<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[iobroker startet nicht]]></title><description><![CDATA[<p dir="auto">Halle in die Runde,</p>
<p dir="auto">ich bin ratlos weil mein iobroker nicht mehr funktioniert.</p>
<p dir="auto">Kann mir jemand einen Tipp geben?</p>
<p dir="auto">Bin leider nicht so der Experte aber das Thema Smarthome finde ich total spannend.</p>
<pre><code>login as: pi
pi@192.168.2.46's password:
Linux raspberrypi 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Sat Jun 20 08:56:12 2026 from 192.168.2.20
pi@raspberrypi:~ $ iobroker status
sudo: node: command not found
pi@raspberrypi:~ $ iobroker fix
library: loaded
Library version=2026-04-11
    Welcome to the ioBroker installation fixer!
    Script version: 2025-09-18
    You might need to enter your password a couple of times.
    Installing prerequisites (1/5)
Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
Reading package lists... Done
E: Unable to locate package polkitd
Installed polkitd
readlink: missing operand
Try 'readlink --help' for more information.
Failed to set capabilities on file `' (No such file or directory)
The value of the capability argument is not permitted for a file. Or the file is not a regular (non-symlink) file
    Checking ioBroker user and directory permissions (2/5)
Created /etc/sudoers.d/iobroker
ACL enabled: true
    Check and cleanup npm temporary directories (3/5)
Done.
    Database maintenance (4/5)
Checking for uncompressed JSONL databases... This might take a while!
usage: sudo -h | -K | -k | -V
usage: sudo -v [-AknS] [-g group] [-h host] [-p prompt] [-u user]
usage: sudo -l [-AknS] [-g group] [-h host] [-p prompt] [-U user] [-u user]
            [command]
usage: sudo [-AbEHknPS] [-r role] [-t type] [-C num] [-D directory] [-g group]
            [-h host] [-p prompt] [-R directory] [-T timeout] [-u user]
            [VAR=value] [-i|-s] [&lt;command&gt;]
usage: sudo -e [-AknS] [-r role] [-t type] [-C num] [-D directory] [-g group]
            [-h host] [-p prompt] [-R directory] [-T timeout] [-u user] file ...
/home/iobroker/.fix.sh: line 14: [: -lt: unary operator expected
sudo: npm: command not found
    Checking autostart (5/5)
==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ===
Authentication is required to stop 'iobroker.service'.
Authenticating as: ,,, (pi)
Password: polkit-agent-helper-1: pam_authenticate failed: Authentication failure
Enabling autostart...
Autostart enabled!
pi@raspberrypi:~ $ ^C
pi@raspberrypi:~ $ iobroker start
pi@raspberrypi:~ $
</code></pre>
<p dir="auto"><strong>MOD-EDIT: Code in code-tags gesetzt!</strong></p>
]]></description><link>https://forum.iobroker.net/topic/84820/iobroker-startet-nicht</link><generator>RSS for Node</generator><lastBuildDate>Sat, 20 Jun 2026 12:40:30 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/84820.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 20 Jun 2026 07:49:33 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to iobroker startet nicht on Sat, 20 Jun 2026 08:47:28 GMT]]></title><description><![CDATA[<p dir="auto">Dann muss ich mich wohl mit dem Gedanken anfreunden....<br />
Trotzdem Danke für die Unterstützung<br />
<a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a><br />
<a class="plugin-mentions-user plugin-mentions-a" href="/user/homoran" aria-label="Profile: homoran">@<bdi>homoran</bdi></a><br />
<a class="plugin-mentions-user plugin-mentions-a" href="/user/haselchen" aria-label="Profile: haselchen">@<bdi>haselchen</bdi></a></p>
]]></description><link>https://forum.iobroker.net/post/1345373</link><guid isPermaLink="true">https://forum.iobroker.net/post/1345373</guid><dc:creator><![CDATA[IbizaGT]]></dc:creator><pubDate>Sat, 20 Jun 2026 08:47:28 GMT</pubDate></item><item><title><![CDATA[Reply to iobroker startet nicht on Sat, 20 Jun 2026 08:44:23 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ibizagt" aria-label="Profile: IbizaGT">@<bdi>IbizaGT</bdi></a> <a href="/post/1345369">sagte</a>:</p>
<p dir="auto">Error: Unsupported architecture: armhf.</p>
</blockquote>
<p dir="auto">Der Zug ist also abgefahren. Und aus dem Debian-Repo gibt es nur nodejs12. Das ist zu alt, das wird vermutlich nicht mal als Notkrücke laufen.<br />
Also Neuinstallation. 64Bit-Lite-Version, Kiste dann künftig regelmäßiger pflegen.</p>
]]></description><link>https://forum.iobroker.net/post/1345370</link><guid isPermaLink="true">https://forum.iobroker.net/post/1345370</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sat, 20 Jun 2026 08:44:23 GMT</pubDate></item><item><title><![CDATA[Reply to iobroker startet nicht on Sat, 20 Jun 2026 08:40:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: Thomas-Braun">@<bdi>Thomas-Braun</bdi></a></p>
<pre><code>pi@raspberrypi:~ $ curl -fsSL https://deb.nodesource.com/setup_20.x | sudo -E bash -
2026-06-20 10:39:51 - Installing pre-requisites
Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
Building dependency tree... Done
All packages are up to date.
apt-transport-https is already the newest version (2.2.4).
ca-certificates is already the newest version (20230311+deb12u1~deb11u1).
curl is already the newest version (7.74.0-1.3+deb11u16).
gnupg is already the newest version (2.2.27-2+deb11u3).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
2026-06-20 10:39:57 - Error: Unsupported architecture: armhf. Only amd64, arm64 are supported. Contact Nodesource for an extended support version https://nodesource.com/pages/contact-us.html. (Exit Code: 1)
pi@raspberrypi:~ $
</code></pre>
]]></description><link>https://forum.iobroker.net/post/1345369</link><guid isPermaLink="true">https://forum.iobroker.net/post/1345369</guid><dc:creator><![CDATA[IbizaGT]]></dc:creator><pubDate>Sat, 20 Jun 2026 08:40:33 GMT</pubDate></item><item><title><![CDATA[Reply to iobroker startet nicht on Sat, 20 Jun 2026 08:39:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ibizagt" aria-label="Profile: IbizaGT">@<bdi>IbizaGT</bdi></a></p>
<p dir="auto">Versuch mal</p>
<pre><code>curl -fsSL https://deb.nodesource.com/setup_20.x | sudo -E bash -
sudo apt-get install -y nodejs
node -v
</code></pre>
]]></description><link>https://forum.iobroker.net/post/1345368</link><guid isPermaLink="true">https://forum.iobroker.net/post/1345368</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sat, 20 Jun 2026 08:39:31 GMT</pubDate></item><item><title><![CDATA[Reply to iobroker startet nicht on Sat, 20 Jun 2026 08:38:52 GMT]]></title><description><![CDATA[<p dir="auto">Gibt es irgeneine Chance das noch mal ans laufen zu bringen damit ich im iobroker ein Backup machen kann?</p>
]]></description><link>https://forum.iobroker.net/post/1345367</link><guid isPermaLink="true">https://forum.iobroker.net/post/1345367</guid><dc:creator><![CDATA[IbizaGT]]></dc:creator><pubDate>Sat, 20 Jun 2026 08:38:52 GMT</pubDate></item><item><title><![CDATA[Reply to iobroker startet nicht on Sat, 20 Jun 2026 08:38:15 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ibizagt" aria-label="Profile: IbizaGT">@<bdi>IbizaGT</bdi></a> <a href="/post/1345343">sagte</a>:</p>
<p dir="auto">Model           : Raspberry Pi 4 Model B Rev 1.1</p>
</blockquote>
<p dir="auto">Kann aber 64 bit, aber nur per Neuinstallation</p>
]]></description><link>https://forum.iobroker.net/post/1345365</link><guid isPermaLink="true">https://forum.iobroker.net/post/1345365</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Sat, 20 Jun 2026 08:38:15 GMT</pubDate></item><item><title><![CDATA[Reply to iobroker startet nicht on Sat, 20 Jun 2026 08:37:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ibizagt" aria-label="Profile: IbizaGT">@<bdi>IbizaGT</bdi></a><br />
Da gibt es nix weiter zu machen. Das Ding ist dir weggegammelt.<br />
Aber da du ja 'nix groß gemacht hast' kannste es ja auch komplett von Grund auf Neuinstallieren:</p>
<p dir="auto"><a href="https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht">https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht</a></p>
]]></description><link>https://forum.iobroker.net/post/1345364</link><guid isPermaLink="true">https://forum.iobroker.net/post/1345364</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sat, 20 Jun 2026 08:37:28 GMT</pubDate></item><item><title><![CDATA[Reply to iobroker startet nicht on Sat, 20 Jun 2026 08:37:16 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ibizagt" aria-label="Profile: IbizaGT">@<bdi>IbizaGT</bdi></a> <a href="/post/1345361">sagte</a>:</p>
<p dir="auto">Unsupported architecture: armhf. Only amd64, arm64 are supported. Contact Nodesource for an extended support version <a href="https://nodesource.com/pages/contact-us.html" rel="nofollow ugc">https://nodesource.com/pages/contact-us.html</a>. (Exit Code: 1)<br />
pi@raspberrypi:~ $</p>
</blockquote>
<p dir="auto">Das ist das Prpblem deiner alten Installation<br />
Nur noch 64bit versionen bei nodejs 22</p>
<p dir="auto">Möglich dass noch was älteres geht, wenn nodesource die noch im Repo hat</p>
]]></description><link>https://forum.iobroker.net/post/1345363</link><guid isPermaLink="true">https://forum.iobroker.net/post/1345363</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Sat, 20 Jun 2026 08:37:16 GMT</pubDate></item><item><title><![CDATA[Reply to iobroker startet nicht on Sat, 20 Jun 2026 08:34:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a><br />
trotz error weitermachen?</p>
]]></description><link>https://forum.iobroker.net/post/1345362</link><guid isPermaLink="true">https://forum.iobroker.net/post/1345362</guid><dc:creator><![CDATA[IbizaGT]]></dc:creator><pubDate>Sat, 20 Jun 2026 08:34:52 GMT</pubDate></item><item><title><![CDATA[Reply to iobroker startet nicht on Sat, 20 Jun 2026 08:34:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: Thomas-Braun">@<bdi>Thomas-Braun</bdi></a></p>
<pre><code>
pi@raspberrypi:~ $ sudo apt-get install -y curl
pi@raspberrypi:~ $ curl -fsSL https://deb.nodesource.com/setup_22.x | sudo -E bash -
2026-06-20 10:33:18 - Installing pre-requisites
The following NEW packages will be installed:
  apt-transport-https
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 160 kB of archives.
After this operation, 166 kB of additional disk space will be used.
Get:1 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian bullseye/main armhf apt-transport-https all 2.2.4 [160 kB]
Fetched 160 kB in 1s (288 kB/s)
Selecting previously unselected package apt-transport-https.
(Reading database ... 49127 files and directories currently installed.)
Preparing to unpack .../apt-transport-https_2.2.4_all.deb ...
Unpacking apt-transport-https (2.2.4) ...
Setting up apt-transport-https (2.2.4) ...
2026-06-20 10:33:27 - Error: Unsupported architecture: armhf. Only amd64, arm64 are supported. Contact Nodesource for an extended support version https://nodesource.com/pages/contact-us.html. (Exit Code: 1)
pi@raspberrypi:~ $
</code></pre>
]]></description><link>https://forum.iobroker.net/post/1345361</link><guid isPermaLink="true">https://forum.iobroker.net/post/1345361</guid><dc:creator><![CDATA[IbizaGT]]></dc:creator><pubDate>Sat, 20 Jun 2026 08:34:23 GMT</pubDate></item><item><title><![CDATA[Reply to iobroker startet nicht on Sat, 20 Jun 2026 08:33:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ibizagt" aria-label="Profile: IbizaGT">@<bdi>IbizaGT</bdi></a></p>
<p dir="auto">Das ist die Folge von "ich habe da nichts groß gemacht. "<br />
Das funktionier nämlich bekanntermaßen NICHT.</p>
]]></description><link>https://forum.iobroker.net/post/1345360</link><guid isPermaLink="true">https://forum.iobroker.net/post/1345360</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sat, 20 Jun 2026 08:33:50 GMT</pubDate></item><item><title><![CDATA[Reply to iobroker startet nicht on Sat, 20 Jun 2026 08:32:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/homoran" aria-label="Profile: Homoran">@<bdi>Homoran</bdi></a><br />
der pi läuft schon lange und ich habe da nichts groß gemacht. Jetzt wollte ich mal was neues dazu machen und da fällt alles auseinander...</p>
]]></description><link>https://forum.iobroker.net/post/1345359</link><guid isPermaLink="true">https://forum.iobroker.net/post/1345359</guid><dc:creator><![CDATA[IbizaGT]]></dc:creator><pubDate>Sat, 20 Jun 2026 08:32:45 GMT</pubDate></item><item><title><![CDATA[Reply to iobroker startet nicht on Sat, 20 Jun 2026 08:32:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ibizagt" aria-label="Profile: IbizaGT">@<bdi>IbizaGT</bdi></a></p>
<pre><code>sudo apt-get install -y curl
node -v
</code></pre>
]]></description><link>https://forum.iobroker.net/post/1345358</link><guid isPermaLink="true">https://forum.iobroker.net/post/1345358</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sat, 20 Jun 2026 08:32:37 GMT</pubDate></item><item><title><![CDATA[Reply to iobroker startet nicht on Sat, 20 Jun 2026 08:29:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ibizagt" aria-label="Profile: IbizaGT">@<bdi>IbizaGT</bdi></a> wo kommt die uralte dfsg version her?</p>
]]></description><link>https://forum.iobroker.net/post/1345357</link><guid isPermaLink="true">https://forum.iobroker.net/post/1345357</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Sat, 20 Jun 2026 08:29:47 GMT</pubDate></item><item><title><![CDATA[Reply to iobroker startet nicht on Sat, 20 Jun 2026 08:29:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: Thomas-Braun">@<bdi>Thomas-Braun</bdi></a></p>
<pre><code>pi@raspberrypi:~ $ sudo apt update
pi@raspberrypi:~ $ apt policy nodejs
nodejs:
 Installed: (none)
 Candidate: 12.22.12~dfsg-1~deb11u8
 Version table:
    12.22.12~dfsg-1~deb11u8 500
       500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
pi@raspberrypi:~ $
</code></pre>
]]></description><link>https://forum.iobroker.net/post/1345355</link><guid isPermaLink="true">https://forum.iobroker.net/post/1345355</guid><dc:creator><![CDATA[IbizaGT]]></dc:creator><pubDate>Sat, 20 Jun 2026 08:29:00 GMT</pubDate></item><item><title><![CDATA[Reply to iobroker startet nicht on Sat, 20 Jun 2026 08:27:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ibizagt" aria-label="Profile: IbizaGT">@<bdi>IbizaGT</bdi></a><br />
Alles komplett veraltet und falsch installiert...</p>
<pre><code>sudo apt update &amp;&amp; apt policy nodejs
</code></pre>
<p dir="auto">sagt?</p>
]]></description><link>https://forum.iobroker.net/post/1345353</link><guid isPermaLink="true">https://forum.iobroker.net/post/1345353</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sat, 20 Jun 2026 08:27:27 GMT</pubDate></item><item><title><![CDATA[Reply to iobroker startet nicht on Sat, 20 Jun 2026 08:24:29 GMT]]></title><description><![CDATA[<pre><code>ioBroker nodejs fixer 2026-03-05
You requested to install latest version from nodejs v22 tree.
Your current setup is:
/home/iobroker/.nodejs-update.sh: line 214: node: command not found
/home/iobroker/.nodejs-update.sh: line 215: npm: command not found
/home/iobroker/.nodejs-update.sh: line 216: npx: command not found
/home/iobroker/.nodejs-update.sh: line 227: node: command not found
/home/iobroker/.nodejs-update.sh: line 228: npm: command not found
/home/iobroker/.nodejs-update.sh: line 229: npx: command not found
*** nodejs is NOT correctly installed ***
We found these nodejs versions available for installation:
nodejs:
  Installed: (none)
  Version table:
Your nodejs-Installation seems to be faulty. Shall we try to fix it?
Press &lt;y&gt; to continue or any other key to quit
Fixing your nodejs setup
*** Deleting  ***
*** Deleting  ***
*** Deleting  ***
Wrong paths have been fixed. Run 'iob diag' or 'iob nodejs-update' again to check if your installation is fine now
/home/iobroker/.nodejs-update.sh: line 317: node: command not found
You are missing the nodesource repo file or
you want to change your current nodejs version:  ?
Trying to fix your installation now. Please be patient.
You are running nodejs . Do you want to install latest version from nodejs v.22 tree?
rm: cannot remove '': No such file or directory
Stopping ioBroker now
ioBroker has been stopped
Removing any previously installed nodejs version
*** The following repos are active on your system:
*** Installing ca-certificates, curl and gnupg, just in case they are missing.
*** Creating new /etc/apt/sources.list.d/nodesource.sources and pinning source
/home/iobroker/.nodejs-update.sh: line 87: log: command not found
pi@raspberrypi:~ $
</code></pre>
]]></description><link>https://forum.iobroker.net/post/1345351</link><guid isPermaLink="true">https://forum.iobroker.net/post/1345351</guid><dc:creator><![CDATA[IbizaGT]]></dc:creator><pubDate>Sat, 20 Jun 2026 08:24:29 GMT</pubDate></item><item><title><![CDATA[Reply to iobroker startet nicht on Sat, 20 Jun 2026 08:21:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ibizagt" aria-label="Profile: IbizaGT">@<bdi>IbizaGT</bdi></a></p>
<pre><code>sudo apt autoremove
iob nodejs-update 22
</code></pre>
<p dir="auto">Rückfragen mit y bestätigen.</p>
<p dir="auto">Und bitte für Texte aus der Konsole die CodeTags &lt;/&gt; verwenden.</p>
]]></description><link>https://forum.iobroker.net/post/1345350</link><guid isPermaLink="true">https://forum.iobroker.net/post/1345350</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sat, 20 Jun 2026 08:21:14 GMT</pubDate></item><item><title><![CDATA[Reply to iobroker startet nicht on Sat, 20 Jun 2026 08:21:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: Thomas-Braun">@<bdi>Thomas-Braun</bdi></a></p>
pi@raspberrypi:~ $ sudo apt install distro-info
distro-info is already the newest version (1.0+deb11u1).
The following packages were automatically installed and are no longer required:
  gyp libauthen-sasl-perl libc-ares2 libclone-perl libdata-dump-perl
  libdrm-amdgpu1 libdrm-nouveau2 libdrm-radeon1 libencode-locale-perl
  libfile-basedir-perl libfile-desktopentry-perl libfile-listing-perl
  libfile-mimeinfo-perl libfont-afm-perl libfontenc1 libgl1 libgl1-mesa-dri
  libglapi-mesa libglvnd0 libglx-mesa0 libglx0 libhtml-form-perl
  libhtml-format-perl libhtml-parser-perl libhtml-tagset-perl
  libhtml-tree-perl libhttp-cookies-perl libhttp-daemon-perl libhttp-date-perl
  libhttp-message-perl libhttp-negotiate-perl libio-html-perl
  libio-socket-ssl-perl libio-stringy-perl libipc-system-simple-perl
  libjs-highlight.js libjs-inherits libjs-is-typedarray libjs-psl
  libjs-typedarray-to-buffer libllvm11 liblwp-mediatypes-perl
  liblwp-protocol-https-perl libmailtools-perl libnet-dbus-perl
  libnet-http-perl libnet-smtp-ssl-perl libnet-ssleay-perl libsensors-config
  libsensors5 libssl-dev libtie-ixhash-perl libtimedate-perl libtry-tiny-perl
  liburi-perl libuv1-dev libvulkan1 libwayland-client0 libwww-perl
  libwww-robotrules-perl libx11-protocol-perl libx11-xcb1 libxaw7
  libxcb-dri2-0 libxcb-dri3-0 libxcb-glx0 libxcb-present0 libxcb-randr0
  libxcb-shape0 libxcb-sync1 libxcb-xfixes0 libxcomposite1 libxcursor1
  libxdamage1 libxfixes3 libxi6 libxinerama1 libxkbfile1 libxml-parser-perl
  libxml-twig-perl libxml-xpathengine-perl libxmu6 libxrandr2 libxshmfence1
  libxt6 libxtst6 libxv1 libxxf86dga1 libxxf86vm1 libz3-4 mesa-vulkan-drivers
  perl-openssl-defaults x11-utils x11-xserver-utils xdg-utils
Use 'sudo apt autoremove' to remove them.
pi@raspberrypi:~ $
</code></pre>
]]></description><link>https://forum.iobroker.net/post/1345349</link><guid isPermaLink="true">https://forum.iobroker.net/post/1345349</guid><dc:creator><![CDATA[IbizaGT]]></dc:creator><pubDate>Sat, 20 Jun 2026 08:21:13 GMT</pubDate></item><item><title><![CDATA[Reply to iobroker startet nicht on Sat, 20 Jun 2026 08:15:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ibizagt" aria-label="Profile: IbizaGT">@<bdi>IbizaGT</bdi></a></p>
<pre><code>sudo apt update &amp;&amp; sudo apt install distro-info
</code></pre>
]]></description><link>https://forum.iobroker.net/post/1345348</link><guid isPermaLink="true">https://forum.iobroker.net/post/1345348</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sat, 20 Jun 2026 08:15:18 GMT</pubDate></item><item><title><![CDATA[Reply to iobroker startet nicht on Sat, 20 Jun 2026 08:14:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a><br />
ich wollte das mal alles auf aktuellen Stand bringen und wollte nodejs, npm aktualisieren aber dabei ist irgendwas schief gegangen und das Backup vorher habe ich vergessen.</p>
]]></description><link>https://forum.iobroker.net/post/1345347</link><guid isPermaLink="true">https://forum.iobroker.net/post/1345347</guid><dc:creator><![CDATA[IbizaGT]]></dc:creator><pubDate>Sat, 20 Jun 2026 08:14:38 GMT</pubDate></item><item><title><![CDATA[Reply to iobroker startet nicht on Sat, 20 Jun 2026 08:14:15 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Userland        : 32bit</p>
</blockquote>
<p dir="auto">Damit MUSST du das neuinstallieren. Diesmal dann in der 64Bit-Lite-Version.</p>
]]></description><link>https://forum.iobroker.net/post/1345346</link><guid isPermaLink="true">https://forum.iobroker.net/post/1345346</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sat, 20 Jun 2026 08:14:15 GMT</pubDate></item><item><title><![CDATA[Reply to iobroker startet nicht on Sat, 20 Jun 2026 08:12:12 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ibizagt" aria-label="Profile: IbizaGT">@<bdi>IbizaGT</bdi></a> <a href="/post/1345342">sagte</a>:</p>
<p dir="auto">das Backup habe ich leider nicht</p>
</blockquote>
<p dir="auto">Warum nicht????<br />
Wichtigstes Ding überhaupt.</p>
<pre><code>iob diag
</code></pre>
<p dir="auto">sagt nun? Dir fehlt nodejs, bzw war/ist das falsch installiert.</p>
]]></description><link>https://forum.iobroker.net/post/1345345</link><guid isPermaLink="true">https://forum.iobroker.net/post/1345345</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sat, 20 Jun 2026 08:12:12 GMT</pubDate></item><item><title><![CDATA[Reply to iobroker startet nicht on Sat, 20 Jun 2026 08:11:26 GMT]]></title><description><![CDATA[<p dir="auto">========== Start marking the full check here ===========</p>
<pre><code class="language-bash">Script v.2026-06-01
*** BASE SYSTEM ***
Operating System: Raspbian GNU/Linux 11 (bullseye)
   Static hostname: raspberrypi
         Icon name: computer
            Kernel: Linux 6.1.21-v8+
      Architecture: arm64
OS is similar to: debian
Docker          : false
Virtualization  : none
Kernel          : aarch64
Userland        : 32bit
System was installed 1693 days ago (on 2021-10-30).
Outdated 32Bit architecture detected. Only a pure 64Bit-System will be supported in the future. You will have to reinstall your operating system with full 64Bit support or upgrade to more modern hardware soon.
Systemuptime and Load:
 10:09:08 up 1 min,  1 user,  load average: 0.37, 0.30, 0.12
CPU threads     : 4
*** LIFE CYCLE STATUS ***
ERROR: Package 'distro-info' is not installed. Please do:
Alternatively execute the 'iob fix'
pi@raspberrypi:~ $</code></pre>
]]></description><link>https://forum.iobroker.net/post/1345343</link><guid isPermaLink="true">https://forum.iobroker.net/post/1345343</guid><dc:creator><![CDATA[IbizaGT]]></dc:creator><pubDate>Sat, 20 Jun 2026 08:11:26 GMT</pubDate></item></channel></rss>
