched 23.4 kB in 0s (71.0 kB/s)
    Reading package lists...
    Pending systemupdates: 10
    *** Listening Ports ***
    Netid State  Recv-Q Send-Q              Local Address:Port          Peer Address:PortProcess
    udp   UNCONN 0      0                         0.0.0.0:mdns               0.0.0.0:*    users:(("io.chromecast.0",pid=4395,fd=35))
    udp   UNCONN 0      0                         0.0.0.0:mdns               0.0.0.0:*    users:(("evcc",pid=1461,fd=22))
    udp   UNCONN 0      0                         0.0.0.0:mdns               0.0.0.0:*    users:(("evcc",pid=1461,fd=3))
    udp   UNCONN 0      0                         0.0.0.0:mdns               0.0.0.0:*    users:(("avahi-daemon",pid=708,fd=12))
    udp   UNCONN 0      0                         0.0.0.0:56744              0.0.0.0:*    users:(("avahi-daemon",pid=708,fd=14))
    udp   UNCONN 0      0                         0.0.0.0:coap               0.0.0.0:*    users:(("io.shelly.1",pid=4516,fd=36))
    udp   UNCONN 0      0                         0.0.0.0:1900               0.0.0.0:*    users:(("evcc",pid=1461,fd=26))
    udp   UNCONN 0      0                         0.0.0.0:1900               0.0.0.0:*    users:(("evcc",pid=1461,fd=25))
    udp   UNCONN 0      0                         0.0.0.0:1900               0.0.0.0:*    users:(("evcc",pid=1461,fd=24))
    udp   UNCONN 0      0                         0.0.0.0:sunrpc             0.0.0.0:*    users:(("rpcbind",pid=678,fd=5),("systemd",pid=1,fd=201))
    udp   UNCONN 0      0      [fe80::e65f:1ff:fea3:9269]:dhcpv6-client            *:*    users:(("NetworkManager",pid=804,fd=35))
    udp   UNCONN 0      0                               *:mdns                     *:*    users:(("evcc",pid=1461,fd=23))
    udp   UNCONN 0      0                               *:mdns                     *:*    users:(("evcc",pid=1461,fd=6))
    udp   UNCONN 0      0                               *:mdns                     *:*    users:(("avahi-daemon",pid=708,fd=13))
    udp   UNCONN 0      0                               *:56692                    *:*    users:(("avahi-daemon",pid=708,fd=15))
    udp   UNCONN 0      0                               *:sunrpc                   *:*    users:(("rpcbind",pid=678,fd=7),("systemd",pid=1,fd=203))
    tcp   LISTEN 0      511                     127.0.0.1:9000               0.0.0.0:*    users:(("iobroker.js-con",pid=4247,fd=29))
    tcp   LISTEN 0      511                     127.0.0.1:9001               0.0.0.0:*    users:(("iobroker.js-con",pid=4247,fd=23))
    tcp   LISTEN 0      4096                      0.0.0.0:sunrpc             0.0.0.0:*    users:(("rpcbind",pid=678,fd=4),("systemd",pid=1,fd=200))
    tcp   LISTEN 0      128                       0.0.0.0:ssh                0.0.0.0:*    users:(("sshd",pid=1290,fd=6))
    tcp   LISTEN 0      511                       0.0.0.0:8400               0.0.0.0:*    users:(("io.jarvis.0",pid=4646,fd=29))
    tcp   LISTEN 0      511                       0.0.0.0:1880               0.0.0.0:*    users:(("node-red",pid=4415,fd=23))
    tcp   LISTEN 0      511                       0.0.0.0:1882               0.0.0.0:*    users:(("io.shelly.0",pid=4504,fd=38))
    tcp   LISTEN 0      511                       0.0.0.0:1883               0.0.0.0:*    users:(("io.sonoff.0",pid=4533,fd=40))
    tcp   LISTEN 0      4096                            *:7070                     *:*    users:(("evcc",pid=1461,fd=12))
    tcp   LISTEN 0      4096                            *:4712                     *:*    users:(("evcc",pid=1461,fd=10))
    tcp   LISTEN 0      4096                            *:8887                     *:*    users:(("evcc",pid=1461,fd=9))
    tcp   LISTEN 0      4096                         [::]:sunrpc                [::]:*    users:(("rpcbind",pid=678,fd=6),("systemd",pid=1,fd=202))
    tcp   LISTEN 0      128                          [::]:ssh                   [::]:*    users:(("sshd",pid=1290,fd=7))
    tcp   LISTEN 0      511                             *:8087                     *:*    users:(("io.simple-api.0",pid=4684,fd=34))
    tcp   LISTEN 0      511                             *:tproxy                   *:*    users:(("io.admin.0",pid=4276,fd=36))
    tcp   LISTEN 0      511                             *:8082                     *:*    users:(("io.web.0",pid=4730,fd=35))
    2026-09-07 19:58:49.419  - debug: sonoff.0 (4533) process task: {"type":"addObject","id":"sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p1","data":{"_id":"sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p1","common":{"role":"value","read":true,"write":false,"type":"number","name":"DVES_3E7859 SENSOR.SML  Curr_p1"},"native":{},"type":"state"},"cbArg":0}
    2026-09-07 19:58:49.419  - debug: sonoff.0 (4533) Set state after task: sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p1
    2026-09-07 19:58:49.420  - debug: sonoff.0 (4533) stateChange sonoff.0.DVES_3E7859.SENSOR.SML.Total_Summe: {"val":18388,"ack":true,"ts":1788803929418,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1788801639298}
    2026-09-07 19:58:49.463  - debug: sonoff.0 (4533) process task: {"type":"addObject","id":"sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p2","data":{"_id":"sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p2","common":{"role":"value","read":true,"write":false,"type":"number","name":"DVES_3E7859 SENSOR.SML  Curr_p2"},"native":{},"type":"state"},"cbArg":0}
    2026-09-07 19:58:49.463  - debug: sonoff.0 (4533) Set state after task: sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p2
    2026-09-07 19:58:49.464  - debug: sonoff.0 (4533) stateChange sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p1: {"val":0,"ack":true,"ts":1788803929462,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1721243462981}
    2026-09-07 19:58:49.507  - debug: sonoff.0 (4533) process task: {"type":"addObject","id":"sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p3","data":{"_id":"sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p3","common":{"role":"value","read":true,"write":false,"type":"number","name":"DVES_3E7859 SENSOR.SML  Curr_p3"},"native":{},"type":"state"},"cbArg":0}
    2026-09-07 19:58:49.507  - debug: sonoff.0 (4533) Set state after task: sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p3
    2026-09-07 19:58:49.508  - debug: sonoff.0 (4533) stateChange sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p2: {"val":0,"ack":true,"ts":1788803929506,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1721243463081}
    2026-09-07 19:58:49.551  - debug: sonoff.0 (4533) process task: {"type":"addObject","id":"sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p1","data":{"_id":"sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p1","common":{"role":"value","read":true,"write":false,"type":"number","name":"DVES_3E7859 SENSOR.SML  Volt_p1"},"native":{},"type":"state"},"cbArg":0}
    2026-09-07 19:58:49.551  - debug: sonoff.0 (4533) Set state after task: sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p1
    2026-09-07 19:58:49.552  - debug: sonoff.0 (4533) stateChange sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p3: {"val":0,"ack":true,"ts":1788803929550,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1721243463181}
    2026-09-07 19:58:49.599  - debug: sonoff.0 (4533) process task: {"type":"addObject","id":"sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p2","data":{"_id":"sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p2","common":{"role":"value","read":true,"write":false,"type":"number","name":"DVES_3E7859 SENSOR.SML  Volt_p2"},"native":{},"type":"state"},"cbArg":0}
    2026-09-07 19:58:49.599  - debug: sonoff.0 (4533) Set state after task: sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p2
    2026-09-07 19:58:49.600  - debug: sonoff.0 (4533) stateChange sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p1: {"val":0,"ack":true,"ts":1788803929598,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1721243463273}
    2026-09-07 19:58:49.643  - debug: sonoff.0 (4533) process task: {"type":"addObject","id":"sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p3","data":{"_id":"sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p3","common":{"role":"value","read":true,"write":false,"type":"number","name":"DVES_3E7859 SENSOR.SML  Volt_p3"},"native":{},"type":"state"},"cbArg":0}
    2026-09-07 19:58:49.643  - debug: sonoff.0 (4533) Set state after task: sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p3
    2026-09-07 19:58:49.644  - debug: sonoff.0 (4533) stateChange sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p2: {"val":0,"ack":true,"ts":1788803929642,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1721243463333}
    2026-09-07 19:58:49.688  - debug: sonoff.0 (4533) stateChange sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p3: {"val":0,"ack":true,"ts":1788803929686,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1721243463393}
    2026-09-07 19:58:50.061  - info: shelly.0 (4504) [authEnabled] 192.168.178.40 (shellyplusplugs / shellyplusplugs-b48a0a1cc8cc / shellyplusplugs#b48a0a1cc8cc#1): This device is not protected via restricted login (see adapter documentation for details)
    2026-09-07 19:58:51.122  - info: shelly.0 (4504) [authEnabled] 192.168.178.57 (shellyplus1 / shellyplus1-80646fd94da8 / shellyplus1#80646fd94da8#1): This device is not protected via restricted login (see adapter documentation for details)
    2026-09-07 19:58:51.459  - info: shelly.1 (4516) [authEnabled] 192.168.178.50 (shelly1 / shelly1-244CAB43CA38 / SHSW-1#244CAB43CA38#1): This device is not protected via restricted login (see adapter documentation for details)
    2026-09-07 19:58:51.883  - info: shelly.0 (4504) [authEnabled] 192.168.178.43 (shellyplus1 / shellyplus1-80646fd8df60 / shellyplus1#80646fd8df60#1): This device is not protected via restricted login (see adapter documentation for details)
    2026-09-07 19:58:52.072  - info: shelly.1 (4516) [authEnabled] 192.168.178.64 (shellyplug-s / shellyplug-s-3CE90ED7361F / SHPLG-S#3CE90ED7361F#1): This device is not protected via restricted login (see adapter documentation for details)
    2026-09-07 19:58:55.334  - info: shelly.0 (4504) [authEnabled] 192.168.178.81 (shellyplus1 / shellyplus1-7c87ce63d85c / shellyplus1#7c87ce63d85c#1): This device is not protected via restricted login (see adapter documentation for details)
    ============= Mark until here for C&P =============
    iob diag has finished.
    karl-heinz@meinbroker:~ $
    schrieb zuletzt editiert von Thomas Braun
    #81
    @Karl-Heinz1 sagte:
    Per direktem Aufruf oder über den Weg mit 'curl'?
    Schalt den Desktop-Krempel aus, wenn da nicht direkt ein Display dran hängt.
    Update die ganzen ioBroker-Adapter...
    Die Quelle zu evcc musst du richtig anlegen. Geht z. B. damit sauber:
    sudo apt install -y debian-keyring debian-archive-keyring apt-transport-https curl
    curl -1sLf 'https://dl.evcc.io/public/evcc/stable/setup.deb.sh' | sudo -E bash
    sudo apt update
    sudo apt install -y evcc
    Quelle: https://docs.evcc.io/de/installation/linux/
    Und wenn die evcc-Quelle sauber ist installierst du die 10 Updates des Betriebssystems...
    Immer regelmäßig und zeitnah updates einspielen!
    • K Offline
      Karl-Heinz1
      #82
      ich habe im Terminal "iob diag" eingegeben.
      Was bedeutet das ?
      Ich habe keinen Display am Raspi ich habe da nix geladen, sondern den iobroker lauf Doku installiert und die Datensicherung mit Backitup wieder eingespielt.
      soll ich jetzt als erstes alle Adapter updaten ?
      EVCC habe ich genauso installiert. https://docs.evcc.io/de/installation/linux/
      nach der Doku
      was ist damit unten, soll ich das so machen ?
      sudo apt update
      Und wo bekomme ich die 10 Updates des Betriebssystems her.
      Ich muss das auch morgen verschieben, habe vom langen sitzen Rückenschmerzen.
      • K Karl-Heinz1
        Was bedeutet das ?
        nach der Doku
        sudo apt update
        #83
        @Karl-Heinz1 sagte:
        Dann brauchst du auch kein graphical.target. Setzt das also auf multiuser.target, das ist die für den Serverbetrieb vorgesehen Stufe. Geht u.a. so:
        sudo systemctl set-default multi-user.target
        Nein, hast du nicht, sonst käme nämlich nicht diese Meldung um's Eck:
        Das ist die Anleitung, wie man die Quelle für evcc richtig anlegt.
        Wie immer über deinen Paketmanager. Aber dafür muss der erstmal sauber eingerichtet sein. Siehe Quelle für evcc...
        Dann halt
        sudo apt update
        sudo apt full-upgrade
