  4. iobroker startet nicht
    6.3k
32 Beiträge 4 Kommentatoren 733 Aufrufe 2 Beobachtet
    @IbizaGT wo kommt die uralte dfsg version her?
    I Offline
    I Offline
    IbizaGT
    @Homoran
    der pi läuft schon lange und ich habe da nichts groß gemacht. Jetzt wollte ich mal was neues dazu machen und da fällt alles auseinander...
    • I IbizaGT
      @Homoran
      @IbizaGT
      Das ist die Folge von "ich habe da nichts groß gemacht. "
      Das funktionier nämlich bekanntermaßen NICHT.
        @IbizaGT
        sudo apt-get install -y curl
        curl -fsSL https://deb.nodesource.com/setup_22.x | sudo -E bash -
        sudo apt-get install -y nodejs
        node -v
        I Offline
        I Offline
        IbizaGT
        @Thomas-Braun
        pi@raspberrypi:~ $ sudo apt-get install -y curl
        Reading package lists... Done
        Building dependency tree... Done
        curl is already the newest version (7.74.0-1.3+deb11u16).
        0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
        pi@raspberrypi:~ $ curl -fsSL https://deb.nodesource.com/setup_22.x | sudo -E bash -
        2026-06-20 10:33:18 - Installing pre-requisites
        Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        All packages are up to date.
        ca-certificates is already the newest version (20230311+deb12u1~deb11u1).
        gnupg is already the newest version (2.2.27-2+deb11u3).
        The following NEW packages will be installed:
          apt-transport-https
        0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
        Need to get 160 kB of archives.
        After this operation, 166 kB of additional disk space will be used.
        Get:1 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian bullseye/main armhf apt-transport-https all 2.2.4 [160 kB]
        Fetched 160 kB in 1s (288 kB/s)
        Selecting previously unselected package apt-transport-https.
        (Reading database ... 49127 files and directories currently installed.)
        Preparing to unpack .../apt-transport-https_2.2.4_all.deb ...
        Unpacking apt-transport-https (2.2.4) ...
        Setting up apt-transport-https (2.2.4) ...
        2026-06-20 10:33:27 - Error: Unsupported architecture: armhf. Only amd64, arm64 are supported. Contact Nodesource for an extended support version https://nodesource.com/pages/contact-us.html. (Exit Code: 1)
        pi@raspberrypi:~ $
        • I Offline
          I Offline
          IbizaGT
          trotz error weitermachen?
          • I IbizaGT
            @Thomas-Braun
              apt-transport-https
            pi@raspberrypi:~ $
            @IbizaGT sagte:
            pi@raspberrypi:~ $
            Das ist das Prpblem deiner alten Installation
            Nur noch 64bit versionen bei nodejs 22
            Möglich dass noch was älteres geht, wenn nodesource die noch im Repo hat
            • I IbizaGT
              @IbizaGT
              Da gibt es nix weiter zu machen. Das Ding ist dir weggegammelt.
              Aber da du ja 'nix groß gemacht hast' kannste es ja auch komplett von Grund auf Neuinstallieren:
              https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
              • I IbizaGT
                Script v.2026-06-01
                *** BASE SYSTEM ***
                Operating System: Raspbian GNU/Linux 11 (bullseye)
                   Static hostname: raspberrypi
                         Icon name: computer
                            Kernel: Linux 6.1.21-v8+
                      Architecture: arm64
                OS is similar to: debian
                Model           : Raspberry Pi 4 Model B Rev 1.1
                Docker          : false
                Virtualization  : none
                Kernel          : aarch64
                Userland        : 32bit
                System was installed 1693 days ago (on 2021-10-30).
                Outdated 32Bit architecture detected. Only a pure 64Bit-System will be supported in the future. You will have to reinstall your operating system with full 64Bit support or upgrade to more modern hardware soon.
                Systemuptime and Load:
                 10:09:08 up 1 min,  1 user,  load average: 0.37, 0.30, 0.12
                CPU threads     : 4
                *** LIFE CYCLE STATUS ***
                ERROR: Package 'distro-info' is not installed. Please do:
                sudo apt update && sudo apt install distro-info
                Alternatively execute the 'iob fix'
                pi@raspberrypi:~ $
                @IbizaGT sagte:
                Kann aber 64 bit, aber nur per Neuinstallation
                • I Offline
                  I Offline
                  IbizaGT
                  Gibt es irgeneine Chance das noch mal ans laufen zu bringen damit ich im iobroker ein Backup machen kann?
                  • I IbizaGT
                    @IbizaGT
                    Versuch mal
                    curl -fsSL https://deb.nodesource.com/setup_20.x | sudo -E bash -
                    node -v
                    I 1 Antwort Letzte Antwort
                      @IbizaGT
                      Versuch mal
                      node -v
                      I Offline
                      I Offline
                      IbizaGT
                      @Thomas-Braun
                      pi@raspberrypi:~ $ curl -fsSL https://deb.nodesource.com/setup_20.x | sudo -E bash -
                      2026-06-20 10:39:51 - Installing pre-requisites
                      Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                      Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                      apt-transport-https is already the newest version (2.2.4).
                      2026-06-20 10:39:57 - Error: Unsupported architecture: armhf. Only amd64, arm64 are supported. Contact Nodesource for an extended support version https://nodesource.com/pages/contact-us.html. (Exit Code: 1)
                      pi@raspberrypi:~ $
                      • I IbizaGT
                        @Thomas-Braun
                        pi@raspberrypi:~ $
                        @IbizaGT sagte:
                        Der Zug ist also abgefahren. Und aus dem Debian-Repo gibt es nur nodejs12. Das ist zu alt, das wird vermutlich nicht mal als Notkrücke laufen.
                        Also Neuinstallation. 64Bit-Lite-Version, Kiste dann künftig regelmäßiger pflegen.
                        • I Offline
                          I Offline
                          IbizaGT
                          Dann muss ich mich wohl mit dem Gedanken anfreunden....
                          Trotzdem Danke für die Unterstützung
                          @haselchen
